155.247.166.219 sent 1.5 year old WU [Project 14188]
SilvioMartin
Hardware configuration: iMac 2017 Intel Quad-Core i5 3,4 GHz, 8 GB RAM, Radeon Pro 560 4 GB, typically with the latest macOS update. 5 Raspberry Pi 4B (2 GB).
Post by SilvioMartin »
Mod note: merged two topics about Project 14188 WUs
The server 155.247.166.219 sent the following WU to my Mac yesterday: Project 14188, run 5, clone 1, gen 1. The project ID is much smaller than what I see else nowadays. So I checked the status of the WU. it was successfully returned by another user on August 22nd 2019, thus almost 1.5 years ago:
https://apps.foldingathome.org/wu?proje ... ne=1&gen=1
I don't think that this is intended. So here is my log for debugging. I deleted the interior of all blocks, where it just reports the progress, because the original log file is too large for uploading here,
*********************** Log Started 2021-01-18T07:12:58Z ***********************
07:12:58:Trying to access database...
07:13:04:Successfully acquired database lock
07:13:34:Read GPUs.txt
07:13:34:Enabled folding slot 00: PAUSED cpu:4 (by user)
07:13:34:****************************** FAHClient ******************************
07:13:34:    Version: 7.6.13
07:13:34:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:13:34:  Copyright: 2020 foldingathome.org
07:13:34:   Homepage: https://foldingathome.org/
07:13:34:       Date: Apr 27 2020
07:13:34:       Time: 21:20:45
07:13:34:   Revision: 5a652817f46116b6e135503af97f18e094414e3b
07:13:34:     Branch: master
07:13:34:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
07:13:34:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
07:13:34:             -Wno-unused-local-typedefs -stdlib=libc++
07:13:34:   Platform: darwin 19.2.0
07:13:34:       Bits: 64
07:13:34:       Mode: Release
07:13:34:     Config: /Library/Application Support/FAHClient/config.xml
07:13:34:******************************** CBang ********************************
07:13:34:       Date: Apr 24 2020
07:13:34:       Time: 17:07:50
07:13:34:   Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
07:13:34:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
07:13:34:       Bits: 64
07:13:34:******************************* System ********************************
07:13:34:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
07:13:34:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:13:34:       CPUs: 4
07:13:34:     Memory: 8.00GiB
07:13:34:Free Memory: 5.43GiB
07:13:34:    Threads: POSIX_THREADS
07:13:34: OS Version: 10.16
07:13:34:Has Battery: false
07:13:34: On Battery: false
07:13:34: UTC Offset: 1
07:13:34:        PID: 69
07:13:34:        CWD: /Library/Application Support/FAHClient
07:13:34:         OS: Darwin 20.2.0 x86_64
07:13:34:    OS Arch: AMD64
07:13:34:       GPUs: 2
07:13:34:      GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Baffin XT [Radeon RX 460]
07:13:34:      GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 630]
07:13:34:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
07:13:34:             dlopen(libcuda.dylib, 1): image not found
07:13:34:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
07:13:34:             dlopen(libOpenCL.dylib, 1): image not found
07:13:34:******************************* libFAH ********************************
07:13:34:       Date: Apr 15 2020
07:13:34:       Time: 14:43:28
07:13:34:   Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:13:34:       Bits: 64
07:13:34:***********************************************************************
07:13:34:<config>
07:13:34:  <!-- Network -->
07:13:34:  <proxy v=':8080'/>
07:13:34:
07:13:34:  <!-- Slot Control -->
07:13:34:  <power v='full'/>
07:13:34:
07:13:34:  <!-- User Information -->
07:13:34:  <passkey v='*****'/>
07:13:34:  <user v='SilvioMartin'/>
07:13:34:
07:13:34:  <!-- Folding Slots -->
07:13:34:  <slot id='0' type='CPU'>
07:13:34:    <paused v='true'/>
07:13:34:  </slot>
07:13:34:</config>
07:18:30:FS00:Unpaused
07:18:30:WU00:FS00:Connecting to assign1.foldingathome.org:80
07:18:31:WU00:FS00:Assigned to work server 206.223.170.146
07:18:31:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 206.223.170.146
07:18:31:WU00:FS00:Connecting to 206.223.170.146:8080
07:18:32:WU00:FS00:Downloading 1.25MiB
07:18:33:WU00:FS00:Download complete
07:18:33:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16452 run:27 clone:77 gen:18 core:0xa7 unit:0x0000004d00000012000040440000001b
07:18:33:WU00:FS00:Starting
07:18:33:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 69 -checkpoint 15 -np 4
07:18:33:WU00:FS00:Started FahCore on PID 710
07:18:34:WU00:FS00:Core PID:712
07:18:34:WU00:FS00:FahCore 0xa7 started
07:18:36:WU00:FS00:0xa7:*********************** Log Started 2021-01-18T07:18:35Z ***********************
07:18:36:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:18:36:WU00:FS00:0xa7:       Type: 0xa7
07:18:36:WU00:FS00:0xa7:       Core: Gromacs
07:18:36:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 710 -checkpoint 15 -np 4
07:18:36:WU00:FS00:0xa7:************************************ CBang *************************************
07:18:36:WU00:FS00:0xa7:       Date: Nov 27 2019
07:18:36:WU00:FS00:0xa7:       Time: 03:27:01
07:18:36:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
07:18:36:WU00:FS00:0xa7:     Branch: master
07:18:36:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
07:18:36:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
07:18:36:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
07:18:36:WU00:FS00:0xa7:   Platform: darwin 19.0.0
07:18:36:WU00:FS00:0xa7:       Bits: 64
07:18:36:WU00:FS00:0xa7:       Mode: Release
07:18:36:WU00:FS00:0xa7:************************************ System ************************************
07:18:36:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
07:18:36:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:18:36:WU00:FS00:0xa7:       CPUs: 4
07:18:36:WU00:FS00:0xa7:     Memory: 8.00GiB
07:18:36:WU00:FS00:0xa7:Free Memory: 1.40GiB
07:18:36:WU00:FS00:0xa7:    Threads: POSIX_THREADS
07:18:36:WU00:FS00:0xa7: OS Version: 10.16
07:18:36:WU00:FS00:0xa7:Has Battery: false
07:18:36:WU00:FS00:0xa7: On Battery: false
07:18:36:WU00:FS00:0xa7: UTC Offset: 1
07:18:36:WU00:FS00:0xa7:        PID: 712
07:18:36:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
07:18:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:18:36:WU00:FS00:0xa7:    Version: 0.0.19
