Server 128.252.203.10 Exception: 10002: Received short respo
sbafiox
Hardware configuration: Motherboard: MSI MAG X570 Tomahawk Wi-Fi
CPU: AMD Ryzen 7 5800x
Graphics card: Sapphire Radeon RX6700 XT
Ram: 32 GB Corsair Vengeance DDR4 3600 (@ 3200)
Post by sbafiox »
I've been having troubles with this server for alnost a week now
Here is the log
*********************** Log Started 2021-02-11T15:00:36Z ***********************
15:00:36:******************************* libFAH ********************************
15:00:36:           Date: Oct 20 2020
15:00:36:           Time: 13:36:55
15:00:36:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:00:36:         Branch: master
15:00:36:       Compiler: Visual C++ 2015
15:00:36:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:00:36:       Platform: win32 10
15:00:36:           Bits: 32
15:00:36:           Mode: Release
15:00:36:****************************** FAHClient ******************************
15:00:36:        Version: 7.6.21
15:00:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:00:36:      Copyright: 2020 foldingathome.org
15:00:36:       Homepage: https://foldingathome.org/
15:00:36:           Time: 13:41:04
15:00:36:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:00:36:           Bits: 32
15:00:36:         Config: C:\ProgramData\FAHClient\config.xml
15:00:36:******************************** CBang ********************************
15:00:36:           Time: 11:36:18
15:00:36:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:00:36:           Bits: 32
15:00:36:******************************* System ********************************
15:00:36:            CPU: AMD Ryzen 5 2600X Six-Core Processor
15:00:36:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:00:36:           CPUs: 12
15:00:36:         Memory: 31.95GiB
15:00:36:    Free Memory: 28.40GiB
15:00:36:        Threads: WINDOWS_THREADS
15:00:36:     OS Version: 6.2
15:00:36:    Has Battery: false
15:00:36:     On Battery: false
15:00:36:     UTC Offset: 1
15:00:36:            PID: 13820
15:00:36:            CWD: C:\ProgramData\FAHClient
15:00:36:  Win32 Service: false
15:00:36:             OS: Windows 10 Home
15:00:36:        OS Arch: AMD64
15:00:36:           GPUs: 1
15:00:36:          GPU 0: Bus:45 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
15:00:36:                 470/480/570/580/590]
15:00:36:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
15:00:36:                 Impossibile trovare il modulo specificato.
15:00:36:
15:00:36:OpenCL Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:1.2 Driver:3188.4
15:00:36:***********************************************************************
15:00:36:<config>
15:00:36:  <!-- Folding Slot Configuration -->
15:00:36:  <cause v='ALZHEIMERS'/>
15:00:36:
15:00:36:  <!-- Network -->
15:00:36:  <proxy v=':8080'/>
15:00:36:
15:00:36:  <!-- User Information -->
15:00:36:  <passkey v='*****'/>
15:00:36:  <team v='31'/>
15:00:36:  <user v='Sbafiox'/>
15:00:36:
15:00:36:  <!-- Folding Slots -->
15:00:36:  <slot id='0' type='CPU'/>
15:00:36:  <slot id='1' type='GPU'>
15:00:36:    <pci-bus v='45'/>
15:00:36:    <pci-slot v='0'/>
15:00:36:  </slot>
15:00:36:</config>
15:00:36:Trying to access database...
15:00:36:Successfully acquired database lock
15:00:36:FS00:Initialized folding slot 00: cpu:10
15:00:36:FS01:Initialized folding slot 01: gpu:45:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
15:00:36:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:17325 run:10 clone:482 gen:8 core:0x22 unit:0x000001e200000008000043ad0000000a
15:00:36:WU04:FS01:Uploading 12.33MiB to 140.163.4.200
15:00:36:WU04:FS01:Connecting to 140.163.4.200:8080
15:00:36:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17433 run:0 clone:470 gen:21 core:0x22 unit:0x000001d6000000150000441900000000
15:00:36:WU00:FS01:Uploading 24.23MiB to 206.223.170.146
15:00:36:WU00:FS01:Connecting to 206.223.170.146:8080
15:00:36:WU02:FS00:Starting
15:00:36:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 13820 -checkpoint 15 -np 10
15:00:36:WU02:FS00:Started FahCore on PID 11472
15:00:37:WU02:FS00:Core PID:13512
15:00:37:WU02:FS00:FahCore 0xa7 started
15:00:37:WU01:FS01:Starting
15:00:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 13820 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
15:00:37:WU01:FS01:Started FahCore on PID 14212
15:00:37:WU01:FS01:Core PID:14352
15:00:37:WU01:FS01:FahCore 0x22 started
15:00:37:WU02:FS00:0xa7:*********************** Log Started 2021-02-11T15:00:37Z ***********************
15:00:37:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:00:37:WU02:FS00:0xa7:       Type: 0xa7
15:00:37:WU02:FS00:0xa7:       Core: Gromacs
15:00:37:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 11472 -checkpoint 15 -np
15:00:37:WU02:FS00:0xa7:             10
15:00:37:WU02:FS00:0xa7:************************************ CBang *************************************
15:00:37:WU02:FS00:0xa7:       Date: Nov 27 2019
15:00:37:WU02:FS00:0xa7:       Time: 03:40:09
15:00:37:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
15:00:37:WU02:FS00:0xa7:     Branch: master
15:00:37:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
