"Duplicate UserName", Missing Points
SQLG0d
Post by SQLG0d »
I set up a new machine for folding and some how wound up with my username associated with the FAH install, but not the groupname I have been using. Now I see about 3.6 M points on FAH associated with a second entry for my username and then my "main" username/groupname shows as a separate line (the top one) with 700M+ points.
Is there any way I can get those points aggregated into my "main" username entry? Thanks in advance!
Oh, my username is TheSQLGuru
Re: "Duplicate UserName", Missing Points
FAH will not modify the stats once they've been added to the database. All points are credited by scripts which collect reports from various Work Servers of recently returned results. Those returned results include the information about the WU and your name/team/passskey that your local copy of FHClient knows about you. If you failed to correctly configure your local client, you only have yourself to blame and it will not be corrected.
Usernames are not unique. Your passkey is.
