domain decomposition Error:Project: 17324
Forcinghavok
Post by Forcinghavok »
Tons of errors or warnings in the code below. I highlighted some of them in red. What is going on? Thank you.
ps. i guess none of it is in red, lol. not sure why that didn't work either.
*********************** Log Started 2021-02-02T22:39:33Z ***********************
22:39:33:******************************* libFAH ********************************
22:39:33:           Date: Oct 20 2020
22:39:33:           Time: 13:36:55
22:39:33:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
22:39:33:         Branch: master
22:39:33:       Compiler: Visual C++ 2015
22:39:33:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:39:33:       Platform: win32 10
22:39:33:           Bits: 32
22:39:33:           Mode: Release
22:39:33:****************************** FAHClient ******************************
22:39:33:        Version: 7.6.21
22:39:33:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:39:33:      Copyright: 2020 foldingathome.org
22:39:33:       Homepage: https://foldingathome.org/
22:39:33:           Time: 13:41:04
22:39:33:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
22:39:33:           Bits: 32
22:39:33:         Config: C:\ProgramData\FAHClient\config.xml
22:39:33:******************************** CBang ********************************
22:39:33:           Time: 11:36:18
22:39:33:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
22:39:33:           Bits: 32
22:39:33:******************************* System ********************************
22:39:33:            CPU: AMD FX(tm)-8350 Eight-Core Processor
22:39:33:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
22:39:33:           CPUs: 8
22:39:33:         Memory: 15.90GiB
22:39:33:    Free Memory: 13.25GiB
22:39:33:        Threads: WINDOWS_THREADS
22:39:33:     OS Version: 6.2
22:39:33:    Has Battery: false
22:39:33:     On Battery: false
22:39:33:     UTC Offset: -5
22:39:33:            PID: 9940
22:39:33:            CWD: C:\ProgramData\FAHClient
22:39:33:  Win32 Service: false
22:39:33:             OS: Windows 10 Home
22:39:33:        OS Arch: AMD64
22:39:33:           GPUs: 1
22:39:33:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
22:39:33:                 470/480/570/580/590]
22:39:33:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:39:33:                 specified module could not be found.
22:39:33:
22:39:33:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3188.4
22:39:33:***********************************************************************
22:39:33:<config>
22:39:33:  <!-- Network -->
22:39:33:  <proxy v=':8080'/>
22:39:33:
22:39:33:  <!-- Slot Control -->
22:39:33:  <power v='full'/>
22:39:33:
22:39:33:  <!-- User Information -->
22:39:33:  <team v='2092'/>
22:39:33:  <user v='forcinghavok'/>
22:39:33:
22:39:33:  <!-- Folding Slots -->
22:39:33:  <slot id='0' type='CPU'>
22:39:33:    <cpus v='4'/>
22:39:33:  </slot>
22:39:33:  <slot id='1' type='GPU'>
22:39:33:    <pci-bus v='1'/>
22:39:33:    <pci-slot v='0'/>
22:39:33:  </slot>
22:39:33:</config>
22:39:33:Trying to access database...
22:39:33:Successfully acquired database lock
22:39:33:FS00:Initialized folding slot 00: cpu:4
22:39:33:FS01:Initialized folding slot 01: gpu:1:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
22:39:33:WU02:FS00:Starting
22:39:33:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 9940 -checkpoint 15 -np 4
22:39:33:WU02:FS00:Started FahCore on PID 9548
22:39:33:WU02:FS00:Core PID:9700
22:39:33:WU02:FS00:FahCore 0xa7 started
22:39:35:WU01:FS01:Starting
22:39:35:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9940 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
22:39:35:WU01:FS01:Started FahCore on PID 7944
22:39:37:WU02:FS00:0xa7:*********************** Log Started 2021-02-02T22:39:36Z ***********************
22:39:37:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:39:37:WU02:FS00:0xa7:       Type: 0xa7
22:39:37:WU02:FS00:0xa7:       Core: Gromacs
22:39:37:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9548 -checkpoint 15 -np 4
22:39:37:WU02:FS00:0xa7:************************************ CBang *************************************
22:39:37:WU02:FS00:0xa7:       Date: Nov 27 2019
22:39:37:WU02:FS00:0xa7:       Time: 03:40:09
22:39:37:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:39:37:WU02:FS00:0xa7:     Branch: master
22:39:37:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
22:39:37:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:39:37:WU02:FS00:0xa7:   Platform: win32 10
22:39:37:WU02:FS00:0xa7:       Bits: 64
22:39:37:WU02:FS00:0xa7:       Mode: Release
22:39:37:WU02:FS00:0xa7:************************************ System ************************************
22:39:37:WU02:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
22:39:37:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
22:39:37:WU02:FS00:0xa7:       CPUs: 8
22:39:37:WU02:FS00:0xa7:     Memory: 15.90GiB
