I downloaded the "newest" AMD driver a couple of days ago. The version is 21.1.1
Since that time, I have had a number of stalled work units. I was just wondering if anyone else was seeing this.
I have an RX 570 on Windows 10.
Stalled work units with 21.1.1
Re: Stalled work units with 21.1.1
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. AFAIK, I haven't seen any increased error reports for AMD GPUs.
Search for WU_STALLED
*********************** Log Started 2021-01-23T12:38:56Z ***********************
12:38:56:******************************* libFAH ********************************
12:38:56: Date: Oct 20 2020
12:38:56: Time: 13:36:55
12:38:56: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
12:38:56: Branch: master
12:38:56: Compiler: Visual C++ 2015
12:38:56: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
12:38:56: Platform: win32 10
12:38:56: Bits: 32
12:38:56: Mode: Release
12:38:56:****************************** FAHClient ******************************
12:38:56: Version: 7.6.21
12:38:56: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:38:56: Copyright: 2020 foldingathome.org
12:38:56: Homepage: https://foldingathome.org/
12:38:56: Time: 13:41:04
12:38:56: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
12:38:56: Bits: 32
12:38:56: Config: D:\C_Alt\data\FAHClient\config.xml
12:38:56:******************************** CBang ********************************
12:38:56: Time: 11:36:18
12:38:56: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
12:38:56: Bits: 32
12:38:56:******************************* System ********************************
12:38:56: CPU: Intel(R) Core(TM) i9-10850K CPU @ 3.60GHz
12:38:56: CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
12:38:56: CPUs: 20
12:38:56: Memory: 31.92GiB
12:38:56: Free Memory: 26.90GiB
12:38:56: Threads: WINDOWS_THREADS
12:38:56: OS Version: 6.2
12:38:56: Has Battery: false
12:38:56: On Battery: false
12:38:56: UTC Offset: -5
12:38:56: PID: 8588
12:38:56: CWD: D:\C_Alt\data\FAHClient
12:38:56: Win32 Service: false
12:38:56: OS: Windows 10 Enterprise
12:38:56: OS Arch: AMD64
12:38:56: GPUs: 2
12:38:56: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 Ti]
12:38:56: GPU 1: Bus:3 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
12:38:56: 470/480/570/580/590]
12:38:56: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.2
12:38:56:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:461.9
12:38:56:OpenCL Device 1: Platform:1 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3188.4
12:38:56:***********************************************************************
12:38:56:<config>
12:38:56: <!-- Folding Core -->
12:38:56: <checkpoint v='5'/>
12:38:56:
12:38:56: <!-- Folding Slot Configuration -->
12:38:56: <cause v='COVID_19'/>
12:38:56:
12:38:56: <!-- Network -->
12:38:56: <proxy v=':8080'/>
12:38:56:
12:38:56: <!-- Slot Control -->
12:38:56: <pause-on-battery v='false'/>
12:38:56:
12:38:56: <!-- User Information -->
12:38:56: <passkey v='*****'/>
12:38:56: <user v='Mark_Roggenbuck'/>
12:38:56:
12:38:56: <!-- Folding Slots -->
12:38:56: <slot id='0' type='GPU'>
12:38:56: <paused v='true'/>
12:38:56: <pci-bus v='1'/>
12:38:56: <pci-slot v='0'/>
12:38:56: </slot>
12:38:56: <slot id='1' type='GPU'>
12:38:56: <pci-bus v='3'/>
12:38:56: </slot>
12:38:56:</config>
12:38:56:Trying to access database...
