Progress decreases and gets stuck at 99.99%
dszimmerman
Post by dszimmerman »
Hi,
I am new to Folding@Home, and I am excited to participate toward this great project.
I have been folding a WU over the past two days, but the progress keeps fluctuating. It will go up to 30% and then suddenly decrease to 9% (without me closing or touching the program). Occasionally, the progress will reach 99.99% and stay there. I have attached the log for reference. If it's of any use, I'm running Ubuntu 64 bit with an Intel Celeron CPU N3050 @ 1.60GHz x 2 processor and an Intel HD Graphics 400. Thank you for your help and for supporting this project!
*********************** Log Started 2021-02-06T01:44:37Z ***********************
01:44:37:******************************* libFAH ********************************
01:44:37:       Date: Oct 20 2020
01:44:37:       Time: 20:36:39
01:44:37:   Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
01:44:37:     Branch: master
01:44:37:   Compiler: GNU 8.3.0
01:44:37:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
01:44:37:             -fdata-sections -O3 -funroll-loops -fno-pie
01:44:37:   Platform: linux2 5.8.0-1-amd64
01:44:37:       Bits: 64
01:44:37:       Mode: Release
01:44:37:****************************** FAHClient ******************************
01:44:37:    Version: 7.6.21
01:44:37:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:44:37:  Copyright: 2020 foldingathome.org
01:44:37:   Homepage: https://foldingathome.org/
01:44:37:       Time: 20:39:00
01:44:37:   Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
01:44:37:       Bits: 64
01:44:37:       Args: --child /etc/fahclient/config.xml --run-as fahclient
01:44:37:             --pid-file=/var/run/fahclient.pid --daemon
01:44:37:     Config: /etc/fahclient/config.xml
01:44:37:******************************** CBang ********************************
01:44:37:       Time: 18:37:59
01:44:37:   Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
01:44:37:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
01:44:37:       Bits: 64
01:44:37:******************************* System ********************************
01:44:37:        CPU: Intel(R) Celeron(R) CPU N3050 @ 1.60GHz
01:44:37:     CPU ID: GenuineIntel Family 6 Model 76 Stepping 3
01:44:37:       CPUs: 2
01:44:37:     Memory: 3.76GiB
01:44:37:Free Memory: 3.15GiB
01:44:37:    Threads: POSIX_THREADS
01:44:37: OS Version: 5.4
01:44:37:Has Battery: false
01:44:37: On Battery: false
01:44:37: UTC Offset: -8
01:44:37:        PID: 1294
01:44:37:        CWD: /var/lib/fahclient
01:44:37:         OS: Linux 5.4.0-65-generic x86_64
01:44:37:    OS Arch: AMD64
01:44:37:       GPUs: 0
01:44:37:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
01:44:37:             libcuda.so: cannot open shared object file: No such file or
01:44:37:             directory
01:44:37:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
01:44:37:             libOpenCL.so: cannot open shared object file: No such file or
01:44:37:             directory
01:44:37:***********************************************************************
01:44:37:<config>
01:44:37:  <!-- Client Control -->
01:44:37:  <fold-anon v='true'/>
01:44:37:
01:44:37:  <!-- Folding Core -->
01:44:37:  <checkpoint v='5'/>
01:44:37:
01:44:37:  <!-- Folding Slot Configuration -->
01:44:37:  <cause v='HIGH_PRIORITY'/>
01:44:37:  <gpu v='false'/>
01:44:37:
01:44:37:  <!-- Network -->
01:44:37:  <proxy v=':8080'/>
01:44:37:
01:44:37:  <!-- Slot Control -->
01:44:37:  <power v='full'/>
01:44:37:
01:44:37:  <!-- User Information -->
01:44:37:  <team v='228216'/>
01:44:37:  <user v='DanDan'/>
01:44:37:
01:44:37:  <!-- Folding Slots -->
01:44:37:  <slot id='0' type='CPU'/>
01:44:37:</config>
01:44:37:Trying to access database...