15:00:37:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:00:37:WU02:FS00:0xa7:   Platform: win32 10
15:00:37:WU02:FS00:0xa7:       Bits: 64
15:00:37:WU02:FS00:0xa7:       Mode: Release
15:00:37:WU02:FS00:0xa7:************************************ System ************************************
15:00:37:WU02:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
15:00:37:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:00:37:WU02:FS00:0xa7:       CPUs: 12
15:00:37:WU02:FS00:0xa7:     Memory: 31.95GiB
15:00:37:WU02:FS00:0xa7:Free Memory: 28.20GiB
15:00:37:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
15:00:37:WU02:FS00:0xa7: OS Version: 6.2
15:00:37:WU02:FS00:0xa7:Has Battery: false
15:00:37:WU02:FS00:0xa7: On Battery: false
15:00:37:WU02:FS00:0xa7: UTC Offset: 1
15:00:37:WU02:FS00:0xa7:        PID: 13512
15:00:37:WU02:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
15:00:37:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
15:00:37:WU02:FS00:0xa7:    Version: 0.0.19
15:00:37:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:00:37:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:00:37:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
15:00:37:WU02:FS00:0xa7:       Date: Nov 25 2019
15:00:37:WU02:FS00:0xa7:       Time: 17:12:41
15:00:37:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
15:00:37:WU02:FS00:0xa7:************************************ Build *************************************
15:00:37:WU02:FS00:0xa7:       SIMD: avx_256
15:00:37:WU02:FS00:0xa7:********************************************************************************
15:00:37:WU02:FS00:0xa7:Project: 16927 (Run 8, Clone 1445, Gen 39)
15:00:37:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
15:00:37:WU01:FS01:0x22:*********************** Log Started 2021-02-11T15:00:37Z ***********************
15:00:37:WU02:FS00:0xa7:Digital signatures verified
15:00:37:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:00:37:WU02:FS00:0xa7:Calling: mdrun -s frame39.tpr -o frame39.trr -cpi state.cpt -cpt 15 -nt 10
15:00:37:WU01:FS01:0x22:       Core: Core22
15:00:37:WU01:FS01:0x22:       Type: 0x22
15:00:37:WU01:FS01:0x22:    Version: 0.0.13
15:00:37:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:00:37:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
15:00:37:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
15:00:37:WU01:FS01:0x22:       Date: Sep 19 2020
15:00:37:WU01:FS01:0x22:       Time: 02:35:58
15:00:37:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
15:00:37:WU01:FS01:0x22:     Branch: core22-0.0.13
15:00:37:WU01:FS01:0x22:   Compiler: Visual C++ 2015
15:00:37:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:00:37:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
15:00:37:WU01:FS01:0x22:   Platform: win32 10
15:00:37:WU01:FS01:0x22:       Bits: 64
15:00:37:WU01:FS01:0x22:       Mode: Release
15:00:37:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:00:37:WU01:FS01:0x22:             <peastman@stanford.edu>
15:00:37:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 14212 -checkpoint 15
15:00:37:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
15:00:37:WU01:FS01:0x22:             -gpu-usage 100
15:00:37:WU01:FS01:0x22:************************************ libFAH ************************************
15:00:37:WU01:FS01:0x22:       Date: Sep 7 2020
15:00:37:WU01:FS01:0x22:       Time: 19:09:56
15:00:37:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
15:00:37:WU01:FS01:0x22:     Branch: HEAD
15:00:37:WU01:FS01:0x22:************************************ CBang *************************************
15:00:37:WU01:FS01:0x22:       Time: 19:08:30
15:00:37:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
15:00:37:WU01:FS01:0x22:************************************ System ************************************
15:00:37:WU01:FS01:0x22:        CPU: AMD Ryzen 5 2600X Six-Core Processor
15:00:37:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:00:37:WU01:FS01:0x22:       CPUs: 12
15:00:37:WU01:FS01:0x22:     Memory: 31.95GiB
15:00:37:WU01:FS01:0x22:Free Memory: 28.14GiB
15:00:37:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
15:00:37:WU01:FS01:0x22: OS Version: 6.2
15:00:37:WU01:FS01:0x22:Has Battery: false
15:00:37:WU01:FS01:0x22: On Battery: false
15:00:37:WU01:FS01:0x22: UTC Offset: 1
15:00:37:WU01:FS01:0x22:        PID: 14352
15:00:37:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
15:00:37:WU01:FS01:0x22:************************************ OpenMM ************************************
15:00:37:WU01:FS01:0x22:   Revision: 189320d0
15:00:37:WU01:FS01:0x22:********************************************************************************
15:00:37:WU01:FS01:0x22:Project: 17434 (Run 0, Clone 1876, Gen 20)
15:00:37:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
15:00:37:WU01:FS01:0x22:Digital signatures verified
15:00:37:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:00:37:WU01:FS01:0x22:Version 0.0.13
15:00:37:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
15:00:37:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
15:00:37:WU01:FS01:0x22:  XTC frame write interval: 10000 steps (0.8%) [125 total]
15:00:37:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
15:00:37:WU01:FS01:0x22:There are 3 platforms available.