07:18:36:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:18:36:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:18:36:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:18:36:WU00:FS00:0xa7:       Date: Nov 25 2019
07:18:36:WU00:FS00:0xa7:       Time: 16:41:59
07:18:36:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
07:18:36:WU00:FS00:0xa7:************************************ Build *************************************
07:18:36:WU00:FS00:0xa7:       SIMD: avx_256
07:18:36:WU00:FS00:0xa7:********************************************************************************
07:18:36:WU00:FS00:0xa7:Project: 16452 (Run 27, Clone 77, Gen 18)
07:18:36:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
07:18:36:WU00:FS00:0xa7:Reading tar file core.xml
07:18:36:WU00:FS00:0xa7:Reading tar file frame18.tpr
07:18:36:WU00:FS00:0xa7:Digital signatures verified
07:18:36:WU00:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -x frame18.xtc -cpt 15 -nt 4
07:18:36:WU00:FS00:0xa7:Steps: first=9000000 total=500000
07:18:39:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
07:19:10:Removing old file 'configs/config-20201208-213602.xml'
07:19:10:Saving configuration to config.xml
07:19:10:<config>
07:19:10:  <!-- Network -->
07:19:10:  <proxy v=':8080'/>
07:19:10:
07:19:10:  <!-- Slot Control -->
07:19:10:  <power v='full'/>
07:19:10:
07:19:10:  <!-- User Information -->
07:19:10:  <passkey v='*****'/>
07:19:10:  <user v='SilvioMartin'/>
07:19:10:
07:19:10:  <!-- Folding Slots -->
07:19:10:  <slot id='0' type='CPU'/>
07:19:10:</config>
07:19:43:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
08:56:33:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
08:56:34:WU01:FS00:Connecting to assign1.foldingathome.org:80
08:56:35:WU01:FS00:Assigned to work server 66.170.111.50
08:56:35:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 66.170.111.50
08:56:35:WU01:FS00:Connecting to 66.170.111.50:8080
08:56:35:WU01:FS00:Downloading 7.36MiB
08:56:41:WU01:FS00:Download 60.27%
08:56:43:WU01:FS00:Download complete
08:56:44:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17415 run:0 clone:461 gen:426 core:0xa7 unit:0x000001cd000001aa0000440700000000
08:57:32:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
08:57:34:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
08:57:34:WU00:FS00:0xa7:Saving result file frame18.trr
08:57:34:WU00:FS00:0xa7:Saving result file frame18.xtc
08:57:34:WU00:FS00:0xa7:Saving result file md.log
08:57:34:WU00:FS00:0xa7:Saving result file science.log
08:57:35:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:57:35:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:57:35:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16452 run:27 clone:77 gen:18 core:0xa7 unit:0x0000004d00000012000040440000001b
08:57:35:WU00:FS00:Uploading 1.41MiB to 206.223.170.146
08:57:35:WU00:FS00:Connecting to 206.223.170.146:8080
08:57:36:WU01:FS00:Starting
08:57:36:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 706 -lifeline 69 -checkpoint 15 -np 4
08:57:36:WU01:FS00:Started FahCore on PID 1147
08:57:36:WU01:FS00:Core PID:1148
08:57:36:WU01:FS00:FahCore 0xa7 started
08:57:37:WU01:FS00:0xa7:*********************** Log Started 2021-01-18T08:57:36Z ***********************
08:57:37:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:57:37:WU01:FS00:0xa7:       Type: 0xa7
08:57:37:WU01:FS00:0xa7:       Core: Gromacs
08:57:37:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1147 -checkpoint 15 -np 4
08:57:37:WU01:FS00:0xa7:************************************ CBang *************************************
08:57:37:WU01:FS00:0xa7:       Date: Nov 27 2019
08:57:37:WU01:FS00:0xa7:       Time: 03:27:01
08:57:37:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
08:57:37:WU01:FS00:0xa7:     Branch: master
08:57:37:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
08:57:37:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
08:57:37:WU01:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
08:57:37:WU01:FS00:0xa7:   Platform: darwin 19.0.0
08:57:37:WU01:FS00:0xa7:       Bits: 64
08:57:37:WU01:FS00:0xa7:       Mode: Release
08:57:37:WU01:FS00:0xa7:************************************ System ************************************
08:57:37:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
08:57:37:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
08:57:37:WU01:FS00:0xa7:       CPUs: 4
08:57:37:WU01:FS00:0xa7:     Memory: 8.00GiB
08:57:37:WU01:FS00:0xa7:Free Memory: 1.38GiB
08:57:37:WU01:FS00:0xa7:    Threads: POSIX_THREADS
08:57:37:WU01:FS00:0xa7: OS Version: 10.16
08:57:37:WU01:FS00:0xa7:Has Battery: false
08:57:37:WU01:FS00:0xa7: On Battery: false
08:57:37:WU01:FS00:0xa7: UTC Offset: 1
08:57:37:WU01:FS00:0xa7:        PID: 1148
08:57:37:WU01:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
08:57:37:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:57:37:WU01:FS00:0xa7:    Version: 0.0.19
08:57:37:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:57:37:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:57:37:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
08:57:37:WU01:FS00:0xa7:       Date: Nov 25 2019
08:57:37:WU01:FS00:0xa7:       Time: 16:41:59
08:57:37:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
08:57:37:WU01:FS00:0xa7:************************************ Build *************************************
08:57:37:WU01:FS00:0xa7:       SIMD: avx_256
08:57:37:WU01:FS00:0xa7:********************************************************************************
08:57:37:WU01:FS00:0xa7:Project: 17415 (Run 0, Clone 461, Gen 426)
08:57:37:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
08:57:37:WU01:FS00:0xa7:Reading tar file core.xml
08:57:37:WU01:FS00:0xa7:Reading tar file frame426.tpr
08:57:37:WU01:FS00:0xa7:Digital signatures verified
08:57:37:WU01:FS00:0xa7:Calling: mdrun -s frame426.tpr -o frame426.trr -x frame426.xtc -cpt 15 -nt 4
08:57:37:WU01:FS00:0xa7:Steps: first=53250000 total=125000
08:57:41:WU00:FS00:Upload complete
08:57:41:WU00:FS00:Server responded WORK_ACK (400)
08:57:41:WU00:FS00:Final credit estimate, 3929.00 points
08:57:41:WU00:FS00:Cleaning up
08:57:42:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
08:5909:31:46:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
09:32:18:FS00:Shutting core down
09:32:18:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 1148
09:32:18:WU01:FS00:0xa7:Exiting, please wait. . .
