*********************** Log Started 2021-02-17T05:03:33Z ***********************
05:03:33:******************************* libFAH ********************************
05:03:33: Date: Oct 20 2020
05:03:33: Time: 13:36:55
05:03:33: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
05:03:33: Branch: master
05:03:33: Compiler: Visual C++ 2015
05:03:33: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
05:03:33: Platform: win32 10
05:03:33: Bits: 32
05:03:33: Mode: Release
05:03:33:****************************** FAHClient ******************************
05:03:33: Version: 7.6.21
05:03:33: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:03:33: Copyright: 2020 foldingathome.org
05:03:33: Homepage: https://foldingathome.org/
05:03:33: Time: 13:41:04
05:03:33: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
05:03:33: Bits: 32
05:03:33: Config: C:\Users\Falcon\AppData\Roaming\FAHClient\config.xml
05:03:33:******************************** CBang ********************************
05:03:33: Time: 11:36:18
05:03:33: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
05:03:33: Bits: 32
05:03:33:******************************* System ********************************
05:03:33: CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
05:03:33: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
05:03:33: CPUs: 8
05:03:33: Memory: 15.88GiB
05:03:33: Free Memory: 8.66GiB
05:03:33: Threads: WINDOWS_THREADS
05:03:33: OS Version: 6.2
05:03:33: Has Battery: true
05:03:33: On Battery: false
05:03:33: UTC Offset: -8
05:03:33: PID: 20800
05:03:33: CWD: C:\Users\Falcon\AppData\Roaming\FAHClient
05:03:33: Win32 Service: false
05:03:33: OS: Windows 10 Enterprise
05:03:33: OS Arch: AMD64
05:03:33: GPUs: 3
05:03:33: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:4 GM108 [GeForce 940MX]
05:03:33: GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 630]
05:03:33: GPU 2: Bus:9 Slot:0 Func:0 AMD:5 Fiji XT [Radeon R9 Fury X]
05:03:33: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.0 Driver:11.0
05:03:33:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:452.66
05:03:33:OpenCL Device 1: Platform:1 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:3075.13
05:03:33:OpenCL Device 2: Platform:2 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
05:03:33:***********************************************************************
05:03:33:<config>
05:03:33: <!-- Folding Core -->
05:03:33: <core-priority v='low'/>
05:03:33:
05:03:33: <!-- Folding Slot Configuration -->
05:03:33: <gpu v='false'/>
05:03:33:
05:03:33: <!-- HTTP Server -->
05:03:33: <allow v='127.0.0.1 192.168.86.0/24 10.0.0.0/8'/>
05:03:33:
05:03:33: <!-- Network -->
05:03:33: <proxy v=':8080'/>
05:03:33:
05:03:33: <!-- Remote Command Server -->
05:03:33: <command-allow-no-pass v='127.0.0.1 192.168.86.0/24 10.0.0.0/8'/>
05:03:33:
05:03:33: <!-- Slot Control -->
05:03:33: <pause-on-battery v='false'/>
05:03:33: <power v='full'/>
05:03:33:
05:03:33: <!-- User Information -->
05:03:33: <passkey v='*****'/>
05:03:33: <team v='245782'/>
05:03:33: <user v='FalconFour'/>
05:03:33:
05:03:33: <!-- Folding Slots -->
05:03:33: <slot id='3' type='CPU'/>
05:03:33: <slot id='0' type='GPU'>
05:03:33: <pci-bus v='9'/>
05:03:33: <pci-slot v='0'/>
05:03:33: </slot>
05:03:33:</config>
05:03:33:Trying to access database...
