Hi im new to folding banano.
I have som questions.
1. I have never gotten a payout of banano and been doing this for about 1,5 week. Do i have to be assigned to a team to get banano for my points?
2. I had about 160 000 points before i verified my client with a passkey and user and those point just disappeared. But when i look at the statistic they are still counted there. Will i get banano for those?
3. How much point is one banano? I read somewhere that 1 banano= 100 points? Is that true?
4. i have about 250 000 points right now...when will i get banano for those?
I have connected my client to Kalium so whats wrong? When can i see some banano pop up?
Havent gotten any apyouts
Re: Havent gotten any apyouts
Welcome to the forums ... I can help you with issues of FaH points ... but you need to reach out to the banano help with regard to anything related to their reward scheme as it is not managed/supported by FaH.
1. ... refer to Banano support
2. ... from a FaH stats position points are awarded to username/passkey pairing and so they never just "disappear" it is simply the case that it depends on where you look to find them ... as to whether you will get banano for them you need to refer to Banano support
3. ... again you need to refer to Banano support
4. ... once again please refer to Banano support
With reference to the Kalium question ... sorry, but agian Banao support is your route for answer on that.
FaH awards fah points in recognition of folders efforts ... there are a number of rewards scheme run by other parties Banano is but one) that are not supported/formally recognised by FaH for reasons related to the status of FaH Consortium members.
