AMD GPU disabled?
Stonehammers
AMD GPU disabled?
Post by Stonehammers »
I'm having trouble getting my GPU to work, it just says disabled. The CPU works, but I would like to get the GPU working too.
Now for the useful info (alien language):
*********************** Log Started 2021-05-01T19:17:19Z ***********************
19:17:19:******************************* libFAH ********************************
19:17:19:         Date: Oct 20 2020
19:17:19:         Time: 13:36:55
19:17:19:     Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
19:17:19:       Branch: master
19:17:19:     Compiler: Visual C++ 2015
19:17:19:      Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:17:19:     Platform: win32 10
19:17:19:         Bits: 32
19:17:19:         Mode: Release
19:17:19:****************************** FAHClient ******************************
19:17:19:      Version: 7.6.21
19:17:19:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:17:19:    Copyright: 2020 foldingathome.org
19:17:19:     Homepage: https://foldingathome.org/
19:17:19:         Time: 13:41:04
19:17:19:     Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
19:17:19:         Bits: 32
19:17:19:         Args: --open-web-control
19:17:19:******************************** CBang ********************************
19:17:19:         Time: 11:36:18
19:17:19:     Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
19:17:19:         Bits: 32
19:17:19:******************************* System ********************************
19:17:19:          CPU: AMD FX(tm)-8350 Eight-Core Processor
19:17:19:       CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
19:17:19:         CPUs: 8
19:17:19:       Memory: 31.97GiB
19:17:19:  Free Memory: 22.47GiB
19:17:19:      Threads: WINDOWS_THREADS
19:17:19:   OS Version: 6.2
19:17:19:  Has Battery: false
19:17:19:   On Battery: false
19:17:19:   UTC Offset: -5
19:17:19:          PID: 10920
19:17:19:          CWD: F:\ProgramData\FAHClient
19:17:19:Win32 Service: false
19:17:19:           OS: Windows 10 Home
19:17:19:      OS Arch: AMD64
19:17:19:         GPUs: 1
19:17:19:        GPU 0: Bus:1 Slot:0 Func:0 AMD:2 Cayman XT [Radeon HD 6900 Series]
19:17:19:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
19:17:19:               specified module could not be found.
19:17:19:
19:17:19:***********************************************************************
19:17:19:<config>
19:17:19:  <!-- Folding Slots -->
19:17:19:</config>
19:17:19:Trying to access database...
19:17:19:Successfully acquired database lock
19:17:19:FS00:Initialized folding slot 00: cpu:6
19:17:19:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:1:0 Cayman XT [Radeon HD 6900 Series].  Disabling.
19:17:23:17:127.0.0.1:New Web session
19:18:20:Saving configuration to config.xml
19:18:20:<config>
19:18:20:  <!-- Folding Slots -->
19:18:20:  <slot id='0' type='CPU'/>
19:18:20:  <slot id='1' type='GPU'>
19:18:20:    <pci-bus v='1'/>
19:18:20:    <pci-slot v='0'/>
19:18:20:  </slot>
19:18:20:</config>
19:18:20:Set client configured
19:18:20:WU00:FS00:Connecting to assign1.foldingathome.org:80
19:18:21:WU00:FS00:Assigned to work server 129.32.209.205
19:18:21:WU00:FS00:Requesting new work unit for slot 00: cpu:6 from 129.32.209.205
19:18:21:WU00:FS00:Connecting to 129.32.209.205:8080
19:18:22:WU00:FS00:Downloading 1.47MiB
19:18:23:WU00:FS00:Download complete
19:18:23:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16959 run:37 clone:34 gen:33 core:0xa8 unit:0x00000022000000210000423f00000025
19:18:23:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah
19:18:23:WU00:FS00:Connecting to cores.foldingathome.org:80
19:18:24:WU00:FS00:FahCore a8: Downloading 7.72MiB
19:18:27:WU00:FS00:FahCore a8: Download complete
19:18:28:WU00:FS00:Valid core signature
19:18:29:WU00:FS00:Unpacked 21.01MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
19:18:29:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
19:18:29:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
19:18:29:WU00:FS00:Starting
