Why is my GPU "disabled"?
bmgomg
Post by bmgomg »
GPU info as it appears on my Folding@home screen:
GPU:0:2KBL GT2 [UHD GRAPHICS 620]
Re: Why is my GPU "disabled"?
Welcome to Folding@Home!
F@H supports AMD and Nvidia GPUs provided they support double precision (64 bit) floating point math and at least OpenCL 1.2
You have an Intel GPU. There is a beta team working on zero point Intel WUs, You could join that team. I assume that at least some Intel GPUs will be supported someday.
Just a beta test of Intel graphics, you can set client to the setting listed in the log, and if there are any of the benchmark WUs available it will be assigned. Membership on beta team not required at this point. Otherwise the Intel iGPUs are disabled and not used for folding at this time.
Just out of curiosity, which CPU is that iGP associated with?
Facts:
The Intel GPUs are relatively slow compared to the fully supported AMD and NV units but there will be projects developed for them once the benchmarking is complete.
Heat generated may be a limiting factor. How good is your CPU's cooling?
jchang6
Hardware configuration: Intel Xeon E3/E5, various generations from Westmere to Skylake. AMD Radeon RX5x00 and nVidia RTX 2080 Super.
Post by jchang6 »
I recently set GPU-beta for a system with 1) a Skylake CPU, UHD 620 , and 2) Comet Lake - UHD 630. The Skylake IGPU did about 10000 PPD, which is not worth the effort. The i10700 Comet Lake seemed to be doing 400K+ PPD. However, this system also has a RTX 3070. The CPU does about 150K PPD, the RTX 3070 seems to be about 3M PPD. With the iGPU enabled, the 3070 dropped to 1.7M PPD. I tried lowering the CPU threads to 10 (of 16 logical), even isolating these two 6 physical cores, leaving one physical CPU core to handle the FahCore_22 process for the 3070 and another for iGPU, no change. So its possible the new Intel iGPU at the 630 and later might be worthwhile in an iGPU only system, it does not seem to play well with nVidia
jchang6 wrote:The Skylake IGPU did about 10K PPD, which is not worth the effort. The i10700 Comet Lake seemed to be doing 400K+ PPD. However, this system also has a RTX 3070. The CPU does about 150K PPD, the RTX 3070 seems to be about 3M PPD. With the iGPU enabled, the 3070 dropped to 1.7M PPD. I tried lowering the CPU threads to 10 (of 16 logical), even isolating these two 6 physical cores, leaving one physical CPU core to handle the FahCore_22 process for the 3070 and another for iGPU, no change. So its possible the new Intel iGPU at the 630 and later might be worthwhile in an iGPU only system, it does not seem to play well with nVidia
Yes, the Intel GPUs are relatively weak performers, compared to discrete GPUs like nV or AMD. A system with no discrete GPUs can benefit when the iGPU can be enabled.
There is a reported client bug in systems with both an iGPU and a dGPU. I have no predicted ETA for a fix.
Once that bug is fixed, it's not clear who will choose to enable their iGPU.
