Quadro K2200 disabled?
ptchernegovski
Post by ptchernegovski »
Have had my Quadro in since Christmas, and having it do some folding in my Unraid server. Came home today, noticed it was saying "disabled" for the Quadro only. CPU still running fine. Was at 27% of a way through a job.
Log is saying "No CUDA or OpenCL 1.2+ support detected. (log attached).
GPU is still showing in system. Nvidia drivers are up to date (455.45.01), no changes to anything I can see. Have tried restarting the system, reinstalling FAH, still same issue.
*********************** Log Started 2021-01-09T03:19:02Z ***********************
03:19:02:******************************* libFAH ********************************
03:19:02:       Date: Oct 20 2020
03:19:02:       Time: 20:36:39
03:19:02:   Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
03:19:02:     Branch: master
03:19:02:   Compiler: GNU 8.3.0
03:19:02:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
03:19:02:             -fdata-sections -O3 -funroll-loops -fno-pie
03:19:02:   Platform: linux2 5.8.0-1-amd64
03:19:02:       Bits: 64
03:19:02:       Mode: Release
03:19:02:****************************** FAHClient ******************************
03:19:02:    Version: 7.6.21
03:19:02:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:19:02:  Copyright: 2020 foldingathome.org
03:19:02:   Homepage: https://foldingathome.org/
03:19:02:       Time: 20:39:00
03:19:02:   Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
03:19:02:       Bits: 64
03:19:02:       Args: --http-addresses 0.0.0.0:7396 --allow 0/0 --web-allow 0/0
03:19:02:             --command-allow-no-pass 0/0
03:19:02:     Config: /config/config.xml
03:19:02:******************************** CBang ********************************
03:19:02:       Time: 18:37:59
03:19:02:   Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
03:19:02:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
03:19:02:       Bits: 64
03:19:02:******************************* System ********************************
03:19:02:        CPU: AMD Ryzen 5 3600 6-Core Processor
03:19:02:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
03:19:02:       CPUs: 12
03:19:02:     Memory: 15.65GiB
03:19:02:Free Memory: 10.48GiB
03:19:02:    Threads: POSIX_THREADS
03:19:02: OS Version: 5.10
03:19:02:Has Battery: false
03:19:02: On Battery: false
03:19:02: UTC Offset: 13
03:19:02:        PID: 269
03:19:02:        CWD: /config
03:19:02:         OS: Linux 5.10.1-Unraid x86_64
03:19:02:    OS Arch: AMD64
03:19:02:       GPUs: 1
03:19:02:      GPU 0: Bus:41 Slot:0 Func:0 NVIDIA:4 GM107GL [Quadro K2200]
03:19:02:       CUDA: Not detected: cuInit() returned 100
03:19:02:     OpenCL: Not detected: clGetPlatformIDs() returned -1001
03:19:02:***********************************************************************
03:19:02:<config>
03:19:02:  <!-- User Information -->
03:19:02:  <passkey v='*****'/>
03:19:02:  <team v='234771'/>
03:19:02:  <user v='ptchernegovski'/>
03:19:02:
03:19:02:  <!-- Folding Slots -->
03:19:02:  <slot id='0' type='CPU'/>
03:19:02:  <slot id='1' type='GPU'>
03:19:02:    <pci-bus v='41'/>
03:19:02:    <pci-slot v='0'/>
03:19:02:  </slot>
03:19:02:</config>
03:19:02:Trying to access database...