15:00:37:WU01:FS01:0x22:Platform 0: Reference
15:00:37:WU01:FS01:0x22:Platform 1: CPU
15:00:37:WU01:FS01:0x22:Platform 2: OpenCL
15:00:37:WU01:FS01:0x22:  opencl-device 0 specified
15:00:37:WU02:FS00:0xa7:Steps: first=19500000 total=500000
15:00:40:WU02:FS00:0xa7:Completed 238781 out of 500000 steps (47%)
15:00:42:WU00:FS01:Upload 93.64%
15:01:00:WU01:FS01:0x22:Attempting to create OpenCL context:
15:01:00:WU01:FS01:0x22:  Configuring platform OpenCL
15:01:07:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:01:07:WU04:FS01:Trying to send results to collection server
15:01:07:WU04:FS01:Uploading 12.33MiB to 140.163.4.210
15:01:07:WU04:FS01:Connecting to 140.163.4.210:8080
15:01:11:WU01:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
15:01:11:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
15:01:15:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:01:15:WU00:FS01:Trying to send results to collection server
15:01:15:WU00:FS01:Uploading 24.23MiB to 128.252.203.10
15:01:15:WU00:FS01:Connecting to 128.252.203.10:8080
15:01:21:WU00:FS01:Upload 46.69%
15:01:27:WU00:FS01:Upload 73.26%
15:01:33:WU00:FS01:Upload 99.31%
15:01:37:WU02:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
15:01:38:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:01:38:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:17325 run:10 clone:482 gen:8 core:0x22 unit:0x000001e200000008000043ad0000000a
15:01:38:WU04:FS01:Uploading 12.33MiB to 140.163.4.200
15:01:38:WU04:FS01:Connecting to 140.163.4.200:8080
15:01:44:WU04:FS01:Upload 90.23%
15:02:03:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:02:03:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17433 run:0 clone:470 gen:21 core:0x22 unit:0x000001d6000000150000441900000000
15:02:03:WU00:FS01:Uploading 24.23MiB to 206.223.170.146
15:02:03:WU00:FS01:Connecting to 206.223.170.146:8080
15:02:09:WU00:FS01:Upload 77.90%
15:02:15:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:02:15:WU04:FS01:Trying to send results to collection server
15:02:15:WU04:FS01:Uploading 12.33MiB to 140.163.4.210
15:02:15:WU04:FS01:Connecting to 140.163.4.210:8080
15:02:21:WU04:FS01:Upload 54.75%
15:02:27:WU04:FS01:Upload 96.32%
15:02:43:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:02:43:WU00:FS01:Trying to send results to collection server
15:02:43:WU00:FS01:Uploading 24.23MiB to 128.252.203.10
15:02:43:WU00:FS01:Connecting to 128.252.203.10:8080
15:02:49:WU00:FS01:Upload 58.04%
15:02:55:WU00:FS01:Upload 81.51%
15:02:57:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:02:58:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:17325 run:10 clone:482 gen:8 core:0x22 unit:0x000001e200000008000043ad0000000a
15:02:58:WU04:FS01:Uploading 12.33MiB to 140.163.4.200
15:02:58:WU04:FS01:Connecting to 140.163.4.200:8080
15:03:04:WU04:FS01:Upload 39.54%
15:03:10:WU04:FS01:Upload 96.32%
15:03:30:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:03:30:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17433 run:0 clone:470 gen:21 core:0x22 unit:0x000001d6000000150000441900000000
15:03:30:WU00:FS01:Uploading 24.23MiB to 206.223.170.146
15:03:30:WU00:FS01:Connecting to 206.223.170.146:8080
15:03:36:WU00:FS01:Upload 84.35%
15:03:40:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:03:40:WU04:FS01:Trying to send results to collection server
15:03:40:WU04:FS01:Uploading 12.33MiB to 140.163.4.210
15:03:40:WU04:FS01:Connecting to 140.163.4.210:8080
15:03:46:WU04:FS01:Upload 56.78%
15:04:10:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:04:10:WU00:FS01:Trying to send results to collection server
15:04:10:WU00:FS01:Uploading 24.23MiB to 128.252.203.10
15:04:10:WU00:FS01:Connecting to 128.252.203.10:8080
15:04:16:WU00:FS01:Upload 78.68%
15:04:21:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:04:27:WU02:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
15:04:35:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:17325 run:10 clone:482 gen:8 core:0x22 unit:0x000001e200000008000043ad0000000a
15:04:35:WU04:FS01:Uploading 12.33MiB to 140.163.4.200
15:04:35:WU04:FS01:Connecting to 140.163.4.200:8080
15:04:41:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
15:04:51:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:05:05:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:05:05:WU04:FS01:Trying to send results to collection server
15:05:05:WU04:FS01:Uploading 12.33MiB to 140.163.4.210
15:05:05:WU04:FS01:Connecting to 140.163.4.210:8080
15:05:07:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17433 run:0 clone:470 gen:21 core:0x22 unit:0x000001d6000000150000441900000000
15:05:07:WU00:FS01:Uploading 24.23MiB to 206.223.170.146
15:05:07:WU00:FS01:Connecting to 206.223.170.146:8080
15:05:13:WU00:FS01:Upload 63.97%
15:05:19:WU00:FS01:Upload 80.48%
15:05:25:WU00:FS01:Upload 96.22%
15:05:35:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:05:56:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:05:56:WU00:FS01:Trying to send results to collection server
15:05:56:WU00:FS01:Uploading 24.23MiB to 128.252.203.10
15:05:56:WU00:FS01:Connecting to 128.252.203.10:8080
15:06:30:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:07:12:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:17325 run:10 clone:482 gen:8 core:0x22 unit:0x000001e200000008000043ad0000000a
15:07:12:WU04:FS01:Uploading 12.33MiB to 140.163.4.200
15:07:12:WU04:FS01:Connecting to 140.163.4.200:8080
15:07:17:WU02:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
15:07:42:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:07:42:WU04:FS01:Trying to send results to collection server