09:32:21:Removing old file 'configs/config-20201209-145634.xml'
09:32:21:Saving configuration to config.xml
09:32:21:<config>
09:32:21:  <!-- Network -->
09:32:21:  <proxy v=':8080'/>
09:32:21:
09:32:21:  <!-- User Information -->
09:32:21:  <passkey v='*****'/>
09:32:21:  <user v='SilvioMartin'/>
09:32:21:
09:32:21:  <!-- Folding Slots -->
09:32:21:  <slot id='0' type='CPU'/>
09:32:21:</config>
09:32:27:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:32:28:WU01:FS00:Starting
[93m09:32:28:WARNING:WU01:FS00:Changed SMP threads from 4 to 3 this can cause some work units to fail[0m
09:32:28:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 706 -lifeline 69 -checkpoint 15 -np 3
09:32:28:WU01:FS00:Started FahCore on PID 1255
09:32:28:WU01:FS00:Core PID:1258
09:32:28:WU01:FS00:FahCore 0xa7 started
09:32:29:WU01:FS00:0xa7:*********************** Log Started 2021-01-18T09:32:29Z ***********************
09:32:29:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:32:29:WU01:FS00:0xa7:       Type: 0xa7
09:32:29:WU01:FS00:0xa7:       Core: Gromacs
09:32:29:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1255 -checkpoint 15 -np 3
09:32:29:WU01:FS00:0xa7:************************************ CBang *************************************
09:32:29:WU01:FS00:0xa7:       Date: Nov 27 2019
09:32:29:WU01:FS00:0xa7:       Time: 03:27:01
09:32:29:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:32:29:WU01:FS00:0xa7:     Branch: master
09:32:29:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
09:32:29:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
09:32:29:WU01:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
09:32:29:WU01:FS00:0xa7:   Platform: darwin 19.0.0
09:32:29:WU01:FS00:0xa7:       Bits: 64
09:32:29:WU01:FS00:0xa7:       Mode: Release
09:32:29:WU01:FS00:0xa7:************************************ System ************************************
09:32:29:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
09:32:29:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:32:29:WU01:FS00:0xa7:       CPUs: 4
09:32:29:WU01:FS00:0xa7:     Memory: 8.00GiB
09:32:29:WU01:FS00:0xa7:Free Memory: 1.48GiB
09:32:29:WU01:FS00:0xa7:    Threads: POSIX_THREADS
09:32:29:WU01:FS00:0xa7: OS Version: 10.16
09:32:29:WU01:FS00:0xa7:Has Battery: false
09:32:29:WU01:FS00:0xa7: On Battery: false
09:32:29:WU01:FS00:0xa7: UTC Offset: 1
09:32:29:WU01:FS00:0xa7:        PID: 1258
09:32:29:WU01:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
09:32:29:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:32:29:WU01:FS00:0xa7:    Version: 0.0.19
09:32:29:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:32:29:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:32:29:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:32:29:WU01:FS00:0xa7:       Date: Nov 25 2019
09:32:29:WU01:FS00:0xa7:       Time: 16:41:59
09:32:29:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:32:29:WU01:FS00:0xa7:************************************ Build *************************************
09:32:29:WU01:FS00:0xa7:       SIMD: avx_256
09:32:29:WU01:FS00:0xa7:********************************************************************************
09:32:29:WU01:FS00:0xa7:Project: 17415 (Run 0, Clone 461, Gen 426)
09:32:29:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
09:32:29:WU01:FS00:0xa7:Digital signatures verified
09:32:29:WU01:FS00:0xa7:Calling: mdrun -s frame426.tpr -o frame426.trr -x frame426.xtc -cpi state.cpt -cpt 15 -nt 3
09:32:29:WU01:FS00:0xa7:Steps: first=53250000 total=125000
09:32:30:WU01:FS00:0xa7:Completed 27912 out of 125000 steps (22%)
11:50:30:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
11:50:31:WU00:FS00:Connecting to assign1.foldingathome.org:80
[93m11:50:33:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
11:50:33:WU00:FS00:Connecting to assign2.foldingathome.org:80
11:50:34:WU00:FS00:Assigned to work server 66.170.111.50
11:50:34:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 66.170.111.50
11:50:34:WU00:FS00:Connecting to 66.170.111.50:8080
11:50:35:WU00:FS00:Downloading 6.93MiB
11:50:41:WU00:FS00:Download 67.60%
11:50:43:WU00:FS00:Download complete
11:50:44:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17409 run:0 clone:183 gen:126 core:0xa7 unit:0x000000b70000007e0000440100000000
11:52:15:WU01:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
11:52:22:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
11:52:22:WU01:FS00:0xa7:Saving result file frame426.trr
11:52:22:WU01:FS00:0xa7:Saving result file frame426.xtc
11:52:22:WU01:FS00:0xa7:Saving result file md.log
11:52:22:WU01:FS00:0xa7:Saving result file science.log
11:52:22:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
11:52:23:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:52:23:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:17415 run:0 clone:461 gen:426 core:0xa7 unit:0x000001cd000001aa0000440700000000
11:52:23:WU01:FS00:Uploading 9.98MiB to 66.170.111.50
11:52:23:WU01:FS00:Connecting to 66.170.111.50:8080
11:52:23:WU00:FS00:Starting
11:52:23:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 69 -checkpoint 15 -np 3
11:52:23:WU00:FS00:Started FahCore on PID 1702
11:52:23:WU00:FS00:Core PID:1703
11:52:23:WU00:FS00:FahCore 0xa7 started
11:52:23:WU00:FS00:0xa7:*********************** Log Started 2021-01-18T11:52:23Z ***********************
11:52:23:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:52:23:WU00:FS00:0xa7:       Type: 0xa7
11:52:23:WU00:FS00:0xa7:       Core: Gromacs
11:52:23:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1702 -checkpoint 15 -np 3
11:52:23:WU00:FS00:0xa7:************************************ CBang *************************************
11:52:23:WU00:FS00:0xa7:       Date: Nov 27 2019
11:52:23:WU00:FS00:0xa7:       Time: 03:27:01
11:52:23:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:52:23:WU00:FS00:0xa7:     Branch: master
11:52:23:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
11:52:23:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
11:52:23:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
11:52:23:WU00:FS00:0xa7:   Platform: darwin 19.0.0
11:52:23:WU00:FS00:0xa7:       Bits: 64
11:52:23:WU00:FS00:0xa7:       Mode: Release
11:52:23:WU00:FS00:0xa7:************************************ System ************************************
11:52:23:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
11:52:23:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
11:52:23:WU00:FS00:0xa7:       CPUs: 4
11:52:23:WU00:FS00:0xa7:     Memory: 8.00GiB