05:03:33:Successfully acquired database lock
05:03:33:FS03:Initialized folding slot 03: cpu:7
05:03:33:FS00:Initialized folding slot 00: gpu:9:0 Fiji XT [Radeon R9 Fury X]
05:03:33:WU01:FS03:Starting
05:03:33:WU01:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Falcon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 20800 -checkpoint 15 -np 7
05:03:33:WU01:FS03:Started FahCore on PID 14984
05:03:33:WU01:FS03:Core PID:20796
05:03:33:WU01:FS03:FahCore 0xa8 started
05:03:34:WU02:FS00:Starting
05:03:34:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Falcon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 20800 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
05:03:34:WU02:FS00:Started FahCore on PID 17816
05:03:34:WU02:FS00:Core PID:20856
05:03:34:WU02:FS00:FahCore 0x22 started
05:03:34:WU01:FS03:0xa8:*********************** Log Started 2021-02-17T05:03:34Z ***********************
05:03:34:WU02:FS00:0x22:*********************** Log Started 2021-02-17T05:03:34Z ***********************
05:03:34:WU01:FS03:0xa8:************************** Gromacs Folding@home Core ***************************
05:03:35:WU02:FS00:0x22:*************************** Core22 Folding@home Core ***************************
05:03:35:WU01:FS03:0xa8: Core: Gromacs
05:03:35:WU02:FS00:0x22: Core: Core22
05:03:35:WU01:FS03:0xa8: Type: 0xa8
05:03:35:WU02:FS00:0x22: Type: 0x22
05:03:35:WU01:FS03:0xa8: Version: 0.0.12
05:03:35:WU02:FS00:0x22: Version: 0.0.13
05:03:35:WU01:FS03:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:03:35:WU02:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:03:35:WU01:FS03:0xa8: Copyright: 2020 foldingathome.org
05:03:35:WU02:FS00:0x22: Copyright: 2020 foldingathome.org
05:03:35:WU01:FS03:0xa8: Homepage: https://foldingathome.org/
05:03:35:WU02:FS00:0x22: Homepage: https://foldingathome.org/
05:03:35:WU01:FS03:0xa8: Date: Jan 16 2021
05:03:35:WU02:FS00:0x22: Date: Sep 19 2020
05:03:35:WU01:FS03:0xa8: Time: 12:29:40
05:03:35:WU02:FS00:0x22: Time: 02:35:58
05:03:35:WU01:FS03:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
05:03:35:WU02:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
05:03:35:WU01:FS03:0xa8: Branch: master
05:03:35:WU02:FS00:0x22: Branch: core22-0.0.13
05:03:35:WU01:FS03:0xa8: Compiler: Visual C++ 2019 16.7
05:03:35:WU02:FS00:0x22: Compiler: Visual C++ 2015
05:03:35:WU01:FS03:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
05:03:35:WU02:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
05:03:35:WU01:FS03:0xa8: Platform: win32 10
05:03:35:WU02:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
05:03:35:WU01:FS03:0xa8: Bits: 64
05:03:35:WU02:FS00:0x22: Platform: win32 10
05:03:35:WU01:FS03:0xa8: Mode: Release
05:03:35:WU02:FS00:0x22: Bits: 64
05:03:35:WU01:FS03:0xa8: SIMD: avx2_256
05:03:35:WU02:FS00:0x22: Mode: Release
05:03:35:WU01:FS03:0xa8: OpenMP: ON
05:03:35:WU02:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
05:03:35:WU01:FS03:0xa8: CUDA: OFF
05:03:35:WU02:FS00:0x22: <peastman@stanford.edu>
05:03:35:WU01:FS03:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 14984 -checkpoint 15 -np
05:03:35:WU02:FS00:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 17816 -checkpoint 15
05:03:35:WU01:FS03:0xa8: 7
05:03:35:WU02:FS00:0x22: -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
05:03:35:WU01:FS03:0xa8:************************************ libFAH ************************************
05:03:35:WU02:FS00:0x22: -gpu-usage 100
05:03:35:WU02:FS00:0x22:************************************ libFAH ************************************
05:03:35:WU01:FS03:0xa8: Time: 11:24:13
05:03:35:WU02:FS00:0x22: Date: Sep 7 2020
05:03:35:WU02:FS00:0x22: Time: 19:09:56
05:03:35:WU02:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
05:03:35:WU02:FS00:0x22: Branch: HEAD
05:03:35:WU01:FS03:0xa8:************************************ CBang *************************************
05:03:35:WU02:FS00:0x22:************************************ CBang *************************************