Joe_Cava
Post by Joe_Cava »
Hey There,
I have a gen 10 intel cpu in a nuc. I'd like to activate the gpu to do some wu's. How do i go about doing this. Here is a paste of my log:
*********************** Log Started 2021-12-09T18:16:42Z ***********************
18:16:42:******************************* libFAH ********************************
18:16:42:           Date: Oct 20 2020
18:16:42:           Time: 13:36:55
18:16:42:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
18:16:42:         Branch: master
18:16:42:       Compiler: Visual C++ 2015
18:16:42:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:16:42:       Platform: win32 10
18:16:42:           Bits: 32
18:16:42:           Mode: Release
18:16:42:****************************** FAHClient ******************************
18:16:42:        Version: 7.6.21
18:16:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:16:42:      Copyright: 2020 foldingathome.org
18:16:42:       Homepage: https://foldingathome.org/
18:16:42:           Time: 13:41:04
18:16:42:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
18:16:42:           Bits: 32
18:16:42:           Args: --open-web-control
18:16:42:******************************** CBang ********************************
18:16:42:           Time: 11:36:18
18:16:42:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
18:16:42:           Bits: 32
18:16:42:******************************* System ********************************
18:16:42:            CPU: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
18:16:42:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
18:16:42:           CPUs: 8
18:16:42:         Memory: 15.79GiB
18:16:42:    Free Memory: 8.48GiB
18:16:42:        Threads: WINDOWS_THREADS
18:16:42:     OS Version: 6.2
18:16:42:    Has Battery: false
18:16:42:     On Battery: false
18:16:42:     UTC Offset: -8
18:16:42:            PID: 10588
18:16:42:            CWD: C:\ProgramData\FAHClient
18:16:42:  Win32 Service: false
18:16:42:             OS: Windows 10 Enterprise
18:16:42:        OS Arch: AMD64
18:16:42:           GPUs: 1
18:16:42:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 CML GT2 [UHD Graphics]
18:16:42:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:16:42:                 specified module could not be found.
18:16:42:
18:16:42:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:27.20
18:16:42:***********************************************************************
18:16:42:<config>
18:16:42:  <!-- Folding Slots -->
18:16:42:</config>
18:16:42:Trying to access database...
18:16:42:Successfully acquired database lock
18:16:42:FS00:Initialized folding slot 00: cpu:6
18:16:42:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 CML GT2 [UHD Graphics].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
18:16:42:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 CML GT2 [UHD Graphics].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
18:16:45:17:127.0.0.1:New Web session
18:17:01:Set client configured
18:17:02:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:17:02:WU00:FS00:Assigned to work server 128.252.203.11
18:17:02:WU00:FS00:Requesting new work unit for slot 00: cpu:6 from 128.252.203.11
18:17:02:WU00:FS00:Connecting to 128.252.203.11:8080
18:17:03:WU00:FS00:Downloading 8.34MiB
18:17:09:WU00:FS00:Download 78.70%
18:17:10:WU00:FS00:Download complete
18:17:10:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18206 run:14470 clone:0 gen:83 core:0xa8 unit:0x00000000000000530000471e00003886
18:17:10:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
18:17:10:WU00:FS00:Connecting to cores.foldingathome.org:80
18:17:11:WU00:FS00:FahCore a8: Downloading 7.72MiB
18:17:17:WU00:FS00:FahCore a8: 84.16%
18:17:18:WU00:FS00:FahCore a8: Download complete
18:17:18:WU00:FS00:Valid core signature
18:17:18:WU00:FS00:Unpacked 20.93MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
18:17:18:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
18:17:18:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
18:17:18:WU00:FS00:Starting