11:52:23:WU00:FS00:0xa7:Free Memory: 1.06GiB
11:52:23:WU00:FS00:0xa7:    Threads: POSIX_THREADS
11:52:23:WU00:FS00:0xa7: OS Version: 10.16
11:52:23:WU00:FS00:0xa7:Has Battery: false
11:52:23:WU00:FS00:0xa7: On Battery: false
11:52:23:WU00:FS00:0xa7: UTC Offset: 1
11:52:23:WU00:FS00:0xa7:        PID: 1703
11:52:23:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
11:52:23:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:52:23:WU00:FS00:0xa7:    Version: 0.0.19
11:52:23:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:52:23:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:52:23:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:52:23:WU00:FS00:0xa7:       Date: Nov 25 2019
11:52:23:WU00:FS00:0xa7:       Time: 16:41:59
11:52:23:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:52:23:WU00:FS00:0xa7:************************************ Build *************************************
11:52:23:WU00:FS00:0xa7:       SIMD: avx_256
11:52:23:WU00:FS00:0xa7:********************************************************************************
11:52:23:WU00:FS00:0xa7:Project: 17409 (Run 0, Clone 183, Gen 126)
11:52:23:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
11:52:23:WU00:FS00:0xa7:Reading tar file core.xml
11:52:23:WU00:FS00:0xa7:Reading tar file frame126.tpr
11:52:23:WU00:FS00:0xa7:Digital signatures verified
11:52:23:WU00:FS00:0xa7:Calling: mdrun -s frame126.tpr -o frame126.trr -x frame126.xtc -cpt 15 -nt 3
11:52:23:WU00:FS00:0xa7:Steps: first=15750000 total=125000
11:52:28:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
11:52:29:WU01:FS00:Upload 15.65%
11:52:35:WU01:FS00:Upload 32.56%
11:52:41:WU01:FS00:Upload 50.09%
11:52:47:WU01:FS00:Upload 65.74%
11:52:53:WU01:FS00:Upload 75.14%
11:52:59:WU01:FS00:Upload 83.90%
11:53:05:WU01:FS00:Upload 98.30%
11:53:06:WU01:FS00:Upload complete
11:53:06:WU01:FS00:Server responded WORK_ACK (400)
11:53:06:WU01:FS00:Final credit estimate, 4361.00 points
11:53:06:WU01:FS00:Cleaning up
11:54:05:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
13:12:32:WU00:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
******************************* Date: 2021-01-18 *******************************
13:14:09:WU00:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
14:36:04:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
14:36:05:WU01:FS00:Connecting to assign1.foldingathome.org:80
14:36:06:WU01:FS00:Assigned to work server 66.170.111.50
14:36:06:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 66.170.111.50
14:36:06:WU01:FS00:Connecting to 66.170.111.50:8080
14:36:07:WU01:FS00:Downloading 7.36MiB
14:36:13:WU01:FS00:Download 53.49%
14:36:17:WU01:FS00:Download complete
14:36:18:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17411 run:0 clone:386 gen:414 core:0xa7 unit:0x000001820000019e0000440300000000
14:37:50:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
14:37:59:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
14:37:59:WU00:FS00:0xa7:Saving result file frame126.trr
14:37:59:WU00:FS00:0xa7:Saving result file frame126.xtc
14:38:00:WU00:FS00:0xa7:Saving result file md.log
14:38:00:WU00:FS00:0xa7:Saving result file science.log
14:38:00:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
14:38:00:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:38:00:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17409 run:0 clone:183 gen:126 core:0xa7 unit:0x000000b70000007e0000440100000000
14:38:00:WU00:FS00:Uploading 9.20MiB to 66.170.111.50
14:38:00:WU01:FS00:Starting
14:38:00:WU00:FS00:Connecting to 66.170.111.50:8080
14:38:00:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 706 -lifeline 69 -checkpoint 15 -np 3
14:38:00:WU01:FS00:Started FahCore on PID 2169
14:38:00:WU01:FS00:Core PID:2170
14:38:00:WU01:FS00:FahCore 0xa7 started
14:38:02:WU01:FS00:0xa7:*********************** Log Started 2021-01-18T14:38:01Z ***********************
14:38:02:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:38:02:WU01:FS00:0xa7:       Type: 0xa7
14:38:02:WU01:FS00:0xa7:       Core: Gromacs
14:38:02:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2169 -checkpoint 15 -np 3
14:38:02:WU01:FS00:0xa7:************************************ CBang *************************************
14:38:02:WU01:FS00:0xa7:       Date: Nov 27 2019
14:38:02:WU01:FS00:0xa7:       Time: 03:27:01
14:38:02:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
14:38:02:WU01:FS00:0xa7:     Branch: master
14:38:02:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
14:38:02:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
14:38:02:WU01:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
14:38:02:WU01:FS00:0xa7:   Platform: darwin 19.0.0
14:38:02:WU01:FS00:0xa7:       Bits: 64
14:38:02:WU01:FS00:0xa7:       Mode: Release
14:38:02:WU01:FS00:0xa7:************************************ System ************************************
14:38:02:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
14:38:02:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
14:38:02:WU01:FS00:0xa7:       CPUs: 4
14:38:02:WU01:FS00:0xa7:     Memory: 8.00GiB
14:38:02:WU01:FS00:0xa7:Free Memory: 739.67MiB
14:38:02:WU01:FS00:0xa7:    Threads: POSIX_THREADS
14:38:02:WU01:FS00:0xa7: OS Version: 10.16
14:38:02:WU01:FS00:0xa7:Has Battery: false
14:38:02:WU01:FS00:0xa7: On Battery: false
14:38:02:WU01:FS00:0xa7: UTC Offset: 1
14:38:02:WU01:FS00:0xa7:        PID: 2170
14:38:02:WU01:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
14:38:02:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
14:38:02:WU01:FS00:0xa7:    Version: 0.0.19
14:38:02:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:38:02:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:38:02:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
14:38:02:WU01:FS00:0xa7:       Date: Nov 25 2019
14:38:02:WU01:FS00:0xa7:       Time: 16:41:59
14:38:02:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
14:38:02:WU01:FS00:0xa7:************************************ Build *************************************
14:38:02:WU01:FS00:0xa7:       SIMD: avx_256
14:38:02:WU01:FS00:0xa7:********************************************************************************
14:38:02:WU01:FS00:0xa7:Project: 17411 (Run 0, Clone 386, Gen 414)
14:38:02:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
14:38:02:WU01:FS00:0xa7:Reading tar file core.xml
14:38:02:WU01:FS00:0xa7:Reading tar file frame414.tpr
14:38:02:WU01:FS00:0xa7:Digital signatures verified
14:38:02:WU01:FS00:0xa7:Calling: mdrun -s frame414.tpr -o frame414.trr -x frame414.xtc -cpt 15 -nt 3