05:03:35:WU01:FS03:0xa8: Time: 11:23:53
05:03:35:WU02:FS00:0x22: Time: 19:08:30
05:03:35:WU02:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
05:03:35:WU01:FS03:0xa8:************************************ System ************************************
05:03:35:WU01:FS03:0xa8: CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
05:03:35:WU02:FS00:0x22:************************************ System ************************************
05:03:35:WU01:FS03:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
05:03:35:WU02:FS00:0x22: CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
05:03:35:WU01:FS03:0xa8: CPUs: 8
05:03:35:WU02:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
05:03:35:WU01:FS03:0xa8: Memory: 15.88GiB
05:03:35:WU02:FS00:0x22: CPUs: 8
05:03:35:WU01:FS03:0xa8:Free Memory: 8.78GiB
05:03:35:WU02:FS00:0x22: Memory: 15.88GiB
05:03:35:WU01:FS03:0xa8: Threads: WINDOWS_THREADS
05:03:35:WU02:FS00:0x22:Free Memory: 8.76GiB
05:03:35:WU01:FS03:0xa8: OS Version: 6.2
05:03:35:WU02:FS00:0x22: Threads: WINDOWS_THREADS
05:03:35:WU01:FS03:0xa8:Has Battery: true
05:03:35:WU02:FS00:0x22: OS Version: 6.2
05:03:35:WU01:FS03:0xa8: On Battery: false
05:03:35:WU02:FS00:0x22:Has Battery: true
05:03:35:WU01:FS03:0xa8: UTC Offset: -8
05:03:35:WU02:FS00:0x22: On Battery: false
05:03:35:WU01:FS03:0xa8: PID: 20796
05:03:35:WU02:FS00:0x22: UTC Offset: -8
05:03:35:WU01:FS03:0xa8: CWD: C:\Users\Falcon\AppData\Roaming\FAHClient\work
05:03:35:WU02:FS00:0x22: PID: 20856
05:03:35:WU01:FS03:0xa8:********************************************************************************
05:03:35:WU02:FS00:0x22: CWD: C:\Users\Falcon\AppData\Roaming\FAHClient\work
05:03:35:WU01:FS03:0xa8:Project: 16950 (Run 6, Clone 2, Gen 52)
05:03:35:WU02:FS00:0x22:************************************ OpenMM ************************************
05:03:35:WU01:FS03:0xa8:Unit: 0x00000000000000000000000000000000
05:03:35:WU02:FS00:0x22: Revision: 189320d0
05:03:35:WU01:FS03:0xa8:Digital signatures verified
05:03:35:WU02:FS00:0x22:********************************************************************************
05:03:35:WU01:FS03:0xa8:Calling: mdrun -c frame52.gro -s frame52.tpr -x frame52.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
05:03:35:WU02:FS00:0x22:Project: 17433 (Run 0, Clone 484, Gen 39)
05:03:35:WU01:FS03:0xa8:Steps: first=260000000 total=265000000
05:03:35:WU02:FS00:0x22:Unit: 0x00000000000000000000000000000000
05:03:35:WU02:FS00:0x22:Digital signatures verified
05:03:35:WU02:FS00:0x22:Folding@home GPU Core22 Folding@home Core
05:03:35:WU02:FS00:0x22:Version 0.0.13
05:03:35:WU02:FS00:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
05:03:35:WU02:FS00:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
05:03:35:WU02:FS00:0x22: XTC frame write interval: 10000 steps (0.8%) [125 total]
05:03:35:WU02:FS00:0x22: Global context and integrator variables write interval: disabled
05:03:35:WU02:FS00:0x22:There are 3 platforms available.
05:03:35:WU02:FS00:0x22:Platform 0: Reference
05:03:35:WU02:FS00:0x22:Platform 1: CPU
05:03:35:WU02:FS00:0x22:Platform 2: OpenCL
05:03:35:WU02:FS00:0x22: opencl-device 0 specified
05:03:39:WU01:FS03:0xa8:Completed 1740892 out of 5000000 steps (34%)
05:04:16:WU02:FS00:0x22:Attempting to create OpenCL context:
05:04:16:WU02:FS00:0x22: Configuring platform OpenCL
05:04:57:WU02:FS00:0x22: Using OpenCL on platformId 1 and gpu 0
05:04:58:WU02:FS00:0x22:Completed 850000 out of 1250000 steps (68%)
05:06:39:WU01:FS03:0xa8:Completed 1750000 out of 5000000 steps (35%)
Yes, it started using the CPU platform.
I only noticed this because my eGPU has activity indicators on it, and there was no activity on it after several minutes... while my laptop CPU fan started roaring up. I checked Task Manager and found that the eGPU is indeed idle, but my GPU 0: Intel HD Graphics was pegged at 100% usage. And the WU was estimated to take 1.2 days.
