Whitelist request for RTX 3060
shizawn
Post by shizawn »
Have an EVGA RTX 3060 and it looks like this particular DevID is not in the list.
0x10de:0x2503:1:0:0:NVIDIA Corporation:NVIDIA GeForce RTX 3060
*********************** Log Started 2021-02-26T01:46:15Z ***********************
01:46:15:******************************* libFAH ********************************
01:46:15:           Date: Oct 20 2020
01:46:15:           Time: 13:36:55
01:46:15:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
01:46:15:         Branch: master
01:46:15:       Compiler: Visual C++ 2015
01:46:15:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:46:15:       Platform: win32 10
01:46:15:           Bits: 32
01:46:15:           Mode: Release
01:46:15:****************************** FAHClient ******************************
01:46:15:        Version: 7.6.21
01:46:15:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:46:15:      Copyright: 2020 foldingathome.org
01:46:15:       Homepage: https://foldingathome.org/
01:46:15:           Time: 13:41:04
01:46:15:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
01:46:15:           Bits: 32
01:46:15:           Args: --open-web-control
01:46:15:         Config: C:\ProgramData\FAHClient\config.xml
01:46:15:******************************** CBang ********************************
01:46:15:           Time: 11:36:18
01:46:15:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
01:46:15:           Bits: 32
01:46:15:******************************* System ********************************
01:46:15:            CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
01:46:15:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
01:46:15:           CPUs: 8
01:46:15:         Memory: 31.95GiB
01:46:15:    Free Memory: 28.93GiB
01:46:15:        Threads: WINDOWS_THREADS
01:46:15:     OS Version: 6.2
01:46:15:    Has Battery: false
01:46:15:     On Battery: false
01:46:15:     UTC Offset: -8
01:46:15:            PID: 1988
01:46:15:            CWD: C:\ProgramData\FAHClient
01:46:15:  Win32 Service: false
01:46:15:             OS: Windows 10 Enterprise
01:46:15:        OS Arch: AMD64
01:46:15:           GPUs: 1
01:46:15:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:1
01:46:15:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:11.2
01:46:15:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:461.72
01:46:15:***********************************************************************
01:46:16:<config>
01:46:16:  <!-- Network -->
01:46:16:  <proxy v=':8080'/>
01:46:16:
01:46:16:  <!-- Slot Control -->
01:46:16:  <power v='MEDIUM'/>
01:46:16:
01:46:16:  <!-- Folding Slots -->
01:46:16:  <slot id='0' type='CPU'>
01:46:16:    <paused v='true'/>
01:46:16:  </slot>
01:46:16:  <slot id='1' type='GPU'>
01:46:16:    <pci-bus v='1'/>
01:46:16:    <pci-slot v='0'/>
01:46:16:  </slot>
01:46:16:</config>
01:46:16:Trying to access database...