22:39:37:WU02:FS00:0xa7:Free Memory: 13.18GiB
22:39:37:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
22:39:37:WU02:FS00:0xa7: OS Version: 6.2
22:39:37:WU02:FS00:0xa7:Has Battery: false
22:39:37:WU02:FS00:0xa7: On Battery: false
22:39:37:WU02:FS00:0xa7: UTC Offset: -5
22:39:37:WU02:FS00:0xa7:        PID: 9700
22:39:37:WU02:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
22:39:37:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
22:39:37:WU02:FS00:0xa7:    Version: 0.0.19
22:39:37:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:39:37:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:39:37:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
22:39:37:WU02:FS00:0xa7:       Date: Nov 25 2019
22:39:37:WU02:FS00:0xa7:       Time: 17:12:41
22:39:37:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:39:37:WU02:FS00:0xa7:************************************ Build *************************************
22:39:37:WU02:FS00:0xa7:       SIMD: avx_256
22:39:37:WU02:FS00:0xa7:********************************************************************************
22:39:37:WU02:FS00:0xa7:Project: 14188 (Run 3, Clone 362, Gen 1)
22:39:37:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
22:39:37:WU02:FS00:0xa7:Digital signatures verified
22:39:37:WU02:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 4
22:39:37:WU02:FS00:0xa7:Steps: first=1250000 total=1250000
22:39:38:WU02:FS00:0xa7:Completed 1 out of 1250000 steps (0%)
22:39:38:WU01:FS01:Core PID:10172
22:39:38:WU01:FS01:FahCore 0x22 started
22:39:42:WU01:FS01:0x22:*********************** Log Started 2021-02-02T22:39:42Z ***********************
22:39:42:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:39:42:WU01:FS01:0x22:       Core: Core22
22:39:42:WU01:FS01:0x22:       Type: 0x22
22:39:42:WU01:FS01:0x22:    Version: 0.0.13
22:39:42:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:39:42:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
22:39:42:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
22:39:42:WU01:FS01:0x22:       Date: Sep 19 2020
22:39:42:WU01:FS01:0x22:       Time: 02:35:58
22:39:42:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
22:39:42:WU01:FS01:0x22:     Branch: core22-0.0.13
22:39:42:WU01:FS01:0x22:   Compiler: Visual C++ 2015
22:39:42:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
22:39:42:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
22:39:42:WU01:FS01:0x22:   Platform: win32 10
22:39:42:WU01:FS01:0x22:       Bits: 64
22:39:42:WU01:FS01:0x22:       Mode: Release
22:39:42:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:39:42:WU01:FS01:0x22:             <peastman@stanford.edu>
22:39:42:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7944 -checkpoint 15
22:39:42:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
22:39:42:WU01:FS01:0x22:             -gpu-usage 100
22:39:42:WU01:FS01:0x22:************************************ libFAH ************************************
22:39:42:WU01:FS01:0x22:       Date: Sep 7 2020
22:39:42:WU01:FS01:0x22:       Time: 19:09:56
22:39:42:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
22:39:42:WU01:FS01:0x22:     Branch: HEAD
22:39:42:WU01:FS01:0x22:************************************ CBang *************************************
22:39:42:WU01:FS01:0x22:       Time: 19:08:30
22:39:42:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
22:39:42:WU01:FS01:0x22:************************************ System ************************************
22:39:42:WU01:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
22:39:42:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
22:39:42:WU01:FS01:0x22:       CPUs: 8
22:39:42:WU01:FS01:0x22:     Memory: 15.90GiB
22:39:42:WU01:FS01:0x22:Free Memory: 13.02GiB
22:39:42:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
22:39:42:WU01:FS01:0x22: OS Version: 6.2
22:39:42:WU01:FS01:0x22:Has Battery: false
22:39:42:WU01:FS01:0x22: On Battery: false
22:39:42:WU01:FS01:0x22: UTC Offset: -5
22:39:42:WU01:FS01:0x22:        PID: 10172
22:39:42:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
22:39:42:WU01:FS01:0x22:************************************ OpenMM ************************************
22:39:42:WU01:FS01:0x22:   Revision: 189320d0
22:39:42:WU01:FS01:0x22:********************************************************************************
22:39:42:WU01:FS01:0x22:Project: 17316 (Run 0, Clone 1890, Gen 81)
22:39:42:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
22:39:42:WU01:FS01:0x22:Digital signatures verified
22:39:42:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:39:42:WU01:FS01:0x22:Version 0.0.13
22:39:42:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
22:39:42:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
22:39:42:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (20%) [5 total]
22:39:42:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
22:39:43:WU01:FS01:0x22:There are 3 platforms available.
