How to run multiple instances of Folding@Home?
PerfectFry
Post by PerfectFry »
I want to run multiple instances of the FAHClient.exe since I have multiple GPU's and want to fully configure each individually by assigning them to a separate instance. I will direct them both to the same wallet. Thank you in advance!
Re: How to run multiple instances of Folding@Home?
You do not want to run multiple instances of the executable, it already has built in the capability to run multiple GPUs. As for configuring for a wallet, follow the directions given by whichever team is supporting that cryptocurrency. F@h is not officially connected with, and does not provide support for that.
What F@h does have is giving points for completed WUs. For the most points you need to complete WUs quickly, have a passkey entered into the client, and maintain at least an 80% return rate. If you provide information about your setup, and if you already have installed the client the first 100-200 lines of the log, we can help you configure your system. Directions on locating and posting your log can be found in the Welcome topic - viewtopic.php?f=16&t=26036.
In the Advanced Control, in the Configure Button, in the Slots tab, are the controls for cpus and gpus. In general, you will have one cpu slot and a gpu slot per graphics card.
There are rare occasions where you might want more than one cpu slot, but lets ignore that.
Historically, the installer does a better job of finding new cards than the client does, so if everything is mixed up, uninstall including data and reinstall.
