RX 480 - Problems
iero
RX 480 - Problems
Post by iero »
I just set up a second rig for folding, with the following specs:
Ryzen 3 2200g
8GB 3000Mhz
RX 480 4GB Gaming X by MSI
So, I started folding. First WU is from Project 13438.
At first, GPU usage was steady at around 75%. Then it started spiking from 0 to 100% over and over again.
Nothing weird in the logs, only checkpoints. Then after about 3 hours, the local folding browser page told me that the
app probably terminated, but the icon was still there at the lower right corner and gpu usage was back at ~75%.
As soon as I clicked on the icon, the pc just froze. Had to use the on button to close it down.
After the restart minimal progress seemed to be lost, and gpu load averages at 17%.
Any ideas what is going on?
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
Re: RX 480 - Project 13438
No, I sure don't. Perhaps if you gave us the first 200 lines of your log, (where the configuration details are) we would have enough details. (What OS, what Driver, etc.)
viewtopic.php?f=24&t=26036
Will help you get us that info.
iero
Post by iero »
*********************** Log Started 2021-03-13T13:56:56Z ***********************
13:56:56:******************************* libFAH ********************************
13:56:56:           Date: Oct 20 2020
13:56:56:           Time: 13:36:55
13:56:56:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
13:56:56:         Branch: master
13:56:56:       Compiler: Visual C++ 2015
13:56:56:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:56:56:       Platform: win32 10
13:56:56:           Bits: 32
13:56:56:           Mode: Release
13:56:56:****************************** FAHClient ******************************
13:56:56:        Version: 7.6.21
13:56:56:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:56:56:      Copyright: 2020 foldingathome.org
13:56:56:       Homepage: https://foldingathome.org/
13:56:56:           Time: 13:41:04
13:56:56:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
13:56:56:           Bits: 32
13:56:56:           Args: --open-web-control
13:56:56:         Config: C:\ProgramData\FAHClient\config.xml
13:56:56:******************************** CBang ********************************
13:56:56:           Time: 11:36:18
13:56:56:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
13:56:56:           Bits: 32
13:56:56:******************************* System ********************************
13:56:56:            CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
13:56:56:         CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
13:56:56:           CPUs: 4
13:56:56:         Memory: 7.93GiB
13:56:56:    Free Memory: 5.92GiB
13:56:56:        Threads: WINDOWS_THREADS
13:56:56:     OS Version: 6.2
13:56:56:    Has Battery: false
13:56:56:     On Battery: false
13:56:56:     UTC Offset: 2
13:56:56:            PID: 5692
13:56:56:            CWD: C:\ProgramData\FAHClient
13:56:56:  Win32 Service: false
13:56:56:             OS: Windows 10 Enterprise
13:56:56:        OS Arch: AMD64
13:56:56:           GPUs: 1
13:56:56:          GPU 0: Bus:16 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
13:56:56:                 470/480/570/580/590]
13:56:56:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
13:56:56:                 specified module could not be found.
13:56:56:
13:56:56:OpenCL Device 0: Platform:0 Device:0 Bus:16 Slot:0 Compute:1.2 Driver:3188.4
13:56:56:***********************************************************************
13:56:56:<config>
13:56:56:  <!-- Network -->
13:56:56:  <proxy v=':8080'/>
13:56:56:
13:56:56:  <!-- Slot Control -->
13:56:56:  <power v='FULL'/>
13:56:56:
13:56:56:  <!-- User Information -->
13:56:56:  <passkey v='*****'/>
13:56:56:  <team v='838'/>
13:56:56:  <user v='iero'/>
13:56:56:
13:56:56:  <!-- Folding Slots -->
13:56:56:  <slot id='0' type='CPU'/>
13:56:56:  <slot id='2' type='GPU'>
13:56:56:    <pci-bus v='16'/>
13:56:56:    <pci-slot v='0'/>
13:56:56:  </slot>
13:56:56:</config>
13:56:56:Trying to access database...