22:39:43:WU01:FS01:0x22:Platform 0: Reference
22:39:43:WU01:FS01:0x22:Platform 1: CPU
22:39:43:WU01:FS01:0x22:Platform 2: OpenCL
22:39:43:WU01:FS01:0x22:  opencl-device 0 specified
22:40:07:WU01:FS01:0x22:Attempting to create OpenCL context:
22:40:07:WU01:FS01:0x22:  Configuring platform OpenCL
22:40:28:WU01:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
22:40:30:WU01:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
22:44:53:WU01:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
22:49:16:WU01:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
22:49:24:WU01:FS01:0x22:Checkpoint completed at step 525000
[color=#FF0000]22:50:57:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.[/color]
22:53:46:WU01:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
22:58:08:WU01:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
22:58:10:WU01:FS01:0x22:Checkpoint completed at step 550000
23:02:36:WU01:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
23:07:00:WU01:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
23:07:02:WU01:FS01:0x22:Checkpoint completed at step 575000
[color=#FF0000]23:08:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:09:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.[/color]
02:12:29:WU01:FS01:0x22:Checkpoint completed at step 1100000
03:01:11:WU00:FS01:Assigned to work server 206.223.170.146
03:01:11:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 206.223.170.146
03:01:11:WU00:FS01:Connecting to 206.223.170.146:8080
03:01:11:WU00:FS01:Downloading 13.75MiB
03:01:13:WU00:FS01:Download complete
03:01:14:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17432 run:0 clone:1434 gen:65 core:0x22 unit:0x0000059a000000410000441800000000
03:05:33:WU01:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
03:05:33:WU01:FS01:0x22:Average performance: 163.636 ns/day
03:05:36:WU01:FS01:0x22:Checkpoint completed at step 1250000
03:05:59:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
03:05:59:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
03:05:59:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
03:05:59:WU01:FS01:0x22:Saving result file positions.xtc
03:05:59:WU01:FS01:0x22:Saving result file science.log
03:05:59:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
03:06:00:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:06:00:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17316 run:0 clone:1890 gen:81 core:0x22 unit:0x0000076200000051000043a400000000
03:06:00:WU01:FS01:Uploading 17.25MiB to 140.163.4.200
03:06:00:WU01:FS01:Connecting to 140.163.4.200:8080
03:06:00:WU00:FS01:Starting
03:06:00:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 9940 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
03:06:00:WU00:FS01:Started FahCore on PID 260
03:06:01:WU00:FS01:Core PID:6404
03:06:01:WU00:FS01:FahCore 0x22 started
03:06:02:WU00:FS01:0x22:*********************** Log Started 2021-02-03T03:06:01Z ***********************
03:06:02:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:06:02:WU00:FS01:0x22:       Core: Core22
03:06:02:WU00:FS01:0x22:       Type: 0x22
03:06:02:WU00:FS01:0x22:    Version: 0.0.13
03:06:02:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:06:02:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
03:06:02:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
03:06:02:WU00:FS01:0x22:       Date: Sep 19 2020
03:06:02:WU00:FS01:0x22:       Time: 02:35:58
03:06:02:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
03:06:02:WU00:FS01:0x22:     Branch: core22-0.0.13
03:06:02:WU00:FS01:0x22:   Compiler: Visual C++ 2015
03:06:02:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
03:06:02:WU00:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
03:06:02:WU00:FS01:0x22:   Platform: win32 10
03:06:02:WU00:FS01:0x22:       Bits: 64
03:06:02:WU00:FS01:0x22:       Mode: Release
03:06:02:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
03:06:02:WU00:FS01:0x22:             <peastman@stanford.edu>
03:06:02:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 260 -checkpoint 15
03:06:02:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
03:06:02:WU00:FS01:0x22:             -gpu-usage 100
03:06:02:WU00:FS01:0x22:************************************ libFAH ************************************
03:06:02:WU00:FS01:0x22:       Date: Sep 7 2020
03:06:02:WU00:FS01:0x22:       Time: 19:09:56
03:06:02:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
03:06:02:WU00:FS01:0x22:     Branch: HEAD
03:06:02:WU00:FS01:0x22:************************************ CBang *************************************
03:06:02:WU00:FS01:0x22:       Time: 19:08:30
03:06:02:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
03:06:02:WU00:FS01:0x22:************************************ System ************************************
03:06:02:WU00:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
03:06:02:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
03:06:02:WU00:FS01:0x22:       CPUs: 8
03:06:02:WU00:FS01:0x22:     Memory: 15.90GiB
03:06:02:WU00:FS01:0x22:Free Memory: 12.28GiB
03:06:02:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
03:06:02:WU00:FS01:0x22: OS Version: 6.2
03:06:02:WU00:FS01:0x22:Has Battery: false
03:06:02:WU00:FS01:0x22: On Battery: false
03:06:02:WU00:FS01:0x22: UTC Offset: -5
03:06:02:WU00:FS01:0x22:        PID: 6404
03:06:02:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
03:06:02:WU00:FS01:0x22:************************************ OpenMM ************************************
03:06:02:WU00:FS01:0x22:   Revision: 189320d0
03:06:02:WU00:FS01:0x22:********************************************************************************
03:06:02:WU00:FS01:0x22:Project: 17432 (Run 0, Clone 1434, Gen 65)
03:06:02:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
03:06:02:WU00:FS01:0x22:Reading tar file core.xml
03:06:02:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
03:06:02:WU00:FS01:0x22:Reading tar file state.xml.bz2
03:06:02:WU00:FS01:0x22:Reading tar file system.xml.bz2
03:06:02:WU00:FS01:0x22:Digital signatures verified
03:06:02:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:06:02:WU00:FS01:0x22:Version 0.0.13
03:06:04:WU00:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
03:06:04:WU00:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
03:06:04:WU00:FS01:0x22:  XTC frame write interval: 10000 steps (0.8%) [125 total]
03:06:04:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
03:06:05:WU00:FS01:0x22:There are 3 platforms available.