01:46:16:Successfully acquired database lock
01:46:16:FS00:Initialized folding slot 00: cpu:6
01:46:16:WARNING:FS01:Disabling beta GPU slot 01: gpu:1:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
01:46:16:WARNING:WU01:No longer matches Slot 1's configuration and there are no other matching slots, dumping
01:46:16:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:17428 run:0 clone:1020 gen:258 core:0xa7 unit:0x000003fc000001020000441400000000
01:46:16:WU01:FS01:Connecting to 128.252.203.9:8080
01:46:17:WU01:FS01:Server responded WORK_ACK (400)
01:46:17:WU01:FS01:Cleaning up
01:46:18:3:127.0.0.1:New Web session
01:46:33:14:127.0.0.1:New Web session
01:46:54:FS01:Paused
01:46:59:FS00:Unpaused
01:46:59:FS01:Unpaused
01:46:59:WU02:FS00:Starting
01:46:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 02 -suffix 01 -version 706 -lifeline 1988 -checkpoint 15 -np 6
01:46:59:WU02:FS00:Started FahCore on PID 5896
01:46:59:WU02:FS00:Core PID:5384
01:46:59:WU02:FS00:FahCore 0xa8 started
01:46:59:WU02:FS00:0xa8:*********************** Log Started 2021-02-26T01:46:59Z ***********************
01:46:59:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
01:46:59:WU02:FS00:0xa8:       Core: Gromacs
01:46:59:WU02:FS00:0xa8:       Type: 0xa8
01:46:59:WU02:FS00:0xa8:    Version: 0.0.12
01:46:59:WU02:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:46:59:WU02:FS00:0xa8:  Copyright: 2020 foldingathome.org
01:46:59:WU02:FS00:0xa8:   Homepage: https://foldingathome.org/
01:46:59:WU02:FS00:0xa8:       Date: Jan 16 2021
01:46:59:WU02:FS00:0xa8:       Time: 12:29:40
01:46:59:WU02:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
01:46:59:WU02:FS00:0xa8:     Branch: master
01:46:59:WU02:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
01:46:59:WU02:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:46:59:WU02:FS00:0xa8:   Platform: win32 10
01:46:59:WU02:FS00:0xa8:       Bits: 64
01:46:59:WU02:FS00:0xa8:       Mode: Release
01:46:59:WU02:FS00:0xa8:       SIMD: avx2_256
01:46:59:WU02:FS00:0xa8:     OpenMP: ON
01:46:59:WU02:FS00:0xa8:       CUDA: OFF
01:46:59:WU02:FS00:0xa8:       Args: -dir 02 -suffix 01 -version 706 -lifeline 5896 -checkpoint 15 -np 6
01:46:59:WU02:FS00:0xa8:************************************ libFAH ************************************
01:46:59:WU02:FS00:0xa8:       Time: 11:24:13
01:46:59:WU02:FS00:0xa8:************************************ CBang *************************************
01:46:59:WU02:FS00:0xa8:       Time: 11:23:53
01:46:59:WU02:FS00:0xa8:************************************ System ************************************
01:46:59:WU02:FS00:0xa8:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
01:46:59:WU02:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
01:46:59:WU02:FS00:0xa8:       CPUs: 8
01:46:59:WU02:FS00:0xa8:     Memory: 31.95GiB
01:46:59:WU02:FS00:0xa8:Free Memory: 28.69GiB
01:46:59:WU02:FS00:0xa8:    Threads: WINDOWS_THREADS
01:46:59:WU02:FS00:0xa8: OS Version: 6.2
01:46:59:WU02:FS00:0xa8:Has Battery: false
01:46:59:WU02:FS00:0xa8: On Battery: false
01:46:59:WU02:FS00:0xa8: UTC Offset: -8
01:46:59:WU02:FS00:0xa8:        PID: 5384
01:46:59:WU02:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
01:47:00:WU02:FS00:0xa8:********************************************************************************
01:47:00:WU02:FS00:0xa8:Project: 16947 (Run 41, Clone 4, Gen 69)
01:47:00:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
01:47:00:WU02:FS00:0xa8:Digital signatures verified
01:47:00:WU02:FS00:0xa8:Calling: mdrun -c frame69.gro -s frame69.tpr -x frame69.xtc -cpi state.cpt -cpt 15 -nt 6 -ntmpi 1
01:47:00:WU02:FS00:0xa8:Steps: first=345000000 total=350000000
01:47:01:WU02:FS00:0xa8:Completed 87508 out of 5000000 steps (1%)
Thanks!
Re: Whitelist request for RTX 3060
Well, so there's two different IDs for 3060 ... I'll add it as soon as possible, but tools (and stats) are actually having issues ... :(
In the meantime, you might try to add the gpu-beta=true setting to the slot ...
It looks like someone else added it ... so it should be fine now.
Edit by Mod.
Yep.
For some reason, there's another ID for a 3060 model that was missing from the list of supported GPUs ...
I just added : 0x2487 / GA104 [GeForce RTX 3060] :)