01:44:37:Successfully acquired database lock
01:44:37:FS00:Initialized folding slot 00: cpu:2
01:44:37:WU00:FS00:Starting
01:44:37:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
01:44:37:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 1294 -checkpoint 5 -np 1
01:44:37:WU00:FS00:Started FahCore on PID 1313
01:44:37:WU00:FS00:Core PID:1317
01:44:37:WU00:FS00:FahCore 0xa7 started
01:44:38:WU00:FS00:0xa7:*********************** Log Started 2021-02-06T01:44:37Z ***********************
01:44:38:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:44:38:WU00:FS00:0xa7:       Type: 0xa7
01:44:38:WU00:FS00:0xa7:       Core: Gromacs
01:44:38:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1313 -checkpoint 5 -np 1
01:44:38:WU00:FS00:0xa7:************************************ CBang *************************************
01:44:38:WU00:FS00:0xa7:       Date: Nov 27 2019
01:44:38:WU00:FS00:0xa7:       Time: 11:26:54
01:44:38:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
01:44:38:WU00:FS00:0xa7:     Branch: master
01:44:38:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
01:44:38:WU00:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
01:44:38:WU00:FS00:0xa7:             -fno-pie -fPIC
01:44:38:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
01:44:38:WU00:FS00:0xa7:       Bits: 64
01:44:38:WU00:FS00:0xa7:       Mode: Release
01:44:38:WU00:FS00:0xa7:************************************ System ************************************
01:44:38:WU00:FS00:0xa7:        CPU: Intel(R) Celeron(R) CPU N3050 @ 1.60GHz
01:44:38:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 76 Stepping 3
01:44:38:WU00:FS00:0xa7:       CPUs: 2
01:44:38:WU00:FS00:0xa7:     Memory: 3.76GiB
01:44:38:WU00:FS00:0xa7:Free Memory: 3.15GiB
01:44:38:WU00:FS00:0xa7:    Threads: POSIX_THREADS
01:44:38:WU00:FS00:0xa7: OS Version: 5.4
01:44:38:WU00:FS00:0xa7:Has Battery: false
01:44:38:WU00:FS00:0xa7: On Battery: false
01:44:38:WU00:FS00:0xa7: UTC Offset: -8
01:44:38:WU00:FS00:0xa7:        PID: 1317
01:44:38:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
01:44:38:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
01:44:38:WU00:FS00:0xa7:    Version: 0.0.19
01:44:38:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:44:38:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
01:44:38:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
01:44:38:WU00:FS00:0xa7:       Date: Nov 26 2019
01:44:38:WU00:FS00:0xa7:       Time: 00:41:43
01:44:38:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
01:44:38:WU00:FS00:0xa7:************************************ Build *************************************
01:44:38:WU00:FS00:0xa7:       SIMD: sse2
01:44:38:WU00:FS00:0xa7:********************************************************************************
01:44:38:WU00:FS00:0xa7:Project: 16927 (Run 5, Clone 940, Gen 93)
01:44:38:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
01:44:38:WU00:FS00:0xa7:Digital signatures verified
01:44:38:WU00:FS00:0xa7:Calling: mdrun -s frame93.tpr -o frame93.trr -cpi state.cpt -cpt 5 -nt 1
01:44:41:WU00:FS00:0xa7:Steps: first=46500000 total=500000
01:44:44:WU00:FS00:0xa7:Completed 84961 out of 500000 steps (16%)
01:45:31:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
03:19:58:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
04:14:04:Removing old file 'configs/config-20210205-003544.xml'
04:14:04:Saving configuration to /etc/fahclient/config.xml
04:14:04:<config>
04:14:04:  <!-- Client Control -->
04:14:04:  <fold-anon v='true'/>
04:14:04:
04:14:04:  <!-- Folding Core -->
04:14:04:  <checkpoint v='5'/>
04:14:04:
04:14:04:  <!-- Folding Slot Configuration -->
04:14:04:  <cause v='HIGH_PRIORITY'/>
04:14:04:  <gpu v='false'/>
04:14:04:
04:14:04:  <!-- Network -->
04:14:04:  <proxy v=':8080'/>
04:14:04:
04:14:04:  <!-- Slot Control -->
04:14:04:  <power v='full'/>
04:14:04:
04:14:04:  <!-- User Information -->
04:14:04:  <team v='228216'/>
04:14:04:  <user v='DanDanDan'/>
04:14:04:
04:14:04:  <!-- Folding Slots -->
04:14:04:  <slot id='0' type='CPU'/>
04:14:04:</config>
04:15:05:Removing old file 'configs/config-20210205-004049.xml'
04:15:05:Saving configuration to /etc/fahclient/config.xml
04:15:05:<config>
04:15:05:  <!-- Client Control -->
04:15:05:  <fold-anon v='true'/>
04:15:05:
04:15:05:  <!-- Folding Core -->
04:15:05:  <checkpoint v='5'/>
04:15:05:
04:15:05:  <!-- Folding Slot Configuration -->
04:15:05:  <cause v='HIGH_PRIORITY'/>
04:15:05:  <gpu v='false'/>
04:15:05:
04:15:05:  <!-- Network -->
04:15:05:  <proxy v=':8080'/>
04:15:05:
04:15:05:  <!-- Slot Control -->
04:15:05:  <power v='full'/>
04:15:05:
04:15:05:  <!-- User Information -->
04:15:05:  <team v='228216'/>
04:15:05:  <user v='DanZDanZ'/>
04:15:05:
04:15:05:  <!-- Folding Slots -->
04:15:05:  <slot id='0' type='CPU'/>
04:15:05:</config>
04:33:33:FS00:Paused
04:33:33:FS00:Shutting core down
04:33:33:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 1317
04:33:33:WU00:FS00:0xa7:Exiting, please wait. . .
