OrsPervIe
Posts: 12 Joined: Mon Jun 24, 2019 1:30 pm
Post
by OrsPervIe » Sun Apr 11, 2021 4:56 pm
I have folding power set at full. Yet even when I am doing nothing it is running at 25% which is the same as if I put it at medium. The only difference with low is it shuts down GPU usage and runs then at 12%. Something is not quite right as I know at full it should be able to run at near 90%.
16:27:12:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:27:12:WU03:FS01:0x22: Core: Core22
16:27:12:WU03:FS01:0x22: Type: 0x22
16:27:12:WU03:FS01:0x22: Version: 0.0.13
16:27:12:WU03:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:27:12:WU03:FS01:0x22: Copyright: 2020 foldingathome.org
16:27:12:WU03:FS01:0x22: Homepage: https://foldingathome.org/
16:27:12:WU03:FS01:0x22: Date: Sep 19 2020
16:27:12:WU03:FS01:0x22: Time: 01:10:35
16:27:12:WU03:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
16:27:12:WU03:FS01:0x22: Branch: core22-0.0.13
16:27:12:WU03:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
16:27:12:WU03:FS01:0x22: Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
16:27:12:WU03:FS01:0x22: -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
16:27:12:WU03:FS01:0x22: Platform: linux2 4.19.76-linuxkit
16:27:12:WU03:FS01:0x22: Bits: 64
16:27:12:WU03:FS01:0x22: Mode: Release
16:27:12:WU03:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:27:12:WU03:FS01:0x22: <peastman@stanford.edu>
16:27:12:WU03:FS01:0x22: Args: -dir 03 -suffix 01 -version 706 -lifeline 3292 -checkpoint 15
16:27:12:WU03:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
16:27:12:WU03:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
16:27:12:WU03:FS01:0x22:************************************ libFAH ************************************
16:27:12:WU03:FS01:0x22: Date: Sep 15 2020
16:27:12:WU03:FS01:0x22: Time: 05:14:43
16:27:12:WU03:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
16:27:12:WU03:FS01:0x22: Branch: HEAD
16:27:12:WU03:FS01:0x22:************************************ CBang *************************************
16:27:12:WU03:FS01:0x22: Time: 05:11:04
16:27:12:WU03:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
16:27:12:WU03:FS01:0x22: -funroll-loops -fPIC
16:27:12:WU03:FS01:0x22:************************************ System ************************************
16:27:12:WU03:FS01:0x22: CPU: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
16:27:12:WU03:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 126 Stepping 5
16:27:12:WU03:FS01:0x22: CPUs: 8
16:27:12:WU03:FS01:0x22: Memory: 15.42GiB
16:27:12:WU03:FS01:0x22:Free Memory: 10.78GiB
16:27:12:WU03:FS01:0x22: Threads: POSIX_THREADS
16:27:12:WU03:FS01:0x22: OS Version: 5.12
16:27:12:WU03:FS01:0x22:Has Battery: true
16:27:12:WU03:FS01:0x22: On Battery: false
16:27:12:WU03:FS01:0x22: UTC Offset: -4
16:27:12:WU03:FS01:0x22: PID: 3296
16:27:12:WU03:FS01:0x22: CWD: /var/lib/private/fah/work
Joe_H on Sun Apr 11, 2021 5:36 pm, edited 1 time in total.
Reason: added Code tags to log
Posts: 2522 Joined: Mon Feb 16, 2009 4:12 am
Post
by JimboPalmer » Sun Apr 11, 2021 5:25 pm
Welcome to Folding@Home!
This is a Core 22 log, Core 22 runs on your GPU. One CPU thread keeps that GPU fed with data. (It might be a Nvidia GPU, but I don't have that part of the log)
https://ark.intel.com/content/www/us/en ... 0-ghz.html
If you had a Core a7 or a8 WU, it would use other CPU threads, most likely 6 of them, and that would use more CPU resources.
If we could see the complete log, the first two hundred lines would tell us a great deal about your configuration.
This should help find that log viewtopic.php?f=24&t=26036
OrsPervIe
Post
by OrsPervIe » Sun Apr 11, 2021 5:54 pm
Sorry didn't clue in what I did. You're right it was only GPU which is working fine.
