Intel HD Graphics 620 not working - add to list?
LoveCrypto
Post by LoveCrypto »
Hi,
The Folding Client is not registering the Intel HD Graphics 620 on my laptop. I looked in GPUI.txt and it does appear there is an entry. However, when I run the command from the windows prompt the output looks a bit different. Can you check and add whatever is needed in order to be able to use this card?
PS C:\Program Files (x86)\FAHClient> fahclient --lspci
0x8086:0x5904:0:0:0:Intel Corporation:Intel(R) Xeon(R) E3 - 1200 v6/7th Gen Intel(R) Core(TM) Host Bridge/DRAM Registers - 5904
0x8086:0x9d21:0:31:2:Intel Corporation:Mobile 6th/7th Generation Intel(R) Processor Family I/O PMC - 9D21
0x8086:0x9d60:0:21:0:Intel Corporation:Intel(R) Serial IO I2C Host Controller - 9D60
0x8086:0x9d14:0:28:0:Intel Corporation:Mobile 6th/7th Generation Intel(R) Processor Family I/O PCI Express Root Port #5 - 9D14
0x8086:0x9d71:0:31:3:Intel Corporation:High Definition Audio Controller
0x8086:0x9d2f:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x10ec:0x8136:2:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIe FE Family Controller
0x8086:0x9d23:0:31:4:Intel Corporation:Mobile 6th/7th Generation Intel(R) Processor Family I/O SMBUS - 9D23
0x8086:0x1903:0:4:0:Intel Corporation:Intel(R) Dynamic Platform and Thermal Framework Processor Participant
0x168c:0x0036:1:0:0:Qualcomm Atheros:Qualcomm QCA9565 802.11b/g/n Wireless Adapter
0x8086:0x9d31:0:20:2:Intel Corporation:Mobile 6th/7th Generation Intel(R) Processor Family I/O Thermal subsystem - 9D31
0x8086:0x5916:0:2:0:Intel Corporation:Intel(R) HD Graphics 620
0x8086:0x9d03:0:23:0:Intel Corporation:Intel(R) 6th Generation Core Processor Family Platform I/O SATA AHCI Controller
0x8086:0x9d3a:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x9d58:0:31:0:Intel Corporation:Mobile 7th Generation Intel(R) Processor Family I/O LPC Controller (U Premium) - 9D58
0x8086:0x9d61:0:21:1:Intel Corporation:Intel(R) Serial IO I2C Host Controller - 9D61
0x8086:0x9d15:0:28:5:Intel Corporation:Mobile 6th/7th Generation Intel(R) Processor Family I/O PCI Express Root Port #6 - 9D15
Re: Intel HD Graphics 620 not working - add to list?
That particular Intel iGPU is currently in the list based on its device ID shown in the lspci output:
0x8086:0x5916:3:1:KBL GT2 [HD Graphics 620]
However use of the Intel iGPUs is a beta test at this point, and there are limited projects set up to be assigned to them. We would need to see what is recorded in your log to see if there is anything additional you can do to get an assignment for this iGPU. The first couple hundred lines of the log should be enough.
LoveCrypto
Here is what is in the log.
