Low PPD on my GTX 970
wontonforevuh
Post by wontonforevuh »
Hi All,
I have been noticing that my PPD has dropped significantly since I started folding about a week ago with my GTX 970. I was getting roughly 200k points every 12 hours when I first started but that has dropped to 100-150k if not less recently:
https://www.monkey2monkey.com/fh-stats/?userid=aehtf0z6i3n1
I don't think I have touched any default settings except for removing the CPU slot. Is my PPD roughly in line with other 970s? Seems odd that my score would vary this much daily. Any helps is appreciated.
Thanks!
Re: Low PPD on my GTX 970
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/g ... -970.c2620
This hints that it should be 10% slower than a GTX 1060 6 GB, like mine, which gets 700,000 PPD.
If you post the first 200 lines of your log, folks can look for ways to optimize your setup
viewtopic.php?f=24&t=26036
Be sure you are using a passkey
https://test.foldingathome.org/support/ ... ?lng=en-US
wontonforevuh
JimboPalmer wrote:Welcome to Folding@Home!
Appreciate the help! I do have my passkey set up. My Advanced Control client says I should be getting about 500K PPD but I am only getting credited with about 250K PPD. Are some of my WUs failing? Not sure why there's such a big discrepancy between what the estimate is vs what I'm actually getting.
Hopefully i did this right:
*********************** Log Started 2021-04-20T23:57:13Z ***********************
23:57:13:******************************* libFAH ********************************
23:57:13:           Date: Oct 20 2020
23:57:13:           Time: 13:36:55
23:57:13:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
23:57:13:         Branch: master
23:57:13:       Compiler: Visual C++ 2015
23:57:13:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:57:13:       Platform: win32 10
23:57:13:           Bits: 32
23:57:13:           Mode: Release
23:57:13:****************************** FAHClient ******************************
23:57:13:        Version: 7.6.21
23:57:13:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:57:13:      Copyright: 2020 foldingathome.org
23:57:13:       Homepage: https://foldingathome.org/
23:57:13:           Time: 13:41:04
23:57:13:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
23:57:13:           Bits: 32
23:57:13:           Args: --open-web-control
23:57:13:******************************** CBang ********************************
23:57:13:           Time: 11:36:18
23:57:13:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
23:57:13:           Bits: 32
23:57:13:******************************* System ********************************
23:57:13:            CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
23:57:13:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:57:13:           CPUs: 4
23:57:13:         Memory: 15.96GiB
23:57:13:    Free Memory: 8.89GiB
23:57:13:        Threads: WINDOWS_THREADS
23:57:13:     OS Version: 6.2
23:57:13:    Has Battery: false
23:57:13:     On Battery: false
23:57:13:     UTC Offset: -5
23:57:13:            PID: 5204
23:57:13:            CWD: C:\ProgramData\FAHClient
23:57:13:  Win32 Service: false
23:57:13:             OS: Windows 10 Enterprise
23:57:13:        OS Arch: AMD64
23:57:13:           GPUs: 1
23:57:13:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:5 GM204 [GeForce GTX 970] 3494
23:57:13:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:5.2 Driver:11.2
23:57:13:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:460.79
23:57:13:***********************************************************************
23:57:13:<config>
23:57:13:  <!-- Folding Slots -->
23:57:13:</config>
23:57:13:Trying to access database...
23:57:13:Successfully acquired database lock
23:57:13:FS00:Initialized folding slot 00: cpu:2
23:57:13:FS01:Initialized folding slot 01: gpu:2:0 GM204 [GeForce GTX 970] 3494
23:57:15:3:127.0.0.1:New Web session
23:58:14:Saving configuration to config.xml
23:58:14:<config>
23:58:14:  <!-- Folding Slots -->
23:58:14:  <slot id='0' type='CPU'/>
23:58:14:  <slot id='1' type='GPU'>
23:58:14:    <pci-bus v='2'/>
23:58:14:    <pci-slot v='0'/>
23:58:14:  </slot>
23:58:14:</config>
23:58:14:Set client configured
23:58:14:WU00:FS00:Connecting to assign1.foldingathome.org:80
23:58:14:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:58:14:WU00:FS00:Assigned to work server 206.223.170.146
23:58:14:WU00:FS00:Requesting new work unit for slot 00: cpu:2 from 206.223.170.146
23:58:14:WU00:FS00:Connecting to 206.223.170.146:8080
23:58:15:WU00:FS00:Downloading 31.21MiB
23:58:15:WU01:FS01:Assigned to work server 140.163.4.210
23:58:15:WU01:FS01:Requesting new work unit for slot 01: gpu:2:0 GM204 [GeForce GTX 970] 3494 from 140.163.4.210
23:58:15:WU01:FS01:Connecting to 140.163.4.210:8080
23:58:15:WU01:FS01:Downloading 1.70MiB
23:58:16:WU01:FS01:Download complete
23:58:16:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17800 run:56 clone:88 gen:378 core:0x22 unit:0x000000580000017a0000458800000038
23:58:16:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
23:58:16:WU01:FS01:Connecting to cores.foldingathome.org:80
23:58:16:WU01:FS01:FahCore 22: Downloading 77.67MiB
23:58:21:WU00:FS00:Download 40.25%
23:58:22:WU01:FS01:FahCore 22: 15.45%
23:58:27:WU00:FS00:Download 65.47%
23:58:28:WU01:FS01:FahCore 22: 37.50%
23:58:33:WU00:FS00:Download 79.09%
23:58:34:WU01:FS01:FahCore 22: 64.54%
23:58:39:WU00:FS00:Download 90.30%
23:58:40:WU01:FS01:FahCore 22: 91.74%
23:58:41:WU01:FS01:FahCore 22: Download complete
23:58:41:WU01:FS01:Valid core signature
23:58:41:WU01:FS01:Unpacked 8.33MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe
23:58:41:WU01:FS01:Unpacked 3.06MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc-builtins64_92.dll
23:58:41:WU01:FS01:Unpacked 3.13MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMM.dll
23:58:41:WU01:FS01:Unpacked 2.07MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMOpenCL.dll
23:58:42:WU01:FS01:Unpacked 14.82MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc64_92.dll
23:58:42:WU01:FS01:Unpacked 82.99MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/cufft64_92.dll
23:58:42:WU01:FS01:Unpacked 275.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCudaCompiler.dll