This is a completely unmodified configuration since it last worked fine, same Windows session and all. Basically, F@H is failing to associate the PCI bus/slot ID to the correct platform/device. I kinda wish it would still just let me pick slot/device, as that worked at least somewhat reliably... but this bus/slot thing seems to just have a lot of issues.
update: after rebooting, no change. after "updating" the AMD driver with itself (update driver -> select the same driver that it already had -> continue), it re-registered itself and again installed AMD's corrupt "Pci Bus" driver (note the capitalization) over the MS standard "PCI Express Root Complex" device, which messes up my touchpad/keyboard... so I reverted that and disabled the "AMD External Events Utility" service which is responsible for installing that bad driver... (ugh, I utterly hate how AMD takes it upon themselves to install these bad drivers on a laptop!)... aaaand guess what? Works great again.
*********************** Log Started 2021-02-17T05:21:38Z ***********************
05:21:38:******************************* libFAH ********************************
05:21:38: Date: Oct 20 2020
05:21:38: Time: 13:36:55
05:21:38: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
05:21:38: Branch: master
05:21:38: Compiler: Visual C++ 2015
05:21:38: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
05:21:38: Platform: win32 10
05:21:38: Bits: 32
05:21:38: Mode: Release
05:21:38:****************************** FAHClient ******************************
05:21:38: Version: 7.6.21
05:21:38: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:21:38: Copyright: 2020 foldingathome.org
05:21:38: Homepage: https://foldingathome.org/
05:21:38: Time: 13:41:04
05:21:38: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
05:21:38: Bits: 32
05:21:38: Config: C:\Users\Falcon\AppData\Roaming\FAHClient\config.xml
05:21:38:******************************** CBang ********************************
05:21:38: Time: 11:36:18
05:21:38: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
05:21:38: Bits: 32
05:21:38:******************************* System ********************************
05:21:38: CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
05:21:38: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
05:21:38: CPUs: 8
05:21:38: Memory: 15.88GiB
05:21:38: Free Memory: 11.56GiB
05:21:38: Threads: WINDOWS_THREADS
05:21:38: OS Version: 6.2
05:21:38: Has Battery: true
05:21:38: On Battery: false
05:21:38: UTC Offset: -8
05:21:38: PID: 6280
05:21:38: CWD: C:\Users\Falcon\AppData\Roaming\FAHClient
05:21:38: Win32 Service: false
05:21:38: OS: Windows 10 Enterprise
05:21:38: OS Arch: AMD64
05:21:38: GPUs: 3
05:21:38: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:4 GM108 [GeForce 940MX]
05:21:38: GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 630]
05:21:38: GPU 2: Bus:9 Slot:0 Func:0 AMD:5 Fiji XT [Radeon R9 Fury X]
05:21:38: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.0 Driver:11.0
05:21:38:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:3075.13
05:21:38:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
05:21:38:OpenCL Device 2: Platform:2 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:452.66
05:21:38:***********************************************************************
05:21:38:<config>
05:21:38: <!-- Folding Core -->
05:21:38: <core-priority v='low'/>
05:21:38:
05:21:38: <!-- Folding Slot Configuration -->
05:21:38: <gpu v='false'/>
05:21:38:
05:21:38: <!-- HTTP Server -->
05:21:38: <allow v='127.0.0.1 192.168.86.0/24 10.0.0.0/8'/>
05:21:38:
05:21:38: <!-- Network -->
05:21:38: <proxy v=':8080'/>
05:21:38:
05:21:38: <!-- Remote Command Server -->
05:21:38: <command-allow-no-pass v='127.0.0.1 192.168.86.0/24 10.0.0.0/8'/>
05:21:38:
05:21:38: <!-- Slot Control -->
05:21:38: <pause-on-battery v='false'/>
05:21:38: <power v='full'/>
05:21:38:
05:21:38: <!-- User Information -->
05:21:38: <passkey v='*****'/>
05:21:38: <team v='245782'/>
05:21:38: <user v='FalconFour'/>
05:21:38:
05:21:38: <!-- Folding Slots -->
05:21:38: <slot id='3' type='CPU'/>
05:21:38: <slot id='0' type='GPU'>
05:21:38: <pci-bus v='9'/>
05:21:38: <pci-slot v='0'/>
05:21:38: </slot>
05:21:38:</config>
05:21:38:Trying to access database...
