folding fails everytime while starting FAHCORE crashed
parthibans
Post by parthibans »
*********************** Log Started 2021-01-08T14:55:39Z ***********************
14:55:39:******************************* libFAH ********************************
14:55:39:           Date: Oct 20 2020
14:55:39:           Time: 13:36:55
14:55:39:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:55:39:         Branch: master
14:55:39:       Compiler: Visual C++ 2015
14:55:39:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:55:39:       Platform: win32 10
14:55:39:           Bits: 32
14:55:39:           Mode: Release
14:55:39:        Version: 7.6.21
nd <joseph@cauldrondevelopment.com>
14:55:39:      Copyright: 2020 foldingathome.org
14:55:39:       Homepage: https://foldingathome.org/
14:55:39:           Time: 13:41:04
14:55:39:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:55:39:           Bits: 32
2 10
14:55:39:           Bits: 32
ase
14:55:39:           Args: --open-web-control
14:55:39:******************************** CBang ********************************
14:55:39:****************************** FAHClient ******************************
14:55:39:           Time: 11:36:18
25d7eaeb775e87c31740181ca603de60
14:55:39:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:55:39:           Bits: 32
oldingathome.org/
* System ********************************
14:55:39:            CPU: Intel(R) Core(TM) i3-3110M CPU @ 2.40GHz
el Family 6 Model 58 Stepping 9
14:55:39:           CPUs: 4
14:55:39:    Free Memory: 463.77MiB
14:55:39:        Threads: WINDOWS_THREADS
14:55:39:    Has Battery: true
14:55:39:     UTC Offset: 5
14:55:39:            CWD: C:\ProgramData\FAHClient
14:55:39:           Bits: 32
e
14:55:39:             OS: Windows 7 Ultimate
14:55:39:        OS Arch: AMD64
14:55:39:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 SI Thames [Radeon HD 7600M Series]
': The
14:55:39:                 specified module could not be found.
14:55:39:
         Date: Oct 20 2020
14:55:39:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.1 Driver:1.4
14:55:39:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:55:39:           Bits: 32
14:55:39:******************************* System ********************************
14:55:39:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
14:55:39:           CPUs: 4
14:55:39:         Memory: 1.90GiB
14:55:39:     OS Version: 6.1
14:55:39:     On Battery: true
14:55:39:            PID: 3112
14:55:39:  Win32 Service: false
14:55:39:           GPUs: 1
14:55:39:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:55:39:
14:55:39:***********************************************************************
14:55:39:<config>
14:55:39:  <!-- Folding Slots -->
14:55:39:</config>
14:55:40:Trying to access database...
14:55:40:ERROR:Exception: Failed to create directory 'work': Cannot create a file when that file already exists.
14:55:44:Successfully acquired database lock
14:55:45:FS00:Initialized folding slot 00: cpu:2
14:55:45:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:1:0 SI Thames [Radeon HD 7600M Series].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
14:55:45:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:1:0 SI Thames [Radeon HD 7600M Series].  Disabling.
14:55:52:5:127.0.0.1:New Web session
14:55:53:6:127.0.0.1:New Web session
14:55:56:14:127.0.0.1:New Web session
14:56:00:Set client configured
14:56:09:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:56:10:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:56:11:WU00:FS00:Assigned to work server 128.252.203.11
14:56:11:WU00:FS00:Requesting new work unit for slot 00: cpu:2 from 128.252.203.11
14:56:11:WU00:FS00:Connecting to 128.252.203.11:8080
14:56:12:WU00:FS00:Downloading 1.86MiB
14:56:15:WU00:FS00:Download complete
14:56:16:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16462 run:132 clone:0 gen:191 core:0xa7 unit:0x00000000000000bf0000404e00000084
14:56:16:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
14:56:16:WU00:FS00:Connecting to cores.foldingathome.org:80
14:56:16:WU00:FS00:FahCore a7: Downloading 6.71MiB
14:56:21:WU00:FS00:FahCore a7: Download complete
14:56:21:WU00:FS00:Valid core signature
14:56:21:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe
14:56:21:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/libfftw3f-3.dll
14:56:21:WU00:FS00:Starting
14:56:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 3112 -checkpoint 15 -np 2
14:56:21:WU00:FS00:Started FahCore on PID 4708
14:56:24:WU00:FS00:Core PID:5036
14:56:24:WU00:FS00:FahCore 0xa7 started
14:56:45:Saving configuration to config.xml
14:56:45:<config>
14:56:45:  <!-- Folding Slots -->
14:56:45:  <slot id='0' type='CPU'/>
14:56:45:  <slot id='1' type='GPU'>
14:56:45:    <pci-bus v='1'/>
14:56:45:    <pci-slot v='0'/>
14:56:45:  </slot>
14:56:45:</config>
14:56:53:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:56:53:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741795 = 0xc000001d)
14:56:54:WU00:FS00:Starting
14:56:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 3112 -checkpoint 15 -np 2
14:56:54:WU00:FS00:Started FahCore on PID 4772
14:56:54:WU00:FS00:Core PID:804
14:56:54:WU00:FS00:FahCore 0xa7 started
14:56:56:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:56:56:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741795 = 0xc000001d)
Re: folding fails everytime while starting FAHCORE crashed
I can't tell if this is a hardware or software/driver issue or if we've classified your GPU incorrectly, but
indicates that you have support for OpenCL 1.1. The minimum requirement is OpenCL 1.2
Certainly the statement
indicates that some driver software is missing.
