Project 14909
Project 14909
14909 (492, 5, 173) 2.00 days 43900
Work Unit (PRCG) Work Unit (ETA) Estimated Points
I'm contributing to Project 14909
COVID-19 PROJECT
GPU:1:0 TU104M (GEFORCE RTX)
0.00%
Before this project started I had updated to the latest drivers and was running GPU projects smoothly. This project has been running for well over 2 days. I have tried stop folding, exiting the folding app,changed the research, rebooted my pc.
I haven't tried reinstalling folding@home becauase I'm unsure what would happen with my stats. Does it just continue with the same username/team? If I join a team with the username would I loose my stats. Do I just type the same username to resume my points earned?
What do you think this problem relates too?
How do I tell folding@home to cancel this project and search for another?
COVID-19 PROJECT
0.00%
Re: Project 14909
Welcome to foldingforum.
When FAH is installed, it analyzes your hardware and then assigns work that you can process. Ordinarily it will process work any time your computer is running. Depeding on the capability of your hardware, as single assignment may require few or many hours (or even days) to complete. When you complete an assignment, the results will be uploaded and a new assignment will be issued.
Ordinarily, if you reinstall it will retain your name, team, and history unless you intentionally delete it. The history of completed work will always be retained.
The identification of your GPU as GPU:1:0 TU104M (GEFORCE RTX) looks strange. It would be very helpful if you posted the first few pages of FAH's log. See the instructions below. I suspect the drivers have not been properly installed.
Re: Project 14909
This is what I see. Note: the middle one is not suppose to be working. They are the intel graphics drivers I have to install on my laptop. The one on the right is the nvidia gpu. I updated to the latest driver version in windows update, nvidia command center (running 457.51). I have also tried reinstalling and telling the app in the advance control panel to finish, which did not work.
Here is the logfile
Here is the logfile
*********************** Log Started 2020-12-06T14:49:04Z ***********************
14:49:04:******************************* libFAH ********************************
14:49:04: Date: Oct 20 2020
14:49:04: Time: 13:36:55
14:49:04: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:49:04: Branch: master
14:49:04: Compiler: Visual C++ 2015
14:49:04: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:49:04: Platform: win32 10
14:49:04: Bits: 32
14:49:04: Mode: Release
14:49:04:****************************** FAHClient ******************************
14:49:04: Version: 7.6.21
14:49:04: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:49:04: Copyright: 2020 foldingathome.org
14:49:04: Homepage: https://foldingathome.org/
14:49:04: Time: 13:41:04
14:49:04: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:49:04: Bits: 32
14:49:04: Args: --open-web-control
14:49:04: Config: C:\ProgramData\FAHClient\config.xml
14:49:04:******************************** CBang ********************************
14:49:04: Time: 11:36:18
14:49:04: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:49:04: Bits: 32
14:49:04:******************************* System ********************************
14:49:04: CPU: Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz
14:49:04: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
14:49:04: CPUs: 16
14:49:04: Memory: 31.79GiB
14:49:04: Free Memory: 17.10GiB
14:49:04: Threads: WINDOWS_THREADS
14:49:04: OS Version: 6.2
14:49:04: Has Battery: true
14:49:04: On Battery: false
14:49:04: UTC Offset: -5
14:49:04: PID: 11904
14:49:04: CWD: C:\ProgramData\FAHClient
14:49:04: Win32 Service: false
14:49:04: OS: Windows 10 Enterprise
14:49:04: OS Arch: AMD64
14:49:04: GPUs: 2
14:49:04: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 CML GT2 [UHD Graphics]
14:49:04: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 TU104M [GeForce RTX 2080 SUPER
14:49:04: Mobile / Max-Q]
14:49:04: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.1
14:49:04:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:457.51
14:49:04:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
14:49:04:***********************************************************************
14:49:04:<config>
14:49:04: <!-- Slot Control -->
14:49:04: <power v='FULL'/>
14:49:04:
14:49:04: <!-- User Information -->
14:49:04: <user v='5-MeO-DMT'/>
14:49:04:
14:49:04: <!-- Folding Slots -->
14:49:04: <slot id='0' type='CPU'/>
14:49:04: <slot id='1' type='GPU'>
14:49:04: <pci-bus v='0'/>
14:49:04: <pci-slot v='2'/>
14:49:04: </slot>
14:49:04: <slot id='2' type='GPU'>
14:49:04: <pci-bus v='1'/>
14:49:04: <pci-slot v='0'/>
14:49:04: </slot>
14:49:04:</config>
14:49:04:Trying to access database...