12:38:56:Successfully acquired database lock
12:38:56:FS00:Initialized folding slot 00: gpu:1:0 TU116 [GeForce GTX 1660 Ti]
12:38:56:FS01:Initialized folding slot 01: gpu:3:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
12:39:08:FS00:Unpaused
12:39:08:FS01:Unpaused
12:39:08:WU02:FS01:Starting
12:39:08:WU02:FS01:Running FahCore: D:\C_Alt\programs\FAHClient/FAHCoreWrapper.exe D:\C_Alt\data\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8588 -checkpoint 5 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
12:39:08:WU02:FS01:Started FahCore on PID 8336
12:39:08:WU02:FS01:Core PID:12860
12:39:08:WU02:FS01:FahCore 0x22 started
12:39:08:WU00:FS00:Starting
12:39:08:WU00:FS00:Running FahCore: D:\C_Alt\programs\FAHClient/FAHCoreWrapper.exe D:\C_Alt\data\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8588 -checkpoint 5 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
12:39:08:WU00:FS00:Started FahCore on PID 9276
12:39:08:WU00:FS00:Core PID:5364
12:39:08:WU00:FS00:FahCore 0x22 started
12:39:08:WU02:FS01:0x22:*********************** Log Started 2021-01-23T12:39:08Z ***********************
12:39:08:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:39:08:WU02:FS01:0x22: Core: Core22
12:39:08:WU02:FS01:0x22: Type: 0x22
12:39:08:WU02:FS01:0x22: Version: 0.0.13
12:39:08:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:39:08:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
12:39:08:WU02:FS01:0x22: Homepage: https://foldingathome.org/
12:39:08:WU02:FS01:0x22: Date: Sep 19 2020
12:39:08:WU02:FS01:0x22: Time: 02:35:58
12:39:08:WU02:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
12:39:08:WU02:FS01:0x22: Branch: core22-0.0.13
12:39:08:WU02:FS01:0x22: Compiler: Visual C++ 2015
12:39:08:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:39:08:WU02:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
12:39:08:WU02:FS01:0x22: Platform: win32 10
12:39:08:WU02:FS01:0x22: Bits: 64
12:39:08:WU02:FS01:0x22: Mode: Release
12:39:08:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:39:08:WU02:FS01:0x22: <peastman@stanford.edu>
12:39:08:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 8336 -checkpoint 5
12:39:08:WU02:FS01:0x22: -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
12:39:08:WU02:FS01:0x22: -gpu-usage 100
12:39:08:WU02:FS01:0x22:************************************ libFAH ************************************
12:39:08:WU02:FS01:0x22: Date: Sep 7 2020
12:39:08:WU02:FS01:0x22: Time: 19:09:56
12:39:08:WU02:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
12:39:08:WU02:FS01:0x22: Branch: HEAD
12:39:08:WU02:FS01:0x22:************************************ CBang *************************************
12:39:09:WU02:FS01:0x22: Time: 19:08:30
12:39:09:WU02:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
12:39:09:WU02:FS01:0x22: Branch: HEAD
12:39:09:WU02:FS01:0x22: Compiler: Visual C++ 2015
12:39:09:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:39:09:WU02:FS01:0x22: Platform: win32 10
12:39:09:WU02:FS01:0x22: Bits: 64
12:39:09:WU02:FS01:0x22: Mode: Release
12:39:09:WU02:FS01:0x22:************************************ System ************************************
12:39:09:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-10850K CPU @ 3.60GHz
12:39:09:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
12:39:09:WU02:FS01:0x22: CPUs: 20
12:39:09:WU02:FS01:0x22: Memory: 31.92GiB
12:39:09:WU02:FS01:0x22:Free Memory: 27.01GiB
12:39:09:WU02:FS01:0x22: Threads: WINDOWS_THREADS
12:39:09:WU02:FS01:0x22: OS Version: 6.2
12:39:09:WU02:FS01:0x22:Has Battery: false
12:39:09:WU02:FS01:0x22: On Battery: false
12:39:09:WU02:FS01:0x22: UTC Offset: -5
12:39:09:WU02:FS01:0x22: PID: 12860
12:39:09:WU02:FS01:0x22: CWD: D:\C_Alt\data\FAHClient\work
12:39:09:WU02:FS01:0x22:************************************ OpenMM ************************************
12:39:09:WU02:FS01:0x22: Revision: 189320d0
12:39:09:WU02:FS01:0x22:********************************************************************************
12:39:09:WU02:FS01:0x22:Project: 13440 (Run 709, Clone 32, Gen 1)
12:39:09:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
12:39:09:WU02:FS01:0x22:Digital signatures verified
12:39:09:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:39:09:WU02:FS01:0x22:Version 0.0.13
12:39:09:WU02:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
12:39:09:WU02:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
12:39:09:WU02:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
12:39:09:WU02:FS01:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
12:39:09:WU02:FS01:0x22:There are 3 platforms available.