19:18:29:WU00:FS00:Running FahCore: "F:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" F:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10920 -checkpoint 15 -np 6
19:18:30:WU00:FS00:Started FahCore on PID 6212
19:18:30:WU00:FS00:Core PID:19384
19:18:30:WU00:FS00:FahCore 0xa8 started
19:18:30:WU00:FS00:0xa8:*********************** Log Started 2021-05-01T19:18:30Z ***********************
19:18:30:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:18:30:WU00:FS00:0xa8:       Core: Gromacs
19:18:30:WU00:FS00:0xa8:       Type: 0xa8
19:18:30:WU00:FS00:0xa8:    Version: 0.0.12
19:18:30:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:18:30:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
19:18:30:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
19:18:30:WU00:FS00:0xa8:       Date: Jan 16 2021
19:18:30:WU00:FS00:0xa8:       Time: 11:56:07
19:18:30:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:18:30:WU00:FS00:0xa8:     Branch: master
19:18:30:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:18:30:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:18:30:WU00:FS00:0xa8:   Platform: win32 10
19:18:30:WU00:FS00:0xa8:       Bits: 64
19:18:30:WU00:FS00:0xa8:       Mode: Release
19:18:30:WU00:FS00:0xa8:       SIMD: avx_256
19:18:30:WU00:FS00:0xa8:     OpenMP: ON
19:18:30:WU00:FS00:0xa8:       CUDA: OFF
19:18:31:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6212 -checkpoint 15 -np 6
19:18:31:WU00:FS00:0xa8:************************************ libFAH ************************************
19:18:31:WU00:FS00:0xa8:       Date: Jan 16 2021
19:18:31:WU00:FS00:0xa8:       Time: 11:24:13
19:18:31:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:18:31:WU00:FS00:0xa8:     Branch: master
19:18:31:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:18:31:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:18:31:WU00:FS00:0xa8:   Platform: win32 10
19:18:31:WU00:FS00:0xa8:       Bits: 64
19:18:31:WU00:FS00:0xa8:       Mode: Release
19:18:31:WU00:FS00:0xa8:************************************ CBang *************************************
19:18:31:WU00:FS00:0xa8:       Time: 11:23:53
19:18:31:WU00:FS00:0xa8:************************************ System ************************************
19:18:31:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
19:18:31:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
19:18:31:WU00:FS00:0xa8:       CPUs: 8
19:18:31:WU00:FS00:0xa8:     Memory: 31.97GiB
19:18:31:WU00:FS00:0xa8:Free Memory: 22.37GiB
19:18:31:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
19:18:31:WU00:FS00:0xa8: OS Version: 6.2
19:18:31:WU00:FS00:0xa8:Has Battery: false
19:18:31:WU00:FS00:0xa8: On Battery: false
19:18:31:WU00:FS00:0xa8: UTC Offset: -5
19:18:31:WU00:FS00:0xa8:        PID: 19384
19:18:31:WU00:FS00:0xa8:        CWD: F:\ProgramData\FAHClient\work
19:18:31:WU00:FS00:0xa8:********************************************************************************
19:18:31:WU00:FS00:0xa8:Project: 16959 (Run 37, Clone 34, Gen 33)
19:18:31:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
19:18:31:WU00:FS00:0xa8:Reading tar file core.xml
19:18:31:WU00:FS00:0xa8:Reading tar file frame33.tpr
19:18:31:WU00:FS00:0xa8:Digital signatures verified
19:18:31:WU00:FS00:0xa8:Calling: mdrun -c frame33.gro -s frame33.tpr -x frame33.xtc -cpt 15 -nt 6 -ntmpi 1
19:18:31:WU00:FS00:0xa8:Steps: first=82500000 total=85000000
19:18:31:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
19:26:28:Saving configuration to config.xml
19:26:28:<config>
19:26:28:  <!-- User Information -->
19:26:28:  <passkey v='*****'/>
19:26:28:  <team v='226715'/>
19:26:28:  <user v='AnonymousDFDQzdCrSkwWYzRhfTwz3QpbCiXF8vKeqk'/>
19:26:28:
19:26:28:  <!-- Folding Slots -->
19:26:28:  <slot id='0' type='CPU'/>
19:26:28:  <slot id='1' type='GPU'>
19:26:28:    <pci-bus v='1'/>
19:26:28:    <pci-slot v='0'/>
19:26:28:  </slot>
19:26:28:</config>
19:26:46:FS00:Shutting core down
19:26:46:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 19384
19:26:46:WU00:FS00:0xa8:Exiting, please wait. . .