14:38:02:WU01:FS00:0xa7:Steps: first=51750000 total=125000
14:38:06:WU00:FS00:Upload 16.30%
14:38:07:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
14:38:12:WU00:FS00:Upload 36.00%
14:38:18:WU00:FS00:Upload 56.38%
14:38:24:WU00:FS00:Upload 76.09%
14:38:30:WU00:FS00:Upload 95.79%
14:38:32:WU00:FS00:Upload complete
14:38:32:WU00:FS00:Server responded WORK_ACK (400)
14:38:32:WU00:FS00:Final credit estimate, 3845.00 points
14:38:32:WU00:FS00:Cleaning up
14:39:59:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
17:34:37:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
17:34:38:WU00:FS00:Connecting to assign1.foldingathome.org:80
17:34:39:WU00:FS00:Assigned to work server 66.170.111.50
17:34:39:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 66.170.111.50
17:34:39:WU00:FS00:Connecting to 66.170.111.50:8080
[91m17:34:40:ERROR:WU00:FS00:Exception: Server did not assign work unit[0m
17:34:40:WU00:FS00:Connecting to assign1.foldingathome.org:80
[93m17:34:41:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
17:34:41:WU00:FS00:Connecting to assign2.foldingathome.org:80
17:34:42:WU00:FS00:Assigned to work server 155.247.166.219
17:34:42:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 155.247.166.219
17:34:42:WU00:FS00:Connecting to 155.247.166.219:8080
17:34:47:WU00:FS00:Downloading 3.13MiB
17:34:52:WU00:FS00:Download complete
17:34:52:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14188 run:5 clone:1 gen:1 core:0xa7 unit:0x00000001000000010000376c00000005
17:36:24:WU01:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
17:36:34:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
17:36:34:WU01:FS00:0xa7:Saving result file frame414.trr
17:36:34:WU01:FS00:0xa7:Saving result file frame414.xtc
17:36:35:WU01:FS00:0xa7:Saving result file md.log
17:36:35:WU01:FS00:0xa7:Saving result file science.log
17:36:35:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
17:36:35:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:36:35:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:17411 run:0 clone:386 gen:414 core:0xa7 unit:0x000001820000019e0000440300000000
17:36:35:WU01:FS00:Uploading 9.95MiB to 66.170.111.50
17:36:35:WU01:FS00:Connecting to 66.170.111.50:8080
17:36:35:WU00:FS00:Starting
17:36:35:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 69 -checkpoint 15 -np 3
17:36:35:WU00:FS00:Started FahCore on PID 2567
17:36:35:WU00:FS00:Core PID:2568
17:36:35:WU00:FS00:FahCore 0xa7 started
17:36:35:WU00:FS00:0xa7:*********************** Log Started 2021-01-18T17:36:35Z ***********************
17:36:35:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:36:35:WU00:FS00:0xa7:       Type: 0xa7
17:36:35:WU00:FS00:0xa7:       Core: Gromacs
17:36:35:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 2567 -checkpoint 15 -np 3
17:36:35:WU00:FS00:0xa7:************************************ CBang *************************************
17:36:35:WU00:FS00:0xa7:       Date: Nov 27 2019
17:36:35:WU00:FS00:0xa7:       Time: 03:27:01
17:36:35:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
17:36:35:WU00:FS00:0xa7:     Branch: master
17:36:35:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
17:36:35:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
17:36:35:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
17:36:35:WU00:FS00:0xa7:   Platform: darwin 19.0.0
17:36:35:WU00:FS00:0xa7:       Bits: 64
17:36:35:WU00:FS00:0xa7:       Mode: Release
17:36:35:WU00:FS00:0xa7:************************************ System ************************************
17:36:35:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
17:36:35:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
17:36:35:WU00:FS00:0xa7:       CPUs: 4
17:36:35:WU00:FS00:0xa7:     Memory: 8.00GiB
17:36:35:WU00:FS00:0xa7:Free Memory: 1.21GiB
17:36:35:WU00:FS00:0xa7:    Threads: POSIX_THREADS
17:36:35:WU00:FS00:0xa7: OS Version: 10.16
17:36:35:WU00:FS00:0xa7:Has Battery: false
17:36:35:WU00:FS00:0xa7: On Battery: false
17:36:35:WU00:FS00:0xa7: UTC Offset: 1
17:36:35:WU00:FS00:0xa7:        PID: 2568
17:36:35:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
17:36:35:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:36:35:WU00:FS00:0xa7:    Version: 0.0.19
17:36:35:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:36:35:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:36:35:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:36:35:WU00:FS00:0xa7:       Date: Nov 25 2019
17:36:35:WU00:FS00:0xa7:       Time: 16:41:59
17:36:35:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
17:36:35:WU00:FS00:0xa7:************************************ Build *************************************
17:36:35:WU00:FS00:0xa7:       SIMD: avx_256
17:36:35:WU00:FS00:0xa7:********************************************************************************
17:36:35:WU00:FS00:0xa7:Project: 14188 (Run 5, Clone 1, Gen 1)
17:36:35:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
17:36:35:WU00:FS00:0xa7:Reading tar file core.xml
17:36:35:WU00:FS00:0xa7:Reading tar file frame1.tpr
17:36:35:WU00:FS00:0xa7:Digital signatures verified
17:36:35:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 3
17:36:36:WU00:FS00:0xa7:Steps: first=1250000 total=1250000
17:36:36:WU00:FS00:0xa7:Completed 1 out of 1250000 steps (0%)
17:36:41:WU01:FS00:Upload 12.56%
17:36:47:WU01:FS00:Upload 30.78%
17:36:53:WU01:FS00:Upload 44.60%
17:36:59:WU01:FS00:Upload 57.17%
17:37:05:WU01:FS00:Upload 71.61%
17:37:11:WU01:FS00:Upload 88.57%
17:37:17:WU01:FS00:Upload complete
17:37:17:WU01:FS00:Server responded WORK_ACK (400)
17:37:17:WU01:FS00:Final credit estimate, 4305.00 points
17:37:17:WU01:FS00:Cleaning up
17:45:52:WU00:FS00:0xa7:Completed 12500 out of 1250000 steps (1%)
19:10:50:WU00:FS00:0xa7:Completed 125000 out of 1250000 steps (10%)
19:20:21:WU00:FS00:0xa7:Completed 137500 out of 1250000 steps (11%)
01:11:26:WU00:FS00:0xa7:Completed 587500 out of 1250000 steps (47%)
******************************* Date: 2021-01-19 *******************************
01:20:41:WU00:FS00:0xa7:Completed 600000 out of 1250000 steps (48%)
07:18:14:WU00:FS00:0xa7:Completed 1075000 out of 1250000 steps (86%)
07:27:59:WU00:FS00:0xa7:Completed 1087500 out of 1250000 steps (87%)
09:22:09:WU00:FS00:0xa7:Completed 1237500 out of 1250000 steps (99%)
09:22:10:WU01:FS00:Connecting to assign1.foldingathome.org:80
09:22:11:WU01:FS00:Assigned to work server 206.223.170.146
09:22:11:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 206.223.170.146
09:22:11:WU01:FS00:Connecting to 206.223.170.146:8080
09:22:11:WU01:FS00:Downloading 1.25MiB