23:58:42:WU01:FS01:Unpacked 1.95MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCUDA.dll
23:58:42:WU01:FS01:Unpacked 786.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCPU.dll
23:58:42:WU01:FS01:Starting
23:58:42:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5204 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
23:58:42:WU01:FS01:Started FahCore on PID 12756
23:58:42:WU00:FS00:Download complete
23:58:43:WU01:FS01:Core PID:15576
23:58:43:WU01:FS01:FahCore 0x22 started
23:58:43:WU01:FS01:0x22:*********************** Log Started 2021-04-20T23:58:43Z ***********************
23:58:43:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:58:43:WU01:FS01:0x22:       Core: Core22
23:58:43:WU01:FS01:0x22:       Type: 0x22
23:58:43:WU01:FS01:0x22:    Version: 0.0.13
23:58:43:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:58:43:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
23:58:43:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
23:58:44:WU01:FS01:0x22:       Date: Sep 19 2020
23:58:44:WU01:FS01:0x22:       Time: 02:35:58
23:58:44:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
23:58:44:WU01:FS01:0x22:     Branch: core22-0.0.13
23:58:44:WU01:FS01:0x22:   Compiler: Visual C++ 2015
23:58:44:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
23:58:44:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
23:58:44:WU01:FS01:0x22:   Platform: win32 10
23:58:44:WU01:FS01:0x22:       Bits: 64
23:58:44:WU01:FS01:0x22:       Mode: Release
23:58:44:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:58:44:WU01:FS01:0x22:             <peastman@stanford.edu>
23:58:44:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 12756 -checkpoint 15
23:58:44:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
23:58:44:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
23:58:44:WU01:FS01:0x22:************************************ libFAH ************************************
23:58:44:WU01:FS01:0x22:       Date: Sep 7 2020
23:58:44:WU01:FS01:0x22:       Time: 19:09:56
23:58:44:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
23:58:44:WU01:FS01:0x22:     Branch: HEAD
23:58:44:WU01:FS01:0x22:************************************ CBang *************************************
23:58:44:WU01:FS01:0x22:       Time: 19:08:30
23:58:44:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
23:58:44:WU01:FS01:0x22:************************************ System ************************************
23:58:44:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
23:58:44:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:58:44:WU01:FS01:0x22:       CPUs: 4
23:58:44:WU01:FS01:0x22:     Memory: 15.96GiB
23:58:44:WU01:FS01:0x22:Free Memory: 8.84GiB
23:58:44:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
23:58:44:WU01:FS01:0x22: OS Version: 6.2
23:58:44:WU01:FS01:0x22:Has Battery: false
23:58:44:WU01:FS01:0x22: On Battery: false
23:58:44:WU01:FS01:0x22: UTC Offset: -5
23:58:44:WU01:FS01:0x22:        PID: 15576
23:58:44:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
23:58:44:WU01:FS01:0x22:************************************ OpenMM ************************************
23:58:44:WU01:FS01:0x22:   Revision: 189320d0
23:58:44:WU01:FS01:0x22:********************************************************************************
23:58:44:WU01:FS01:0x22:Project: 17800 (Run 56, Clone 88, Gen 378)
23:58:44:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
23:58:44:WU01:FS01:0x22:Reading tar file core.xml
23:58:44:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
23:58:44:WU01:FS01:0x22:Reading tar file state.xml.bz2
23:58:44:WU01:FS01:0x22:Reading tar file system.xml.bz2
23:58:44:WU01:FS01:0x22:Digital signatures verified
23:58:44:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:58:44:WU01:FS01:0x22:Version 0.0.13
23:58:44:WU01:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
23:58:44:WU01:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
23:58:44:WU01:FS01:0x22:  XTC frame write interval: 25000 steps (0.5%) [200 total]
23:58:44:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
That is a fairly recent driver. Here is last weeks:
https://www.nvidia.com/en-us/drivers/results/172458/
I suspect you edited out the username and passkey info, so no one can report what the servers are seeing.
wontonforevuh
JimboPalmer wrote:23:57:13:FS01:Initialized folding slot 01: gpu:2:0 GM204 [GeForce GTX 970] 3494
Hm I think it's set correctly here but im not sure. Ill try the new driver though thanks.
To sort out what the log is telling us, we need to mentally separate the segments of the log associated with each slot from the lines that are associated with setting up FAHClient and the slots, themselves. The prefixes FS00 and FS01 make that distinction.
FS00 is associated with 2 CPUs and after initialization, it downloads something and then never reports that it's starting. Is some other application using all the computer's resources? Do your OS settings allow your system to sleep/hibernate? FAH can easily quit working if some other application uses all the resources or the system enters a sleep state.
FS01 is associated with your GPU. I can see that it downloaded Project: 17800 (Run 56, Clone 88, Gen 378) but no progress is shown in the segment of log that you posted.
You won't earn any points until either FS00 or FS01 completes a WU and uploads the results.
Where are the messages like:
13:49:47:WU02:FS01:0x22:Completed 0 out of 750000 steps (0%)
06:54:54:WU02:FS01:0x22:Completed 750000 out of 750000 steps (100%)
06:56:19:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:56:19:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:17343 run:3 clone:369 gen:13 core:0x22
06:56:19:WU02:FS01:Uploading 24.07MiB to 140.163.4.200
06:56:56:WU02:FS01:Upload complete
06:56:56:WU02:FS01:Server responded WORK_ACK (400)
06:56:56:WU02:FS01:Final credit estimate, 41927.00 points
Note that ~17 hours of uninterrupted hard work took place between 13:49:47 and 06:56:56 the next day. (YMMV)
wontonforevuh
bruce wrote:To sort out what the log is telling us, we need to mentally separate the segments of the log associated with each slot from the lines that are associated with setting up FAHClient and the slots, themselves. The prefixes FS00 and FS01 make that distinction.
