155.247.166.219 Successful upload but no credits (p14188)
Der_mit_dem_Hund
Post by Der_mit_dem_Hund »
It looks as if my work has been in vain.
project:16461 run:119 clone:4 gen:174 core:0xa7 unit:0x00000004000000ae0000404d00000077 still results in "Not found." on the WU Status page.
Let's see how this one fares. I have delivered it an hour ago...
13:09:20:WU00:FS00:0xa7:Completed 1250000 out of 1250000 steps (100%)
13:09:22:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
13:09:22:WU00:FS00:0xa7:Saving result file frame1.trr
13:09:25:WU00:FS00:0xa7:Saving result file md.log
13:09:25:WU00:FS00:0xa7:Saving result file science.log
13:09:25:WU00:FS00:0xa7:Saving result file traj_comp.xtc
13:09:25:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:09:25:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR [b]project:14188 run:3 clone:786 gen:1 core:0xa7 unit:0x00000312000000010000376c00000003[/b]
13:09:25:WU00:FS00:Uploading 9.23MiB to 155.247.166.219
13:09:25:WU00:FS00:Connecting to 155.247.166.219:8080
Cheers
Edit by Mod:
P14188 is being uploaded to 155.247.166.219. I'm moving that to a different topic. It may or may not be credited quickly,, but it's certainly unrelated to the current title:
"155.247.166.219 Successful upload but no credits (project 16461)"
Post by Neil-B »
Not sure what you mean by in vain?
you have missed the part of your log that shows the receives succesfully and estimated points message - but as long as you have seen those then you will get your points once the stats system is sorted ... but these things take time to resolve - they are low priority as dev effort is first used on sorting out issues that actually impact the throughput of the science ... catching up on a stats blockage can take weeks or in bad cases months - but it does happen :) ... one just needs to be patient and let the team have time to sort it out.
now if your log is however showing a dumped message then yes your work may have been in vain :( ... and that is the point where we try to help you find out why the wus return was dumped and see if there is anything that can be done to ensure that doesn't happen again.
Der_mit_dem_Hund
Again: Successful upload but no credits (NOW project 14188)
... and it looks a bit as if there was something wrong with my WUs:
09:00:19:WU00:FS00:0xa7:Completed 1212500 out of 1250000 steps (97%)
10:23:23:WU00:FS00:0xa7:Completed 1225000 out of 1250000 steps (98%)
11:46:33:WU00:FS00:0xa7:Completed 1237500 out of 1250000 steps (99%)
13:09:25:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14188 run:3 clone:786 gen:1 core:0xa7 unit:0x00000312000000010000376c00000003
My stats say: Date of last Work Unit 2021-01-19 08:26:24
ThorstenR
Re: Successful upload but no credits (project 16461)
Post by ThorstenR »
Don't despair. As long as you got a WORK_ACK message (which you probably cut off from your log file), the work is not in vain. The thing is that the client downloads and starts a new work unit while the last one is still uploading, so this is mixed up a bit in the log file. See the example below, with the old work unit in red and the new one in blue.
12:41:32:WU01:FS00:Connecting to assign1.foldingathome.org:80
12:41:33:WU01:FS00:Assigned to work server 129.32.209.201
12:41:33:WU01:FS00:Requesting new work unit for slot 00: cpu:4 from 129.32.209.201
12:41:33:WU01:FS00:Connecting to 129.32.209.201:8080
12:41:35:WU01:FS00:Downloading 6.65MiB
12:41:41:WU01:FS00:Download 94.95%
12:41:41:WU01:FS00:Download complete
12:41:41:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16927 run:6 clone:134 gen:101 core:0xa7 unit:0x00000086000000650000421f00000006
12:43:58:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
12:44:10:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
12:44:10:WU00:FS00:0xa7:Saving result file frame233.trr
12:44:10:WU00:FS00:0xa7:Saving result file frame233.xtc
12:44:10:WU00:FS00:0xa7:Saving result file md.log
12:44:10:WU00:FS00:0xa7:Saving result file science.log
12:44:10:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:44:10:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:44:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17428 run:0 clone:4731 gen:233 core:0xa7 unit:0x0000127b000000e90000441400000000
12:44:10:WU00:FS00:Uploading 10.16MiB to 128.252.203.9
12:44:10:WU00:FS00:Connecting to 128.252.203.9:8080
12:44:10:WU01:FS00:Starting
12:44:10:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 706 -lifeline 254 -checkpoint 15 -np 4
12:44:10:WU01:FS00:Started FahCore on PID 14043
12:44:10:WU01:FS00:Core PID:14044
12:44:10:WU01:FS00:FahCore 0xa7 started
12:44:11:WU01:FS00:0xa7:*********************** Log Started 2021-02-02T12:44:10Z ***********************
12:44:11:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:44:11:WU01:FS00:0xa7: Type: 0xa7
12:44:11:WU01:FS00:0xa7: Core: Gromacs
12:44:11:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 14043 -checkpoint 15 -np
12:44:11:WU01:FS00:0xa7: 4
