My gpu went to 2 seconds left 99% and then started a new one
I started folding last night so i am quite new but i have watched my GPU complete or i guess make it to 2 seconds left 99% twice now and then start on a new project. then i have no points awarded or any BAN given to my wallet. Am i doing something wrong becuase i just watch 10 hours of folding basically to have it start a new project again. I'm running an asus tuf gamiing laptop geforce gx 1650 with 6 cpu cores at medium power. i should have gotten around 200,000 points so far just from the gpu but i have a total of 49,000 points which seems to be from the cpu side. Can someone help me with this?
Re: My gpu went to 2 seconds left 99% and then started a new
It's showing 89,000 points now which doesnt make any sense either
It's showing 4 Wu's i think completed at 83,000 points my bad but it should be around 250,000 points im confused
It's not really going from 2 seconds to 99%. Check FAHLog.
This usually happens because your CPU is overclocked and has failed while processing a WU. See my SIg block
Are you using a passkey?
It will say 2 seconds left till completion at 99% and then stop and start a new one and what is fahlog? Im very new have no idea what im doing really and slg block? yeah im using a pass key too
Welcome to Folding@Home!
Once you enter the passkey, you need to complete 10 WU's and maintain a 80% success ratio, THEN you will get the Quick Return Bonus.
The Client does not know this, so it reports the bonus before it is awarded.
The link at the bottom of bruce's post shows how to find and post FAHlog.
*********************** Log Started 2021-02-23T06:06:23Z ***********************
06:06:23:******************************* libFAH ********************************
06:06:23: Date: Oct 20 2020
06:06:23: Time: 13:36:55
06:06:23: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
06:06:23: Branch: master
06:06:23: Compiler: Visual C++ 2015
06:06:23: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
06:06:23: Platform: win32 10
06:06:23: Bits: 32
06:06:23: Mode: Release
06:06:23:****************************** FAHClient ******************************
06:06:23: Version: 7.6.21
06:06:23: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:06:23: Copyright: 2020 foldingathome.org
06:06:23: Homepage: https://foldingathome.org/
06:06:23: Time: 13:41:04
06:06:23: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
06:06:23: Bits: 32
06:06:23: Args: --open-web-control
06:06:23:******************************** CBang ********************************
06:06:23: Time: 11:36:18
06:06:23: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
06:06:23: Bits: 32
06:06:23:******************************* System ********************************
06:06:23: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:06:23: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:06:23: CPUs: 8
06:06:23: Memory: 7.86GiB
06:06:23: Free Memory: 2.82GiB
06:06:23: Threads: WINDOWS_THREADS
06:06:23: OS Version: 6.2
06:06:23: Has Battery: true
06:06:23: On Battery: false
06:06:23: UTC Offset: -6
06:06:23: PID: 10108
06:06:23: CWD: C:\ProgramData\FAHClient
06:06:23: Win32 Service: false
06:06:23: OS: Windows 10 Home
06:06:23: OS Arch: AMD64
06:06:23: GPUs: 2
06:06:23: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 CFL GT2 [UHD Graphics 630]
06:06:23: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117M [GeForce GTX 1650 Mobile /
06:06:23: Max-Q]
06:06:23: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
06:06:23:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:446.14
06:06:23:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
06:06:23:***********************************************************************
06:06:23:<config>
06:06:23: <!-- Folding Slots -->
06:06:23:</config>
06:06:23:Trying to access database...
06:06:23:Successfully acquired database lock
06:06:23:FS00:Initialized folding slot 00: cpu:3
06:06:23:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 CFL GT2 [UHD Graphics 630]. Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
06:06:23:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 CFL GT2 [UHD Graphics 630]. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
06:06:23:FS02:Initialized folding slot 02: gpu:1:0 TU117M [GeForce GTX 1650 Mobile / Max-Q]
06:07:24:Saving configuration to config.xml
06:07:24:<config>
06:07:24: <!-- Folding Slots -->
06:07:24: <slot id='0' type='CPU'/>
06:07:24: <slot id='1' type='GPU'>
06:07:24: <pci-bus v='0'/>
06:07:24: <pci-slot v='2'/>
06:07:24: </slot>
06:07:24: <slot id='2' type='GPU'>
06:07:24: <pci-bus v='1'/>
06:07:24: <pci-slot v='0'/>
06:07:24: </slot>
06:07:24:</config>
06:07:24:Set client configured
06:07:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
06:07:25:WU00:FS00:Connecting to assign1.foldingathome.org:80
06:07:25:WU00:FS00:Assigned to work server 66.170.111.50
06:07:25:WU00:FS00:Requesting new work unit for slot 00: cpu:3 from 66.170.111.50
06:07:25:WU00:FS00:Connecting to 66.170.111.50:8080
06:07:26:WU00:FS00:Downloading 7.36MiB
06:07:31:WU00:FS00:Download complete
06:07:31:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17411 run:0 clone:421 gen:554 core:0xa7 unit:0x000001a50000022a0000440300000000
06:07:31:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
06:07:31:WU00:FS00:Connecting to cores.foldingathome.org:80
06:07:31:WU00:FS00:FahCore a7: Downloading 6.71MiB
06:07:34:WU00:FS00:FahCore a7: Download complete
06:07:34:WU00:FS00:Valid core signature
06:07:34:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe
06:07:34:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/libfftw3f-3.dll
06:07:34:WU00:FS00:Starting
06:07:34:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 3
06:07:34:WU00:FS00:Started FahCore on PID 12676
06:07:34:WU00:FS00:Core PID:1336
06:07:34:WU00:FS00:FahCore 0xa7 started
06:07:35:WU00:FS00:0xa7:*********************** Log Started 2021-02-23T06:07:34Z ***********************
06:07:35:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:07:35:WU00:FS00:0xa7: Type: 0xa7
06:07:35:WU00:FS00:0xa7: Core: Gromacs
06:07:35:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 12676 -checkpoint 15 -np
06:07:35:WU00:FS00:0xa7: 3
06:07:35:WU00:FS00:0xa7:************************************ CBang *************************************
06:07:35:WU00:FS00:0xa7: Date: Nov 27 2019
06:07:35:WU00:FS00:0xa7: Time: 03:40:09
06:07:35:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:07:35:WU00:FS00:0xa7: Branch: master
06:07:35:WU00:FS00:0xa7: Compiler: Visual C++ 2008
06:07:35:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:07:35:WU00:FS00:0xa7: Platform: win32 10
06:07:35:WU00:FS00:0xa7: Bits: 64
06:07:35:WU00:FS00:0xa7: Mode: Release
06:07:35:WU00:FS00:0xa7:************************************ System ************************************
06:07:35:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:07:35:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:07:35:WU00:FS00:0xa7: CPUs: 8
06:07:35:WU00:FS00:0xa7: Memory: 7.86GiB
06:07:35:WU00:FS00:0xa7:Free Memory: 2.84GiB
06:07:35:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:07:35:WU00:FS00:0xa7: OS Version: 6.2
06:07:35:WU00:FS00:0xa7:Has Battery: true
06:07:35:WU00:FS00:0xa7: On Battery: false
06:07:35:WU00:FS00:0xa7: UTC Offset: -6
06:07:35:WU00:FS00:0xa7: PID: 1336
06:07:35:WU00:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
06:07:35:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:07:35:WU00:FS00:0xa7: Version: 0.0.19
06:07:35:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:07:35:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:07:35:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:07:35:WU00:FS00:0xa7: Date: Nov 25 2019
06:07:35:WU00:FS00:0xa7: Time: 17:12:41
06:07:35:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:07:35:WU00:FS00:0xa7:************************************ Build *************************************
06:07:35:WU00:FS00:0xa7: SIMD: avx_256
06:07:35:WU00:FS00:0xa7:********************************************************************************
06:07:35:WU00:FS00:0xa7:Project: 17411 (Run 0, Clone 421, Gen 554)
06:07:35:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:07:35:WU00:FS00:0xa7:Reading tar file core.xml
06:07:35:WU00:FS00:0xa7:Reading tar file frame554.tpr
06:07:35:WU00:FS00:0xa7:Digital signatures verified
06:07:35:WU00:FS00:0xa7:Calling: mdrun -s frame554.tpr -o frame554.trr -x frame554.xtc -cpt 15 -nt 3
06:07:35:WU00:FS00:0xa7:Steps: first=69250000 total=125000
06:07:37:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
06:07:57:17:127.0.0.1:New Web session
06:09:26:Saving configuration to config.xml
06:09:26:<config>
06:09:26: <!-- User Information -->
06:09:26: <user v='zach'/>
06:09:26:
06:09:26: <!-- Folding Slots -->
06:09:26: <slot id='0' type='CPU'/>
06:09:26: <slot id='1' type='GPU'>
06:09:26: <pci-bus v='0'/>
06:09:26: <pci-slot v='2'/>
06:09:26: </slot>
06:09:26: <slot id='2' type='GPU'>
06:09:26: <pci-bus v='1'/>
06:09:26: <pci-slot v='0'/>
06:09:26: </slot>
06:09:26:</config>
06:10:00:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
06:12:24:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
06:13:30:Saving configuration to config.xml
06:13:30:<config>
06:13:30: <!-- User Information -->
06:13:30: <passkey v='*****'/>
06:13:30: <team v='234980'/>
06:13:30: <user v='w6pb36jgbict'/>
06:13:30:
06:13:30: <!-- Folding Slots -->
06:13:30: <slot id='0' type='CPU'/>
06:13:30: <slot id='1' type='GPU'>
06:13:30: <pci-bus v='0'/>
06:13:30: <pci-slot v='2'/>
06:13:30: </slot>
06:13:30: <slot id='2' type='GPU'>
06:13:30: <pci-bus v='1'/>
06:13:30: <pci-slot v='0'/>
06:13:30: </slot>
06:13:30:</config>
06:13:56:FS00:Shutting core down
06:13:56:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 1336
06:13:56:WU00:FS00:0xa7:Exiting, please wait. . .
06:13:56:WU01:FS02:Connecting to assign1.foldingathome.org:80
06:13:56:WU01:FS02:Assigned to work server 140.163.4.200
06:13:56:WU01:FS02:Requesting new work unit for slot 02: gpu:1:0 TU117M [GeForce GTX 1650 Mobile / Max-Q] from 140.163.4.200
06:13:56:WU01:FS02:Connecting to 140.163.4.200:8080
06:13:57:WU01:FS02:Downloading 20.25MiB
06:13:58:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
06:13:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:13:58:WU00:FS00:Starting
06:13:58:WARNING:WU00:FS00:Changed SMP threads from 3 to 5 this can cause some work units to fail
06:13:58:WARNING:WU00:FS00:AS lowered CPUs from 5 to 3
06:13:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 3
06:13:58:WU00:FS00:Started FahCore on PID 16864
06:13:58:WU00:FS00:Core PID:6440
06:13:58:WU00:FS00:FahCore 0xa7 started
06:13:59:WU00:FS00:0xa7:*********************** Log Started 2021-02-23T06:13:58Z ***********************
06:13:59:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:13:59:WU00:FS00:0xa7: Type: 0xa7
06:13:59:WU00:FS00:0xa7: Core: Gromacs
06:13:59:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 16864 -checkpoint 15 -np
06:13:59:WU00:FS00:0xa7: 3
06:13:59:WU00:FS00:0xa7:************************************ CBang *************************************
06:13:59:WU00:FS00:0xa7: Date: Nov 27 2019
06:13:59:WU00:FS00:0xa7: Time: 03:40:09
06:13:59:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:13:59:WU00:FS00:0xa7: Branch: master
06:13:59:WU00:FS00:0xa7: Compiler: Visual C++ 2008
06:13:59:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:13:59:WU00:FS00:0xa7: Platform: win32 10
06:13:59:WU00:FS00:0xa7: Bits: 64
06:13:59:WU00:FS00:0xa7: Mode: Release
06:13:59:WU00:FS00:0xa7:************************************ System ************************************
06:13:59:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:13:59:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:13:59:WU00:FS00:0xa7: CPUs: 8
06:13:59:WU00:FS00:0xa7: Memory: 7.86GiB
06:13:59:WU00:FS00:0xa7:Free Memory: 3.32GiB
06:13:59:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:13:59:WU00:FS00:0xa7: OS Version: 6.2
06:13:59:WU00:FS00:0xa7:Has Battery: true
06:13:59:WU00:FS00:0xa7: On Battery: false
06:13:59:WU00:FS00:0xa7: UTC Offset: -6
06:13:59:WU00:FS00:0xa7: PID: 6440
06:13:59:WU00:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
06:13:59:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:13:59:WU00:FS00:0xa7: Version: 0.0.19
06:13:59:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:13:59:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:13:59:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:13:59:WU00:FS00:0xa7: Date: Nov 25 2019
06:13:59:WU00:FS00:0xa7: Time: 17:12:41
06:13:59:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:13:59:WU00:FS00:0xa7:************************************ Build *************************************
06:13:59:WU00:FS00:0xa7: SIMD: avx_256
06:13:59:WU00:FS00:0xa7:********************************************************************************
06:13:59:WU00:FS00:0xa7:Project: 17411 (Run 0, Clone 421, Gen 554)
06:13:59:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:13:59:WU00:FS00:0xa7:Digital signatures verified
06:13:59:WU00:FS00:0xa7:Calling: mdrun -s frame554.tpr -o frame554.trr -x frame554.xtc -cpi state.cpt -cpt 15 -nt 3
06:13:59:WU00:FS00:0xa7:Steps: first=69250000 total=125000
06:14:01:WU00:FS00:0xa7:Completed 3282 out of 125000 steps (2%)
06:14:03:WU01:FS02:Download 66.66%
06:14:05:WU01:FS02:Download complete
06:14:05:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17335 run:9 clone:544 gen:2 core:0x22 unit:0x0000022000000002000043b700000009
06:14:05:WU01:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
06:14:05:WU01:FS02:Connecting to cores.foldingathome.org:80
06:14:06:WU01:FS02:FahCore 22: Downloading 77.67MiB
06:14:12:WU01:FS02:FahCore 22: 27.60%
06:14:18:WU01:FS02:FahCore 22: 51.02%
06:14:24:WU01:FS02:FahCore 22: 77.17%
06:14:28:WU01:FS02:FahCore 22: Download complete
06:14:29:WU01:FS02:Valid core signature
06:14:29:WU01:FS02:Unpacked 8.33MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe
06:14:29:WU01:FS02:Unpacked 3.06MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc-builtins64_92.dll
06:14:29:WU01:FS02:Unpacked 3.13MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMM.dll
06:14:29:WU01:FS02:Unpacked 2.07MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMOpenCL.dll
06:14:29:WU01:FS02:Unpacked 14.82MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc64_92.dll
06:14:30:WU01:FS02:Unpacked 82.99MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/cufft64_92.dll
06:14:30:WU01:FS02:Unpacked 275.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCudaCompiler.dll
06:14:30:WU01:FS02:Unpacked 1.95MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCUDA.dll
06:14:30:WU01:FS02:Unpacked 786.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCPU.dll
06:14:30:WU01:FS02:Starting
06:14:30:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
06:14:30:WU01:FS02:Started FahCore on PID 4916
06:14:31:WU01:FS02:Core PID:14768
06:14:31:WU01:FS02:FahCore 0x22 started
06:14:31:Saving configuration to config.xml
06:14:31:<config>
06:14:31: <!-- Slot Control -->
06:14:31: <power v='MEDIUM'/>
06:14:31:
06:14:31: <!-- User Information -->
06:14:31: <passkey v='*****'/>
06:14:31: <team v='234980'/>
06:14:31: <user v='w6pb36jgbict'/>
06:14:31:
06:14:31: <!-- Folding Slots -->
06:14:31: <slot id='0' type='CPU'/>
06:14:31: <slot id='1' type='GPU'>
06:14:31: <pci-bus v='0'/>
06:14:31: <pci-slot v='2'/>
06:14:31: </slot>
06:14:31: <slot id='2' type='GPU'>
06:14:31: <pci-bus v='1'/>
06:14:31: <pci-slot v='0'/>
06:14:31: </slot>
06:14:31:</config>
06:14:31:WU01:FS02:0x22:*********************** Log Started 2021-02-23T06:14:31Z ***********************
06:14:31:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
06:14:31:WU01:FS02:0x22: Core: Core22
06:14:31:WU01:FS02:0x22: Type: 0x22
06:14:31:WU01:FS02:0x22: Version: 0.0.13
06:14:31:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:14:31:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
06:14:31:WU01:FS02:0x22: Homepage: https://foldingathome.org/
06:14:31:WU01:FS02:0x22: Date: Sep 19 2020
06:14:31:WU01:FS02:0x22: Time: 02:35:58
06:14:31:WU01:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
06:14:31:WU01:FS02:0x22: Branch: core22-0.0.13
06:14:31:WU01:FS02:0x22: Compiler: Visual C++ 2015
06:14:31:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
06:14:31:WU01:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
06:14:31:WU01:FS02:0x22: Platform: win32 10
06:14:31:WU01:FS02:0x22: Bits: 64
06:14:31:WU01:FS02:0x22: Mode: Release
06:14:31:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:14:31:WU01:FS02:0x22: <peastman@stanford.edu>
06:14:31:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 4916 -checkpoint 15
06:14:31:WU01:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
06:14:31:WU01:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
06:14:31:WU01:FS02:0x22:************************************ libFAH ************************************
06:14:31:WU01:FS02:0x22: Date: Sep 7 2020
06:14:31:WU01:FS02:0x22: Time: 19:09:56
06:14:31:WU01:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
06:14:31:WU01:FS02:0x22: Branch: HEAD
06:14:31:WU01:FS02:0x22:************************************ CBang *************************************
06:14:31:WU01:FS02:0x22: Time: 19:08:30
06:14:31:WU01:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
06:14:31:WU01:FS02:0x22:************************************ System ************************************
06:14:31:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:14:31:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:14:31:WU01:FS02:0x22: CPUs: 8
06:14:31:WU01:FS02:0x22: Memory: 7.86GiB
06:14:31:WU01:FS02:0x22:Free Memory: 3.08GiB
06:14:31:WU01:FS02:0x22: Threads: WINDOWS_THREADS
06:14:31:WU01:FS02:0x22: OS Version: 6.2
06:14:31:WU01:FS02:0x22:Has Battery: true
06:14:31:WU01:FS02:0x22: On Battery: false
06:14:31:WU01:FS02:0x22: UTC Offset: -6
06:14:31:WU01:FS02:0x22: PID: 14768
06:14:31:WU01:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
06:14:31:WU01:FS02:0x22:************************************ OpenMM ************************************
06:14:31:WU01:FS02:0x22: Revision: 189320d0
06:14:31:WU01:FS02:0x22:********************************************************************************
06:14:31:WU01:FS02:0x22:Project: 17335 (Run 9, Clone 544, Gen 2)
06:14:31:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
06:14:31:WU01:FS02:0x22:Reading tar file core.xml
06:14:31:WU01:FS02:0x22:Reading tar file integrator.xml.bz2
06:14:31:WU01:FS02:0x22:Reading tar file state.xml.bz2
06:14:31:WU01:FS02:0x22:Reading tar file system.xml.bz2
06:14:31:WU01:FS02:0x22:Digital signatures verified
06:14:31:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
06:14:31:WU01:FS02:0x22:Version 0.0.13
06:14:32:WU01:FS02:0x22: Checkpoint write interval: 15000 steps (2%) [50 total]
06:14:32:WU01:FS02:0x22: JSON viewer frame write interval: 7500 steps (1%) [100 total]
06:14:32:WU01:FS02:0x22: XTC frame write interval: 250000 steps (33%) [3 total]
06:14:32:WU01:FS02:0x22: Global context and integrator variables write interval: disabled
06:14:33:WU01:FS02:0x22:There are 4 platforms available.