14:49:04:Successfully acquired database lock
14:49:04:FS00:Initialized folding slot 00: cpu:14
14:49:04:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 CML GT2 [UHD Graphics]. Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
14:49:04:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 CML GT2 [UHD Graphics]. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
14:49:04:FS02:Initialized folding slot 02: gpu:1:0 TU104M [GeForce RTX 2080 SUPER Mobile / Max-Q]
14:49:04:WU00:FS00:Starting
14:49:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 11904 -checkpoint 15 -np 14
14:49:05:WU00:FS00:Started FahCore on PID 18864
14:49:05:WU00:FS00:Core PID:22512
14:49:05:WU00:FS00:FahCore 0xa8 started
14:49:05:WU01:FS02:Starting
14:49:05:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 11904 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:49:05:WU01:FS02:Started FahCore on PID 29488
14:49:05:WU00:FS00:0xa8:*********************** Log Started 2020-12-06T14:49:05Z ***********************
14:49:05:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:49:05:WU00:FS00:0xa8: Core: Gromacs
14:49:05:WU00:FS00:0xa8: Type: 0xa8
14:49:05:WU00:FS00:0xa8: Version: 0.0.9
14:49:05:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:49:05:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
14:49:05:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
14:49:05:WU00:FS00:0xa8: Date: Oct 28 2020
14:49:05:WU00:FS00:0xa8: Time: 16:17:37
14:49:05:WU00:FS00:0xa8: Revision: 15f9b5e1edd6089f1a45553d2709a6aba62f735c
14:49:05:WU00:FS00:0xa8: Branch: master
14:49:05:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
14:49:05:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:49:05:WU00:FS00:0xa8: Platform: win32 10
14:49:05:WU00:FS00:0xa8: Bits: 64
14:49:05:WU00:FS00:0xa8: Mode: Release
14:49:05:WU00:FS00:0xa8: SIMD: avx2_256
14:49:05:WU00:FS00:0xa8: OpenMP: ON
14:49:05:WU00:FS00:0xa8: CUDA: OFF
14:49:05:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 18864 -checkpoint 15 -np
14:49:05:WU00:FS00:0xa8: 14
14:49:05:WU00:FS00:0xa8:************************************ libFAH ************************************
14:49:05:WU00:FS00:0xa8: Time: 15:11:42
14:49:05:WU00:FS00:0xa8:************************************ CBang *************************************
14:49:05:WU00:FS00:0xa8: Time: 15:11:22
14:49:05:WU00:FS00:0xa8:************************************ System ************************************
14:49:05:WU00:FS00:0xa8: CPU: Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz
14:49:05:WU00:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
14:49:05:WU00:FS00:0xa8: CPUs: 16
14:49:05:WU00:FS00:0xa8: Memory: 31.79GiB
14:49:05:WU00:FS00:0xa8:Free Memory: 17.04GiB
14:49:05:WU00:FS00:0xa8: Threads: WINDOWS_THREADS
14:49:05:WU00:FS00:0xa8: OS Version: 6.2
14:49:05:WU00:FS00:0xa8:Has Battery: true
14:49:05:WU00:FS00:0xa8: On Battery: false
14:49:05:WU00:FS00:0xa8: UTC Offset: -5
14:49:05:WU00:FS00:0xa8: PID: 22512
14:49:05:WU00:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
14:49:05:WU00:FS00:0xa8:********************************************************************************
14:49:05:WU00:FS00:0xa8:Project: 16814 (Run 9, Clone 1479, Gen 41)
14:49:05:WU00:FS00:0xa8:Unit: 0x0000002b82ed0b9100000000000905c7
14:49:05:WU00:FS00:0xa8:Digital signatures verified
14:49:05:WU00:FS00:0xa8:Calling: mdrun -c frame41.gro -s frame41.tpr -x frame41.xtc -cpi state.cpt -cpt 15 -nt 14 -ntmpi 1
14:49:05:WU00:FS00:0xa8:Steps: first=20500000 total=21000000
14:49:05:WU01:FS02:Core PID:21216
14:49:05:WU01:FS02:FahCore 0x22 started
