Hello,
I'm already folding using 3 other computers. I freshly reinstalled a 4th one; but I'm unable to get a WU.
switching to "full" or "light" didn't help. Can you help me?
***EDIT :
worked about an hour after first attempt. strange because it's my faster computer and the other ones got WU much quicker
unable to get WU on a fresh installed computer
Re: unable to get WU on a fresh installed computer
Full vs. Light will not change the assignment process -- only the rate of progress on work that has already been assigned (and potentially the heat generated inside your computer when it's working).
FAH is short of work to be assigned. There are several new projects being beta tested which should be ready to assign to the public soon.