06:14:33:WU01:FS02:0x22:Platform 0: Reference
06:14:33:WU01:FS02:0x22:Platform 1: CPU
06:14:33:WU01:FS02:0x22:Platform 2: OpenCL
06:14:33:WU01:FS02:0x22: opencl-device 0 specified
06:14:33:WU01:FS02:0x22:Platform 3: CUDA
06:14:33:WU01:FS02:0x22: cuda-device 0 specified
06:14:53:WU01:FS02:0x22:Attempting to create CUDA context:
06:14:53:WU01:FS02:0x22: Configuring platform CUDA
06:14:59:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
06:15:08:WU01:FS02:0x22: Using CUDA and gpu 0
06:15:08:WU01:FS02:0x22:Completed 0 out of 750000 steps (0%)
06:15:10:WU01:FS02:0x22:Checkpoint completed at step 0
06:16:13:FS00:Shutting core down
06:16:13:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 6440
06:16:13:WU00:FS00:0xa7:Exiting, please wait. . .
06:16:15:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:16:15:WU00:FS00:Starting
06:16:15:WARNING:WU00:FS00:Changed SMP threads from 5 to 6 this can cause some work units to fail
06:16:15:WARNING:WU00:FS00:AS lowered CPUs from 6 to 3
06:16:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 3
06:16:15:WU00:FS00:Started FahCore on PID 8176
06:16:15:WU00:FS00:Core PID:8268
06:16:15:WU00:FS00:FahCore 0xa7 started
06:16:16:WU00:FS00:0xa7:*********************** Log Started 2021-02-23T06:16:15Z ***********************
06:16:16:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:16:16:WU00:FS00:0xa7: Type: 0xa7
06:16:16:WU00:FS00:0xa7: Core: Gromacs
06:16:16:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 8176 -checkpoint 15 -np 3
06:16:16:WU00:FS00:0xa7:************************************ CBang *************************************
06:16:16:WU00:FS00:0xa7: Date: Nov 27 2019
06:16:16:WU00:FS00:0xa7: Time: 03:40:09
06:16:16:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:16:16:WU00:FS00:0xa7: Branch: master
06:16:16:WU00:FS00:0xa7: Compiler: Visual C++ 2008
06:16:16:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:16:16:WU00:FS00:0xa7: Platform: win32 10
06:16:16:WU00:FS00:0xa7: Bits: 64
06:16:16:WU00:FS00:0xa7: Mode: Release
06:16:16:WU00:FS00:0xa7:************************************ System ************************************
06:16:16:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:16:16:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:16:16:WU00:FS00:0xa7: CPUs: 8
06:16:16:WU00:FS00:0xa7: Memory: 7.86GiB
06:16:16:WU00:FS00:0xa7:Free Memory: 2.48GiB
06:16:16:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:16:16:WU00:FS00:0xa7: OS Version: 6.2
06:16:16:WU00:FS00:0xa7:Has Battery: true
06:16:16:WU00:FS00:0xa7: On Battery: false
06:16:16:WU00:FS00:0xa7: UTC Offset: -6
06:16:16:WU00:FS00:0xa7: PID: 8268
06:16:16:WU00:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
06:16:16:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:16:16:WU00:FS00:0xa7: Version: 0.0.19
06:16:16:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:16:16:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:16:16:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:16:16:WU00:FS00:0xa7: Date: Nov 25 2019
06:16:16:WU00:FS00:0xa7: Time: 17:12:41
06:16:16:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:16:16:WU00:FS00:0xa7:************************************ Build *************************************
06:16:16:WU00:FS00:0xa7: SIMD: avx_256
06:16:16:WU00:FS00:0xa7:********************************************************************************
06:16:16:WU00:FS00:0xa7:Project: 17411 (Run 0, Clone 421, Gen 554)
06:16:16:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:16:16:WU00:FS00:0xa7:Digital signatures verified
06:16:16:WU00:FS00:0xa7:Calling: mdrun -s frame554.tpr -o frame554.trr -x frame554.xtc -cpi state.cpt -cpt 15 -nt 3
06:16:16:WU00:FS00:0xa7:Steps: first=69250000 total=125000
06:16:18:WU00:FS00:0xa7:Completed 4322 out of 125000 steps (3%)
06:16:33:Saving configuration to config.xml
06:16:33:<config>
06:16:33: <!-- Slot Control -->
06:16:33: <power v='FULL'/>
06:16:33:
06:16:33: <!-- User Information -->
06:16:33: <passkey v='*****'/>
06:16:33: <team v='234980'/>
06:16:33: <user v='w6pb36jgbict'/>
06:16:33:
06:16:33: <!-- Folding Slots -->
06:16:33: <slot id='0' type='CPU'/>
06:16:33: <slot id='1' type='GPU'>
06:16:33: <pci-bus v='0'/>
06:16:33: <pci-slot v='2'/>
06:16:33: </slot>
06:16:33: <slot id='2' type='GPU'>
06:16:33: <pci-bus v='1'/>
06:16:33: <pci-slot v='0'/>
06:16:33: </slot>
06:16:33:</config>
06:17:58:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
06:18:47:WU01:FS02:0x22:Completed 7500 out of 750000 steps (1%)
06:21:02:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
06:22:32:WU01:FS02:0x22:Completed 15000 out of 750000 steps (2%)
06:22:35:WU01:FS02:0x22:Checkpoint completed at step 15000
06:23:25:WU01:FS02:0x22:An exception occurred at step 16683: Error invoking kernel: CUDA_ERROR_UNKNOWN (999)
06:23:25:WU01:FS02:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
06:23:25:WU01:FS02:0x22:Folding@home Core Shutdown: CORE_RESTART
06:23:29:WARNING:WU01:FS02:FahCore returned an unknown error code which probably indicates that it crashed
06:23:29:WARNING:WU01:FS02:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
06:23:29:WU01:FS02:Starting
06:23:29:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
06:23:29:WU01:FS02:Started FahCore on PID 14668
06:23:29:WU01:FS02:Core PID:11268
06:23:29:WU01:FS02:FahCore 0x22 started
06:23:30:WU01:FS02:0x22:*********************** Log Started 2021-02-23T06:23:29Z ***********************
06:23:30:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
06:23:30:WU01:FS02:0x22: Core: Core22
06:23:30:WU01:FS02:0x22: Type: 0x22
06:23:30:WU01:FS02:0x22: Version: 0.0.13
06:23:30:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:23:30:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
06:23:30:WU01:FS02:0x22: Homepage: https://foldingathome.org/
06:23:30:WU01:FS02:0x22: Date: Sep 19 2020
06:23:30:WU01:FS02:0x22: Time: 02:35:58
06:23:30:WU01:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
06:23:30:WU01:FS02:0x22: Branch: core22-0.0.13
06:23:30:WU01:FS02:0x22: Compiler: Visual C++ 2015
06:23:30:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
06:23:30:WU01:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
06:23:30:WU01:FS02:0x22: Platform: win32 10
06:23:30:WU01:FS02:0x22: Bits: 64
06:23:30:WU01:FS02:0x22: Mode: Release
06:23:30:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:23:30:WU01:FS02:0x22: <peastman@stanford.edu>
06:23:30:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 14668 -checkpoint 15
06:23:30:WU01:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
06:23:30:WU01:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
06:23:30:WU01:FS02:0x22:************************************ libFAH ************************************
06:23:30:WU01:FS02:0x22: Date: Sep 7 2020
06:23:30:WU01:FS02:0x22: Time: 19:09:56
06:23:30:WU01:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
06:23:30:WU01:FS02:0x22: Branch: HEAD
06:23:30:WU01:FS02:0x22:************************************ CBang *************************************
06:23:30:WU01:FS02:0x22: Time: 19:08:30
06:23:30:WU01:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
06:23:30:WU01:FS02:0x22:************************************ System ************************************
06:23:30:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:23:30:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:23:30:WU01:FS02:0x22: CPUs: 8
06:23:30:WU01:FS02:0x22: Memory: 7.86GiB
06:23:30:WU01:FS02:0x22:Free Memory: 3.35GiB
06:23:30:WU01:FS02:0x22: Threads: WINDOWS_THREADS
06:23:30:WU01:FS02:0x22: OS Version: 6.2
06:23:30:WU01:FS02:0x22:Has Battery: true
06:23:30:WU01:FS02:0x22: On Battery: false
06:23:30:WU01:FS02:0x22: UTC Offset: -6
06:23:30:WU01:FS02:0x22: PID: 11268
06:23:30:WU01:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
06:23:30:WU01:FS02:0x22:************************************ OpenMM ************************************
06:23:30:WU01:FS02:0x22: Revision: 189320d0
06:23:30:WU01:FS02:0x22:********************************************************************************
06:23:30:WU01:FS02:0x22:Project: 17335 (Run 9, Clone 544, Gen 2)
06:23:30:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
06:23:30:WU01:FS02:0x22:Digital signatures verified
06:23:30:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
06:23:30:WU01:FS02:0x22:Version 0.0.13
06:23:30:WU01:FS02:0x22: Checkpoint write interval: 15000 steps (2%) [50 total]
06:23:30:WU01:FS02:0x22: JSON viewer frame write interval: 7500 steps (1%) [100 total]
06:23:30:WU01:FS02:0x22: XTC frame write interval: 250000 steps (33%) [3 total]
06:23:30:WU01:FS02:0x22: Global context and integrator variables write interval: disabled
06:23:31:WU01:FS02:0x22:There are 4 platforms available.
06:23:31:WU01:FS02:0x22:Platform 0: Reference
06:23:31:WU01:FS02:0x22:Platform 1: CPU
06:23:31:WU01:FS02:0x22:Platform 2: OpenCL
06:23:31:WU01:FS02:0x22: opencl-device 0 specified
06:23:31:WU01:FS02:0x22:Platform 3: CUDA
06:23:31:WU01:FS02:0x22: cuda-device 0 specified
06:23:57:WU01:FS02:0x22:Attempting to create CUDA context:
06:23:57:WU01:FS02:0x22: Configuring platform CUDA
06:24:06:WU01:FS02:0x22: Using CUDA and gpu 0
06:24:07:WU01:FS02:0x22:Completed 15000 out of 750000 steps (2%)
06:24:21:WU00:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
06:27:04:WU00:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
06:27:29:WU01:FS02:0x22:Completed 22500 out of 750000 steps (3%)
06:29:54:WU00:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
06:30:53:WU01:FS02:0x22:Completed 30000 out of 750000 steps (4%)
06:30:56:WU01:FS02:0x22:Checkpoint completed at step 30000
06:32:41:WU00:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
06:34:20:WU01:FS02:0x22:Completed 37500 out of 750000 steps (5%)
06:35:24:WU00:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
06:37:44:WU01:FS02:0x22:Completed 45000 out of 750000 steps (6%)
06:37:46:WU01:FS02:0x22:Checkpoint completed at step 45000
06:38:08:WU00:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
06:41:10:WU01:FS02:0x22:Completed 52500 out of 750000 steps (7%)
06:41:11:WU00:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
06:43:33:FS00:Shutting core down
06:43:33:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 8268
06:43:33:WU00:FS00:0xa7:Exiting, please wait. . .
06:43:35:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
06:43:35:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:43:35:WU00:FS00:Starting
06:43:35:WARNING:WU00:FS00:Changed SMP threads from 6 to 5 this can cause some work units to fail
06:43:35:WARNING:WU00:FS00:AS lowered CPUs from 5 to 3
06:43:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 3
06:43:35:WU00:FS00:Started FahCore on PID 13568
06:43:35:WU00:FS00:Core PID:13464
06:43:35:WU00:FS00:FahCore 0xa7 started
06:43:36:WU00:FS00:0xa7:*********************** Log Started 2021-02-23T06:43:35Z ***********************
06:43:36:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:43:36:WU00:FS00:0xa7: Type: 0xa7
06:43:36:WU00:FS00:0xa7: Core: Gromacs
06:43:36:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 13568 -checkpoint 15 -np
06:43:36:WU00:FS00:0xa7: 3
06:43:36:WU00:FS00:0xa7:************************************ CBang *************************************
06:43:36:WU00:FS00:0xa7: Date: Nov 27 2019
06:43:36:WU00:FS00:0xa7: Time: 03:40:09
06:43:36:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:43:36:WU00:FS00:0xa7: Branch: master
06:43:36:WU00:FS00:0xa7: Compiler: Visual C++ 2008
06:43:36:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:43:36:WU00:FS00:0xa7: Platform: win32 10
06:43:36:WU00:FS00:0xa7: Bits: 64
06:43:36:WU00:FS00:0xa7: Mode: Release
06:43:36:WU00:FS00:0xa7:************************************ System ************************************
06:43:36:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:43:36:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:43:36:WU00:FS00:0xa7: CPUs: 8
06:43:36:WU00:FS00:0xa7: Memory: 7.86GiB
06:43:36:WU00:FS00:0xa7:Free Memory: 2.73GiB
06:43:36:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:43:36:WU00:FS00:0xa7: OS Version: 6.2
06:43:36:WU00:FS00:0xa7:Has Battery: true
06:43:36:WU00:FS00:0xa7: On Battery: false
06:43:36:WU00:FS00:0xa7: UTC Offset: -6
06:43:36:WU00:FS00:0xa7: PID: 13464
06:43:36:WU00:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
06:43:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:43:36:WU00:FS00:0xa7: Version: 0.0.19
06:43:36:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:43:36:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:43:36:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:43:36:WU00:FS00:0xa7: Date: Nov 25 2019
06:43:36:WU00:FS00:0xa7: Time: 17:12:41
06:43:36:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:43:36:WU00:FS00:0xa7:************************************ Build *************************************
06:43:36:WU00:FS00:0xa7: SIMD: avx_256
06:43:36:WU00:FS00:0xa7:********************************************************************************
06:43:36:WU00:FS00:0xa7:Project: 17411 (Run 0, Clone 421, Gen 554)
06:43:36:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:43:36:WU00:FS00:0xa7:Digital signatures verified
06:43:36:WU00:FS00:0xa7:Calling: mdrun -s frame554.tpr -o frame554.trr -x frame554.xtc -cpi state.cpt -cpt 15 -nt 3
06:43:36:WU00:FS00:0xa7:Steps: first=69250000 total=125000
06:43:38:WU00:FS00:0xa7:Completed 16022 out of 125000 steps (12%)
06:44:00:Saving configuration to config.xml
06:44:00:<config>
06:44:00: <!-- Slot Control -->
06:44:00: <power v='MEDIUM'/>
06:44:00:
06:44:00: <!-- User Information -->
06:44:00: <passkey v='*****'/>
06:44:00: <team v='234980'/>
06:44:00: <user v='w6pb36jgbict'/>
06:44:00:
06:44:00: <!-- Folding Slots -->
06:44:00: <slot id='0' type='CPU'/>
06:44:00: <slot id='1' type='GPU'>
06:44:00: <pci-bus v='0'/>
06:44:00: <pci-slot v='2'/>
06:44:00: </slot>
06:44:00: <slot id='2' type='GPU'>
06:44:00: <pci-bus v='1'/>
06:44:00: <pci-slot v='0'/>
06:44:00: </slot>
06:44:00:</config>
06:44:09:WU00:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
06:44:34:WU01:FS02:0x22:Completed 60000 out of 750000 steps (8%)
06:44:37:WU01:FS02:0x22:Checkpoint completed at step 60000
06:46:58:WU00:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
06:48:00:WU01:FS02:0x22:Completed 67500 out of 750000 steps (9%)
06:49:50:WU00:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
06:51:24:WU01:FS02:0x22:Completed 75000 out of 750000 steps (10%)
06:51:27:WU01:FS02:0x22:Checkpoint completed at step 75000
06:52:40:WU00:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
06:54:50:WU01:FS02:0x22:Completed 82500 out of 750000 steps (11%)
06:55:30:WU00:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
06:56:12:FS00:Shutting core down
06:56:12:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 13464
06:56:12:WU00:FS00:0xa7:Exiting, please wait. . .
06:56:15:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
06:56:15:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:56:15:WU00:FS00:Starting
06:56:15:WARNING:WU00:FS00:Changed SMP threads from 5 to 6 this can cause some work units to fail
06:56:15:WARNING:WU00:FS00:AS lowered CPUs from 6 to 3
06:56:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 3
06:56:15:WU00:FS00:Started FahCore on PID 2168
06:56:15:WU00:FS00:Core PID:11784
06:56:15:WU00:FS00:FahCore 0xa7 started
06:56:16:WU00:FS00:0xa7:*********************** Log Started 2021-02-23T06:56:15Z ***********************
06:56:16:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:56:16:WU00:FS00:0xa7: Type: 0xa7
06:56:16:WU00:FS00:0xa7: Core: Gromacs
06:56:16:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 2168 -checkpoint 15 -np 3
06:56:16:WU00:FS00:0xa7:************************************ CBang *************************************
06:56:16:WU00:FS00:0xa7: Date: Nov 27 2019
06:56:16:WU00:FS00:0xa7: Time: 03:40:09
06:56:16:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:56:16:WU00:FS00:0xa7: Branch: master
06:56:16:WU00:FS00:0xa7: Compiler: Visual C++ 2008
06:56:16:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:56:16:WU00:FS00:0xa7: Platform: win32 10
06:56:16:WU00:FS00:0xa7: Bits: 64
06:56:16:WU00:FS00:0xa7: Mode: Release
06:56:16:WU00:FS00:0xa7:************************************ System ************************************
06:56:16:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:56:16:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:56:16:WU00:FS00:0xa7: CPUs: 8
06:56:16:WU00:FS00:0xa7: Memory: 7.86GiB
06:56:16:WU00:FS00:0xa7:Free Memory: 3.47GiB
06:56:16:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:56:16:WU00:FS00:0xa7: OS Version: 6.2
06:56:16:WU00:FS00:0xa7:Has Battery: true
06:56:16:WU00:FS00:0xa7: On Battery: false
06:56:16:WU00:FS00:0xa7: UTC Offset: -6
06:56:16:WU00:FS00:0xa7: PID: 11784
06:56:16:WU00:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
06:56:16:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:56:16:WU00:FS00:0xa7: Version: 0.0.19
06:56:16:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:56:16:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:56:16:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:56:16:WU00:FS00:0xa7: Date: Nov 25 2019
06:56:16:WU00:FS00:0xa7: Time: 17:12:41
06:56:16:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:56:16:WU00:FS00:0xa7:************************************ Build *************************************
06:56:16:WU00:FS00:0xa7: SIMD: avx_256
06:56:16:WU00:FS00:0xa7:********************************************************************************
06:56:16:WU00:FS00:0xa7:Project: 17411 (Run 0, Clone 421, Gen 554)
06:56:16:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:56:16:WU00:FS00:0xa7:Digital signatures verified
06:56:16:WU00:FS00:0xa7:Calling: mdrun -s frame554.tpr -o frame554.trr -x frame554.xtc -cpi state.cpt -cpt 15 -nt 3
06:56:16:WU00:FS00:0xa7:Steps: first=69250000 total=125000
06:56:18:WU00:FS00:0xa7:Completed 21572 out of 125000 steps (17%)
06:57:13:Saving configuration to config.xml
06:57:13:<config>
06:57:13: <!-- Slot Control -->
06:57:13: <power v='FULL'/>
06:57:13:
06:57:13: <!-- User Information -->
06:57:13: <passkey v='*****'/>
06:57:13: <team v='234980'/>
06:57:13: <user v='w6pb36jgbict'/>
06:57:13:
06:57:13: <!-- Folding Slots -->
06:57:13: <slot id='0' type='CPU'/>
06:57:13: <slot id='1' type='GPU'>
06:57:13: <pci-bus v='0'/>
06:57:13: <pci-slot v='2'/>
06:57:13: </slot>
06:57:13: <slot id='2' type='GPU'>
06:57:13: <pci-bus v='1'/>
06:57:13: <pci-slot v='0'/>
06:57:13: </slot>
06:57:13:</config>
06:58:14:WU01:FS02:0x22:Completed 90000 out of 750000 steps (12%)
06:58:15:FS00:Shutting core down
06:58:16:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 11784
06:58:16:WU00:FS00:0xa7:Exiting, please wait. . .