13:56:56:Successfully acquired database lock
13:56:56:FS00:Initialized folding slot 00: cpu:3
13:56:56:FS02:Initialized folding slot 02: gpu:16:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
13:56:56:WU00:FS00:Starting
13:56:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 5692 -checkpoint 15 -np 3
13:56:56:WU00:FS00:Started FahCore on PID 7968
13:56:56:WU00:FS00:Core PID:4356
13:56:56:WU00:FS00:FahCore 0xa7 started
13:56:57:WU00:FS00:0xa7:*********************** Log Started 2021-03-13T13:56:56Z ***********************
13:56:57:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:56:57:WU00:FS00:0xa7:       Type: 0xa7
13:56:57:WU00:FS00:0xa7:       Core: Gromacs
13:56:57:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7968 -checkpoint 15 -np 3
13:56:57:WU00:FS00:0xa7:************************************ CBang *************************************
13:56:57:WU00:FS00:0xa7:       Date: Nov 27 2019
13:56:57:WU00:FS00:0xa7:       Time: 03:40:09
13:56:57:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
13:56:57:WU00:FS00:0xa7:     Branch: master
13:56:57:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:56:57:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:56:57:WU00:FS00:0xa7:   Platform: win32 10
13:56:57:WU00:FS00:0xa7:       Bits: 64
13:56:57:WU00:FS00:0xa7:       Mode: Release
13:56:57:WU00:FS00:0xa7:************************************ System ************************************
13:56:57:WU00:FS00:0xa7:        CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
13:56:57:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
13:56:57:WU00:FS00:0xa7:       CPUs: 4
13:56:57:WU00:FS00:0xa7:     Memory: 7.93GiB
13:56:57:WU00:FS00:0xa7:Free Memory: 5.89GiB
13:56:57:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:56:57:WU00:FS00:0xa7: OS Version: 6.2
13:56:57:WU00:FS00:0xa7:Has Battery: false
13:56:57:WU00:FS00:0xa7: On Battery: false
13:56:57:WU00:FS00:0xa7: UTC Offset: 2
13:56:57:WU00:FS00:0xa7:        PID: 4356
13:56:57:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
13:56:57:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:56:57:WU00:FS00:0xa7:    Version: 0.0.19
13:56:57:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:56:57:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:56:57:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
13:56:57:WU00:FS00:0xa7:       Date: Nov 25 2019
13:56:57:WU00:FS00:0xa7:       Time: 17:12:41
13:56:57:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
13:56:57:WU00:FS00:0xa7:************************************ Build *************************************
13:56:57:WU00:FS00:0xa7:       SIMD: avx_256
13:56:57:WU00:FS00:0xa7:********************************************************************************
13:56:57:WU00:FS00:0xa7:Project: 17231 (Run 1227, Clone 2, Gen 15)
13:56:57:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
13:56:57:WU00:FS00:0xa7:Digital signatures verified
13:56:57:WU00:FS00:0xa7:Calling: mdrun -s frame15.tpr -o frame15.trr -x frame15.xtc -cpi state.cpt -cpt 15 -nt 3
13:56:57:WU01:FS02:Starting
13:56:57:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5692 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
13:56:57:WU01:FS02:Started FahCore on PID 1660
13:56:58:WU01:FS02:Core PID:7580
13:56:58:WU01:FS02:FahCore 0x22 started
13:56:58:WU00:FS00:0xa7:Steps: first=937500 total=62500
13:56:58:WU01:FS02:0x22:*********************** Log Started 2021-03-13T13:56:58Z ***********************
13:56:58:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
13:56:58:WU01:FS02:0x22:       Core: Core22
13:56:58:WU01:FS02:0x22:       Type: 0x22
13:56:58:WU01:FS02:0x22:    Version: 0.0.13
13:56:58:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:56:58:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
