Disabled 2nd GPU
Disabled 2nd GPU
I am trying to fold with both of my GPUs. FAH seems to recognize the second one is there but it is disabled.
Both GPUs are identical and have the same firmware. The first GPU is working just fine but the second one says disabled and I cannot seem to get it to work.
Re: Disabled 2nd GPU
Please post the first part of your FAH log file, which shows your hardware and software setup: viewtopic.php?f=24&t=26036
Welcome to Folding@Home!
We know nothing about your PC, (gunnarre has a link for you to tell us much about your PC) but is it possible it is a laptop?
Many laptops have two GPUs but only use one or the other at any time, a low power unit for light use and a more powerful unit for intense work.
The light powered (iGPU) will be detected by the client and a slot created - but it is under beta test at the moment and tbh may well not add anything to your folding experience - indeed it may just make you device hotter/slower ... but as gunnarre and JimboPalmer said a log will help work out what is happening.
Below is the log file I believe. I am not on a laptop. I have a desktop with 2 GTX1070 GPUs in it.
*********************** Log Started 2021-03-10T15:58:47Z ***********************
15:58:47:******************************* libFAH ********************************
15:58:47: Date: Oct 20 2020
15:58:47: Time: 13:36:55
15:58:47: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:58:47: Branch: master
15:58:47: Compiler: Visual C++ 2015
15:58:47: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:58:47: Platform: win32 10
15:58:47: Bits: 32
15:58:47: Mode: Release
15:58:47:****************************** FAHClient ******************************
15:58:47: Version: 7.6.21
15:58:47: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:58:47: Copyright: 2020 foldingathome.org
15:58:47: Homepage: https://foldingathome.org/
15:58:47: Time: 13:41:04
15:58:47: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:58:47: Bits: 32
15:58:47: Args: --open-web-control
15:58:47: Config: C:\ProgramData\FAHClient\config.xml
15:58:47:******************************** CBang ********************************
15:58:47: Time: 11:36:18
15:58:47: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:58:47: Bits: 32
15:58:47:******************************* System ********************************
15:58:47: CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
15:58:47: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:58:47: CPUs: 4
15:58:47: Memory: 15.94GiB
15:58:47: Free Memory: 11.97GiB
15:58:47: Threads: WINDOWS_THREADS
15:58:47: OS Version: 6.2
15:58:47: Has Battery: false
15:58:47: On Battery: false
15:58:47: UTC Offset: -7
15:58:47: PID: 7464
15:58:47: CWD: C:\ProgramData\FAHClient
15:58:47: Win32 Service: false
15:58:47: OS: Windows 10 Home
15:58:47: OS Arch: AMD64
15:58:47: GPUs: 2
15:58:47: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
15:58:47: GPU 1: Bus:2 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
15:58:47: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.1
15:58:47:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:456.71
15:58:47:***********************************************************************
15:58:47:<config>
15:58:47: <!-- Network -->
15:58:47: <proxy v=':8080'/>
15:58:47:
15:58:47: <!-- Slot Control -->
15:58:47: <power v='FULL'/>
15:58:47:
15:58:47: <!-- User Information -->
15:58:47: <team v='883'/>
15:58:47: <user v='crpocock'/>
15:58:47:
15:58:47: <!-- Folding Slots -->
15:58:47: <slot id='0' type='CPU'/>
15:58:47: <slot id='1' type='GPU'>
15:58:47: <pci-bus v='1'/>
15:58:47: <pci-slot v='0'/>
15:58:47: </slot>
15:58:47: <slot id='2' type='GPU'>
15:58:47: <pci-bus v='2'/>
15:58:47: </slot>
15:58:47:</config>
15:58:47:Trying to access database...
15:58:47:Successfully acquired database lock
15:58:47:FS00:Initialized folding slot 00: cpu:2
15:58:47:FS01:Initialized folding slot 01: gpu:1:0 GP104 [GeForce GTX 1070] 6463
15:58:47:WARNING:FS02:No CUDA or OpenCL 1.2+ support detected for GPU slot 02: gpu:2:0 GP104 [GeForce GTX 1070] 6463. Disabling.