03:06:05:WU00:FS01:0x22:Platform 0: Reference
03:06:05:WU00:FS01:0x22:Platform 1: CPU
03:06:05:WU00:FS01:0x22:Platform 2: OpenCL
03:06:05:WU00:FS01:0x22:  opencl-device 0 specified
03:06:06:WU01:FS01:Upload 14.49%
03:06:12:WU01:FS01:Upload 30.07%
03:06:18:WU01:FS01:Upload 45.28%
03:06:22:WU00:FS01:0x22:Attempting to create OpenCL context:
03:06:22:WU00:FS01:0x22:  Configuring platform OpenCL
03:06:24:WU01:FS01:Upload 60.86%
03:06:30:WU01:FS01:Upload 77.88%
03:06:34:WU00:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
03:06:34:WU00:FS01:0x22:Completed 0 out of 1250000 steps (0%)
03:06:36:WU01:FS01:Upload 91.29%
03:06:36:WU00:FS01:0x22:Checkpoint completed at step 0
03:06:38:WU01:FS01:Upload complete
03:06:38:WU01:FS01:Server responded WORK_ACK (400)
03:06:38:WU01:FS01:Final credit estimate, 83078.00 points
03:06:38:WU01:FS01:Cleaning up
03:09:46:WU00:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
[color=#FF0000]07:10:33:WU02:FS00:0xa7:ERROR:Win32: 0xc0000005: Exception access violation[/color]
07:10:33:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
07:10:33:WU02:FS00:0xa7:Saving result file frame1.trr
07:10:33:WU02:FS00:0xa7:Saving result file md.log
07:10:33:WU02:FS00:0xa7:Saving result file science.log
07:10:33:WU02:FS00:0xa7:Saving result file traj_comp.xtc
[color=#FF0000]07:10:33:WU02:FS00:0xa7:WARNING:While cleaning up: Failed to remove '01/ener.edr': The process cannot access the file because it is being used by another process.
07:10:33:WU02:FS00:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
07:10:33:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:10:33:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:14188 run:3 clone:362 gen:1 core:0xa7 unit:0x0000016a000000010000376c00000003[/color]
07:10:33:WU02:FS00:Uploading 210.82KiB to 155.247.166.219
07:10:33:WU02:FS00:Connecting to 155.247.166.219:8080
07:10:34:WU02:FS00:Upload complete
07:10:34:WU01:FS00:Connecting to assign1.foldingathome.org:80
07:10:34:WU02:FS00:Server responded WORK_ACK (400)
07:10:34:WU02:FS00:Cleaning up
07:10:35:WU01:FS00:Assigned to work server 129.32.209.201
07:10:35:WU01:FS00:Requesting new work unit for slot 00: cpu:4 from 129.32.209.201
07:10:35:WU01:FS00:Connecting to 129.32.209.201:8080
07:10:35:WU01:FS00:Downloading 6.65MiB
07:10:36:WU01:FS00:Download complete
07:10:36:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16927 run:0 clone:934 gen:87 core:0xa7 unit:0x000003a6000000570000421f00000000
07:10:37:WU01:FS00:Starting
07:10:37:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 9940 -checkpoint 15 -np 4
07:10:37:WU01:FS00:Started FahCore on PID 3616
07:10:37:WU01:FS00:Core PID:7344
07:10:37:WU01:FS00:FahCore 0xa7 started
07:10:37:WU01:FS00:0xa7:*********************** Log Started 2021-02-03T07:10:37Z ***********************
07:10:37:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:10:37:WU01:FS00:0xa7:       Type: 0xa7
07:10:37:WU01:FS00:0xa7:       Core: Gromacs
07:10:37:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3616 -checkpoint 15 -np 4
07:10:37:WU01:FS00:0xa7:************************************ CBang *************************************
07:10:37:WU01:FS00:0xa7:       Date: Nov 27 2019
07:10:37:WU01:FS00:0xa7:       Time: 03:40:09
07:10:37:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:10:37:WU01:FS00:0xa7:     Branch: master
07:10:37:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
07:10:37:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:10:37:WU01:FS00:0xa7:   Platform: win32 10
07:10:37:WU01:FS00:0xa7:       Bits: 64
07:10:37:WU01:FS00:0xa7:       Mode: Release
07:10:37:WU01:FS00:0xa7:************************************ System ************************************
07:10:37:WU01:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
07:10:37:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
07:10:37:WU01:FS00:0xa7:       CPUs: 8
07:10:37:WU01:FS00:0xa7:     Memory: 15.90GiB
07:10:37:WU01:FS00:0xa7:Free Memory: 12.47GiB
07:10:37:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
07:10:37:WU01:FS00:0xa7: OS Version: 6.2
07:10:37:WU01:FS00:0xa7:Has Battery: false
07:10:37:WU01:FS00:0xa7: On Battery: false
07:10:37:WU01:FS00:0xa7: UTC Offset: -5
07:10:37:WU01:FS00:0xa7:        PID: 7344
07:10:37:WU01:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
07:10:37:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
07:10:37:WU01:FS00:0xa7:    Version: 0.0.19
07:10:37:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:10:37:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:10:37:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
07:10:37:WU01:FS00:0xa7:       Date: Nov 25 2019
07:10:37:WU01:FS00:0xa7:       Time: 17:12:41
07:10:37:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:10:37:WU01:FS00:0xa7:************************************ Build *************************************
07:10:37:WU01:FS00:0xa7:       SIMD: avx_256
07:10:37:WU01:FS00:0xa7:********************************************************************************
07:10:37:WU01:FS00:0xa7:Project: 16927 (Run 0, Clone 934, Gen 87)
07:10:37:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
07:10:37:WU01:FS00:0xa7:Reading tar file core.xml