13:56:58:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
13:56:58:WU01:FS02:0x22:       Date: Sep 19 2020
13:56:58:WU01:FS02:0x22:       Time: 02:35:58
13:56:58:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
13:56:58:WU01:FS02:0x22:     Branch: core22-0.0.13
13:56:58:WU01:FS02:0x22:   Compiler: Visual C++ 2015
13:56:58:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
13:56:58:WU01:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
13:56:58:WU01:FS02:0x22:   Platform: win32 10
13:56:58:WU01:FS02:0x22:       Bits: 64
13:56:58:WU01:FS02:0x22:       Mode: Release
13:56:58:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
13:56:58:WU01:FS02:0x22:             <peastman@stanford.edu>
13:56:58:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1660 -checkpoint 15
13:56:58:WU01:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
13:56:58:WU01:FS02:0x22:             -gpu-usage 100
13:56:58:WU01:FS02:0x22:************************************ libFAH ************************************
13:56:58:WU01:FS02:0x22:       Date: Sep 7 2020
13:56:58:WU01:FS02:0x22:       Time: 19:09:56
13:56:58:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
13:56:58:WU01:FS02:0x22:     Branch: HEAD
13:56:58:WU01:FS02:0x22:************************************ CBang *************************************
13:56:58:WU01:FS02:0x22:       Time: 19:08:30
13:56:58:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
13:56:58:WU01:FS02:0x22:************************************ System ************************************
13:56:58:WU01:FS02:0x22:        CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
13:56:58:WU01:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
13:56:58:WU01:FS02:0x22:       CPUs: 4
13:56:58:WU01:FS02:0x22:     Memory: 7.93GiB
13:56:58:WU01:FS02:0x22:Free Memory: 5.79GiB
13:56:58:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
13:56:58:WU01:FS02:0x22: OS Version: 6.2
13:56:58:WU01:FS02:0x22:Has Battery: false
13:56:58:WU01:FS02:0x22: On Battery: false
13:56:58:WU01:FS02:0x22: UTC Offset: 2
13:56:58:WU01:FS02:0x22:        PID: 7580
13:56:58:WU01:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
13:56:58:WU01:FS02:0x22:************************************ OpenMM ************************************
13:56:58:WU01:FS02:0x22:   Revision: 189320d0
13:56:58:WU01:FS02:0x22:********************************************************************************
13:56:58:WU01:FS02:0x22:Project: 13438 (Run 4282, Clone 52, Gen 1)
13:56:58:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
13:56:58:WU01:FS02:0x22:Digital signatures verified
13:56:58:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
13:56:58:WU01:FS02:0x22:Version 0.0.13
13:56:58:WU01:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
13:56:58:WU01:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
13:56:58:WU01:FS02:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
13:56:58:WU01:FS02:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
13:56:58:WU01:FS02:0x22:There are 3 platforms available.
13:56:58:WU01:FS02:0x22:Platform 0: Reference
13:56:58:WU01:FS02:0x22:Platform 1: CPU
13:56:58:WU01:FS02:0x22:Platform 2: OpenCL
13:56:58:WU01:FS02:0x22:  opencl-device 0 specified
13:57:04:WU00:FS00:0xa7:Completed 29391 out of 62500 steps (47%)
13:57:14:WU01:FS02:0x22:Attempting to create OpenCL context:
13:57:14:WU01:FS02:0x22:  Configuring platform OpenCL
13:57:23:26:127.0.0.1:New Web session
13:57:28:WU01:FS02:0x22:  Using OpenCL on platformId 0 and gpu 0
There you go! If I find the time i'll try to DDU back to another driver, cause I think im using a BETA one
GPU only
https://www.amd.com/en/support/graphics ... eon-rx-480
seems to be the current driver for Win 10 64 Bit
https://www.techpowerup.com/gpu-specs/r ... -480.c2848
Your log stops just before it tries to start Core_22 on your GPU.