06:58:17:WU01:FS02:0x22:Checkpoint completed at step 90000
06:58:17:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:58:17:WU00:FS00:Starting
06:58:17:WARNING:WU00:FS00:Changed SMP threads from 6 to 5 this can cause some work units to fail
06:58:17:WARNING:WU00:FS00:AS lowered CPUs from 5 to 3
06:58:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 3
06:58:17:WU00:FS00:Started FahCore on PID 11792
06:58:17:WU00:FS00:Core PID:11572
06:58:17:WU00:FS00:FahCore 0xa7 started
06:58:18:WU00:FS00:0xa7:*********************** Log Started 2021-02-23T06:58:17Z ***********************
06:58:18:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:58:18:WU00:FS00:0xa7: Type: 0xa7
06:58:18:WU00:FS00:0xa7: Core: Gromacs
06:58:18:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 11792 -checkpoint 15 -np
06:58:18:WU00:FS00:0xa7: 3
06:58:18:WU00:FS00:0xa7:************************************ CBang *************************************
06:58:18:WU00:FS00:0xa7: Date: Nov 27 2019
06:58:18:WU00:FS00:0xa7: Time: 03:40:09
06:58:18:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:58:18:WU00:FS00:0xa7: Branch: master
06:58:18:WU00:FS00:0xa7: Compiler: Visual C++ 2008
06:58:18:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:58:18:WU00:FS00:0xa7: Platform: win32 10
06:58:18:WU00:FS00:0xa7: Bits: 64
06:58:18:WU00:FS00:0xa7: Mode: Release
06:58:18:WU00:FS00:0xa7:************************************ System ************************************
06:58:18:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:58:18:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:58:18:WU00:FS00:0xa7: CPUs: 8
06:58:18:WU00:FS00:0xa7: Memory: 7.86GiB
06:58:18:WU00:FS00:0xa7:Free Memory: 3.40GiB
06:58:18:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:58:18:WU00:FS00:0xa7: OS Version: 6.2
06:58:18:WU00:FS00:0xa7:Has Battery: true
06:58:18:WU00:FS00:0xa7: On Battery: false
06:58:18:WU00:FS00:0xa7: UTC Offset: -6
06:58:18:WU00:FS00:0xa7: PID: 11572
06:58:18:WU00:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
06:58:18:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:58:18:WU00:FS00:0xa7: Version: 0.0.19
06:58:18:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:58:18:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:58:18:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:58:18:WU00:FS00:0xa7: Date: Nov 25 2019
06:58:18:WU00:FS00:0xa7: Time: 17:12:41
06:58:18:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:58:18:WU00:FS00:0xa7:************************************ Build *************************************
06:58:18:WU00:FS00:0xa7: SIMD: avx_256
06:58:18:WU00:FS00:0xa7:********************************************************************************
06:58:18:WU00:FS00:0xa7:Project: 17411 (Run 0, Clone 421, Gen 554)
06:58:18:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:58:18:WU00:FS00:0xa7:Digital signatures verified
06:58:18:WU00:FS00:0xa7:Calling: mdrun -s frame554.tpr -o frame554.trr -x frame554.xtc -cpi state.cpt -cpt 15 -nt 3
06:58:18:WU00:FS00:0xa7:Steps: first=69250000 total=125000
06:58:20:WU00:FS00:0xa7:Completed 22432 out of 125000 steps (17%)
06:58:23:FS00:Shutting core down
06:58:23:FS02:Shutting core down
06:58:23:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 11572
06:58:23:WU00:FS00:0xa7:Exiting, please wait. . .
06:58:23:WU01:FS02:0x22:WARNING:Console control signal 1 on PID 11268
06:58:23:WU01:FS02:0x22:Exiting, please wait. . .
06:58:23:WU01:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
06:58:23:WU01:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
06:58:25:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
06:58:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:59:15:Saving configuration to config.xml
06:59:15:<config>
06:59:15: <!-- Slot Control -->
06:59:15: <power v='LIGHT'/>
06:59:15:
06:59:15: <!-- User Information -->
06:59:15: <passkey v='*****'/>
06:59:15: <team v='234980'/>
06:59:15: <user v='w6pb36jgbict'/>
06:59:15:
06:59:15: <!-- Folding Slots -->
06:59:15: <slot id='0' type='CPU'/>
06:59:15: <slot id='1' type='GPU'>
06:59:15: <pci-bus v='0'/>
06:59:15: <pci-slot v='2'/>
06:59:15: </slot>
06:59:15: <slot id='2' type='GPU'>
06:59:15: <pci-bus v='1'/>
06:59:15: <pci-slot v='0'/>
06:59:15: </slot>
06:59:15:</config>
06:59:18:WU00:FS00:Starting
06:59:18:WARNING:WU00:FS00:Changed SMP threads from 5 to 3 this can cause some work units to fail
06:59:18:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 3
06:59:18:WU00:FS00:Started FahCore on PID 16948
06:59:18:WU00:FS00:Core PID:8492
06:59:18:WU00:FS00:FahCore 0xa7 started
06:59:18:WU00:FS00:0xa7:*********************** Log Started 2021-02-23T06:59:18Z ***********************
06:59:18:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:59:18:WU00:FS00:0xa7: Type: 0xa7
06:59:18:WU00:FS00:0xa7: Core: Gromacs
06:59:18:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 16948 -checkpoint 15 -np
06:59:18:WU00:FS00:0xa7: 3
06:59:18:WU00:FS00:0xa7:************************************ CBang *************************************
06:59:18:WU00:FS00:0xa7: Date: Nov 27 2019
06:59:18:WU00:FS00:0xa7: Time: 03:40:09
06:59:18:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
06:59:18:WU00:FS00:0xa7: Branch: master
06:59:18:WU00:FS00:0xa7: Compiler: Visual C++ 2008
06:59:18:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:59:18:WU00:FS00:0xa7: Platform: win32 10
06:59:18:WU00:FS00:0xa7: Bits: 64
06:59:18:WU00:FS00:0xa7: Mode: Release
06:59:18:WU00:FS00:0xa7:************************************ System ************************************
06:59:18:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
06:59:18:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:59:18:WU00:FS00:0xa7: CPUs: 8
06:59:18:WU00:FS00:0xa7: Memory: 7.86GiB
06:59:18:WU00:FS00:0xa7:Free Memory: 4.19GiB
06:59:18:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:59:18:WU00:FS00:0xa7: OS Version: 6.2
06:59:18:WU00:FS00:0xa7:Has Battery: true
06:59:18:WU00:FS00:0xa7: On Battery: false
06:59:18:WU00:FS00:0xa7: UTC Offset: -6
06:59:18:WU00:FS00:0xa7: PID: 8492
06:59:18:WU00:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
06:59:18:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:59:18:WU00:FS00:0xa7: Version: 0.0.19
06:59:18:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:59:18:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:59:18:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:59:18:WU00:FS00:0xa7: Date: Nov 25 2019
06:59:18:WU00:FS00:0xa7: Time: 17:12:41
06:59:18:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
06:59:18:WU00:FS00:0xa7:************************************ Build *************************************
06:59:18:WU00:FS00:0xa7: SIMD: avx_256
06:59:18:WU00:FS00:0xa7:********************************************************************************
06:59:18:WU00:FS00:0xa7:Project: 17411 (Run 0, Clone 421, Gen 554)
06:59:18:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
06:59:18:WU00:FS00:0xa7:Digital signatures verified
06:59:18:WU00:FS00:0xa7:Calling: mdrun -s frame554.tpr -o frame554.trr -x frame554.xtc -cpi state.cpt -cpt 15 -nt 3
06:59:18:WU00:FS00:0xa7:Steps: first=69250000 total=125000
06:59:20:WU00:FS00:0xa7:Completed 22462 out of 125000 steps (17%)
06:59:25:WU00:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
Reason: added missing Code tag to log
07:01:16:FS00:Shutting core down
07:01:16:WU01:FS02:Starting
07:01:16:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
07:01:16:WU01:FS02:Started FahCore on PID 13204
07:01:16:WU01:FS02:Core PID:17704
07:01:16:WU01:FS02:FahCore 0x22 started
07:01:16:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 8492
07:01:16:WU00:FS00:0xa7:Exiting, please wait. . .
07:01:17:Saving configuration to config.xml
07:01:17:<config>
07:01:17: <!-- Slot Control -->
07:01:17: <power v='MEDIUM'/>
07:01:17:
07:01:17: <!-- User Information -->
07:01:17: <passkey v='*****'/>
07:01:17: <team v='234980'/>
07:01:17: <user v='w6pb36jgbict'/>
07:01:17:
07:01:17: <!-- Folding Slots -->
07:01:17: <slot id='0' type='CPU'/>
07:01:17: <slot id='1' type='GPU'>
07:01:17: <pci-bus v='0'/>
07:01:17: <pci-slot v='2'/>
07:01:17: </slot>
07:01:17: <slot id='2' type='GPU'>
07:01:17: <pci-bus v='1'/>
07:01:17: <pci-slot v='0'/>
07:01:17: </slot>
07:01:17:</config>
07:01:17:WU01:FS02:0x22:*********************** Log Started 2021-02-23T07:01:16Z ***********************
07:01:17:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
07:01:17:WU01:FS02:0x22: Core: Core22
07:01:17:WU01:FS02:0x22: Type: 0x22
07:01:17:WU01:FS02:0x22: Version: 0.0.13
07:01:17:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:01:17:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
07:01:17:WU01:FS02:0x22: Homepage: https://foldingathome.org/
07:01:17:WU01:FS02:0x22: Date: Sep 19 2020
07:01:17:WU01:FS02:0x22: Time: 02:35:58
07:01:17:WU01:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
07:01:17:WU01:FS02:0x22: Branch: core22-0.0.13
07:01:17:WU01:FS02:0x22: Compiler: Visual C++ 2015
07:01:17:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:01:17:WU01:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
07:01:17:WU01:FS02:0x22: Platform: win32 10
07:01:17:WU01:FS02:0x22: Bits: 64
07:01:17:WU01:FS02:0x22: Mode: Release
07:01:17:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:01:17:WU01:FS02:0x22: <peastman@stanford.edu>
07:01:17:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 13204 -checkpoint 15
07:01:17:WU01:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
07:01:17:WU01:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
07:01:17:WU01:FS02:0x22:************************************ libFAH ************************************
07:01:17:WU01:FS02:0x22: Date: Sep 7 2020
07:01:17:WU01:FS02:0x22: Time: 19:09:56
07:01:17:WU01:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
07:01:17:WU01:FS02:0x22: Branch: HEAD
07:01:17:WU01:FS02:0x22:************************************ CBang *************************************
07:01:17:WU01:FS02:0x22: Time: 19:08:30
07:01:17:WU01:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
07:01:17:WU01:FS02:0x22:************************************ System ************************************
07:01:17:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
07:01:17:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
07:01:17:WU01:FS02:0x22: CPUs: 8
07:01:17:WU01:FS02:0x22: Memory: 7.86GiB
07:01:17:WU01:FS02:0x22:Free Memory: 3.99GiB
07:01:17:WU01:FS02:0x22: Threads: WINDOWS_THREADS
07:01:17:WU01:FS02:0x22: OS Version: 6.2
07:01:17:WU01:FS02:0x22:Has Battery: true
07:01:17:WU01:FS02:0x22: On Battery: false
07:01:17:WU01:FS02:0x22: UTC Offset: -6
07:01:17:WU01:FS02:0x22: PID: 17704
07:01:17:WU01:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
07:01:17:WU01:FS02:0x22:************************************ OpenMM ************************************
07:01:17:WU01:FS02:0x22: Revision: 189320d0
07:01:17:WU01:FS02:0x22:********************************************************************************
07:01:17:WU01:FS02:0x22:Project: 17335 (Run 9, Clone 544, Gen 2)
07:01:17:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
07:01:17:WU01:FS02:0x22:Digital signatures verified
07:01:17:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
07:01:17:WU01:FS02:0x22:Version 0.0.13
07:01:18:WU01:FS02:0x22: Checkpoint write interval: 15000 steps (2%) [50 total]
07:01:18:WU01:FS02:0x22: JSON viewer frame write interval: 7500 steps (1%) [100 total]
07:01:18:WU01:FS02:0x22: XTC frame write interval: 250000 steps (33%) [3 total]
07:01:18:WU01:FS02:0x22: Global context and integrator variables write interval: disabled
07:01:18:WU01:FS02:0x22:There are 4 platforms available.
07:01:18:WU01:FS02:0x22:Platform 0: Reference
07:01:18:WU01:FS02:0x22:Platform 1: CPU
07:01:18:WU01:FS02:0x22:Platform 2: OpenCL
07:01:18:WU01:FS02:0x22: opencl-device 0 specified
07:01:18:WU01:FS02:0x22:Platform 3: CUDA
07:01:18:WU01:FS02:0x22: cuda-device 0 specified
07:01:18:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
07:01:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:01:18:WU00:FS00:Starting
07:01:18:WARNING:WU00:FS00:Changed SMP threads from 3 to 5 this can cause some work units to fail
07:01:18:WARNING:WU00:FS00:AS lowered CPUs from 5 to 3
07:01:18:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 3
07:01:18:WU00:FS00:Started FahCore on PID 16596
07:01:18:WU00:FS00:Core PID:12828
07:01:18:WU00:FS00:FahCore 0xa7 started
07:01:19:WU00:FS00:0xa7:*********************** Log Started 2021-02-23T07:01:18Z ***********************
07:01:19:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:01:19:WU00:FS00:0xa7: Type: 0xa7
07:01:19:WU00:FS00:0xa7: Core: Gromacs
07:01:19:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 16596 -checkpoint 15 -np
07:01:19:WU00:FS00:0xa7: 3
07:01:19:WU00:FS00:0xa7:************************************ CBang *************************************
07:01:19:WU00:FS00:0xa7: Date: Nov 27 2019
07:01:19:WU00:FS00:0xa7: Time: 03:40:09
07:01:19:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:01:19:WU00:FS00:0xa7: Branch: master
07:01:19:WU00:FS00:0xa7: Compiler: Visual C++ 2008
07:01:19:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:01:19:WU00:FS00:0xa7: Platform: win32 10
07:01:19:WU00:FS00:0xa7: Bits: 64
07:01:19:WU00:FS00:0xa7: Mode: Release
07:01:19:WU00:FS00:0xa7:************************************ System ************************************
07:01:19:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
07:01:19:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
07:01:19:WU00:FS00:0xa7: CPUs: 8
07:01:19:WU00:FS00:0xa7: Memory: 7.86GiB
07:01:19:WU00:FS00:0xa7:Free Memory: 4.01GiB
07:01:19:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
07:01:19:WU00:FS00:0xa7: OS Version: 6.2
07:01:19:WU00:FS00:0xa7:Has Battery: true
07:01:19:WU00:FS00:0xa7: On Battery: false
07:01:19:WU00:FS00:0xa7: UTC Offset: -6
07:01:19:WU00:FS00:0xa7: PID: 12828
07:01:19:WU00:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
07:01:19:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:01:19:WU00:FS00:0xa7: Version: 0.0.19
07:01:19:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:01:19:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
07:01:19:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
07:01:19:WU00:FS00:0xa7: Date: Nov 25 2019
07:01:19:WU00:FS00:0xa7: Time: 17:12:41
07:01:19:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:01:19:WU00:FS00:0xa7:************************************ Build *************************************
07:01:19:WU00:FS00:0xa7: SIMD: avx_256
07:01:19:WU00:FS00:0xa7:********************************************************************************
07:01:19:WU00:FS00:0xa7:Project: 17411 (Run 0, Clone 421, Gen 554)
07:01:19:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
07:01:19:WU00:FS00:0xa7:Digital signatures verified
07:01:19:WU00:FS00:0xa7:Calling: mdrun -s frame554.tpr -o frame554.trr -x frame554.xtc -cpi state.cpt -cpt 15 -nt 3
07:01:19:WU00:FS00:0xa7:Steps: first=69250000 total=125000
07:01:21:WU00:FS00:0xa7:Completed 23452 out of 125000 steps (18%)
07:01:38:WU01:FS02:0x22:Attempting to create CUDA context:
07:01:38:WU01:FS02:0x22: Configuring platform CUDA
07:01:45:WU01:FS02:0x22: Using CUDA and gpu 0
07:01:46:WU01:FS02:0x22:Completed 90000 out of 750000 steps (12%)
07:02:02:WU00:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
07:04:49:WU00:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
07:05:08:WU01:FS02:0x22:Completed 97500 out of 750000 steps (13%)
07:07:40:WU00:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
07:08:31:WU01:FS02:0x22:Completed 105000 out of 750000 steps (14%)
07:08:35:WU01:FS02:0x22:Checkpoint completed at step 105000
07:10:34:WU00:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
07:11:58:WU01:FS02:0x22:Completed 112500 out of 750000 steps (15%)
07:13:30:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
07:15:21:WU01:FS02:0x22:Completed 120000 out of 750000 steps (16%)
07:15:24:WU01:FS02:0x
22:Checkpoint completed at step 120000
07:15:47:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
07:16:28:WU00:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
07:18:48:WU01:FS02:0x22:Completed 127500 out of 750000 steps (17%)
07:19:20:WU00:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
07:22:12:WU01:FS02:0x22:Completed 135000 out of 750000 steps (18%)
07:22:16:WU01:FS02:0x22:Checkpoint completed at step 135000
07:22:20:WU00:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
07:25:14:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
07:25:39:WU01:FS02:0x22:Completed 142500 out of 750000 steps (19%)
07:28:11:WU00:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
07:29:03:WU01:FS02:0x22:Completed 150000 out of 750000 steps (20%)
07:29:06:WU01:FS02:0x22:Checkpoint completed at step 150000
07:31:06:WU00:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
07:32:29:WU01:FS02:0x22:Completed 157500 out of 750000 steps (21%)
07:33:59:WU00:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
07:35:53:WU01:FS02:0x22:Completed 165000 out of 750000 steps (22%)
07:35:56:WU01:FS02:0x22:Checkpoint completed at step 165000
07:36:52:WU00:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
07:39:19:WU01:FS02:0x22:Completed 172500 out of 750000 steps (23%)
07:39:50:WU00:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
07:42:43:WU01:FS02:0x22:Completed 180000 out of 750000 steps (24%)
07:42:46:WU01:FS02:0x22:Checkpoint completed at step 180000
07:42:52:WU00:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
07:45:44:WU00:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
07:46:10:WU01:FS02:0x22:Completed 187500 out of 750000 steps (25%)
07:48:36:WU00:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
07:49:33:WU01:FS02:0x22:Completed 195000 out of 750000 steps (26%)
07:49:36:WU01:FS02:0x22:Checkpoint completed at step 195000
07:51:25:WU00:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
07:52:59:WU01:FS02:0x22:Completed 202500 out of 750000 steps (27%)
07:54:14:WU00:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
07:56:22:WU01:FS02:0x22:Completed 210000 out of 750000 steps (28%)
07:56:25:WU01:FS02:0x22:Checkpoint completed at step 210000
07:57:05:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
07:59:48:WU01:FS02:0x22:Completed 217500 out of 750000 steps (29%)
07:59:54:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
08:02:46:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
08:03:12:WU01:FS02:0x22:Completed 225000 out of 750000 steps (30%)
08:03:15:WU01:FS02:0x22:Checkpoint completed at step 225000
08:05:39:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
08:06:39:WU01:FS02:0x22:Completed 232500 out of 750000 steps (31%)
08:08:31:WU00:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
08:10:02:WU01:FS02:0x22:Completed 240000 out of 750000 steps (32%)
08:10:05:WU01:FS02:0x22:Checkpoint completed at step 240000
08:11:21:WU00:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
08:13:28:WU01:FS02:0x22:Completed 247500 out of 750000 steps (33%)
08:14:13:WU00:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
08:16:52:WU01:FS02:0x22:Completed 255000 out of 750000 steps (34%)
08:16:54:WU01:FS02:0x22:Checkpoint completed at step 255000
08:17:05:WU00:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
08:19:53:WU00:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
08:20:18:WU01:FS02:0x22:Completed 262500 out of 750000 steps (35%)
08:22:41:WU00:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
08:23:41:WU01:FS02:0x22:Completed 270000 out of 750000 steps (36%)
08:23:44:WU01:FS02:0x22:Checkpoint completed at step 270000
08:25:30:WU00:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
08:27:07:WU01:FS02:0x22:Completed 277500 out of 750000 steps (37%)
08:28:18:WU00:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
08:30:30:WU01:FS02:0x22:Completed 285000 out of 750000 steps (38%)
08:30:33:WU01:FS02:0x22:Checkpoint completed at step 285000