07:10:37:WU01:FS00:0xa7:Reading tar file frame87.tpr
07:10:37:WU01:FS00:0xa7:Digital signatures verified
07:10:37:WU01:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -cpt 15 -nt 4
07:10:38:WU01:FS00:0xa7:Steps: first=43500000 total=500000
07:10:40:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
07:12:28:WU00:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
07:12:30:WU00:FS01:0x22:Checkpoint completed at step 975000
07:15:38:WU00:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
07:18:46:WU00:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
07:18:48:WU00:FS01:0x22:Checkpoint completed at step 1000000
07:53:28:WU00:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
08:15:33:WU00:FS01:0x22:Checkpoint completed at step 1225000
08:18:42:WU00:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
08:18:42:WU02:FS01:Connecting to assign1.foldingathome.org:80
08:18:43:WU02:FS01:Assigned to work server 140.163.4.200
08:18:43:WU02:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.200
08:18:43:WU02:FS01:Connecting to 140.163.4.200:8080
08:18:43:WU02:FS01:Downloading 12.61MiB
08:18:44:WU02:FS01:Download complete
08:18:44:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:17324 run:0 clone:1973 gen:17 core:0x22 unit:0x000007b500000011000043ac00000000
08:21:50:WU00:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
08:21:50:WU00:FS01:0x22:Average performance: 9.16711 ns/day
08:21:52:WU00:FS01:0x22:Checkpoint completed at step 1250000
08:22:01:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
08:22:01:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
08:22:01:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
08:22:02:WU00:FS01:0x22:Saving result file positions.xtc
08:22:02:WU00:FS01:0x22:Saving result file science.log
08:22:02:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
08:22:02:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:22:02:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17432 run:0 clone:1434 gen:65 core:0x22 unit:0x0000059a000000410000441800000000
08:22:02:WU00:FS01:Uploading 16.43MiB to 206.223.170.146
08:22:02:WU00:FS01:Connecting to 206.223.170.146:8080
08:22:03:WU02:FS01:Starting
08:22:03:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9940 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
08:22:03:WU02:FS01:Started FahCore on PID 1452
08:22:03:WU02:FS01:Core PID:3520
08:22:03:WU02:FS01:FahCore 0x22 started
08:22:04:WU02:FS01:0x22:*********************** Log Started 2021-02-03T08:22:03Z ***********************
08:22:04:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:22:04:WU02:FS01:0x22:       Core: Core22
08:22:04:WU02:FS01:0x22:       Type: 0x22
08:22:04:WU02:FS01:0x22:    Version: 0.0.13
08:22:04:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:22:04:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
08:22:04:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
08:22:04:WU02:FS01:0x22:       Date: Sep 19 2020
08:22:04:WU02:FS01:0x22:       Time: 02:35:58
08:22:04:WU02:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
08:22:04:WU02:FS01:0x22:     Branch: core22-0.0.13
08:22:04:WU02:FS01:0x22:   Compiler: Visual C++ 2015
08:22:04:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
08:22:04:WU02:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
08:22:04:WU02:FS01:0x22:   Platform: win32 10
08:22:04:WU02:FS01:0x22:       Bits: 64
08:22:04:WU02:FS01:0x22:       Mode: Release
08:22:04:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
08:22:04:WU02:FS01:0x22:             <peastman@stanford.edu>
08:22:04:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 1452 -checkpoint 15
08:22:04:WU02:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
08:22:04:WU02:FS01:0x22:             -gpu-usage 100
08:22:04:WU02:FS01:0x22:************************************ libFAH ************************************
08:22:04:WU02:FS01:0x22:       Date: Sep 7 2020
08:22:04:WU02:FS01:0x22:       Time: 19:09:56
08:22:04:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
08:22:04:WU02:FS01:0x22:     Branch: HEAD
08:22:04:WU02:FS01:0x22:************************************ CBang *************************************
08:22:04:WU02:FS01:0x22:       Time: 19:08:30
08:22:04:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
08:22:04:WU02:FS01:0x22:************************************ System ************************************
08:22:04:WU02:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
08:22:04:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
08:22:04:WU02:FS01:0x22:       CPUs: 8
08:22:04:WU02:FS01:0x22:     Memory: 15.90GiB
08:22:04:WU02:FS01:0x22:Free Memory: 12.82GiB
08:22:04:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
08:22:04:WU02:FS01:0x22: OS Version: 6.2
08:22:04:WU02:FS01:0x22:Has Battery: false
08:22:04:WU02:FS01:0x22: On Battery: false
08:22:04:WU02:FS01:0x22: UTC Offset: -5
08:22:04:WU02:FS01:0x22:        PID: 3520
08:22:04:WU02:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
08:22:04:WU02:FS01:0x22:************************************ OpenMM ************************************
08:22:04:WU02:FS01:0x22:   Revision: 189320d0
08:22:04:WU02:FS01:0x22:********************************************************************************
