VeridisQuo
Posts: 1 Joined: Wed Apr 28, 2021 5:04 pm
Post
by VeridisQuo » Wed Apr 28, 2021 5:58 pm
Hello,
I'd like to request a whitelisting for a device ID which doesn't seem to be in the GPUs.txt. As far as I see the graphic card 3060 RTX Mobile is supported by FAH.
Device ID : 10DE - 2560
fahclient --lspci
0x10de:0x2560:1:0:0:NVIDIA Corporation:NVIDIA GeForce RTX 3060 Laptop GPU
Thanks a lot !
Posts: 6559 Joined: Sun Dec 02, 2007 10:38 am
Post
by toTOW » Wed May 05, 2021 7:18 pm
I added it to the list of supported GPUs.
Delete your GPUs.txt file and restart the client.
elnovio
Posts: 4 Joined: Wed May 05, 2021 7:45 pm
Post
by elnovio » Wed May 05, 2021 7:52 pm
Hello,
thanks for the ultra fast addressing of this query. I have the same GPU but did not managed to activate it. Nvidia Driver 466.27 installed after all windows updates.
The GPUs.txt shows 0x10de:0x2520:2:7:GA106M [GeForce RTX 3060 Mobile / Max-Q]
My client shows
fahclient --lspci
Log Started 2021-05-05T19:31:35Z ***********************
19:31:35:WARNING:FS01:Disabling beta GPU slot 01: gpu:1:0. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
Thanks for looking into it and sorry if I was overseeing something as a Noob.
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Wed May 05, 2021 10:33 pm
@"elnovio"
The GA106M [GeForce RTX 3060 Mobile / Max-Q] is in the active version of GPUs.txt. Delete your local copy and restart FAHClient. Be sure you got the latest proprietary drivers -- directly from nVidia.
elnovio
Post
by elnovio » Thu May 06, 2021 3:10 pm
Thanks @bruce for your response, I am using nvidia studio 421 or game 466 with actual GPUs.txt, but the Warning because of beta GPU remains
@VeridisQuo is it working for you right now?
Post
by bruce » Thu May 06, 2021 4:22 pm
1) The device 0x10de:0x2560 is not the same as the device 0x10de:0x2520, no matter what name is associated with it. The drivers are important, too, but the message about "gpu-beta" is not related.
2) You cannot add an unsupported device to GPUs.txt because it's the master copy on the server that defined what is supported. (I or toTOW can correct the server's copy but we need you to give us the correct information. "lspci' only works if you have the actual GPU in your system.)
3) The man-readable text in [...] does not govern what is supported but it should inform you of the translation of those binary codes.
elnovio
Post
by elnovio » Thu May 06, 2021 4:59 pm
Ok, that is what lspci is giving me as information:
fahclient --lspci
Thanks for correcting the server´s copy. Do you need any further information about this GPU in my system?
Post
by bruce » Thu May 06, 2021 9:06 pm
The segment at the top of FAH's log showing it initializing would be helpful.
elnovio
Post
by elnovio » Thu May 06, 2021 9:38 pm
*********************** Log Started 2021-05-06T21:35:14Z ***********************
21:35:14:******************************* libFAH ********************************
21:35:14: Date: Oct 20 2020
21:35:14: Time: 13:36:55
21:35:14: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
21:35:14: Branch: master
21:35:14: Compiler: Visual C++ 2015
21:35:14: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
21:35:14: Platform: win32 10
21:35:14: Bits: 32
21:35:14: Mode: Release
21:35:14:****************************** FAHClient ******************************
21:35:14: Version: 7.6.21
21:35:14: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:35:14: Copyright: 2020 foldingathome.org
21:35:14: Homepage: https://foldingathome.org/
21:35:14: Time: 13:41:04
21:35:14: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
21:35:14: Bits: 32
21:35:14: Args: --open-web-control
21:35:14: Config: C:\ProgramData\FAHClient\config.xml
21:35:14:******************************** CBang ********************************
21:35:14: Time: 11:36:18
21:35:14: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
21:35:14: Bits: 32
21:35:14:******************************* System ********************************
21:35:14: CPU: AMD Ryzen 5 5600H with Radeon Graphics
21:35:14: CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
21:35:14: CPUs: 12
21:35:14: Memory: 15.87GiB
21:35:14: Free Memory: 13.32GiB
21:35:14: Threads: WINDOWS_THREADS
21:35:14: OS Version: 6.2
21:35:14: Has Battery: true
21:35:14: On Battery: false
21:35:14: UTC Offset: 2
21:35:14: PID: 9860
21:35:14: CWD: C:\ProgramData\FAHClient
21:35:14: Win32 Service: false
21:35:14: OS: Windows 10 Home
21:35:14: OS Arch: AMD64
21:35:14: GPUs: 1
21:35:14: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GA106M [GeForce RTX 3060 Laptop
21:35:14: GPU]
21:35:14: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:11.2
21:35:14:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:462.31
21:35:14:***********************************************************************
21:35:14:<config>
21:35:14: <!-- Network -->
21:35:14: <proxy v=':8080'/>
21:35:14:
21:35:14: <!-- Slot Control -->
21:35:14: <power v='full'/>
21:35:14:
21:35:14: <!-- User Information -->
21:35:14: <passkey v='*****'/>
21:35:14: <team v='234980'/>
21:35:14: <user v='7m2xk28ddr0y'/>
21:35:14:
21:35:14: <!-- Folding Slots -->
21:35:14: <slot id='0' type='GPU'>
21:35:14: <pci-bus v='1'/>
21:35:14: <pci-slot v='0'/>
21:35:14: </slot>
21:35:14:</config>
21:35:14:Trying to access database...