08:31:06:WU00:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
08:33:55:WU00:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
08:33:56:WU01:FS02:0x22:Completed 292500 out of 750000 steps (39%)
08:36:42:WU00:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
08:37:20:WU01:FS02:0x22:Completed 300000 out of 750000 steps (40%)
08:37:22:WU01:FS02:0x22:Checkpoint completed at step 300000
08:39:31:WU00:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
08:40:46:WU01:FS02:0x22:Completed 307500 out of 750000 steps (41%)
08:42:21:WU00:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
08:44:09:WU01:FS02:0x22:Completed 315000 out of 750000 steps (42%)
08:44:12:WU01:FS02:0x22:Checkpoint completed at step 315000
08:45:11:WU00:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
08:47:35:WU01:FS02:0x22:Completed 322500 out of 750000 steps (43%)
08:47:58:WU00:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
08:50:38:WU00:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
08:50:58:WU01:FS02:0x22:Completed 330000 out of 750000 steps (44%)
08:51:00:WU01:FS02:0x22:Checkpoint completed at step 330000
08:53:22:WU00:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
08:54:23:WU01:FS02:0x22:Completed 337500 out of 750000 steps (45%)
08:56:11:WU00:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
08:57:46:WU01:FS02:0x22:Completed 345000 out of 750000 steps (46%)
08:57:49:WU01:FS02:0x22:Checkpoint completed at step 345000
08:59:00:WU00:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
09:01:12:WU01:FS02:0x22:Completed 352500 out of 750000 steps (47%)
09:01:47:WU00:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
09:04:34:WU00:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
09:04:35:WU01:FS02:0x22:Completed 360000 out of 750000 steps (48%)
09:04:37:WU01:FS02:0x22:Checkpoint completed at step 360000
09:07:21:WU00:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
09:08:00:WU01:FS02:0x22:Completed 367500 out of 750000 steps (49%)
09:10:03:WU00:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
09:11:23:WU01:FS02:0x22:Completed 375000 out of 750000 steps (50%)
09:11:26:WU01:FS02:0x22:Checkpoint completed at step 375000
09:12:45:WU00:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
09:14:48:WU01:FS02:0x22:Completed 382500 out of 750000 steps (51%)
09:15:27:WU00:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
09:18:10:WU00:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
09:18:11:WU01:FS02:0x22:Completed 390000 out of 750000 steps (52%)
09:18:14:WU01:FS02:0x22:Checkpoint completed at step 390000
09:20:53:WU00:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
09:21:37:WU01:FS02:0x22:Completed 397500 out of 750000 steps (53%)
09:23:34:WU00:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
09:24:59:WU01:FS02:0x22:Completed 405000 out of 750000 steps (54%)
09:25:02:WU01:FS02:0x22:Checkpoint completed at step 405000
09:26:17:WU00:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
09:28:25:WU01:FS02:0x22:Completed 412500 out of 750000 steps (55%)
09:29:00:WU00:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
09:31:46:WU00:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
09:31:48:WU01:FS02:0x22:Completed 420000 out of 750000 steps (56%)
09:31:51:WU01:FS02:0x22:Checkpoint completed at step 420000
09:34:29:WU00:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
09:35:13:WU01:FS02:0x22:Completed 427500 out of 750000 steps (57%)
09:37:11:WU00:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
09:38:36:WU01:FS02:0x22:Completed 435000 out of 750000 steps (58%)
09:38:39:WU01:FS02:0x22:Checkpoint completed at step 435000
09:39:54:WU00:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
09:42:02:WU01:FS02:0x22:Completed 442500 out of 750000 steps (59%)
09:42:35:WU00:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
09:45:18:WU00:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
09:45:25:WU01:FS02:0x22:Completed 450000 out of 750000 steps (60%)
09:45:28:WU01:FS02:0x22:Checkpoint completed at step 450000
09:48:06:WU00:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
09:48:51:WU01:FS02:0x22:Completed 457500 out of 750000 steps (61%)
09:50:55:WU00:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
09:52:14:WU01:FS02:0x22:Completed 465000 out of 750000 steps (62%)
09:52:17:WU01:FS02:0x22:Checkpoint completed at step 465000
09:53:43:WU00:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
09:55:40:WU01:FS02:0x22:Completed 472500 out of 750000 steps (63%)
09:56:24:WU00:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
09:59:03:WU01:FS02:0x22:Completed 480000 out of 750000 steps (64%)
09:59:06:WU00:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
09:59:06:WU01:FS02:0x22:Checkpoint completed at step 480000
10:01:50:WU00:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
10:02:29:WU01:FS02:0x22:Completed 487500 out of 750000 steps (65%)
10:04:35:WU00:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
10:05:52:WU01:FS02:0x22:Completed 495000 out of 750000 steps (66%)
10:05:55:WU01:FS02:0x22:Checkpoint completed at step 495000
10:07:20:WU00:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
10:09:18:WU01:FS02:0x22:Completed 502500 out of 750000 steps (67%)
10:10:07:WU00:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
10:12:41:WU01:FS02:0x22:Completed 510000 out of 750000 steps (68%)
10:12:44:WU01:FS02:0x22:Checkpoint completed at step 510000
10:12:58:WU00:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
10:15:43:WU00:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
10:16:06:WU01:FS02:0x22:Completed 517500 out of 750000 steps (69%)
10:18:27:WU00:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
10:19:29:WU01:FS02:0x22:Completed 525000 out of 750000 steps (70%)
10:19:32:WU01:FS02:0x22:Checkpoint completed at step 525000
10:21:13:WU00:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
10:22:55:WU01:FS02:0x22:Completed 532500 out of 750000 steps (71%)
10:23:59:WU00:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
10:26:18:WU01:FS02:0x22:Completed 540000 out of 750000 steps (72%)
10:26:21:WU01:FS02:0x22:Checkpoint completed at step 540000
10:26:43:WU00:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
10:29:24:WU00:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
10:29:44:WU01:FS02:0x22:Completed 547500 out of 750000 steps (73%)
10:32:06:WU00:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
10:33:07:WU01:FS02:0x22:Completed 555000 out of 750000 steps (74%)
10:33:10:WU01:FS02:0x22:Checkpoint completed at step 555000
10:34:52:WU00:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
10:36:33:WU01:FS02:0x22:Completed 562500 out of 750000 steps (75%)
10:37:41:WU00:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
10:39:56:WU01:FS02:0x22:Completed 570000 out of 750000 steps (76%)
10:39:59:WU01:FS02:0x22:Checkpoint completed at step 570000
10:40:30:WU00:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
10:43:18:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
10:43:21:WU01:FS02:0x22:Completed 577500 out of 750000 steps (77%)
10:46:07:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
10:46:08:WU02:FS00:Connecting to assign1.foldingathome.org:80
10:46:08:WU02:FS00:Assigned to work server 129.32.209.201
10:46:08:WU02:FS00:Requesting new work unit for slot 00: cpu:5 from 129.32.209.201
10:46:08:WU02:FS00:Connecting to 129.32.209.201:8080
10:46:09:WU02:FS00:Downloading 6.65MiB
10:46:13:WU02:FS00:Download complete
10:46:13:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16927 run:30 clone:17 gen:139 core:0xa7 unit:0x000000110000008b0000421f0000001e
10:46:44:WU01:FS02:0x22:Completed 585000 out of 750000 steps (78%)
10:46:47:WU01:FS02:0x22:Checkpoint completed at step 585000
10:48:58:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
10:49:01:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
10:49:01:WU00:FS00:0xa7:Saving result file frame554.trr
10:49:01:WU00:FS00:0xa7:Saving result file frame554.xtc
10:49:01:WU00:FS00:0xa7:Saving result file md.log
10:49:01:WU00:FS00:0xa7:Saving result file science.log
10:49:01:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
10:49:02:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:49:02:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17411 run:0 clone:421 gen:554 core:0xa7 unit:0x000001a50000022a0000440300000000
10:49:02:WU00:FS00:Uploading 10.04MiB to 66.170.111.50
10:49:02:WU00:FS00:Connecting to 66.170.111.50:8080
10:49:02:WU02:FS00:Starting
10:49:02:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 5
10:49:02:WU02:FS00:Started FahCore on PID 8580
10:49:02:WU02:FS00:Core PID:16876
10:49:02:WU02:FS00:FahCore 0xa7 started
10:49:02:WU02:FS00:0xa7:*********************** Log Started 2021-02-23T10:49:02Z ***********************
10:49:02:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:49:02:WU02:FS00:0xa7: Type: 0xa7
10:49:02:WU02:FS00:0xa7: Core: Gromacs
10:49:02:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 8580 -checkpoint 15 -np 5
10:49:02:WU02:FS00:0xa7:************************************ CBang *************************************
10:49:02:WU02:FS00:0xa7: Date: Nov 27 2019
10:49:02:WU02:FS00:0xa7: Time: 03:40:09
10:49:02:WU02:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
10:49:02:WU02:FS00:0xa7: Branch: master
10:49:02:WU02:FS00:0xa7: Compiler: Visual C++ 2008
10:49:02:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:49:02:WU02:FS00:0xa7: Platform: win32 10
10:49:02:WU02:FS00:0xa7: Bits: 64
10:49:02:WU02:FS00:0xa7: Mode: Release
10:49:02:WU02:FS00:0xa7:************************************ System ************************************
10:49:02:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
10:49:02:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
10:49:02:WU02:FS00:0xa7: CPUs: 8
10:49:02:WU02:FS00:0xa7: Memory: 7.86GiB
10:49:02:WU02:FS00:0xa7:Free Memory: 3.16GiB
10:49:02:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
10:49:02:WU02:FS00:0xa7: OS Version: 6.2
10:49:02:WU02:FS00:0xa7:Has Battery: true
10:49:02:WU02:FS00:0xa7: On Battery: false
10:49:02:WU02:FS00:0xa7: UTC Offset: -6
10:49:02:WU02:FS00:0xa7: PID: 16876
10:49:02:WU02:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
10:49:02:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
10:49:02:WU02:FS00:0xa7: Version: 0.0.19
10:49:02:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:49:02:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
10:49:02:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
10:49:02:WU02:FS00:0xa7: Date: Nov 25 2019
10:49:02:WU02:FS00:0xa7: Time: 17:12:41
10:49:02:WU02:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
10:49:02:WU02:FS00:0xa7:************************************ Build *************************************
10:49:02:WU02:FS00:0xa7: SIMD: avx_256
10:49:02:WU02:FS00:0xa7:********************************************************************************
10:49:02:WU02:FS00:0xa7:Project: 16927 (Run 30, Clone 17, Gen 139)
10:49:02:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
10:49:02:WU02:FS00:0xa7:Reading tar file core.xml
10:49:02:WU02:FS00:0xa7:Reading tar file frame139.tpr
10:49:02:WU02:FS00:0xa7:Digital signatures verified
10:49:02:WU02:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
10:49:02:WU02:FS00:0xa7:Calling: mdrun -s frame139.tpr -o frame139.trr -cpt 15 -nt 4
10:49:02:WU02:FS00:0xa7:Steps: first=69500000 total=500000
10:49:04:WU02:FS00:0xa7:Completed 1 out of 500000 steps (0%)
10:49:08:WU00:FS00:Upload 19.30%
10:49:14:WU00:FS00:Upload 42.34%
10:49:20:WU00:FS00:Upload 66.01%
10:49:26:WU00:FS00:Upload 88.42%
10:49:29:WU00:FS00:Upload complete
10:49:29:WU00:FS00:Server responded WORK_ACK (400)
10:49:29:WU00:FS00:Final credit estimate, 3453.00 points
10:49:29:WU00:FS00:Cleaning up
10:50:10:WU01:FS02:0x22:Completed 592500 out of 750000 steps (79%)
10:53:34:WU01:FS02:0x22:Completed 600000 out of 750000 steps (80%)
10:53:37:WU01:FS02:0x22:Checkpoint completed at step 600000
10:54:33:WU02:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
10:57:00:WU01:FS02:0x22:Completed 607500 out of 750000 steps (81%)
11:00:03:WU02:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
11:00:23:WU01:FS02:0x22:Completed 615000 out of 750000 steps (82%)
11:00:26:WU01:FS02:0x22:Checkpoint completed at step 615000
11:03:48:WU01:FS02:0x22:Completed 622500 out of 750000 steps (83%)
11:05:34:WU02:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
11:07:11:WU01:FS02:0x22:Completed 630000 out of 750000 steps (84%)
11:07:14:WU01:FS02:0x22:Checkpoint completed at step 630000
11:10:38:WU01:FS02:0x22:Completed 637500 out of 750000 steps (85%)
11:11:03:WU02:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
11:14:01:WU01:FS02:0x22:Completed 645000 out of 750000 steps (86%)
11:14:04:WU01:FS02:0x22:Checkpoint completed at step 645000
11:16:31:WU02:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
11:17:27:WU01:FS02:0x22:Completed 652500 out of 750000 steps (87%)
11:20:50:WU01:FS02:0x22:Completed 660000 out of 750000 steps (88%)
11:20:53:WU01:FS02:0x22:Checkpoint completed at step 660000
11:21:58:WU02:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
11:24:16:WU01:FS02:0x22:Completed 667500 out of 750000 steps (89%)
11:27:25:WU02:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
11:27:39:WU01:FS02:0x22:Completed 675000 out of 750000 steps (90%)
11:27:42:WU01:FS02:0x22:Checkpoint completed at step 675000
11:31:05:WU01:FS02:0x22:Completed 682500 out of 750000 steps (91%)
11:32:49:WU02:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
11:34:28:WU01:FS02:0x22:Completed 690000 out of 750000 steps (92%)
11:34:31:WU01:FS02:0x22:Checkpoint completed at step 690000
11:37:54:WU01:FS02:0x22:Completed 697500 out of 750000 steps (93%)
11:38:13:WU02:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
11:41:17:WU01:FS02:0x22:Completed 705000 out of 750000 steps (94%)
11:41:20:WU01:FS02:0x22:Checkpoint completed at step 705000
11:43:38:WU02:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
11:44:43:WU01:FS02:0x22:Completed 712500 out of 750000 steps (95%)
11:48:06:WU01:FS02:0x22:Completed 720000 out of 750000 steps (96%)
11:48:08:WU01:FS02:0x22:Checkpoint completed at step 720000
11:49:04:WU02:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
11:51:32:WU01:FS02:0x22:Completed 727500 out of 750000 steps (97%)
11:52:45:66:127.0.0.1:New Web session
11:54:33:WU02:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
11:54:55:WU01:FS02:0x22:Completed 735000 out of 750000 steps (98%)
11:54:58:WU01:FS02:0x22:Checkpoint completed at step 735000
11:58:21:WU01:FS02:0x22:Completed 742500 out of 750000 steps (99%)
11:58:22:WU00:FS02:Connecting to assign1.foldingathome.org:80
11:58:23:WU00:FS02:Assigned to work server 140.163.4.210
11:58:23:WU00:FS02:Requesting new work unit for slot 02: gpu:1:0 TU117M [GeForce GTX 1650 Mobile / Max-Q] from 140.163.4.210
11:58:23:WU00:FS02:Connecting to 140.163.4.210:8080
11:58:23:WU00:FS02:Downloading 1.89MiB
11:58:24:WU00:FS02:Download complete
11:58:24:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17800 run:55 clone:7 gen:149 core:0x22 unit:0x00000007000000950000458800000037
12:00:09:WU02:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
12:01:45:WU01:FS02:0x22:Completed 750000 out of 750000 steps (100%)
12:01:45:WU01:FS02:0x22:Average performance: 212.285 ns/day
12:01:48:WU01:FS02:0x22:Checkpoint completed at step 750000
12:02:17:WU01:FS02:0x22:Saving result file ..\logfile_01.txt
12:02:17:WU01:FS02:0x22:Saving result file checkpointIntegrator.xml.bz2
12:02:17:WU01:FS02:0x22:Saving result file checkpointState.xml.bz2
12:02:17:WU01:FS02:0x22:Saving result file positions.xtc
12:02:17:WU01:FS02:0x22:Saving result file science.log
12:02:17:WU01:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
12:02:18:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:02:18:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:17335 run:9 clone:544 gen:2 core:0x22 unit:0x0000022000000002000043b700000009
12:02:18:WU01:FS02:Uploading 24.07MiB to 140.163.4.200
12:02:18:WU01:FS02:Connecting to 140.163.4.200:8080
12:02:19:WU00:FS02:Starting
12:02:19:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:02:19:WU00:FS02:Started FahCore on PID 15628
12:02:19:WU00:FS02:Core PID:4216
12:02:19:WU00:FS02:FahCore 0x22 started
12:02:19:WU00:FS02:0x22:*********************** Log Started 2021-02-23T12:02:19Z ***********************
12:02:19:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
12:02:19:WU00:FS02:0x22: Core: Core22
12:02:19:WU00:FS02:0x22: Type: 0x22
12:02:19:WU00:FS02:0x22: Version: 0.0.13
12:02:19:WU00:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:02:19:WU00:FS02:0x22: Copyright: 2020 foldingathome.org
12:02:19:WU00:FS02:0x22: Homepage: https://foldingathome.org/
12:02:19:WU00:FS02:0x22: Date: Sep 19 2020
12:02:19:WU00:FS02:0x22: Time: 02:35:58
12:02:19:WU00:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
12:02:19:WU00:FS02:0x22: Branch: core22-0.0.13
12:02:19:WU00:FS02:0x22: Compiler: Visual C++ 2015
12:02:19:WU00:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:02:19:WU00:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
12:02:19:WU00:FS02:0x22: Platform: win32 10
12:02:19:WU00:FS02:0x22: Bits: 64
12:02:19:WU00:FS02:0x22: Mode: Release
12:02:19:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:02:19:WU00:FS02:0x22: <peastman@stanford.edu>
12:02:19:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 15628 -checkpoint 15
12:02:19:WU00:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
12:02:19:WU00:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
12:02:19:WU00:FS02:0x22:************************************ libFAH ************************************
12:02:19:WU00:FS02:0x22: Date: Sep 7 2020
12:02:19:WU00:FS02:0x22: Time: 19:09:56
12:02:19:WU00:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
12:02:19:WU00:FS02:0x22: Branch: HEAD
12:02:19:WU00:FS02:0x22:************************************ CBang *************************************
12:02:19:WU00:FS02:0x22: Time: 19:08:30
12:02:19:WU00:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
12:02:19:WU00:FS02:0x22:************************************ System ************************************
12:02:19:WU00:FS02:0x22: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
12:02:19:WU00:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
12:02:19:WU00:FS02:0x22: CPUs: 8
12:02:19:WU00:FS02:0x22: Memory: 7.86GiB
12:02:19:WU00:FS02:0x22:Free Memory: 3.76GiB
12:02:19:WU00:FS02:0x22: Threads: WINDOWS_THREADS
12:02:19:WU00:FS02:0x22: OS Version: 6.2
12:02:19:WU00:FS02:0x22:Has Battery: true
12:02:19:WU00:FS02:0x22: On Battery: false
12:02:19:WU00:FS02:0x22: UTC Offset: -6
12:02:19:WU00:FS02:0x22: PID: 4216
12:02:19:WU00:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
12:02:19:WU00:FS02:0x22:************************************ OpenMM ************************************
12:02:19:WU00:FS02:0x22: Revision: 189320d0
12:02:19:WU00:FS02:0x22:********************************************************************************
12:02:19:WU00:FS02:0x22:Project: 17800 (Run 55, Clone 7, Gen 149)
12:02:19:WU00:FS02:0x22:Unit: 0x00000000000000000000000000000000
12:02:19:WU00:FS02:0x22:Reading tar file core.xml
12:02:19:WU00:FS02:0x22:Reading tar file integrator.xml.bz2
12:02:19:WU00:FS02:0x22:Reading tar file state.xml.bz2
12:02:19:WU00:FS02:0x22:Reading tar file system.xml.bz2
12:02:19:WU00:FS02:0x22:Digital signatures verified
12:02:19:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
12:02:19:WU00:FS02:0x22:Version 0.0.13
12:02:19:WU00:FS02:0x22: Checkpoint write interval: 250000 steps (5%) [20 total]
12:02:19:WU00:FS02:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
12:02:19:WU00:FS02:0x22: XTC frame write interval: 25000 steps (0.5%) [200 total]
12:02:19:WU00:FS02:0x22: Global context and integrator variables write interval: disabled
12:02:19:WU00:FS02:0x22:There are 4 platforms available.