15:07:42:WU04:FS01:Uploading 12.33MiB to 140.163.4.210
15:07:42:WU04:FS01:Connecting to 140.163.4.210:8080
15:07:44:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17433 run:0 clone:470 gen:21 core:0x22 unit:0x000001d6000000150000441900000000
15:07:44:WU00:FS01:Uploading 24.23MiB to 206.223.170.146
15:07:44:WU00:FS01:Connecting to 206.223.170.146:8080
15:07:50:WU00:FS01:Upload 68.87%
15:07:56:WU00:FS01:Upload 86.42%
15:08:04:WU01:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
15:08:06:WU01:FS01:0x22:Checkpoint completed at step 50000
15:08:13:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:08:31:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:08:31:WU00:FS01:Trying to send results to collection server
15:08:31:WU00:FS01:Uploading 24.23MiB to 128.252.203.10
15:08:31:WU00:FS01:Connecting to 128.252.203.10:8080
15:09:06:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:10:04:WU02:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
15:11:26:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:17325 run:10 clone:482 gen:8 core:0x22 unit:0x000001e200000008000043ad0000000a
15:11:26:WU04:FS01:Uploading 12.33MiB to 140.163.4.200
15:11:26:WU04:FS01:Connecting to 140.163.4.200:8080
15:11:32:WU01:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
15:11:57:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:11:57:WU04:FS01:Trying to send results to collection server
15:11:57:WU04:FS01:Uploading 12.33MiB to 140.163.4.210
15:11:57:WU04:FS01:Connecting to 140.163.4.210:8080
15:11:58:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17433 run:0 clone:470 gen:21 core:0x22 unit:0x000001d6000000150000441900000000
15:11:58:WU00:FS01:Uploading 24.23MiB to 206.223.170.146
15:11:58:WU00:FS01:Connecting to 206.223.170.146:8080
15:12:04:WU00:FS01:Upload 69.91%
15:12:10:WU00:FS01:Upload 84.61%
15:12:27:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:12:45:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:12:45:WU00:FS01:Trying to send results to collection server
15:12:45:WU00:FS01:Uploading 24.23MiB to 128.252.203.10
15:12:45:WU00:FS01:Connecting to 128.252.203.10:8080
15:12:51:WU00:FS01:Upload 98.02%
15:12:58:WU02:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
15:13:21:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:14:57:WU01:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
15:14:59:WU01:FS01:0x22:Checkpoint completed at step 75000
15:15:50:WU02:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
15:18:18:WU04:FS01:Sending unit results: id:04 state:SEND error:NO_ERROR project:17325 run:10 clone:482 gen:8 core:0x22 unit:0x000001e200000008000043ad0000000a
15:18:18:WU04:FS01:Uploading 12.33MiB to 140.163.4.200
15:18:18:WU04:FS01:Connecting to 140.163.4.200:8080
15:18:25:WU01:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
15:18:41:WU02:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
15:18:48:WARNING:WU04:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:18:48:WU04:FS01:Trying to send results to collection server
15:18:48:WU04:FS01:Uploading 12.33MiB to 140.163.4.210
15:18:48:WU04:FS01:Connecting to 140.163.4.210:8080
15:18:50:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17433 run:0 clone:470 gen:21 core:0x22 unit:0x000001d6000000150000441900000000
15:18:50:WU00:FS01:Uploading 24.23MiB to 206.223.170.146
15:18:50:WU00:FS01:Connecting to 206.223.170.146:8080
15:18:56:WU00:FS01:Upload 66.55%
15:19:02:WU00:FS01:Upload 83.32%
15:19:08:WU00:FS01:Upload 98.02%
15:19:10:ERROR:WU04:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:19:39:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
15:19:39:WU00:FS01:Trying to send results to collection server
15:19:39:WU00:FS01:Uploading 24.23MiB to 128.252.203.10
15:19:39:WU00:FS01:Connecting to 128.252.203.10:8080
15:20:09:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:21:31:WU02:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
15:21:51:WU01:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
15:21:53:WU01:FS01:0x22:Checkpoint completed at step 100000
Sbafiox
Re: Server 128.252.203.10 Exception: 10002: Received short r
Yes, those servers have been reported having unresolved issues.
Whose firewall are you running? Will the results upload if you shut it off?
sbafiox
Post by sbafiox »
I do not think it is a firewall issue, as I am uploading to other FaH servers and have no problems at all.
I also clicked the link provided to check connectivity and the FaH page opened regularly
I have Kaspersky antivirus with firewall and a closed-source Router provided by my ISP (TIM) with very limited options to modify the default settings. Furthermore I am not so tech-savvy and have a very limited knowledge of how to change the settings.
However, I tried to open the specific slots in my router for these IP's, but nothing changed.
I think it would be wise to stop these servers from uploading Work Units until the problem is solved, as the energy required to run them goes wasted. I am not worried about my personal expense, which is negligeable to me (otherwise I would not be running FaH), but I think of the many thousands, if not hundreds of thousands or millions users who experience the same issue as I.
I guess this useless energy consumption is somewhat contrary to the spirit of FaH.
Sbafiox
RMCholewa
Hardware configuration: Lenovo Y540 Notebook with an Intel Core i7-9750H, nvidia RTX2060 Mobile amd 32GB RAM
Post by RMCholewa »
I am getting similiar behavior here, Kaspersky AV user too.
A few times it seems to work, most of the time it does not.