05:21:38:Successfully acquired database lock
05:21:38:FS03:Initialized folding slot 03: cpu:7
05:21:38:FS00:Initialized folding slot 00: gpu:9:0 Fiji XT [Radeon R9 Fury X]
05:21:38:WU02:FS00:Starting
05:21:38:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Falcon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 6280 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
05:21:38:WU02:FS00:Started FahCore on PID 11688
05:21:38:WU02:FS00:Core PID:11700
05:21:38:WU02:FS00:FahCore 0x22 started
05:21:39:WU01:FS03:Starting
05:21:39:WU01:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Falcon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 6280 -checkpoint 15 -np 7
05:21:39:WU01:FS03:Started FahCore on PID 16192
05:21:39:WU01:FS03:Core PID:3700
05:21:39:WU01:FS03:FahCore 0xa8 started
05:21:39:WU02:FS00:0x22:*********************** Log Started 2021-02-17T05:21:38Z ***********************
05:21:39:WU02:FS00:0x22:*************************** Core22 Folding@home Core ***************************
05:21:39:WU02:FS00:0x22: Core: Core22
05:21:39:WU02:FS00:0x22: Type: 0x22
05:21:39:WU02:FS00:0x22: Version: 0.0.13
05:21:39:WU02:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:21:39:WU02:FS00:0x22: Copyright: 2020 foldingathome.org
05:21:39:WU02:FS00:0x22: Homepage: https://foldingathome.org/
05:21:39:WU02:FS00:0x22: Date: Sep 19 2020
05:21:39:WU02:FS00:0x22: Time: 02:35:58
05:21:39:WU02:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
05:21:39:WU02:FS00:0x22: Branch: core22-0.0.13
05:21:39:WU02:FS00:0x22: Compiler: Visual C++ 2015
05:21:39:WU02:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
05:21:39:WU02:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
05:21:39:WU02:FS00:0x22: Platform: win32 10
05:21:39:WU02:FS00:0x22: Bits: 64
05:21:39:WU02:FS00:0x22: Mode: Release
05:21:39:WU02:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
05:21:39:WU02:FS00:0x22: <peastman@stanford.edu>
05:21:39:WU02:FS00:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 11688 -checkpoint 15
05:21:39:WU02:FS00:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
05:21:39:WU02:FS00:0x22: -gpu-usage 100
05:21:39:WU02:FS00:0x22:************************************ libFAH ************************************
05:21:39:WU02:FS00:0x22: Date: Sep 7 2020
05:21:39:WU02:FS00:0x22: Time: 19:09:56
05:21:39:WU02:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
05:21:39:WU02:FS00:0x22: Branch: HEAD
05:21:39:WU02:FS00:0x22:************************************ CBang *************************************
05:21:39:WU02:FS00:0x22: Time: 19:08:30
05:21:39:WU02:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
05:21:39:WU02:FS00:0x22:************************************ System ************************************
05:21:39:WU02:FS00:0x22: CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
05:21:39:WU02:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
05:21:39:WU02:FS00:0x22: CPUs: 8
05:21:39:WU02:FS00:0x22: Memory: 15.88GiB
05:21:39:WU02:FS00:0x22:Free Memory: 11.50GiB
05:21:39:WU02:FS00:0x22: Threads: WINDOWS_THREADS
05:21:39:WU02:FS00:0x22: OS Version: 6.2
05:21:39:WU02:FS00:0x22:Has Battery: true
05:21:39:WU02:FS00:0x22: On Battery: false
05:21:39:WU02:FS00:0x22: UTC Offset: -8
05:21:39:WU02:FS00:0x22: PID: 11700
05:21:39:WU02:FS00:0x22: CWD: C:\Users\Falcon\AppData\Roaming\FAHClient\work
05:21:39:WU02:FS00:0x22:************************************ OpenMM ************************************
05:21:39:WU02:FS00:0x22: Revision: 189320d0
05:21:39:WU02:FS00:0x22:********************************************************************************
05:21:39:WU02:FS00:0x22:Project: 17433 (Run 0, Clone 484, Gen 39)
05:21:39:WU02:FS00:0x22:Unit: 0x00000000000000000000000000000000