04:33:57:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:34:24:Removing old file 'configs/config-20210205-004352.xml'
04:34:24:Saving configuration to /etc/fahclient/config.xml
04:34:24:<config>
04:34:24:  <!-- Client Control -->
04:34:24:  <fold-anon v='true'/>
04:34:24:
04:34:24:  <!-- Folding Core -->
04:34:24:  <checkpoint v='5'/>
04:34:24:
04:34:24:  <!-- Folding Slot Configuration -->
04:34:24:  <cause v='HIGH_PRIORITY'/>
04:34:24:  <gpu v='false'/>
04:34:24:
04:34:24:  <!-- Network -->
04:34:24:  <proxy v=':8080'/>
04:34:24:
04:34:24:  <!-- Slot Control -->
04:34:24:  <power v='full'/>
04:34:24:
04:34:24:  <!-- User Information -->
04:34:24:  <team v='228216'/>
04:34:24:  <user v='DanZDanZ'/>
04:34:24:
04:34:24:  <!-- Folding Slots -->
04:34:24:  <slot id='0' type='CPU'>
04:34:24:    <paused v='true'/>
04:34:24:  </slot>
04:34:24:</config>
04:34:36:FS00:Unpaused
04:34:36:WU00:FS00:Starting
04:34:36:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
04:34:36:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 1294 -checkpoint 5 -np 1
04:34:36:WU00:FS00:Started FahCore on PID 6824
04:34:37:WU00:FS00:Core PID:6828
04:34:37:WU00:FS00:FahCore 0xa7 started
04:34:37:WU00:FS00:0xa7:*********************** Log Started 2021-02-06T04:34:37Z ***********************
04:34:37:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:34:37:WU00:FS00:0xa7:       Type: 0xa7
04:34:37:WU00:FS00:0xa7:       Core: Gromacs
04:34:37:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6824 -checkpoint 5 -np 1
04:34:37:WU00:FS00:0xa7:************************************ CBang *************************************
04:34:37:WU00:FS00:0xa7:       Date: Nov 27 2019
04:34:37:WU00:FS00:0xa7:       Time: 11:26:54
04:34:37:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
04:34:37:WU00:FS00:0xa7:     Branch: master
04:34:37:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
04:34:37:WU00:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
04:34:37:WU00:FS00:0xa7:             -fno-pie -fPIC
04:34:37:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
04:34:37:WU00:FS00:0xa7:       Bits: 64
04:34:37:WU00:FS00:0xa7:       Mode: Release
04:34:37:WU00:FS00:0xa7:************************************ System ************************************
04:34:37:WU00:FS00:0xa7:        CPU: Intel(R) Celeron(R) CPU N3050 @ 1.60GHz
04:34:37:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 76 Stepping 3
04:34:37:WU00:FS00:0xa7:       CPUs: 2
04:34:37:WU00:FS00:0xa7:     Memory: 3.76GiB
04:34:37:WU00:FS00:0xa7:Free Memory: 1.06GiB
04:34:37:WU00:FS00:0xa7:    Threads: POSIX_THREADS
04:34:37:WU00:FS00:0xa7: OS Version: 5.4
04:34:37:WU00:FS00:0xa7:Has Battery: false
04:34:37:WU00:FS00:0xa7: On Battery: false
04:34:37:WU00:FS00:0xa7: UTC Offset: -8
04:34:37:WU00:FS00:0xa7:        PID: 6828
04:34:37:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
04:34:37:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
04:34:37:WU00:FS00:0xa7:    Version: 0.0.19
04:34:37:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:34:37:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
04:34:37:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
04:34:37:WU00:FS00:0xa7:       Date: Nov 26 2019
04:34:37:WU00:FS00:0xa7:       Time: 00:41:43