18:17:18:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10588 -checkpoint 15 -np 6
18:17:19:WU00:FS00:Started FahCore on PID 13132
18:17:19:WU00:FS00:Core PID:9928
18:17:19:WU00:FS00:FahCore 0xa8 started
18:17:20:WU00:FS00:0xa8:*********************** Log Started 2021-12-09T18:17:20Z ***********************
18:17:20:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
18:17:20:WU00:FS00:0xa8:       Core: Gromacs
18:17:20:WU00:FS00:0xa8:       Type: 0xa8
18:17:20:WU00:FS00:0xa8:    Version: 0.0.12
18:17:20:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:17:20:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
18:17:20:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
18:17:20:WU00:FS00:0xa8:       Date: Jan 16 2021
18:17:20:WU00:FS00:0xa8:       Time: 12:29:40
18:17:20:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
18:17:20:WU00:FS00:0xa8:     Branch: master
18:17:20:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
18:17:20:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:17:20:WU00:FS00:0xa8:   Platform: win32 10
18:17:20:WU00:FS00:0xa8:       Bits: 64
18:17:20:WU00:FS00:0xa8:       Mode: Release
18:17:20:WU00:FS00:0xa8:       SIMD: avx2_256
18:17:20:WU00:FS00:0xa8:     OpenMP: ON
18:17:20:WU00:FS00:0xa8:       CUDA: OFF
18:17:20:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13132 -checkpoint 15 -np
18:17:20:WU00:FS00:0xa8:             6
18:17:20:WU00:FS00:0xa8:************************************ libFAH ************************************
18:17:20:WU00:FS00:0xa8:       Time: 11:24:13
18:17:20:WU00:FS00:0xa8:************************************ CBang *************************************
18:17:20:WU00:FS00:0xa8:       Time: 11:23:53
18:17:20:WU00:FS00:0xa8:************************************ System ************************************
18:17:20:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
18:17:20:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
18:17:20:WU00:FS00:0xa8:       CPUs: 8
18:17:20:WU00:FS00:0xa8:     Memory: 15.79GiB
18:17:20:WU00:FS00:0xa8:Free Memory: 8.45GiB
18:17:20:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
18:17:20:WU00:FS00:0xa8: OS Version: 6.2
18:17:20:WU00:FS00:0xa8:Has Battery: false
18:17:20:WU00:FS00:0xa8: On Battery: false
18:17:20:WU00:FS00:0xa8: UTC Offset: -8
18:17:20:WU00:FS00:0xa8:        PID: 9928
18:17:20:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
18:17:20:WU00:FS00:0xa8:********************************************************************************
18:17:20:WU00:FS00:0xa8:Project: 18206 (Run 14470, Clone 0, Gen 83)
18:17:20:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
18:17:20:WU00:FS00:0xa8:Reading tar file core.xml
18:17:20:WU00:FS00:0xa8:Reading tar file frame83.tpr
18:17:20:WU00:FS00:0xa8:Digital signatures verified
18:17:20:WU00:FS00:0xa8:Calling: mdrun -c frame83.gro -s frame83.tpr -x frame83.xtc -cpt 15 -nt 6 -ntmpi 1
18:17:20:WU00:FS00:0xa8:Steps: first=10375000 total=10500000
18:17:23:WU00:FS00:0xa8:Completed 1 out of 125000 steps (0%)
18:17:43:Saving configuration to config.xml
18:17:43:<config>
18:17:43:  <!-- User Information -->
18:17:43:  <passkey v='*****'/>
18:17:43:  <team v='9317'/>
18:17:43:  <user v='Joe_Cava'/>
18:17:43:
18:17:43:  <!-- Folding Slots -->
18:17:43:  <slot id='0' type='CPU'/>
18:17:43:  <slot id='1' type='GPU'>
18:17:43:    <pci-bus v='0'/>
18:17:43:    <pci-slot v='2'/>
18:17:43:  </slot>
18:17:43:</config>
18:19:45:Saving configuration to config.xml
18:19:45:<config>
18:19:45:  <!-- Folding Slot Configuration -->
18:19:45:  <cause v='HIGH_PRIORITY'/>
18:19:45:
18:19:45:  <!-- User Information -->
18:19:45:  <passkey v='*****'/>
18:19:45:  <team v='9317'/>
18:19:45:  <user v='Joe_Cava'/>
18:19:45:
18:19:45:  <!-- Folding Slots -->
18:19:45:  <slot id='0' type='CPU'/>
18:19:45:  <slot id='1' type='GPU'>
18:19:45:    <pci-bus v='0'/>
18:19:45:    <pci-slot v='2'/>
18:19:45:  </slot>
18:19:45:</config>
18:20:13:FS00:Shutting core down
18:20:13:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 9928
18:20:13:WU00:FS00:0xa8:Exiting, please wait. . .