05:21:39:WU02:FS00:0x22:Digital signatures verified
05:21:39:WU02:FS00:0x22:Folding@home GPU Core22 Folding@home Core
05:21:39:WU02:FS00:0x22:Version 0.0.13
05:21:39:WU01:FS03:0xa8:*********************** Log Started 2021-02-17T05:21:39Z ***********************
05:21:39:WU01:FS03:0xa8:************************** Gromacs Folding@home Core ***************************
05:21:39:WU01:FS03:0xa8: Core: Gromacs
05:21:39:WU01:FS03:0xa8: Type: 0xa8
05:21:39:WU01:FS03:0xa8: Version: 0.0.12
05:21:39:WU01:FS03:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:21:39:WU01:FS03:0xa8: Copyright: 2020 foldingathome.org
05:21:39:WU01:FS03:0xa8: Homepage: https://foldingathome.org/
05:21:39:WU01:FS03:0xa8: Date: Jan 16 2021
05:21:39:WU01:FS03:0xa8: Time: 12:29:40
05:21:39:WU01:FS03:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
05:21:39:WU01:FS03:0xa8: Branch: master
05:21:39:WU01:FS03:0xa8: Compiler: Visual C++ 2019 16.7
05:21:39:WU01:FS03:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
05:21:39:WU01:FS03:0xa8: Platform: win32 10
05:21:39:WU01:FS03:0xa8: Bits: 64
05:21:39:WU01:FS03:0xa8: Mode: Release
05:21:39:WU01:FS03:0xa8: SIMD: avx2_256
05:21:39:WU01:FS03:0xa8: OpenMP: ON
05:21:39:WU01:FS03:0xa8: CUDA: OFF
05:21:39:WU01:FS03:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 16192 -checkpoint 15 -np
05:21:39:WU01:FS03:0xa8: 7
05:21:39:WU01:FS03:0xa8:************************************ libFAH ************************************
05:21:39:WU01:FS03:0xa8: Time: 11:24:13
05:21:39:WU01:FS03:0xa8:************************************ CBang *************************************
05:21:39:WU01:FS03:0xa8: Time: 11:23:53
05:21:39:WU01:FS03:0xa8:************************************ System ************************************
05:21:39:WU01:FS03:0xa8: CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
05:21:39:WU01:FS03:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
05:21:39:WU01:FS03:0xa8: CPUs: 8
05:21:39:WU01:FS03:0xa8: Memory: 15.88GiB
05:21:39:WU01:FS03:0xa8:Free Memory: 11.49GiB
05:21:39:WU01:FS03:0xa8: Threads: WINDOWS_THREADS
05:21:39:WU01:FS03:0xa8: OS Version: 6.2
05:21:39:WU01:FS03:0xa8:Has Battery: true
05:21:39:WU01:FS03:0xa8: On Battery: false
05:21:39:WU01:FS03:0xa8: UTC Offset: -8
05:21:39:WU01:FS03:0xa8: PID: 3700
05:21:39:WU01:FS03:0xa8: CWD: C:\Users\Falcon\AppData\Roaming\FAHClient\work
05:21:39:WU01:FS03:0xa8:********************************************************************************
05:21:39:WU01:FS03:0xa8:Project: 16950 (Run 6, Clone 2, Gen 52)
05:21:39:WU01:FS03:0xa8:Unit: 0x00000000000000000000000000000000
05:21:39:WU01:FS03:0xa8:Digital signatures verified
05:21:39:WU01:FS03:0xa8:Calling: mdrun -c frame52.gro -s frame52.tpr -x frame52.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
05:21:39:WU01:FS03:0xa8:Steps: first=260000000 total=265000000
05:21:39:WU02:FS00:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
05:21:39:WU02:FS00:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
05:21:39:WU02:FS00:0x22: XTC frame write interval: 10000 steps (0.8%) [125 total]
05:21:39:WU02:FS00:0x22: Global context and integrator variables write interval: disabled
05:21:39:WU02:FS00:0x22:There are 3 platforms available.
05:21:39:WU02:FS00:0x22:Platform 0: Reference
05:21:39:WU02:FS00:0x22:Platform 1: CPU
05:21:39:WU02:FS00:0x22:Platform 2: OpenCL
05:21:39:WU02:FS00:0x22: opencl-device 0 specified
05:21:41:WU01:FS03:0xa8:Completed 1779901 out of 5000000 steps (35%)
05:22:18:WU02:FS00:0x22:Attempting to create OpenCL context:
05:22:18:WU02:FS00:0x22: Configuring platform OpenCL
05:22:36:WU02:FS00:0x22: Using OpenCL on platformId 0 and gpu 0
05:22:37:WU02:FS00:0x22:Completed 850000 out of 1250000 steps (68%)