I removed the CPU folding slot since I heard it can make GPU work better. So there is no CPU folding on my computer at this moment. I don't allow my PC to sleep/hibernate, only the screens turn off. I don't think there are any resource heavy programs running as I fold, but I do have some gaming apps like Steam that might be downloading in the background. I'll try turning that off tonight.
Maybe I deleted too much of my log. Here is a longer version:
23:57:13:           Bits: 32
23:57:13:           Bits: 32
23:57:13:           Bits: 32
23:57:13:           CPUs: 4
23:57:13:            PID: 5204
23:57:13:           GPUs: 1
23:57:13:<config>
23:57:13:</config>
23:58:14:<config>
23:58:14:  </slot>
23:58:14:</config>
23:58:44:WU01:FS01:0x22:There are 4 platforms available.
23:58:44:WU01:FS01:0x22:Platform 0: Reference
23:58:44:WU01:FS01:0x22:Platform 1: CPU
23:58:44:WU01:FS01:0x22:Platform 2: OpenCL
23:58:44:WU01:FS01:0x22:  opencl-device 0 specified
23:58:44:WU01:FS01:0x22:Platform 3: CUDA
23:58:44:WU01:FS01:0x22:  cuda-device 0 specified
23:58:44:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17220 run:10686 clone:1 gen:6 core:0xa7 unit:0x000000010000000600004344000029be
23:58:44:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
23:58:44:WU00:FS00:Connecting to cores.foldingathome.org:80
23:58:44:WU00:FS00:FahCore a7: Downloading 6.71MiB
23:58:45:WU01:FS01:0x22:Attempting to create CUDA context:
23:58:45:WU01:FS01:0x22:  Configuring platform CUDA
23:58:46:WU00:FS00:FahCore a7: Download complete
23:58:46:WU00:FS00:Valid core signature
23:58:46:WU01:FS01:0x22:  Using CUDA and gpu 0
23:58:46:WU01:FS01:0x22:Completed 0 out of 5000000 steps (0%)
23:58:46:WU01:FS01:0x22:Checkpoint completed at step 0
23:58:46:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe
23:58:46:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/libfftw3f-3.dll
23:58:46:WU00:FS00:Starting
23:58:46:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 5204 -checkpoint 15 -np 2
23:58:46:WU00:FS00:Started FahCore on PID 8348
23:58:47:WU00:FS00:Core PID:3852
23:58:47:WU00:FS00:FahCore 0xa7 started
23:58:47:WU00:FS00:0xa7:*********************** Log Started 2021-04-20T23:58:47Z ***********************
23:58:47:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:58:47:WU00:FS00:0xa7:       Type: 0xa7
23:58:47:WU00:FS00:0xa7:       Core: Gromacs
23:58:47:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8348 -checkpoint 15 -np 2
23:58:47:WU00:FS00:0xa7:************************************ CBang *************************************
23:58:47:WU00:FS00:0xa7:       Date: Nov 27 2019
23:58:47:WU00:FS00:0xa7:       Time: 03:40:09
23:58:47:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
23:58:47:WU00:FS00:0xa7:     Branch: master
23:58:47:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:58:47:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:58:47:WU00:FS00:0xa7:   Platform: win32 10
23:58:47:WU00:FS00:0xa7:       Bits: 64
23:58:47:WU00:FS00:0xa7:       Mode: Release
23:58:47:WU00:FS00:0xa7:************************************ System ************************************
23:58:47:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
23:58:47:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
23:58:47:WU00:FS00:0xa7:       CPUs: 4
23:58:47:WU00:FS00:0xa7:     Memory: 15.96GiB
23:58:47:WU00:FS00:0xa7:Free Memory: 8.63GiB
23:58:47:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:58:47:WU00:FS00:0xa7: OS Version: 6.2
23:58:47:WU00:FS00:0xa7:Has Battery: false
23:58:47:WU00:FS00:0xa7: On Battery: false
23:58:47:WU00:FS00:0xa7: UTC Offset: -5
23:58:47:WU00:FS00:0xa7:        PID: 3852
23:58:47:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
23:58:47:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:58:47:WU00:FS00:0xa7:    Version: 0.0.19
23:58:47:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:58:47:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:58:47:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:58:47:WU00:FS00:0xa7:       Date: Nov 25 2019
23:58:47:WU00:FS00:0xa7:       Time: 17:12:41
23:58:47:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
23:58:47:WU00:FS00:0xa7:************************************ Build *************************************
23:58:47:WU00:FS00:0xa7:       SIMD: avx_256
23:58:47:WU00:FS00:0xa7:********************************************************************************
23:58:47:WU00:FS00:0xa7:Project: 17220 (Run 10686, Clone 1, Gen 6)
23:58:47:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
23:58:47:WU00:FS00:0xa7:Reading tar file core.xml
23:58:47:WU00:FS00:0xa7:Reading tar file frame6.tpr
23:58:47:WU00:FS00:0xa7:Digital signatures verified
23:58:47:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -x frame6.xtc -cpt 15 -nt 2
23:58:48:WU00:FS00:0xa7:Steps: first=375000 total=62500
23:58:54:WU00:FS00:0xa7:Completed 1 out of 62500 steps (0%)
23:59:15:Saving configuration to config.xml
23:59:15:<config>
23:59:15:  <!-- User Information -->
23:59:15:  <passkey v='*****'/>
23:59:15:  <team v='234980'/>
23:59:15:  <user v='aehtf0z6i3n1'/>
23:59:15:
23:59:15:  <!-- Folding Slots -->
23:59:15:  <slot id='0' type='CPU'/>
23:59:15:  <slot id='1' type='GPU'>
23:59:15:    <pci-bus v='2'/>
23:59:15:    <pci-slot v='0'/>
23:59:15:  </slot>
23:59:15:</config>
00:00:24:WU01:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
00:02:01:WU01:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
00:03:38:WU01:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
00:05:07:FS00:Shutting core down
00:05:08:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 3852
00:05:08:WU00:FS00:0xa7:Exiting, please wait. . .