08:22:04:WU02:FS01:0x22:Project: 17324 (Run 0, Clone 1973, Gen 17)
08:22:04:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
08:22:04:WU02:FS01:0x22:Reading tar file core.xml
08:22:04:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
08:22:04:WU02:FS01:0x22:Reading tar file state.xml.bz2
08:22:04:WU02:FS01:0x22:Reading tar file system.xml.bz2
08:22:04:WU02:FS01:0x22:Digital signatures verified
08:22:04:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:22:04:WU02:FS01:0x22:Version 0.0.13
08:22:04:WU02:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
08:22:04:WU02:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
08:22:04:WU02:FS01:0x22:  XTC frame write interval: 250000 steps (20%) [5 total]
08:22:04:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
08:22:04:WU02:FS01:0x22:There are 3 platforms available.
08:22:04:WU02:FS01:0x22:Platform 0: Reference
08:22:04:WU02:FS01:0x22:Platform 1: CPU
08:22:04:WU02:FS01:0x22:Platform 2: OpenCL
08:22:04:WU02:FS01:0x22:  opencl-device 0 specified
08:22:08:WU00:FS01:Upload 38.80%
08:22:14:WU00:FS01:Upload 86.36%
08:22:15:WU00:FS01:Upload complete
08:22:15:WU00:FS01:Server responded WORK_ACK (400)
08:22:15:WU00:FS01:Final credit estimate, 78328.00 points
08:22:16:WU00:FS01:Cleaning up
08:22:21:WU02:FS01:0x22:Attempting to create OpenCL context:
08:22:21:WU02:FS01:0x22:  Configuring platform OpenCL
08:22:32:WU02:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
08:22:32:WU02:FS01:0x22:Completed 0 out of 1250000 steps (0%)
08:22:33:WU02:FS01:0x22:Checkpoint completed at step 0
08:22:48:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
08:25:57:WU02:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
09:10:14:WU02:FS01:0x22:Checkpoint completed at step 175000
10:45:35:WU02:FS01:0x22:Checkpoint completed at step 525000
10:46:07:WU01:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
12:58:21:WU02:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
13:22:12:WU02:FS01:0x22:Checkpoint completed at step 1100000
[color=#FF0000]13:22:18:WU01:FS00:0xa7:ERROR:
13:22:18:WU01:FS00:0xa7:ERROR:-------------------------------------------------------
13:22:18:WU01:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
13:22:18:WU01:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\pme.c, line: 754
13:22:18:WU01:FS00:0xa7:ERROR:Fatal error:
13:22:18:WU01:FS00:0xa7:ERROR:31288 particles communicated to PME rank 2 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
13:22:18:WU01:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
13:22:18:WU01:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
13:22:18:WU01:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
13:22:25:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
13:22:25:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740940 = 0xc0000374)[/color]
13:22:25:WU01:FS00:Starting
13:22:25:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 9940 -checkpoint 15 -np 4
13:22:25:WU01:FS00:Started FahCore on PID 3096
13:22:25:WU01:FS00:Core PID:4728
13:22:25:WU01:FS00:FahCore 0xa7 started
13:22:26:WU01:FS00:0xa7:*********************** Log Started 2021-02-03T13:22:25Z ***********************
13:22:26:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:22:26:WU01:FS00:0xa7:       Type: 0xa7
13:22:26:WU01:FS00:0xa7:       Core: Gromacs
13:22:26:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3096 -checkpoint 15 -np 4
13:22:26:WU01:FS00:0xa7:************************************ CBang *************************************
13:22:26:WU01:FS00:0xa7:       Date: Nov 27 2019
13:22:26:WU01:FS00:0xa7:       Time: 03:40:09
13:22:26:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
13:22:26:WU01:FS00:0xa7:     Branch: master
13:22:26:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
13:22:26:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:22:26:WU01:FS00:0xa7:   Platform: win32 10
13:22:26:WU01:FS00:0xa7:       Bits: 64
13:22:26:WU01:FS00:0xa7:       Mode: Release
13:22:26:WU01:FS00:0xa7:************************************ System ************************************
13:22:26:WU01:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
13:22:26:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
13:22:26:WU01:FS00:0xa7:       CPUs: 8
13:22:26:WU01:FS00:0xa7:     Memory: 15.90GiB
13:22:26:WU01:FS00:0xa7:Free Memory: 12.35GiB
13:22:26:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
13:22:26:WU01:FS00:0xa7: OS Version: 6.2
13:22:26:WU01:FS00:0xa7:Has Battery: false
13:22:26:WU01:FS00:0xa7: On Battery: false
13:22:26:WU01:FS00:0xa7: UTC Offset: -5
13:22:26:WU01:FS00:0xa7:        PID: 4728
13:22:26:WU01:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
13:22:26:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
13:22:26:WU01:FS00:0xa7:    Version: 0.0.19
13:22:26:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:22:26:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:22:26:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
13:22:26:WU01:FS00:0xa7:       Date: Nov 25 2019
13:22:26:WU01:FS00:0xa7:       Time: 17:12:41
13:22:26:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
13:22:26:WU01:FS00:0xa7:************************************ Build *************************************