*********************** Log Started 2021-04-02T19:06:23Z ***********************
19:06:23:******************************* libFAH ********************************
19:06:23:           Date: Oct 20 2020
19:06:23:           Time: 13:36:55
19:06:23:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
19:06:23:         Branch: master
19:06:23:       Compiler: Visual C++ 2015
19:06:23:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:06:23:       Platform: win32 10
19:06:23:           Bits: 32
19:06:23:           Mode: Release
19:06:23:****************************** FAHClient ******************************
19:06:23:        Version: 7.6.21
19:06:23:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:06:23:      Copyright: 2020 foldingathome.org
19:06:23:       Homepage: https://foldingathome.org/
19:06:23:           Time: 13:41:04
19:06:23:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
19:06:23:           Bits: 32
19:06:23:           Args: --open-web-control
19:06:23:         Config: C:\ProgramData\FAHClient\config.xml
19:06:23:******************************** CBang ********************************
19:06:23:           Time: 11:36:18
19:06:23:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
19:06:23:           Bits: 32
19:06:23:******************************* System ********************************
19:06:23:            CPU: Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
19:06:23:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
19:06:23:           CPUs: 4
19:06:23:         Memory: 5.87GiB
19:06:23:    Free Memory: 2.02GiB
19:06:23:        Threads: WINDOWS_THREADS
19:06:23:     OS Version: 6.2
19:06:23:    Has Battery: true
19:06:23:     On Battery: false
19:06:23:     UTC Offset: -7
19:06:23:            PID: 1008
19:06:23:            CWD: C:\ProgramData\FAHClient
19:06:23:  Win32 Service: false
19:06:23:             OS: Windows 10 Home
19:06:23:        OS Arch: AMD64
19:06:23:           GPUs: 1
19:06:23:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 620]
19:06:23:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
19:06:23:                 specified module could not be found.
19:06:23:
19:06:23:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:23.20
19:06:23:***********************************************************************
19:06:23:<config>
19:06:23:  <!-- Network -->
19:06:23:  <proxy v=':8080'/>
19:06:23:
19:06:23:  <!-- Slot Control -->
19:06:23:  <power v='FULL'/>
19:06:23:
19:06:23:  <!-- User Information -->
19:06:23:  <passkey v='*****'/>
19:06:23:  <team v='224497'/>
19:06:23:  <user v='LoveCrypto'/>
19:06:23:
19:06:23:  <!-- Folding Slots -->
19:06:23:  <slot id='0' type='CPU'/>
19:06:23:  <slot id='1' type='GPU'>
19:06:23:    <pci-bus v='0'/>
19:06:23:    <pci-slot v='2'/>
19:06:23:  </slot>
19:06:23:</config>
19:06:23:Trying to access database...
19:06:23:Successfully acquired database lock
19:06:23:FS00:Initialized folding slot 00: cpu:3
19:06:23:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 KBL GT2 [HD Graphics 620].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
19:06:23:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 KBL GT2 [HD Graphics 620].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
19:06:23:WU00:FS00:Starting
19:06:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 1008 -checkpoint 15 -np 3
19:06:23:WU00:FS00:Started FahCore on PID 5000
19:06:24:WU00:FS00:Core PID:12984
19:06:24:WU00:FS00:FahCore 0xa8 started
19:06:24:WU00:FS00:0xa8:*********************** Log Started 2021-04-02T19:06:24Z ***********************
19:06:25:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:06:25:WU00:FS00:0xa8:       Core: Gromacs
19:06:25:WU00:FS00:0xa8:       Type: 0xa8
19:06:25:WU00:FS00:0xa8:    Version: 0.0.12
19:06:25:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:06:25:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
19:06:25:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
19:06:25:WU00:FS00:0xa8:       Date: Jan 16 2021
19:06:25:WU00:FS00:0xa8:       Time: 12:29:40