09:22:13:WU01:FS00:Download complete
09:22:13:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16452 run:54 clone:129 gen:19 core:0xa7 unit:0x00000081000000130000404400000036
09:31:35:WU00:FS00:0xa7:Completed 1250000 out of 1250000 steps (100%)
09:31:44:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
09:31:44:WU00:FS00:0xa7:Saving result file frame1.trr
09:31:45:WU00:FS00:0xa7:Saving result file md.log
09:31:45:WU00:FS00:0xa7:Saving result file science.log
09:31:45:WU00:FS00:0xa7:Saving result file traj_comp.xtc
09:31:45:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:31:45:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14188 run:5 clone:1 gen:1 core:0xa7 unit:0x00000001000000010000376c00000005
09:31:45:WU00:FS00:Uploading 9.20MiB to 155.247.166.219
09:31:45:WU00:FS00:Connecting to 155.247.166.219:8080
09:31:46:WU01:FS00:Starting
09:31:46:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 706 -lifeline 69 -checkpoint 15 -np 3
09:31:46:WU01:FS00:Started FahCore on PID 4140
09:31:46:WU01:FS00:Core PID:4141
09:31:46:WU01:FS00:FahCore 0xa7 started
09:31:46:WU01:FS00:0xa7:*********************** Log Started 2021-01-19T09:31:46Z ***********************
09:31:46:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:31:46:WU01:FS00:0xa7:       Type: 0xa7
09:31:46:WU01:FS00:0xa7:       Core: Gromacs
09:31:46:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -np 3
09:31:46:WU01:FS00:0xa7:************************************ CBang *************************************
09:31:46:WU01:FS00:0xa7:       Date: Nov 27 2019
09:31:46:WU01:FS00:0xa7:       Time: 03:27:01
09:31:46:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
09:31:46:WU01:FS00:0xa7:     Branch: master
09:31:46:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
09:31:46:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
09:31:46:WU01:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
09:31:46:WU01:FS00:0xa7:   Platform: darwin 19.0.0
09:31:46:WU01:FS00:0xa7:       Bits: 64
09:31:46:WU01:FS00:0xa7:       Mode: Release
09:31:46:WU01:FS00:0xa7:************************************ System ************************************
09:31:46:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
09:31:46:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:31:46:WU01:FS00:0xa7:       CPUs: 4
09:31:46:WU01:FS00:0xa7:     Memory: 8.00GiB
09:31:46:WU01:FS00:0xa7:Free Memory: 1.49GiB
09:31:46:WU01:FS00:0xa7:    Threads: POSIX_THREADS
09:31:46:WU01:FS00:0xa7: OS Version: 10.16
09:31:46:WU01:FS00:0xa7:Has Battery: false
09:31:46:WU01:FS00:0xa7: On Battery: false
09:31:46:WU01:FS00:0xa7: UTC Offset: 1
09:31:46:WU01:FS00:0xa7:        PID: 4141
09:31:46:WU01:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
09:31:46:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:31:46:WU01:FS00:0xa7:    Version: 0.0.19
09:31:46:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:31:46:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:31:46:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:31:46:WU01:FS00:0xa7:       Date: Nov 25 2019
09:31:46:WU01:FS00:0xa7:       Time: 16:41:59
09:31:46:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
09:31:46:WU01:FS00:0xa7:************************************ Build *************************************
09:31:46:WU01:FS00:0xa7:       SIMD: avx_256
09:31:46:WU01:FS00:0xa7:********************************************************************************
09:31:46:WU01:FS00:0xa7:Project: 16452 (Run 54, Clone 129, Gen 19)
09:31:46:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
09:31:46:WU01:FS00:0xa7:Reading tar file core.xml
09:31:46:WU01:FS00:0xa7:Reading tar file frame19.tpr
09:31:46:WU01:FS00:0xa7:Digital signatures verified
09:31:46:WU01:FS00:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -x frame19.xtc -cpt 15 -nt 3
09:31:46:WU01:FS00:0xa7:Steps: first=9500000 total=500000
09:31:46:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
09:31:51:WU00:FS00:Upload 25.14%
09:31:57:WU00:FS00:Upload 54.36%
09:32:03:WU00:FS00:Upload 78.82%
09:32:10:WU00:FS00:Upload complete
09:32:10:WU00:FS00:Server responded WORK_ACK (400)
09:32:10:WU00:FS00:Final credit estimate, 26123.00 points
09:32:10:WU00:FS00:Cleaning up
09:32:57:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
11:28:18:WU01:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
11:28:21:WU00:FS00:Connecting to assign1.foldingathome.org:80
11:28:23:WU00:FS00:Assigned to work server 206.223.170.146
11:28:23:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 206.223.170.146
11:28:23:WU00:FS00:Connecting to 206.223.170.146:8080
11:28:24:WU00:FS00:Downloading 1.25MiB
11:28:30:WU00:FS00:Download 69.97%
11:28:37:WU00:FS00:Download 99.96%
11:28:37:WU00:FS00:Download complete
11:28:37:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16452 run:110 clone:94 gen:17 core:0xa7 unit:0x0000005e00000011000040440000006e
11:29:34:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
11:29:36:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
11:29:36:WU01:FS00:0xa7:Saving result file frame19.trr
11:29:36:WU01:FS00:0xa7:Saving result file frame19.xtc
11:29:36:WU01:FS00:0xa7:Saving result file md.log
11:29:36:WU01:FS00:0xa7:Saving result file science.log
11:29:36:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
11:29:36:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:29:36:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16452 run:54 clone:129 gen:19 core:0xa7 unit:0x00000081000000130000404400000036
11:29:36:WU01:FS00:Uploading 1.42MiB to 206.223.170.146
11:29:36:WU00:FS00:Starting
11:29:36:WU01:FS00:Connecting to 206.223.170.146:8080
11:29:36:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 69 -checkpoint 15 -np 3
11:29:36:WU00:FS00:Started FahCore on PID 4547
11:29:36:WU00:FS00:Core PID:4548
11:29:36:WU00:FS00:FahCore 0xa7 started
11:29:38:WU00:FS00:0xa7:*********************** Log Started 2021-01-19T11:29:37Z ***********************
11:29:38:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:29:38:WU00:FS00:0xa7:       Type: 0xa7
11:29:38:WU00:FS00:0xa7:       Core: Gromacs
11:29:38:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 4547 -checkpoint 15 -np 3
11:29:38:WU00:FS00:0xa7:************************************ CBang *************************************
11:29:38:WU00:FS00:0xa7:       Date: Nov 27 2019
11:29:38:WU00:FS00:0xa7:       Time: 03:27:01
11:29:38:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
11:29:38:WU00:FS00:0xa7:     Branch: master
11:29:38:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