04:34:37:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
04:34:37:WU00:FS00:0xa7:************************************ Build *************************************
04:34:37:WU00:FS00:0xa7:       SIMD: sse2
04:34:37:WU00:FS00:0xa7:********************************************************************************
04:34:37:WU00:FS00:0xa7:Project: 16927 (Run 5, Clone 940, Gen 93)
04:34:37:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
04:34:37:WU00:FS00:0xa7:Digital signatures verified
04:34:37:WU00:FS00:0xa7:Calling: mdrun -s frame93.tpr -o frame93.trr -cpi state.cpt -cpt 5 -nt 1
04:34:38:WU00:FS00:0xa7:Steps: first=46500000 total=500000
04:34:42:WU00:FS00:0xa7:Completed 93922 out of 500000 steps (18%)
04:35:25:Removing old file 'configs/config-20210205-005059.xml'
04:35:25:Saving configuration to /etc/fahclient/config.xml
04:35:25:<config>
04:35:25:  <!-- Client Control -->
04:35:25:  <fold-anon v='true'/>
04:35:25:
04:35:25:  <!-- Folding Core -->
04:35:25:  <checkpoint v='5'/>
04:35:25:
04:35:25:  <!-- Folding Slot Configuration -->
04:35:25:  <cause v='HIGH_PRIORITY'/>
04:35:25:  <gpu v='false'/>
04:35:25:
04:35:25:  <!-- Network -->
04:35:25:  <proxy v=':8080'/>
04:35:25:
04:35:25:  <!-- Slot Control -->
04:35:25:  <power v='full'/>
04:35:25:
04:35:25:  <!-- User Information -->
04:35:25:  <team v='228216'/>
04:35:25:  <user v='DanZDanZ'/>
04:35:25:
04:35:25:  <!-- Folding Slots -->
04:35:25:  <slot id='0' type='CPU'/>
04:35:25:</config>
04:54:29:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
Re: Progress decreases and gets stuck at 99.99%
Welcome to Folding@Home.
Sadly the N3050 is not going to have much performance in F@H.
https://en.wikichip.org/wiki/intel/celeron/n3050
It lacks several 'modern' Floating Point Math features. Currently AVX offers twice the speed of SSE2, and AVX2 offers 60% more speed than AVX.
Despite being recent, your CPU lacks AVX and AVX2, so must use the much weaker, older SSE2 code.
https://en.wikipedia.org/wiki/SSE2
https://en.wikipedia.org/wiki/Advanced_ ... Extensions
While your N3050 is a dual core part, F@H keeps turning it down to a single core
This says that your checkpoint interval is 5% so if your CPU has an error, F@H may drop back by 5% and try again, so you can see 'reverses' in the forward progress.
(it also shows the number of threads as 1)
It's difficult to diagnose your system from what you've posted.
With a processor as old as your Celeron, I'd guess that you've experienced an overheating condition. Dust has problably accumulated on the fins of the heatsink, degrading it's ability to keep a busy CPU from overheating. The thermal paste under the heatsink may also have degraded over the years.
In fact, there once was an error that interrupted processing at about 9% and it's not really progressing beyond that point. The software that reports progress between checkpoints continues reporting progress when, in fact, no progress is being made ... up to 99.99% where it suddenly figures out that it can't go past 100%.
We can't tell if you've gotten a bad WU, or if it's thermally limited. I would dump the WU to rule out the former and/or figure out how to improve your CPU's cooling.
dszimmerman
Thanks for the advice and suggestions. I'll try these and see if it helps! Thanks.