*********************** Log Started 2021-02-12T16:05:38Z ***********************
16:05:38:******************************* libFAH ********************************
16:05:38:           Date: Oct 20 2020
16:05:38:           Time: 13:36:55
16:05:38:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
16:05:38:         Branch: master
16:05:38:       Compiler: Visual C++ 2015
16:05:38:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:05:38:       Platform: win32 10
16:05:38:           Bits: 32
16:05:38:           Mode: Release
16:05:38:****************************** FAHClient ******************************
16:05:38:        Version: 7.6.21
16:05:38:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:05:38:      Copyright: 2020 foldingathome.org
16:05:38:       Homepage: https://foldingathome.org/
16:05:38:           Time: 13:41:04
16:05:38:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
16:05:38:           Bits: 32
16:05:38:         Config: C:\ProgramData\FAHClient\config.xml
16:05:38:******************************** CBang ********************************
16:05:38:           Time: 11:36:18
16:05:38:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
16:05:38:           Bits: 32
16:05:38:******************************* System ********************************
16:05:38:            CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
16:05:38:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
16:05:38:           CPUs: 12
16:05:38:         Memory: 31.88GiB
16:05:38:    Free Memory: 26.04GiB
16:05:38:        Threads: WINDOWS_THREADS
16:05:38:     OS Version: 6.2
16:05:38:    Has Battery: true
16:05:38:     On Battery: false
16:05:38:     UTC Offset: -3
16:05:38:            PID: 7044
16:05:38:            CWD: C:\ProgramData\FAHClient
16:05:38:  Win32 Service: false
16:05:38:             OS: Windows 10 Enterprise
16:05:38:        OS Arch: AMD64
16:05:38:           GPUs: 2
16:05:38:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106M [GeForce RTX 2060 Mobile]
16:05:38:                 4608
16:05:38:          GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 CFL GT2 [UHD Graphics 630]
16:05:38:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.2
16:05:38:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:460.89
16:05:38:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
16:05:38:***********************************************************************
16:05:38:<config>
16:05:38:  <!-- Network -->
16:05:38:  <proxy v=':8080'/>
16:05:38:
16:05:38:  <!-- Slot Control -->
16:05:38:  <power v='full'/>
16:05:38:
16:05:38:  <!-- User Information -->
16:05:38:  <passkey v='*****'/>
16:05:38:  <team v='NNNNNN'/>
16:05:38:  <user v='XXXXXXX'/>
16:05:38:
16:05:38:  <!-- Folding Slots -->
16:05:38:  <slot id='0' type='CPU'>
16:05:38:    <cpus v='4'/>
16:05:38:  </slot>
16:05:38:  <slot id='1' type='GPU'>
16:05:38:    <pci-bus v='1'/>
16:05:38:    <pci-slot v='0'/>
16:05:38:  </slot>
16:05:38:  <slot id='2' type='GPU'>
16:05:38:    <paused v='true'/>
16:05:38:    <pci-bus v='0'/>
16:05:38:    <pci-slot v='2'/>
16:05:38:  </slot>
16:05:38:</config>
16:05:38:Trying to access database...
16:05:38:Successfully acquired database lock
16:05:38:FS00:Initialized folding slot 00: cpu:4
16:05:38:FS01:Initialized folding slot 01: gpu:1:0 TU106M [GeForce RTX 2060 Mobile] 4608
16:05:38:WARNING:FS02:Guessing ambiguous GPU to OpenCL device mapping for 02: gpu:0:2 CFL GT2 [UHD Graphics 630].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
16:05:38:WARNING:FS02:Disabling beta GPU slot 02: gpu:0:2 CFL GT2 [UHD Graphics 630].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
16:05:38:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:17427 run:0 clone:1769 gen:139 core:0x22 unit:0x000006e90000008b0000441300000000
16:05:38:WU02:FS01:Uploading 17.91MiB to 206.223.170.146
16:05:38:WU02:FS01:Connecting to 206.223.170.146:8080
16:05:38:WU06:FS00:Sending unit results: id:06 state:SEND error:NO_ERROR project:17414 run:0 clone:93 gen:501 core:0xa7 unit:0x0000005d000001f50000440600000000
16:05:38:WU06:FS00:Uploading 9.95MiB to 66.170.111.50
16:05:38:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14561 run:0 clone:510 gen:9 core:0x22 unit:0x0000000d80fccb025f3305effc7b8457
16:05:38:WU06:FS00:Connecting to 66.170.111.50:8080
16:05:38:WU01:FS01:Uploading 42.81MiB to 128.252.203.2
16:05:38:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:17319 run:0 clone:1717 gen:55 core:0x22 unit:0x000006b500000037000043a700000000
16:05:38:WU01:FS01:Connecting to 128.252.203.2:8080
16:05:38:WU03:FS01:Uploading 26.80MiB to 140.163.4.200
16:05:38:WU03:FS01:Connecting to 140.163.4.200:8080
16:05:38:WU07:FS00:Starting
16:05:38:WU07:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 07 -suffix 01 -version 706 -lifeline 7044 -checkpoint 15 -np 4
16:05:38:WU07:FS00:Started FahCore on PID 22328
16:05:40:WU07:FS00:Core PID:12472
16:05:40:WU07:FS00:FahCore 0xa7 started
16:05:40:WU00:FS01:Starting
16:05:40:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 7044 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
16:05:40:WU00:FS01:Started FahCore on PID 6968
16:05:40:WU07:FS00:0xa7:*********************** Log Started 2021-02-12T16:05:40Z ***********************
16:05:40:WU07:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:05:40:WU07:FS00:0xa7:       Type: 0xa7
16:05:40:WU07:FS00:0xa7:       Core: Gromacs
16:05:40:WU07:FS00:0xa7:       Args: -dir 07 -suffix 01 -version 706 -lifeline 22328 -checkpoint 15 -np
16:05:40:WU07:FS00:0xa7:             4
16:05:40:WU07:FS00:0xa7:************************************ CBang *************************************
16:05:40:WU07:FS00:0xa7:       Date: Nov 27 2019