15:58:47:WU00:FS00:Starting
15:58:47:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
15:58:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7464 -checkpoint 15 -np 1
15:58:47:WU00:FS00:Started FahCore on PID 7528
15:58:47:WU00:FS00:Core PID:1348
15:58:47:WU00:FS00:FahCore 0xa7 started
15:58:47:WU01:FS01:Starting
15:58:47:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 7464 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
15:58:47:WU01:FS01:Started FahCore on PID 6204
15:58:47:WU01:FS01:Core PID:9088
15:58:47:WU01:FS01:FahCore 0x22 started
15:58:48:WU00:FS00:0xa7:*********************** Log Started 2021-03-10T15:58:47Z ***********************
15:58:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:58:48:WU00:FS00:0xa7: Type: 0xa7
15:58:48:WU00:FS00:0xa7: Core: Gromacs
15:58:48:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 7528 -checkpoint 15 -np 1
15:58:48:WU01:FS01:0x22:*********************** Log Started 2021-03-10T15:58:47Z ***********************
15:58:48:WU00:FS00:0xa7:************************************ CBang *************************************
15:58:48:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:58:48:WU00:FS00:0xa7: Date: Nov 27 2019
15:58:48:WU01:FS01:0x22: Core: Core22
15:58:48:WU00:FS00:0xa7: Time: 03:40:09
15:58:48:WU01:FS01:0x22: Type: 0x22
15:58:48:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
15:58:48:WU01:FS01:0x22: Version: 0.0.13
15:58:48:WU00:FS00:0xa7: Branch: master
15:58:48:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:58:48:WU00:FS00:0xa7: Compiler: Visual C++ 2008
15:58:48:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
15:58:48:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:58:48:WU01:FS01:0x22: Homepage: https://foldingathome.org/
15:58:48:WU00:FS00:0xa7: Platform: win32 10
15:58:48:WU01:FS01:0x22: Date: Sep 19 2020
15:58:48:WU00:FS00:0xa7: Bits: 64
15:58:48:WU01:FS01:0x22: Time: 02:35:58
15:58:48:WU00:FS00:0xa7: Mode: Release
15:58:48:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
15:58:48:WU00:FS00:0xa7:************************************ System ************************************
15:58:48:WU01:FS01:0x22: Branch: core22-0.0.13
15:58:48:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
15:58:48:WU01:FS01:0x22: Compiler: Visual C++ 2015
15:58:48:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:58:48:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:58:48:WU00:FS00:0xa7: CPUs: 4
15:58:48:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
15:58:48:WU00:FS00:0xa7: Memory: 15.94GiB
15:58:48:WU01:FS01:0x22: Platform: win32 10
15:58:48:WU00:FS00:0xa7:Free Memory: 11.96GiB
15:58:48:WU01:FS01:0x22: Bits: 64
15:58:48:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
15:58:48:WU01:FS01:0x22: Mode: Release
15:58:48:WU00:FS00:0xa7: OS Version: 6.2
15:58:48:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:58:48:WU00:FS00:0xa7:Has Battery: false
15:58:48:WU01:FS01:0x22: <peastman@stanford.edu>
15:58:48:WU00:FS00:0xa7: On Battery: false
15:58:48:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 6204 -checkpoint 15
15:58:48:WU00:FS00:0xa7: UTC Offset: -7
15:58:48:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
15:58:48:WU00:FS00:0xa7: PID: 1348
15:58:48:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
15:58:48:WU00:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
15:58:48:WU01:FS01:0x22:************************************ libFAH ************************************
15:58:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:58:48:WU01:FS01:0x22: Date: Sep 7 2020
15:58:48:WU00:FS00:0xa7: Version: 0.0.19
15:58:48:WU01:FS01:0x22: Time: 19:09:56
15:58:48:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:58:48:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
15:58:48:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
15:58:48:WU01:FS01:0x22: Branch: HEAD
15:58:48:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
15:58:48:WU00:FS00:0xa7: Date: Nov 25 2019
15:58:48:WU00:FS00:0xa7: Time: 17:12:41
15:58:48:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
15:58:48:WU01:FS01:0x22:************************************ CBang *************************************
15:58:48:WU01:FS01:0x22: Time: 19:08:30
15:58:48:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
15:58:48:WU00:FS00:0xa7:************************************ Build *************************************
15:58:48:WU00:FS00:0xa7: SIMD: avx_256
15:58:48:WU00:FS00:0xa7:********************************************************************************
15:58:48:WU00:FS00:0xa7:Project: 17411 (Run 0, Clone 211, Gen 256)
15:58:48:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
15:58:48:WU00:FS00:0xa7:Digital signatures verified
15:58:48:WU01:FS01:0x22:************************************ System ************************************
15:58:48:WU00:FS00:0xa7:Calling: mdrun -s frame256.tpr -o frame256.trr -x frame256.xtc -cpi state.cpt -cpt 15 -nt 1
15:58:48:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
15:58:48:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:58:48:WU01:FS01:0x22: CPUs: 4
15:58:48:WU01:FS01:0x22: Memory: 15.94GiB
15:58:48:WU01:FS01:0x22:Free Memory: 11.94GiB
15:58:48:WU01:FS01:0x22: Threads: WINDOWS_THREADS
15:58:48:WU01:FS01:0x22: OS Version: 6.2
15:58:48:WU01:FS01:0x22:Has Battery: false
15:58:48:WU01:FS01:0x22: On Battery: false
15:58:48:WU01:FS01:0x22: UTC Offset: -7
15:58:48:WU01:FS01:0x22: PID: 9088
15:58:48:WU01:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
15:58:48:WU01:FS01:0x22:************************************ OpenMM ************************************
15:58:48:WU01:FS01:0x22: Revision: 189320d0
15:58:48:WU01:FS01:0x22:********************************************************************************
15:58:48:WU01:FS01:0x22:Project: 17330 (Run 0, Clone 422, Gen 82)
15:58:48:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
15:58:48:WU01:FS01:0x22:Digital signatures verified
15:58:48:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:58:48:WU01:FS01:0x22:Version 0.0.13
15:58:48:WU01:FS01:0x22: Checkpoint write interval: 15000 steps (2%) [50 total]
15:58:48:WU01:FS01:0x22: JSON viewer frame write interval: 7500 steps (1%) [100 total]
15:58:48:WU01:FS01:0x22: XTC frame write interval: 250000 steps (33%) [3 total]
15:58:48:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
15:58:48:WU01:FS01:0x22:There are 4 platforms available.
