(Solved) Timestamp and update times
Patrick Australien
Hardware configuration: PC Gamer MSI MAG META 5
- OS: Windows 10 Famille 64 Bits
- MB : B450M PRO-VDH MAX (MSI)
- CPU : AMD Ryzen 5 3600 - 6 cores/12 threads - 3600 MHz
- Ventirad : Pure Rock Slim (Be quiet!)
- GPU : NVIDIA GeForce GTX 1660 SUPER (MSI)
- RAM : 2x8GB DDR4-2666 (Integral)
- SSD NVMe : Western Digital PC SN730 NVMe (512Go)
- HDD : Western Digital WDC WD10EZEX-22MFCA0 (1To)
Post by Patrick Australien »
Hello
The stats download timestamp and update times is blocked.
And the counters (Score, WUS) appear nearly correct.
Last edited by Patrick Australien on Thu Mar 11, 2021 1:06 am, edited 1 time in total.
Re: Timestamp and update times
The development team is aware of the problem.
Patrick Australien
Hello bruce.
Many thank for job execute.
tbladh
Post by tbladh »
Hi there,
I seem to be experiencing the same problem as Patrick. Work units and points are updating but the date of last work unit is not. Is there any workaround that can be performed client side?
Donor: uuq1zsdefqiz
Date of last Work Unit 2021-03-07 20:26:19
Total score 29,444,196
Total WUs 240
Great that you are already looking into it.
Best,
Thomas
Patrick Australien
Hi,
Solved
Many thank
JWhy
Re: (Solved) Timestamp and update times
Post by JWhy »
Hi,
There seem to be problems, still, with the "Last Returned" / "PRCG" information in the CPU page. (it seems related to this issue, that's why I'm posting here and not in a new topic.)
https://apps.foldingathome.org/cpu?q=JWhy shows that my FAHClients returned WU today ("Last Returned" is ok)
But the PRCG & Credit information is wrong.
Both WU were returned early march 2021
e.g. https://apps.foldingathome.org/wu?p=174 ... 1897&g=191
This is also the information found in the "Work Unit Viewer" @ HFM.net
Thanks for your help,
JY.
DK-tastrophe
Post by DK-tastrophe »
Hi,
Same issue for me (and for a few dozen accounts of my team I've just checked) in the Recent CPUs page with :
- Last credit
- Last returned link towards WU Status
- PRCG
https://apps.foldingathome.org/cpu?q=[Zebulon.fr]_DK
https://apps.foldingathome.org/wu?p=178 ... 24&gen=221
NB: For my account, Last credit, Last returned link and PRCG have not changed since Mars 11th.
Last edited by DK-tastrophe on Mon Mar 28, 2022 11:57 am, edited 3 times in total.
j'ai fait don de mon core à la science...
JWhy wrote:There seem to be problems, still, with the "Last Returned" / "PRCG" information in the CPU page. (it seems related to this issue, that's why I'm posting here and not in a new topic.)
This is a separate problem, the last I checked there was a problem report on the F@H GitHub site waiting on a fix.
The last WU date problem that has been identified has come from credit logs not necessarily being processed in order. This is especially a problem when the connection between some Work Servers and the credit database has been down and the logs get processed in a large batch after the connection is reestablished.
The problem with the WU app is that date entries in the Returned and Credited columns are reversed. At some point the database query and filling of these fields should get fixed.
DK-tastrophe
Ok, thx ;)
JWhy
Post by JWhy »
Thanks Joe_H , and sorry for posting in this thread (maybe it can be split ?)
