Project: 2592 (Run 8, Clone 11, Gen 0)
PeterA
- Hardware configuration: PC: AMD Sempron(tm) Processor 2800+, 1024 MB RAM, Microsoft Windows XP (Home Edition) SP3
Laptop: Mobile AMD Sempron(tm) Processor 3500+, 896 MB RAM, Microsoft Windows Vista (Home Premium) - Location: Blaine, MN
I just received this WU, but I don't see it listed in the Project Summary list. Any idea on what is worth in points?
FahMon is coming up empty to. (Keeps trying to download new projects.)
Re: Project: 2592 (Run 8, Clone 11, Gen 0)
Hi PeterA,
Let me look into this info. It will be posted shortly.
Thanks!
Paula
Thanks!
Paula
ChelseaOilman
It's worth 176 points.
PeterA
Hi,
sorry if there was any technical trouble, but I can't see any trouble. Try http://fah-web.stanford.edu/cgi-bin/fahproject?p=2592
Hope this helps,
Ed
Hope this helps,
Ed
PeterA
FahMon is still confused about this WU. Where does it get this info? I'm still not seeing here.
anandhanju
@PeterA, Can you post the first 30 lines of your latest FAHLog.txt? Thanks
PeterA
[22:02:31] - Preparing to get new work unit...
[22:02:31] + Attempting to get work packet
[22:02:31] - Connecting to assignment server
[22:02:32] - Successful: assigned to (171.64.122.139).
[22:02:32] + News From Folding@Home: Welcome to Folding@Home
[22:02:32] Loaded queue successfully.
[22:02:34] + Closed connections
[22:02:34]
[22:02:34] + Processing work unit
[22:02:34] Core required: FahCore_79.exe
[22:02:34] Core found.
[22:02:34] Working on Unit 01 [June 30 22:02:34]
[22:02:34] + Working ...
[22:02:34]
[22:02:34] *------------------------------*
[22:02:34] Folding@Home Double Gromacs Core
[22:02:34] Version 1.91 (April 11, 2006)
[22:02:34]
[22:02:34] Preparing to commence simulation
[22:02:34] - Looking at optimizations...
[22:02:34] - Created dyn
[22:02:34] - Files status OK
[22:02:35] - Expanded 254112 -> 1762901 (decompressed 693.7 percent)
[22:02:35] - Starting from initial work packet
[22:02:35]
[22:02:35] Project: 2592 (Run 8, Clone 11, Gen 0)
[22:02:35]
[22:02:35] Assembly optimizations on if available.
[22:02:35] Entering M.D.
[22:02:41] Protein: BBA5_ext
[22:02:41]
[22:02:41] Writing local files
[22:03:22] Extra SSE2 boost OK.
[22:03:23] Writing local files
[22:03:23] Completed 0 out of 200000 steps (0)
[22:26:57] Writing local files
[22:26:57] Completed 2000 out of 200000 steps (1)
[22:46:05] Writing local filesThis is what I see with FahMon:
Maybe I'm just nitpicking, but I got nothing else to do.
The technical trouble is here: http://fah-web.stanford.edu/psummary.htmled wrote:Hi,
Hope this helps,
Ed
2592 is missing.
Thank you Bruce. I alerted Edgar. It will be fixed shortly.
Paula
Paula
