NVidia 2060 stuck on Ready when booting into Kali Linux
derekhanks
Post by derekhanks »
For some reason, my GPU doesn't fold when booted into Kali Linux. It works fine when booted into windows and worked when I was running Fedora. Can you help me understand why?
*********************** Log Started 2021-05-02T19:18:19Z ***********************
19:18:19:******************************* libFAH ********************************
19:18:19:           Date: Oct 20 2020
19:18:19:           Time: 20:36:39
19:18:19:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
19:18:19:         Branch: master
19:18:19:       Compiler: GNU 8.3.0
19:18:19:        Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
19:18:19:                 -fdata-sections -O3 -funroll-loops -fno-pie
19:18:19:       Platform: linux2 5.8.0-1-amd64
19:18:19:           Bits: 64
19:18:19:           Mode: Release
19:18:19:****************************** FAHClient ******************************
19:18:19:        Version: 7.6.21
19:18:19:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:18:19:      Copyright: 2020 foldingathome.org
19:18:19:       Homepage: https://foldingathome.org/
19:18:19:           Time: 20:39:00
19:18:19:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
19:18:19:           Bits: 64
19:18:19:           Args: --child /etc/fahclient/config.xml --run-as fahclient
19:18:19:                 --pid-file=/var/run/fahclient.pid --daemon
19:18:19:         Config: /etc/fahclient/config.xml
19:18:19:******************************** CBang ********************************
19:18:19:           Time: 18:37:59
19:18:19:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
19:18:19:                 -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
19:18:19:           Bits: 64
19:18:19:******************************* System ********************************
19:18:19:            CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
19:18:19:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
19:18:19:           CPUs: 12
19:18:19:         Memory: 31.03GiB
19:18:19:    Free Memory: 29.66GiB
19:18:19:        Threads: POSIX_THREADS
19:18:19:     OS Version: 5.10
19:18:19:    Has Battery: true
19:18:19:     On Battery: false
19:18:19:     UTC Offset: -6
19:18:19:            PID: 1649
19:18:19:            CWD: /var/lib/fahclient
19:18:19:             OS: Linux 5.10.0-kali7-amd64 x86_64
19:18:19:        OS Arch: AMD64
19:18:19:           GPUs: 2
19:18:19:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 CFL GT2 [UHD Graphics 630]
19:18:19:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106M [GeForce RTX 2060 Mobile]
19:18:19:                 4608
19:18:19:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.2
19:18:19:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:460.73
19:18:19:***********************************************************************
19:18:19:<config>
19:18:19:  <!-- Client Control -->
19:18:19:  <fold-anon v='true'/>
19:18:19:
19:18:19:  <!-- Slot Control -->
19:18:19:  <power v='MEDIUM'/>
19:18:19:
19:18:19:  <!-- User Information -->
19:18:19:  <passkey v='*****'/>
19:18:19:  <team v='182116'/>
19:18:19:  <user v='Derek_Hanks'/>
19:18:19:
19:18:19:  <!-- Folding Slots -->
19:18:19:  <slot id='0' type='CPU'/>
19:18:19:  <slot id='1' type='GPU'>
19:18:19:    <pci-bus v='0'/>
19:18:19:    <pci-slot v='2'/>
19:18:19:  </slot>
19:18:19:  <slot id='2' type='GPU'>
19:18:19:    <pci-bus v='1'/>
19:18:19:    <pci-slot v='0'/>
19:18:19:  </slot>
19:18:19:</config>
19:18:19:Trying to access database...
19:18:19:Successfully acquired database lock
19:18:19:FS00:Initialized folding slot 00: cpu:9
19:18:19:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 CFL GT2 [UHD Graphics 630].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
19:18:19:FS02:Initialized folding slot 02: gpu:1:0 TU106M [GeForce RTX 2060 Mobile] 4608
19:18:19:WU01:FS02:Starting
19:18:19:WU01:FS02:Removing old file 'work/01/logfile_01-20210502-150859.txt'
19:18:19:WU01:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1649 -checkpoint 15 -opencl-platform 0 -open
cl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
19:18:19:WU01:FS02:Started FahCore on PID 1671
19:18:19:WU01:FS02:Core PID:1675
19:18:19:WU01:FS02:FahCore 0x22 started
19:18:19:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:18:19:WU01:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
19:18:19:WU01:FS02:Started FahCore on PID 1683
19:18:19:WU01:FS02:Core PID:1687
19:18:20:WU01:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
19:18:20:WU00:FS00:Assigned to work server 206.223.170.146
19:18:20:WU00:FS00:Requesting new work unit for slot 00: cpu:9 from 206.223.170.146
19:18:20:WU00:FS00:Connecting to 206.223.170.146:8080
19:18:22:WU00:FS00:Downloading 31.14MiB
19:18:28:WU00:FS00:Download 69.03%
19:18:32:WU00:FS00:Download complete
19:18:33:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17231 run:3846 clone:3 gen:83 core:0xa7 unit:0x00000003000000530000434f00000f06
19:18:33:WU00:FS00:Starting
19:18:33:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 1649 -checkpoint 15 -np 9
19:18:33:WU00:FS00:Started FahCore on PID 1696
19:18:33:WU00:FS00:Core PID:1700
19:18:33:WU00:FS00:FahCore 0xa7 started
Re: NVidia 2060 stuck on Ready when booting into Kali Linux
I can't tell for sure, but it's probably that you need to activate the proprietary driver that can be obtained from nvidia.com. I managed to find the right drivers ported for Ubuntu. There are several choices of non- proprietary Linux drivers that do not talk properly to CUDA and do not include OpenCL.
Does GPU-Z have checkmarks saying those drivers are supported? (And, yes, it doesn't exist. https://www.techpowerup.com/forums/thre ... ux.188470/ Is there another way?)
