To get idle detection working again, there are two possible solutions:
- Put xscreensaver back. (I don't recommend this, but if you want to try, here's the guide for that: https://forums.linuxmint.com/viewtopic.php?t=284037)
- Use a custom idle-detect script. Credit for this goes to Norbert Preining's blog post "Changing cinnamon’s lockscreen background". The rest of this post explains how. It has been tested in Linux Mint 20, but should work in most Linux distributions using cinnamon-screensaver:
Note 2: Remove any "On idle" settings on the slots or client first - we're going to explicitly pause and unpause the slots when the screensaver enables, rather than relying on the broken idle detection.
Note 3: Set "pause-on-start" to "True" on any slots that you're controlling with this script, if you don't want to fold until you've logged in and started the screensaver.
Note 4: It is assumed that you want the screensaver to control slot 01 (the GPU) here. Adjust the script as needed by changing the slot number, remove the slot number if you want to control the whole client, or just add command lines.
Run
sudo pico /usr/local/bin/cinnamon-lockscreen-folding.shCode: Select all
#!/bin/bash
# Check for existing instances and kill them leaving current instance running
for PID in $(pidof -o %PPID -x "${0##*/}"); do
if [ "$PID" != $$ ]; then
kill -9 "$PID"
fi
done
dbus-monitor --session "interface='org.cinnamon.ScreenSaver', member='ActiveChanged'" | while read -r msg
do
case "$msg" in
"boolean true")
# Unpause command(s) for when screensaver enables. The number is for the folding slot. Leave out the number to unpause the whole client:
FAHClient --send-unpause 01
"boolean false")
# Pause command for when desktop in use:
FAHClient --send-pause 01
esac
doneCode: Select all
pico ~/.config/autostart/cinnamon-lockscreen-folding-autostart.desktopCode: Select all
[Desktop Entry]
Type=Application
Exec=/bin/bash /usr/local/bin/cinnamon-lockscreen-folding.sh
X-GNOME-Autostart-enabled=true
NoDisplay=false
Hidden=false
Name=cinnamon-lockscreen-folding.desktop
Comment=Change folding
X-GNOME-Autostart-Delay=1
