I'm running 7.6.21 on Windows 10. I use the Client Advanced Control => Configure => Slots to delete 2 GPU slots and set the CPU slot to use 6 threads.
After a reboot, the CPU slot is still using 6 threads, but both GPU slots are back, which leads to the GPU overheating.
I searched and found a similar problem back in 2014, but I'm assuming a lot has changed since then.
Deleted GPU Slots Return After Reboot
Re: Deleted GPU Slots Return After Reboot
Pause the slots and add the pause on start = true flag
The client's CPU setting allows you to overcommit the number of CPUs. If you configure it for -1, it will choose the recommended number, which in this case, probably isn't what you want since there's no point in allocating a CPU thread for each GPU if you're not going to be running the GPU(s).
Have you tried setting an extra client option to gpu=false in FAHControl's EXPERT tab?
I used bruce's suggestion. It worked perfectly!
Definitely not something I would have figured out on my own (I'm certainly no expert!).
Thanks, bruce!
If somebody can close this problem or mark in solved, I would appreciate it.
P.S. I always allocate 6 of my processor's 8 threads to F@H. I've done this for years without any problems.
Thanks, bruce!
Thanks for the feedback, AlanD2. My suggestion was based on a hunch --- I had not had the opportunity to test it yet.
For everybody who has been recommending the pause-on-start method, we can now recommend turning off the GPU reconfiguration step that runs on every client restart. It will only create a new problem if somebody adds or replaces one GPU with another type.