16:05:40:WU07:FS00:0xa7:       Time: 03:40:09
16:05:40:WU07:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
16:05:40:WU07:FS00:0xa7:     Branch: master
16:05:40:WU07:FS00:0xa7:   Compiler: Visual C++ 2008
16:05:40:WU07:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:05:40:WU07:FS00:0xa7:   Platform: win32 10
16:05:40:WU07:FS00:0xa7:       Bits: 64
16:05:40:WU07:FS00:0xa7:       Mode: Release
16:05:40:WU07:FS00:0xa7:************************************ System ************************************
16:05:40:WU07:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
16:05:40:WU07:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
16:05:40:WU07:FS00:0xa7:       CPUs: 12
16:05:40:WU07:FS00:0xa7:     Memory: 31.88GiB
16:05:40:WU07:FS00:0xa7:Free Memory: 25.67GiB
16:05:40:WU07:FS00:0xa7:    Threads: WINDOWS_THREADS
16:05:40:WU07:FS00:0xa7: OS Version: 6.2
16:05:40:WU07:FS00:0xa7:Has Battery: true
16:05:40:WU07:FS00:0xa7: On Battery: false
16:05:40:WU07:FS00:0xa7: UTC Offset: -3
16:05:40:WU07:FS00:0xa7:        PID: 12472
16:05:40:WU07:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
16:05:40:WU07:FS00:0xa7:******************************** Build - libFAH ********************************
16:05:40:WU07:FS00:0xa7:    Version: 0.0.19
16:05:40:WU07:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:05:40:WU07:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:05:40:WU07:FS00:0xa7:   Homepage: https://foldingathome.org/
16:05:40:WU07:FS00:0xa7:       Date: Nov 25 2019
16:05:40:WU07:FS00:0xa7:       Time: 17:12:41
16:05:40:WU07:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
16:05:40:WU07:FS00:0xa7:************************************ Build *************************************
16:05:40:WU07:FS00:0xa7:       SIMD: avx_256
16:05:40:WU07:FS00:0xa7:********************************************************************************
16:05:40:WU07:FS00:0xa7:Project: 16927 (Run 19, Clone 509, Gen 108)
16:05:40:WU07:FS00:0xa7:Unit: 0x00000000000000000000000000000000
16:05:40:WU07:FS00:0xa7:Digital signatures verified
16:05:40:WU07:FS00:0xa7:Calling: mdrun -s frame108.tpr -o frame108.trr -cpi state.cpt -cpt 15 -nt 4
16:05:40:WU07:FS00:0xa7:Steps: first=54000000 total=500000
16:05:40:WU00:FS01:Core PID:2180
16:05:40:WU00:FS01:FahCore 0x22 started
16:05:41:WU00:FS01:0x22:*********************** Log Started 2021-02-12T16:05:41Z ***********************
16:05:41:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:05:41:WU00:FS01:0x22:       Core: Core22
16:05:41:WU00:FS01:0x22:       Type: 0x22
16:05:41:WU00:FS01:0x22:    Version: 0.0.13
16:05:41:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:05:41:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
16:05:41:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
16:05:41:WU00:FS01:0x22:       Date: Sep 19 2020
16:05:41:WU00:FS01:0x22:       Time: 02:35:58
16:05:41:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
16:05:41:WU00:FS01:0x22:     Branch: core22-0.0.13
16:05:41:WU00:FS01:0x22:   Compiler: Visual C++ 2015
16:05:41:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
16:05:41:WU00:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
16:05:41:WU00:FS01:0x22:   Platform: win32 10
16:05:41:WU00:FS01:0x22:       Bits: 64
16:05:41:WU00:FS01:0x22:       Mode: Release
16:05:41:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:05:41:WU00:FS01:0x22:             <peastman@stanford.edu>
16:05:41:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6968 -checkpoint 15
16:05:41:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
16:05:41:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
16:05:41:WU00:FS01:0x22:************************************ libFAH ************************************
16:05:41:WU00:FS01:0x22:       Date: Sep 7 2020
16:05:41:WU00:FS01:0x22:       Time: 19:09:56
16:05:41:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
16:05:41:WU00:FS01:0x22:     Branch: HEAD
16:05:41:WU00:FS01:0x22:************************************ CBang *************************************
16:05:41:WU00:FS01:0x22:       Time: 19:08:30
16:05:41:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
16:05:41:WU00:FS01:0x22:************************************ System ************************************
16:05:41:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
16:05:41:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
16:05:41:WU00:FS01:0x22:       CPUs: 12
16:05:41:WU00:FS01:0x22:     Memory: 31.88GiB
16:05:41:WU00:FS01:0x22:Free Memory: 25.55GiB
16:05:41:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
16:05:41:WU00:FS01:0x22: OS Version: 6.2
16:05:41:WU00:FS01:0x22:Has Battery: true
16:05:41:WU00:FS01:0x22: On Battery: false
16:05:41:WU00:FS01:0x22: UTC Offset: -3
16:05:41:WU00:FS01:0x22:        PID: 2180
16:05:41:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
16:05:41:WU00:FS01:0x22:************************************ OpenMM ************************************
16:05:41:WU00:FS01:0x22:   Revision: 189320d0
16:05:41:WU00:FS01:0x22:********************************************************************************
16:05:41:WU00:FS01:0x22:Project: 13440 (Run 2148, Clone 3, Gen 0)
16:05:41:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
16:05:41:WU00:FS01:0x22:Digital signatures verified
16:05:41:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:05:41:WU00:FS01:0x22:Version 0.0.13
16:05:41:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
16:05:41:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
16:05:41:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
16:05:41:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
16:05:42:WU00:FS01:0x22:There are 4 platforms available.