00:05:15:WU01:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
00:05:16:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
00:05:17:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:05:17:WU00:FS00:Starting
00:05:17:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
00:05:17:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
00:05:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 5204 -checkpoint 15 -np 2
00:05:17:WU00:FS00:Started FahCore on PID 14860
00:05:17:WU00:FS00:Core PID:11672
00:05:17:WU00:FS00:FahCore 0xa7 started
00:05:17:WU00:FS00:0xa7:*********************** Log Started 2021-04-21T00:05:17Z ***********************
00:05:17:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:05:17:WU00:FS00:0xa7:       Type: 0xa7
00:05:17:WU00:FS00:0xa7:       Core: Gromacs
00:05:17:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 14860 -checkpoint 15 -np
00:05:17:WU00:FS00:0xa7:             2
00:05:17:WU00:FS00:0xa7:************************************ CBang *************************************
00:05:17:WU00:FS00:0xa7:       Date: Nov 27 2019
00:05:17:WU00:FS00:0xa7:       Time: 03:40:09
00:05:17:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
00:05:17:WU00:FS00:0xa7:     Branch: master
00:05:17:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
00:05:17:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:05:17:WU00:FS00:0xa7:   Platform: win32 10
00:05:17:WU00:FS00:0xa7:       Bits: 64
00:05:17:WU00:FS00:0xa7:       Mode: Release
00:05:17:WU00:FS00:0xa7:************************************ System ************************************
00:05:17:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
00:05:17:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
00:05:17:WU00:FS00:0xa7:       CPUs: 4
00:05:17:WU00:FS00:0xa7:     Memory: 15.96GiB
00:05:17:WU00:FS00:0xa7:Free Memory: 8.76GiB
00:05:17:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
00:05:17:WU00:FS00:0xa7: OS Version: 6.2
00:05:17:WU00:FS00:0xa7:Has Battery: false
00:05:17:WU00:FS00:0xa7: On Battery: false
00:05:17:WU00:FS00:0xa7: UTC Offset: -5
00:05:17:WU00:FS00:0xa7:        PID: 11672
00:05:17:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
00:05:17:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
00:05:17:WU00:FS00:0xa7:    Version: 0.0.19
00:05:17:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:05:17:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:05:17:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
00:05:17:WU00:FS00:0xa7:       Date: Nov 25 2019
00:05:17:WU00:FS00:0xa7:       Time: 17:12:41
00:05:17:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
00:05:17:WU00:FS00:0xa7:************************************ Build *************************************
00:05:17:WU00:FS00:0xa7:       SIMD: avx_256
00:05:17:WU00:FS00:0xa7:********************************************************************************
00:05:17:WU00:FS00:0xa7:Project: 17220 (Run 10686, Clone 1, Gen 6)
00:05:17:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
00:05:17:WU00:FS00:0xa7:Digital signatures verified
00:05:17:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -x frame6.xtc -cpi state.cpt -cpt 15 -nt 2
00:05:18:WU00:FS00:0xa7:Steps: first=375000 total=62500
00:05:21:Saving configuration to config.xml
00:05:21:<config>
00:05:21:  <!-- Slot Control -->
00:05:21:  <power v='full'/>
00:05:21:
00:05:21:  <!-- User Information -->
00:05:21:  <passkey v='*****'/>
00:05:21:  <team v='234980'/>
00:05:21:  <user v='aehtf0z6i3n1'/>
00:05:21:
00:05:21:  <!-- Folding Slots -->
00:05:21:  <slot id='0' type='CPU'/>
00:05:21:  <slot id='1' type='GPU'>
00:05:21:    <pci-bus v='2'/>
00:05:21:    <pci-slot v='0'/>
00:05:21:  </slot>
00:05:21:</config>
00:05:26:WU00:FS00:0xa7:Completed 372 out of 62500 steps (0%)
00:05:28:18:127.0.0.1:New Web session
00:06:52:WU01:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
00:06:52:WU01:FS01:0x22:Checkpoint completed at step 250000
00:06:54:25:127.0.0.1:New Web session
00:08:29:WU01:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
00:09:41:WU00:FS00:0xa7:Completed 625 out of 62500 steps (1%)
00:10:12:WU01:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
00:11:57:35:127.0.0.1:New Web session
00:12:02:WU01:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
00:13:48:WU01:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
00:15:25:WU01:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
00:15:25:WU01:FS01:0x22:Checkpoint completed at step 500000
00:17:06:WU01:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
00:17:57:Saving configuration to config.xml
00:17:57:<config>
00:17:57:  <!-- Network -->
00:17:57:  <proxy v=':8080'/>
00:17:57:
00:17:57:  <!-- Slot Control -->
00:17:57:  <power v='full'/>
00:17:57:
00:17:57:  <!-- User Information -->
00:17:57:  <passkey v='*****'/>
00:17:57:  <team v='234980'/>
00:17:57:  <user v='aehtf0z6i3n1'/>
00:17:57:
00:17:57:  <!-- Folding Slots -->
00:17:57:  <slot id='0' type='CPU'/>
00:17:57:  <slot id='1' type='GPU'>
00:17:57:    <pci-bus v='1'/>
00:17:57:    <pci-slot v='0'/>
00:17:57:  </slot>
00:17:57:</config>
00:18:34:Saving configuration to config.xml
00:18:34:<config>
00:18:34:  <!-- Network -->
00:18:34:  <proxy v=':8080'/>
00:18:34:
00:18:34:  <!-- Slot Control -->
00:18:34:  <power v='full'/>
00:18:34:
00:18:34:  <!-- User Information -->
00:18:34:  <passkey v='*****'/>
00:18:34:  <team v='234980'/>
00:18:34:  <user v='aehtf0z6i3n1'/>
00:18:34:
00:18:34:  <!-- Folding Slots -->
00:18:34:  <slot id='0' type='CPU'/>
00:18:34:  <slot id='1' type='GPU'>
00:18:34:    <pci-bus v='1'/>
00:18:34:    <pci-slot v='0'/>
00:18:34:  </slot>
00:18:34:</config>
00:18:48:WU01:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
00:20:37:WU01:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
00:21:37:WU00:FS00:0xa7:Completed 1250 out of 62500 steps (2%)
00:22:34:WU01:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
00:23:41:46:127.0.0.1:New Web session
00:24:25:WU01:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
00:24:25:WU01:FS01:0x22:Checkpoint completed at step 750000
00:26:00:WU01:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
00:27:32:WU01:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