18:20:15:WU00:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
18:20:16:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:20:16:WU00:FS00:Starting
18:20:16:WARNING:WU00:FS00:Changed SMP threads from 6 to 4 this can cause some work units to fail
18:20:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10588 -checkpoint 15 -np 4
18:20:16:WU00:FS00:Started FahCore on PID 18604
18:20:16:WU00:FS00:Core PID:13876
18:20:16:WU00:FS00:FahCore 0xa8 started
18:20:16:WU00:FS00:0xa8:*********************** Log Started 2021-12-09T18:20:16Z ***********************
18:20:16:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
18:20:16:WU00:FS00:0xa8:       Core: Gromacs
18:20:16:WU00:FS00:0xa8:       Type: 0xa8
18:20:16:WU00:FS00:0xa8:    Version: 0.0.12
18:20:16:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:20:16:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
18:20:16:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
18:20:16:WU00:FS00:0xa8:       Date: Jan 16 2021
18:20:16:WU00:FS00:0xa8:       Time: 12:29:40
18:20:16:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
18:20:16:WU00:FS00:0xa8:     Branch: master
18:20:16:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
18:20:16:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:20:16:WU00:FS00:0xa8:   Platform: win32 10
18:20:16:WU00:FS00:0xa8:       Bits: 64
18:20:16:WU00:FS00:0xa8:       Mode: Release
18:20:16:WU00:FS00:0xa8:       SIMD: avx2_256
18:20:16:WU00:FS00:0xa8:     OpenMP: ON
18:20:16:WU00:FS00:0xa8:       CUDA: OFF
18:20:16:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 18604 -checkpoint 15 -np
18:20:16:WU00:FS00:0xa8:             4
18:20:16:WU00:FS00:0xa8:************************************ libFAH ************************************
18:20:16:WU00:FS00:0xa8:       Time: 11:24:13
18:20:16:WU00:FS00:0xa8:************************************ CBang *************************************
18:20:16:WU00:FS00:0xa8:       Time: 11:23:53
18:20:16:WU00:FS00:0xa8:************************************ System ************************************
18:20:16:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
18:20:16:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 12
18:20:16:WU00:FS00:0xa8:       CPUs: 8
18:20:16:WU00:FS00:0xa8:     Memory: 15.79GiB
18:20:16:WU00:FS00:0xa8:Free Memory: 8.47GiB
18:20:16:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
18:20:16:WU00:FS00:0xa8: OS Version: 6.2
18:20:16:WU00:FS00:0xa8:Has Battery: false
18:20:16:WU00:FS00:0xa8: On Battery: false
18:20:16:WU00:FS00:0xa8: UTC Offset: -8
18:20:16:WU00:FS00:0xa8:        PID: 13876
18:20:16:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
18:20:16:WU00:FS00:0xa8:********************************************************************************
18:20:16:WU00:FS00:0xa8:Project: 18206 (Run 14470, Clone 0, Gen 83)
18:20:16:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
18:20:16:WU00:FS00:0xa8:Digital signatures verified
18:20:16:WU00:FS00:0xa8:Calling: mdrun -c frame83.gro -s frame83.tpr -x frame83.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
18:20:16:WU00:FS00:0xa8:Steps: first=10375000 total=10500000
18:20:19:WU00:FS00:0xa8:Completed 1222 out of 125000 steps (0%)
18:20:23:WU00:FS00:0xa8:Completed 1250 out of 125000 steps (1%)
18:20:46:Saving configuration to config.xml
18:20:46:<config>
18:20:46:  <!-- Folding Slot Configuration -->
18:20:46:  <cause v='HIGH_PRIORITY'/>
18:20:46:
18:20:46:  <!-- Slot Control -->
18:20:46:  <power v='light'/>
18:20:46:
18:20:46:  <!-- User Information -->
18:20:46:  <passkey v='*****'/>
18:20:46:  <team v='9317'/>
18:20:46:  <user v='Joe_Cava'/>
18:20:46:
18:20:46:  <!-- Folding Slots -->
18:20:46:  <slot id='0' type='CPU'/>
18:20:46:  <slot id='1' type='GPU'>
18:20:46:    <pci-bus v='0'/>
18:20:46:    <pci-slot v='2'/>
18:20:46:  </slot>
18:20:46:</config>
18:23:31:WU00:FS00:0xa8:Completed 2500 out of 125000 steps (2%)
18:26:46:WU00:FS00:0xa8:Completed 3750 out of 125000 steps (3%)
18:27:43:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
