phpbb3 technical issues
uncle_fungus
Please use this thread to report any technical issues with the new software.
Do not use this thread to complain about the default theme.
v00d00
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
uncle_fungus
Re: phpbb3 technical issues
I've just installed the French Languages Pack(s), American English will be installed as soon as it gets validated by the phpbb translation team.
pythagoras
Isnt that an Oxymoron?uncle_fungus wrote:I've just installed the French Languages Pack(s), American English will be installed as soon as it gets validated by the phpbb translation team.
Regards
John.
uncle_fungus
Hehe, maybe I should have written "murican" instead
I don't know why there is two French packs
Btw I'm now using the Standard one ... it looks good as far as I can see
uncle_fungus
No I didn't quite understand that either, so I just installed both.toTOW wrote:I don't know why there is two French packs![]()
sortofageek
Re: phpbb3 issues
If you dig into the User Control Panel, you'll see another forum color choice. At least for now, UF seems to have left that choice open.v00d00 wrote:The colours are different. But still good.
uncle fuzzy
Soooooo...are the [Bot]s listed at the bottom of the index as registered users a problem?
edit- OK
edit- OK
uncle_fungus
Nope, not a problem, a feature.uncle fuzzy wrote:Soooooo...are the [Bot]s listed at the bottom of the index as registered users a problem?
This forum provides a "search" function which works but has some limitations. If a newbie doesn't know about this site and they search for the right keywords in Google (or your favorite search engine) they really should be able to find the discussion on this forum. The bots which generate that information for Google (or your favorite search engine) are good things as long as they don't overload the forum. Even in the worst of times on Folding-Community.org, the bots were friendly and didn't cause any serious problems. They use guest access and since they don't log on, they do not have access to any closed discussions, nor do they leave any posts.
Now if you're talking about a spam-bot, that's another story entirely. They SHOULD be blocked from registering and posting.
uncle_fungus
The spider bots, like google, yahoo, etc, which appear in the online member list are perfectly fine. The forum software automatically categorises them as [bots] to prevent them messing up the sessions tables and a couple of other things.
The captcha should suffice to prevent spam bots from registering on the forum. If/when that starts to be bypassed, I'll add the RAC MOD back to the registration process.
v00d00
- 16GB DDR3,
Debian 9.
One minor issue is the favicon is missing at present.
The old one was just the default phpbb favicon, but maybe someone could create a FF one. One needs doing at some point to get rid of the generic document icon.
I have a little identification problem : if I arrive on the forum with the url http://www.foldingforum.org/, I can't log in .
I had to use http://foldingforum.org/ to be able to log in.
uncle_fungus
It's a cookies thing. Could you login with the old forum software?toTOW wrote:I have a little identification problem : if I arrive on the forum with the url http://www.foldingforum.org/, I can't log in .
Edit: Try it now...