19:26:49:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:26:49:WU00:FS00:Starting
19:26:49:WARNING:WU00:FS00:Changed SMP threads from 6 to 4 this can cause some work units to fail
19:26:49:WU00:FS00:Running FahCore: "F:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" F:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10920 -checkpoint 15 -np 4
19:26:49:WU00:FS00:Started FahCore on PID 16840
19:26:49:WU00:FS00:Core PID:14420
19:26:49:WU00:FS00:FahCore 0xa8 started
19:26:49:WU00:FS00:0xa8:*********************** Log Started 2021-05-01T19:26:49Z ***********************
19:26:49:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:26:49:WU00:FS00:0xa8:       Core: Gromacs
19:26:49:WU00:FS00:0xa8:       Type: 0xa8
19:26:49:WU00:FS00:0xa8:    Version: 0.0.12
19:26:49:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:26:49:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
19:26:49:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
19:26:49:WU00:FS00:0xa8:       Date: Jan 16 2021
19:26:49:WU00:FS00:0xa8:       Time: 11:56:07
19:26:49:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:26:49:WU00:FS00:0xa8:     Branch: master
19:26:49:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:26:49:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:26:49:WU00:FS00:0xa8:   Platform: win32 10
19:26:49:WU00:FS00:0xa8:       Bits: 64
19:26:49:WU00:FS00:0xa8:       Mode: Release
19:26:49:WU00:FS00:0xa8:       SIMD: avx_256
19:26:49:WU00:FS00:0xa8:     OpenMP: ON
19:26:49:WU00:FS00:0xa8:       CUDA: OFF
19:26:49:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 16840 -checkpoint 15 -np
19:26:49:WU00:FS00:0xa8:             4
19:26:49:WU00:FS00:0xa8:************************************ libFAH ************************************
19:26:49:WU00:FS00:0xa8:       Time: 11:24:13
19:26:50:WU00:FS00:0xa8:       Mode: Release
19:26:50:WU00:FS00:0xa8:************************************ CBang *************************************
19:26:50:WU00:FS00:0xa8:       Date: Jan 16 2021
19:26:50:WU00:FS00:0xa8:       Time: 11:23:53
19:26:50:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:26:50:WU00:FS00:0xa8:     Branch: master
19:26:50:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:26:50:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:26:50:WU00:FS00:0xa8:   Platform: win32 10
19:26:50:WU00:FS00:0xa8:       Bits: 64
19:26:50:WU00:FS00:0xa8:************************************ System ************************************
19:26:50:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
19:26:50:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
19:26:50:WU00:FS00:0xa8:       CPUs: 8
19:26:50:WU00:FS00:0xa8:     Memory: 31.97GiB
19:26:50:WU00:FS00:0xa8:Free Memory: 21.81GiB
19:26:50:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
19:26:50:WU00:FS00:0xa8: OS Version: 6.2
19:26:50:WU00:FS00:0xa8:Has Battery: false
19:26:50:WU00:FS00:0xa8: On Battery: false
19:26:50:WU00:FS00:0xa8: UTC Offset: -5
19:26:50:WU00:FS00:0xa8:        PID: 14420
19:26:50:WU00:FS00:0xa8:        CWD: F:\ProgramData\FAHClient\work
19:26:50:WU00:FS00:0xa8:********************************************************************************
19:26:50:WU00:FS00:0xa8:Project: 16959 (Run 37, Clone 34, Gen 33)
19:26:50:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
19:26:50:WU00:FS00:0xa8:Digital signatures verified
19:26:50:WU00:FS00:0xa8:Calling: mdrun -c frame33.gro -s frame33.tpr -x frame33.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
19:26:50:WU00:FS00:0xa8:Steps: first=82500000 total=85000000
19:26:50:WU00:FS00:0xa8:Completed 9252 out of 2500000 steps (0%)
19:27:29:Saving configuration to config.xml
19:27:29:<config>
19:27:29:  <!-- Slot Control -->
19:27:29:  <power v='LIGHT'/>
19:27:29:
19:27:29:  <!-- User Information -->
19:27:29:  <passkey v='*****'/>
19:27:29:  <team v='226715'/>
19:27:29:  <user v='DFDQzdCrSkwWYzRhfTwz3QpbCiXF8vKeqk'/>
19:27:29:
19:27:29:  <!-- Folding Slots -->
19:27:29:  <slot id='0' type='CPU'/>
19:27:29:  <slot id='1' type='GPU'>
19:27:29:    <pci-bus v='1'/>
19:27:29:    <pci-slot v='0'/>
19:27:29:  </slot>
19:27:29:</config>
19:31:52:48:127.0.0.1:New Web session
19:32:16:55:127.0.0.1:New Web session
19:39:45:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
19:40:31:FS00:Shutting core down
19:40:31:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 14420
19:40:31:WU00:FS00:0xa8:Exiting, please wait. . .