12:39:09:WU02:FS01:0x22:Platform 0: Reference
12:39:09:WU02:FS01:0x22:Platform 1: CPU
12:39:09:WU02:FS01:0x22:Platform 2: OpenCL
12:39:09:WU02:FS01:0x22: opencl-device 0 specified
12:39:09:WU00:FS00:0x22:*********************** Log Started 2021-01-23T12:39:08Z ***********************
12:39:09:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
12:39:09:WU00:FS00:0x22: Core: Core22
12:39:09:WU00:FS00:0x22: Type: 0x22
12:39:09:WU00:FS00:0x22: Version: 0.0.13
12:39:09:WU00:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:39:09:WU00:FS00:0x22: Copyright: 2020 foldingathome.org
12:39:09:WU00:FS00:0x22: Homepage: https://foldingathome.org/
12:39:09:WU00:FS00:0x22: Date: Sep 19 2020
12:39:09:WU00:FS00:0x22: Time: 02:35:58
12:39:09:WU00:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
12:39:09:WU00:FS00:0x22: Branch: core22-0.0.13
12:39:09:WU00:FS00:0x22: Compiler: Visual C++ 2015
12:39:09:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:39:09:WU00:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
12:39:09:WU00:FS00:0x22: Platform: win32 10
12:39:09:WU00:FS00:0x22: Bits: 64
12:39:09:WU00:FS00:0x22: Mode: Release
12:39:09:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:39:09:WU00:FS00:0x22: <peastman@stanford.edu>
12:39:09:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 9276 -checkpoint 5
12:39:09:WU00:FS00:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
12:39:09:WU00:FS00:0x22: nvidia -gpu 0 -gpu-usage 100
12:39:09:WU00:FS00:0x22:************************************ libFAH ************************************
12:39:09:WU00:FS00:0x22: Date: Sep 7 2020
12:39:09:WU00:FS00:0x22: Time: 19:09:56
12:39:09:WU00:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
12:39:09:WU00:FS00:0x22: Branch: HEAD
12:39:09:WU00:FS00:0x22:************************************ CBang *************************************
12:39:09:WU00:FS00:0x22: Time: 19:08:30
12:39:09:WU00:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
12:39:09:WU00:FS00:0x22:************************************ System ************************************
12:39:09:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i9-10850K CPU @ 3.60GHz
12:39:09:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
12:39:09:WU00:FS00:0x22: CPUs: 20
12:39:09:WU00:FS00:0x22: Memory: 31.92GiB
12:39:09:WU00:FS00:0x22:Free Memory: 27.01GiB
12:39:09:WU00:FS00:0x22: Threads: WINDOWS_THREADS
12:39:09:WU00:FS00:0x22: OS Version: 6.2
12:39:09:WU00:FS00:0x22:Has Battery: false
12:39:09:WU00:FS00:0x22: On Battery: false
12:39:09:WU00:FS00:0x22: UTC Offset: -5
12:39:09:WU00:FS00:0x22: PID: 5364
12:39:09:WU00:FS00:0x22: CWD: D:\C_Alt\data\FAHClient\work
12:39:09:WU00:FS00:0x22:************************************ OpenMM ************************************
12:39:09:WU00:FS00:0x22: Revision: 189320d0
12:39:09:WU00:FS00:0x22:********************************************************************************
12:39:09:WU00:FS00:0x22:Project: 13440 (Run 829, Clone 40, Gen 1)
12:39:09:WU00:FS00:0x22:Unit: 0x00000000000000000000000000000000
12:39:09:WU00:FS00:0x22:Digital signatures verified
12:39:09:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
12:39:09:WU00:FS00:0x22:Version 0.0.13
12:39:09:WU00:FS00:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
12:39:09:WU00:FS00:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
12:39:09:WU00:FS00:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
12:39:09:WU00:FS00:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
12:39:09:WU00:FS00:0x22:There are 4 platforms available.