********************** Log Started 2021-04-11T16:17:07Z ***********************
16:17:07:******************************* libFAH ********************************
16:17:07: Date: Oct 20 2020
16:17:07: Time: 20:36:39
16:17:07: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
16:17:07: Branch: master
16:17:07: Compiler: GNU 8.3.0
16:17:07: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
16:17:07: -fdata-sections -O3 -funroll-loops -fno-pie
16:17:07: Platform: linux2 5.8.0-1-amd64
16:17:07: Bits: 64
16:17:07: Mode: Release
16:17:07:****************************** FAHClient ******************************
16:17:07: Version: 7.6.21
16:17:07: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:17:07: Copyright: 2020 foldingathome.org
16:17:07: Homepage: https://foldingathome.org/
16:17:07: Time: 20:39:00
16:17:07: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
16:17:07: Bits: 64
16:17:07: Args: --config /etc/foldingathome/config.xml --log
16:17:07: /var/log/foldingathome/log.txt --log-rotate-dir
16:17:07: Config: /etc/foldingathome/config.xml
16:17:07:******************************** CBang ********************************
16:17:07: Time: 18:37:59
16:17:07: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
16:17:07: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
16:17:07: Bits: 64
16:17:07:******************************* System ********************************
16:17:07: CPU: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
16:17:07: CPU ID: GenuineIntel Family 6 Model 126 Stepping 5
16:17:07: CPUs: 8
16:17:07: Memory: 15.42GiB
16:17:07: Free Memory: 11.99GiB
16:17:07: Threads: POSIX_THREADS
16:17:07: OS Version: 5.12
16:17:07: Has Battery: true
16:17:07: On Battery: false
16:17:07: UTC Offset: -4
16:17:07: PID: 2522
16:17:07: CWD: /var/lib/private/fah
16:17:07: OS: Linux 5.12.0-1-MANJARO x86_64
16:17:07: OS Arch: AMD64
16:17:07: GPUs: 1
16:17:07: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP108M [GeForce MX330]
16:17:07: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.2
16:17:07:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:460.67
16:17:07:***********************************************************************
16:17:07:<config>
16:17:07: <!-- Folding Slot Configuration -->
16:17:07: <gpu v='false'/>
16:17:07:
16:17:07: <!-- User Information -->
16:17:07: <user v='anonymous'/>
16:17:07:
16:17:07: <!-- Folding Slots -->
16:17:07:</config>
16:17:07:Trying to access database...
16:17:07:Successfully acquired database lock
16:17:07:FS00:Initialized folding slot 00: cpu:4
16:17:07:WARNING:WU03:Slot ID 1 no longer exists and there are no other matching slots, dumping
16:17:07:WU00:FS00:Starting
16:17:07:WARNING:WU00:FS00:Changed SMP threads from 7 to 4 this can cause some work units to fail
16:17:07:WARNING:WU00:FS00:AS lowered CPUs from 4 to 1
16:17:07:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 2522 -checkpoint 15 -np 1
16:17:07:WU00:FS00:Started FahCore on PID 2533
16:17:07:WU00:FS00:Core PID:2537
16:17:07:WU00:FS00:FahCore 0xa7 started
16:17:08:WU03:Sending unit results: id:03 state:SEND error:DUMPED project:17800 run:41 clone:240 gen:18 core:0x22 unit:0x000000f0000000120000458800000029
16:17:08:WU03:Connecting to 140.163.4.210:8080
16:17:08:WU00:FS00:0xa7:*********************** Log Started 2021-04-11T16:17:08Z ***********************
16:17:08:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:17:08:WU00:FS00:0xa7: Type: 0xa7
16:17:08:WU00:FS00:0xa7: Core: Gromacs
16:17:08:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 2533 -checkpoint 15 -np 1
16:17:08:WU00:FS00:0xa7:************************************ CBang *************************************
16:17:08:WU00:FS00:0xa7: Date: Nov 27 2019
16:17:08:WU00:FS00:0xa7: Time: 11:26:54
16:17:08:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