19:40:33:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:40:34:WU00:FS00:Starting
19:40:34:WARNING:WU00:FS00:Changed SMP threads from 4 to 7 this can cause some work units to fail
19:40:34:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
19:40:34:WU00:FS00:Running FahCore: "F:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" F:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10920 -checkpoint 15 -np 6
19:40:34:WU00:FS00:Started FahCore on PID 20024
19:40:34:WU00:FS00:Core PID:20744
19:40:34:WU00:FS00:FahCore 0xa8 started
19:40:34:WU00:FS00:0xa8:*********************** Log Started 2021-05-01T19:40:34Z ***********************
19:40:34:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:40:34:WU00:FS00:0xa8:       Core: Gromacs
19:40:34:WU00:FS00:0xa8:       Type: 0xa8
19:40:34:WU00:FS00:0xa8:    Version: 0.0.12
19:40:34:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:40:34:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
19:40:34:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
19:40:34:WU00:FS00:0xa8:       Date: Jan 16 2021
19:40:34:WU00:FS00:0xa8:       Time: 11:56:07
19:40:34:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:40:34:WU00:FS00:0xa8:     Branch: master
19:40:34:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:40:34:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:40:34:WU00:FS00:0xa8:   Platform: win32 10
19:40:34:WU00:FS00:0xa8:       Bits: 64
19:40:34:WU00:FS00:0xa8:       Mode: Release
19:40:34:WU00:FS00:0xa8:       SIMD: avx_256
19:40:34:WU00:FS00:0xa8:     OpenMP: ON
19:40:34:WU00:FS00:0xa8:       CUDA: OFF
19:40:34:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 20024 -checkpoint 15 -np
19:40:34:WU00:FS00:0xa8:             6
19:40:34:WU00:FS00:0xa8:************************************ libFAH ************************************
19:40:34:WU00:FS00:0xa8:       Time: 11:24:13
19:40:34:WU00:FS00:0xa8:************************************ CBang *************************************
19:40:34:WU00:FS00:0xa8:       Time: 11:23:53
19:40:34:WU00:FS00:0xa8:************************************ System ************************************
19:40:34:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
19:40:34:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
19:40:34:WU00:FS00:0xa8:       CPUs: 8
19:40:34:WU00:FS00:0xa8:     Memory: 31.97GiB
19:40:34:WU00:FS00:0xa8:Free Memory: 23.08GiB
19:40:34:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
19:40:34:WU00:FS00:0xa8: OS Version: 6.2
19:40:34:WU00:FS00:0xa8:Has Battery: false
19:40:34:WU00:FS00:0xa8: On Battery: false
19:40:34:WU00:FS00:0xa8: UTC Offset: -5
19:40:34:WU00:FS00:0xa8:        PID: 20744
19:40:34:WU00:FS00:0xa8:        CWD: F:\ProgramData\FAHClient\work
19:40:34:WU00:FS00:0xa8:********************************************************************************
19:40:34:WU00:FS00:0xa8:Project: 16959 (Run 37, Clone 34, Gen 33)
19:40:34:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
19:40:34:WU00:FS00:0xa8:Digital signatures verified
19:40:34:WU00:FS00:0xa8:Calling: mdrun -c frame33.gro -s frame33.tpr -x frame33.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
19:40:34:WU00:FS00:0xa8:Steps: first=82500000 total=85000000
19:40:35:WU00:FS00:0xa8:Completed 22402 out of 2500000 steps (0%)
19:40:42:Saving configuration to config.xml
19:40:42:<config>
19:40:42:  <!-- Slot Control -->
19:40:42:  <power v='FULL'/>
19:40:42:
19:40:42:  <!-- User Information -->
19:40:42:  <passkey v='*****'/>
19:40:42:  <team v='226715'/>
19:40:42:  <user v='DFDQzdCrSkwWYzRhfTwz3QpbCiXF8vKeqk'/>
19:40:42:
19:40:42:  <!-- Folding Slots -->
19:40:42:  <slot id='0' type='CPU'/>
19:40:42:  <slot id='1' type='GPU'>
19:40:42:    <pci-bus v='1'/>
19:40:42:    <pci-slot v='0'/>
19:40:42:  </slot>
19:40:42:</config>
19:41:25:FS00:Shutting core down
19:41:25:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 20744
19:41:25:WU00:FS00:0xa8:Exiting, please wait. . .
