Hi, sorry this is a question that will seem a bit noob.
I'm setting up some machines for folding, and one has an old AMD Firepro v5800 installed but the client says its disabled.
I suspect that maybe it's not a double-precision card and so isn't permitted, but I've looked at the gpu.txt file and there is an entry for it:
0x1002:0x68a9:::Juniper XT [FirePro V5800 (FireGL V)]
I don't know if this means that it's white listed, or black listed. And if the card is indeed OK, I've no idea why the client has disabled it.
Any advice humbly appreciated.
GPU Support
GPU Support
Chief Engineer at the Mouldotron Center for Supercomputing Applications
Re: GPU Support
Gpu.txt is a grey list in that it has both white and black list .. firepro has no double precision as you state and so won't be able to fold .. I'll track down a post with the instructions for decoding lines from gpu.txt
- Hardware configuration: Mac Pro 2.8 quad 12 GB smp4
MacBook Pro 2.9 i7 8 GB smp2 - Location: W. MA
Re: GPU Support
That means the card is blacklisted, the 3rd and 4th fields are blank. They can also contain zeros, that is the same as if the fields were blank.
And yes, it does not support double precision - https://www.techpowerup.com/gpu-specs/f ... 5800.c2441
iMac 2.8 i7 12 GB smp8, Mac Pro 2.8 quad 12 GB smp6
MacBook Pro 2.9 i7 8 GB smp3
Re: GPU Support
Hey thanks guys that's really helpful. I know it's an old card, it's just I have a bunch of them already, but I'll put them back on the retro shelf and stick with newer silicon for folding.
Stay safe
Stay safe
Re: GPU Support
Basic requirements for a GPU at this point is support for OpenCL 1.2 or better, and support for double precision arithmetic (FP64). Some older Fermi based cards from nVidia support enough of the instructions added between OpenCL 1.1 and 1.2 that they may work on some of the current projects.
Re: GPU Support
Unfortunately there is no classification system for either GPUs or for projects that allow those projects to be assigned to those GPUs.Joe_H wrote:Some older Fermi based cards from nVidia support enough of the instructions added between OpenCL 1.1 and 1.2 that they may work on some of the current projects.