16:17:08:WU00:FS00:0xa7: Branch: master
16:17:08:WU00:FS00:0xa7: Compiler: GNU 8.3.0
16:17:08:WU00:FS00:0xa7: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
16:17:08:WU00:FS00:0xa7: -fno-pie -fPIC
16:17:08:WU00:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
16:17:08:WU00:FS00:0xa7: Bits: 64
16:17:08:WU00:FS00:0xa7: Mode: Release
16:17:08:WU00:FS00:0xa7:************************************ System ************************************
16:17:08:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
16:17:08:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 126 Stepping 5
16:17:08:WU00:FS00:0xa7: CPUs: 8
16:17:08:WU00:FS00:0xa7: Memory: 15.42GiB
16:17:08:WU00:FS00:0xa7:Free Memory: 11.96GiB
16:17:08:WU00:FS00:0xa7: Threads: POSIX_THREADS
16:17:08:WU00:FS00:0xa7: OS Version: 5.12
16:17:08:WU00:FS00:0xa7:Has Battery: true
16:17:08:WU00:FS00:0xa7: On Battery: false
16:17:08:WU00:FS00:0xa7: UTC Offset: -4
16:17:08:WU00:FS00:0xa7: PID: 2537
16:17:08:WU00:FS00:0xa7: CWD: /var/lib/private/fah/work
16:17:08:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:17:08:WU00:FS00:0xa7: Version: 0.0.19
16:17:08:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:17:08:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
16:17:08:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
16:17:08:WU00:FS00:0xa7: Date: Nov 26 2019
16:17:08:WU00:FS00:0xa7: Time: 00:41:42
16:17:08:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
16:17:08:WU00:FS00:0xa7:************************************ Build *************************************
16:17:08:WU00:FS00:0xa7: SIMD: avx_256
16:17:08:WU00:FS00:0xa7:********************************************************************************
16:17:08:WU00:FS00:0xa7:Project: 17231 (Run 8691, Clone 0, Gen 1)
16:17:08:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
16:17:08:WU00:FS00:0xa7:Digital signatures verified
16:17:08:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -x frame1.xtc -cpi state.cpt -cpt 15 -nt 1
16:17:08:WU00:FS00:0xa7:Steps: first=62500 total=62500
16:17:13:WU00:FS00:0xa7:Completed 55242 out of 62500 steps (88%)
16:17:18:WU03:Server responded WORK_ACK (400)
16:17:18:WU03:Cleaning up
16:18:08:Removing old file 'configs/config-20210411-025806.xml'
16:18:08:Saving configuration to /etc/foldingathome/config.xml
16:18:08:<config>
16:18:08: <!-- Folding Slot Configuration -->
16:18:08: <gpu v='false'/>
16:18:08:
16:18:08: <!-- User Information -->
16:18:08: <user v='anonymous'/>
16:18:08:
16:18:08: <!-- Folding Slots -->
16:18:08: <slot id='0' type='CPU'/>
16:18:08:</config>
16:18:27:FS00:Shutting core down
16:18:27:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 2537
16:18:27:WU00:FS00:0xa7:Exiting, please wait. . .
16:18:39:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
16:18:39:WU01:FS00:Starting
16:18:39:WARNING:WU01:FS00:Changed SMP threads from 3 to 8 this can cause some work units to fail
16:18:39:WARNING:WU01:FS00:AS lowered CPUs from 8 to 1
16:18:39:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 01 -suffix 01 -version 706 -lifeline 2522 -checkpoint 15 -np 1
16:18:39:WU01:FS00:Started FahCore on PID 2908
16:18:39:WU01:FS00:Core PID:2912
16:18:39:WU01:FS00:FahCore 0xa8 started
16:18:39:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:18:40:WU01:FS00:0xa8:*********************** Log Started 2021-04-11T16:18:39Z ***********************
16:18:40:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
16:18:40:WU01:FS00:0xa8: Core: Gromacs
16:18:40:WU01:FS00:0xa8: Type: 0xa8
16:18:40:WU01:FS00:0xa8: Version: 0.0.12
16:18:40:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:18:40:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
16:18:40:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
16:18:40:WU01:FS00:0xa8: Date: Jan 16 2021
16:18:40:WU01:FS00:0xa8: Time: 19:24:44