19:41:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:41:34:WU00:FS00:Starting
19:41:34:WARNING:WU00:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
19:41:34:WU00:FS00:Running FahCore: "F:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" F:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10920 -checkpoint 15 -np 6
19:41:34:WU00:FS00:Started FahCore on PID 16124
19:41:34:WU00:FS00:Core PID:22476
19:41:34:WU00:FS00:FahCore 0xa8 started
19:41:34:WU00:FS00:0xa8:*********************** Log Started 2021-05-01T19:41:34Z ***********************
19:41:34:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:41:34:WU00:FS00:0xa8:       Core: Gromacs
19:41:34:WU00:FS00:0xa8:       Type: 0xa8
19:41:34:WU00:FS00:0xa8:    Version: 0.0.12
19:41:34:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:41:34:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
19:41:34:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
19:41:34:WU00:FS00:0xa8:       Date: Jan 16 2021
19:41:34:WU00:FS00:0xa8:       Time: 11:56:07
19:41:34:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:41:34:WU00:FS00:0xa8:     Branch: master
19:41:34:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:41:34:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:41:34:WU00:FS00:0xa8:   Platform: win32 10
19:41:34:WU00:FS00:0xa8:       Bits: 64
19:41:34:WU00:FS00:0xa8:       Mode: Release
19:41:34:WU00:FS00:0xa8:       SIMD: avx_256
19:41:34:WU00:FS00:0xa8:     OpenMP: ON
19:41:34:WU00:FS00:0xa8:       CUDA: OFF
19:41:34:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 16124 -checkpoint 15 -np
19:41:34:WU00:FS00:0xa8:             6
19:41:34:WU00:FS00:0xa8:************************************ libFAH ************************************
19:41:35:WU00:FS00:0xa8:       Date: Jan 16 2021
19:41:35:WU00:FS00:0xa8:       Time: 11:24:13
19:41:35:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:41:35:WU00:FS00:0xa8:     Branch: master
19:41:35:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:41:35:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:41:35:WU00:FS00:0xa8:   Platform: win32 10
19:41:35:WU00:FS00:0xa8:       Bits: 64
19:41:35:WU00:FS00:0xa8:       Mode: Release
19:41:35:WU00:FS00:0xa8:************************************ CBang *************************************
19:41:35:WU00:FS00:0xa8:       Time: 11:23:53
19:41:35:WU00:FS00:0xa8:************************************ System ************************************
19:41:35:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
19:41:35:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
19:41:35:WU00:FS00:0xa8:       CPUs: 8
19:41:35:WU00:FS00:0xa8:     Memory: 31.97GiB
19:41:35:WU00:FS00:0xa8:Free Memory: 23.07GiB
19:41:35:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
19:41:35:WU00:FS00:0xa8: OS Version: 6.2
19:41:35:WU00:FS00:0xa8:Has Battery: false
19:41:35:WU00:FS00:0xa8: On Battery: false
19:41:35:WU00:FS00:0xa8: UTC Offset: -5
19:41:35:WU00:FS00:0xa8:        PID: 22476
19:41:35:WU00:FS00:0xa8:        CWD: F:\ProgramData\FAHClient\work
19:41:35:WU00:FS00:0xa8:********************************************************************************
19:41:35:WU00:FS00:0xa8:Project: 16959 (Run 37, Clone 34, Gen 33)
19:41:35:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
19:41:35:WU00:FS00:0xa8:Digital signatures verified
19:41:35:WU00:FS00:0xa8:Calling: mdrun -c frame33.gro -s frame33.tpr -x frame33.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
19:41:35:WU00:FS00:0xa8:Steps: first=82500000 total=85000000
19:41:35:WU00:FS00:0xa8:Completed 23702 out of 2500000 steps (0%)
19:41:43:Saving configuration to config.xml
19:41:43:<config>
19:41:43:  <!-- Slot Control -->
19:41:43:  <power v='MEDIUM'/>
19:41:43:
19:41:43:  <!-- User Information -->
19:41:43:  <passkey v='*****'/>
19:41:43:  <team v='226715'/>
19:41:43:  <user v='DFDQzdCrSkwWYzRhfTwz3QpbCiXF8vKeqk'/>
19:41:43:
19:41:43:  <!-- Folding Slots -->
19:41:43:  <slot id='0' type='CPU'/>
19:41:43:  <slot id='1' type='GPU'>
19:41:43:    <pci-bus v='1'/>
19:41:43:    <pci-slot v='0'/>
19:41:43:  </slot>
19:41:43:</config>
19:42:01:FS00:Shutting core down
19:42:01:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 22476
19:42:01:WU00:FS00:0xa8:Exiting, please wait. . .