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/r ... 7610m.c377
There are two prerequisites for Folding@Home for Nvidia and AMD GPUs: it needs to support OpenCL 1.2 (some GPUs that only support OpenCL 1.1 have all the parts of OpenCL 1.2 that F@H uses) and 64 Bit Floating Point math.
Your GPU does not support 64 Bit Floating Point math. There is no way around that.
Yes, the GPU is not classified correctly. None of the Radeon HD 7600 series GPUs support FP64, desktop or mobile. The HD 7700 and above desktop GPUs in the HD 7000 series cards do support FP64, and it appears the same holds for the mobile GPUs in that series.
There are several entries that used to be correct at not listing them as supporting FP64, it appears someone has modified the file. I will see if that can be corrected.
One clarification:
JimboPalmer wrote:There are two prerequisites for Folding@Home for Nvidia and AMD GPUs: it needs to support OpenCL 1.2 (some GPUs that only support OpenCL 1.1 have all the parts of OpenCL 1.2 that F@H uses) and 64 Bit Floating Point math.
The part about some GPUs that only support OpenCL 1.1 only applies to some nVidia GPUs. These are Fermi based cards, they support some, not all, of the OpenCL 1.2 parts that F@h uses. It also depends on which Fermis chip is used, they have different levels of 1.1+ support. Depending on the folding project, WUs may successfully process on these cards, but a different project will fail.
AMD adopted OpenCL 1.2 early on, any of their cards that support FP64 also support at least OpenCL 1.2 as well.
FAH used to enable a limited number of very small projects for devices like yours but they've quit creating such projects just like managing a limited number of very small projects that can run on a 32-bit OS. Support for managing separate queues of projects isn't worth the extra overhead of managing and extra queue which is perpetually empty.
Both of those features have been deprecated since they expect there will be no such projects available in the future. The GPUs should be disabled in GPUs.txt.
It's a CPU core (A7) that is failing ... his GPU is already disabled ...
Is there a Windows Event logged at the same time the core crashes ?
Post by Neil-B »
32bit os? ... didn't think these were supported any more
Neil-B wrote:32bit os? ... didn't think these were supported any more
It depends on what you mean by "supported"
The FAHCore that was written for 32-bit still exists so if you manage to find a WU that's enabled to use it, it will still run. All large proteins require mixed precision (which requires a modicum of FP64 instructions.) Small proteins can be processed on a 32-bit OS with that FAHCore but I suspect that the default construction of all new WUs will request 64-bit. Thus if your system is seeking a 32-bit assignment, you probably will get VERY few assignments.
I have one PC with a 32 bit OS it gets Core_a7 WUs just fine. (I have not checked for Core_a8)
Some Points:
No GPU folding is for 32 Bit OS, the AMD and Nvidia drivers do not support it. (I suspect it would work if the drivers did)
A '32 bit OS' uses 32 bit integers and addresses, F@H is all about Floating Point math. Intel has supported 64 Bit floats since the 8087 in 1980. Current F@H needs SSE2, which was introduced in 2000.
There is an issue with OSes up to Win 7 Service Pack 1 where it does not save the AVX registers on a task switch, which makes a modern OS mandatory. Linux is the same time frame.
So if you have an older OS (32 bit or 64 bit) F@H can't do AVX math, only SSE2 on your CPU.
If you have a 32 bit OS, you can't fold on GPUs.
If you have MacOS you can't fold on GPUs.
If you have a modern AMD GPU (RDNA) you must use Core_22, Core_21 is not supported. (It is possible that Core_21 will never reappear, but not announced as such)
If you still use a 'Fermi' Nividia GPU, you can't us CUDA in F@H. (Fermi was current in 2010, superseded in 2012. The last new Fermi may have been 2014's GT 705)
Your GPU must support 64 bit Floating Point Math and should support OpenCL 1.2 to fold. (There are rare instances where OpenCL 1.1 works on Nvidia Fermi cards)
That is a lot of arcane rules, and I may have some wrong, but that is what I think I know.
JimboPalmer wrote:That is a lot of arcane rules...
Looks right to me, but if somebody is exceedingly lucky, they might do better ... but FAH does not support drivers that no longer have the GPU manufacturer's support. We don't build drivers.
JimboPalmer wrote:If you have a 32 bit OS, you can't fold on GPUs.
That's a direct result of nV (and probably AMD) deciding to un-support 32-bit drivers. I'm not sure what would happen if you managed to find deprecated 32-bit drivers from those folks.
