Stats false on web
PhilTheNet
Stats false on web
Post by PhilTheNet »
The page https://client.foldingathome.org/ shows a completely wrong point total: 6,888,188 whereas the total is now 15,028,132
When I click on Stats the link is
https://stats.foldingathome.org/donor/PhilTheNet
which gives an empty page
whereas the link
https://stats.foldingathome.org/donor/239973
gives the right results
(same problem on all my Ubuntu OSX Windows machines)
Any ideas?
PaulTV
Re: Stats false on web
Post by PaulTV »
Hi,
Maybe it's passkey related. When you look at https://apps.foldingathome.org/bonus?user=PhilTheNet, you see one entry, with 736 WUs returned. Your stats page shows 1837 units though. Could it be that you haven't set the (same) passkey everywhere? My guess would be that WUs returned with a username but without passkey aren't listed on the bonus status page, meaning about 1100 were returned by clients that don't have the passkey set.
Paul
PhilTheNet
Indeed if I delete the passkey on a computer it gives the right total, the one that corresponds to the username
It is strange that the statistics do not link username and passkey....
Thks
gunnarre
Post by gunnarre »
The statistics site is being reworked at the moment. You might want to submit an issue here: https://github.com/FoldingCommunity/fah ... end/issues
PaulTV
Post by PaulTV »
You're probably already aware, but still: you'll only get quick return bonus (read: much more points) if you've set the passkey (and return more than 10 WUs, with 80% success rate, which you've exceeded by far).
With regards to the stats... The web control client most likely asks for the current points of the username/passkey combination. The API returns the total for the username with any or no passkey, if the passkey isn't given. The fact that the web control client doesn't give the proper link to the stats page is a known issue, already reported on github.