19:42:03:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:42:34:WU00:FS00:Starting
19:42:34:WARNING:WU00:FS00:Changed SMP threads from 6 to 4 this can cause some work units to fail
19:42:34:WU00:FS00:Running FahCore: "F:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" F:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10920 -checkpoint 15 -np 4
19:42:34:WU00:FS00:Started FahCore on PID 5924
19:42:34:WU00:FS00:Core PID:19216
19:42:34:WU00:FS00:FahCore 0xa8 started
19:42:35:WU00:FS00:0xa8:*********************** Log Started 2021-05-01T19:42:34Z ***********************
19:42:35:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:42:35:WU00:FS00:0xa8:       Core: Gromacs
19:42:35:WU00:FS00:0xa8:       Type: 0xa8
19:42:35:WU00:FS00:0xa8:    Version: 0.0.12
19:42:35:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:42:35:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
19:42:35:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
19:42:35:WU00:FS00:0xa8:       Date: Jan 16 2021
19:42:35:WU00:FS00:0xa8:       Time: 11:56:07
19:42:35:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:42:35:WU00:FS00:0xa8:     Branch: master
19:42:35:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:42:35:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:42:35:WU00:FS00:0xa8:   Platform: win32 10
19:42:35:WU00:FS00:0xa8:       Bits: 64
19:42:35:WU00:FS00:0xa8:       Mode: Release
19:42:35:WU00:FS00:0xa8:       SIMD: avx_256
19:42:35:WU00:FS00:0xa8:     OpenMP: ON
19:42:35:WU00:FS00:0xa8:       CUDA: OFF
19:42:35:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5924 -checkpoint 15 -np 4
19:42:35:WU00:FS00:0xa8:************************************ libFAH ************************************
19:42:35:WU00:FS00:0xa8:       Time: 11:24:13
19:42:35:WU00:FS00:0xa8:************************************ CBang *************************************
19:42:35:WU00:FS00:0xa8:       Time: 11:23:53
19:42:35:WU00:FS00:0xa8:************************************ System ************************************
19:42:35:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
19:42:35:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
19:42:35:WU00:FS00:0xa8:       CPUs: 8
19:42:35:WU00:FS00:0xa8:     Memory: 31.97GiB
19:42:35:WU00:FS00:0xa8:Free Memory: 23.00GiB
19:42:35:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
19:42:35:WU00:FS00:0xa8: OS Version: 6.2
19:42:35:WU00:FS00:0xa8:Has Battery: false
19:42:35:WU00:FS00:0xa8: On Battery: false
19:42:35:WU00:FS00:0xa8: UTC Offset: -5
19:42:35:WU00:FS00:0xa8:        PID: 19216
19:42:35:WU00:FS00:0xa8:        CWD: F:\ProgramData\FAHClient\work
19:42:35:WU00:FS00:0xa8:********************************************************************************
19:42:35:WU00:FS00:0xa8:Project: 16959 (Run 37, Clone 34, Gen 33)
19:42:35:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
19:42:35:WU00:FS00:0xa8:Digital signatures verified
19:42:35:WU00:FS00:0xa8:Calling: mdrun -c frame33.gro -s frame33.tpr -x frame33.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
19:42:35:WU00:FS00:0xa8:Steps: first=82500000 total=85000000
19:42:35:WU00:FS00:0xa8:Completed 24402 out of 2500000 steps (0%)
19:42:44:Saving configuration to config.xml
19:42:44:<config>
19:42:44:  <!-- Slot Control -->
19:42:44:  <power v='LIGHT'/>
19:42:44:
19:42:44:  <!-- User Information -->
19:42:44:  <passkey v='*****'/>
19:42:44:  <team v='226715'/>
19:42:44:  <user v='DFDQzdCrSkwWYzRhfTwz3QpbCiXF8vKeqk'/>
19:42:44:
19:42:44:  <!-- Folding Slots -->
19:42:44:  <slot id='0' type='CPU'/>
19:42:44:  <slot id='1' type='GPU'>
19:42:44:    <pci-bus v='1'/>
19:42:44:    <pci-slot v='0'/>
19:42:44:  </slot>
19:42:44:</config>
19:43:06:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
20:05:46:WU00:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
20:29:01:WU00:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
20:51:46:WU00:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
21:13:51:WU00:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
21:35:59:WU00:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
21:45:47:88:127.0.0.1:New Web session
21:48:30:FS00:Paused
21:48:30:FS01:Paused
21:48:30:FS00:Shutting core down
21:48:30:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 19216
21:48:30:WU00:FS00:0xa8:Exiting, please wait. . .
21:48:33:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:48:48:Saving configuration to config.xml
21:48:48:<config>