12:39:09:WU00:FS00:0x22:Platform 0: Reference
12:39:09:WU00:FS00:0x22:Platform 1: CPU
12:39:09:WU00:FS00:0x22:Platform 2: OpenCL
12:39:09:WU00:FS00:0x22: opencl-device 0 specified
12:39:09:WU00:FS00:0x22:Platform 3: CUDA
12:39:09:WU00:FS00:0x22: cuda-device 0 specified
12:39:20:WU02:FS01:0x22:Attempting to create OpenCL context:
12:39:20:WU02:FS01:0x22: Configuring platform OpenCL
12:39:21:WU00:FS00:0x22:Attempting to create CUDA context:
12:39:21:WU00:FS00:0x22: Configuring platform CUDA
12:39:30:WU02:FS01:0x22: Using OpenCL on platformId 1 and gpu 0
12:39:30:WU02:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
12:39:31:WU00:FS00:0x22: Using CUDA and gpu 0
12:39:32:WU00:FS00:0x22:Completed 300000 out of 1000000 steps (30%)
12:39:57:Removing old file 'configs/config-20210115-194411.xml'
12:39:57:Saving configuration to config.xml
12:39:57:<config>
12:39:57: <!-- Folding Core -->
12:39:57: <checkpoint v='5'/>
12:39:57:
12:39:57: <!-- Folding Slot Configuration -->
12:39:57: <cause v='COVID_19'/>
12:39:57:
12:39:57: <!-- Network -->
12:39:57: <proxy v=':8080'/>
12:39:57:
12:39:57: <!-- Slot Control -->
12:39:57: <pause-on-battery v='false'/>
12:39:57:
12:39:57: <!-- User Information -->
12:39:57: <passkey v='*****'/>
12:39:57: <user v='Mark_Roggenbuck'/>
12:39:57:
12:39:57: <!-- Folding Slots -->
12:39:57: <slot id='0' type='GPU'>
12:39:57: <pci-bus v='1'/>
12:39:57: <pci-slot v='0'/>
12:39:57: </slot>
12:39:57: <slot id='1' type='GPU'>
12:39:57: <pci-bus v='3'/>
12:39:57: </slot>
12:39:57:</config>
12:41:40:WU00:FS00:0x22:Completed 310000 out of 1000000 steps (31%)
12:43:47:WU00:FS00:0x22:Completed 320000 out of 1000000 steps (32%)
12:43:51:WU02:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
12:45:48:WU00:FS00:0x22:Completed 330000 out of 1000000 steps (33%)
12:47:49:WU00:FS00:0x22:Completed 340000 out of 1000000 steps (34%)
12:48:05:WU02:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
12:49:51:WU00:FS00:0x22:Completed 350000 out of 1000000 steps (35%)
12:49:52:WU00:FS00:0x22:Checkpoint completed at step 350000
12:51:53:WU00:FS00:0x22:Completed 360000 out of 1000000 steps (36%)
12:52:22:WU02:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
12:53:55:WU00:FS00:0x22:Completed 370000 out of 1000000 steps (37%)
12:55:56:WU00:FS00:0x22:Completed 380000 out of 1000000 steps (38%)
12:56:36:WU02:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
12:58:00:WU00:FS00:0x22:Completed 390000 out of 1000000 steps (39%)
13:00:02:WU00:FS00:0x22:Completed 400000 out of 1000000 steps (40%)
13:00:03:WU00:FS00:0x22:Checkpoint completed at step 400000
13:00:59:WU02:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
13:00:59:WU02:FS01:0x22:Checkpoint completed at step 700000
13:02:06:WU00:FS00:0x22:Completed 410000 out of 1000000 steps (41%)
13:04:07:WU00:FS00:0x22:Completed 420000 out of 1000000 steps (42%)
13:05:12:WU02:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
13:06:08:WU00:FS00:0x22:Completed 430000 out of 1000000 steps (43%)
13:08:10:WU00:FS00:0x22:Completed 440000 out of 1000000 steps (44%)
13:09:26:WU02:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
13:10:12:WU00:FS00:0x22:Completed 450000 out of 1000000 steps (45%)
13:10:13:WU00:FS00:0x22:Checkpoint completed at step 450000
13:12:15:WU00:FS00:0x22:Completed 460000 out of 1000000 steps (46%)
13:13:40:WU02:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
13:14:17:WU00:FS00:0x22:Completed 470000 out of 1000000 steps (47%)
13:16:20:WU00:FS00:0x22:Completed 480000 out of 1000000 steps (48%)
13:17:55:WU02:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
13:18:23:WU00:FS00:0x22:Completed 490000 out of 1000000 steps (49%)
13:20:25:WU00:FS00:0x22:Completed 500000 out of 1000000 steps (50%)
13:20:25:WU00:FS00:0x22:Checkpoint completed at step 500000
13:22:10:WU02:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
13:22:11:WU02:FS01:0x22:Checkpoint completed at step 750000
13:22:26:WU00:FS00:0x22:Completed 510000 out of 1000000 steps (51%)
13:24:26:WU00:FS00:0x22:Completed 520000 out of 1000000 steps (52%)