11:29:38:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
11:29:38:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
11:29:38:WU00:FS00:0xa7:   Platform: darwin 19.0.0
11:29:38:WU00:FS00:0xa7:       Bits: 64
11:29:38:WU00:FS00:0xa7:       Mode: Release
11:29:38:WU00:FS00:0xa7:************************************ System ************************************
11:29:38:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
11:29:38:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
11:29:38:WU00:FS00:0xa7:       CPUs: 4
11:29:38:WU00:FS00:0xa7:     Memory: 8.00GiB
11:29:38:WU00:FS00:0xa7:Free Memory: 1.13GiB
11:29:38:WU00:FS00:0xa7:    Threads: POSIX_THREADS
11:29:38:WU00:FS00:0xa7: OS Version: 10.16
11:29:38:WU00:FS00:0xa7:Has Battery: false
11:29:38:WU00:FS00:0xa7: On Battery: false
11:29:38:WU00:FS00:0xa7: UTC Offset: 1
11:29:38:WU00:FS00:0xa7:        PID: 4548
11:29:38:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
11:29:38:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:29:38:WU00:FS00:0xa7:    Version: 0.0.19
11:29:38:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:29:38:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:29:38:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:29:38:WU00:FS00:0xa7:       Date: Nov 25 2019
11:29:38:WU00:FS00:0xa7:       Time: 16:41:59
11:29:38:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
11:29:38:WU00:FS00:0xa7:************************************ Build *************************************
11:29:38:WU00:FS00:0xa7:       SIMD: avx_256
11:29:38:WU00:FS00:0xa7:********************************************************************************
11:29:38:WU00:FS00:0xa7:Project: 16452 (Run 110, Clone 94, Gen 17)
11:29:38:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
11:29:38:WU00:FS00:0xa7:Reading tar file core.xml
11:29:38:WU00:FS00:0xa7:Reading tar file frame17.tpr
11:29:38:WU00:FS00:0xa7:Digital signatures verified
11:29:38:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -x frame17.xtc -cpt 15 -nt 3
11:29:38:WU00:FS00:0xa7:Steps: first=8500000 total=500000
11:29:39:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
11:29:42:WU01:FS00:Upload 83.78%
11:29:43:WU01:FS00:Upload complete
11:29:43:WU01:FS00:Server responded WORK_ACK (400)
11:29:43:WU01:FS00:Final credit estimate, 3464.00 points
11:29:43:WU01:FS00:Cleaning up
11:30:52:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
13:27:50:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
13:29:00:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
13:29:00:WU01:FS00:Connecting to assign1.foldingathome.org:80
13:29:01:WU01:FS00:Assigned to work server 206.223.170.146
13:29:01:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 206.223.170.146
13:29:01:WU01:FS00:Connecting to 206.223.170.146:8080
13:29:01:WU01:FS00:Downloading 1.25MiB
13:29:05:WU01:FS00:Download complete
13:29:05:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16452 run:39 clone:19 gen:21 core:0xa7 unit:0x00000013000000150000404400000027
13:30:10:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
13:30:12:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
13:30:12:WU00:FS00:0xa7:Saving result file frame17.trr
13:30:12:WU00:FS00:0xa7:Saving result file frame17.xtc
13:30:12:WU00:FS00:0xa7:Saving result file md.log
13:30:12:WU00:FS00:0xa7:Saving result file science.log
13:30:12:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
13:30:12:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:30:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16452 run:110 clone:94 gen:17 core:0xa7 unit:0x0000005e00000011000040440000006e
13:30:12:WU00:FS00:Uploading 1.42MiB to 206.223.170.146
13:30:12:WU01:FS00:Starting
13:30:12:WU00:FS00:Connecting to 206.223.170.146:8080
13:30:12:WU01:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 01 -suffix 01 -version 706 -lifeline 69 -checkpoint 15 -np 3
13:30:12:WU01:FS00:Started FahCore on PID 5032
13:30:12:WU01:FS00:Core PID:5033
13:30:12:WU01:FS00:FahCore 0xa7 started
13:30:13:WU01:FS00:0xa7:*********************** Log Started 2021-01-19T13:30:12Z ***********************
13:30:13:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:30:13:WU01:FS00:0xa7:       Type: 0xa7
13:30:13:WU01:FS00:0xa7:       Core: Gromacs
13:30:13:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5032 -checkpoint 15 -np 3
13:30:13:WU01:FS00:0xa7:************************************ CBang *************************************
13:30:13:WU01:FS00:0xa7:       Date: Nov 27 2019
13:30:13:WU01:FS00:0xa7:       Time: 03:27:01
13:30:13:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
13:30:13:WU01:FS00:0xa7:     Branch: master
13:30:13:WU01:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
13:30:13:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
13:30:13:WU01:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
13:30:13:WU01:FS00:0xa7:   Platform: darwin 19.0.0
13:30:13:WU01:FS00:0xa7:       Bits: 64
13:30:13:WU01:FS00:0xa7:       Mode: Release
13:30:13:WU01:FS00:0xa7:************************************ System ************************************
13:30:13:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
13:30:13:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
13:30:13:WU01:FS00:0xa7:       CPUs: 4
13:30:13:WU01:FS00:0xa7:     Memory: 8.00GiB
13:30:13:WU01:FS00:0xa7:Free Memory: 1.94GiB
13:30:13:WU01:FS00:0xa7:    Threads: POSIX_THREADS
13:30:13:WU01:FS00:0xa7: OS Version: 10.16
13:30:13:WU01:FS00:0xa7:Has Battery: false
13:30:13:WU01:FS00:0xa7: On Battery: false
13:30:13:WU01:FS00:0xa7: UTC Offset: 1
13:30:13:WU01:FS00:0xa7:        PID: 5033
13:30:13:WU01:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
13:30:13:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
13:30:13:WU01:FS00:0xa7:    Version: 0.0.19
13:30:13:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:30:13:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:30:13:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
13:30:13:WU01:FS00:0xa7:       Date: Nov 25 2019
13:30:13:WU01:FS00:0xa7:       Time: 16:41:59
13:30:13:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
13:30:13:WU01:FS00:0xa7:************************************ Build *************************************
13:30:13:WU01:FS00:0xa7:       SIMD: avx_256
13:30:13:WU01:FS00:0xa7:********************************************************************************
13:30:13:WU01:FS00:0xa7:Project: 16452 (Run 39, Clone 19, Gen 21)
13:30:13:WU01:FS00:0xa7:Unit: 0x00000000000000000000000000000000