00:29:02:WU01:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
00:30:32:WU01:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
00:31:51:WU00:FS00:0xa7:Completed 1875 out of 62500 steps (3%)
00:32:04:WU01:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
00:32:04:WU01:FS01:0x22:Checkpoint completed at step 1000000
00:33:36:WU01:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
00:35:09:WU01:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
00:35:23:Saving configuration to config.xml
00:35:23:<config>
00:35:23:  <!-- Network -->
00:35:23:  <proxy v=':8080'/>
00:35:23:
00:35:23:  <!-- Slot Control -->
00:35:23:  <power v='full'/>
00:35:23:
00:35:23:  <!-- User Information -->
00:35:23:  <passkey v='*****'/>
00:35:23:  <team v='234980'/>
00:35:23:  <user v='aehtf0z6i3n1'/>
00:35:23:
00:35:23:  <!-- Folding Slots -->
00:35:23:  <slot id='1' type='GPU'>
00:35:23:    <pci-bus v='1'/>
00:35:23:    <pci-slot v='0'/>
00:35:23:  </slot>
00:35:23:</config>
00:35:23:FS00:Shutting core down
00:35:23:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 11672
00:35:23:WU00:FS00:0xa7:Exiting, please wait. . .
00:35:32:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:35:32:WARNING:WU00:Slot ID 0 no longer exists and there are no other matching slots, dumping
00:35:32:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:17220 run:10686 clone:1 gen:6 core:0xa7 unit:0x000000010000000600004344000029be
00:35:32:WU00:Connecting to 206.223.170.146:8080
00:35:32:WU00:Server responded WORK_ACK (400)
00:35:32:WU00:Cleaning up
00:35:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:35:51:Saving configuration to config.xml
00:35:51:<config>
00:35:51:  <!-- Network -->
00:35:51:  <proxy v=':8080'/>
00:35:51:
00:35:51:  <!-- Slot Control -->
00:35:51:  <power v='full'/>
00:35:51:
00:35:51:  <!-- User Information -->
00:35:51:  <passkey v='*****'/>
00:35:51:  <team v='234980'/>
00:35:51:  <user v='aehtf0z6i3n1'/>
00:35:51:
00:35:51:  <!-- Folding Slots -->
00:35:51:  <slot id='1' type='GPU'>
00:35:51:    <pci-bus v='1'/>
00:35:51:    <pci-slot v='0'/>
00:35:51:  </slot>
00:35:51:</config>
00:36:40:WU01:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
00:37:03:57:127.0.0.1:New Web session
00:38:11:WU01:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
00:39:43:WU01:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
00:39:44:WU01:FS01:0x22:Checkpoint completed at step 1250000
00:41:16:WU01:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
00:42:49:WU01:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
00:44:25:WU01:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
00:45:59:WU01:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
00:47:51:WU01:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
00:47:51:WU01:FS01:0x22:Checkpoint completed at step 1500000
00:49:52:WU01:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
00:51:27:WU01:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
00:51:37:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:53:03:WU01:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
00:54:39:WU01:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
00:56:19:WU01:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
00:56:19:WU01:FS01:0x22:Checkpoint completed at step 1750000
00:57:54:WU01:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
00:59:34:WU01:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
01:01:10:WU01:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
01:02:56:WU01:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
01:04:33:WU01:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
01:04:34:WU01:FS01:0x22:Checkpoint completed at step 2000000
01:06:19:WU01:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
01:07:58:WU01:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
01:09:39:WU01:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
01:11:39:WU01:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
01:14:39:WU01:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
01:14:40:WU01:FS01:0x22:Checkpoint completed at step 2250000
01:16:36:WU01:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
01:19:04:WU01:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
01:20:44:WU01:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
01:23:06:WU01:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
01:25:26:WU01:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
01:25:26:WU01:FS01:0x22:Checkpoint completed at step 2500000
01:27:59:WU01:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
01:30:20:WU01:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
01:31:57:WU01:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
01:33:36:WU01:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
01:35:24:WU01:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
01:35:24:WU01:FS01:0x22:Checkpoint completed at step 2750000
01:37:21:WU01:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
01:39:03:WU01:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
01:40:58:WU01:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
01:42:49:WU01:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
01:44:45:WU01:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
01:44:45:WU01:FS01:0x22:Checkpoint completed at step 3000000
01:47:10:WU01:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
01:52:48:WU01:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
01:58:37:WU01:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
02:03:47:WU01:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
02:08:43:WU01:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
02:08:44:WU01:FS01:0x22:Checkpoint completed at step 3250000
02:13:44:WU01:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
02:21:08:WU01:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
02:25:01:WU01:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
02:27:14:WU01:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
02:29:13:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
02:29:14:WU01:FS01:0x22:Checkpoint completed at step 3500000
02:31:16:FS01:Shutting core down
02:31:16:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 15576
02:31:16:WU01:FS01:0x22:Exiting, please wait. . .