03:19:02:Successfully acquired database lock
03:19:02:FS00:Initialized folding slot 00: cpu:10
[93m03:19:02:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:41:0 GM107GL [Quadro K2200].  Disabling.[0m
03:19:02:WU00:FS00:Cleaning up
03:19:02:WU02:FS00:Starting
03:19:02:WU02:FS00:Running FahCore: /app/usr/bin/FAHCoreWrapper /config/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 269 -checkpoint 15 -np 10
03:19:02:WU02:FS00:Started FahCore on PID 292
03:19:02:WU02:FS00:Core PID:296
03:19:02:WU02:FS00:FahCore 0xa7 started
03:19:03:WU02:FS00:0xa7:*********************** Log Started 2021-01-09T03:19:02Z ***********************
03:19:03:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:19:03:WU02:FS00:0xa7:       Type: 0xa7
03:19:03:WU02:FS00:0xa7:       Core: Gromacs
03:19:03:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 292 -checkpoint 15 -np 10
03:19:03:WU02:FS00:0xa7:************************************ CBang *************************************
03:19:03:WU02:FS00:0xa7:       Date: Nov 27 2019
03:19:03:WU02:FS00:0xa7:       Time: 11:26:54
03:19:03:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
03:19:03:WU02:FS00:0xa7:     Branch: master
03:19:03:WU02:FS00:0xa7:   Compiler: GNU 8.3.0
03:19:03:WU02:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
03:19:03:WU02:FS00:0xa7:             -fno-pie -fPIC
03:19:03:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
03:19:03:WU02:FS00:0xa7:       Bits: 64
03:19:03:WU02:FS00:0xa7:       Mode: Release
03:19:03:WU02:FS00:0xa7:************************************ System ************************************
03:19:03:WU02:FS00:0xa7:        CPU: AMD Ryzen 5 3600 6-Core Processor
03:19:03:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
03:19:03:WU02:FS00:0xa7:       CPUs: 12
03:19:03:WU02:FS00:0xa7:     Memory: 15.65GiB
03:19:03:WU02:FS00:0xa7:Free Memory: 10.45GiB
03:19:03:WU02:FS00:0xa7:    Threads: POSIX_THREADS
03:19:03:WU02:FS00:0xa7: OS Version: 5.10
03:19:03:WU02:FS00:0xa7:Has Battery: false
03:19:03:WU02:FS00:0xa7: On Battery: false
03:19:03:WU02:FS00:0xa7: UTC Offset: 13
03:19:03:WU02:FS00:0xa7:        PID: 296
03:19:03:WU02:FS00:0xa7:        CWD: /config/work
03:19:03:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
03:19:03:WU02:FS00:0xa7:    Version: 0.0.19
03:19:03:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:19:03:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:19:03:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
03:19:03:WU02:FS00:0xa7:       Date: Nov 26 2019
03:19:03:WU02:FS00:0xa7:       Time: 00:41:42
03:19:03:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
03:19:03:WU02:FS00:0xa7:************************************ Build *************************************
03:19:03:WU02:FS00:0xa7:       SIMD: avx_256
03:19:03:WU02:FS00:0xa7:********************************************************************************
03:19:03:WU02:FS00:0xa7:Project: 16927 (Run 19, Clone 258, Gen 53)
03:19:03:WU02:FS00:0xa7:Unit: 0x00000000000000000000000000000000
03:19:03:WU02:FS00:0xa7:Digital signatures verified
03:19:03:WU02:FS00:0xa7:Calling: mdrun -s frame53.tpr -o frame53.trr -cpi state.cpt -cpt 15 -nt 10
03:19:03:WU02:FS00:0xa7:Steps: first=26500000 total=500000
03:19:05:WU02:FS00:0xa7:Completed 219942 out of 500000 steps (43%)
03:19:07:WU02:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
03:20:28:11:192.168.178.23:New Web session
03:22:45:WU02:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
Knish
Re: Quadro K2200 disabled?
Post by Knish »
chances are it's the issue I usually run into https://github.com/gitHu6-newb/FoldingA ... leshooting
reinstall linux headers and the nvidia driver, reboot, then good to go
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/q ... 2200.c2601
The K2200 meets the minimum requirements of F@H: it has OpenCL 1.2 support and it can do 64 bit Floating Point math. (Double Precision)
FYI, I would suggest that you update the Nvidia Drivers to the latest version due to Nvidia fixing several high severity flaws in their drivers:
https://nvidia.custhelp.com/app/answers ... 20Bulletin
https://www.bleepingcomputer.com/news/s ... x-devices/
https://www.techpowerup.com/276890/nvid ... ql-drivers
ptchernegovski
Thanks for replies.
Had a couple of busy days, just sat back down at desk, and about to go through the ideas, and for some reason it is back up working.
Couldn't update the drivers, as the Unraid plugin latest is 455.45.1
Something is not set up correctly as the client can't access OpenCL and CUDA libraries ... :(