16:18:40:WU01:FS00:0xa8: Compiler: GNU 8.3.0
16:18:40:WU01:FS00:0xa8: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
16:18:40:WU01:FS00:0xa8: -fdata-sections -O3 -funroll-loops -fno-pie
16:18:40:WU01:FS00:0xa8: Platform: linux2 4.15.0-128-generic
16:18:40:WU01:FS00:0xa8: Bits: 64
16:18:40:WU01:FS00:0xa8: Mode: Release
16:18:40:WU01:FS00:0xa8: SIMD: avx2_256
16:18:40:WU01:FS00:0xa8: OpenMP: ON
16:18:40:WU01:FS00:0xa8: CUDA: OFF
16:18:40:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 2908 -checkpoint 15 -np 1
16:18:40:WU01:FS00:0xa8:************************************ libFAH ************************************
16:18:40:WU01:FS00:0xa8: Time: 19:21:38
16:18:40:WU01:FS00:0xa8:************************************ CBang *************************************
16:18:40:WU01:FS00:0xa8: Time: 19:21:24
16:18:40:WU01:FS00:0xa8: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
16:18:40:WU01:FS00:0xa8:************************************ System ************************************
16:18:40:WU01:FS00:0xa8: CPU: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
16:18:40:WU01:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 126 Stepping 5
16:18:40:WU01:FS00:0xa8: CPUs: 8
16:18:40:WU01:FS00:0xa8: Memory: 15.42GiB
16:18:40:WU01:FS00:0xa8:Free Memory: 11.37GiB
16:18:40:WU01:FS00:0xa8: Threads: POSIX_THREADS
16:18:40:WU01:FS00:0xa8: OS Version: 5.12
16:18:40:WU01:FS00:0xa8:Has Battery: true
16:18:40:WU01:FS00:0xa8: On Battery: false
16:18:40:WU01:FS00:0xa8: UTC Offset: -4
16:18:40:WU01:FS00:0xa8: PID: 2912
16:18:40:WU01:FS00:0xa8: CWD: /var/lib/private/fah/work
16:18:40:WU01:FS00:0xa8:********************************************************************************
16:18:40:WU01:FS00:0xa8:Project: 16815 (Run 24, Clone 354, Gen 39)
16:18:40:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
16:18:40:WU01:FS00:0xa8:Digital signatures verified
16:18:40:WU01:FS00:0xa8:Calling: mdrun -c frame39.gro -s frame39.tpr -x frame39.xtc -cpi state.cpt -cpt 15 -nt 1 -ntmpi 1
16:18:40:WU01:FS00:0xa8:Steps: first=0 total=500000
16:18:41:WU01:FS00:0xa8:Completed 52042 out of 500000 steps (10%)
16:19:09:Removing old file 'configs/config-20210411-030455.xml'
16:19:09:Saving configuration to /etc/foldingathome/config.xml
16:19:09:<config>
16:19:09: <!-- Folding Slot Configuration -->
16:19:09: <gpu v='false'/>
16:19:09:
16:19:09: <!-- Slot Control -->
16:19:09: <power v='full'/>
16:19:09:
16:19:09: <!-- User Information -->
16:19:09: <user v='anonymous'/>
16:19:09:
16:19:09: <!-- Folding Slots -->
16:19:09: <slot id='0' type='CPU'/>
16:19:09:</config>
*********************** Log Started 2021-04-11T16:17:07Z ***********************
16:17:07: Bits: 64
16:17:07: Bits: 64
16:17:07: Bits: 64
16:17:07: CPUs: 8
16:17:07: PID: 2522
16:17:07: GPUs: 1
16:17:07:<config>
16:17:07:
16:17:07:
16:17:07:</config>
16:18:08:<config>
16:18:08:
16:18:08:
16:18:08:</config>
16:19:09:<config>
16:19:09:
16:19:09:
16:19:09:
16:19:09:</config>
16:22:52:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:-1:-1. Disabling.
16:22:52:Adding folding slot 01: gpu:-1:-1
16:22:52:Removing old file 'configs/config-20210411-030513.xml'
16:22:52:Saving configuration to /etc/foldingathome/config.xml
16:22:52:<config>
16:22:52: <!-- Folding Slot Configuration -->
16:22:52: <gpu v='false'/>
16:22:52:
16:22:52: <!-- Network -->
16:22:52: <proxy v=':8080'/>
16:22:52:
16:22:52: <!-- Slot Control -->
16:22:52: <power v='full'/>
16:22:52:
16:22:52: <!-- User Information -->
16:22:52: <passkey v='*****'/>
16:22:52: <user v='LRC1962'/>
16:22:52:
16:22:52: <!-- Folding Slots -->
16:22:52: <slot id='0' type='CPU'/>
16:22:52: <slot id='1' type='GPU'/>
16:22:52:</config>
16:22:52:FS00:Shutting core down
16:22:52:WU01:FS00:0xa8:Caught signal SIGINT(2) on PID 2912
16:22:52:WU01:FS00:0xa8:Exiting, please wait. . .