02:31:16:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
02:31:16:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
02:31:45:Saving configuration to config.xml
02:31:45:<config>
02:31:45:  <!-- Network -->
02:31:45:  <proxy v=':8080'/>
02:31:45:
02:31:45:  <!-- Slot Control -->
02:31:45:  <power v='LIGHT'/>
02:31:45:
02:31:45:  <!-- User Information -->
02:31:45:  <passkey v='*****'/>
02:31:45:  <team v='234980'/>
02:31:45:  <user v='aehtf0z6i3n1'/>
02:31:45:
02:31:45:  <!-- Folding Slots -->
02:31:45:  <slot id='1' type='GPU'>
02:31:45:    <pci-bus v='1'/>
02:31:45:    <pci-slot v='0'/>
02:31:45:  </slot>
02:31:45:</config>
02:49:23:73:127.0.0.1:New Web session
04:09:53:WU01:FS01:Starting
04:09:53:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5204 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
04:09:53:WU01:FS01:Started FahCore on PID 6740
04:09:53:WU01:FS01:Core PID:14696
04:09:53:WU01:FS01:FahCore 0x22 started
04:09:54:WU01:FS01:0x22:*********************** Log Started 2021-04-21T04:09:54Z ***********************
04:09:54:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:09:54:WU01:FS01:0x22:       Core: Core22
04:09:54:WU01:FS01:0x22:       Type: 0x22
04:09:54:WU01:FS01:0x22:    Version: 0.0.13
04:09:54:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:09:54:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
04:09:54:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
04:09:54:WU01:FS01:0x22:       Date: Sep 19 2020
04:09:54:WU01:FS01:0x22:       Time: 02:35:58
04:09:54:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
04:09:54:WU01:FS01:0x22:     Branch: core22-0.0.13
04:09:54:WU01:FS01:0x22:   Compiler: Visual C++ 2015
04:09:54:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
04:09:54:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
04:09:54:WU01:FS01:0x22:   Platform: win32 10
04:09:54:WU01:FS01:0x22:       Bits: 64
04:09:54:WU01:FS01:0x22:       Mode: Release
04:09:54:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
04:09:54:WU01:FS01:0x22:             <peastman@stanford.edu>
04:09:54:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6740 -checkpoint 15
04:09:54:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
04:09:54:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
04:09:54:WU01:FS01:0x22:************************************ libFAH ************************************
04:09:54:WU01:FS01:0x22:       Date: Sep 7 2020
04:09:54:WU01:FS01:0x22:       Time: 19:09:56
04:09:54:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
04:09:54:WU01:FS01:0x22:     Branch: HEAD
04:09:54:WU01:FS01:0x22:************************************ CBang *************************************
04:09:54:WU01:FS01:0x22:       Time: 19:08:30
04:09:54:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
04:09:54:WU01:FS01:0x22:************************************ System ************************************
04:09:54:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
04:09:54:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
04:09:54:WU01:FS01:0x22:       CPUs: 4
04:09:54:WU01:FS01:0x22:     Memory: 15.96GiB
04:09:54:WU01:FS01:0x22:Free Memory: 8.96GiB
04:09:54:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
04:09:54:WU01:FS01:0x22: OS Version: 6.2
04:09:54:WU01:FS01:0x22:Has Battery: false
04:09:54:WU01:FS01:0x22: On Battery: false
04:09:54:WU01:FS01:0x22: UTC Offset: -5
04:09:54:WU01:FS01:0x22:        PID: 14696
04:09:54:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
04:09:54:WU01:FS01:0x22:************************************ OpenMM ************************************
04:09:54:WU01:FS01:0x22:   Revision: 189320d0
04:09:54:WU01:FS01:0x22:********************************************************************************
04:09:54:WU01:FS01:0x22:Project: 17800 (Run 56, Clone 88, Gen 378)
04:09:54:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
04:09:54:WU01:FS01:0x22:Digital signatures verified
04:09:54:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:09:54:WU01:FS01:0x22:Version 0.0.13
04:09:54:WU01:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
04:09:54:WU01:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
04:09:54:WU01:FS01:0x22:  XTC frame write interval: 25000 steps (0.5%) [200 total]
04:09:54:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
04:09:54:WU01:FS01:0x22:There are 4 platforms available.
04:09:54:WU01:FS01:0x22:Platform 0: Reference
04:09:54:WU01:FS01:0x22:Platform 1: CPU
04:09:54:WU01:FS01:0x22:Platform 2: OpenCL
04:09:54:WU01:FS01:0x22:  opencl-device 0 specified
04:09:54:WU01:FS01:0x22:Platform 3: CUDA
04:09:54:WU01:FS01:0x22:  cuda-device 0 specified
04:09:59:WU01:FS01:0x22:Attempting to create CUDA context:
04:09:59:WU01:FS01:0x22:  Configuring platform CUDA
04:10:01:WU01:FS01:0x22:  Using CUDA and gpu 0
04:10:01:WU01:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
04:10:22:Saving configuration to config.xml
04:10:22:<config>
04:10:22:  <!-- Network -->
04:10:22:  <proxy v=':8080'/>
04:10:22:
04:10:22:  <!-- Slot Control -->
04:10:22:  <power v='FULL'/>
04:10:22:
04:10:22:  <!-- User Information -->
04:10:22:  <passkey v='*****'/>
04:10:22:  <team v='234980'/>
04:10:22:  <user v='aehtf0z6i3n1'/>
04:10:22:
04:10:22:  <!-- Folding Slots -->
04:10:22:  <slot id='1' type='GPU'>
04:10:22:    <pci-bus v='1'/>
04:10:22:    <pci-slot v='0'/>
04:10:22:  </slot>
04:10:22:</config>
04:11:54:WU01:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
04:13:32:WU01:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
04:14:05:82:127.0.0.1:New Web session
04:15:12:WU01:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
04:16:48:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
04:18:24:WU01:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
04:18:24:WU01:FS01:0x22:Checkpoint completed at step 3750000
04:20:02:WU01:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
04:21:43:WU01:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
04:23:25:WU01:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
04:25:10:WU01:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
04:26:56:WU01:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
04:26:56:WU01:FS01:0x22:Checkpoint completed at step 4000000
04:28:41:WU01:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
04:30:18:WU01:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
04:31:51:WU01:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
04:33:49:WU01:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
04:35:31:WU01:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
04:35:32:WU01:FS01:0x22:Checkpoint completed at step 4250000
04:36:29:91:127.0.0.1:New Web session
04:37:07:WU01:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
04:38:45:WU01:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
04:40:21:WU01:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
04:41:20:98:127.0.0.1:New Web session
04:42:00:WU01:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
04:43:39:WU01:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
04:43:39:WU01:FS01:0x22:Checkpoint completed at step 4500000
04:45:16:WU01:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
04:46:49:WU01:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
04:48:24:WU01:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
04:49:57:WU01:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
04:51:46:WU01:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
04:51:47:WU01:FS01:0x22:Checkpoint completed at step 4750000
04:53:22:WU01:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
04:55:38:WU01:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
04:57:29:WU01:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
04:59:14:WU01:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
04:59:14:WU00:FS01:Connecting to assign1.foldingathome.org:80
04:59:14:WU00:FS01:Assigned to work server 128.174.73.74
04:59:14:WU00:FS01:Requesting new work unit for slot 01: gpu:2:0 GM204 [GeForce GTX 970] 3494 from 128.174.73.74
wontonforevuh wrote: I removed the CPU folding slot since I heard it can make GPU work better. So there is no CPU folding on my computer at this moment.
