results of project never loaded
It seems my completed project has been stuck on "Send Results" for a couple of hours now. In "Advanced Control" it is/has a Workqueue with "Send" status and "100 percent" progress. However, the results are yet to load.
Robert Frost
"In three words I can sum up everything I've learned about life. It goes on."
work time-employee monitoring software
Re: results of project never loaded
Welcome to the F@H Forum BorisVivienne,
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