12:02:19:WU00:FS02:0x22:Platform 0: Reference
12:02:19:WU00:FS02:0x22:Platform 1: CPU
12:02:19:WU00:FS02:0x22:Platform 2: OpenCL
12:02:19:WU00:FS02:0x22: opencl-device 0 specified
12:02:19:WU00:FS02:0x22:Platform 3: CUDA
12:02:19:WU00:FS02:0x22: cuda-device 0 specified
12:02:22:WU00:FS02:0x22:Attempting to create CUDA context:
12:02:22:WU00:FS02:0x22: Configuring platform CUDA
12:02:24:WU01:FS02:Upload 9.35%
12:02:27:WU00:FS02:0x22: Using CUDA and gpu 0
12:02:27:WU00:FS02:0x22:Completed 0 out of 5000000 steps (0%)
12:02:28:WU00:FS02:0x22:Checkpoint completed at step 0
12:02:30:WU01:FS02:Upload 19.74%
12:02:36:WU01:FS02:Upload 27.01%
12:02:42:WU01:FS02:Upload 32.98%
12:02:48:WU01:FS02:Upload 42.59%
12:02:54:WU01:FS02:Upload 54.01%
12:03:00:WU01:FS02:Upload 63.10%
12:03:06:WU01:FS02:Upload 73.75%
12:03:12:WU01:FS02:Upload 84.14%
12:03:18:WU01:FS02:Upload 94.52%
12:03:22:WU01:FS02:Upload complete
12:03:22:WU01:FS02:Server responded WORK_ACK (400)
12:03:22:WU01:FS02:Final credit estimate, 106207.00 points
12:03:22:WU01:FS02:Cleaning up
12:03:48:WU00:FS02:0x22:Completed 50000 out of 5000000 steps (1%)
12:05:08:WU00:FS02:0x22:Completed 100000 out of 5000000 steps (2%)
12:05:49:WU02:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
******************************* Date: 2021-02-23 *******************************
12:06:28:WU00:FS02:0x22:Completed 150000 out of 5000000 steps (3%)
12:07:48:WU00:FS02:0x22:Completed 200000 out of 5000000 steps (4%)
12:09:08:WU00:FS02:0x22:Completed 250000 out of 5000000 steps (5%)
12:09:08:WU00:FS02:0x22:Checkpoint completed at step 250000
12:10:28:WU00:FS02:0x22:Completed 300000 out of 5000000 steps (6%)
12:11:34:WU02:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
12:11:48:WU00:FS02:0x22:Completed 350000 out of 5000000 steps (7%)
12:13:08:WU00:FS02:0x22:Completed 400000 out of 5000000 steps (8%)
12:14:29:WU00:FS02:0x22:Completed 450000 out of 5000000 steps (9%)
12:15:49:WU00:FS02:0x22:Completed 500000 out of 5000000 steps (10%)
12:15:49:WU00:FS02:0x22:Checkpoint completed at step 500000
12:17:09:WU00:FS02:0x22:Completed 550000 out of 5000000 steps (11%)
12:17:18:WU02:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
12:18:29:WU00:FS02:0x22:Completed 600000 out of 5000000 steps (12%)
12:19:49:WU00:FS02:0x22:Completed 650000 out of 5000000 steps (13%)
12:21:09:WU00:FS02:0x22:Completed 700000 out of 5000000 steps (14%)
12:22:29:WU00:FS02:0x22:Completed 750000 out of 5000000 steps (15%)
12:22:29:WU00:FS02:0x22:Checkpoint completed at step 750000
12:22:59:WU02:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
12:23:49:WU00:FS02:0x22:Completed 800000 out of 5000000 steps (16%)
12:25:09:WU00:FS02:0x22:Completed 850000 out of 5000000 steps (17%)
12:26:29:WU00:FS02:0x22:Completed 900000 out of 5000000 steps (18%)
12:27:49:WU00:FS02:0x22:Completed 950000 out of 5000000 steps (19%)
12:28:40:WU02:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
12:29:09:WU00:FS02:0x22:Completed 1000000 out of 5000000 steps (20%)
12:29:10:WU00:FS02:0x22:Checkpoint completed at step 1000000
12:30:30:WU00:FS02:0x22:Completed 1050000 out of 5000000 steps (21%)
12:31:50:WU00:FS02:0x22:Completed 1100000 out of 5000000 steps (22%)
12:33:10:WU00:FS02:0x22:Completed 1150000 out of 5000000 steps (23%)
12:34:24:WU02:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
12:34:30:WU00:FS02:0x22:Completed 1200000 out of 5000000 steps (24%)
12:35:50:WU00:FS02:0x22:Completed 1250000 out of 5000000 steps (25%)
12:35:50:WU00:FS02:0x22:Checkpoint completed at step 1250000
12:37:10:WU00:FS02:0x22:Completed 1300000 out of 5000000 steps (26%)
12:38:30:WU00:FS02:0x22:Completed 1350000 out of 5000000 steps (27%)
12:39:50:WU00:FS02:0x22:Completed 1400000 out of 5000000 steps (28%)
12:40:05:WU02:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
12:41:10:WU00:FS02:0x22:Completed 1450000 out of 5000000 steps (29%)
12:42:31:WU00:FS02:0x22:Completed 1500000 out of 5000000 steps (30%)
12:42:31:WU00:FS02:0x22:Checkpoint completed at step 1500000
12:43:51:WU00:FS02:0x22:Completed 1550000 out of 5000000 steps (31%)
12:45:11:WU00:FS02:0x22:Completed 1600000 out of 5000000 steps (32%)
12:45:45:WU02:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
12:46:31:WU00:FS02:0x22:Completed 1650000 out of 5000000 steps (33%)
12:47:51:WU00:FS02:0x22:Completed 1700000 out of 5000000 steps (34%)
12:49:11:WU00:FS02:0x22:Completed 1750000 out of 5000000 steps (35%)
12:49:11:WU00:FS02:0x22:Checkpoint completed at step 1750000
12:50:31:WU00:FS02:0x22:Completed 1800000 out of 5000000 steps (36%)
12:51:27:WU02:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
12:51:52:WU00:FS02:0x22:Completed 1850000 out of 5000000 steps (37%)
12:53:12:WU00:FS02:0x22:Completed 1900000 out of 5000000 steps (38%)
12:54:32:WU00:FS02:0x22:Completed 1950000 out of 5000000 steps (39%)
12:55:51:WU00:FS02:0x22:Completed 2000000 out of 5000000 steps (40%)
12:55:52:WU00:FS02:0x22:Checkpoint completed at step 2000000
12:57:05:WU02:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
12:57:12:WU00:FS02:0x22:Completed 2050000 out of 5000000 steps (41%)
12:58:31:WU00:FS02:0x22:Completed 2100000 out of 5000000 steps (42%)
12:59:51:WU00:FS02:0x22:Completed 2150000 out of 5000000 steps (43%)
13:01:11:WU00:FS02:0x22:Completed 2200000 out of 5000000 steps (44%)
13:02:30:WU00:FS02:0x22:Completed 2250000 out of 5000000 steps (45%)
13:02:31:WU00:FS02:0x22:Checkpoint completed at step 2250000
13:02:42:WU02:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
13:03:50:WU00:FS02:0x22:Completed 2300000 out of 5000000 steps (46%)
13:05:10:WU00:FS02:0x22:Completed 2350000 out of 5000000 steps (47%)
13:06:30:WU00:FS02:0x22:Completed 2400000 out of 5000000 steps (48%)
13:07:50:WU00:FS02:0x22:Completed 2450000 out of 5000000 steps (49%)
13:08:17:WU02:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
13:09:09:WU00:FS02:0x22:Completed 2500000 out of 5000000 steps (50%)
13:09:09:WU00:FS02:0x22:Checkpoint completed at step 2500000
13:10:29:WU00:FS02:0x22:Completed 2550000 out of 5000000 steps (51%)
13:11:49:WU00:FS02:0x22:Completed 2600000 out of 5000000 steps (52%)
13:13:09:WU00:FS02:0x22:Completed 2650000 out of 5000000 steps (53%)
13:13:52:WU02:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
13:14:28:WU00:FS02:0x22:Completed 2700000 out of 5000000 steps (54%)
13:15:48:WU00:FS02:0x22:Completed 2750000 out of 5000000 steps (55%)
13:15:49:WU00:FS02:0x22:Checkpoint completed at step 2750000
13:17:08:WU00:FS02:0x22:Completed 2800000 out of 5000000 steps (56%)
13:18:28:WU00:FS02:0x22:Completed 2850000 out of 5000000 steps (57%)
13:19:31:WU02:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
13:19:48:WU00:FS02:0x22:Completed 2900000 out of 5000000 steps (58%)
13:21:08:WU00:FS02:0x22:Completed 2950000 out of 5000000 steps (59%)
13:22:28:WU00:FS02:0x22:Completed 3000000 out of 5000000 steps (60%)
13:22:28:WU00:FS02:0x22:Checkpoint completed at step 3000000
13:23:48:WU00:FS02:0x22:Completed 3050000 out of 5000000 steps (61%)
13:25:08:WU00:FS02:0x22:Completed 3100000 out of 5000000 steps (62%)
13:25:09:WU02:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
13:26:27:WU00:FS02:0x22:Completed 3150000 out of 5000000 steps (63%)
13:27:47:WU00:FS02:0x22:Completed 3200000 out of 5000000 steps (64%)
13:29:07:WU00:FS02:0x22:Completed 3250000 out of 5000000 steps (65%)
13:29:07:WU00:FS02:0x22:Checkpoint completed at step 3250000
13:30:27:WU00:FS02:0x22:Completed 3300000 out of 5000000 steps (66%)
13:30:47:WU02:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
13:31:47:WU00:FS02:0x22:Completed 3350000 out of 5000000 steps (67%)
13:33:07:WU00:FS02:0x22:Completed 3400000 out of 5000000 steps (68%)
13:34:27:WU00:FS02:0x22:Completed 3450000 out of 5000000 steps (69%)
13:35:47:WU00:FS02:0x22:Completed 3500000 out of 5000000 steps (70%)
13:35:47:WU00:FS02:0x22:Checkpoint completed at step 3500000
13:36:21:WU02:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
13:37:06:WU00:FS02:0x22:Completed 3550000 out of 5000000 steps (71%)
13:38:26:WU00:FS02:0x22:Completed 3600000 out of 5000000 steps (72%)
13:39:46:WU00:FS02:0x22:Completed 3650000 out of 5000000 steps (73%)
13:41:06:WU00:FS02:0x22:Completed 3700000 out of 5000000 steps (74%)
13:41:55:WU02:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
13:42:25:WU00:FS02:0x22:Completed 3750000 out of 5000000 steps (75%)
13:42:25:WU00:FS02:0x22:Checkpoint completed at step 3750000
13:43:45:WU00:FS02:0x22:Completed 3800000 out of 5000000 steps (76%)
13:45:05:WU00:FS02:0x22:Completed 3850000 out of 5000000 steps (77%)
13:46:25:WU00:FS02:0x22:Completed 3900000 out of 5000000 steps (78%)
13:47:30:WU02:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
13:47:45:WU00:FS02:0x22:Completed 3950000 out of 5000000 steps (79%)
13:49:05:WU00:FS02:0x22:Completed 4000000 out of 5000000 steps (80%)
13:49:05:WU00:FS02:0x22:Checkpoint completed at step 4000000
13:50:25:WU00:FS02:0x22:Completed 4050000 out of 5000000 steps (81%)
13:51:45:WU00:FS02:0x22:Completed 4100000 out of 5000000 steps (82%)
13:53:04:WU00:FS02:0x22:Completed 4150000 out of 5000000 steps (83%)
13:53:08:WU02:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
13:54:24:WU00:FS02:0x22:Completed 4200000 out of 5000000 steps (84%)
13:55:44:WU00:FS02:0x22:Completed 4250000 out of 5000000 steps (85%)
13:55:44:WU00:FS02:0x22:Checkpoint completed at step 4250000
13:57:04:WU00:FS02:0x22:Completed 4300000 out of 5000000 steps (86%)
13:58:24:WU00:FS02:0x22:Completed 4350000 out of 5000000 steps (87%)
13:58:45:WU02:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
13:59:44:WU00:FS02:0x22:Completed 4400000 out of 5000000 steps (88%)
14:01:04:WU00:FS02:0x22:Completed 4450000 out of 5000000 steps (89%)
14:02:24:WU00:FS02:0x22:Completed 4500000 out of 5000000 steps (90%)
14:02:24:WU00:FS02:0x22:Checkpoint completed at step 4500000
14:03:44:WU00:FS02:0x22:Completed 4550000 out of 5000000 steps (91%)
14:04:28:WU02:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
14:05:04:WU00:FS02:0x22:Completed 4600000 out of 5000000 steps (92%)
14:06:24:WU00:FS02:0x22:Completed 4650000 out of 5000000 steps (93%)
14:07:44:WU00:FS02:0x22:Completed 4700000 out of 5000000 steps (94%)
14:09:04:WU00:FS02:0x22:Completed 4750000 out of 5000000 steps (95%)
14:09:04:WU00:FS02:0x22:Checkpoint completed at step 4750000
14:10:05:WU02:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
14:10:24:WU00:FS02:0x22:Completed 4800000 out of 5000000 steps (96%)
14:11:43:WU00:FS02:0x22:Completed 4850000 out of 5000000 steps (97%)
14:13:04:WU00:FS02:0x22:Completed 4900000 out of 5000000 steps (98%)
14:14:23:WU00:FS02:0x22:Completed 4950000 out of 5000000 steps (99%)
14:14:24:WU01:FS02:Connecting to assign1.foldingathome.org:80
14:14:25:WU01:FS02:Assigned to work server 140.163.4.200
14:14:25:WU01:FS02:Requesting new work unit for slot 02: gpu:1:0 TU117M [GeForce GTX 1650 Mobile / Max-Q] from 140.163.4.200
14:14:25:WU01:FS02:Connecting to 140.163.4.200:8080
14:14:25:WU01:FS02:Downloading 20.26MiB
14:14:31:WU01:FS02:Download 59.55%
14:14:34:WU01:FS02:Download complete
14:14:34:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17334 run:0 clone:757 gen:20 core:0x22 unit:0x000002f500000014000043b600000000
14:15:44:WU00:FS02:0x22:Completed 5000000 out of 5000000 steps (100%)
14:15:44:WU00:FS02:0x22:Average performance: 21.6541 ns/day
14:15:44:WU00:FS02:0x22:Checkpoint completed at step 5000000
14:15:45:WU02:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
14:15:45:WU00:FS02:0x22:Saving result file ..\logfile_01.txt
14:15:45:WU00:FS02:0x22:Saving result file checkpointIntegrator.xml.bz2
14:15:45:WU00:FS02:0x22:Saving result file checkpointState.xml.bz2
14:15:45:WU00:FS02:0x22:Saving result file positions.xtc
14:15:45:WU00:FS02:0x22:Saving result file science.log
14:15:45:WU00:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
14:15:46:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:15:46:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:17800 run:55 clone:7 gen:149 core:0x22 unit:0x00000007000000950000458800000037
14:15:46:WU00:FS02:Uploading 3.30MiB to 140.163.4.210
14:15:46:WU00:FS02:Connecting to 140.163.4.210:8080
14:15:46:WU01:FS02:Starting
14:15:46:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:15:46:WU01:FS02:Started FahCore on PID 9532
14:15:46:WU01:FS02:Core PID:12404
14:15:46:WU01:FS02:FahCore 0x22 started
14:15:46:WU01:FS02:0x22:*********************** Log Started 2021-02-23T14:15:46Z ***********************
14:15:46:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
14:15:46:WU01:FS02:0x22: Core: Core22
14:15:46:WU01:FS02:0x22: Type: 0x22
14:15:46:WU01:FS02:0x22: Version: 0.0.13
14:15:46:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:15:46:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
14:15:46:WU01:FS02:0x22: Homepage: https://foldingathome.org/
14:15:46:WU01:FS02:0x22: Date: Sep 19 2020
14:15:46:WU01:FS02:0x22: Time: 02:35:58
14:15:46:WU01:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
14:15:46:WU01:FS02:0x22: Branch: core22-0.0.13
14:15:46:WU01:FS02:0x22: Compiler: Visual C++ 2015
14:15:46:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:15:46:WU01:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
14:15:46:WU01:FS02:0x22: Platform: win32 10
14:15:46:WU01:FS02:0x22: Bits: 64
14:15:46:WU01:FS02:0x22: Mode: Release
14:15:46:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:15:46:WU01:FS02:0x22: <peastman@stanford.edu>
14:15:46:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 9532 -checkpoint 15
14:15:46:WU01:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
14:15:46:WU01:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
14:15:46:WU01:FS02:0x22:************************************ libFAH ************************************
14:15:46:WU01:FS02:0x22: Date: Sep 7 2020
14:15:46:WU01:FS02:0x22: Time: 19:09:56
14:15:46:WU01:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
14:15:46:WU01:FS02:0x22: Branch: HEAD
14:15:46:WU01:FS02:0x22:************************************ CBang *************************************
14:15:46:WU01:FS02:0x22: Time: 19:08:30
14:15:46:WU01:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
14:15:46:WU01:FS02:0x22:************************************ System ************************************
14:15:46:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
14:15:46:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
14:15:46:WU01:FS02:0x22: CPUs: 8
14:15:46:WU01:FS02:0x22: Memory: 7.86GiB
14:15:46:WU01:FS02:0x22:Free Memory: 3.49GiB
14:15:46:WU01:FS02:0x22: Threads: WINDOWS_THREADS
14:15:46:WU01:FS02:0x22: OS Version: 6.2
14:15:46:WU01:FS02:0x22:Has Battery: true
14:15:46:WU01:FS02:0x22: On Battery: false
14:15:46:WU01:FS02:0x22: UTC Offset: -6
14:15:46:WU01:FS02:0x22: PID: 12404
14:15:46:WU01:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
14:15:46:WU01:FS02:0x22:************************************ OpenMM ************************************
14:15:46:WU01:FS02:0x22: Revision: 189320d0
14:15:46:WU01:FS02:0x22:********************************************************************************
14:15:46:WU01:FS02:0x22:Project: 17334 (Run 0, Clone 757, Gen 20)
14:15:46:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
14:15:46:WU01:FS02:0x22:Reading tar file core.xml
14:15:46:WU01:FS02:0x22:Reading tar file integrator.xml.bz2
14:15:46:WU01:FS02:0x22:Reading tar file state.xml.bz2
14:15:46:WU01:FS02:0x22:Reading tar file system.xml.bz2
14:15:46:WU01:FS02:0x22:Digital signatures verified
14:15:46:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
14:15:46:WU01:FS02:0x22:Version 0.0.13
14:15:46:WU01:FS02:0x22: Checkpoint write interval: 15000 steps (2%) [50 total]
14:15:46:WU01:FS02:0x22: JSON viewer frame write interval: 7500 steps (1%) [100 total]
14:15:46:WU01:FS02:0x22: XTC frame write interval: 250000 steps (33%) [3 total]
14:15:46:WU01:FS02:0x22: Global context and integrator variables write interval: disabled
14:15:46:WU01:FS02:0x22:There are 4 platforms available.