14:49:06:WU01:FS02:0x22:*********************** Log Started 2020-12-06T14:49:05Z ***********************
14:49:06:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
14:49:06:WU01:FS02:0x22: Core: Core22
14:49:06:WU01:FS02:0x22: Type: 0x22
14:49:06:WU01:FS02:0x22: Version: 0.0.13
14:49:06:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:49:06:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
14:49:06:WU01:FS02:0x22: Homepage: https://foldingathome.org/
14:49:06:WU01:FS02:0x22: Date: Sep 19 2020
14:49:06:WU01:FS02:0x22: Time: 02:35:58
14:49:06:WU01:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
14:49:06:WU01:FS02:0x22: Branch: core22-0.0.13
14:49:06:WU01:FS02:0x22: Compiler: Visual C++ 2015
14:49:06:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:49:06:WU01:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
14:49:06:WU01:FS02:0x22: Platform: win32 10
14:49:06:WU01:FS02:0x22: Bits: 64
14:49:06:WU01:FS02:0x22: Mode: Release
14:49:06:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:49:06:WU01:FS02:0x22: <peastman@stanford.edu>
14:49:06:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 29488 -checkpoint 15
14:49:06:WU01:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
14:49:06:WU01:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
14:49:06:WU01:FS02:0x22:************************************ libFAH ************************************
14:49:06:WU01:FS02:0x22: Date: Sep 7 2020
14:49:06:WU01:FS02:0x22: Time: 19:09:56
14:49:06:WU01:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
14:49:06:WU01:FS02:0x22: Branch: HEAD
14:49:06:WU01:FS02:0x22:************************************ CBang *************************************
14:49:06:WU01:FS02:0x22: Time: 19:08:30
14:49:06:WU01:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
14:49:06:WU01:FS02:0x22:************************************ System ************************************
14:49:06:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz
14:49:06:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
14:49:06:WU01:FS02:0x22: CPUs: 16
14:49:06:WU01:FS02:0x22: Memory: 31.79GiB
14:49:06:WU01:FS02:0x22:Free Memory: 16.95GiB
14:49:06:WU01:FS02:0x22: Threads: WINDOWS_THREADS
14:49:06:WU01:FS02:0x22: OS Version: 6.2
14:49:06:WU01:FS02:0x22:Has Battery: true
14:49:06:WU01:FS02:0x22: On Battery: false
14:49:06:WU01:FS02:0x22: UTC Offset: -5
14:49:06:WU01:FS02:0x22: PID: 21216
14:49:06:WU01:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
14:49:06:WU01:FS02:0x22:************************************ OpenMM ************************************
14:49:06:WU01:FS02:0x22: Revision: 189320d0
14:49:06:WU01:FS02:0x22:********************************************************************************
14:49:06:WU01:FS02:0x22:Project: 14909 (Run 492, Clone 5, Gen 173)
14:49:06:WU01:FS02:0x22:Unit: 0x000000dd81d59d690000000001ec0005
14:49:06:WU01:FS02:0x22:Reading tar file core.xml
14:49:06:WU01:FS02:0x22:Reading tar file integrator.xml
14:49:06:WU01:FS02:0x22:Reading tar file state.xml
14:49:07:WU00:FS00:0xa8:Completed 479482 out of 500000 steps (95%)
14:49:21:87:127.0.0.1:New Web session
14:49:21:88:127.0.0.1:New Web session
14:49:21:90:127.0.0.1:New Web session
14:49:21:89:127.0.0.1:New Web session
14:49:23:WU00:FS00:0xa8:Completed 480000 out of 500000 steps (96%)
14:49:29:106:127.0.0.1:New Web session
14:51:28:WU00:FS00:0xa8:Completed 485000 out of 500000 steps (97%)
14:53:32:WU00:FS00:0xa8:Completed 490000 out of 500000 steps (98%)
14:55:30:WU00:FS00:0xa8:Completed 495000 out of 500000 steps (99%)
14:55:31:WU02:FS00:Connecting to assign1.foldingathome.org:80