Your CPU has embedded graphics, do you have a graphics card as well or is F@H finding your 2200g as a RX 480? It it is the embedded GPU
https://www.amd.com/en/support/apu/amd- ... -ryzen-3-0
https://www.techpowerup.com/gpu-specs/r ... ga-8.c3042
iero
Post by iero »
I only cut of the rest of the log,cause it was just steps for the CPU and the GPU.
Its right there, in the log.
No, the vega 8 graphics are shown as stopped in F@H.
And GPU 0 is RX 480. With a new WU from project 17433 gpu usage is averaging 76%.
It could be just a fluke.
GPU only
iero
Post by iero »
+2 WUs later GPU load still averaging 76%.
GPU only
Which app are you using to determine the GPU's performance level? (Many folks happen upon the CPU performance level associated with FAHCore_22.)
iero
Post by iero »
I'm using GPU-Z and MSI Afterburner to monitor Usage and Power Draw, since I'm always trying to aim for the best efficiency. Todays WUs are up to 91% usage. There are still some 0% spikes that do not seem to correspond to anything particular (say checkpoints).
GPU only
iero
Re: RX 480 - Problems
Post by iero »
*********************** Log Started 2021-03-16T06:25:21Z ***********************
06:25:21:******************************* libFAH ********************************
06:25:21:           Date: Oct 20 2020
06:25:21:           Time: 13:36:55
06:25:21:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
06:25:21:         Branch: master
06:25:21:       Compiler: Visual C++ 2015
06:25:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
06:25:21:       Platform: win32 10
06:25:21:           Bits: 32
06:25:21:           Mode: Release
06:25:21:****************************** FAHClient ******************************
06:25:21:        Version: 7.6.21
06:25:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:25:21:      Copyright: 2020 foldingathome.org
06:25:21:       Homepage: https://foldingathome.org/
06:25:21:           Time: 13:41:04
06:25:21:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
06:25:21:           Bits: 32
06:25:21:           Args: --open-web-control
06:25:21:         Config: C:\ProgramData\FAHClient\config.xml
06:25:21:******************************** CBang ********************************
06:25:21:           Time: 11:36:18
06:25:21:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
06:25:21:           Bits: 32
06:25:21:******************************* System ********************************
06:25:21:            CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
06:25:21:         CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
06:25:21:           CPUs: 4
06:25:21:         Memory: 7.93GiB
06:25:21:    Free Memory: 5.70GiB
06:25:21:        Threads: WINDOWS_THREADS
06:25:21:     OS Version: 6.2
06:25:21:    Has Battery: false
06:25:21:     On Battery: false
06:25:21:     UTC Offset: 2
06:25:21:            PID: 6608
06:25:21:            CWD: C:\ProgramData\FAHClient
06:25:21:  Win32 Service: false
06:25:21:             OS: Windows 10 Enterprise
06:25:21:        OS Arch: AMD64
06:25:21:           GPUs: 1
06:25:21:          GPU 0: Bus:16 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
06:25:21:                 470/480/570/580/590]
06:25:21:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
06:25:21:                 specified module could not be found.
06:25:21:
06:25:21:OpenCL Device 0: Platform:0 Device:0 Bus:16 Slot:0 Compute:1.2 Driver:3188.4
06:25:21:***********************************************************************
06:25:21:<config>
06:25:21:  <!-- Network -->
06:25:21:  <proxy v=':8080'/>
06:25:21:
06:25:21:  <!-- Slot Control -->
06:25:21:  <power v='FULL'/>
06:25:21:
06:25:21:  <!-- User Information -->
06:25:21:  <passkey v='*****'/>
06:25:21:  <team v='838'/>
06:25:21:  <user v='iero'/>
06:25:21:
06:25:21:  <!-- Folding Slots -->
06:25:21:  <slot id='0' type='CPU'>
06:25:21:    <pause-on-start v='true'/>
06:25:21:  </slot>
06:25:21:  <slot id='2' type='GPU'>
06:25:21:    <pci-bus v='16'/>
06:25:21:    <pci-slot v='0'/>
06:25:21:  </slot>
06:25:21:</config>
06:25:21:Trying to access database...