21:48:48:  <!-- Slot Control -->
21:48:48:  <power v='LIGHT'/>
21:48:48:
21:48:48:  <!-- User Information -->
21:48:48:  <passkey v='*****'/>
21:48:48:  <team v='226715'/>
21:48:48:  <user v='DFDQzdCrSkwWYzRhfTwz3QpbCiXF8vKeqk'/>
21:48:48:
21:48:48:  <!-- Folding Slots -->
21:48:48:  <slot id='0' type='CPU'>
21:48:48:    <paused v='true'/>
21:48:48:  </slot>
21:48:48:  <slot id='1' type='GPU'>
21:48:48:    <pci-bus v='1'/>
21:48:48:    <pci-slot v='0'/>
21:48:48:  </slot>
21:48:48:</config>
22:19:42:97:127.0.0.1:New Web session
22:19:46:FS00:Unpaused
22:19:46:FS01:Unpaused
22:19:46:WU00:FS00:Starting
22:19:46:WU00:FS00:Running FahCore: "F:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" F:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10920 -checkpoint 15 -np 4
22:19:46:WU00:FS00:Started FahCore on PID 6968
22:19:46:WU00:FS00:Core PID:12688
22:19:46:WU00:FS00:FahCore 0xa8 started
22:19:47:WU00:FS00:0xa8:*********************** Log Started 2021-05-01T22:19:47Z ***********************
22:19:47:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
22:19:47:WU00:FS00:0xa8:       Core: Gromacs
22:19:47:WU00:FS00:0xa8:       Type: 0xa8
22:19:47:WU00:FS00:0xa8:    Version: 0.0.12
22:19:47:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:19:47:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
22:19:47:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
22:19:47:WU00:FS00:0xa8:       Date: Jan 16 2021
22:19:47:WU00:FS00:0xa8:       Time: 11:56:07
22:19:47:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
22:19:47:WU00:FS00:0xa8:     Branch: master
22:19:47:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
22:19:47:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:19:47:WU00:FS00:0xa8:   Platform: win32 10
22:19:47:WU00:FS00:0xa8:       Bits: 64
22:19:47:WU00:FS00:0xa8:       Mode: Release
22:19:47:WU00:FS00:0xa8:       SIMD: avx_256
22:19:47:WU00:FS00:0xa8:     OpenMP: ON
22:19:47:WU00:FS00:0xa8:       CUDA: OFF
22:19:47:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6968 -checkpoint 15 -np 4
22:19:47:WU00:FS00:0xa8:************************************ libFAH ************************************
22:19:47:WU00:FS00:0xa8:       Time: 11:24:13
22:19:47:WU00:FS00:0xa8:************************************ CBang *************************************
22:19:47:WU00:FS00:0xa8:       Time: 11:23:53
22:19:47:WU00:FS00:0xa8:************************************ System ************************************
22:19:47:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
22:19:47:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
22:19:47:WU00:FS00:0xa8:       CPUs: 8
22:19:47:WU00:FS00:0xa8:     Memory: 31.97GiB
22:19:47:WU00:FS00:0xa8:Free Memory: 23.41GiB
22:19:47:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
22:19:47:WU00:FS00:0xa8: OS Version: 6.2
22:19:47:WU00:FS00:0xa8:Has Battery: false
22:19:47:WU00:FS00:0xa8: On Battery: false
22:19:47:WU00:FS00:0xa8: UTC Offset: -5
22:19:47:WU00:FS00:0xa8:        PID: 12688
22:19:47:WU00:FS00:0xa8:        CWD: F:\ProgramData\FAHClient\work
22:19:47:WU00:FS00:0xa8:********************************************************************************
22:19:47:WU00:FS00:0xa8:Project: 16959 (Run 37, Clone 34, Gen 33)
22:19:47:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
22:19:47:WU00:FS00:0xa8:Digital signatures verified
22:19:47:WU00:FS00:0xa8:Calling: mdrun -c frame33.gro -s frame33.tpr -x frame33.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
22:19:47:WU00:FS00:0xa8:Steps: first=82500000 total=85000000
22:19:48:WU00:FS00:0xa8:Completed 163802 out of 2500000 steps (6%)
22:20:27:Saving configuration to config.xml
22:20:27:<config>
22:20:27:  <!-- Slot Control -->
22:20:27:  <power v='LIGHT'/>
22:20:27:
22:20:27:  <!-- User Information -->
22:20:27:  <passkey v='*****'/>
22:20:27:  <team v='226715'/>
22:20:27:  <user v='DFDQzdCrSkwWYzRhfTwz3QpbCiXF8vKeqk'/>
22:20:27:
22:20:27:  <!-- Folding Slots -->
22:20:27:  <slot id='0' type='CPU'/>
22:20:27:  <slot id='1' type='GPU'>
22:20:27:    <pci-bus v='1'/>
22:20:27:    <pci-slot v='0'/>
22:20:27:  </slot>
22:20:27:</config>
22:29:42:WU00:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
22:52:05:WU00:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
23:13:51:WU00:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
23:22:51:FS00:Shutting core down
23:22:51:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 12688
23:22:51:WU00:FS00:0xa8:Exiting, please wait. . .
