22:41:38:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
22:41:39:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:41:39:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13444 run:1957 clone:0 gen:1 core:0x22 unit:0x000000000000000100003484000007a5
22:41:39:WU01:FS01:Uploading 7.67MiB to 18.188.125.154
22:41:39:WU01:FS01:Connecting to 18.188.125.154:8080
22:41:39:WU00:FS01:Starting
22:41:39:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11372 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
22:41:39:WU00:FS01:Started FahCore on PID 1692
22:41:39:WU00:FS01:Core PID:14316
22:41:39:WU00:FS01:FahCore 0x22 started
22:41:39:WU00:FS01:0x22:*********************** Log Started 2021-01-25T22:41:39Z ***********************
22:41:39:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:41:39:WU00:FS01:0x22: Core: Core22
22:41:39:WU00:FS01:0x22: Type: 0x22
22:41:39:WU00:FS01:0x22: Version: 0.0.13
22:41:39:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:41:39:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
22:41:39:WU00:FS01:0x22: Homepage: https://foldingathome.org/
22:41:39:WU00:FS01:0x22: Date: Sep 19 2020
22:41:39:WU00:FS01:0x22: Time: 02:35:58
22:41:39:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
22:41:39:WU00:FS01:0x22: Branch: core22-0.0.13
22:41:39:WU00:FS01:0x22: Compiler: Visual C++ 2015
22:41:39:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
22:41:39:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
22:41:39:WU00:FS01:0x22: Platform: win32 10
22:41:39:WU00:FS01:0x22: Bits: 64
22:41:39:WU00:FS01:0x22: Mode: Release
22:41:39:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:41:39:WU00:FS01:0x22: <peastman@stanford.edu>
22:41:39:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 1692 -checkpoint 15
22:41:39:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
22:41:39:WU00:FS01:0x22: -gpu-usage 100
22:41:39:WU00:FS01:0x22:************************************ libFAH ************************************
22:41:39:WU00:FS01:0x22: Date: Sep 7 2020
22:41:39:WU00:FS01:0x22: Time: 19:09:56
22:41:39:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
22:41:39:WU00:FS01:0x22: Branch: HEAD
22:41:39:WU00:FS01:0x22:************************************ CBang *************************************
22:41:39:WU00:FS01:0x22: Time: 19:08:30
22:41:39:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
22:41:39:WU00:FS01:0x22:************************************ System ************************************
22:41:39:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
22:41:39:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
22:41:39:WU00:FS01:0x22: CPUs: 8
22:41:39:WU00:FS01:0x22: Memory: 31.92GiB
22:41:39:WU00:FS01:0x22:Free Memory: 26.01GiB
22:41:39:WU00:FS01:0x22: Threads: WINDOWS_THREADS
22:41:39:WU00:FS01:0x22: OS Version: 6.2
22:41:39:WU00:FS01:0x22:Has Battery: false
22:41:39:WU00:FS01:0x22: On Battery: false
22:41:39:WU00:FS01:0x22: UTC Offset: -8
22:41:39:WU00:FS01:0x22: PID: 14316
22:41:39:WU00:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
22:41:39:WU00:FS01:0x22:************************************ OpenMM ************************************
22:41:39:WU00:FS01:0x22: Revision: 189320d0
22:41:39:WU00:FS01:0x22:********************************************************************************
22:41:39:WU00:FS01:0x22:Project: 13444 (Run 2232, Clone 36, Gen 1)
22:41:39:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
22:41:39:WU00:FS01:0x22:Reading tar file core.xml
22:41:39:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
22:41:39:WU00:FS01:0x22:Reading tar file state.xml.bz2
22:41:39:WU00:FS01:0x22:Reading tar file system.xml.bz2
22:41:39:WU00:FS01:0x22:Digital signatures verified
22:41:39:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:41:39:WU00:FS01:0x22:Version 0.0.13
22:41:40:WU00:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
22:41:40:WU00:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
22:41:40:WU00:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
22:41:40:WU00:FS01:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
22:41:40:WU00:FS01:0x22:There are 3 platforms available.
22:41:40:WU00:FS01:0x22:Platform 0: Reference
22:41:40:WU00:FS01:0x22:Platform 1: CPU
22:41:40:WU00:FS01:0x22:Platform 2: OpenCL
22:41:40:WU00:FS01:0x22: opencl-device 0 specified
22:41:45:WU01:FS01:Upload 33.41%
22:41:51:WU01:FS01:Upload 86.38%
22:41:52:WU01:FS01:Upload complete
22:41:53:WU01:FS01:Server responded WORK_ACK (400)
22:41:53:WU01:FS01:Final credit estimate, 124923.00 points
22:41:53:WU01:FS01:Cleaning up
22:41:57:WU00:FS01:0x22:Attempting to create OpenCL context:
22:41:57:WU00:FS01:0x22: Configuring platform OpenCL