16:05:42:WU00:FS01:0x22:Platform 0: Reference
16:05:42:WU00:FS01:0x22:Platform 1: CPU
16:05:42:WU00:FS01:0x22:Platform 2: OpenCL
16:05:42:WU00:FS01:0x22:  opencl-device 0 specified
16:05:42:WU00:FS01:0x22:Platform 3: CUDA
16:05:42:WU00:FS01:0x22:  cuda-device 0 specified
16:05:42:WU07:FS00:0xa7:Completed 448461 out of 500000 steps (89%)
16:05:44:WU02:FS01:Upload 97.69%
16:05:44:WU06:FS00:Upload 27.65%
16:05:44:WU01:FS01:Upload 20.88%
16:05:44:WU03:FS01:Upload 40.12%
16:05:50:WU01:FS01:Upload 31.39%
16:05:50:WU06:FS00:Upload 51.53%
16:05:50:WU03:FS01:Upload 45.95%
16:05:56:WU01:FS01:Upload 40.44%
16:05:56:WU06:FS00:Upload 77.30%
16:05:56:WU03:FS01:Upload 55.74%
16:05:56:WU00:FS01:0x22:Attempting to create CUDA context:
16:05:56:WU00:FS01:0x22:  Configuring platform CUDA
16:06:02:WU01:FS01:Upload 48.76%
16:06:02:WU03:FS01:Upload 69.04%
16:06:02:WU00:FS01:0x22:  Using CUDA and gpu 0
16:06:02:WU00:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
16:06:07:WU06:FS00:Upload complete
16:06:08:WU01:FS01:Upload 59.86%
16:06:08:WU03:FS01:Upload 84.67%
16:06:08:WU06:FS00:Server responded WORK_ACK (400)
16:06:08:WU06:FS00:Final credit estimate, 1656.00 points
16:06:08:WU06:FS00:Cleaning up
16:06:12:WU02:FS01:Upload complete
16:06:12:WU02:FS01:Server responded WORK_ACK (400)
16:06:12:WU02:FS01:Final credit estimate, 81665.00 points
16:06:12:WU02:FS01:Cleaning up
16:06:14:WU03:FS01:Upload 94.93%
16:06:14:WU01:FS01:Upload 68.32%
16:06:20:WU03:FS01:Upload 99.13%
16:06:20:WU01:FS01:Upload 74.75%
16:06:26:WU01:FS01:Upload 82.78%
16:06:32:WU01:FS01:Upload 91.24%
16:06:51:WARNING:WU03:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
16:06:51:WU03:FS01:Trying to send results to collection server
16:06:51:WU03:FS01:Uploading 26.80MiB to 18.188.125.154
16:06:51:WU03:FS01:Connecting to 18.188.125.154:8080
16:06:57:WU03:FS01:Upload 56.91%
16:07:03:WU03:FS01:Upload 81.17%
16:07:07:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
16:07:08:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14561 run:0 clone:510 gen:9 core:0x22 unit:0x0000000d80fccb025f3305effc7b8457
16:07:08:WU01:FS01:Uploading 42.81MiB to 128.252.203.2
16:07:08:WU01:FS01:Connecting to 128.252.203.2:8080
16:07:14:WU01:FS01:Upload 18.25%
16:07:15:WU07:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
16:07:20:WU01:FS01:Upload 33.43%
16:07:26:WU01:FS01:Upload 48.32%
16:07:32:WU01:FS01:Upload 63.21%
16:07:37:ERROR:WU03:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
16:07:38:WU01:FS01:Upload 80.00%
16:07:38:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:17319 run:0 clone:1717 gen:55 core:0x22 unit:0x000006b500000037000043a700000000
16:07:38:WU03:FS01:Uploading 26.80MiB to 140.163.4.200
16:07:38:WU03:FS01:Connecting to 140.163.4.200:8080
16:07:44:WU03:FS01:Upload 12.13%
16:07:44:WU01:FS01:Upload 94.16%
16:07:50:WU03:FS01:Upload 29.39%
16:07:56:WU03:FS01:Upload 49.68%
16:08:01:WU00:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
16:08:02:WU03:FS01:Upload 67.17%
16:08:08:WU03:FS01:Upload 85.13%
16:08:14:WU03:FS01:Upload 99.13%
16:08:16:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
16:08:16:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14561 run:0 clone:510 gen:9 core:0x22 unit:0x0000000d80fccb025f3305effc7b8457
16:08:16:WU01:FS01:Uploading 42.81MiB to 128.252.203.2
16:08:17:WU01:FS01:Connecting to 128.252.203.2:8080
16:08:23:WU01:FS01:Upload 17.96%
16:08:29:WU01:FS01:Upload 34.02%
16:08:35:WU01:FS01:Upload 49.78%
16:08:41:WU01:FS01:Upload 63.80%
16:08:44:WARNING:WU03:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
16:08:44:WU03:FS01:Trying to send results to collection server
16:08:44:WU03:FS01:Uploading 26.80MiB to 18.188.125.154
16:08:44:WU03:FS01:Connecting to 18.188.125.154:8080
16:08:47:WU01:FS01:Upload 72.56%
16:08:50:WU03:FS01:Upload 9.10%
16:08:53:WU01:FS01:Upload 81.02%
16:08:56:WU03:FS01:Upload 19.83%
16:08:59:WU01:FS01:Upload 88.76%
16:09:02:WU03:FS01:Upload 32.19%
16:09:05:WU01:FS01:Upload 96.50%
16:09:08:WU03:FS01:Upload 43.85%
16:09:14:WU03:FS01:Upload 67.87%
16:09:20:WU03:FS01:Upload 92.36%
16:09:37:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
16:09:44:WU03:FS01:Upload complete
16:09:44:WU03:FS01:Server responded WORK_ACK (400)
16:09:44:WU03:FS01:Final credit estimate, 116443.00 points
16:09:44:WU03:FS01:Cleaning up
16:09:54:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14561 run:0 clone:510 gen:9 core:0x22 unit:0x0000000d80fccb025f3305effc7b8457
16:09:54:WU01:FS01:Uploading 42.81MiB to 128.252.203.2
16:09:54:WU01:FS01:Connecting to 128.252.203.2:8080
16:10:00:WU01:FS01:Upload 73.58%
16:10:02:WU00:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
16:10:06:WU01:FS01:Upload 83.21%
16:10:12:WU01:FS01:Upload 92.27%
16:10:47:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
All my CPU slots happen to be running WUs that use FAHCore_a8 instead of FAHCore_a7 so I can't really test your scenario here because my client is talking to different servers. Also, I do not use Kaspersky AV.