23:22:55:WU00:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
23:22:55:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:22:55:WU00:FS00:Starting
23:22:55:WARNING:WU00:FS00:Changed SMP threads from 4 to 7 this can cause some work units to fail
23:22:55:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
23:22:55:WU00:FS00:Running FahCore: "F:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" F:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 10920 -checkpoint 15 -np 6
23:22:56:WU00:FS00:Started FahCore on PID 1816
23:22:56:WU00:FS00:Core PID:8564
23:22:56:WU00:FS00:FahCore 0xa8 started
23:22:56:WU00:FS00:0xa8:*********************** Log Started 2021-05-01T23:22:56Z ***********************
23:22:56:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
23:22:56:WU00:FS00:0xa8:       Core: Gromacs
23:22:56:WU00:FS00:0xa8:       Type: 0xa8
23:22:56:WU00:FS00:0xa8:    Version: 0.0.12
23:22:56:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:22:56:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
23:22:56:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
23:22:56:WU00:FS00:0xa8:       Date: Jan 16 2021
23:22:56:WU00:FS00:0xa8:       Time: 11:56:07
23:22:56:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
23:22:56:WU00:FS00:0xa8:     Branch: master
23:22:56:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
23:22:56:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:22:56:WU00:FS00:0xa8:   Platform: win32 10
23:22:56:WU00:FS00:0xa8:       Bits: 64
23:22:56:WU00:FS00:0xa8:       Mode: Release
23:22:56:WU00:FS00:0xa8:       SIMD: avx_256
23:22:56:WU00:FS00:0xa8:     OpenMP: ON
23:22:56:WU00:FS00:0xa8:       CUDA: OFF
23:22:56:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1816 -checkpoint 15 -np 6
23:22:56:WU00:FS00:0xa8:************************************ libFAH ************************************
23:22:56:WU00:FS00:0xa8:       Time: 11:24:13
23:22:56:WU00:FS00:0xa8:************************************ CBang *************************************
23:22:56:WU00:FS00:0xa8:       Time: 11:23:53
23:22:56:WU00:FS00:0xa8:************************************ System ************************************
23:22:56:WU00:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
23:22:56:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
23:22:56:WU00:FS00:0xa8:       CPUs: 8
23:22:56:WU00:FS00:0xa8:     Memory: 31.97GiB
23:22:56:WU00:FS00:0xa8:Free Memory: 22.54GiB
23:22:56:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
23:22:56:WU00:FS00:0xa8: OS Version: 6.2
23:22:56:WU00:FS00:0xa8:Has Battery: false
23:22:56:WU00:FS00:0xa8: On Battery: false
23:22:56:WU00:FS00:0xa8: UTC Offset: -5
23:22:56:WU00:FS00:0xa8:        PID: 8564
23:22:56:WU00:FS00:0xa8:        CWD: F:\ProgramData\FAHClient\work
23:22:56:WU00:FS00:0xa8:********************************************************************************
23:22:56:WU00:FS00:0xa8:Project: 16959 (Run 37, Clone 34, Gen 33)
23:22:56:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
23:22:56:WU00:FS00:0xa8:Digital signatures verified
23:22:56:WU00:FS00:0xa8:Calling: mdrun -c frame33.gro -s frame33.tpr -x frame33.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
23:22:56:WU00:FS00:0xa8:Steps: first=82500000 total=85000000
23:22:57:WU00:FS00:0xa8:Completed 235552 out of 2500000 steps (9%)
23:23:29:Saving configuration to config.xml
23:23:29:<config>
23:23:29:  <!-- Slot Control -->
23:23:29:  <power v='FULL'/>
23:23:29:
23:23:29:  <!-- User Information -->
23:23:29:  <passkey v='*****'/>
23:23:29:  <team v='226715'/>
23:23:29:  <user v='DFDQzdCrSkwWYzRhfTwz3QpbCiXF8vKeqk'/>
23:23:29:
23:23:29:  <!-- Folding Slots -->
23:23:29:  <slot id='0' type='CPU'/>
23:23:29:  <slot id='1' type='GPU'>
23:23:29:    <pci-bus v='1'/>
23:23:29:    <pci-slot v='0'/>
23:23:29:  </slot>
23:23:29:</config>
23:35:55:WU00:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
23:55:37:WU00:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
00:13:58:WU00:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
00:26:12:FS00:Finishing
00:26:12:FS01:Finishing
00:31:10:WU00:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
Re: AMD GPU disabled?
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/r ... -6970.c258
This is an 11 year old graphics card, think dog years.
AMD has not made a driver for this card since 2015, 15.7.1 WHQL
"the crimson driver doesn't work with OPEN CL but the WHQL driver does" - https://community.amd.com/t5/drivers-so ... m-p/313497
https://www.amd.com/en/support/graphics ... on-hd-6970
If you get it to work, expect it to finish Work Units before the deadlines. It may be 40% faster than a GT 1030.
JimboPalmer wrote:It may be 40% faster than a GT 1030.
That's a pretty lame comparison. :( NV reserves the GT prefix for their slowest cards.
bruce, all too often the folder is trying to get a card to fold that was entry level a decade ago, and if they get it to start folding it will never meet the deadlines.
This was a performance card a decade ago, if the OP finds the magic driver that supports this card and OpenCL 1.2, it would complete some WUs. The quest is not useless, just unlikely.
I used to fold on a Nvidia G 205, G is when it doesn't even come to GT standards, it had 16 shaders.
Agreed.
...and today's quest will be different tomorrow, but the quest is still worthwhile unless we're talking about a GPU that already needs to be retired by FAH. The quest for AMD is a bigger challenge than either for nV or for Intel. There are lots of nV options which might succeed; there are zero Intel; and for AMD, there are lots more driver options that might or might not work. :shock:
