Can't Figure Out What's Going On
DrBB1
Post by DrBB1 »
First, some background. About 17 hours ago, I noticed I had four completed WU that were sitting in queue waiting to be successfully uploaded, and a fifth that was actively folding. [I only fold one CPU WU at a time.] I wound up rebooting and while the four completed work units no longer appear in my client interface as waiting to be uploaded, only one appears to have been successfully uploaded based on the stats.
Following is a very confusing (to me) log excerpt from after the reboot. Apparently, something resolved after about an hour, and the persistent set of error messages stopped.
******************************* Date: 2020-12-05 *******************************
02:21:41:WU04:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
02:22:08:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:22:08:ERROR:WU01:FS00:Frame timer not running, starting it
02:22:08:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:22:11:ERROR:WU04:FS00:Exception: Failed to advance statement result: The database file is locked
02:22:40:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:22:40:ERROR:WU01:FS00:Frame timer not running, starting it
02:22:40:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:22:42:WARNING:WU04:FS00:Exception: Failed to advance statement result: The database file is locked
02:22:42:WARNING:WU04:FS00:Detected clock skew (1 mins 01 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
02:23:10:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:23:11:ERROR:WU01:FS00:Frame timer not running, starting it
02:23:11:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:23:41:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:23:41:ERROR:WU01:FS00:Frame timer not running, starting it
02:23:41:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:24:12:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:24:12:ERROR:WU01:FS00:Frame timer not running, starting it
02:24:12:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:24:44:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:24:44:ERROR:WU01:FS00:Frame timer not running, starting it
02:24:44:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:25:15:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:25:15:ERROR:WU01:FS00:Frame timer not running, starting it
02:25:15:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:25:46:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:25:46:ERROR:WU01:FS00:Frame timer not running, starting it
02:25:46:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:26:16:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:26:17:ERROR:WU01:FS00:Frame timer not running, starting it
02:26:17:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:26:47:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:26:47:ERROR:WU01:FS00:Frame timer not running, starting it
02:26:47:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:27:18:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:27:18:ERROR:WU01:FS00:Frame timer not running, starting it
02:27:18:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:27:49:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:27:49:ERROR:WU01:FS00:Frame timer not running, starting it
02:27:49:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:28:20:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:28:20:ERROR:WU01:FS00:Frame timer not running, starting it
02:28:20:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:28:50:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:28:50:ERROR:WU01:FS00:Frame timer not running, starting it
02:28:50:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:29:21:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:29:21:ERROR:WU01:FS00:Frame timer not running, starting it
02:29:21:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:29:52:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:29:52:ERROR:WU01:FS00:Frame timer not running, starting it
02:29:52:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:30:12:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14259 run:0 clone:3217 gen:196 core:0xa7 unit:0x000000dfcedfaa920000000000000c91
02:30:23:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:30:23:ERROR:WU01:FS00:Frame timer not running, starting it
02:30:23:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:30:43:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to advance statement result: The database file is locked
02:30:54:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:30:55:ERROR:WU01:FS00:Frame timer not running, starting it
02:30:55:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:31:25:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:31:25:ERROR:WU01:FS00:Frame timer not running, starting it
02:31:25:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:31:56:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:31:56:ERROR:WU01:FS00:Frame timer not running, starting it
02:31:56:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:32:27:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:32:27:ERROR:WU01:FS00:Frame timer not running, starting it
02:32:27:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:32:58:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:32:58:ERROR:WU01:FS00:Frame timer not running, starting it
02:32:58:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:33:28:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:33:29:ERROR:WU01:FS00:Frame timer not running, starting it
02:33:29:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:33:59:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:34:00:ERROR:WU01:FS00:Frame timer not running, starting it
02:34:00:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:34:31:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:34:31:ERROR:WU01:FS00:Frame timer not running, starting it
02:34:31:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:35:03:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:35:03:ERROR:WU01:FS00:Frame timer not running, starting it
02:35:03:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:35:34:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:35:34:ERROR:WU01:FS00:Frame timer not running, starting it
02:35:34:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:36:06:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:36:06:ERROR:WU01:FS00:Frame timer not running, starting it
02:36:06:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:36:36:WU04:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
02:36:37:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:36:37:ERROR:WU01:FS00:Frame timer not running, starting it
02:36:37:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:37:06:ERROR:WU04:FS00:Exception: Failed to advance statement result: The database file is locked
02:37:07:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:37:08:ERROR:WU01:FS00:Frame timer not running, starting it
02:37:08:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:37:37:WARNING:WU04:FS00:Exception: Failed to advance statement result: The database file is locked
02:37:37:WARNING:WU04:FS00:Detected clock skew (1 mins 01 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
02:37:38:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:37:38:ERROR:WU01:FS00:Frame timer not running, starting it
02:37:38:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:38:04:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13823 run:365 clone:1 gen:166 core:0xa7 unit:0x000000be80fccb0900000000016d0001
02:38:09:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:38:09:ERROR:WU01:FS00:Frame timer not running, starting it
02:38:09:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:38:34:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to advance statement result: The database file is locked
02:38:34:WU00:FS00:Trying to send results to collection server
02:38:39:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:38:40:ERROR:WU01:FS00:Frame timer not running, starting it
02:38:40:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:39:05:ERROR:WU00:FS00:Exception: Failed to advance statement result: The database file is locked
02:39:05:WARNING:WU04:FS00:Detected clock skew (1 mins 02 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
02:39:10:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:39:10:ERROR:WU01:FS00:Frame timer not running, starting it
02:39:10:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:39:35:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:13821 run:545 clone:4 gen:78 core:0xa7 unit:0x0000005a80fccb090000000002210004
02:39:41:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:39:41:ERROR:WU01:FS00:Frame timer not running, starting it
02:39:41:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:40:05:WARNING:WU03:FS00:Exception: Failed to send results to work server: Failed to advance statement result: The database file is locked
02:40:05:WU03:FS00:Trying to send results to collection server
02:40:12:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:40:12:ERROR:WU01:FS00:Frame timer not running, starting it
02:40:12:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:40:36:ERROR:WU03:FS00:Exception: Failed to advance statement result: The database file is locked
02:40:36:WARNING:WU04:FS00:Detected clock skew (1 mins 01 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
02:40:42:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:40:43:ERROR:WU01:FS00:Frame timer not running, starting it
02:40:43:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:41:13:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:41:13:ERROR:WU01:FS00:Frame timer not running, starting it
02:41:13:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:41:44:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:41:44:ERROR:WU01:FS00:Frame timer not running, starting it
02:41:44:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:42:14:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:42:14:ERROR:WU01:FS00:Frame timer not running, starting it
02:42:14:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:42:45:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:42:45:ERROR:WU01:FS00:Frame timer not running, starting it
02:42:45:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:43:17:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:43:18:ERROR:WU01:FS00:Frame timer not running, starting it
02:43:18:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:43:48:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:43:48:ERROR:WU01:FS00:Frame timer not running, starting it
02:43:48:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:44:21:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:44:21:ERROR:WU01:FS00:Frame timer not running, starting it
02:44:21:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:44:51:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:44:52:ERROR:WU01:FS00:Frame timer not running, starting it
02:44:52:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:45:22:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:45:22:ERROR:WU01:FS00:Frame timer not running, starting it
02:45:22:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:45:53:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:45:53:ERROR:WU01:FS00:Frame timer not running, starting it
02:45:53:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:46:24:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:46:24:ERROR:WU01:FS00:Frame timer not running, starting it
02:46:24:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:46:56:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:46:56:ERROR:WU01:FS00:Frame timer not running, starting it
02:46:56:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:47:26:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:47:27:ERROR:WU01:FS00:Frame timer not running, starting it
02:47:27:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:47:57:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:47:57:ERROR:WU01:FS00:Frame timer not running, starting it
02:47:57:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:48:28:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:48:28:ERROR:WU01:FS00:Frame timer not running, starting it
02:48:28:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:48:59:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:48:59:ERROR:WU01:FS00:Frame timer not running, starting it
02:48:59:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:49:30:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:49:31:ERROR:WU01:FS00:Frame timer not running, starting it
02:49:31:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:50:01:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:50:02:ERROR:WU01:FS00:Frame timer not running, starting it
02:50:02:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:50:32:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:50:32:ERROR:WU01:FS00:Frame timer not running, starting it
02:50:32:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:50:53:WU04:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
02:51:03:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:51:04:ERROR:WU01:FS00:Frame timer not running, starting it
02:51:04:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:51:25:ERROR:WU04:FS00:Exception: Failed to advance statement result: The database file is locked
02:51:34:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:51:35:ERROR:WU01:FS00:Frame timer not running, starting it
02:51:35:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:51:55:WARNING:WU04:FS00:Exception: Failed to advance statement result: The database file is locked
02:51:55:WARNING:WU04:FS00:Detected clock skew (1 mins 01 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
02:52:05:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:52:05:ERROR:WU01:FS00:Frame timer not running, starting it
02:52:05:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:52:12:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:17410 run:0 clone:475 gen:239 core:0xa7 unit:0x0000011042aa6f3200000000000001db
02:52:36:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:52:36:ERROR:WU01:FS00:Frame timer not running, starting it
02:52:36:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:52:43:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to advance statement result: The database file is locked
02:53:07:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:53:07:ERROR:WU01:FS00:Frame timer not running, starting it
02:53:07:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:53:38:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:53:38:ERROR:WU01:FS00:Frame timer not running, starting it
02:53:38:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:54:09:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:54:09:ERROR:WU01:FS00:Frame timer not running, starting it
02:54:09:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:54:39:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:54:39:ERROR:WU01:FS00:Frame timer not running, starting it
02:54:39:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:55:10:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:55:10:ERROR:WU01:FS00:Frame timer not running, starting it
02:55:10:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:55:41:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:55:41:ERROR:WU01:FS00:Frame timer not running, starting it
02:55:41:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:56:11:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:56:12:ERROR:WU01:FS00:Frame timer not running, starting it
02:56:12:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:56:42:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:56:42:ERROR:WU01:FS00:Frame timer not running, starting it
02:56:42:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:57:13:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:57:13:ERROR:WU01:FS00:Frame timer not running, starting it
02:57:13:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:57:43:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:57:44:ERROR:WU01:FS00:Frame timer not running, starting it
02:57:44:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:58:14:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:58:14:ERROR:WU01:FS00:Frame timer not running, starting it
02:58:14:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:58:46:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:58:46:ERROR:WU01:FS00:Frame timer not running, starting it
02:58:46:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:59:18:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:59:18:ERROR:WU01:FS00:Frame timer not running, starting it
02:59:18:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
02:59:49:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
02:59:49:ERROR:WU01:FS00:Frame timer not running, starting it
02:59:49:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:00:20:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:00:20:ERROR:WU01:FS00:Frame timer not running, starting it
03:00:20:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:00:50:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:00:51:ERROR:WU01:FS00:Frame timer not running, starting it
03:00:51:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:01:21:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:01:21:ERROR:WU01:FS00:Frame timer not running, starting it
03:01:21:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:01:52:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:01:52:ERROR:WU01:FS00:Frame timer not running, starting it
03:01:52:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:02:22:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:02:23:ERROR:WU01:FS00:Frame timer not running, starting it
03:02:23:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:02:53:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:02:54:ERROR:WU01:FS00:Frame timer not running, starting it
03:02:54:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:03:25:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:03:25:ERROR:WU01:FS00:Frame timer not running, starting it
03:03:25:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:03:55:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:03:56:ERROR:WU01:FS00:Frame timer not running, starting it
03:03:56:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:04:26:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:04:26:ERROR:WU01:FS00:Frame timer not running, starting it
03:04:26:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:04:57:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:04:57:ERROR:WU01:FS00:Frame timer not running, starting it
03:04:57:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:05:29:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:05:29:ERROR:WU01:FS00:Frame timer not running, starting it
03:05:29:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:05:35:WU04:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
03:05:59:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:05:59:ERROR:WU01:FS00:Frame timer not running, starting it
03:05:59:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:06:05:ERROR:WU04:FS00:Exception: Failed to advance statement result: The database file is locked
03:06:31:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:06:31:ERROR:WU01:FS00:Frame timer not running, starting it
03:06:31:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:06:37:WARNING:WU04:FS00:Exception: Failed to advance statement result: The database file is locked
03:06:37:WARNING:WU04:FS00:Detected clock skew (1 mins 02 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
03:07:03:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:07:03:ERROR:WU01:FS00:Frame timer not running, starting it
03:07:03:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:07:34:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:07:34:ERROR:WU01:FS00:Frame timer not running, starting it
03:07:34:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:08:06:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:08:06:ERROR:WU01:FS00:Frame timer not running, starting it
03:08:06:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:08:39:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:08:39:ERROR:WU01:FS00:Frame timer not running, starting it
03:08:39:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:09:12:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:09:12:ERROR:WU01:FS00:Frame timer not running, starting it
03:09:12:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:09:46:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:09:46:ERROR:WU01:FS00:Frame timer not running, starting it
03:09:46:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:10:17:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:10:17:ERROR:WU01:FS00:Frame timer not running, starting it
03:10:17:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:10:48:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:10:48:ERROR:WU01:FS00:Frame timer not running, starting it
03:10:48:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:11:19:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:11:19:ERROR:WU01:FS00:Frame timer not running, starting it
03:11:19:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:11:50:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:11:50:ERROR:WU01:FS00:Frame timer not running, starting it
03:11:50:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:12:21:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:12:21:ERROR:WU01:FS00:Frame timer not running, starting it
03:12:21:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:12:52:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:12:52:ERROR:WU01:FS00:Frame timer not running, starting it
03:12:52:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:13:23:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:13:23:ERROR:WU01:FS00:Frame timer not running, starting it
03:13:23:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:13:54:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:13:55:ERROR:WU01:FS00:Frame timer not running, starting it
03:13:55:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:14:26:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:14:27:ERROR:WU01:FS00:Frame timer not running, starting it
03:14:27:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:14:57:ERROR:WU01:FS00:Exception: Failed to advance statement result: The database file is locked
03:14:58:ERROR:WU01:FS00:Frame timer not running, starting it
03:14:58:WARNING:WU01:FS00:FahCore returned: CORE_RESTART (98 = 0x62)
03:15:05:FS00:Shutting core down
03:15:06:WU04:FS00:0xa7:WARNING:Console control signal 1 on PID 6892
03:15:06:WU04:FS00:0xa7:Exiting, please wait. . .
03:15:14:Clean exit
03:15:15:WU01:FS00:Starting
03:15:15:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 9024 -checkpoint 15 -np 4
03:15:15:WU01:FS00:Started FahCore on PID 1060
03:15:15:WU01:FS00:Core PID:7880
03:15:15:WU01:FS00:FahCore 0xa7 started
03:15:16:WU01:FS00:0xa7:*********************** Log Started 2020-12-05T03:15:15Z ***********************
03:15:16:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:15:16:WU01:FS00:0xa7:       Type: 0xa7
03:15:16:WU01:FS00:0xa7:       Core: Gromacs
03:15:16:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1060 -checkpoint 15 -np 4
03:15:16:WU01:FS00:0xa7:************************************ CBang *************************************
03:15:16:WU01:FS00:0xa7:       Date: Nov 27 2019
03:15:16:WU01:FS00:0xa7:       Time: 03:40:13
03:15:16:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
03:15:16:WU01:FS00:0xa7:     Branch: master
03:15:16:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
03:15:16:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:15:16:WU01:FS00:0xa7:   Platform: win32 10
03:15:16:WU01:FS00:0xa7:       Bits: 64
03:15:16:WU01:FS00:0xa7:       Mode: Release
03:15:16:WU01:FS00:0xa7:************************************ System ************************************
03:15:16:WU01:FS00:0xa7:        CPU: AMD Phenom(tm) II X4 810 Processor
03:15:16:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
03:15:16:WU01:FS00:0xa7:       CPUs: 4
03:15:16:WU01:FS00:0xa7:     Memory: 7.75GiB
03:15:16:WU01:FS00:0xa7:Free Memory: 4.41GiB
03:15:16:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
03:15:16:WU01:FS00:0xa7: OS Version: 6.2
03:15:16:WU01:FS00:0xa7:Has Battery: false
03:15:16:WU01:FS00:0xa7: On Battery: false
03:15:16:WU01:FS00:0xa7: UTC Offset: -5
03:15:16:WU01:FS00:0xa7:        PID: 7880
03:15:16:WU01:FS00:0xa7:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
03:15:16:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
03:15:16:WU01:FS00:0xa7:    Version: 0.0.19
03:15:16:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:15:16:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:15:16:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
03:15:16:WU01:FS00:0xa7:       Date: Nov 25 2019
03:15:16:WU01:FS00:0xa7:       Time: 17:12:41
03:15:16:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
03:15:16:WU01:FS00:0xa7:************************************ Build *************************************
03:15:16:WU01:FS00:0xa7:       SIMD: sse2
03:15:16:WU01:FS00:0xa7:********************************************************************************
03:15:16:WU01:FS00:0xa7:Project: 17410 (Run 0, Clone 475, Gen 239)
03:15:16:WU01:FS00:0xa7:Unit: 0x0000011042aa6f3200000000000001db
03:15:16:WU01:FS00:0xa7:Reading tar file core.xml
03:15:16:WU01:FS00:0xa7:Reading tar file frame239.tpr
03:15:17:WU01:FS00:0xa7:Digital signatures verified
03:15:17:WU01:FS00:0xa7:Calling: mdrun -s frame239.tpr -o frame239.trr -x frame239.xtc -cpt 15 -nt 4
03:15:17:WU01:FS00:0xa7:Steps: first=29875000 total=125000
03:15:27:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
03:15:39:WU00:FS00:Connecting to assign1.foldingathome.org:80
03:15:40:WU00:FS00:Assigned to work server 69.94.66.6
03:15:40:WU00:FS00:Requesting new work unit for slot 00: cpu:4 - RUNNING from 69.94.66.6
03:15:40:WU00:FS00:Connecting to 69.94.66.6:8080
03:15:41:WU00:FS00:Downloading 2.82MiB
03:15:42:WU00:FS00:Download complete
03:15:42:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14815 run:1339 clone:1 gen:201 core:0xa7 unit:0x000000ef455e420600000000053b0001
03:15:42:25:127.0.0.1:New Web session
03:21:10:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
03:25:58:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
03:30:49:WU01:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
03:35:42:WU01:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
03:40:39:WU01:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
03:45:32:WU01:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
03:50:21:WU01:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
03:55:09:WU01:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
03:59:58:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
04:04:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:04:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:04:57:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
04:09:48:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
04:14:38:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
04:19:29:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
04:24:18:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
04:29:14:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
04:34:07:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
04:39:00:WU01:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
04:43:49:WU01:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
04:48:39:WU01:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
04:53:31:WU01:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
04:58:30:WU01:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
05:03:53:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
05:08:43:WU01:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
05:13:35:WU01:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
05:18:27:WU01:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
05:19:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:23:25:WU01:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
05:28:15:WU01:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
05:28:24:WARNING:WU01:FS00:Past final deadline 2020-12-05T05:28:23Z, dumping
05:28:24:WU01:FS00:Shutting core down
05:28:24:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 7880
05:28:24:WU01:FS00:0xa7:Exiting, please wait. . .
05:28:30:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
05:28:31:WU00:FS00:Starting
05:28:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 9024 -checkpoint 15 -np 4
05:28:31:WU00:FS00:Started FahCore on PID 12196
05:28:31:WU00:FS00:Core PID:3884
05:28:31:WU00:FS00:FahCore 0xa7 started
05:28:31:WU00:FS00:0xa7:*********************** Log Started 2020-12-05T05:28:31Z ***********************
05:28:31:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:28:31:WU00:FS00:0xa7:       Type: 0xa7
05:28:31:WU00:FS00:0xa7:       Core: Gromacs
05:28:31:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 12196 -checkpoint 15 -np
05:28:31:WU00:FS00:0xa7:             4
05:28:31:WU00:FS00:0xa7:************************************ CBang *************************************
05:28:31:WU00:FS00:0xa7:       Date: Nov 27 2019
05:28:31:WU00:FS00:0xa7:       Time: 03:40:13
05:28:31:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
05:28:31:WU00:FS00:0xa7:     Branch: master
05:28:31:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
05:28:31:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:28:31:WU00:FS00:0xa7:   Platform: win32 10
05:28:31:WU00:FS00:0xa7:       Bits: 64
05:28:31:WU00:FS00:0xa7:       Mode: Release
05:28:31:WU00:FS00:0xa7:************************************ System ************************************
05:28:31:WU00:FS00:0xa7:        CPU: AMD Phenom(tm) II X4 810 Processor
05:28:31:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
05:28:31:WU00:FS00:0xa7:       CPUs: 4
05:28:31:WU00:FS00:0xa7:     Memory: 7.75GiB
05:28:31:WU00:FS00:0xa7:Free Memory: 5.18GiB
05:28:31:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
05:28:31:WU00:FS00:0xa7: OS Version: 6.2
05:28:31:WU00:FS00:0xa7:Has Battery: false
05:28:31:WU00:FS00:0xa7: On Battery: false
05:28:31:WU00:FS00:0xa7: UTC Offset: -5
05:28:31:WU00:FS00:0xa7:        PID: 3884
05:28:31:WU00:FS00:0xa7:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
05:28:31:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
05:28:31:WU00:FS00:0xa7:    Version: 0.0.19
05:28:31:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:28:31:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:28:31:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
05:28:31:WU00:FS00:0xa7:       Date: Nov 25 2019
05:28:31:WU00:FS00:0xa7:       Time: 17:12:41
05:28:31:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
05:28:31:WU00:FS00:0xa7:************************************ Build *************************************
05:28:31:WU00:FS00:0xa7:       SIMD: sse2
05:28:31:WU00:FS00:0xa7:********************************************************************************
05:28:31:WU00:FS00:0xa7:Project: 14815 (Run 1339, Clone 1, Gen 201)
05:28:31:WU00:FS00:0xa7:Unit: 0x000000ef455e420600000000053b0001
05:28:31:WU00:FS00:0xa7:Reading tar file core.xml
05:28:31:WU00:FS00:0xa7:Reading tar file frame201.tpr
05:28:31:WU00:FS00:0xa7:Digital signatures verified
05:28:31:WU00:FS00:0xa7:Calling: mdrun -s frame201.tpr -o frame201.trr -cpt 15 -nt 4
05:28:31:WU00:FS00:0xa7:Steps: first=0 total=250000
05:28:32:WU02:FS00:Connecting to assign1.foldingathome.org:80
05:28:34:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
05:28:52:WU02:FS00:Assigned to work server 206.223.170.146
05:28:52:WU02:FS00:Requesting new work unit for slot 00: cpu:4 - RUNNING from 206.223.170.146
05:28:52:WU02:FS00:Connecting to 206.223.170.146:8080
05:28:53:ERROR:WU02:FS00:Exception: Server did not assign work unit
05:28:53:WU02:FS00:Connecting to assign1.foldingathome.org:80
05:28:54:WU02:FS00:Assigned to work server 178.174.196.138
05:28:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:28:54:WU02:FS00:Requesting new work unit for slot 00: cpu:4 - RUNNING from 178.174.196.138
05:28:54:WU02:FS00:Connecting to 178.174.196.138:8080
05:28:55:WU02:FS00:Downloading 2.05MiB
05:28:56:WU02:FS00:Download complete
05:28:56:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16812 run:7 clone:470 gen:61 core:0xa8 unit:0x00000046b2aec48a00000000000701d6
05:29:24:WU01:FS00:Cleaning up
05:33:05:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
05:37:36:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
05:42:02:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
05:46:41:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
05:51:07:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
05:55:34:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
06:00:02:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
06:04:30:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
06:09:01:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
06:13:35:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
06:18:01:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
06:22:27:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
06:26:53:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
06:31:21:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
06:34:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:36:01:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
06:40:29:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
06:44:57:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
06:49:23:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
06:53:48:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
06:58:14:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
07:02:56:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
07:07:23:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
07:11:50:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
07:16:21:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
07:20:50:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
07:24:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
07:25:25:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
07:29:55:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
07:34:21:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
07:38:52:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
07:43:17:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
07:47:43:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
07:52:23:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
07:56:53:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
08:01:25:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
08:04:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:05:53:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
08:10:22:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
08:15:05:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
08:19:39:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
08:24:08:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
08:28:36:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
08:33:05:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
08:37:38:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
08:42:16:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
08:46:48:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
08:51:16:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
08:55:59:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
09:00:33:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
09:05:14:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
09:09:48:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
09:14:22:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
09:18:54:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
09:23:27:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
09:27:57:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
09:28:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
09:32:42:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
09:32:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
09:37:17:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
09:41:45:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
09:46:19:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
09:50:51:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
09:53:57:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
09:55:31:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
10:00:08:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
10:04:41:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
10:09:13:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
10:13:47:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
10:18:20:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
10:23:04:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
10:27:35:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
10:32:08:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
10:36:45:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
10:41:17:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
10:46:00:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
10:50:33:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
10:55:04:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
10:59:38:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
11:04:11:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
11:08:49:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
11:13:26:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
11:17:58:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
11:22:30:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
11:27:01:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
11:31:33:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
11:36:17:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
11:40:48:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
11:45:20:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
11:49:51:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
11:54:21:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
11:59:01:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
12:03:29:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
12:05:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
12:08:09:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
12:12:39:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
12:17:09:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
12:21:35:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
12:23:41:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
12:26:11:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
12:30:37:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
12:35:07:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
12:39:32:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
12:43:58:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
12:48:26:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
12:48:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
12:52:58:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
12:57:22:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
13:01:47:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
13:01:50:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
13:01:50:WU00:FS00:0xa7:Saving result file dhdl.xvg
13:01:50:WU00:FS00:0xa7:Saving result file frame201.trr
13:01:50:WU00:FS00:0xa7:Saving result file md.log
13:01:50:WU00:FS00:0xa7:Saving result file pullf.xvg
13:01:50:WU00:FS00:0xa7:Saving result file pullx.xvg
13:01:50:WU00:FS00:0xa7:Saving result file science.log
13:01:50:WU00:FS00:0xa7:Saving result file traj_comp.xtc
13:01:50:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
13:01:51:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:01:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14815 run:1339 clone:1 gen:201 core:0xa7 unit:0x000000ef455e420600000000053b0001
13:01:51:WU00:FS00:Uploading 6.77MiB to 69.94.66.6
13:01:51:WU02:FS00:Starting
13:01:51:WU00:FS00:Connecting to 69.94.66.6:8080
13:01:51:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-sse2/a8-0.0.9/Core_a8.fah/FahCore_a8.exe -dir 02 -suffix 01 -version 706 -lifeline 9024 -checkpoint 15 -np 4
13:01:51:WU02:FS00:Started FahCore on PID 9140
13:01:51:WU02:FS00:Core PID:3704
13:01:51:WU02:FS00:FahCore 0xa8 started
13:01:52:WU02:FS00:0xa8:*********************** Log Started 2020-12-05T13:01:51Z ***********************
13:01:52:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
13:01:52:WU02:FS00:0xa8:       Core: Gromacs
13:01:52:WU02:FS00:0xa8:       Type: 0xa8
13:01:52:WU02:FS00:0xa8:    Version: 0.0.9
13:01:52:WU02:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:01:52:WU02:FS00:0xa8:  Copyright: 2020 foldingathome.org
13:01:52:WU02:FS00:0xa8:   Homepage: https://foldingathome.org/
13:01:52:WU02:FS00:0xa8:       Date: Oct 28 2020
13:01:52:WU02:FS00:0xa8:       Time: 15:12:32
13:01:52:WU02:FS00:0xa8:   Revision: 15f9b5e1edd6089f1a45553d2709a6aba62f735c
13:01:52:WU02:FS00:0xa8:     Branch: master
13:01:52:WU02:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
13:01:52:WU02:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:01:52:WU02:FS00:0xa8:   Platform: win32 10
13:01:52:WU02:FS00:0xa8:       Bits: 64
13:01:52:WU02:FS00:0xa8:       Mode: Release
13:01:52:WU02:FS00:0xa8:       SIMD: sse2
13:01:52:WU02:FS00:0xa8:     OpenMP: ON
13:01:52:WU02:FS00:0xa8:       CUDA: OFF
13:01:52:WU02:FS00:0xa8:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9140 -checkpoint 15 -np 4
13:01:52:WU02:FS00:0xa8:************************************ libFAH ************************************
13:01:52:WU02:FS00:0xa8:       Time: 15:11:42
13:01:52:WU02:FS00:0xa8:************************************ CBang *************************************
13:01:52:WU02:FS00:0xa8:       Time: 15:11:22
13:01:52:WU02:FS00:0xa8:************************************ System ************************************
13:01:52:WU02:FS00:0xa8:        CPU: AMD Phenom(tm) II X4 810 Processor
13:01:52:WU02:FS00:0xa8:     CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
13:01:52:WU02:FS00:0xa8:       CPUs: 4
13:01:52:WU02:FS00:0xa8:     Memory: 7.75GiB
13:01:52:WU02:FS00:0xa8:Free Memory: 5.16GiB
13:01:52:WU02:FS00:0xa8:    Threads: WINDOWS_THREADS
13:01:52:WU02:FS00:0xa8: OS Version: 6.2
13:01:52:WU02:FS00:0xa8:Has Battery: false
13:01:52:WU02:FS00:0xa8: On Battery: false
13:01:52:WU02:FS00:0xa8: UTC Offset: -5
13:01:52:WU02:FS00:0xa8:        PID: 3704
13:01:52:WU02:FS00:0xa8:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
13:01:52:WU02:FS00:0xa8:********************************************************************************
13:01:52:WU02:FS00:0xa8:Project: 16812 (Run 7, Clone 470, Gen 61)
13:01:52:WU02:FS00:0xa8:Unit: 0x00000046b2aec48a00000000000701d6
13:01:52:WU02:FS00:0xa8:Reading tar file core.xml
13:01:52:WU02:FS00:0xa8:Reading tar file frame61.tpr
13:01:52:WU02:FS00:0xa8:Digital signatures verified
13:01:52:WU02:FS00:0xa8:Calling: mdrun -c frame61.gro -s frame61.tpr -x frame61.xtc -cpt 15 -nt 4 -ntmpi 1
13:01:52:WU02:FS00:0xa8:Steps: first=30500000 total=31000000
13:01:54:WU02:FS00:0xa8:Completed 1 out of 500000 steps (0%)
13:01:57:WU00:FS00:Upload 35.99%
13:02:03:WU00:FS00:Upload 72.91%
13:02:07:WU00:FS00:Upload complete
13:02:07:WU00:FS00:Server responded WORK_ACK (400)
13:02:07:WU00:FS00:Final credit estimate, 2192.00 points
13:02:07:WU00:FS00:Cleaning up
13:11:18:WU02:FS00:0xa8:Completed 5000 out of 500000 steps (1%)
13:13:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
13:20:54:WU02:FS00:0xa8:Completed 10000 out of 500000 steps (2%)
13:30:19:WU02:FS00:0xa8:Completed 15000 out of 500000 steps (3%)
13:39:59:WU02:FS00:0xa8:Completed 20000 out of 500000 steps (4%)
13:49:28:WU02:FS00:0xa8:Completed 25000 out of 500000 steps (5%)
13:58:52:WU02:FS00:0xa8:Completed 30000 out of 500000 steps (6%)
14:03:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
14:08:27:WU02:FS00:0xa8:Completed 35000 out of 500000 steps (7%)
14:17:53:WU02:FS00:0xa8:Completed 40000 out of 500000 steps (8%)
14:27:18:WU02:FS00:0xa8:Completed 45000 out of 500000 steps (9%)
14:28:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
14:36:58:WU02:FS00:0xa8:Completed 50000 out of 500000 steps (10%)
14:46:22:WU02:FS00:0xa8:Completed 55000 out of 500000 steps (11%)
14:53:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
14:55:57:WU02:FS00:0xa8:Completed 60000 out of 500000 steps (12%)
15:05:22:WU02:FS00:0xa8:Completed 65000 out of 500000 steps (13%)
15:14:46:WU02:FS00:0xa8:Completed 70000 out of 500000 steps (14%)
15:18:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:24:22:WU02:FS00:0xa8:Completed 75000 out of 500000 steps (15%)
15:33:48:WU02:FS00:0xa8:Completed 80000 out of 500000 steps (16%)
15:43:25:WU02:FS00:0xa8:Completed 85000 out of 500000 steps (17%)
15:43:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:52:55:WU02:FS00:0xa8:Completed 90000 out of 500000 steps (18%)
16:02:19:WU02:FS00:0xa8:Completed 95000 out of 500000 steps (19%)
16:12:02:WU02:FS00:0xa8:Completed 100000 out of 500000 steps (20%)
16:21:28:WU02:FS00:0xa8:Completed 105000 out of 500000 steps (21%)
16:30:53:WU02:FS00:0xa8:Completed 110000 out of 500000 steps (22%)
16:33:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:40:34:WU02:FS00:0xa8:Completed 115000 out of 500000 steps (23%)
16:49:59:WU02:FS00:0xa8:Completed 120000 out of 500000 steps (24%)
16:58:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:59:30:WU02:FS00:0xa8:Completed 125000 out of 500000 steps (25%)
17:08:58:WU02:FS00:0xa8:Completed 130000 out of 500000 steps (26%)
17:18:24:WU02:FS00:0xa8:Completed 135000 out of 500000 steps (27%)
17:27:59:WU02:FS00:0xa8:Completed 140000 out of 500000 steps (28%)
17:37:30:WU02:FS00:0xa8:Completed 145000 out of 500000 steps (29%)
17:46:53:WU02:FS00:0xa8:Completed 150000 out of 500000 steps (30%)
17:56:29:WU02:FS00:0xa8:Completed 155000 out of 500000 steps (31%)
18:05:53:WU02:FS00:0xa8:Completed 160000 out of 500000 steps (32%)
18:20:40:WU02:FS00:0xa8:Completed 165000 out of 500000 steps (33%)
18:36:24:WU02:FS00:0xa8:Completed 170000 out of 500000 steps (34%)
18:54:15:WU02:FS00:0xa8:Completed 175000 out of 500000 steps (35%)
19:03:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:11:49:WU02:FS00:0xa8:Completed 180000 out of 500000 steps (36%)
19:28:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:30:03:WU02:FS00:0xa8:Completed 185000 out of 500000 steps (37%)
However, since that time at irregular intervals I have been getting the following error written to the log:
I made no changes to my system (that I am aware of) over the past few days that would account for these issues. FWIW, my client is 7.6.20, running on Windows 10 Home. I also did two targeted virus scans of my \AppData\Roaming\FAHClient folder (Malwarebytes and Avast), which came up clean.
Thanks in advance for any insights, especially about the implications of Error 10053 for the current WU and beyond.
DrBB1
gs60
Re: Can't Figure Out What's Going On
Post by gs60 »
Hello,
Here is a good place to start: viewtopic.php?f=61&t=23475
It seems that the locked issue usually points to two 2 copies of fah trying to run at the same time.
DrBB1
Post by DrBB1 »
Thanks gs60. I checked and I only have one instance of the three F@H processes running that are referred to in the link you shared.
DrBB1
Ignore the message:
It generally means that you were running something optional (like the protein-viewer or web-control) and you simply used WIndows to closed that window rather than using the Exit button inside of the app.
Closing a window is a normal activity and it certainly shouldn't produce an ERROR message in another program that happens to be communicating with the window you closed.
DrBB1
Post by DrBB1 »
Thanks bruce. That may be the answer. Apparently, a Windows update was started overnight (despite my having temporarily suspended any updates) that caused my PC to shut down and do an initial reboot. Once I discovered this, I rebooted again (for a total of three), which apparently completed the update. F@H is now running with no error messages.
DrBB1