13:26:26:WU00:FS00:0x22:Completed 530000 out of 1000000 steps (53%)
13:26:29:WU02:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
13:28:26:WU00:FS00:0x22:Completed 540000 out of 1000000 steps (54%)
13:30:29:WU00:FS00:0x22:Completed 550000 out of 1000000 steps (55%)
13:30:29:WU00:FS00:0x22:Checkpoint completed at step 550000
13:30:47:WU02:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
13:32:31:WU00:FS00:0x22:Completed 560000 out of 1000000 steps (56%)
13:34:32:WU00:FS00:0x22:Completed 570000 out of 1000000 steps (57%)
13:35:05:WU02:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
13:36:33:WU00:FS00:0x22:Completed 580000 out of 1000000 steps (58%)
13:38:35:WU00:FS00:0x22:Completed 590000 out of 1000000 steps (59%)
13:39:25:WU02:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
13:40:36:WU00:FS00:0x22:Completed 600000 out of 1000000 steps (60%)
13:40:37:WU00:FS00:0x22:Checkpoint completed at step 600000
13:42:38:WU00:FS00:0x22:Completed 610000 out of 1000000 steps (61%)
13:43:42:WU02:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
13:43:43:WU02:FS01:0x22:Checkpoint completed at step 800000
13:44:39:WU00:FS00:0x22:Completed 620000 out of 1000000 steps (62%)
13:46:40:WU00:FS00:0x22:Completed 630000 out of 1000000 steps (63%)
13:48:01:WU02:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
13:48:41:WU00:FS00:0x22:Completed 640000 out of 1000000 steps (64%)
13:50:42:WU00:FS00:0x22:Completed 650000 out of 1000000 steps (65%)
13:50:43:WU00:FS00:0x22:Checkpoint completed at step 650000
13:52:19:WU02:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
13:52:43:WU00:FS00:0x22:Completed 660000 out of 1000000 steps (66%)
13:54:45:WU00:FS00:0x22:Completed 670000 out of 1000000 steps (67%)
13:56:38:WU02:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
13:56:47:WU00:FS00:0x22:Completed 680000 out of 1000000 steps (68%)
13:58:48:WU00:FS00:0x22:Completed 690000 out of 1000000 steps (69%)
14:00:51:WU00:FS00:0x22:Completed 700000 out of 1000000 steps (70%)
14:00:51:WU00:FS00:0x22:Checkpoint completed at step 700000
14:00:58:WU02:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
14:02:53:WU00:FS00:0x22:Completed 710000 out of 1000000 steps (71%)
14:04:56:WU00:FS00:0x22:Completed 720000 out of 1000000 steps (72%)
14:05:34:WU02:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
14:05:35:WU02:FS01:0x22:Checkpoint completed at step 850000
14:07:04:WU00:FS00:0x22:Completed 730000 out of 1000000 steps (73%)
14:09:07:WU00:FS00:0x22:Completed 740000 out of 1000000 steps (74%)
14:10:13:WU02:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
14:11:09:WU00:FS00:0x22:Completed 750000 out of 1000000 steps (75%)
14:11:10:WU00:FS00:0x22:Checkpoint completed at step 750000
14:13:12:WU00:FS00:0x22:Completed 760000 out of 1000000 steps (76%)
14:14:32:WU02:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
14:15:16:WU00:FS00:0x22:Completed 770000 out of 1000000 steps (77%)
14:17:20:WU00:FS00:0x22:Completed 780000 out of 1000000 steps (78%)
14:18:50:WU02:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
14:19:24:WU00:FS00:0x22:Completed 790000 out of 1000000 steps (79%)
14:21:27:WU00:FS00:0x22:Completed 800000 out of 1000000 steps (80%)
14:21:27:WU00:FS00:0x22:Checkpoint completed at step 800000
14:23:06:WU02:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
14:23:30:WU00:FS00:0x22:Completed 810000 out of 1000000 steps (81%)
14:25:33:WU00:FS00:0x22:Completed 820000 out of 1000000 steps (82%)
14:27:25:WU02:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
14:27:26:WU02:FS01:0x22:Checkpoint completed at step 900000
14:27:34:WU00:FS00:0x22:Completed 830000 out of 1000000 steps (83%)
14:29:36:WU00:FS00:0x22:Completed 840000 out of 1000000 steps (84%)
14:31:39:WU00:FS00:0x22:Completed 850000 out of 1000000 steps (85%)
14:31:39:WU00:FS00:0x22:Checkpoint completed at step 850000
14:31:44:WU02:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
14:33:42:WU00:FS00:0x22:Completed 860000 out of 1000000 steps (86%)
14:35:45:WU00:FS00:0x22:Completed 870000 out of 1000000 steps (87%)
14:36:03:WU02:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