13:30:13:WU01:FS00:0xa7:Reading tar file core.xml
13:30:13:WU01:FS00:0xa7:Reading tar file frame21.tpr
13:30:13:WU01:FS00:0xa7:Digital signatures verified
13:30:13:WU01:FS00:0xa7:Calling: mdrun -s frame21.tpr -o frame21.trr -x frame21.xtc -cpt 15 -nt 3
13:30:13:WU01:FS00:0xa7:Steps: first=10500000 total=500000
13:30:13:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
13:30:18:WU00:FS00:Upload 96.94%
13:30:20:WU00:FS00:Upload complete
13:30:20:WU00:FS00:Server responded WORK_ACK (400)
13:30:20:WU00:FS00:Final credit estimate, 3543.00 points
13:30:20:WU00:FS00:Cleaning up
13:31:22:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
15:03:59:WU01:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
15:04:58:FS00:Finishing
15:05:13:WU01:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
15:27:09:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
15:27:11:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
15:27:11:WU01:FS00:0xa7:Saving result file frame21.trr
15:27:11:WU01:FS00:0xa7:Saving result file frame21.xtc
15:27:11:WU01:FS00:0xa7:Saving result file md.log
15:27:11:WU01:FS00:0xa7:Saving result file science.log
15:27:11:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
15:27:11:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:27:11:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16452 run:39 clone:19 gen:21 core:0xa7 unit:0x00000013000000150000404400000027
15:27:11:WU01:FS00:Uploading 1.42MiB to 206.223.170.146
15:27:11:WU01:FS00:Connecting to 206.223.170.146:8080
15:27:16:WU01:FS00:Upload complete
15:27:16:WU01:FS00:Server responded WORK_ACK (400)
15:27:16:WU01:FS00:Final credit estimate, 3598.00 points
15:27:16:WU01:FS00:Cleaning up
16:05:49:FS00:Paused
16:06:19:Caught signal SIGTERM(15) on PID 69
16:06:19:Exiting, please wait. . .
16:06:21:Removing old file 'configs/config-20201212-224051.xml'
16:06:21:Saving configuration to config.xml
16:06:21:<config>
16:06:21:  <!-- Network -->
16:06:21:  <proxy v=':8080'/>
16:06:21:
16:06:21:  <!-- User Information -->
16:06:21:  <passkey v='*****'/>
16:06:21:  <user v='SilvioMartin'/>
16:06:21:
16:06:21:  <!-- Folding Slots -->
16:06:21:  <slot id='0' type='CPU'>
16:06:21:    <paused v='true'/>
16:06:21:  </slot>
16:06:21:</config>
16:06:21:Clean exit
My Raspberry Pi folding rack: http://www.anne-emscher.net/fah/
Re: 155.247.166.219 sent 1.5 year old WU
Post by Neil-B »
It may be a case of the project number being reused - this doesn't happen often (and is usually avoided) but when it does shows this type of effect ... there might also be needs occasionally for researchers to rerun certain parts of their project - possibly for scientific verification
Frogging101
Getting reruns of old 14188 WUs
Post by Frogging101 »
I've been assigned (and have completed) a couple of WUs from project 14188 which apparently were previously completed in late 2019 (according to the WU status page):
2021-01-18 16:20:09Z - project:14188 run:2 clone:582 gen:0
2021-01-19 17:07:51Z - project:14188 run:3 clone:854 gen:1
Both were assigned by and returned to 155.247.166.219. My results have not appeared on the status page yet, but it hasn't been very long, so I'll check again later.
This may not be an issue per se, but it's interesting.
psaam0001
Re: Getting reruns of old 14188 WUs
Post by psaam0001 »
Could it be possible that they restarted this project, and that the previous results were cleared/missing from the original WS's WU's completed database???
Hopefully someone with better knowledge as to how these things happen can explain it.
Paul
I have posted a question about this to the researcher running Project 14188. As Neil-B has posted the project number may have been reused, or the researcher needs more data.
In this case while I was typing, a response came back that the researcher is looking to get more data on the project started back in 2019.
Post by Neil-B »
@Joe_H Just as a matter of interest would the researcher be able to confirm if the wus are actually new wus under their project (so reusing the RCG numbers)?
That was my followup question, waiting to hear back.
SilvioMartin
Interesting. Thanks for your replies. For good luck I didn't stop the WU.
Re: 155.247.166.219 sent 1.5 year old WU [Project 14188]
There's also the possibility that when the paper was undergoing peer-review, somebody discovered an error :oops: or maybe a better way to simulate the protein. There's another project that contained an error and selected WUs which encountered that error are being re-run. When something like that happens, FAH doesn't go in and remove the credit for those who ran those WUs the first time but good data are replacing bad data and potentially new conclusions can be incorporated.
It doesn't happen often, but re-running questionable results is always a possibility.
psaam0001
Post by psaam0001 »
FWIW: Any WU that my client(s) get, is fair game... I'm not going to question why I'm running it.
Paul
Frogging101
I have absolutely no problem with it, I'm just pointing it out to the operators because it looked weird, in case it indicates a problem.
Frogging101
I will note though that none of the WUs in this thread have shown up as newly completed on the status page yet. In case this indicates another server that's getting stuck with the stats.
Generally that means one of two things:
* The server is not properly connected to the stats server so all of the Completed WU Reports are accumulating on that server until somebody fixes the problem
-or-
* Completed WU Reports are now transferred in batches and you didn't wait long enough.
Lost reports are VERY rare. Delayed reports seem to be rather frequent right now.
Maddog
Post by Maddog »
I was also wondering about this. Currently have one due to finish in about 7 hours and one was completed yesterday but not found on the status page.
What I would like to understand is, how are we getting these WUs when the server shows zero work units and other servers have many more plus a higher assign rate?
Post by Neil-B »
There may be a fairly small number of wus in play as this is additional work to a project - and if all the wus are out being folded then there are zero waiting to be assigned - if the wu is returned and the next gen created and assigned immediately then it could appear as if the isn't doing much - other servers will full projects worth of wus may well be farming out far more per hour ... and I guess since it may just be some additional wus that they might be being given higher priority than most to allow the project to be finalised/finished?