19:06:25:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
19:06:25:WU00:FS00:0xa8:     Branch: master
19:06:25:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
19:06:25:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:06:25:WU00:FS00:0xa8:   Platform: win32 10
19:06:25:WU00:FS00:0xa8:       Bits: 64
19:06:25:WU00:FS00:0xa8:       Mode: Release
19:06:25:WU00:FS00:0xa8:       SIMD: avx2_256
19:06:25:WU00:FS00:0xa8:     OpenMP: ON
19:06:25:WU00:FS00:0xa8:       CUDA: OFF
19:06:25:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5000 -checkpoint 15 -np 3
19:06:25:WU00:FS00:0xa8:************************************ libFAH ************************************
19:06:25:WU00:FS00:0xa8:       Time: 11:24:13
19:06:25:WU00:FS00:0xa8:************************************ CBang *************************************
19:06:25:WU00:FS00:0xa8:       Time: 11:23:53
19:06:25:WU00:FS00:0xa8:************************************ System ************************************
19:06:25:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
19:06:25:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
19:06:25:WU00:FS00:0xa8:       CPUs: 4
19:06:25:WU00:FS00:0xa8:     Memory: 5.87GiB
19:06:25:WU00:FS00:0xa8:Free Memory: 1.98GiB
19:06:25:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
19:06:25:WU00:FS00:0xa8: OS Version: 6.2
19:06:25:WU00:FS00:0xa8:Has Battery: true
19:06:25:WU00:FS00:0xa8: On Battery: false
19:06:25:WU00:FS00:0xa8: UTC Offset: -7
19:06:25:WU00:FS00:0xa8:        PID: 12984
19:06:25:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
19:06:25:WU00:FS00:0xa8:********************************************************************************
19:06:25:WU00:FS00:0xa8:Project: 16815 (Run 25, Clone 386, Gen 31)
19:06:25:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
19:06:25:WU00:FS00:0xa8:Digital signatures verified
19:06:25:WU00:FS00:0xa8:Calling: mdrun -c frame31.gro -s frame31.tpr -x frame31.xtc -cpi state.cpt -cpt 15 -nt 3 -ntmpi 1
19:06:26:WU00:FS00:0xa8:Steps: first=0 total=500000
19:06:30:WU00:FS00:0xa8:Completed 329202 out of 500000 steps (65%)
19:06:32:5:127.0.0.1:New Web session
19:07:43:WU00:FS00:0xa8:Completed 330000 out of 500000 steps (66%)
19:15:50:WU00:FS00:0xa8:Completed 335000 out of 500000 steps (67%)
19:24:31:WU00:FS00:0xa8:Completed 340000 out of 500000 steps (68%)
19:32:48:WU00:FS00:0xa8:Completed 345000 out of 500000 steps (69%)
19:40:38:WU00:FS00:0xa8:Completed 350000 out of 500000 steps (70%)
19:49:04:WU00:FS00:0xa8:Completed 355000 out of 500000 steps (71%)
19:57:27:WU00:FS00:0xa8:Completed 360000 out of 500000 steps (72%)
20:05:54:WU00:FS00:0xa8:Completed 365000 out of 500000 steps (73%)
20:13:25:WU00:FS00:0xa8:Completed 370000 out of 500000 steps (74%)
20:20:53:WU00:FS00:0xa8:Completed 375000 out of 500000 steps (75%)
20:28:24:WU00:FS00:0xa8:Completed 380000 out of 500000 steps (76%)
20:35:51:WU00:FS00:0xa8:Completed 385000 out of 500000 steps (77%)
20:38:33:14:127.0.0.1:New Web session
20:45:07:WU00:FS00:0xa8:Completed 390000 out of 500000 steps (78%)
20:54:01:WU00:FS00:0xa8:Completed 395000 out of 500000 steps (79%)
21:01:38:WU00:FS00:0xa8:Completed 400000 out of 500000 steps (80%)
Reason: added Code tags to log
Folding with the Intel GPU is still considered to be beta testing.
1) You need the latest driver from Intel or Microsoft.
2) You'll have to add the noted setting to your configuration with FAHControl: ``gpu-beta=true`` and restart.
3) Even with the GPU enabled, you may have trouble getting assignments.
4) You'll probably still earn 0 points.
Jonazz
Post by Jonazz »
I haven't received any work for my Intel GPU for a few weeks now.
I predict that they're going to have to customize the protein pool. FAH's workload has outgrown the capabilities of all but the newest iGPUs. If FAH ever releases a client to run on Android it will face a similar hurdle, but a higher one because portable phones don't connect to the charger 24x7 while the HD Graphics 620 is available 24x7 in spite as being extremely slow.