14:15:46:WU01:FS02:0x22:Platform 0: Reference
14:15:46:WU01:FS02:0x22:Platform 1: CPU
14:15:46:WU01:FS02:0x22:Platform 2: OpenCL
14:15:46:WU01:FS02:0x22: opencl-device 0 specified
14:15:46:WU01:FS02:0x22:Platform 3: CUDA
14:15:46:WU01:FS02:0x22: cuda-device 0 specified
14:15:52:WU00:FS02:Upload 60.67%
14:15:56:WU00:FS02:Upload complete
14:15:56:WU00:FS02:Server responded WORK_ACK (400)
14:15:56:WU00:FS02:Final credit estimate, 51277.00 points
14:15:56:WU00:FS02:Cleaning up
14:16:09:WU01:FS02:0x22:Attempting to create CUDA context:
14:16:09:WU01:FS02:0x22: Configuring platform CUDA
14:16:24:WU01:FS02:0x22: Using CUDA and gpu 0
14:16:24:WU01:FS02:0x22:Completed 0 out of 750000 steps (0%)
14:16:26:WU01:FS02:0x22:Checkpoint completed at step 0
14:19:49:WU01:FS02:0x22:Completed 7500 out of 750000 steps (1%)
14:21:24:WU02:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
14:23:12:WU01:FS02:0x22:Completed 15000 out of 750000 steps (2%)
14:23:15:WU01:FS02:0x22:Checkpoint completed at step 15000
14:26:38:WU01:FS02:0x22:Completed 22500 out of 750000 steps (3%)
14:27:02:WU02:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
14:30:02:WU01:FS02:0x22:Completed 30000 out of 750000 steps (4%)
14:30:04:WU01:FS02:0x22:Checkpoint completed at step 30000
14:32:28:WU02:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
14:33:28:WU01:FS02:0x22:Completed 37500 out of 750000 steps (5%)
14:36:51:WU01:FS02:0x22:Completed 45000 out of 750000 steps (6%)
14:36:53:WU01:FS02:0x22:Checkpoint completed at step 45000
14:37:52:WU02:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
14:40:16:WU01:FS02:0x22:Completed 52500 out of 750000 steps (7%)
14:43:23:WU02:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
14:43:40:WU01:FS02:0x22:Completed 60000 out of 750000 steps (8%)
14:43:43:WU01:FS02:0x22:Checkpoint completed at step 60000
14:47:06:WU01:FS02:0x22:Completed 67500 out of 750000 steps (9%)
14:49:03:WU02:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
14:50:30:WU01:FS02:0x22:Completed 75000 out of 750000 steps (10%)
14:50:33:WU01:FS02:0x22:Checkpoint completed at step 75000
14:53:56:WU01:FS02:0x22:Completed 82500 out of 750000 steps (11%)
14:54:44:WU02:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
14:57:20:WU01:FS02:0x22:Completed 90000 out of 750000 steps (12%)
14:57:23:WU01:FS02:0x22:Checkpoint completed at step 90000
15:00:23:WU02:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
15:00:46:WU01:FS02:0x22:Completed 97500 out of 750000 steps (13%)
15:04:10:WU01:FS02:0x22:Completed 105000 out of 750000 steps (14%)
15:04:13:WU01:FS02:0x22:Checkpoint completed at step 105000
15:06:02:WU02:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
15:07:36:WU01:FS02:0x22:Completed 112500 out of 750000 steps (15%)
15:11:00:WU01:FS02:0x22:Completed 120000 out of 750000 steps (16%)
15:11:03:WU01:FS02:0x22:Checkpoint completed at step 120000
15:11:38:WU02:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
15:14:26:WU01:FS02:0x22:Completed 127500 out of 750000 steps (17%)
15:14:45:79:127.0.0.1:New Web session
15:17:13:WU02:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
15:17:50:WU01:FS02:0x22:Completed 135000 out of 750000 steps (18%)
15:17:53:WU01:FS02:0x22:Checkpoint completed at step 135000
15:21:17:WU01:FS02:0x22:Completed 142500 out of 750000 steps (19%)
15:22:54:WU02:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
15:24:41:WU01:FS02:0x22:Completed 150000 out of 750000 steps (20%)
15:24:44:WU01:FS02:0x22:Checkpoint completed at step 150000
15:28:07:WU01:FS02:0x22:Completed 157500 out of 750000 steps (21%)
15:28:29:WU02:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
15:31:30:WU01:FS02:0x22:Completed 165000 out of 750000 steps (22%)
15:31:33:WU01:FS02:0x22:Checkpoint completed at step 165000
15:34:05:WU02:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
15:34:56:WU01:FS02:0x22:Completed 172500 out of 750000 steps (23%)
15:38:20:WU01:FS02:0x22:Completed 180000 out of 750000 steps (24%)
15:38:23:WU01:FS02:0x22:Checkpoint completed at step 180000
15:39:40:WU02:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
15:41:46:WU01:FS02:0x22:Completed 187500 out of 750000 steps (25%)
15:45:10:WU01:FS02:0x22:Completed 195000 out of 750000 steps (26%)
15:45:13:WU01:FS02:0x22:Checkpoint completed at step 195000
15:45:16:WU02:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
15:48:36:WU01:FS02:0x22:Completed 202500 out of 750000 steps (27%)
15:50:48:WU02:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
15:51:59:WU01:FS02:0x22:Completed 210000 out of 750000 steps (28%)
15:52:02:WU01:FS02:0x22:Checkpoint completed at step 210000
15:55:25:WU01:FS02:0x22:Completed 217500 out of 750000 steps (29%)
15:56:22:WU02:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
15:58:48:WU01:FS02:0x22:Completed 225000 out of 750000 steps (30%)
15:58:51:WU01:FS02:0x22:Checkpoint completed at step 225000
Re: My gpu went to 2 seconds left 99% and then started a new
16:01:56:WU02:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
16:02:15:WU01:FS02:0x22:Completed 232500 out of 750000 steps (31%)
16:05:39:WU01:FS02:0x22:Completed 240000 out of 750000 steps (32%)
16:05:42:WU01:FS02:0x22:Checkpoint completed at step 240000
16:07:33:WU02:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
16:09:05:WU01:FS02:0x22:Completed 247500 out of 750000 steps (33%)
16:12:29:WU01:FS02:0x22:Completed 255000 out of 750000 steps (34%)
16:12:32:WU01:FS02:0x22:Checkpoint completed at step 255000
16:13:09:WU02:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
16:15:55:WU01:FS02:0x22:Completed 262500 out of 750000 steps (35%)
16:18:44:WU02:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
16:19:18:WU01:FS02:0x22:Completed 270000 out of 750000 steps (36%)
16:19:21:WU01:FS02:0x22:Checkpoint completed at step 270000
16:22:45:WU01:FS02:0x22:Completed 277500 out of 750000 steps (37%)
16:24:19:WU02:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
16:26:08:WU01:FS02:0x22:Completed 285000 out of 750000 steps (38%)
16:26:11:WU01:FS02:0x22:Checkpoint completed at step 285000
16:29:34:WU01:FS02:0x22:Completed 292500 out of 750000 steps (39%)
16:29:49:WU02:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
16:32:57:WU01:FS02:0x22:Completed 300000 out of 750000 steps (40%)
16:33:00:WU01:FS02:0x22:Checkpoint completed at step 300000
16:35:21:WU02:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
16:36:23:WU01:FS02:0x22:Completed 307500 out of 750000 steps (41%)
16:39:46:WU01:FS02:0x22:Completed 315000 out of 750000 steps (42%)
16:39:49:WU01:FS02:0x22:Checkpoint completed at step 315000
16:40:48:WU02:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
16:43:13:WU01:FS02:0x22:Completed 322500 out of 750000 steps (43%)
16:46:19:WU02:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
16:46:36:WU01:FS02:0x22:Completed 330000 out of 750000 steps (44%)
16:46:39:WU01:FS02:0x22:Checkpoint completed at step 330000
16:50:02:WU01:FS02:0x22:Completed 337500 out of 750000 steps (45%)
16:51:49:WU02:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
16:53:25:WU01:FS02:0x22:Completed 345000 out of 750000 steps (46%)
16:53:28:WU01:FS02:0x22:Checkpoint completed at step 345000
16:56:51:WU01:FS02:0x22:Completed 352500 out of 750000 steps (47%)
16:57:16:WU02:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
17:00:15:WU01:FS02:0x22:Completed 360000 out of 750000 steps (48%)
17:00:18:WU01:FS02:0x22:Checkpoint completed at step 360000
17:02:42:WU02:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
17:03:41:WU01:FS02:0x22:Completed 367500 out of 750000 steps (49%)
17:07:05:WU01:FS02:0x22:Completed 375000 out of 750000 steps (50%)
17:07:08:WU01:FS02:0x22:Checkpoint completed at step 375000
17:08:13:WU02:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
17:10:31:WU01:FS02:0x22:Completed 382500 out of 750000 steps (51%)
17:13:45:WU02:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
17:13:54:WU01:FS02:0x22:Completed 390000 out of 750000 steps (52%)
17:13:57:WU01:FS02:0x22:Checkpoint completed at step 390000
17:17:20:WU01:FS02:0x22:Completed 397500 out of 750000 steps (53%)
17:19:17:WU02:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
17:20:43:WU01:FS02:0x22:Completed 405000 out of 750000 steps (54%)
17:20:46:WU01:FS02:0x22:Checkpoint completed at step 405000
17:24:09:WU01:FS02:0x22:Completed 412500 out of 750000 steps (55%)
17:24:44:WU02:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
17:27:32:WU01:FS02:0x22:Completed 420000 out of 750000 steps (56%)
17:27:35:WU01:FS02:0x22:Checkpoint completed at step 420000
17:30:13:WU02:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
17:30:59:WU01:FS02:0x22:Completed 427500 out of 750000 steps (57%)
17:34:22:WU01:FS02:0x22:Completed 435000 out of 750000 steps (58%)
17:34:25:WU01:FS02:0x22:Checkpoint completed at step 435000
17:35:39:WU02:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
17:37:48:WU01:FS02:0x22:Completed 442500 out of 750000 steps (59%)
17:41:04:WU02:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
17:41:11:WU01:FS02:0x22:Completed 450000 out of 750000 steps (60%)
17:41:14:WU01:FS02:0x22:Checkpoint completed at step 450000
17:44:38:WU01:FS02:0x22:Completed 457500 out of 750000 steps (61%)
17:46:29:WU02:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
17:48:01:WU01:FS02:0x22:Completed 465000 out of 750000 steps (62%)
17:48:04:WU01:FS02:0x22:Checkpoint completed at step 465000
17:51:27:WU01:FS02:0x22:Completed 472500 out of 750000 steps (63%)
17:51:58:WU02:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
17:54:50:WU01:FS02:0x22:Completed 480000 out of 750000 steps (64%)
17:54:53:WU01:FS02:0x22:Checkpoint completed at step 480000
17:57:21:WU02:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
17:58:16:WU01:FS02:0x22:Completed 487500 out of 750000 steps (65%)
18:01:39:WU01:FS02:0x22:Completed 495000 out of 750000 steps (66%)
18:01:41:WU01:FS02:0x22:Checkpoint completed at step 495000
18:02:42:WU02:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
18:02:59:92:127.0.0.1:New Web session
18:05:05:WU01:FS02:0x22:Completed 502500 out of 750000 steps (67%)
18:08:18:WU02:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
18:08:28:WU01:FS02:0x22:Completed 510000 out of 750000 steps (68%)
18:08:31:WU01:FS02:0x22:Checkpoint completed at step 510000
18:11:55:WU01:FS02:0x22:Completed 517500 out of 750000 steps (69%)
18:13:47:WU02:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
18:15:18:WU01:FS02:0x22:Completed 525000 out of 750000 steps (70%)
18:15:21:WU01:FS02:0x22:Checkpoint completed at step 525000
18:18:44:WU01:FS02:0x22:Completed 532500 out of 750000 steps (71%)
18:19:15:WU02:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
18:22:07:WU01:FS02:0x22:Completed 540000 out of 750000 steps (72%)
18:22:10:WU01:FS02:0x22:Checkpoint completed at step 540000
18:24:44:WU02:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
18:25:34:WU01:FS02:0x22:Completed 547500 out of 750000 steps (73%)
18:28:57:WU01:FS02:0x22:Completed 555000 out of 750000 steps (74%)
18:29:00:WU01:FS02:0x22:Checkpoint completed at step 555000
18:30:15:WU02:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
18:32:23:WU01:FS02:0x22:Completed 562500 out of 750000 steps (75%)
18:35:47:WU01:FS02:0x22:Completed 570000 out of 750000 steps (76%)
18:35:49:WU02:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
18:35:50:WU01:FS02:0x22:Checkpoint completed at step 570000
18:39:13:WU01:FS02:0x22:Completed 577500 out of 750000 steps (77%)
18:41:20:WU02:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
18:42:36:WU01:FS02:0x22:Completed 585000 out of 750000 steps (78%)
18:42:39:WU01:FS02:0x22:Checkpoint completed at step 585000
18:46:03:WU01:FS02:0x22:Completed 592500 out of 750000 steps (79%)
18:46:49:WU02:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
18:49:25:WU01:FS02:0x22:Completed 600000 out of 750000 steps (80%)
18:49:28:WU01:FS02:0x22:Checkpoint completed at step 600000
18:52:21:WU02:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
18:52:51:WU01:FS02:0x22:Completed 607500 out of 750000 steps (81%)
18:56:15:WU01:FS02:0x22:Completed 615000 out of 750000 steps (82%)
18:56:17:WU01:FS02:0x22:Checkpoint completed at step 615000
18:57:49:WU02:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
18:59:41:WU01:FS02:0x22:Completed 622500 out of 750000 steps (83%)
19:03:03:WU01:FS02:0x22:Completed 630000 out of 750000 steps (84%)
19:03:06:WU01:FS02:0x22:Checkpoint completed at step 630000
19:03:16:WU02:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
19:06:29:WU01:FS02:0x22:Completed 637500 out of 750000 steps (85%)
19:08:43:WU02:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
19:09:52:WU01:FS02:0x22:Completed 645000 out of 750000 steps (86%)
19:09:55:WU01:FS02:0x22:Checkpoint completed at step 645000
19:13:18:WU01:FS02:0x22:Completed 652500 out of 750000 steps (87%)
19:14:11:WU02:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
19:16:41:WU01:FS02:0x22:Completed 660000 out of 750000 steps (88%)
19:16:44:WU01:FS02:0x22:Checkpoint completed at step 660000
19:19:39:WU02:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
19:20:07:WU01:FS02:0x22:Completed 667500 out of 750000 steps (89%)
19:23:30:WU01:FS02:0x22:Completed 675000 out of 750000 steps (90%)
19:23:33:WU01:FS02:0x22:Checkpoint completed at step 675000
19:25:07:WU02:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
19:26:56:WU01:FS02:0x22:Completed 682500 out of 750000 steps (91%)
19:30:19:WU01:FS02:0x22:Completed 690000 out of 750000 steps (92%)
19:30:22:WU01:FS02:0x22:Checkpoint completed at step 690000
19:30:32:WU02:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
19:33:45:WU01:FS02:0x22:Completed 697500 out of 750000 steps (93%)
19:35:58:WU02:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
19:37:07:WU01:FS02:0x22:Completed 705000 out of 750000 steps (94%)
19:37:10:WU01:FS02:0x22:Checkpoint completed at step 705000
19:40:33:WU01:FS02:0x22:Completed 712500 out of 750000 steps (95%)
19:41:28:WU02:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
19:43:05:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
19:43:56:WU01:FS02:0x22:Completed 720000 out of 750000 steps (96%)
19:43:59:WU01:FS02:0x22:Checkpoint completed at step 720000
19:46:56:WU02:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
19:47:22:WU01:FS02:0x22:Completed 727500 out of 750000 steps (97%)
19:50:45:WU01:FS02:0x22:Completed 735000 out of 750000 steps (98%)
19:50:48:WU01:FS02:0x22:Checkpoint completed at step 735000
19:52:24:WU02:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
19:54:11:WU01:FS02:0x22:Completed 742500 out of 750000 steps (99%)
19:54:12:WU00:FS02:Connecting to assign1.foldingathome.org:80
19:54:13:WU00:FS02:Assigned to work server 140.163.4.210
19:54:13:WU00:FS02:Requesting new work unit for slot 02: gpu:1:0 TU117M [GeForce GTX 1650 Mobile / Max-Q] from 140.163.4.210
19:54:13:WU00:FS02:Connecting to 140.163.4.210:8080
19:54:13:WU00:FS02:Downloading 1.89MiB
19:54:14:WU00:FS02:Download complete
19:54:15:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17800 run:68 clone:11 gen:126 core:0x22 unit:0x0000000b0000007e0000458800000044
19:57:34:WU01:FS02:0x22:Completed 750000 out of 750000 steps (100%)
19:57:34:WU01:FS02:0x22:Average performance: 212.808 ns/day
19:57:37:WU01:FS02:0x22:Checkpoint completed at step 750000
19:57:55:WU02:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
19:57:55:WU03:FS00:Connecting to assign1.foldingathome.org:80
19:57:55:WU03:FS00:Assigned to work server 129.32.209.203
19:57:55:WU03:FS00:Requesting new work unit for slot 00: cpu:5 from 129.32.209.203
19:57:55:WU03:FS00:Connecting to 129.32.209.203:8080
19:57:55:WU03:FS00:Downloading 752.50KiB
19:57:56:WU03:FS00:Download complete
19:57:56:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:16944 run:79 clone:3 gen:62 core:0xa8 unit:0x000000030000003e000042300000004f
19:57:56:WU03:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
19:57:56:WU03:FS00:Connecting to cores.foldingathome.org:80
19:57:57:WU03:FS00:FahCore a8: Downloading 7.72MiB
19:58:02:WU03:FS00:FahCore a8: Download complete
19:58:02:WU03:FS00:Valid core signature
19:58:02:WU03:FS00:Unpacked 20.93MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
19:58:02:WU03:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
19:58:02:WU03:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
19:58:06:WU01:FS02:0x22:Saving result file ..\logfile_01.txt
19:58:06:WU01:FS02:0x22:Saving result file checkpointIntegrator.xml.bz2
19:58:06:WU01:FS02:0x22:Saving result file checkpointState.xml.bz2
19:58:06:WU01:FS02:0x22:Saving result file positions.xtc
19:58:06:WU01:FS02:0x22:Saving result file science.log
19:58:06:WU01:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
19:58:07:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:58:07:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:17334 run:0 clone:757 gen:20 core:0x22 unit:0x000002f500000014000043b600000000
19:58:07:WU01:FS02:Uploading 24.07MiB to 140.163.4.200
19:58:07:WU01:FS02:Connecting to 140.163.4.200:8080
19:58:07:WU00:FS02:Starting
19:58:07:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
19:58:07:WU00:FS02:Started FahCore on PID 4292
19:58:07:WU00:FS02:Core PID:17008
19:58:07:WU00:FS02:FahCore 0x22 started
19:58:08:WU00:FS02:0x22:*********************** Log Started 2021-02-23T19:58:07Z ***********************
19:58:08:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
19:58:08:WU00:FS02:0x22: Core: Core22
19:58:08:WU00:FS02:0x22: Type: 0x22
19:58:08:WU00:FS02:0x22: Version: 0.0.13
19:58:08:WU00:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:58:08:WU00:FS02:0x22: Copyright: 2020 foldingathome.org
19:58:08:WU00:FS02:0x22: Homepage: https://foldingathome.org/
19:58:08:WU00:FS02:0x22: Date: Sep 19 2020
19:58:08:WU00:FS02:0x22: Time: 02:35:58
19:58:08:WU00:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:58:08:WU00:FS02:0x22: Branch: core22-0.0.13
19:58:08:WU00:FS02:0x22: Compiler: Visual C++ 2015
19:58:08:WU00:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:58:08:WU00:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
19:58:08:WU00:FS02:0x22: Platform: win32 10
19:58:08:WU00:FS02:0x22: Bits: 64
19:58:08:WU00:FS02:0x22: Mode: Release
19:58:08:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:58:08:WU00:FS02:0x22: <peastman@stanford.edu>
19:58:08:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 4292 -checkpoint 15
19:58:08:WU00:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
19:58:08:WU00:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
19:58:08:WU00:FS02:0x22:************************************ libFAH ************************************
19:58:08:WU00:FS02:0x22: Date: Sep 7 2020
19:58:08:WU00:FS02:0x22: Time: 19:09:56
19:58:08:WU00:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:58:08:WU00:FS02:0x22: Branch: HEAD
19:58:08:WU00:FS02:0x22:************************************ CBang *************************************
19:58:08:WU00:FS02:0x22: Time: 19:08:30
19:58:08:WU00:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:58:08:WU00:FS02:0x22:************************************ System ************************************
19:58:08:WU00:FS02:0x22: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
19:58:08:WU00:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
19:58:08:WU00:FS02:0x22: CPUs: 8
19:58:08:WU00:FS02:0x22: Memory: 7.86GiB
19:58:08:WU00:FS02:0x22:Free Memory: 3.77GiB
19:58:08:WU00:FS02:0x22: Threads: WINDOWS_THREADS
19:58:08:WU00:FS02:0x22: OS Version: 6.2
19:58:08:WU00:FS02:0x22:Has Battery: true
19:58:08:WU00:FS02:0x22: On Battery: false
19:58:08:WU00:FS02:0x22: UTC Offset: -6
19:58:08:WU00:FS02:0x22: PID: 17008
19:58:08:WU00:FS02:0x22:************************************ OpenMM ************************************
19:58:08:WU00:FS02:0x22: Revision: 189320d0
19:58:08:WU00:FS02:0x22:********************************************************************************
19:58:08:WU00:FS02:0x22:Project: 17800 (Run 68, Clone 11, Gen 126)
19:58:08:WU00:FS02:0x22:Unit: 0x00000000000000000000000000000000
19:58:08:WU00:FS02:0x22:Reading tar file core.xml
19:58:08:WU00:FS02:0x22:Reading tar file integrator.xml.bz2
19:58:08:WU00:FS02:0x22:Reading tar file state.xml.bz2
19:58:08:WU00:FS02:0x22:Reading tar file system.xml.bz2
19:58:08:WU00:FS02:0x22:Digital signatures verified
19:58:08:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
19:58:08:WU00:FS02:0x22:Version 0.0.13
19:58:09:WU00:FS02:0x22: Checkpoint write interval: 250000 steps (5%) [20 total]
19:58:09:WU00:FS02:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
19:58:09:WU00:FS02:0x22: XTC frame write interval: 25000 steps (0.5%) [200 total]
19:58:09:WU00:FS02:0x22: Global context and integrator variables write interval: disabled
19:58:09:WU00:FS02:0x22:There are 4 platforms available.