There are several places in the log you posted where the CPU slot was being reconfigured.
I do know that your CPU slot will slow down your GPU depending on how many of the threads are invoked. Using all 4 is a bad idea. There are differences of opinion about using 3 out of your 4 and I've never attempted to measure that difference. I doubt that there would be a problem if you only used 2 out of 4, but the CPU slot is much slower than the GPU slot and it earns significantly fewer points so you might want to benchmark 2 or 3 yourself.
I notice that you have avx-256 which does enhance the throughput of CPUs.
Having started a new GPU assignment, you might want to find the beginning and end (as I did in my example above) and we'll compute the points and see how you GPU slot is actually doing. Unfortunately there are a couple of servers which are not properly connecting to the stats system so it might just be that your credits are being delayed. We can check that out, too.
wontonforevuh
Interesting. Ok I might try turning the CPU on with 3 threads and see if that's better. I think i have a WU cycle here.
23:59:16:WU00:FS01:0x22:  Using CUDA and gpu 0
23:59:16:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
23:59:16:WU00:FS01:0x22:Checkpoint completed at step 0
00:00:47:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
******************************* Date: 2021-04-22 *******************************
00:02:16:WU00:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
00:03:47:WU00:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
00:05:16:WU00:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
00:06:46:WU00:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
00:06:46:WU00:FS01:0x22:Checkpoint completed at step 250000
00:08:16:WU00:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
00:09:46:WU00:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
00:11:16:WU00:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
00:12:46:WU00:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
00:14:16:WU00:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
00:14:16:WU00:FS01:0x22:Checkpoint completed at step 500000
00:15:45:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
00:17:16:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
00:18:47:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
00:20:18:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
00:21:50:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
00:21:50:WU00:FS01:0x22:Checkpoint completed at step 750000
00:23:18:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
00:24:49:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
00:26:18:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
00:27:48:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
00:29:20:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
00:29:20:WU00:FS01:0x22:Checkpoint completed at step 1000000
00:30:57:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
00:32:28:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
00:33:56:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
00:35:26:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
00:36:54:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
00:36:54:WU00:FS01:0x22:Checkpoint completed at step 1250000
00:38:22:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
00:39:50:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
00:41:18:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
00:42:46:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
00:44:14:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
00:44:14:WU00:FS01:0x22:Checkpoint completed at step 1500000
00:45:43:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
00:47:11:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
00:48:39:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
00:50:07:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
00:51:35:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
00:51:35:WU00:FS01:0x22:Checkpoint completed at step 1750000
00:53:02:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
00:54:30:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
00:55:58:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
00:57:26:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
00:58:54:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
00:58:54:WU00:FS01:0x22:Checkpoint completed at step 2000000
01:00:22:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
01:01:49:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
01:03:17:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
01:04:45:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
01:06:12:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
01:06:13:WU00:FS01:0x22:Checkpoint completed at step 2250000
01:07:40:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
01:09:08:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
01:10:36:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
01:12:03:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
01:13:31:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
01:13:31:WU00:FS01:0x22:Checkpoint completed at step 2500000
01:14:59:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
01:16:27:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
01:17:54:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
01:19:22:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
01:20:50:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
01:20:50:WU00:FS01:0x22:Checkpoint completed at step 2750000
01:22:18:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
01:23:45:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
01:25:13:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
01:26:41:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
01:28:09:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
01:28:09:WU00:FS01:0x22:Checkpoint completed at step 3000000
01:29:36:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
01:31:04:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
01:32:32:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
01:34:00:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
01:35:27:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
01:35:27:WU00:FS01:0x22:Checkpoint completed at step 3250000
01:36:55:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
01:38:23:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
01:39:50:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
01:41:20:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
01:42:50:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
01:42:50:WU00:FS01:0x22:Checkpoint completed at step 3500000
01:44:22:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
01:45:51:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
01:47:20:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
01:48:52:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
01:50:23:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
01:50:24:WU00:FS01:0x22:Checkpoint completed at step 3750000
01:51:57:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
01:53:30:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
01:55:02:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
01:56:45:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
01:58:27:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
