my computer has much more power in the gpu than in the cpu. Is it possible to choose a project that uses as much gpu as possible??
-GPU: 11741 to 11764
-CPU: 14328–14329–14530–14531
what project is this 11741 to 11764 ??
Gpu vs Cpu
Re: Gpu vs Cpu
Welcome to Folding@Home!
The researchers choose which GPUs (and CPUs) their project runs on. Some combinations produce bad or just slow results.
You are only given WUs that the researchers believe will work well. (They .are not always right)
You are discouraged from just running the 'low hanging fruit' projects you want.
There is a file on the servers called GPUs.txt (a copy is on your PC, but the server is the master) it lists the vendor and species (capabilities) of your card.
Very occasionally, a vendor will list multiple cards with the same name, so your GT 710 may not have the same capabilities as some one else's GT 710. This is rare.
Re: Gpu vs Cpu
Yes. When FAH is installed, it will create one slot for CPU folding and one slot for each GPU that can fold. You can enable or disable each of them. The GPU cannot be moderated. It will either fold a maximum or it will be disabled. Depending on the characteristics of your CPU, you have some ability to moderate the CPU processing.
Re: Gpu vs Cpu
Okey, maybe you can come up with a proposal if I tell you my specs.
Intel I7-4790k and nvidia 1080TI
There is a file on the servers called GPUs.txt (a copy is on your PC, but the server is the master) it lists the vendor and species (capabilities) of your card.........where is this on my computer??
Re: Gpu vs Cpu
I am not sure what OS you are running, (if you posted the first 200 lines of your log, we would know more about your PCs configuration.ullaen wrote:There is a file on the servers called GPUs.txt (a copy is on your PC, but the server is the master) it lists the vendor and species (capabilities) of your card.........where is this on my computer??
viewtopic.php?f=24&t=26036
I run Windows 10, but I updated from earlier versions so it may not be in the same place on your PC.
C:\Users\User\AppData\Roaming\FAHClient\GPUs.txt
As I understand it, it gets updated once a month. Mine is dated April 13, 2021
0x10de:0x1b06:2:8:GP102 [GeForce GTX 1080 Ti] 11380
So vendor = 2 Species = 8
AMD is vendor 1, Nvidia is vendor 2
Species 8 is the most capable Species for Nvidia. (AMD species are not related)
(My RTX 3060 is 2:8, but my GTX 1650 and GTX 1060 are 2:7, so they may get smaller, less complicated proteins)
GP102 the P stands for the Pascal micro architecture, chip 102 https://en.wikipedia.org/wiki/Pascal_(m ... ure)#Chips
Several cards all used the GP102 chip ( TITAN Xp, Titan X, GeForce GTX 1080 Ti, Quadro P6000 & Tesla P40)
The vast majority of CPUs are Intel compatible chips with 2 to 128 threads, so basically all your client needs to send to the server is how many threads it wants to use.
https://ark.intel.com/content/www/us/en ... 0-ghz.html
Your CPU has 8 threads, but will use one to support the GPU, so you may see 7 claimed in the client.
Your CPU supports the fastest Floating Point math that F@H uses: AVX2.
https://en.wikipedia.org/wiki/Advanced_ ... tensions_2
FMA3 allows a Multiply and an Add in the same step, for a 60% speed up compared to AVX, which would use two steps.
Re: Gpu vs Cpu
FAH chooses a default setting for the number of threads allocated to the CPU slot. It's up to you to adjust that setting if that's not the optimum for your system. (N-1) seems to be a good choice for NVidia GPUs. See viewtopic.php?f=111&t=36531&p=351065#p351065 for Intel GPUs.