14:55:31:WU02:FS00:Assigned to work server 128.252.203.1
14:55:31:WU02:FS00:Requesting new work unit for slot 00: cpu:14 from 128.252.203.1
14:55:31:WU02:FS00:Connecting to 128.252.203.1:8080
14:55:32:ERROR:WU02:FS00:Exception: Server did not assign work unit
14:55:33:WU02:FS00:Connecting to assign1.foldingathome.org:80
14:55:33:WU02:FS00:Assigned to work server 130.237.11.145
14:55:33:WU02:FS00:Requesting new work unit for slot 00: cpu:14 from 130.237.11.145
14:55:33:WU02:FS00:Connecting to 130.237.11.145:8080
14:55:34:WU02:FS00:Downloading 2.06MiB
14:55:40:WU02:FS00:Download 24.24%
14:55:49:WU02:FS00:Download 27.27%
14:55:55:WU02:FS00:Download 48.47%
14:56:03:WU02:FS00:Download 60.59%Re: Project 14909
Have you updated the drivers for you iGP and then restarted?
Re: Project 14909
Interiour Gateway Protocol?
I'm running on wifi. My internet drivers were updated to the latest version. And yes then I restarted. I can connect to the internet just fine, and the CPU programs works fine. I've also run other gpu projects with ease with no problems. But this specific one, I can't even cancel it for some strange reason. And when I reinstall it's always the exact same projects I was running before, doesn't change.
Btw for the gui this is what it's suppose to say. I got this in the advance control.
Re: Project 14909
Some sources have recently started referring to integrated GPUs (iGPU) as IGP or Integrated Graphics Processor. Not a good choice in my opinion for the reason you show, IGP already had a computer related usage. I stick with iGPU to keep the meaning clear. AMD APUs and most Intel processors are examples of processors that include an iGPU.5-MeO-DMT wrote:Interiour Gateway Protocol?
Support for using Intel iGPUs was recently added to the client and is being officially supported on an open Beta status currently for Intel Gen9 iGPUs. As long as drivers are installed and the iGPU enabled, the client will detect the iGPU and by default create a disabled slot. Unless you want to fold on that iGPU you should not need to do anything further with it.
Is the nVidia GPU installed internally in the laptop or external through an eGPU setup? If internally, then your laptop is probably using nVidia's Optimus technology to switch between the iGPU and the RTX 2080 mobile chip. People have reported problems with the Optimus system and folding in the past. Sometimes they have needed to disable to iGPU or set the laptop to always use the nVidia GPU to get F@h to work properly on a GPU WU.
Re: Project 14909
Here are some additional details. It's an ASUS ROG Strix Gaming Notebook. It has a core i9-10980HK
I would guess it's a dedicated gpu attached to the motherboard (dedicated 8gb), but has shared graphics driver with the core i9 with 8gb of memory for it which is a combined shared memory total of 16gb. I am guessing this is something to do with my monitor because it's a 300hz display.
I'll post some more pics so you can see the details between the intel UHD and the nvidia 2080 Super.
Re: Project 14909
I rebooted into the bios, couldn't see any options that were relevant to the graphics driver. Anyways when I booted back in another project took over, I guess I have to reboot after selecting finishing.
Re: Project 14909
With a properly running slot selecting finish will mean that the current wu will complete than no new WU will download and the slot will be paused .. no reboot required .. what probably happened when you rebooted was the client dumped the stalled wu for some reason and you got a new one downloaded that works fine