06:25:21:Successfully acquired database lock
06:25:21:FS00:Initialized folding slot 00: cpu:3
06:25:21:FS02:Initialized folding slot 02: gpu:16:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
06:25:21:WU00:FS02:Connecting to assign1.foldingathome.org:80
06:25:23:WU00:FS02:Assigned to work server 128.174.73.74
06:25:23:WU00:FS02:Requesting new work unit for slot 02: gpu:16:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.174.73.74
06:25:23:WU00:FS02:Connecting to 128.174.73.74:8080
06:25:24:ERROR:WU00:FS02:Exception: Server did not assign work unit
06:25:24:WU00:FS02:Connecting to assign1.foldingathome.org:80
06:25:25:WU00:FS02:Assigned to work server 128.174.73.74
06:25:25:WU00:FS02:Requesting new work unit for slot 02: gpu:16:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.174.73.74
06:25:25:WU00:FS02:Connecting to 128.174.73.74:8080
06:25:26:14:127.0.0.1:New Web session
06:25:37:WU00:FS02:Downloading 11.69MiB
06:25:43:WU00:FS02:Download 17.10%
06:25:49:WU00:FS02:Download 61.47%
06:25:53:WU00:FS02:Download complete
06:25:53:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17722 run:22 clone:0 gen:76 core:0x22 unit:0x000000000000004c0000453a00000016
06:25:53:WU00:FS02:Starting
06:25:53:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 6608 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
06:25:53:WU00:FS02:Started FahCore on PID 7436
06:25:53:WU00:FS02:Core PID:8132
06:25:53:WU00:FS02:FahCore 0x22 started
06:25:54:WU00:FS02:0x22:*********************** Log Started 2021-03-16T06:25:53Z ***********************
06:25:54:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
06:25:54:WU00:FS02:0x22:       Core: Core22
06:25:54:WU00:FS02:0x22:       Type: 0x22
06:25:54:WU00:FS02:0x22:    Version: 0.0.13
06:25:54:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:25:54:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
06:25:54:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
06:25:54:WU00:FS02:0x22:       Date: Sep 19 2020
06:25:54:WU00:FS02:0x22:       Time: 02:35:58
06:25:54:WU00:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
06:25:54:WU00:FS02:0x22:     Branch: core22-0.0.13
06:25:54:WU00:FS02:0x22:   Compiler: Visual C++ 2015
06:25:54:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
06:25:54:WU00:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
06:25:54:WU00:FS02:0x22:   Platform: win32 10
06:25:54:WU00:FS02:0x22:       Bits: 64
06:25:54:WU00:FS02:0x22:       Mode: Release
06:25:54:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:25:54:WU00:FS02:0x22:             <peastman@stanford.edu>
06:25:54:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7436 -checkpoint 15
06:25:54:WU00:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
06:25:54:WU00:FS02:0x22:             -gpu-usage 100
06:25:54:WU00:FS02:0x22:************************************ libFAH ************************************
06:25:54:WU00:FS02:0x22:       Date: Sep 7 2020
06:25:54:WU00:FS02:0x22:       Time: 19:09:56
06:25:54:WU00:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
06:25:54:WU00:FS02:0x22:     Branch: HEAD
06:25:54:WU00:FS02:0x22:************************************ CBang *************************************
06:25:54:WU00:FS02:0x22:       Time: 19:08:30
06:25:54:WU00:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
06:25:54:WU00:FS02:0x22:************************************ System ************************************
06:25:54:WU00:FS02:0x22:        CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
06:25:54:WU00:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
06:25:54:WU00:FS02:0x22:       CPUs: 4
06:25:54:WU00:FS02:0x22:     Memory: 7.93GiB