16:22:53:WU01:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
16:22:53:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:22:53:WU00:FS00:Starting
16:22:53:WARNING:WU00:FS00:Changed SMP threads from 4 to 7 this can cause some work units to fail
16:22:53:WARNING:WU00:FS00:AS lowered CPUs from 7 to 1
16:22:53:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 2522 -checkpoint 15 -np 1
16:22:53:WU00:FS00:Started FahCore on PID 3024
16:22:53:WU00:FS00:Core PID:3028
16:22:53:WU00:FS00:FahCore 0xa7 started
16:22:53:WU00:FS00:0xa7:*********************** Log Started 2021-04-11T16:22:53Z ***********************
16:22:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:22:53:WU00:FS00:0xa7: Type: 0xa7
16:22:53:WU00:FS00:0xa7: Core: Gromacs
16:22:53:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 3024 -checkpoint 15 -np 1
16:22:53:WU00:FS00:0xa7:************************************ CBang *************************************
16:22:53:WU00:FS00:0xa7: Date: Nov 27 2019
16:22:53:WU00:FS00:0xa7: Time: 11:26:54
16:22:53:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
16:22:53:WU00:FS00:0xa7: Branch: master
16:22:53:WU00:FS00:0xa7: Compiler: GNU 8.3.0
16:22:53:WU00:FS00:0xa7: Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
16:22:53:WU00:FS00:0xa7: -fno-pie -fPIC
16:22:53:WU00:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
16:22:53:WU00:FS00:0xa7: Bits: 64
16:22:53:WU00:FS00:0xa7: Mode: Release
16:22:53:WU00:FS00:0xa7:************************************ System ************************************
16:22:53:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
16:22:53:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 126 Stepping 5
16:22:53:WU00:FS00:0xa7: CPUs: 8
16:22:53:WU00:FS00:0xa7: Memory: 15.42GiB
16:22:53:WU00:FS00:0xa7:Free Memory: 11.23GiB
16:22:53:WU00:FS00:0xa7: Threads: POSIX_THREADS
16:22:53:WU00:FS00:0xa7: OS Version: 5.12
16:22:53:WU00:FS00:0xa7:Has Battery: true
16:22:53:WU00:FS00:0xa7: On Battery: false
16:22:53:WU00:FS00:0xa7: UTC Offset: -4
16:22:53:WU00:FS00:0xa7: PID: 3028
16:22:53:WU00:FS00:0xa7: CWD: /var/lib/private/fah/work
16:22:53:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:22:53:WU00:FS00:0xa7: Version: 0.0.19
16:22:53:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:22:53:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
16:22:53:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
16:22:53:WU00:FS00:0xa7: Date: Nov 26 2019
16:22:53:WU00:FS00:0xa7: Time: 00:41:42
16:22:53:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
16:22:53:WU00:FS00:0xa7:************************************ Build *************************************
16:22:53:WU00:FS00:0xa7: SIMD: avx_256
16:22:53:WU00:FS00:0xa7:********************************************************************************
16:22:53:WU00:FS00:0xa7:Project: 17231 (Run 8691, Clone 0, Gen 1)
16:22:53:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
16:22:53:WU00:FS00:0xa7:Digital signatures verified
16:22:53:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -x frame1.xtc -cpi state.cpt -cpt 15 -nt 1
16:22:54:WU00:FS00:0xa7:Steps: first=62500 total=62500
16:17:07: Bits: 64
16:17:07: Bits: 64
16:17:07: Bits: 64
16:17:07: CPUs: 8
16:17:07: PID: 2522
16:17:07: GPUs: 1
16:17:07:<config>
16:17:07:
16:17:07:
16:17:07:</config>
Posts: 20824 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Sun Apr 11, 2021 8:16 pm
As JimboPalmer suggests, a GPU assignment defaults to using 1 CPU and that's commonly about right. Almost all the "heavy" computations are done on the GPU and won''t show up on the typical CPU monitoring app. That leaves (N-1) threads that can be allocated to a CPU assignment at your discretion.
Post
by JimboPalmer » Sun Apr 11, 2021 9:12 pm
Something is causing your PC to 'downshift' from 7 to 1 CPU. This can be just that the first WU is traditionally single threaded. (-np1, sometimes you see -nt1)
Is there any chance you have not let the first WU complete?
(You can lower the number of threads during a WU, but can only increase the number of threads on the beginning of the next WU.)
OrsPervIe
Post
by OrsPervIe » Sun Apr 11, 2021 9:27 pm
Now I got things the way I was looking for. Info I was reading really can be confusing as to what the different settings do. Including that doing one thread at a time was faster.
Each individual unit may take a little longer but put together is much work.
Post
by JimboPalmer » Sun Apr 11, 2021 9:55 pm
There was a 'feature' where the client started the first CPU WU before it read haw many CPU threads it had, so the first WU was always 1. I am unsure if that is still true.
For each GPU you have installed, the number of CPU threads is lowered by 1. So your 8 thread CPU is seen as 7.
Earlier clients had issues with 'large' primes and 'large' prime factors. Sometimes 5 and always all primes greater then 5. So when the number of threads available was a prime, the client lowered by 1 and tried again. Newer clients can jump by more than one.
If we decide you need to specify how many 'CPUs' to use, I vote 6.
You seem to have a MX330 GPU, is this perhaps a laptop?
https://www.techpowerup.com/gpu-specs/g ... x330.c3493
It should be about the same folding power as a Desktop GT 1030.