19:58:09:WU00:FS02:0x22:Platform 0: Reference
19:58:09:WU00:FS02:0x22:Platform 1: CPU
19:58:09:WU00:FS02:0x22:Platform 2: OpenCL
19:58:09:WU00:FS02:0x22: opencl-device 0 specified
19:58:09:WU00:FS02:0x22:Platform 3: CUDA
19:58:09:WU00:FS02:0x22: cuda-device 0 specified
19:58:11:WU00:FS02:0x22:Attempting to create CUDA context:
19:58:11:WU00:FS02:0x22: Configuring platform CUDA
19:58:13:WU01:FS02:Upload 9.61%
19:58:13:WU00:FS02:0x22: Using CUDA and gpu 0
19:58:13:WU00:FS02:0x22:Completed 0 out of 5000000 steps (0%)
19:58:13:WU00:FS02:0x22:Checkpoint completed at step 0
19:58:19:WU01:FS02:Upload 21.04%
19:58:25:WU01:FS02:Upload 31.42%
19:58:31:WU01:FS02:Upload 42.85%
19:58:37:WU01:FS02:Upload 53.76%
19:58:43:WU01:FS02:Upload 64.66%
19:58:49:WU01:FS02:Upload 76.87%
19:58:55:WU01:FS02:Upload 87.52%
19:58:58:118:127.0.0.1:New Web session
19:59:01:WU01:FS02:Upload 98.94%
19:59:01:WU01:FS02:Upload complete
19:59:01:WU01:FS02:Server responded WORK_ACK (400)
19:59:01:WU01:FS02:Final credit estimate, 106382.00 points
19:59:01:WU01:FS02:Cleaning up
19:59:33:WU00:FS02:0x22:Completed 50000 out of 5000000 steps (1%)
20:00:53:WU00:FS02:0x22:Completed 100000 out of 5000000 steps (2%)
20:02:13:WU00:FS02:0x22:Completed 150000 out of 5000000 steps (3%)
20:03:34:WU00:FS02:0x22:Completed 200000 out of 5000000 steps (4%)
20:03:39:WU02:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
20:03:42:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
20:03:42:WU02:FS00:0xa7:Saving result file frame139.trr
20:03:42:WU02:FS00:0xa7:Saving result file md.log
20:03:42:WU02:FS00:0xa7:Saving result file science.log
20:03:42:WU02:FS00:0xa7:Saving result file traj_comp.xtc
20:03:42:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:03:42:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:03:42:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16927 run:30 clone:17 gen:139 core:0xa7 unit:0x000000110000008b0000421f0000001e
20:03:42:WU02:FS00:Uploading 6.30MiB to 129.32.209.201
20:03:42:WU02:FS00:Connecting to 129.32.209.201:8080
20:03:43:WU03:FS00:Starting
20:03:43:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 03 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 5
20:03:43:WU03:FS00:Started FahCore on PID 11548
20:03:43:WU03:FS00:Core PID:8792
20:03:43:WU03:FS00:FahCore 0xa8 started
20:03:43:WU03:FS00:0xa8:*********************** Log Started 2021-02-23T20:03:43Z ***********************
20:03:43:WU03:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
20:03:43:WU03:FS00:0xa8: Core: Gromacs
20:03:43:WU03:FS00:0xa8: Type: 0xa8
20:03:43:WU03:FS00:0xa8: Version: 0.0.12
20:03:43:WU03:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:03:43:WU03:FS00:0xa8: Copyright: 2020 foldingathome.org
20:03:43:WU03:FS00:0xa8: Homepage: https://foldingathome.org/
20:03:43:WU03:FS00:0xa8: Date: Jan 16 2021
20:03:43:WU03:FS00:0xa8: Time: 12:29:40
20:03:43:WU03:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
20:03:43:WU03:FS00:0xa8: Branch: master
20:03:43:WU03:FS00:0xa8: Compiler: Visual C++ 2019 16.7
20:03:43:WU03:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:03:43:WU03:FS00:0xa8: Platform: win32 10
20:03:43:WU03:FS00:0xa8: Bits: 64
20:03:43:WU03:FS00:0xa8: Mode: Release
20:03:43:WU03:FS00:0xa8: SIMD: avx2_256
20:03:43:WU03:FS00:0xa8: OpenMP: ON
20:03:43:WU03:FS00:0xa8: CUDA: OFF
20:03:43:WU03:FS00:0xa8: Args: -dir 03 -suffix 01 -version 706 -lifeline 11548 -checkpoint 15 -np
20:03:43:WU03:FS00:0xa8: 5
20:03:43:WU03:FS00:0xa8:************************************ libFAH ************************************
20:03:43:WU03:FS00:0xa8: Time: 11:24:13
20:03:43:WU03:FS00:0xa8:************************************ CBang *************************************
20:03:43:WU03:FS00:0xa8: Time: 11:23:53
20:03:43:WU03:FS00:0xa8:************************************ System ************************************
20:03:43:WU03:FS00:0xa8: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
20:03:43:WU03:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
20:03:43:WU03:FS00:0xa8: CPUs: 8
20:03:43:WU03:FS00:0xa8: Memory: 7.86GiB
20:03:43:WU03:FS00:0xa8:Free Memory: 3.42GiB
20:03:43:WU03:FS00:0xa8: Threads: WINDOWS_THREADS
20:03:43:WU03:FS00:0xa8: OS Version: 6.2
20:03:43:WU03:FS00:0xa8:Has Battery: true
20:03:43:WU03:FS00:0xa8: On Battery: false
20:03:43:WU03:FS00:0xa8: UTC Offset: -6
20:03:43:WU03:FS00:0xa8: PID: 8792
20:03:43:WU03:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
20:03:43:WU03:FS00:0xa8:********************************************************************************
20:03:43:WU03:FS00:0xa8:Project: 16944 (Run 79, Clone 3, Gen 62)
20:03:43:WU03:FS00:0xa8:Unit: 0x00000000000000000000000000000000
20:03:43:WU03:FS00:0xa8:Reading tar file core.xml
20:03:43:WU03:FS00:0xa8:Reading tar file frame62.tpr
20:03:43:WU03:FS00:0xa8:Digital signatures verified
20:03:43:WU03:FS00:0xa8:Calling: mdrun -c frame62.gro -s frame62.tpr -x frame62.xtc -cpt 15 -nt 5 -ntmpi 1
20:03:43:WU03:FS00:0xa8:Steps: first=310000000 total=315000000
20:03:45:WU03:FS00:0xa8:Completed 1 out of 5000000 steps (0%)
20:03:48:WU02:FS00:Upload 18.85%
20:03:54:WU02:FS00:Upload 38.69%
20:04:00:WU02:FS00:Upload 69.45%
20:04:06:WU02:FS00:Upload 98.22%
20:04:07:WU02:FS00:Upload complete
20:04:07:WU02:FS00:Server responded WORK_ACK (400)
20:04:07:WU02:FS00:Final credit estimate, 8461.00 points
20:04:07:WU02:FS00:Cleaning up
20:04:55:WU00:FS02:0x22:Completed 250000 out of 5000000 steps (5%)
20:04:55:WU00:FS02:0x22:Checkpoint completed at step 250000
20:06:17:WU00:FS02:0x22:Completed 300000 out of 5000000 steps (6%)
20:07:38:WU00:FS02:0x22:Completed 350000 out of 5000000 steps (7%)
20:08:59:WU00:FS02:0x22:Completed 400000 out of 5000000 steps (8%)
20:10:21:WU00:FS02:0x22:Completed 450000 out of 5000000 steps (9%)
20:11:41:WU00:FS02:0x22:Completed 500000 out of 5000000 steps (10%)
20:11:42:WU00:FS02:0x22:Checkpoint completed at step 500000
20:13:03:WU00:FS02:0x22:Completed 550000 out of 5000000 steps (11%)
20:14:23:WU00:FS02:0x22:Completed 600000 out of 5000000 steps (12%)
20:14:58:FS00:Paused
20:14:58:FS01:Paused
20:14:58:FS02:Paused
20:14:59:FS00:Shutting core down
20:14:59:FS02:Shutting core down
20:14:59:WU03:FS00:0xa8:WARNING:Console control signal 1 on PID 8792
20:14:59:WU03:FS00:0xa8:Exiting, please wait. . .
20:14:59:WU00:FS02:0x22:WARNING:Console control signal 1 on PID 17008
20:14:59:WU00:FS02:0x22:Exiting, please wait. . .
20:14:59:WU00:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
20:14:59:WU00:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
20:14:59:WU03:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:15:13:FS00:Unpaused
20:15:13:FS01:Unpaused
20:15:13:FS02:Unpaused
20:15:14:WU00:FS02:Starting
20:15:14:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
20:15:14:WU00:FS02:Started FahCore on PID 3164
20:15:14:WU00:FS02:Core PID:11916
20:15:14:WU00:FS02:FahCore 0x22 started
20:15:14:WU03:FS00:Starting
20:15:14:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 03 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -np 5
20:15:14:WU03:FS00:Started FahCore on PID 13080
20:15:14:WU03:FS00:Core PID:8212
20:15:14:WU03:FS00:FahCore 0xa8 started
20:15:14:WU00:FS02:0x22:*********************** Log Started 2021-02-23T20:15:14Z ***********************
20:15:14:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
20:15:14:WU00:FS02:0x22: Core: Core22
20:15:14:WU00:FS02:0x22: Type: 0x22
20:15:14:WU00:FS02:0x22: Version: 0.0.13
20:15:14:WU00:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:15:14:WU00:FS02:0x22: Copyright: 2020 foldingathome.org
20:15:14:WU00:FS02:0x22: Homepage: https://foldingathome.org/
20:15:14:WU00:FS02:0x22: Date: Sep 19 2020
20:15:14:WU00:FS02:0x22: Time: 02:35:58
20:15:14:WU00:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:15:14:WU00:FS02:0x22: Branch: core22-0.0.13
20:15:14:WU00:FS02:0x22: Compiler: Visual C++ 2015
20:15:14:WU00:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:15:14:WU00:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
20:15:14:WU00:FS02:0x22: Platform: win32 10
20:15:14:WU00:FS02:0x22: Bits: 64
20:15:14:WU00:FS02:0x22: Mode: Release
20:15:14:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:15:14:WU00:FS02:0x22: <peastman@stanford.edu>
20:15:14:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 3164 -checkpoint 15
20:15:14:WU00:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
20:15:14:WU00:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
20:15:14:WU00:FS02:0x22:************************************ libFAH ************************************
20:15:14:WU00:FS02:0x22: Date: Sep 7 2020
20:15:14:WU00:FS02:0x22: Time: 19:09:56
20:15:14:WU00:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:15:14:WU00:FS02:0x22: Branch: HEAD
20:15:14:WU00:FS02:0x22:************************************ CBang *************************************
20:15:14:WU00:FS02:0x22: Time: 19:08:30
20:15:14:WU00:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:15:14:WU03:FS00:0xa8:*********************** Log Started 2021-02-23T20:15:14Z ***********************
20:15:14:WU03:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
20:15:14:WU03:FS00:0xa8: Core: Gromacs
20:15:14:WU00:FS02:0x22:************************************ System ************************************
20:15:14:WU03:FS00:0xa8: Type: 0xa8
20:15:14:WU00:FS02:0x22: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
20:15:14:WU03:FS00:0xa8: Version: 0.0.12
20:15:14:WU00:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
20:15:14:WU03:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:15:14:WU00:FS02:0x22: CPUs: 8
20:15:14:WU03:FS00:0xa8: Copyright: 2020 foldingathome.org
20:15:14:WU00:FS02:0x22: Memory: 7.86GiB
20:15:14:WU03:FS00:0xa8: Homepage: https://foldingathome.org/
20:15:14:WU00:FS02:0x22:Free Memory: 3.57GiB
20:15:14:WU03:FS00:0xa8: Date: Jan 16 2021
20:15:14:WU00:FS02:0x22: Threads: WINDOWS_THREADS
20:15:14:WU03:FS00:0xa8: Time: 12:29:40
20:15:14:WU00:FS02:0x22: OS Version: 6.2
20:15:14:WU03:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
20:15:14:WU00:FS02:0x22:Has Battery: true
20:15:14:WU03:FS00:0xa8: Branch: master
20:15:14:WU00:FS02:0x22: On Battery: false
20:15:14:WU03:FS00:0xa8: Compiler: Visual C++ 2019 16.7
20:15:14:WU00:FS02:0x22: UTC Offset: -6
20:15:14:WU03:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:15:14:WU00:FS02:0x22: PID: 11916
20:15:14:WU03:FS00:0xa8: Platform: win32 10
20:15:14:WU00:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
20:15:14:WU03:FS00:0xa8: Bits: 64
20:15:14:WU00:FS02:0x22:************************************ OpenMM ************************************
20:15:14:WU03:FS00:0xa8: Mode: Release
20:15:14:WU00:FS02:0x22: Revision: 189320d0
20:15:14:WU03:FS00:0xa8: SIMD: avx2_256
20:15:14:WU00:FS02:0x22:********************************************************************************
20:15:14:WU03:FS00:0xa8: OpenMP: ON
20:15:14:WU00:FS02:0x22:Project: 17800 (Run 68, Clone 11, Gen 126)
20:15:14:WU03:FS00:0xa8: CUDA: OFF
20:15:14:WU00:FS02:0x22:Unit: 0x00000000000000000000000000000000
20:15:14:WU03:FS00:0xa8: Args: -dir 03 -suffix 01 -version 706 -lifeline 13080 -checkpoint 15 -np
20:15:14:WU00:FS02:0x22:Digital signatures verified
20:15:14:WU03:FS00:0xa8: 5
20:15:14:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
20:15:14:WU03:FS00:0xa8:************************************ libFAH ************************************
20:15:14:WU00:FS02:0x22:Version 0.0.13
20:15:14:WU03:FS00:0xa8: Time: 11:24:13
20:15:14:WU03:FS00:0xa8:************************************ CBang *************************************
20:15:14:WU03:FS00:0xa8: Time: 11:23:53
20:15:14:WU03:FS00:0xa8:************************************ System ************************************
20:15:14:WU03:FS00:0xa8: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
20:15:14:WU03:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
20:15:14:WU03:FS00:0xa8: CPUs: 8
20:15:14:WU03:FS00:0xa8: Memory: 7.86GiB
20:15:14:WU03:FS00:0xa8:Free Memory: 3.56GiB
20:15:14:WU03:FS00:0xa8: Threads: WINDOWS_THREADS
20:15:14:WU03:FS00:0xa8: OS Version: 6.2
20:15:14:WU03:FS00:0xa8:Has Battery: true
20:15:14:WU03:FS00:0xa8: On Battery: false
20:15:14:WU03:FS00:0xa8: UTC Offset: -6
20:15:14:WU03:FS00:0xa8: PID: 8212
20:15:14:WU03:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
20:15:14:WU03:FS00:0xa8:********************************************************************************
20:15:14:WU03:FS00:0xa8:Project: 16944 (Run 79, Clone 3, Gen 62)
20:15:14:WU03:FS00:0xa8:Unit: 0x00000000000000000000000000000000
20:15:14:WU03:FS00:0xa8:Digital signatures verified
20:15:14:WU03:FS00:0xa8:Calling: mdrun -c frame62.gro -s frame62.tpr -x frame62.xtc -cpi state.cpt -cpt 15 -nt 5 -ntmpi 1
20:15:14:WU03:FS00:0xa8:Steps: first=310000000 total=315000000
20:15:15:WU00:FS02:0x22: Checkpoint write interval: 250000 steps (5%) [20 total]
20:15:15:WU00:FS02:0x22: JSON viewer frame write interval: 50000 steps (1%) [100 total]
20:15:15:WU00:FS02:0x22: XTC frame write interval: 25000 steps (0.5%) [200 total]
20:15:15:WU00:FS02:0x22: Global context and integrator variables write interval: disabled
20:15:15:WU00:FS02:0x22:There are 4 platforms available.