06:25:54:WU00:FS02:0x22:Free Memory: 5.50GiB
06:25:54:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
06:25:54:WU00:FS02:0x22: OS Version: 6.2
06:25:54:WU00:FS02:0x22:Has Battery: false
06:25:54:WU00:FS02:0x22: On Battery: false
06:25:54:WU00:FS02:0x22: UTC Offset: 2
06:25:54:WU00:FS02:0x22:        PID: 8132
06:25:54:WU00:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
06:25:54:WU00:FS02:0x22:************************************ OpenMM ************************************
06:25:54:WU00:FS02:0x22:   Revision: 189320d0
06:25:54:WU00:FS02:0x22:********************************************************************************
06:25:54:WU00:FS02:0x22:Project: 17722 (Run 22, Clone 0, Gen 76)
06:25:54:WU00:FS02:0x22:Unit: 0x00000000000000000000000000000000
06:25:54:WU00:FS02:0x22:Reading tar file core.xml
06:25:54:WU00:FS02:0x22:Reading tar file integrator.xml
06:25:54:WU00:FS02:0x22:Reading tar file state.xml
06:25:54:WU00:FS02:0x22:Reading tar file system.xml
06:25:56:WU00:FS02:0x22:Digital signatures verified
06:25:56:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
06:25:56:WU00:FS02:0x22:Version 0.0.13
06:25:56:WU00:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
06:25:56:WU00:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
06:25:56:WU00:FS02:0x22:  XTC frame write interval: 25000 steps (2.5%) [40 total]
06:25:56:WU00:FS02:0x22:  Global context and integrator variables write interval: disabled
06:25:56:WU00:FS02:0x22:There are 3 platforms available.
06:25:56:WU00:FS02:0x22:Platform 0: Reference
06:25:56:WU00:FS02:0x22:Platform 1: CPU
06:25:56:WU00:FS02:0x22:Platform 2: OpenCL
06:25:56:WU00:FS02:0x22:  opencl-device 0 specified
06:26:10:WU00:FS02:0x22:Attempting to create OpenCL context:
06:26:10:WU00:FS02:0x22:  Configuring platform OpenCL
06:26:25:WU00:FS02:0x22:  Using OpenCL on platformId 0 and gpu 0
06:26:25:WU00:FS02:0x22:Completed 0 out of 1000000 steps (0%)
06:26:27:WU00:FS02:0x22:Checkpoint completed at step 0
06:28:25:WU00:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
06:30:21:WU00:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
09:24:51:WU00:FS02:0x22:Completed 940000 out of 1000000 steps (94%)
09:26:44:WU00:FS02:0x22:Completed 950000 out of 1000000 steps (95%)
09:26:47:WU00:FS02:0x22:Checkpoint completed at step 950000
09:28:40:WU00:FS02:0x22:Completed 960000 out of 1000000 steps (96%)
09:30:33:WU00:FS02:0x22:Completed 970000 out of 1000000 steps (97%)
09:32:26:WU00:FS02:0x22:Completed 980000 out of 1000000 steps (98%)
09:34:19:WU00:FS02:0x22:Completed 990000 out of 1000000 steps (99%)
09:34:20:WU01:FS02:Connecting to assign1.foldingathome.org:80
09:34:21:WU01:FS02:Assigned to work server 128.174.73.74
09:34:21:WU01:FS02:Requesting new work unit for slot 02: gpu:16:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.174.73.74
09:34:21:WU01:FS02:Connecting to 128.174.73.74:8080
09:34:39:WU01:FS02:Downloading 11.69MiB
09:34:45:WU01:FS02:Download 37.96%
09:34:50:WU01:FS02:Download complete
09:34:50:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17722 run:92 clone:1 gen:17 core:0x22 unit:0x00000001000000110000453a0000005c
09:36:16:WU00:FS02:0x22:An exception occurred at step 999481: Particle coordinate is nan
09:36:16:WU00:FS02:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
09:36:16:WU00:FS02:0x22:Folding@home Core Shutdown: CORE_RESTART
09:36:17:WARNING:WU00:FS02:FahCore returned: CORE_RESTART (98 = 0x62)
09:36:17:WU01:FS02:Starting
09:36:17:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 6608 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
09:36:17:WU01:FS02:Started FahCore on PID 856
09:36:17:WU01:FS02:Core PID:3704
09:36:17:WU01:FS02:FahCore 0x22 started