14:37:46:WU00:FS00:0x22:Completed 880000 out of 1000000 steps (88%)
14:39:47:WU00:FS00:0x22:Completed 890000 out of 1000000 steps (89%)
14:40:21:WU02:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
14:41:49:WU00:FS00:0x22:Completed 900000 out of 1000000 steps (90%)
14:41:49:WU00:FS00:0x22:Checkpoint completed at step 900000
14:43:51:WU00:FS00:0x22:Completed 910000 out of 1000000 steps (91%)
14:45:52:WU00:FS00:0x22:Completed 920000 out of 1000000 steps (92%)
14:47:52:WU00:FS00:0x22:Completed 930000 out of 1000000 steps (93%)
14:49:53:WU00:FS00:0x22:Completed 940000 out of 1000000 steps (94%)
14:51:54:WU00:FS00:0x22:Completed 950000 out of 1000000 steps (95%)
14:51:54:WU00:FS00:0x22:Checkpoint completed at step 950000
14:53:34:WU02:FS01:0x22:Watchdog triggered, requesting soft shutdown down
14:53:55:WU00:FS00:0x22:Completed 960000 out of 1000000 steps (96%)
14:55:56:WU00:FS00:0x22:Completed 970000 out of 1000000 steps (97%)
14:57:56:WU00:FS00:0x22:Completed 980000 out of 1000000 steps (98%)
14:59:55:WU00:FS00:0x22:Completed 990000 out of 1000000 steps (99%)
14:59:56:WU01:FS00:Connecting to assign1.foldingathome.org:80
14:59:56:WU01:FS00:Assigned to work server 18.188.125.154
14:59:56:WU01:FS00:Requesting new work unit for slot 00: gpu:1:0 TU116 [GeForce GTX 1660 Ti] from 18.188.125.154
14:59:56:WU01:FS00:Connecting to 18.188.125.154:8080
14:59:58:WU01:FS00:Downloading 7.65MiB
14:59:59:WU01:FS00:Download complete
14:59:59:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13440 run:316 clone:12 gen:1 core:0x22 unit:0x0000000c00000001000034800000013c
15:01:55:WU00:FS00:0x22:Completed 1000000 out of 1000000 steps (100%)
15:01:55:WU00:FS00:0x22:Average performance: 71.8802 ns/day
15:01:56:WU00:FS00:0x22:Checkpoint completed at step 1000000
15:02:03:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
15:02:03:WU00:FS00:0x22:Saving result file checkpointIntegrator.xml.bz2
15:02:03:WU00:FS00:0x22:Saving result file checkpointState.xml.bz2
15:02:03:WU00:FS00:0x22:Saving result file globals.csv
15:02:03:WU00:FS00:0x22:Saving result file positions.xtc
15:02:03:WU00:FS00:0x22:Saving result file science.log
15:02:03:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
15:02:04:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:02:04:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13440 run:829 clone:40 gen:1 core:0x22 unit:0x0000002800000001000034800000033d
15:02:04:WU00:FS00:Uploading 8.45MiB to 18.188.125.154
15:02:04:WU01:FS00:Starting
15:02:04:WU00:FS00:Connecting to 18.188.125.154:8080
15:02:04:WU01:FS00:Running FahCore: D:\C_Alt\programs\FAHClient/FAHCoreWrapper.exe D:\C_Alt\data\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8588 -checkpoint 5 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
15:02:04:WU01:FS00:Started FahCore on PID 14092
15:02:04:WU01:FS00:Core PID:11916
15:02:04:WU01:FS00:FahCore 0x22 started
15:02:05:WU01:FS00:0x22:*********************** Log Started 2021-01-23T15:02:04Z ***********************
15:02:05:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
15:02:05:WU01:FS00:0x22: Core: Core22
15:02:05:WU01:FS00:0x22: Type: 0x22
15:02:05:WU01:FS00:0x22: Version: 0.0.13
15:02:05:WU01:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:02:05:WU01:FS00:0x22: Copyright: 2020 foldingathome.org
15:02:05:WU01:FS00:0x22: Homepage: https://foldingathome.org/
15:02:05:WU01:FS00:0x22: Date: Sep 19 2020
15:02:05:WU01:FS00:0x22: Time: 02:35:58
15:02:05:WU01:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
15:02:05:WU01:FS00:0x22: Branch: core22-0.0.13
15:02:05:WU01:FS00:0x22: Compiler: Visual C++ 2015
15:02:05:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:02:05:WU01:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
15:02:05:WU01:FS00:0x22: Platform: win32 10
15:02:05:WU01:FS00:0x22: Bits: 64
15:02:05:WU01:FS00:0x22: Mode: Release
15:02:05:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:02:05:WU01:FS00:0x22: <peastman@stanford.edu>
15:02:05:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 14092 -checkpoint 5