20:15:15:WU00:FS02:0x22:Platform 0: Reference
20:15:15:WU00:FS02:0x22:Platform 1: CPU
20:15:15:WU00:FS02:0x22:Platform 2: OpenCL
20:15:15:WU00:FS02:0x22: opencl-device 0 specified
20:15:15:WU00:FS02:0x22:Platform 3: CUDA
20:15:15:WU00:FS02:0x22: cuda-device 0 specified
20:15:16:WU03:FS00:0xa8:Completed 45946 out of 5000000 steps (0%)
20:15:17:WU00:FS02:0x22:Attempting to create CUDA context:
20:15:17:WU00:FS02:0x22: Configuring platform CUDA
20:15:18:WU00:FS02:0x22: Using CUDA and gpu 0
20:15:18:WU00:FS02:0x22:Completed 500000 out of 5000000 steps (10%)
20:16:13:WU03:FS00:0xa8:Completed 50000 out of 5000000 steps (1%)
20:16:39:WU00:FS02:0x22:Completed 550000 out of 5000000 steps (11%)
20:18:01:WU00:FS02:0x22:Completed 600000 out of 5000000 steps (12%)
20:19:22:WU00:FS02:0x22:Completed 650000 out of 5000000 steps (13%)
20:20:44:WU00:FS02:0x22:Completed 700000 out of 5000000 steps (14%)
20:21:41:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
20:21:55:131:127.0.0.1:New Web session
20:22:06:WU00:FS02:0x22:Completed 750000 out of 5000000 steps (15%)
20:22:06:WU00:FS02:0x22:Checkpoint completed at step 750000
20:23:27:WU00:FS02:0x22:Completed 800000 out of 5000000 steps (16%)
20:24:12:137:127.0.0.1:New Web session
20:24:48:WU00:FS02:0x22:Completed 850000 out of 5000000 steps (17%)
20:26:09:WU00:FS02:0x22:Completed 900000 out of 5000000 steps (18%)
20:27:30:WU00:FS02:0x22:Completed 950000 out of 5000000 steps (19%)
20:28:03:WU03:FS00:0xa8:Completed 100000 out of 5000000 steps (2%)
20:28:51:WU00:FS02:0x22:Completed 1000000 out of 5000000 steps (20%)
20:28:51:WU00:FS02:0x22:Checkpoint completed at step 1000000
20:30:12:WU00:FS02:0x22:Completed 1050000 out of 5000000 steps (21%)
20:31:33:WU00:FS02:0x22:Completed 1100000 out of 5000000 steps (22%)
20:32:54:WU00:FS02:0x22:Completed 1150000 out of 5000000 steps (23%)
20:34:14:WU00:FS02:0x22:Completed 1200000 out of 5000000 steps (24%)
20:35:35:WU00:FS02:0x22:Completed 1250000 out of 5000000 steps (25%)
20:35:35:WU00:FS02:0x22:Checkpoint completed at step 1250000
20:36:56:WU00:FS02:0x22:Completed 1300000 out of 5000000 steps (26%)
20:38:16:WU00:FS02:0x22:Completed 1350000 out of 5000000 steps (27%)
20:39:21:WU03:FS00:0xa8:Completed 150000 out of 5000000 steps (3%)
20:39:36:WU00:FS02:0x22:Completed 1400000 out of 5000000 steps (28%)
20:40:57:WU00:FS02:0x22:Completed 1450000 out of 5000000 steps (29%)
20:42:17:WU00:FS02:0x22:Completed 1500000 out of 5000000 steps (30%)
20:42:18:WU00:FS02:0x22:Checkpoint completed at step 1500000
20:43:38:WU00:FS02:0x22:Completed 1550000 out of 5000000 steps (31%)
20:44:59:WU00:FS02:0x22:Completed 1600000 out of 5000000 steps (32%)
20:46:19:WU00:FS02:0x22:Completed 1650000 out of 5000000 steps (33%)
20:47:40:WU00:FS02:0x22:Completed 1700000 out of 5000000 steps (34%)
20:49:00:WU00:FS02:0x22:Completed 1750000 out of 5000000 steps (35%)
20:49:00:WU00:FS02:0x22:Checkpoint completed at step 1750000
20:50:21:WU00:FS02:0x22:Completed 1800000 out of 5000000 steps (36%)
20:50:30:WU03:FS00:0xa8:Completed 200000 out of 5000000 steps (4%)
20:51:41:WU00:FS02:0x22:Completed 1850000 out of 5000000 steps (37%)
20:53:01:WU00:FS02:0x22:Completed 1900000 out of 5000000 steps (38%)
20:54:22:WU00:FS02:0x22:Completed 1950000 out of 5000000 steps (39%)
20:55:43:WU00:FS02:0x22:Completed 2000000 out of 5000000 steps (40%)
20:55:43:WU00:FS02:0x22:Checkpoint completed at step 2000000
20:57:03:WU00:FS02:0x22:Completed 2050000 out of 5000000 steps (41%)
20:58:24:WU00:FS02:0x22:Completed 2100000 out of 5000000 steps (42%)
20:59:44:WU00:FS02:0x22:Completed 2150000 out of 5000000 steps (43%)
21:01:05:WU00:FS02:0x22:Completed 2200000 out of 5000000 steps (44%)
21:01:42:WU03:FS00:0xa8:Completed 250000 out of 5000000 steps (5%)
21:02:26:WU00:FS02:0x22:Completed 2250000 out of 5000000 steps (45%)
21:02:26:WU00:FS02:0x22:Checkpoint completed at step 2250000
21:03:47:WU00:FS02:0x22:Completed 2300000 out of 5000000 steps (46%)
21:05:08:WU00:FS02:0x22:Completed 2350000 out of 5000000 steps (47%)
21:06:28:WU00:FS02:0x22:Completed 2400000 out of 5000000 steps (48%)
21:07:49:WU00:FS02:0x22:Completed 2450000 out of 5000000 steps (49%)
21:09:09:WU00:FS02:0x22:Completed 2500000 out of 5000000 steps (50%)
21:09:09:WU00:FS02:0x22:Checkpoint completed at step 2500000
21:10:30:WU00:FS02:0x22:Completed 2550000 out of 5000000 steps (51%)
21:11:50:WU00:FS02:0x22:Completed 2600000 out of 5000000 steps (52%)
21:12:50:WU03:FS00:0xa8:Completed 300000 out of 5000000 steps (6%)
21:13:11:WU00:FS02:0x22:Completed 2650000 out of 5000000 steps (53%)
21:14:31:WU00:FS02:0x22:Completed 2700000 out of 5000000 steps (54%)
21:15:52:WU00:FS02:0x22:Completed 2750000 out of 5000000 steps (55%)
21:15:52:WU00:FS02:0x22:Checkpoint completed at step 2750000
21:17:13:WU00:FS02:0x22:Completed 2800000 out of 5000000 steps (56%)
21:18:33:WU00:FS02:0x22:Completed 2850000 out of 5000000 steps (57%)
21:19:53:WU00:FS02:0x22:Completed 2900000 out of 5000000 steps (58%)
21:21:14:WU00:FS02:0x22:Completed 2950000 out of 5000000 steps (59%)
21:22:34:WU00:FS02:0x22:Completed 3000000 out of 5000000 steps (60%)
21:22:34:WU00:FS02:0x22:Checkpoint completed at step 3000000
21:23:55:WU00:FS02:0x22:Completed 3050000 out of 5000000 steps (61%)
21:23:59:WU03:FS00:0xa8:Completed 350000 out of 5000000 steps (7%)
21:25:15:WU00:FS02:0x22:Completed 3100000 out of 5000000 steps (62%)
21:26:36:WU00:FS02:0x22:Completed 3150000 out of 5000000 steps (63%)
21:27:56:WU00:FS02:0x22:Completed 3200000 out of 5000000 steps (64%)
21:29:17:WU00:FS02:0x22:Completed 3250000 out of 5000000 steps (65%)
21:29:17:WU00:FS02:0x22:Checkpoint completed at step 3250000
21:30:38:WU00:FS02:0x22:Completed 3300000 out of 5000000 steps (66%)
21:31:58:WU00:FS02:0x22:Completed 3350000 out of 5000000 steps (67%)
21:33:19:WU00:FS02:0x22:Completed 3400000 out of 5000000 steps (68%)
21:34:39:WU00:FS02:0x22:Completed 3450000 out of 5000000 steps (69%)
21:34:55:150:127.0.0.1:New Web session
21:35:07:WU03:FS00:0xa8:Completed 400000 out of 5000000 steps (8%)
21:36:00:WU00:FS02:0x22:Completed 3500000 out of 5000000 steps (70%)
21:36:00:WU00:FS02:0x22:Checkpoint completed at step 3500000
21:37:21:WU00:FS02:0x22:Completed 3550000 out of 5000000 steps (71%)
21:38:41:WU00:FS02:0x22:Completed 3600000 out of 5000000 steps (72%)
21:40:02:WU00:FS02:0x22:Completed 3650000 out of 5000000 steps (73%)
21:41:22:WU00:FS02:0x22:Completed 3700000 out of 5000000 steps (74%)
21:42:43:WU00:FS02:0x22:Completed 3750000 out of 5000000 steps (75%)
21:42:43:WU00:FS02:0x22:Checkpoint completed at step 3750000
21:44:03:WU00:FS02:0x22:Completed 3800000 out of 5000000 steps (76%)
21:45:24:WU00:FS02:0x22:Completed 3850000 out of 5000000 steps (77%)
21:46:16:WU03:FS00:0xa8:Completed 450000 out of 5000000 steps (9%)
21:46:44:WU00:FS02:0x22:Completed 3900000 out of 5000000 steps (78%)
21:48:05:WU00:FS02:0x22:Completed 3950000 out of 5000000 steps (79%)
21:49:27:WU00:FS02:0x22:Completed 4000000 out of 5000000 steps (80%)
21:49:28:WU00:FS02:0x22:Checkpoint completed at step 4000000
21:50:50:WU00:FS02:0x22:Completed 4050000 out of 5000000 steps (81%)
21:52:12:WU00:FS02:0x22:Completed 4100000 out of 5000000 steps (82%)
21:53:35:WU00:FS02:0x22:Completed 4150000 out of 5000000 steps (83%)
21:54:58:WU00:FS02:0x22:Completed 4200000 out of 5000000 steps (84%)
21:56:19:WU00:FS02:0x22:Completed 4250000 out of 5000000 steps (85%)
21:56:19:WU00:FS02:0x22:Checkpoint completed at step 4250000
21:57:40:WU00:FS02:0x22:Completed 4300000 out of 5000000 steps (86%)
21:58:30:WU03:FS00:0xa8:Completed 500000 out of 5000000 steps (10%)
21:59:02:WU00:FS02:0x22:Completed 4350000 out of 5000000 steps (87%)
22:00:24:WU00:FS02:0x22:Completed 4400000 out of 5000000 steps (88%)
22:01:45:WU00:FS02:0x22:Completed 4450000 out of 5000000 steps (89%)
22:03:06:WU00:FS02:0x22:Completed 4500000 out of 5000000 steps (90%)
22:03:06:WU00:FS02:0x22:Checkpoint completed at step 4500000
22:04:29:WU00:FS02:0x22:Completed 4550000 out of 5000000 steps (91%)
22:05:51:WU00:FS02:0x22:Completed 4600000 out of 5000000 steps (92%)
22:07:12:WU00:FS02:0x22:Completed 4650000 out of 5000000 steps (93%)
22:08:33:WU00:FS02:0x22:Completed 4700000 out of 5000000 steps (94%)
22:09:54:WU00:FS02:0x22:Completed 4750000 out of 5000000 steps (95%)
22:09:55:WU00:FS02:0x22:Checkpoint completed at step 4750000
22:10:17:WU03:FS00:0xa8:Completed 550000 out of 5000000 steps (11%)
22:11:16:WU00:FS02:0x22:Completed 4800000 out of 5000000 steps (96%)
22:12:37:WU00:FS02:0x22:Completed 4850000 out of 5000000 steps (97%)
22:13:59:WU00:FS02:0x22:Completed 4900000 out of 5000000 steps (98%)
22:15:20:WU00:FS02:0x22:Completed 4950000 out of 5000000 steps (99%)
22:15:21:WU01:FS02:Connecting to assign1.foldingathome.org:80
22:15:22:WU01:FS02:Assigned to work server 206.223.170.146
22:15:22:WU01:FS02:Requesting new work unit for slot 02: gpu:1:0 TU117M [GeForce GTX 1650 Mobile / Max-Q] from 206.223.170.146
22:15:22:WU01:FS02:Connecting to 206.223.170.146:8080
22:15:22:WU01:FS02:Downloading 13.75MiB
22:15:28:WU01:FS02:Download 45.45%
22:15:34:WU01:FS02:Download 96.36%
22:15:34:WU01:FS02:Download complete
22:15:34:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17432 run:0 clone:555 gen:153 core:0x22 unit:0x0000022b000000990000441800000000
22:16:41:WU00:FS02:0x22:Completed 5000000 out of 5000000 steps (100%)
22:16:41:WU00:FS02:0x22:Average performance: 21.2808 ns/day
22:16:41:WU00:FS02:0x22:Checkpoint completed at step 5000000
22:16:43:WU00:FS02:0x22:Saving result file ..\logfile_01.txt
22:16:43:WU00:FS02:0x22:Saving result file checkpointIntegrator.xml.bz2
22:16:43:WU00:FS02:0x22:Saving result file checkpointState.xml.bz2
22:16:43:WU00:FS02:0x22:Saving result file positions.xtc
22:16:43:WU00:FS02:0x22:Saving result file science.log
22:16:43:WU00:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
22:16:43:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:16:43:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:17800 run:68 clone:11 gen:126 core:0x22 unit:0x0000000b0000007e0000458800000044
22:16:43:WU00:FS02:Uploading 3.31MiB to 140.163.4.210
22:16:43:WU00:FS02:Connecting to 140.163.4.210:8080
22:16:44:WU01:FS02:Starting
22:16:44:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 10108 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:16:44:WU01:FS02:Started FahCore on PID 8024
22:16:44:WU01:FS02:Core PID:3028
22:16:44:WU01:FS02:FahCore 0x22 started
22:16:44:WU01:FS02:0x22:*********************** Log Started 2021-02-23T22:16:44Z ***********************
22:16:44:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
22:16:44:WU01:FS02:0x22: Core: Core22
22:16:44:WU01:FS02:0x22: Type: 0x22
22:16:44:WU01:FS02:0x22: Version: 0.0.13
22:16:44:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:16:44:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
22:16:44:WU01:FS02:0x22: Homepage: https://foldingathome.org/
22:16:44:WU01:FS02:0x22: Date: Sep 19 2020
22:16:44:WU01:FS02:0x22: Time: 02:35:58
22:16:44:WU01:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
22:16:44:WU01:FS02:0x22: Branch: core22-0.0.13
22:16:44:WU01:FS02:0x22: Compiler: Visual C++ 2015
22:16:44:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
22:16:44:WU01:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
22:16:44:WU01:FS02:0x22: Platform: win32 10
22:16:44:WU01:FS02:0x22: Bits: 64
22:16:44:WU01:FS02:0x22: Mode: Release
22:16:44:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:16:44:WU01:FS02:0x22: <peastman@stanford.edu>
22:16:44:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 8024 -checkpoint 15
22:16:44:WU01:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
22:16:44:WU01:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
22:16:44:WU01:FS02:0x22:************************************ libFAH ************************************
22:16:44:WU01:FS02:0x22: Date: Sep 7 2020
22:16:44:WU01:FS02:0x22: Time: 19:09:56
22:16:44:WU01:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
22:16:44:WU01:FS02:0x22: Branch: HEAD
22:16:44:WU01:FS02:0x22:************************************ CBang *************************************
22:16:44:WU01:FS02:0x22: Time: 19:08:30
22:16:44:WU01:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
22:16:44:WU01:FS02:0x22:************************************ System ************************************
22:16:44:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i5-9300H CPU @ 2.40GHz
22:16:44:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:16:44:WU01:FS02:0x22: CPUs: 8
22:16:44:WU01:FS02:0x22: Memory: 7.86GiB
22:16:44:WU01:FS02:0x22:Free Memory: 3.40GiB
22:16:44:WU01:FS02:0x22: Threads: WINDOWS_THREADS
22:16:44:WU01:FS02:0x22: OS Version: 6.2
22:16:44:WU01:FS02:0x22:Has Battery: true
22:16:44:WU01:FS02:0x22: On Battery: false
22:16:44:WU01:FS02:0x22: UTC Offset: -6
22:16:44:WU01:FS02:0x22: PID: 3028
22:16:44:WU01:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
22:16:44:WU01:FS02:0x22:************************************ OpenMM ************************************
22:16:44:WU01:FS02:0x22: Revision: 189320d0
22:16:44:WU01:FS02:0x22:********************************************************************************
22:16:44:WU01:FS02:0x22:Project: 17432 (Run 0, Clone 555, Gen 153)
22:16:44:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
22:16:44:WU01:FS02:0x22:Reading tar file core.xml
22:16:44:WU01:FS02:0x22:Reading tar file integrator.xml.bz2
22:16:44:WU01:FS02:0x22:Reading tar file state.xml.bz2
22:16:44:WU01:FS02:0x22:Reading tar file system.xml.bz2
22:16:44:WU01:FS02:0x22:Digital signatures verified
22:16:44:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
22:16:44:WU01:FS02:0x22:Version 0.0.13
22:16:44:WU01:FS02:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
22:16:44:WU01:FS02:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
22:16:44:WU01:FS02:0x22: XTC frame write interval: 10000 steps (0.8%) [125 total]
22:16:44:WU01:FS02:0x22: Global context and integrator variables write interval: disabled
22:16:44:WU01:FS02:0x22:There are 4 platforms available.
22:16:44:WU01:FS02:0x22:Platform 0: Reference
22:16:44:WU01:FS02:0x22:Platform 1: CPU
22:16:44:WU01:FS02:0x22:Platform 2: OpenCL
22:16:44:WU01:FS02:0x22: opencl-device 0 specified
22:16:44:WU01:FS02:0x22:Platform 3: CUDA
22:16:44:WU01:FS02:0x22: cuda-device 0 specified
22:16:49:WU00:FS02:Upload 32.13%
22:16:55:WU00:FS02:Upload 73.70%
22:16:59:WU00:FS02:Upload complete
22:16:59:WU00:FS02:Server responded WORK_ACK (400)
22:16:59:WU00:FS02:Final credit estimate, 50335.00 points
22:16:59:WU00:FS02:Cleaning up
22:17:02:WU01:FS02:0x22:Attempting to create CUDA context:
22:17:02:WU01:FS02:0x22: Configuring pla
Hey thanks for editing this for me too im still learning much apperciated!
but there is my fah log am i in need of changing anything or whats up
JimboPalmer wrote:Welcome to Folding@Home!
Once you enter the passkey, you need to complete 10 WU's and maintain a 80% success ratio, THEN you will get the Quick Return Bonus.
The Client does not know this, so it reports the bonus before it is awarded.
The link at the bottom of bruce's post shows how to find and post FAHlog.
So there is a success rate going on? as in i wont get it every time right? how do you know how many you have completed and what your success rate is? and is there anything else i should know?
Also thanks for the welcome!!!!
I am assuming this is a Laptop, and that that is our problem. Nvidia has a technology to use low power Intel GPUs until there is a need for more intensive work, then swapping to a Nvidia GPU.
At first this was called Optimus, but is now called Max-Q, I think.
https://www.nvidia.com/en-us/geforce/te ... echnology/
So you have two GPUs, but only one is active at a time. Worse, the Nvidia GPU is not swapped in until AFTER F@H tries to use it and fails.
06:06:23: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 CFL GT2 [UHD Graphics 630]
06:06:23: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117M [GeForce GTX 1650 Mobile /
06:06:23: Max-Q]
06:06:23: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
06:06:23:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:446.14
06:06:23:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
In my ancient laptop it was a BIOS setting, more recently some have been able to constantly enable the Nvidia GPU in the Nvidia Control Panel. Some folders here have had some luck using MSI Afterburner and altering some setting then minimizing it. Apparently the Nvidia GPU is enable until you close Afterburner.
None of this is obvious or easy. but it is what you are up against, in my opinion.
By the way, you seem to have an older version of the Nvidia driver. This is a more recent version: https://www.nvidia.com/en-us/drivers/results/170799/
06:06:23: Max-Q]
Normally folders aim for 100% and on a stable system that is achievable or at least very near .. if you look at your logs each wu should complete to 100% then pack up and be uploaded .. there will then bd aittle sequence sometimes after the next wu has started when the upload completes and what you are looking for is a line that states estimated points .. this will mean that thd wu was sucessfully uploaded ... now until your qrb qualifies as previously mentioned then the estimates will be significantly higher than the points you will actually get ... as far as is there anything else you should know a good starting place is the new donors forum
this will give you quite a bit of knowledge that may help ... as far a ban snd any issues with that you will need to contact their support ... this forum simply tries to support the fah software - and ban is outside its remit
Here is a page to check your bonus
https://apps.foldingathome.org/bonus
Okay well thanks. It is a laptop but i think i can still get it to run the folding with some good potential. I'd like to figure out how to get it all up and working properly. You say that i can constantly enable the nvidia GPU in the control panel? Is this where i should start or should i start somewhere else? also it would be absolutely amazing if you could give me a basic walkthrough on how to get this all working correctly. The last thing i want to do is start messing with settings and then ruin my laptop. I'd greatly appreciate it.JimboPalmer wrote:I am assuming this is a Laptop, and that that is our problem. Nvidia has a technology to use low power Intel GPUs until there is a need for more intensive work, then swapping to a Nvidia GPU.
06:06:23: Max-Q]