If you temporarily disable Kaspersky. does the upload work?
RMCholewa wrote:A few times it seems to work, most of the time it does not.
You mightsearch back in your log and check the specific servers on which it fails or works and see if there is a pattern.
gacuxz
Post by gacuxz »
Got stuck with 128.252.203.10 too. Same error message.
Post by Neil-B »
Just "Thinking Out Loud" ... not specifically responding as such to any post in this thread :)
One of the things to remember about av and firewalls is that different traffic (even just a different WU) to a different IP can have issue depending on how they are set up and various factors relating to network transmission even if the majority of other traffic is unaffected ... Even though it may not seem likely that a certain av or firewall is causing the issue it is sometimes worth checking ... When reports from a number of folders are all having issues with the same av or firewall and someone has tried turning it off (including simple inspection) and reported that this has fixed the issue - and then a few days later the issue resolves itself after an av update then this gives rise to those who have seen this happen raising it as a potential issue to cross of the list - and one that can usually be checked very much quicker than getting server issues resolved.
It is not people saying it is an av or firewall issue just that in the past there have been similar/identical cases where av or firewall has seemingly been the cause ... and it isn't about passing the buck/blame more a case of trying to check all options to find the quickest resolution.
Normally if a server is having issues lots of people report that server and it may be the case with this one ... but the "short message" style issue has as far as I have observed on the forums been a mixture of server, av/firewall, and ISP routing issues in the past so when I see these I mention av and firewall checks as something that might be worth doing :)
gunnarre
Post by gunnarre »
One way to test this could be to upload the WU via a cell phone link or some other alternative way. Disabling the firewall, Kaspersky AV (which often is a problem) or using an alternative network might also be something you need the permission of your employer to do, if it's a work computer.
(Remember that requiring written permission from your employer to run folding@home applies also to work computers that you have at home - you need permission form both the owner of the computer and the ones paying the power bill. When you're at home, you might be paying the power, but the computer might belong to your employer.)
gacuxz
Post by gacuxz »
Sorry, it was my Kaspersky Endpoint AV indeed - just disabled it and WU was almost instantly uploaded to two different servers which was stuck before. Had Kaspersky around 3 years and am folding for around an year, never had problems before. Kaspersky's Firewall was always disabled too so it misdirected me to check Kaspersky anyway and looks like it blocks connections using other tools than Firewall. Can't find anything in Kaspersky logs with particular FAH Collection server IP or FAH application. It may be a Kaspersky bug.
RMCholewa
Post by RMCholewa »
Hummm interesting behavior. I recently changed from Norton LifeLock do Kaspersky, exactly when I started seeing this. But there is a big but...
I also use a VPN (NordVPN) with killswitch on (and other configurations to enforce it).
I've noticed that while connected to a vpn server in Switzerland, WUs were not getting out (but downloads were ok).
Tested with servers in costa rica, mexico and chile and the WUs got uploaded. Maybe a restriction on the side of NordVPN, maybe a curious interaction between NordVPN and kaspersky (while using NordVPN and Norton LifeLock in the past, had no problems).
Post by Neil-B »
Think there may be a setting buried in the AV that allows for inspection even if firewall is off - but mine is a different vendor so just recalling something I think someone posted
Post by Neil-B »
sbafiox wrote:I do not think it is a firewall issue, as I am uploading to other FaH servers and have no problems at all.
As others have found (see above) Kaspersky is currently causing this issue for some folders (it doesn't necessarily impact all servers or all project wus - so being able to return some wus but not others doesn't give the av/firewall a free pass) ... If hundreds (let alone thousands or millions) of users were having this issue and it was a server side issue then I am sure something would be done ... from experience of what I am seeing on the support forms at the moment I would expect this to be impacting a relatively small number of folders (against the total pool) and since this issue appears at present to be AV/Firewall related it will probably be fixed in a vendor update (hopefully soon) ... until then someone with the relevant AV/Firewall may find a way to tweak the settings and report it here so it can be shared.
That isn't to say there is not a server issue - I am sure someone will be looking into it - but shutting down the servers when patently the vast majority of WUs sent out are being returned will not help the progress of science ... if this were impacting thousands or millions (there arent that many) folders then FaH would see the extremely low rate of successful returns and would react accordingly.
gacuxz
Post by gacuxz »
Today one of my WU's was uploaded to collection server with Kaspersky Endpoint enabled without any issues. So it's impacting not all servers or even same server but only sometimes. Will investigate this when my other WU will be stuck.
Post by Neil-B »
This is to expected given the way most av and firewalls work nowadays .. you may find that after a while your av with either learn to let the wus through or be patched by the vendor and the issue goes away