15:02:05:WU01:FS00:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
15:02:05:WU01:FS00:0x22: nvidia -gpu 0 -gpu-usage 100
15:02:05:WU01:FS00:0x22:************************************ libFAH ************************************
15:02:05:WU01:FS00:0x22: Date: Sep 7 2020
15:02:05:WU01:FS00:0x22: Time: 19:09:56
15:02:05:WU01:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
15:02:05:WU01:FS00:0x22: Branch: HEAD
15:02:05:WU01:FS00:0x22:************************************ CBang *************************************
15:02:05:WU01:FS00:0x22: Time: 19:08:30
15:02:05:WU01:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
15:02:05:WU01:FS00:0x22:************************************ System ************************************
15:02:05:WU01:FS00:0x22: CPU: Intel(R) Core(TM) i9-10850K CPU @ 3.60GHz
15:02:05:WU01:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
15:02:05:WU01:FS00:0x22: CPUs: 20
15:02:05:WU01:FS00:0x22: Memory: 31.92GiB
15:02:05:WU01:FS00:0x22:Free Memory: 24.99GiB
15:02:05:WU01:FS00:0x22: Threads: WINDOWS_THREADS
15:02:05:WU01:FS00:0x22: OS Version: 6.2
15:02:05:WU01:FS00:0x22:Has Battery: false
15:02:05:WU01:FS00:0x22: On Battery: false
15:02:05:WU01:FS00:0x22: UTC Offset: -5
15:02:05:WU01:FS00:0x22: PID: 11916
15:02:05:WU01:FS00:0x22: CWD: D:\C_Alt\data\FAHClient\work
15:02:05:WU01:FS00:0x22:************************************ OpenMM ************************************
15:02:05:WU01:FS00:0x22: Revision: 189320d0
15:02:05:WU01:FS00:0x22:********************************************************************************
15:02:05:WU01:FS00:0x22:Project: 13440 (Run 316, Clone 12, Gen 1)
15:02:05:WU01:FS00:0x22:Unit: 0x00000000000000000000000000000000
15:02:05:WU01:FS00:0x22:Reading tar file core.xml
15:02:05:WU01:FS00:0x22:Reading tar file integrator.xml.bz2
15:02:05:WU01:FS00:0x22:Reading tar file state.xml.bz2
15:02:05:WU01:FS00:0x22:Reading tar file system.xml.bz2
15:02:05:WU01:FS00:0x22:Digital signatures verified
15:02:05:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
15:02:05:WU01:FS00:0x22:Version 0.0.13
15:02:05:WU01:FS00:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
15:02:05:WU01:FS00:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
15:02:05:WU01:FS00:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
15:02:05:WU01:FS00:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
15:02:05:WU01:FS00:0x22:There are 4 platforms available.
15:02:05:WU01:FS00:0x22:Platform 0: Reference
15:02:05:WU01:FS00:0x22:Platform 1: CPU
15:02:05:WU01:FS00:0x22:Platform 2: OpenCL
15:02:05:WU01:FS00:0x22: opencl-device 0 specified
15:02:05:WU01:FS00:0x22:Platform 3: CUDA
15:02:05:WU01:FS00:0x22: cuda-device 0 specified
15:02:10:WU00:FS00:Upload 41.44%
15:02:16:WU00:FS00:Upload 91.76%
15:02:16:WU01:FS00:0x22:Attempting to create CUDA context:
15:02:16:WU01:FS00:0x22: Configuring platform CUDA
15:02:17:WU00:FS00:Upload complete
15:02:17:WU00:FS00:Server responded WORK_ACK (400)
15:02:17:WU00:FS00:Final credit estimate, 174281.00 points
15:02:17:WU00:FS00:Cleaning up
15:02:27:WU01:FS00:0x22: Using CUDA and gpu 0
15:02:27:WU01:FS00:0x22:Completed 0 out of 1000000 steps (0%)
15:02:28:WU01:FS00:0x22:Checkpoint completed at step 0
15:03:34:WU02:FS01:0x22:Watchdog shutdown failed, hard shutdown triggered
15:03:34:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
15:03:34:WARNING:WU02:FS01:FahCore returned: WU_STALLED (127 = 0x7f)
15:03:35:WU02:FS01:Starting
15:03:35:WU02:FS01:Running FahCore: D:\C_Alt\programs\FAHClient/FAHCoreWrapper.exe D:\C_Alt\data\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8588 -checkpoint 5 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
15:03:35:WU02:FS01:Started FahCore on PID 9448
15:03:35:WU02:FS01:Core PID:13692
15:03:35:WU02:FS01:FahCore 0x22 started
15:03:35:WU02:FS01:0x22:*********************** Log Started 2021-01-23T15:03:35Z ***********************
15:03:35:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:03:35:WU02:FS01:0x22: Core: Core22
15:03:35:WU02:FS01:0x22: Type: 0x22
15:03:35:WU02:FS01:0x22: Version: 0.0.13