21:35:14:Successfully acquired database lock
21:35:14:FS00:Initialized folding slot 00: gpu:1:0 GA106M [GeForce RTX 3060 Laptop GPU]
21:35:14:WU00:FS00:Starting
21:35:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 9860 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:35:14:WU00:FS00:Started FahCore on PID 2200
21:35:14:WU00:FS00:Core PID:11292
21:35:14:WU00:FS00:FahCore 0x22 started
21:35:15:WU00:FS00:0x22:*********************** Log Started 2021-05-06T21:35:14Z ***********************
21:35:15:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
21:35:15:WU00:FS00:0x22: Core: Core22
21:35:15:WU00:FS00:0x22: Type: 0x22
21:35:15:WU00:FS00:0x22: Version: 0.0.13
21:35:15:WU00:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:35:15:WU00:FS00:0x22: Copyright: 2020 foldingathome.org
21:35:15:WU00:FS00:0x22: Homepage: https://foldingathome.org/
21:35:15:WU00:FS00:0x22: Date: Sep 19 2020
21:35:15:WU00:FS00:0x22: Time: 02:35:58
21:35:15:WU00:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
21:35:15:WU00:FS00:0x22: Branch: core22-0.0.13
21:35:15:WU00:FS00:0x22: Compiler: Visual C++ 2015
21:35:15:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
21:35:15:WU00:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
21:35:15:WU00:FS00:0x22: Platform: win32 10
21:35:15:WU00:FS00:0x22: Bits: 64
21:35:15:WU00:FS00:0x22: Mode: Release
21:35:15:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:35:15:WU00:FS00:0x22: <peastman@stanford.edu>
21:35:15:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 2200 -checkpoint 15
21:35:15:WU00:FS00:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:35:15:WU00:FS00:0x22: nvidia -gpu 0 -gpu-usage 100
21:35:15:WU00:FS00:0x22:************************************ libFAH ************************************
21:35:15:WU00:FS00:0x22: Date: Sep 7 2020
21:35:15:WU00:FS00:0x22: Time: 19:09:56
21:35:15:WU00:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
21:35:15:WU00:FS00:0x22: Branch: HEAD
21:35:15:WU00:FS00:0x22:************************************ CBang *************************************
21:35:15:WU00:FS00:0x22: Time: 19:08:30
21:35:15:WU00:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
21:35:15:WU00:FS00:0x22:************************************ System ************************************
21:35:15:WU00:FS00:0x22: CPU: AMD Ryzen 5 5600H with Radeon Graphics
21:35:15:WU00:FS00:0x22: CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
21:35:15:WU00:FS00:0x22: CPUs: 12
21:35:15:WU00:FS00:0x22: Memory: 15.87GiB
21:35:15:WU00:FS00:0x22:Free Memory: 13.30GiB
21:35:15:WU00:FS00:0x22: Threads: WINDOWS_THREADS
21:35:15:WU00:FS00:0x22: OS Version: 6.2
21:35:15:WU00:FS00:0x22:Has Battery: true
21:35:15:WU00:FS00:0x22: On Battery: false
21:35:15:WU00:FS00:0x22: UTC Offset: 2
21:35:15:WU00:FS00:0x22: PID: 11292
21:35:15:WU00:FS00:0x22: CWD: C:\ProgramData\FAHClient\work
21:35:15:WU00:FS00:0x22:************************************ OpenMM ************************************
21:35:15:WU00:FS00:0x22: Revision: 189320d0
21:35:15:WU00:FS00:0x22:********************************************************************************
21:35:15:WU00:FS00:0x22:Project: 17346 (Run 0, Clone 405, Gen 36)
21:35:15:WU00:FS00:0x22:Unit: 0x00000000000000000000000000000000
21:35:15:WU00:FS00:0x22:Digital signatures verified
21:35:15:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
21:35:15:WU00:FS00:0x22:Version 0.0.13
21:35:15:WU00:FS00:0x22: Checkpoint write interval: 15000 steps (2%) [50 total]
21:35:15:WU00:FS00:0x22: JSON viewer frame write interval: 7500 steps (1%) [100 total]
21:35:15:WU00:FS00:0x22: XTC frame write interval: 250000 steps (33%) [3 total]
21:35:15:WU00:FS00:0x22: Global context and integrator variables write interval: disabled
21:35:15:WU00:FS00:0x22:There are 4 platforms available.
21:35:15:WU00:FS00:0x22:Platform 0: Reference
21:35:15:WU00:FS00:0x22:Platform 1: CPU
21:35:15:WU00:FS00:0x22:Platform 2: OpenCL
21:35:15:WU00:FS00:0x22: opencl-device 0 specified
21:35:15:WU00:FS00:0x22:Platform 3: CUDA
21:35:15:WU00:FS00:0x22: cuda-device 0 specified
21:35:16:4:127.0.0.1:New Web session
21:35:27:WU00:FS00:0x22:Attempting to create CUDA context:
21:35:27:WU00:FS00:0x22: Configuring platform CUDA
21:35:32:WU00:FS00:0x22: Using CUDA and gpu 0
21:35:32:WU00:FS00:0x22:Completed 30000 out of 750000 steps (4%)
I think, now that GPUs.txt is updated by you, all is working well? Great help, thank you!
Posts: 2521 Joined: Mon Feb 16, 2009 4:12 am
Post
by JimboPalmer » Thu May 06, 2021 11:08 pm
Thanks for letting us know we helped
Post
by bruce » Fri May 07, 2021 4:44 pm
elnovio wrote: ... all is working well?
You need to tell US if all is working well!