13:22:26:WU01:FS00:0xa7:       SIMD: avx_256
13:22:26:WU01:FS00:0xa7:********************************************************************************
13:22:26:WU01:FS00:0xa7:Project: 16927 (Run 0, Clone 934, Gen 87)
13:22:26:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
13:22:26:WU01:FS00:0xa7:Digital signatures verified
13:22:26:WU01:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -cpi state.cpt -cpt 15 -nt 4
13:22:26:WU01:FS00:0xa7:Steps: first=43500000 total=500000
13:22:27:WU01:FS00:0xa7:Completed 150526 out of 500000 steps (30%)
13:25:35:WU02:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
13:28:58:WU02:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
13:29:01:WU02:FS01:0x22:Checkpoint completed at step 1125000
13:32:24:WU02:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
13:33:09:WU01:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
13:35:48:WU02:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
13:35:50:WU02:FS01:0x22:Checkpoint completed at step 1150000
13:39:14:WU02:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
13:42:38:WU02:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
13:42:40:WU02:FS01:0x22:Checkpoint completed at step 1175000
13:45:15:WU01:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
13:46:03:WU02:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
13:49:26:WU02:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
13:49:28:WU02:FS01:0x22:Checkpoint completed at step 1200000
13:52:51:WU02:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
13:56:15:WU02:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
13:56:17:WU02:FS01:0x22:Checkpoint completed at step 1225000
13:57:15:WU01:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
13:59:40:WU02:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
13:59:41:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:59:42:WU00:FS01:Assigned to work server 18.188.125.154
13:59:42:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 18.188.125.154
13:59:42:WU00:FS01:Connecting to 18.188.125.154:8080
13:59:43:WU00:FS01:Downloading 6.88MiB
13:59:43:WU00:FS01:Download complete
13:59:44:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13444 run:6484 clone:37 gen:0 core:0x22 unit:0x00000025000000000000348400001954
14:03:03:WU02:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
14:03:03:WU02:FS01:0x22:Average performance: 212.285 ns/day
14:03:05:WU02:FS01:0x22:Checkpoint completed at step 1250000
14:03:23:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
14:03:23:WU02:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
14:03:23:WU02:FS01:0x22:Saving result file checkpointState.xml.bz2
14:03:23:WU02:FS01:0x22:Saving result file positions.xtc
14:03:23:WU02:FS01:0x22:Saving result file science.log
14:03:23:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
14:03:24:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:03:24:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:17324 run:0 clone:1973 gen:17 core:0x22 unit:0x000007b500000011000043ac00000000
14:03:24:WU02:FS01:Uploading 13.52MiB to 140.163.4.200
14:03:24:WU00:FS01:Starting
14:03:24:WU02:FS01:Connecting to 140.163.4.200:8080
14:03:24:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 9940 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
14:03:24:WU00:FS01:Started FahCore on PID 2504
14:03:25:WU00:FS01:Core PID:3188
14:03:25:WU00:FS01:FahCore 0x22 started
14:03:25:WU00:FS01:0x22:*********************** Log Started 2021-02-03T14:03:25Z ***********************
14:03:25:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:03:25:WU00:FS01:0x22:       Core: Core22
14:03:25:WU00:FS01:0x22:       Type: 0x22
14:03:25:WU00:FS01:0x22:    Version: 0.0.13
14:03:25:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:03:25:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
14:03:25:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
14:03:25:WU00:FS01:0x22:       Date: Sep 19 2020
14:03:25:WU00:FS01:0x22:       Time: 02:35:58
14:03:25:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
14:03:25:WU00:FS01:0x22:     Branch: core22-0.0.13
14:03:25:WU00:FS01:0x22:   Compiler: Visual C++ 2015
14:03:25:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:03:25:WU00:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
14:03:25:WU00:FS01:0x22:   Platform: win32 10
14:03:25:WU00:FS01:0x22:       Bits: 64
14:03:25:WU00:FS01:0x22:       Mode: Release
14:03:25:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:03:25:WU00:FS01:0x22:             <peastman@stanford.edu>
14:03:25:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 2504 -checkpoint 15
14:03:25:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
14:03:25:WU00:FS01:0x22:             -gpu-usage 100
14:03:25:WU00:FS01:0x22:************************************ libFAH ************************************
14:03:25:WU00:FS01:0x22:       Date: Sep 7 2020
14:03:25:WU00:FS01:0x22:       Time: 19:09:56
14:03:25:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
14:03:25:WU00:FS01:0x22:     Branch: HEAD
14:03:25:WU00:FS01:0x22:************************************ CBang *************************************
14:03:25:WU00:FS01:0x22:       Time: 19:08:30
14:03:25:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
14:03:25:WU00:FS01:0x22:************************************ System ************************************
14:03:25:WU00:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
14:03:25:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
14:03:25:WU00:FS01:0x22:       CPUs: 8
14:03:25:WU00:FS01:0x22:     Memory: 15.90GiB
14:03:25:WU00:FS01:0x22:Free Memory: 12.64GiB
14:03:25:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
14:03:25:WU00:FS01:0x22: OS Version: 6.2
14:03:25:WU00:FS01:0x22:Has Battery: false
14:03:25:WU00:FS01:0x22: On Battery: false
14:03:25:WU00:FS01:0x22: UTC Offset: -5
14:03:25:WU00:FS01:0x22:        PID: 3188
14:03:25:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
14:03:25:WU00:FS01:0x22:************************************ OpenMM ************************************
14:03:25:WU00:FS01:0x22:   Revision: 189320d0
14:03:25:WU00:FS01:0x22:********************************************************************************
14:03:25:WU00:FS01:0x22:Project: 13444 (Run 6484, Clone 37, Gen 0)
14:03:25:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
14:03:25:WU00:FS01:0x22:Reading tar file core.xml
14:03:25:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
14:03:25:WU00:FS01:0x22:Reading tar file state.xml.bz2
14:03:25:WU00:FS01:0x22:Reading tar file system.xml.bz2
14:03:25:WU00:FS01:0x22:Digital signatures verified
14:03:25:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:03:25:WU00:FS01:0x22:Version 0.0.13
14:03:25:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
14:03:25:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
14:03:25:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
14:03:25:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
14:03:26:WU00:FS01:0x22:There are 3 platforms available.
14:03:26:WU00:FS01:0x22:Platform 0: Reference
14:03:26:WU00:FS01:0x22:Platform 1: CPU
14:03:26:WU00:FS01:0x22:Platform 2: OpenCL
14:03:26:WU00:FS01:0x22:  opencl-device 0 specified
14:03:30:WU02:FS01:Upload 18.95%
14:03:36:WU02:FS01:Upload 36.52%
14:03:42:WU00:FS01:0x22:Attempting to create OpenCL context:
14:03:42:WU00:FS01:0x22:  Configuring platform OpenCL
14:03:42:WU02:FS01:Upload 57.32%
14:03:48:WU02:FS01:Upload 79.04%
14:03:54:WU02:FS01:Upload 97.07%
14:03:55:WU02:FS01:Upload complete
14:03:55:WU02:FS01:Server responded WORK_ACK (400)
14:03:55:WU02:FS01:Final credit estimate, 102457.00 points
14:03:55:WU02:FS01:Cleaning up
14:03:56:WU00:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
14:03:56:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
14:03:57:WU00:FS01:0x22:Checkpoint completed at step 0
14:08:14:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
14:09:24:WU01:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
14:12:30:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
14:16:46:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
14:21:03:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
14:21:41:WU01:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
14:25:19:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
14:25:20:WU00:FS01:0x22:Checkpoint completed at step 50000
14:29:36:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
Re: WARNING:WU01:FS00
Post by Neil-B »
colour doesn't work in code pages :( ... but those are shutdown message from when you close certain things like web control, protein viewer, etc. iirc ... nothing to worry about ... see https://foldingforum.org/viewtopic.php? ... on#p346696 for better explanation :)
Forcinghavok
The errors below are because of turning something on or off? Which I wasn't doing. Can we explain this more? Thank you.
Post by Neil-B »
Apologies the first errors i found in your initial log were the ones I commented on - looked at post from phone so scrolling through log log wasnt working well .. that series of errors you posted 2nd looks possibly like bad wu (which happen) did the wu get uploaded as a faulty project? And was this just one wu or is it happening repeatedly? If repeatedly then ard they all the same project .. I think the bad equilibrate bit refers to the project setup especially with mention of pme .. if it were your system unstable through oc or some such then fairly sure it would look different but I am sure someone will confirm/correct this
The error 0xa7:ERROR:31288 particles communicated to PME rank 2 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
is not something you can fix. The project owner will have been notified of this error and presumably will have fixed it before reissuing the WU to somebody else.
The identifiers WU01:FS00 that you used in the title of this post don't happen to be useful. They only identify the WU while it's on your machine. The permanent identifiers are called PRCG or Project/Run/Clone/Gen numbers as in Project: 17324 (Run 0, Clone 1973, Gen 17). I'll edit your original title.
The 0xa7:ERROR:Win32: 0xc0000005: Exception access violation message indicates you didn't start FAHClient correctly and it is unable to store it's working files in the local directory.
As Neil has said, the :ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine. messages should be ignored.