12:44:11:WU01:FS00:0xa7:************************************ CBang *************************************
12:44:11:WU01:FS00:0xa7: Date: Nov 27 2019
12:44:11:WU01:FS00:0xa7: Time: 03:27:01
12:44:11:WU01:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
12:44:11:WU01:FS00:0xa7: Branch: master
12:44:11:WU01:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
12:44:11:WU01:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
12:44:11:WU01:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
12:44:11:WU01:FS00:0xa7: Platform: darwin 19.0.0
12:44:11:WU01:FS00:0xa7: Bits: 64
12:44:11:WU01:FS00:0xa7: Mode: Release
12:44:11:WU01:FS00:0xa7:************************************ System ************************************
12:44:11:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4980HQ CPU @ 2.80GHz
12:44:11:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
12:44:11:WU01:FS00:0xa7: CPUs: 8
12:44:11:WU01:FS00:0xa7: Memory: 16.00GiB
12:44:11:WU01:FS00:0xa7:Free Memory: 3.83GiB
12:44:11:WU01:FS00:0xa7: Threads: POSIX_THREADS
12:44:11:WU01:FS00:0xa7: OS Version: 10.11
12:44:11:WU01:FS00:0xa7:Has Battery: true
12:44:11:WU01:FS00:0xa7: On Battery: false
12:44:11:WU01:FS00:0xa7: UTC Offset: 1
12:44:11:WU01:FS00:0xa7: PID: 14044
12:44:11:WU01:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
12:44:11:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
12:44:11:WU01:FS00:0xa7: Version: 0.0.19
12:44:11:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:44:11:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
12:44:11:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
12:44:11:WU01:FS00:0xa7: Date: Nov 25 2019
12:44:11:WU01:FS00:0xa7: Time: 16:41:59
12:44:11:WU01:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
12:44:11:WU01:FS00:0xa7:************************************ Build *************************************
12:44:11:WU01:FS00:0xa7: SIMD: avx_256
12:44:11:WU01:FS00:0xa7:********************************************************************************
12:44:11:WU01:FS00:0xa7:Project: 16927 (Run 6, Clone 134, Gen 101)
12:44:11:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
12:44:11:WU01:FS00:0xa7:Reading tar file core.xml
12:44:11:WU01:FS00:0xa7:Reading tar file frame101.tpr
12:44:11:WU01:FS00:0xa7:Digital signatures verified
12:44:11:WU01:FS00:0xa7:Calling: mdrun -s frame101.tpr -o frame101.trr -cpt 15 -nt 4
12:44:11:WU01:FS00:0xa7:Steps: first=50500000 total=500000
12:44:14:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
12:44:16:WU00:FS00:Upload 10.46%
12:44:22:WU00:FS00:Upload 14.77%
12:44:31:WU00:FS00:Upload 19.69%
12:44:38:WU00:FS00:Upload 22.15%
12:44:44:WU00:FS00:Upload 28.30%
12:44:50:WU00:FS00:Upload 40.61%
12:44:57:WU00:FS00:Upload 50.45%
12:45:04:WU00:FS00:Upload 52.91%
12:45:10:WU00:FS00:Upload 56.60%
12:45:16:WU00:FS00:Upload 63.37%
12:45:22:WU00:FS00:Upload 73.21%
12:45:29:WU00:FS00:Upload 80.60%
12:45:35:WU00:FS00:Upload 87.36%
12:45:41:WU00:FS00:Upload 98.44%
12:45:42:WU00:FS00:Upload complete
12:45:42:WU00:FS00:Server responded WORK_ACK (400)
12:45:42:WU00:FS00:Final credit estimate, 3979.00 points
12:45:42:WU00:FS00:Cleaning up
12:50:07:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
[/code]
The servers 155.247.166.219 and 129.32.209.201, and maybe others, seem to have lost connection to the credits server, but I understand that this does not impact the usefulness of your work.
Cheers,
Thorsten
Re: Again: Successful upload but no credits (NOW project 141
Post by Neil-B »
Der_mit_dem_Hund wrote:... and it looks a bit as if there was something wrong with my WUs:
There isn't anything wrong in the log snippet you have posted it is just only the first part of the send message the rest will be later in the log ... the download and startup of a new wu overlap the finish and upload of the completed wu ... if you look are the timestamp of all the log entries during this crossover you will see they tend to be very close together ... the request and download for the next wu is default at 99% completion of current wu then the current ond finishes and gets packaged for upload and this process starts ... then the new wu commences and once that starts running the process of uploading normally completes
ajm
Re: 155.247.166.219 Successful upload but no credits (p14188
Post by ajm »
The problem appears to be general to the whole stats system, now.
EOC hasn't found any acknowledgment of any points for over 9 hours: https://folding.extremeoverclocking.com ... ary.php?s=
new08
Hardware configuration: Hewlett-Packard 1494 Win10 Build 1836
GeForce [MSI] GTX 950
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
Yes,, all my team (Mozilla) are showing nil points, as of this time - even the big leader, on 10 million per day normally..
My work has been uploaded ok, but I haven't checked official stats yet -as it looks like an EOC/Server issue, with no updates showing at all.
No comments on their site page, as yet...
Not an EOC problem, the files it uses from F@h are not being updated, see - viewtopic.php?f=18&t=36770