09:36:17:WU01:FS02:0x22:*********************** Log Started 2021-03-16T09:36:17Z ***********************
09:36:17:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
09:36:17:WU01:FS02:0x22:       Core: Core22
09:36:17:WU01:FS02:0x22:       Type: 0x22
09:36:17:WU01:FS02:0x22:    Version: 0.0.13
09:36:17:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:36:17:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
09:36:17:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
09:36:17:WU01:FS02:0x22:       Date: Sep 19 2020
09:36:17:WU01:FS02:0x22:       Time: 02:35:58
09:36:17:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
09:36:17:WU01:FS02:0x22:     Branch: core22-0.0.13
09:36:17:WU01:FS02:0x22:   Compiler: Visual C++ 2015
09:36:17:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
09:36:17:WU01:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
09:36:17:WU01:FS02:0x22:   Platform: win32 10
09:36:17:WU01:FS02:0x22:       Bits: 64
09:36:17:WU01:FS02:0x22:       Mode: Release
09:36:17:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:36:17:WU01:FS02:0x22:             <peastman@stanford.edu>
09:36:17:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 856 -checkpoint 15
09:36:17:WU01:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
09:36:17:WU01:FS02:0x22:             -gpu-usage 100
09:36:17:WU01:FS02:0x22:************************************ libFAH ************************************
09:36:17:WU01:FS02:0x22:       Date: Sep 7 2020
09:36:17:WU01:FS02:0x22:       Time: 19:09:56
09:36:17:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
09:36:17:WU01:FS02:0x22:     Branch: HEAD
09:36:17:WU01:FS02:0x22:************************************ CBang *************************************
09:36:17:WU01:FS02:0x22:       Time: 19:08:30
09:36:17:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
09:36:17:WU01:FS02:0x22:************************************ System ************************************
09:36:17:WU01:FS02:0x22:        CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
09:36:17:WU01:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
09:36:17:WU01:FS02:0x22:       CPUs: 4
09:36:17:WU01:FS02:0x22:     Memory: 7.93GiB
09:36:17:WU01:FS02:0x22:Free Memory: 5.32GiB
09:36:17:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
09:36:17:WU01:FS02:0x22: OS Version: 6.2
09:36:17:WU01:FS02:0x22:Has Battery: false
09:36:17:WU01:FS02:0x22: On Battery: false
09:36:17:WU01:FS02:0x22: UTC Offset: 2
09:36:17:WU01:FS02:0x22:        PID: 3704
09:36:17:WU01:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
09:36:17:WU01:FS02:0x22:************************************ OpenMM ************************************
09:36:17:WU01:FS02:0x22:   Revision: 189320d0
09:36:17:WU01:FS02:0x22:********************************************************************************
09:36:17:WU01:FS02:0x22:Project: 17722 (Run 92, Clone 1, Gen 17)
09:36:17:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
09:36:17:WU01:FS02:0x22:Reading tar file core.xml
09:36:17:WU01:FS02:0x22:Reading tar file integrator.xml
09:36:17:WU01:FS02:0x22:Reading tar file state.xml
09:36:17:WU01:FS02:0x22:Reading tar file system.xml
09:36:19:WU01:FS02:0x22:Digital signatures verified
09:36:19:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
09:36:19:WU01:FS02:0x22:Version 0.0.13
09:36:19:WU01:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
09:36:19:WU01:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
09:36:19:WU01:FS02:0x22:  XTC frame write interval: 25000 steps (2.5%) [40 total]
09:36:19:WU01:FS02:0x22:  Global context and integrator variables write interval: disabled
09:36:19:WU01:FS02:0x22:There are 3 platforms available.