15:03:35:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:03:35:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
15:03:35:WU02:FS01:0x22: Homepage: https://foldingathome.org/
15:03:35:WU02:FS01:0x22: Date: Sep 19 2020
15:03:35:WU02:FS01:0x22: Time: 02:35:58
15:03:35:WU02:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
15:03:35:WU02:FS01:0x22: Branch: core22-0.0.13
15:03:35:WU02:FS01:0x22: Compiler: Visual C++ 2015
15:03:35:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:03:35:WU02:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
15:03:35:WU02:FS01:0x22: Platform: win32 10
15:03:35:WU02:FS01:0x22: Bits: 64
15:03:35:WU02:FS01:0x22: Mode: Release
15:03:35:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:03:35:WU02:FS01:0x22: <peastman@stanford.edu>
15:03:35:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 9448 -checkpoint 5
15:03:35:WU02:FS01:0x22: -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
15:03:35:WU02:FS01:0x22: -gpu-usage 100
15:03:35:WU02:FS01:0x22:************************************ libFAH ************************************
15:03:35:WU02:FS01:0x22: Date: Sep 7 2020
15:03:35:WU02:FS01:0x22: Time: 19:09:56
15:03:35:WU02:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
15:03:35:WU02:FS01:0x22: Branch: HEAD
15:03:35:WU02:FS01:0x22:************************************ CBang *************************************
15:03:35:WU02:FS01:0x22: Time: 19:08:30
15:03:35:WU02:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
15:03:35:WU02:FS01:0x22:************************************ System ************************************
15:03:35:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i9-10850K CPU @ 3.60GHz
15:03:35:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
15:03:35:WU02:FS01:0x22: CPUs: 20
15:03:35:WU02:FS01:0x22: Memory: 31.92GiB
15:03:35:WU02:FS01:0x22:Free Memory: 24.93GiB
15:03:35:WU02:FS01:0x22: Threads: WINDOWS_THREADS
15:03:35:WU02:FS01:0x22: OS Version: 6.2
15:03:35:WU02:FS01:0x22:Has Battery: false
15:03:35:WU02:FS01:0x22: On Battery: false
15:03:35:WU02:FS01:0x22: UTC Offset: -5
15:03:35:WU02:FS01:0x22: PID: 13692
15:03:35:WU02:FS01:0x22: CWD: D:\C_Alt\data\FAHClient\work
15:03:35:WU02:FS01:0x22:************************************ OpenMM ************************************
15:03:35:WU02:FS01:0x22: Revision: 189320d0
15:03:35:WU02:FS01:0x22:********************************************************************************
15:03:35:WU02:FS01:0x22:Project: 13440 (Run 709, Clone 32, Gen 1)
15:03:35:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
15:03:35:WU02:FS01:0x22:Digital signatures verified
15:03:35:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:03:35:WU02:FS01:0x22:Version 0.0.13
15:03:35:WU02:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
15:03:35:WU02:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
15:03:35:WU02:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
15:03:35:WU02:FS01:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
15:03:35:WU02:FS01:0x22:There are 3 platforms available.
15:03:35:WU02:FS01:0x22:Platform 0: Reference
15:03:35:WU02:FS01:0x22:Platform 1: CPU
15:03:35:WU02:FS01:0x22:Platform 2: OpenCL
15:03:35:WU02:FS01:0x22: opencl-device 0 specified
15:03:47:WU02:FS01:0x22:Attempting to create OpenCL context:
15:03:47:WU02:FS01:0x22: Configuring platform OpenCL
15:03:56:WU02:FS01:0x22: Using OpenCL on platformId 1 and gpu 0
15:03:57:WU02:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
Update:
This error continued to happen, so I went back to 20.11.2 drivers. I have not seen a problem since then.
I do not recommend anything, but you can draw you own conclusions.
Thanks for the heads up ... I'll mention your solution to others (and link this thread) if I see them reporting stalled wus
- Hardware configuration: Ryzen 2700x 16gb ram fury nano 4gb + Ryzen 2700x 32gb rsm Navi 5700xt 8gb
I have the same issue running windows 19042 with that driver. RX 580 8gb. I may get a few percentage into the WU and it crashes. in the driver hud it says wattman encountered an error and restarted.... no overclock and countless units prior driver ok.