01:58:27:WU00:FS01:0x22:Checkpoint completed at step 4000000
02:00:05:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
02:01:42:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
02:03:16:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
02:04:47:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
02:06:19:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
02:06:19:WU00:FS01:0x22:Checkpoint completed at step 4250000
02:07:54:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
02:09:25:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
02:10:56:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
02:12:29:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
02:13:59:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
02:13:59:WU00:FS01:0x22:Checkpoint completed at step 4500000
02:15:31:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
02:17:12:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
02:18:54:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
02:20:34:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
02:22:12:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
02:22:12:WU00:FS01:0x22:Checkpoint completed at step 4750000
02:23:54:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
02:25:33:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
02:27:08:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
02:28:43:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
02:28:44:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:28:44:WU01:FS01:Assigned to work server 140.163.4.210
02:28:44:WU01:FS01:Requesting new work unit for slot 01: gpu:2:0 GM204 [GeForce GTX 970] 3494 from 140.163.4.210
02:28:44:WU01:FS01:Connecting to 140.163.4.210:8080
02:28:45:WU01:FS01:Downloading 1.89MiB
02:28:45:WU01:FS01:Download complete
02:28:45:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17800 run:64 clone:204 gen:80 core:0x22 unit:0x000000cc000000500000458800000040
02:30:19:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
02:30:19:WU00:FS01:0x22:Average performance: 17.7413 ns/day
02:30:19:WU00:FS01:0x22:Checkpoint completed at step 5000000
02:30:20:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
02:30:20:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
02:30:20:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
02:30:20:WU00:FS01:0x22:Saving result file positions.xtc
02:30:20:WU00:FS01:0x22:Saving result file science.log
02:30:20:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
02:30:20:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:30:20:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17800 run:58 clone:206 gen:82 core:0x22 unit:0x000000ce00000052000045880000003a
02:30:20:WU00:FS01:Uploading 3.30MiB to 140.163.4.210
02:30:20:WU01:FS01:Starting
02:30:21:WU00:FS01:Connecting to 140.163.4.210:8080
02:30:21:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5204 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
02:30:21:WU01:FS01:Started FahCore on PID 6576
02:30:21:WU01:FS01:Core PID:1948
02:30:21:WU01:FS01:FahCore 0x22 started
02:30:21:WU01:FS01:0x22:*********************** Log Started 2021-04-22T02:30:21Z ***********************
02:30:21:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:30:21:WU01:FS01:0x22:       Core: Core22
02:30:21:WU01:FS01:0x22:       Type: 0x22
02:30:21:WU01:FS01:0x22:    Version: 0.0.13
02:30:21:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:30:21:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
02:30:21:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
02:30:21:WU01:FS01:0x22:       Date: Sep 19 2020
02:30:21:WU01:FS01:0x22:       Time: 02:35:58
02:30:21:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
02:30:21:WU01:FS01:0x22:     Branch: core22-0.0.13
02:30:21:WU01:FS01:0x22:   Compiler: Visual C++ 2015
02:30:21:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
02:30:21:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
02:30:21:WU01:FS01:0x22:   Platform: win32 10
02:30:21:WU01:FS01:0x22:       Bits: 64
02:30:21:WU01:FS01:0x22:       Mode: Release
02:30:21:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:30:21:WU01:FS01:0x22:             <peastman@stanford.edu>
02:30:21:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6576 -checkpoint 15
02:30:21:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
02:30:21:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
02:30:21:WU01:FS01:0x22:************************************ libFAH ************************************
02:30:21:WU01:FS01:0x22:       Date: Sep 7 2020
02:30:21:WU01:FS01:0x22:       Time: 19:09:56
02:30:21:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
02:30:21:WU01:FS01:0x22:     Branch: HEAD
02:30:21:WU01:FS01:0x22:************************************ CBang *************************************
02:30:21:WU01:FS01:0x22:       Time: 19:08:30
02:30:21:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
02:30:21:WU01:FS01:0x22:************************************ System ************************************
02:30:21:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
02:30:21:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
02:30:21:WU01:FS01:0x22:       CPUs: 4
02:30:21:WU01:FS01:0x22:     Memory: 15.96GiB
02:30:21:WU01:FS01:0x22:Free Memory: 7.91GiB
02:30:21:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
02:30:21:WU01:FS01:0x22: OS Version: 6.2
02:30:21:WU01:FS01:0x22:Has Battery: false
02:30:21:WU01:FS01:0x22: On Battery: false
02:30:21:WU01:FS01:0x22: UTC Offset: -5
02:30:21:WU01:FS01:0x22:        PID: 1948
02:30:21:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
02:30:21:WU01:FS01:0x22:************************************ OpenMM ************************************
02:30:21:WU01:FS01:0x22:   Revision: 189320d0
02:30:21:WU01:FS01:0x22:********************************************************************************
02:30:21:WU01:FS01:0x22:Project: 17800 (Run 64, Clone 204, Gen 80)
02:30:21:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
02:30:21:WU01:FS01:0x22:Reading tar file core.xml
02:30:21:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
02:30:21:WU01:FS01:0x22:Reading tar file state.xml.bz2
02:30:21:WU01:FS01:0x22:Reading tar file system.xml.bz2
02:30:21:WU01:FS01:0x22:Digital signatures verified
02:30:21:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:30:21:WU01:FS01:0x22:Version 0.0.13
02:30:21:WU01:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
02:30:21:WU01:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
02:30:21:WU01:FS01:0x22:  XTC frame write interval: 25000 steps (0.5%) [200 total]
02:30:21:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
02:30:21:WU01:FS01:0x22:There are 4 platforms available.
02:30:21:WU01:FS01:0x22:Platform 0: Reference
02:30:21:WU01:FS01:0x22:Platform 1: CPU
02:30:21:WU01:FS01:0x22:Platform 2: OpenCL
02:30:21:WU01:FS01:0x22:  opencl-device 0 specified
02:30:21:WU01:FS01:0x22:Platform 3: CUDA
02:30:21:WU01:FS01:0x22:  cuda-device 0 specified
02:30:22:WU01:FS01:0x22:Attempting to create CUDA context:
02:30:22:WU01:FS01:0x22:  Configuring platform CUDA
02:30:23:WU00:FS01:Upload complete
02:30:23:WU00:FS01:Server responded WORK_ACK (400)
02:30:23:WU00:FS01:Final credit estimate, 48659.00 points
iero
Post by iero »
CPU folding tried to run and failed 7 minutes later.
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