09:36:19:WU01:FS02:0x22:Platform 0: Reference
09:36:19:WU01:FS02:0x22:Platform 1: CPU
09:36:19:WU01:FS02:0x22:Platform 2: OpenCL
09:36:19:WU01:FS02:0x22:  opencl-device 0 specified
09:36:33:WU01:FS02:0x22:Attempting to create OpenCL context:
09:36:33:WU01:FS02:0x22:  Configuring platform OpenCL
09:36:48:WU01:FS02:0x22:  Using OpenCL on platformId 0 and gpu 0
09:36:48:WU01:FS02:0x22:Completed 0 out of 1000000 steps (0%)
09:36:51:WU01:FS02:0x22:Checkpoint completed at step 0
09:38:46:WU01:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
09:40:39:WU01:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
09:42:32:WU01:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
09:44:25:WU01:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
09:46:18:WU01:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
09:46:21:WU01:FS02:0x22:Checkpoint completed at step 50000
09:48:14:WU01:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
09:50:08:WU01:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
09:52:01:WU01:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
09:53:55:WU01:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
09:55:48:WU01:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
09:55:51:WU01:FS02:0x22:Checkpoint completed at step 100000
09:57:44:WU01:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
09:59:37:WU01:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
10:01:30:WU01:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
10:03:23:WU01:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
10:05:17:WU01:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
10:05:20:WU01:FS02:0x22:Checkpoint completed at step 150000
10:07:13:WU01:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
10:09:06:WU01:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
10:10:59:WU01:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
10:12:53:WU01:FS02:0x22:Completed 190000 out of 1000000 steps (19%)
10:13:41:29:127.0.0.1:New Web session
I just had an error at 99% and now i have 2 WUs shown in Advanced view, one stuck at 99% another, seemingly progressing just fine .
After the restart it went straight to the newly downloaded WU, and left the unfinished one to the side?
Any advice?
GPU only
gunnarre
Post by gunnarre »
Pause and unpause. That should pick up the older WU and re-try it from the checkpoint. If it fails again, pause and unpause until the client gives up on it and dumps it.
iero
Post by iero »
I was aiming for a 100% completion rate, I would prefer to save the WU if possible. I was wrong, its Labeled: Ready, at 99% while the other WU is running. I've set the client to Finishing, hoping it will do both WUs.
Otherwise i'll restart the app, cause I have the CPU on pause-on-start.
GPU only
gunnarre
Post by gunnarre »
The reason this happens is that when a WU hits 99% (configurable with the "next-unit-percentage" slot option), it will start downloading the next WU, and if the old WU fails, it'll start folding the new one before it re-tries the old one. I wonder if this is intended behavior. The "Ready" WU will stay at 99% until the one currently folding finishes.
Restarting the client, or pausing and unpausing briefly, will usually make it pick up the oldest one first, then do the newest one when it has finished (or given up on) the old one. I'd try doing that.
iero
Post by iero »
iero wrote:I was aiming for a 100% completion rate, I would prefer to save the WU if possible. I was wrong, its Labeled: Ready, at 99% while the other WU is running. I've set the client to Finishing, hoping it will do both WUs.
Finish up and then pause worked. Ther first WU started from 95%. Lets see if its gonna finish this time around.
EDIT* - It did!
GPU only
gunnarre
Post by gunnarre »
If the work unit threw a NaN fault once but not on a re-try then it indicates that your card is barely stable. FAH doesn't officially support over- and under-clocking GPUs, and will tax GPUs harder than games, so if you're doing any under-volting or under-clocking then I'd reverse that. Using the power limiting feature in the driver is a safer way to reduce power draw.
iero
Post by iero »
The card is in its stock configuration. I haven't even played around with the Power Limit yet. The *FS02:0x22:An exception occurred at step 999481: Particle coordinate is nan* came moments after the next WU completed its download and seemed to coincide with a sudden drop to 0% gpu usage - as far as I can tell from MSI Afterburner and GPU-Z.
*The card is cruising along at 63 degrees Celsius at 20% fan speed.*
GPU only