15:58:48:WU01:FS01:0x22:Platform 0: Reference
15:58:48:WU01:FS01:0x22:Platform 1: CPU
15:58:48:WU01:FS01:0x22:Platform 2: OpenCL
15:58:48:WU01:FS01:0x22: opencl-device 0 specified
15:58:48:WU01:FS01:0x22:Platform 3: CUDA
15:58:48:WU01:FS01:0x22: cuda-device 0 specified
15:58:49:WU00:FS00:0xa7:Steps: first=32000000 total=125000
15:58:49:3:127.0.0.1:New Web session
15:58:50:WU00:FS00:0xa7:Completed 1772 out of 125000 steps (1%)
15:59:06:WU01:FS01:0x22:Attempting to create CUDA context:
15:59:06:WU01:FS01:0x22: Configuring platform CUDA
15:59:06:WU01:FS01:0x22:Failed to create CUDA context:
15:59:06:WU01:FS01:0x22:Error loading CUDA module: CUDA_ERROR_FILE_NOT_FOUND (301)
15:59:06:WU01:FS01:0x22:Attempting to create OpenCL context:
15:59:06:WU01:FS01:0x22: Configuring platform OpenCL
15:59:12:WU01:FS01:0x22: Using OpenCL on platformId 0 and gpu 0
15:59:12:WU01:FS01:0x22:Completed 0 out of 750000 steps (0%)
15:59:14:WU01:FS01:0x22:Checkpoint completed at step 0
15:59:48:Saving configuration to config.xml
15:59:48:<config>
15:59:48: <!-- Folding Core -->
15:59:48: <core-priority v='low'/>
15:59:48:
15:59:48: <!-- Network -->
15:59:48: <proxy v=':8080'/>
15:59:48:
15:59:48: <!-- Slot Control -->
15:59:48: <power v='FULL'/>
15:59:48:
15:59:48: <!-- User Information -->
15:59:48: <team v='883'/>
15:59:48: <user v='crpocock'/>
15:59:48:
15:59:48: <!-- Folding Slots -->
15:59:48: <slot id='0' type='CPU'/>
15:59:48: <slot id='1' type='GPU'>
15:59:48: <pci-bus v='1'/>
15:59:48: <pci-slot v='0'/>
15:59:48: </slot>
15:59:48: <slot id='2' type='GPU'>
15:59:48: <pci-bus v='2'/>
15:59:48: </slot>
15:59:48:</config>
That's pretty clear.
1) Installl the drivers from NVidia.com AFTER you plug the devices into your system.
2) Reinstall FAH after both devices have drivers properly configured.
It's possible (but unlikely) that the CUDA support installed by FAHCore_22 has a problem with duplicated GPUs but I haven't seen any specific reports of that sort of problem.
I did updated the drivers and reinstalled FAH, but it is still disabling the 2nd GPU...
Cool ... two 1070s ... our assumption of iGPU was wrong - our bad - in my case I really should have read your initial post carefully not just the thread - Sorry
Did you reboot system between updating drivers and reinstalling FaH? ... Sometimes not doing that means the drivers aren't found properly (but not always) ... I mention just in case.
Ideas:
Reboot after every stage of installation.
Try the Studio Driver version of the Nvidia driver rather than the "Game ready" ones?
Run the FAH uninstaller and check the box for removing it completely, including the settings.
Check that both cards are getting adequate power - move the power leads from one card to the other and see if that changes.
Try to swap the cards in the slots and see if that helps.
Does GPU-Z shows complete imformation for both gpus?
Does Nvidia panel recognize both gpus / has an option for SLI?
***I would suggest a removal of drivers with DDU and a clean install with 1 GPU, installing of F@H, then installation of second GPU.***
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