18:28:54:Saving configuration to config.xml
18:28:54:<config>
18:28:54:  <!-- Folding Slot Configuration -->
18:28:54:  <cause v='HIGH_PRIORITY'/>
18:28:54:
18:28:54:  <!-- Network -->
18:28:54:  <proxy v=':8080'/>
18:28:54:
18:28:54:  <!-- Slot Control -->
18:28:54:  <power v='light'/>
18:28:54:
18:28:54:  <!-- User Information -->
18:28:54:  <passkey v='*****'/>
18:28:54:  <team v='9317'/>
18:28:54:  <user v='Joe_Cava'/>
18:28:54:
18:28:54:  <!-- Folding Slots -->
18:28:54:  <slot id='0' type='CPU'/>
18:28:54:  <slot id='1' type='GPU'>
18:28:54:    <pci-bus v='0'/>
18:28:54:    <pci-slot v='2'/>
18:28:54:  </slot>
18:28:54:</config>
18:29:57:WU00:FS00:0xa8:Completed 5000 out of 125000 steps (4%)
18:30:10:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
18:33:04:WU00:FS00:0xa8:Completed 6250 out of 125000 steps (5%)
18:36:10:WU00:FS00:0xa8:Completed 7500 out of 125000 steps (6%)
18:39:07:WU00:FS00:0xa8:Completed 8750 out of 125000 steps (7%)
18:42:16:WU00:FS00:0xa8:Completed 10000 out of 125000 steps (8%)
This is the newest driver I can find.
https://www.intel.com/content/www/us/en ... ivers.html
If F@H ever supports Intel graphics, it will need the newest drivers.
Joe_Cava
Post by Joe_Cava »
JimboPalmer wrote:This is the newest driver I can find.
I am running Windows 11 Pro and it has the latest drivers installed?
As mentioned in the log, currently Intel iGPUs are in a beta test status. There are limited numbers of WUs that will process on them, and these may run out at times. You do need to enable the GPU slot by adding the option mentioned in the log - gpu-beta set to true.
The good news is that your processor and its iGPU is not too recent. As best as I can find the UHD Graphics on your i5-10210U does support double precision calculations, Intel has removed that support from its newest iGPUs.
For drivers you will probably need to download them directly from Intel, the drivers installed through Windows update may only support use of the iGPU for video display, not calculations using OpenCL for the folding core.
Joe_Cava
Post by Joe_Cava »
Joe_H wrote:As mentioned in the log, currently Intel iGPUs are in a beta test status. There are limited numbers of WUs that will process on them, and these may run out at times. You do need to enable the GPU slot by adding the option mentioned in the log - gpu-beta set to true.
Forgive me, I'm not sure what I need to do to enable the gpu for folding. Is their instructions somewhere on how to enable this? I did download the latest video drivers from intel and i installed them. You were right, they weren't the full package nor the proper version.
Someone has posted full directions in the past, the general directions for advanced configuration are here - viewtopic.php?f=61&t=26036#p327411.
In this case, use FAHControl and its Configure button. Select Slots, click on the GPU slot to select it, and then click on Edit. Using Add to Extra Slot Options set the Option Name gpu-beta and set the Value to true. OK, and OK and Save to set the value and exit from Configure.
Joe_Cava
Post by Joe_Cava »
Joe_H wrote:Someone has posted full directions in the past, the general directions for advanced configuration are here - viewtopic.php?f=61&t=26036#p327411.
Ok I added the values.
For GPU 1 = I added gpu-beta=true and per the log it wanted opencl-index. Didn't specify a value so i selected 1. 0 didn't make a difference. Still shows "disabled."
Here is my updated log.
*********************** Log Started 2021-12-09T23:02:37Z ***********************
23:02:37:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 CML GT2 [UHD Graphics]. Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
23:02:37:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 CML GT2 [UHD Graphics]. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
Joe_Cava
Post by Joe_Cava »
I fixed it. Its now ready to work but nothing to download. At least its setup now. Thank you for the help!
There's currently no work available that is small enough for Intel iGPUs ... :(
