GPU Failing after several retries
jcnwilson
Post by jcnwilson »
Hello,
My GPU has been giving me trouble for the past 24 hours or so, in that it won't fold anymore. I have a Radeon 7970GHz that has been working constantly for the past 9 months or so until yesterday. I have made sure the drivers are fully updated and that the GPU is working as it should by stress testing it with FurMark. My issue is that it will get work units, but before the GPU even leaves idle, it gives the "FAULTY" error and returns it as a "BAD_WORK_UNIT" repeatedly until it gives the "FAILED" error on FAHControl. I have tried to fix it by deleting the cores and work units under the Roaming file, forcing it to download new copies, and updating F@H to the latest version with no luck. I have attached the config and the latest log file in case that is helpful.
Thank you in advance for any help, and if this is the wrong place to post, I apologize (long time folder, first time caller).
Config:
<?xml version="1.0"?>
-<config>
<cause v="COVID_19"/>
<!-- Network -->
<proxy v=":8080"/>
<!-- Slot Control -->
<power v="full"/>
<!-- User Information -->
<passkey v="REDACTED"/>
<team v="50959"/>
<user v="theent"/>
<!-- Folding Slots -->
-<slot type="CPU" id="0">
<client-type v="beta"/>
</slot>
<slot type="GPU" id="1"/>
</config>
Log:
19:57:30:</config>
19:57:43:WU01:FS01:0x22:Attempting to create OpenCL context:
19:57:43:WU01:FS01:0x22:  Configuring platform OpenCL
19:57:55:WU01:FS01:0x22:Failed to create OpenCL context:
19:57:55:WU01:FS01:0x22:Error compiling kernel: "C:\Users\User\AppData\Local\Temp\OCL17636T24.cl", line 21: warning: OpenCL
19:57:55:WU01:FS01:0x22:          extension is now part of core
19:57:55:WU01:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
19:57:55:WU01:FS01:0x22:                           ^
19:57:55:WU01:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
19:57:55:WU01:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
19:57:55:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
19:57:55:WU01:FS01:0x22:Saving result file science.log
19:57:55:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:57:55:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:57:55:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13428 run:2862 clone:44 gen:0 core:0x22 unit:0x0000000012bc7d9a000000000b2e002c
19:57:55:WU01:FS01:Uploading 2.76KiB to 18.188.125.154
19:57:55:WU01:FS01:Connecting to 18.188.125.154:8080
19:57:55:WU01:FS01:Upload complete
19:57:55:WU01:FS01:Server responded WORK_ACK (400)
19:57:55:WU01:FS01:Cleaning up
19:57:55:WU02:FS01:Connecting to assign1.foldingathome.org:80
19:57:56:WU02:FS01:Assigned to work server 18.188.125.154
19:57:56:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 18.188.125.154
19:57:56:WU02:FS01:Connecting to 18.188.125.154:8080
19:57:57:WU02:FS01:Downloading 6.72MiB
19:57:58:WU02:FS01:Download complete
19:57:58:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13428 run:2863 clone:48 gen:0 core:0x22 unit:0x0000000012bc7d9a000000000b2f0030
19:57:58:WU02:FS01:Starting
19:57:58:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:57:58:WU02:FS01:Started FahCore on PID 11180
19:57:58:WU02:FS01:Core PID:6344
19:57:58:WU02:FS01:FahCore 0x22 started
19:57:59:WU02:FS01:0x22:*********************** Log Started 2020-12-03T19:57:58Z ****
19:57:59:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***
19:57:59:WU02:FS01:0x22:       Core: Core22
19:57:59:WU02:FS01:0x22:       Type: 0x22
19:57:59:WU02:FS01:0x22:    Version: 0.0.13
19:57:59:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:57:59:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
19:57:59:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
19:57:59:WU02:FS01:0x22:       Date: Sep 19 2020
19:57:59:WU02:FS01:0x22:       Time: 02:35:58
19:57:59:WU02:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:57:59:WU02:FS01:0x22:     Branch: core22-0.0.13
19:57:59:WU02:FS01:0x22:   Compiler: Visual C++ 2015
19:57:59:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:57:59:WU02:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
19:57:59:WU02:FS01:0x22:   Platform: win32 10
19:57:59:WU02:FS01:0x22:       Bits: 64
19:57:59:WU02:FS01:0x22:       Mode: Release
19:57:59:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:57:59:WU02:FS01:0x22:             <peastman@stanford.edu>
19:57:59:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 11180 -checkpoint 15
19:57:59:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:57:59:WU02:FS01:0x22:***** libFAH ****
19:57:59:WU02:FS01:0x22:       Date: Sep 7 2020
19:57:59:WU02:FS01:0x22:       Time: 19:09:56
19:57:59:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:57:59:WU02:FS01:0x22:     Branch: HEAD
19:57:59:WU02:FS01:0x22:******** CBang ***
19:57:59:WU02:FS01:0x22:       Time: 19:08:30
19:57:59:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:57:59:WU02:FS01:0x22:***** System **
19:57:59:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
19:57:59:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:57:59:WU02:FS01:0x22:       CPUs: 8
19:57:59:WU02:FS01:0x22:     Memory: 15.95GiB
19:57:59:WU02:FS01:0x22:Free Memory: 8.31GiB
19:57:59:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
19:57:59:WU02:FS01:0x22: OS Version: 6.2
19:57:59:WU02:FS01:0x22:Has Battery: false
19:57:59:WU02:FS01:0x22: On Battery: false
19:57:59:WU02:FS01:0x22: UTC Offset: -6
19:57:59:WU02:FS01:0x22:        PID: 6344
19:57:59:WU02:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
19:57:59:WU02:FS01:0x22:************************************ OpenMM *****
19:57:59:WU02:FS01:0x22:   Revision: 189320d0
19:57:59:WU02:FS01:0x22:Project: 13428 (Run 2863, Clone 48, Gen 0)
19:57:59:WU02:FS01:0x22:Unit: 0x0000000012bc7d9a000000000b2f0030
19:57:59:WU02:FS01:0x22:Reading tar file core.xml
19:57:59:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
19:57:59:WU02:FS01:0x22:Reading tar file state.xml.bz2
19:57:59:WU02:FS01:0x22:Reading tar file system.xml.bz2
19:57:59:WU02:FS01:0x22:Digital signatures verified
19:57:59:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:57:59:WU02:FS01:0x22:Version 0.0.13
19:58:00:WU02:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
19:58:00:WU02:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
19:58:00:WU02:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
19:58:00:WU02:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
19:58:00:WU02:FS01:0x22:There are 3 platforms available.
19:58:00:WU02:FS01:0x22:Platform 0: Reference
19:58:00:WU02:FS01:0x22:Platform 1: CPU
19:58:00:WU02:FS01:0x22:Platform 2: OpenCL
19:58:00:WU02:FS01:0x22:  opencl-device 0 specified
19:58:25:WU02:FS01:0x22:Attempting to create OpenCL context:
19:58:25:WU02:FS01:0x22:  Configuring platform OpenCL
19:58:38:WU02:FS01:0x22:Failed to create OpenCL context:
19:58:38:WU02:FS01:0x22:Error compiling kernel: "C:\Users\User\AppData\Local\Temp\OCL6344T24.cl", line 21: warning: OpenCL
19:58:38:WU02:FS01:0x22:          extension is now part of core
19:58:38:WU02:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
19:58:38:WU02:FS01:0x22:                           ^
19:58:38:WU02:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
19:58:38:WU02:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
19:58:38:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
19:58:38:WU02:FS01:0x22:Saving result file science.log
19:58:38:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:58:38:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:58:38:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13428 run:2863 clone:48 gen:0 core:0x22 unit:0x0000000012bc7d9a000000000b2f0030
19:58:38:WU02:FS01:Uploading 2.76KiB to 18.188.125.154
19:58:38:WU02:FS01:Connecting to 18.188.125.154:8080
19:58:39:WU02:FS01:Upload complete
19:58:39:WU02:FS01:Server responded WORK_ACK (400)
19:58:39:WU02:FS01:Cleaning up
19:58:39:WU01:FS01:Connecting to assign1.foldingathome.org:80
19:58:39:WU01:FS01:Assigned to work server 18.188.125.154
19:58:39:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 18.188.125.154
19:58:39:WU01:FS01:Connecting to 18.188.125.154:8080
19:58:41:WU01:FS01:Downloading 6.73MiB
19:58:42:WU01:FS01:Download complete
19:58:42:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13428 run:2866 clone:49 gen:0 core:0x22 unit:0x0000000012bc7d9a000000000b320031
19:58:42:WU01:FS01:Starting
19:58:42:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:58:42:WU01:FS01:Started FahCore on PID 12256
19:58:42:WU01:FS01:Core PID:11608
19:58:42:WU01:FS01:FahCore 0x22 started
19:58:42:WU01:FS01:0x22:*********************** Log Started 2020-12-03T19:58:42Z ***
19:58:42:WU01:FS01:0x22:*************************** Core22 Folding@home Core **
19:58:42:WU01:FS01:0x22:       Core: Core22
19:58:42:WU01:FS01:0x22:       Type: 0x22
19:58:42:WU01:FS01:0x22:    Version: 0.0.13
19:58:42:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:58:42:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
19:58:42:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
19:58:42:WU01:FS01:0x22:       Date: Sep 19 2020
19:58:42:WU01:FS01:0x22:       Time: 02:35:58
19:58:42:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:58:42:WU01:FS01:0x22:     Branch: core22-0.0.13
19:58:42:WU01:FS01:0x22:   Compiler: Visual C++ 2015
19:58:42:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:58:42:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
19:58:42:WU01:FS01:0x22:   Platform: win32 10
19:58:42:WU01:FS01:0x22:       Bits: 64
19:58:42:WU01:FS01:0x22:       Mode: Release
19:58:42:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:58:42:WU01:FS01:0x22:             <peastman@stanford.edu>
19:58:42:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 12256 -checkpoint 15
19:58:43:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:58:43:WU01:FS01:0x22:************************************ libFAH **
19:58:43:WU01:FS01:0x22:       Date: Sep 7 2020
19:58:43:WU01:FS01:0x22:       Time: 19:09:56
19:58:43:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:58:43:WU01:FS01:0x22:     Branch: HEAD
19:58:43:WU01:FS01:0x22:   Compiler: Visual C++ 2015
19:58:43:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:58:43:WU01:FS01:0x22:   Platform: win32 10
19:58:43:WU01:FS01:0x22:       Bits: 64
19:58:43:WU01:FS01:0x22:       Mode: Release
19:58:43:WU01:FS01:0x22:************************************ CBang ****
19:58:43:WU01:FS01:0x22:       Time: 19:08:30
19:58:43:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:58:43:WU01:FS01:0x22:************************************ System ****
19:58:43:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
19:58:43:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:58:43:WU01:FS01:0x22:       CPUs: 8
19:58:43:WU01:FS01:0x22:     Memory: 15.95GiB
19:58:43:WU01:FS01:0x22:Free Memory: 8.38GiB
19:58:43:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:58:43:WU01:FS01:0x22: OS Version: 6.2
19:58:43:WU01:FS01:0x22:Has Battery: false
19:58:43:WU01:FS01:0x22: On Battery: false
19:58:43:WU01:FS01:0x22: UTC Offset: -6
19:58:43:WU01:FS01:0x22:        PID: 11608
19:58:43:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
19:58:43:WU01:FS01:0x22:************************************ OpenMM ****
19:58:43:WU01:FS01:0x22:   Revision: 189320d0
19:58:43:WU01:FS01:0x22:Project: 13428 (Run 2866, Clone 49, Gen 0)
19:58:43:WU01:FS01:0x22:Unit: 0x0000000012bc7d9a000000000b320031
19:58:43:WU01:FS01:0x22:Reading tar file core.xml
19:58:43:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
19:58:43:WU01:FS01:0x22:Reading tar file state.xml.bz2
19:58:43:WU01:FS01:0x22:Reading tar file system.xml.bz2
19:58:43:WU01:FS01:0x22:Digital signatures verified
19:58:43:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:58:43:WU01:FS01:0x22:Version 0.0.13
19:58:44:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
19:58:44:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
19:58:44:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
19:58:44:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
19:58:44:WU01:FS01:0x22:There are 3 platforms available.
19:58:44:WU01:FS01:0x22:Platform 0: Reference
19:58:44:WU01:FS01:0x22:Platform 1: CPU
19:58:44:WU01:FS01:0x22:Platform 2: OpenCL
19:58:44:WU01:FS01:0x22:  opencl-device 0 specified
19:59:08:WU01:FS01:0x22:Attempting to create OpenCL context:
19:59:08:WU01:FS01:0x22:  Configuring platform OpenCL
19:59:19:WU01:FS01:0x22:Failed to create OpenCL context:
19:59:19:WU01:FS01:0x22:Error compiling kernel: "C:\Users\User\AppData\Local\Temp\OCL11608T24.cl", line 21: warning: OpenCL
19:59:19:WU01:FS01:0x22:          extension is now part of core
19:59:19:WU01:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
19:59:19:WU01:FS01:0x22:                           ^
19:59:19:WU01:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
19:59:19:WU01:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
19:59:19:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
19:59:19:WU01:FS01:0x22:Saving result file science.log
19:59:19:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:59:19:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:59:19:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13428 run:2866 clone:49 gen:0 core:0x22 unit:0x0000000012bc7d9a000000000b320031
19:59:19:WU01:FS01:Uploading 2.76KiB to 18.188.125.154
19:59:19:WU01:FS01:Connecting to 18.188.125.154:8080
19:59:19:WU01:FS01:Upload complete
19:59:19:WU01:FS01:Server responded WORK_ACK (400)
19:59:19:WU01:FS01:Cleaning up
19:59:19:WU01:FS01:Connecting to assign1.foldingathome.org:80
19:59:20:WU01:FS01:Assigned to work server 18.188.125.154
19:59:20:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 18.188.125.154
19:59:20:WU01:FS01:Connecting to 18.188.125.154:8080
19:59:21:WU01:FS01:Downloading 7.50MiB
19:59:22:WU01:FS01:Download complete
19:59:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13428 run:1962 clone:44 gen:2 core:0x22 unit:0x0000000212bc7d9a0000000007aa002c
19:59:23:WU01:FS01:Starting
19:59:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:59:23:WU01:FS01:Started FahCore on PID 17432
19:59:23:WU01:FS01:Core PID:17484
19:59:23:WU01:FS01:FahCore 0x22 started
19:59:23:WU01:FS01:0x22:*********************** Log Started 2020-12-03T19:59:23Z ***
19:59:23:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***
19:59:23:WU01:FS01:0x22:       Core: Core22
19:59:23:WU01:FS01:0x22:       Type: 0x22
19:59:23:WU01:FS01:0x22:    Version: 0.0.13
19:59:23:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:59:23:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
19:59:23:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
19:59:23:WU01:FS01:0x22:       Date: Sep 19 2020
19:59:23:WU01:FS01:0x22:       Time: 02:35:58
19:59:23:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:59:23:WU01:FS01:0x22:     Branch: core22-0.0.13
19:59:23:WU01:FS01:0x22:   Compiler: Visual C++ 2015
19:59:23:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:59:23:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
19:59:23:WU01:FS01:0x22:   Platform: win32 10
19:59:23:WU01:FS01:0x22:       Bits: 64
19:59:23:WU01:FS01:0x22:       Mode: Release
19:59:23:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:59:23:WU01:FS01:0x22:             <peastman@stanford.edu>
19:59:23:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 17432 -checkpoint 15
19:59:23:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:59:23:WU01:FS01:0x22:************************************ libFAH ***
19:59:23:WU01:FS01:0x22:       Date: Sep 7 2020
19:59:23:WU01:FS01:0x22:       Time: 19:09:56
19:59:23:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:59:23:WU01:FS01:0x22:     Branch: HEAD
19:59:23:WU01:FS01:0x22:************************************ CBang **
19:59:23:WU01:FS01:0x22:       Time: 19:08:30
19:59:23:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:59:23:WU01:FS01:0x22:************************************ System ****
19:59:23:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
19:59:23:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:59:23:WU01:FS01:0x22:       CPUs: 8
19:59:23:WU01:FS01:0x22:     Memory: 15.95GiB
19:59:23:WU01:FS01:0x22:Free Memory: 8.41GiB
19:59:23:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:59:23:WU01:FS01:0x22: OS Version: 6.2
19:59:23:WU01:FS01:0x22:Has Battery: false
19:59:23:WU01:FS01:0x22: On Battery: false
19:59:23:WU01:FS01:0x22: UTC Offset: -6
19:59:23:WU01:FS01:0x22:        PID: 17484
19:59:23:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
19:59:23:WU01:FS01:0x22:************************************ OpenMM ***
19:59:23:WU01:FS01:0x22:   Revision: 189320d0
19:59:23:WU01:FS01:0x22:Project: 13428 (Run 1962, Clone 44, Gen 2)
19:59:23:WU01:FS01:0x22:Unit: 0x0000000212bc7d9a0000000007aa002c
19:59:23:WU01:FS01:0x22:Reading tar file core.xml
19:59:23:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
19:59:23:WU01:FS01:0x22:Reading tar file state.xml.bz2
19:59:23:WU01:FS01:0x22:Reading tar file system.xml.bz2
19:59:23:WU01:FS01:0x22:Digital signatures verified
19:59:23:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:59:23:WU01:FS01:0x22:Version 0.0.13
19:59:24:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
19:59:24:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
19:59:24:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
19:59:24:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
19:59:24:WU01:FS01:0x22:There are 3 platforms available.
19:59:24:WU01:FS01:0x22:Platform 0: Reference
19:59:24:WU01:FS01:0x22:Platform 1: CPU
19:59:24:WU01:FS01:0x22:Platform 2: OpenCL
19:59:24:WU01:FS01:0x22:  opencl-device 0 specified
19:59:49:WU01:FS01:0x22:Attempting to create OpenCL context:
19:59:49:WU01:FS01:0x22:  Configuring platform OpenCL
19:59:59:WU01:FS01:0x22:Failed to create OpenCL context:
19:59:59:WU01:FS01:0x22:Error compiling kernel: "C:\Users\User\AppData\Local\Temp\OCL17484T24.cl", line 21: warning: OpenCL
19:59:59:WU01:FS01:0x22:          extension is now part of core
19:59:59:WU01:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
19:59:59:WU01:FS01:0x22:                           ^
19:59:59:WU01:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
19:59:59:WU01:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
19:59:59:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
19:59:59:WU01:FS01:0x22:Saving result file science.log
19:59:59:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:59:59:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:59:59:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13428 run:1962 clone:44 gen:2 core:0x22 unit:0x0000000212bc7d9a0000000007aa002c
19:59:59:WU01:FS01:Uploading 2.76KiB to 18.188.125.154
19:59:59:WU01:FS01:Connecting to 18.188.125.154:8080
20:00:00:WU01:FS01:Upload complete
20:00:00:WU01:FS01:Server responded WORK_ACK (400)
20:00:00:WU01:FS01:Cleaning up
20:00:00:WU02:FS01:Connecting to assign1.foldingathome.org:80
20:00:00:WU02:FS01:Assigned to work server 18.188.125.154
20:00:00:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 18.188.125.154
20:00:00:WU02:FS01:Connecting to 18.188.125.154:8080
20:00:02:WU02:FS01:Downloading 7.52MiB
20:00:03:WU02:FS01:Download complete
20:00:03:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13428 run:2698 clone:43 gen:1 core:0x22 unit:0x0000000112bc7d9a000000000a8a002b
20:00:03:WU02:FS01:Starting
20:00:03:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:00:03:WU02:FS01:Started FahCore on PID 15012
20:00:03:WU02:FS01:Core PID:8320
20:00:03:WU02:FS01:FahCore 0x22 started
20:00:04:WU02:FS01:0x22:*********************** Log Started 2020-12-03T20:00:04Z ***********************
20:00:04:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:00:04:WU02:FS01:0x22:       Core: Core22
20:00:04:WU02:FS01:0x22:       Type: 0x22
20:00:04:WU02:FS01:0x22:    Version: 0.0.13
20:00:04:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:00:04:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
20:00:04:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
20:00:04:WU02:FS01:0x22:       Date: Sep 19 2020
20:00:04:WU02:FS01:0x22:       Time: 02:35:58
20:00:04:WU02:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:00:04:WU02:FS01:0x22:     Branch: core22-0.0.13
20:00:04:WU02:FS01:0x22:   Compiler: Visual C++ 2015
20:00:04:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:00:04:WU02:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
20:00:04:WU02:FS01:0x22:   Platform: win32 10
20:00:04:WU02:FS01:0x22:       Bits: 64
20:00:04:WU02:FS01:0x22:       Mode: Release
20:00:04:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:00:04:WU02:FS01:0x22:             <peastman@stanford.edu>
20:00:04:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 15012 -checkpoint 15
20:00:04:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:00:04:WU02:FS01:0x22:************************************ libFAH ************************************
20:00:04:WU02:FS01:0x22:       Date: Sep 7 2020
20:00:04:WU02:FS01:0x22:       Time: 19:09:56
20:00:04:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:00:04:WU02:FS01:0x22:     Branch: HEAD
20:00:04:WU02:FS01:0x22:************************************ CBang *************************************
20:00:04:WU02:FS01:0x22:       Time: 19:08:30
20:00:04:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:00:04:WU02:FS01:0x22:************************************ System ************************************
20:00:04:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
20:00:04:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:00:04:WU02:FS01:0x22:       CPUs: 8
20:00:04:WU02:FS01:0x22:     Memory: 15.95GiB
20:00:04:WU02:FS01:0x22:Free Memory: 8.43GiB
20:00:04:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
20:00:04:WU02:FS01:0x22: OS Version: 6.2
20:00:04:WU02:FS01:0x22:Has Battery: false
20:00:04:WU02:FS01:0x22: On Battery: false
20:00:04:WU02:FS01:0x22: UTC Offset: -6
20:00:04:WU02:FS01:0x22:        PID: 8320
20:00:04:WU02:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
20:00:04:WU02:FS01:0x22:************************************ OpenMM ************************************
20:00:04:WU02:FS01:0x22:   Revision: 189320d0
20:00:04:WU02:FS01:0x22:********************************************************************************
20:00:04:WU02:FS01:0x22:Project: 13428 (Run 2698, Clone 43, Gen 1)
20:00:04:WU02:FS01:0x22:Unit: 0x0000000112bc7d9a000000000a8a002b
20:00:04:WU02:FS01:0x22:Reading tar file core.xml
20:00:04:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
20:00:04:WU02:FS01:0x22:Reading tar file state.xml.bz2
20:00:04:WU02:FS01:0x22:Reading tar file system.xml.bz2
20:00:04:WU02:FS01:0x22:Digital signatures verified
20:00:04:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:00:04:WU02:FS01:0x22:Version 0.0.13
20:00:05:WU02:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
20:00:05:WU02:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
20:00:05:WU02:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
20:00:05:WU02:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
20:00:05:WU02:FS01:0x22:There are 3 platforms available.
20:00:05:WU02:FS01:0x22:Platform 0: Reference
20:00:05:WU02:FS01:0x22:Platform 1: CPU
20:00:05:WU02:FS01:0x22:Platform 2: OpenCL
20:00:05:WU02:FS01:0x22:  opencl-device 0 specified
20:00:28:WU02:FS01:0x22:Attempting to create OpenCL context:
20:00:28:WU02:FS01:0x22:  Configuring platform OpenCL
20:00:40:WU02:FS01:0x22:Failed to create OpenCL context:
20:00:40:WU02:FS01:0x22:Error compiling kernel: "C:\Users\User\AppData\Local\Temp\OCL8320T24.cl", line 21: warning: OpenCL
20:00:40:WU02:FS01:0x22:          extension is now part of core
20:00:40:WU02:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
20:00:40:WU02:FS01:0x22:                           ^
20:00:40:WU02:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
20:00:40:WU02:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
20:00:40:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:00:40:WU02:FS01:0x22:Saving result file science.log
20:00:40:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:00:41:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:00:41:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13428 run:2698 clone:43 gen:1 core:0x22 unit:0x0000000112bc7d9a000000000a8a002b
20:00:41:WU02:FS01:Uploading 2.76KiB to 18.188.125.154
20:00:41:WU02:FS01:Connecting to 18.188.125.154:8080
20:00:41:WU02:FS01:Upload complete
20:00:41:WU02:FS01:Server responded WORK_ACK (400)
20:00:41:WU02:FS01:Cleaning up
20:00:41:WU01:FS01:Connecting to assign1.foldingathome.org:80
20:00:42:WU01:FS01:Assigned to work server 18.188.125.154
20:00:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 18.188.125.154
20:00:42:WU01:FS01:Connecting to 18.188.125.154:8080
20:00:43:WU01:FS01:Downloading 6.75MiB
20:00:44:WU01:FS01:Download complete
20:00:45:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13428 run:1699 clone:40 gen:1 core:0x22 unit:0x0000000112bc7d9a0000000006a30028
20:00:45:WU01:FS01:Starting
20:00:45:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:00:45:WU01:FS01:Started FahCore on PID 20132
20:00:45:WU01:FS01:Core PID:15708
20:00:45:WU01:FS01:FahCore 0x22 started
20:00:45:WU01:FS01:0x22:*********************** Log Started 2020-12-03T20:00:45Z ***********************
20:00:45:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:00:45:WU01:FS01:0x22:       Core: Core22
20:00:45:WU01:FS01:0x22:       Type: 0x22
20:00:45:WU01:FS01:0x22:    Version: 0.0.13
20:00:45:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:00:45:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
20:00:45:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
20:00:45:WU01:FS01:0x22:       Date: Sep 19 2020
20:00:45:WU01:FS01:0x22:       Time: 02:35:58
20:00:45:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:00:45:WU01:FS01:0x22:     Branch: core22-0.0.13
20:00:45:WU01:FS01:0x22:   Compiler: Visual C++ 2015
20:00:45:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:00:45:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
20:00:45:WU01:FS01:0x22:   Platform: win32 10
20:00:45:WU01:FS01:0x22:       Bits: 64
20:00:45:WU01:FS01:0x22:       Mode: Release
20:00:45:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:00:45:WU01:FS01:0x22:             <peastman@stanford.edu>
20:00:45:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 20132 -checkpoint 15
20:00:45:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:00:45:WU01:FS01:0x22:************************************ libFAH ************************************
20:00:45:WU01:FS01:0x22:       Date: Sep 7 2020
20:00:45:WU01:FS01:0x22:       Time: 19:09:56
20:00:45:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:00:45:WU01:FS01:0x22:     Branch: HEAD
20:00:45:WU01:FS01:0x22:************************************ CBang *************************************
20:00:45:WU01:FS01:0x22:       Time: 19:08:30
20:00:45:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:00:45:WU01:FS01:0x22:************************************ System ************************************
20:00:45:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
20:00:45:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:00:45:WU01:FS01:0x22:       CPUs: 8
20:00:45:WU01:FS01:0x22:     Memory: 15.95GiB
20:00:45:WU01:FS01:0x22:Free Memory: 8.42GiB
20:00:45:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
20:00:45:WU01:FS01:0x22: OS Version: 6.2
20:00:45:WU01:FS01:0x22:Has Battery: false
20:00:45:WU01:FS01:0x22: On Battery: false
20:00:45:WU01:FS01:0x22: UTC Offset: -6
20:00:45:WU01:FS01:0x22:        PID: 15708
20:00:45:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
20:00:45:WU01:FS01:0x22:************************************ OpenMM ************************************
20:00:45:WU01:FS01:0x22:   Revision: 189320d0
20:00:45:WU01:FS01:0x22:********************************************************************************
20:00:45:WU01:FS01:0x22:Project: 13428 (Run 1699, Clone 40, Gen 1)
20:00:45:WU01:FS01:0x22:Unit: 0x0000000112bc7d9a0000000006a30028
20:00:45:WU01:FS01:0x22:Reading tar file core.xml
20:00:45:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
20:00:45:WU01:FS01:0x22:Reading tar file state.xml.bz2
20:00:45:WU01:FS01:0x22:Reading tar file system.xml.bz2
20:00:45:WU01:FS01:0x22:Digital signatures verified
20:00:45:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:00:45:WU01:FS01:0x22:Version 0.0.13
20:00:46:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
20:00:46:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
20:00:46:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
20:00:46:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
20:00:46:WU01:FS01:0x22:There are 3 platforms available.
20:00:46:WU01:FS01:0x22:Platform 0: Reference
20:00:46:WU01:FS01:0x22:Platform 1: CPU
20:00:46:WU01:FS01:0x22:Platform 2: OpenCL
20:00:46:WU01:FS01:0x22:  opencl-device 0 specified
20:01:18:WU01:FS01:0x22:Attempting to create OpenCL context:
20:01:18:WU01:FS01:0x22:  Configuring platform OpenCL
20:01:36:WU01:FS01:0x22:Failed to create OpenCL context:
20:01:36:WU01:FS01:0x22:Error compiling kernel: "C:\Users\User\AppData\Local\Temp\OCL15708T24.cl", line 21: warning: OpenCL
20:01:36:WU01:FS01:0x22:          extension is now part of core
20:01:36:WU01:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
20:01:36:WU01:FS01:0x22:                           ^
20:01:36:WU01:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
20:01:36:WU01:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
20:01:36:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
20:01:36:WU01:FS01:0x22:Saving result file science.log
20:01:36:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:01:37:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:01:37:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13428 run:1699 clone:40 gen:1 core:0x22 unit:0x0000000112bc7d9a0000000006a30028
20:01:37:WU01:FS01:Uploading 2.76KiB to 18.188.125.154
20:01:37:WU01:FS01:Connecting to 18.188.125.154:8080
20:01:37:WU01:FS01:Upload complete
20:01:37:WU01:FS01:Server responded WORK_ACK (400)
20:01:37:WU01:FS01:Cleaning up
20:01:37:WU02:FS01:Connecting to assign1.foldingathome.org:80
20:01:37:WU02:FS01:Assigned to work server 18.188.125.154
20:01:37:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 18.188.125.154
20:01:37:WU02:FS01:Connecting to 18.188.125.154:8080
20:01:39:WU02:FS01:Downloading 7.50MiB
20:01:40:WU02:FS01:Download complete
20:01:40:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13428 run:2107 clone:49 gen:2 core:0x22 unit:0x0000000212bc7d9a00000000083b0031
20:01:40:WU02:FS01:Starting
20:01:40:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:01:40:WU02:FS01:Started FahCore on PID 660
20:01:40:WU02:FS01:Core PID:21404
20:01:40:WU02:FS01:FahCore 0x22 started
20:01:41:WU02:FS01:0x22:*********************** Log Started 2020-12-03T20:01:40Z ***********************
20:01:41:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:01:41:WU02:FS01:0x22:       Core: Core22
20:01:41:WU02:FS01:0x22:       Type: 0x22
20:01:41:WU02:FS01:0x22:    Version: 0.0.13
20:01:41:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:01:41:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
20:01:41:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
20:01:41:WU02:FS01:0x22:       Date: Sep 19 2020
20:01:41:WU02:FS01:0x22:       Time: 02:35:58
20:01:41:WU02:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:01:41:WU02:FS01:0x22:     Branch: core22-0.0.13
20:01:41:WU02:FS01:0x22:   Compiler: Visual C++ 2015
20:01:41:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:01:41:WU02:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
20:01:41:WU02:FS01:0x22:   Platform: win32 10
20:01:41:WU02:FS01:0x22:       Bits: 64
20:01:41:WU02:FS01:0x22:       Mode: Release
20:01:41:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:01:41:WU02:FS01:0x22:             <peastman@stanford.edu>
20:01:41:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 660 -checkpoint 15
20:01:41:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:01:41:WU02:FS01:0x22:************************************ libFAH ************************************
20:01:41:WU02:FS01:0x22:       Date: Sep 7 2020
20:01:41:WU02:FS01:0x22:       Time: 19:09:56
20:01:41:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:01:41:WU02:FS01:0x22:     Branch: HEAD
20:01:41:WU02:FS01:0x22:************************************ CBang *************************************
20:01:41:WU02:FS01:0x22:       Time: 19:08:30
20:01:41:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:01:41:WU02:FS01:0x22:************************************ System ************************************
20:01:41:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
20:01:41:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:01:41:WU02:FS01:0x22:       CPUs: 8
20:01:41:WU02:FS01:0x22:     Memory: 15.95GiB
20:01:41:WU02:FS01:0x22:Free Memory: 8.48GiB
20:01:41:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
20:01:41:WU02:FS01:0x22: OS Version: 6.2
20:01:41:WU02:FS01:0x22:Has Battery: false
20:01:41:WU02:FS01:0x22: On Battery: false
20:01:41:WU02:FS01:0x22: UTC Offset: -6
20:01:41:WU02:FS01:0x22:        PID: 21404
20:01:41:WU02:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
20:01:41:WU02:FS01:0x22:************************************ OpenMM ************************************
20:01:41:WU02:FS01:0x22:   Revision: 189320d0
20:01:41:WU02:FS01:0x22:********************************************************************************
20:01:41:WU02:FS01:0x22:Project: 13428 (Run 2107, Clone 49, Gen 2)
20:01:41:WU02:FS01:0x22:Unit: 0x0000000212bc7d9a00000000083b0031
20:01:41:WU02:FS01:0x22:Reading tar file core.xml
20:01:41:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
20:01:41:WU02:FS01:0x22:Reading tar file state.xml.bz2
20:01:41:WU02:FS01:0x22:Reading tar file system.xml.bz2
20:01:41:WU02:FS01:0x22:Digital signatures verified
20:01:41:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:01:41:WU02:FS01:0x22:Version 0.0.13
20:01:42:WU02:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
20:01:42:WU02:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
20:01:42:WU02:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
20:01:42:WU02:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
20:01:42:WU02:FS01:0x22:There are 3 platforms available.
20:01:42:WU02:FS01:0x22:Platform 0: Reference
20:01:42:WU02:FS01:0x22:Platform 1: CPU
20:01:42:WU02:FS01:0x22:Platform 2: OpenCL
20:01:42:WU02:FS01:0x22:  opencl-device 0 specified
20:02:11:WU02:FS01:0x22:Attempting to create OpenCL context:
20:02:11:WU02:FS01:0x22:  Configuring platform OpenCL
20:02:20:WU02:FS01:0x22:Failed to create OpenCL context:
20:02:20:WU02:FS01:0x22:Error compiling kernel: "C:\Users\User\AppData\Local\Temp\OCL21404T24.cl", line 21: warning: OpenCL
20:02:20:WU02:FS01:0x22:          extension is now part of core
20:02:20:WU02:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
20:02:20:WU02:FS01:0x22:                           ^
20:02:20:WU02:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
20:02:20:WU02:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
20:02:20:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:02:20:WU02:FS01:0x22:Saving result file science.log
20:02:20:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:02:21:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:02:21:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13428 run:2107 clone:49 gen:2 core:0x22 unit:0x0000000212bc7d9a00000000083b0031
20:02:21:WU02:FS01:Uploading 2.76KiB to 18.188.125.154
20:02:21:WU02:FS01:Connecting to 18.188.125.154:8080
20:02:21:WU01:FS01:Connecting to assign1.foldingathome.org:80
20:02:21:WU02:FS01:Upload complete
20:02:21:WU02:FS01:Server responded WORK_ACK (400)
20:02:21:WU02:FS01:Cleaning up
20:02:22:WU01:FS01:Assigned to work server 18.188.125.154
20:02:22:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 18.188.125.154
20:02:22:WU01:FS01:Connecting to 18.188.125.154:8080
20:02:23:WU01:FS01:Downloading 7.49MiB
20:02:24:WU01:FS01:Download complete
20:02:25:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13428 run:2012 clone:46 gen:2 core:0x22 unit:0x0000000412bc7d9a0000000007dc002e
20:02:25:WU01:FS01:Starting
20:02:25:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:02:25:WU01:FS01:Started FahCore on PID 3580
20:02:25:WU01:FS01:Core PID:4136
20:02:25:WU01:FS01:FahCore 0x22 started
20:02:25:WU01:FS01:0x22:*********************** Log Started 2020-12-03T20:02:25Z ***********************
20:02:25:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:02:25:WU01:FS01:0x22:       Core: Core22
20:02:25:WU01:FS01:0x22:       Type: 0x22
20:02:25:WU01:FS01:0x22:    Version: 0.0.13
20:02:25:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:02:25:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
20:02:25:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
20:02:25:WU01:FS01:0x22:       Date: Sep 19 2020
20:02:25:WU01:FS01:0x22:       Time: 02:35:58
20:02:25:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:02:25:WU01:FS01:0x22:     Branch: core22-0.0.13
20:02:25:WU01:FS01:0x22:   Compiler: Visual C++ 2015
20:02:25:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:02:25:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
20:02:25:WU01:FS01:0x22:   Platform: win32 10
20:02:25:WU01:FS01:0x22:       Bits: 64
20:02:25:WU01:FS01:0x22:       Mode: Release
20:02:25:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:02:25:WU01:FS01:0x22:             <peastman@stanford.edu>
20:02:25:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3580 -checkpoint 15
20:02:25:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:02:25:WU01:FS01:0x22:************************************ libFAH ************************************
20:02:25:WU01:FS01:0x22:       Date: Sep 7 2020
20:02:25:WU01:FS01:0x22:       Time: 19:09:56
20:02:25:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:02:25:WU01:FS01:0x22:     Branch: HEAD
20:02:25:WU01:FS01:0x22:************************************ CBang *************************************
20:02:25:WU01:FS01:0x22:       Time: 19:08:30
20:02:25:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:02:25:WU01:FS01:0x22:************************************ System ************************************
20:02:25:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
20:02:25:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:02:25:WU01:FS01:0x22:       CPUs: 8
20:02:25:WU01:FS01:0x22:     Memory: 15.95GiB
20:02:25:WU01:FS01:0x22:Free Memory: 8.63GiB
20:02:25:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
20:02:25:WU01:FS01:0x22: OS Version: 6.2
20:02:25:WU01:FS01:0x22:Has Battery: false
20:02:25:WU01:FS01:0x22: On Battery: false
20:02:25:WU01:FS01:0x22: UTC Offset: -6
20:02:25:WU01:FS01:0x22:        PID: 4136
20:02:25:WU01:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
20:02:25:WU01:FS01:0x22:************************************ OpenMM ************************************
20:02:25:WU01:FS01:0x22:   Revision: 189320d0
20:02:25:WU01:FS01:0x22:********************************************************************************
20:02:25:WU01:FS01:0x22:Project: 13428 (Run 2012, Clone 46, Gen 2)
20:02:25:WU01:FS01:0x22:Unit: 0x0000000412bc7d9a0000000007dc002e
20:02:25:WU01:FS01:0x22:Reading tar file core.xml
20:02:25:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
20:02:25:WU01:FS01:0x22:Reading tar file state.xml.bz2
20:02:25:WU01:FS01:0x22:Reading tar file system.xml.bz2
20:02:25:WU01:FS01:0x22:Digital signatures verified
20:02:25:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:02:25:WU01:FS01:0x22:Version 0.0.13
20:02:26:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
20:02:26:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
20:02:26:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
20:02:26:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
20:02:26:WU01:FS01:0x22:There are 3 platforms available.
20:02:26:WU01:FS01:0x22:Platform 0: Reference
20:02:26:WU01:FS01:0x22:Platform 1: CPU
20:02:26:WU01:FS01:0x22:Platform 2: OpenCL
20:02:26:WU01:FS01:0x22:  opencl-device 0 specified
20:02:48:WU01:FS01:0x22:Attempting to create OpenCL context:
20:02:48:WU01:FS01:0x22:  Configuring platform OpenCL
20:03:00:WU01:FS01:0x22:Failed to create OpenCL context:
20:03:00:WU01:FS01:0x22:Error compiling kernel: "C:\Users\User\AppData\Local\Temp\OCL4136T24.cl", line 21: warning: OpenCL
20:03:00:WU01:FS01:0x22:          extension is now part of core
20:03:00:WU01:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
20:03:00:WU01:FS01:0x22:                           ^
20:03:00:WU01:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
20:03:00:WU01:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
20:03:00:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
20:03:00:WU01:FS01:0x22:Saving result file science.log
20:03:00:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:03:01:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:03:01:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13428 run:2012 clone:46 gen:2 core:0x22 unit:0x0000000412bc7d9a0000000007dc002e
20:03:01:WU01:FS01:Uploading 2.76KiB to 18.188.125.154
20:03:01:WU01:FS01:Connecting to 18.188.125.154:8080
20:03:01:WU02:FS01:Connecting to assign1.foldingathome.org:80
20:03:01:WU01:FS01:Upload complete
20:03:01:WU01:FS01:Server responded WORK_ACK (400)
20:03:01:WU01:FS01:Cleaning up
20:03:01:WU02:FS01:Assigned to work server 18.188.125.154
20:03:01:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 18.188.125.154
20:03:01:WU02:FS01:Connecting to 18.188.125.154:8080
20:03:03:WU02:FS01:Downloading 6.72MiB
20:03:04:WU02:FS01:Download complete
20:03:04:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13428 run:2876 clone:41 gen:0 core:0x22 unit:0x0000000012bc7d9a000000000b3c0029
20:03:04:WU02:FS01:Starting
20:03:04:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:03:04:WU02:FS01:Started FahCore on PID 17596
20:03:04:WU02:FS01:Core PID:14016
20:03:04:WU02:FS01:FahCore 0x22 started
20:03:05:WU02:FS01:0x22:*********************** Log Started 2020-12-03T20:03:04Z ***********************
20:03:05:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:03:05:WU02:FS01:0x22:       Core: Core22
20:03:05:WU02:FS01:0x22:       Type: 0x22
20:03:05:WU02:FS01:0x22:    Version: 0.0.13
20:03:05:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:03:05:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
20:03:05:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
20:03:05:WU02:FS01:0x22:       Date: Sep 19 2020
20:03:05:WU02:FS01:0x22:       Time: 02:35:58
20:03:05:WU02:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:03:05:WU02:FS01:0x22:     Branch: core22-0.0.13
20:03:05:WU02:FS01:0x22:   Compiler: Visual C++ 2015
20:03:05:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:03:05:WU02:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
20:03:05:WU02:FS01:0x22:   Platform: win32 10
20:03:05:WU02:FS01:0x22:       Bits: 64
20:03:05:WU02:FS01:0x22:       Mode: Release
20:03:05:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:03:05:WU02:FS01:0x22:             <peastman@stanford.edu>
20:03:05:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 17596 -checkpoint 15
20:03:05:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:03:05:WU02:FS01:0x22:************************************ libFAH ************************************
20:03:05:WU02:FS01:0x22:       Date: Sep 7 2020
20:03:05:WU02:FS01:0x22:       Time: 19:09:56
20:03:05:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:03:05:WU02:FS01:0x22:     Branch: HEAD
20:03:05:WU02:FS01:0x22:************************************ CBang *************************************
20:03:05:WU02:FS01:0x22:       Time: 19:08:30
20:03:05:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:03:05:WU02:FS01:0x22:************************************ System ************************************
20:03:05:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
20:03:05:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:03:05:WU02:FS01:0x22:       CPUs: 8
20:03:05:WU02:FS01:0x22:     Memory: 15.95GiB
20:03:05:WU02:FS01:0x22:Free Memory: 8.63GiB
20:03:05:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
20:03:05:WU02:FS01:0x22: OS Version: 6.2
20:03:05:WU02:FS01:0x22:Has Battery: false
20:03:05:WU02:FS01:0x22: On Battery: false
20:03:05:WU02:FS01:0x22: UTC Offset: -6
20:03:05:WU02:FS01:0x22:        PID: 14016
20:03:05:WU02:FS01:0x22:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
20:03:05:WU02:FS01:0x22:************************************ OpenMM ************************************
20:03:05:WU02:FS01:0x22:   Revision: 189320d0
20:03:05:WU02:FS01:0x22:********************************************************************************
20:03:05:WU02:FS01:0x22:Project: 13428 (Run 2876, Clone 41, Gen 0)
20:03:05:WU02:FS01:0x22:Unit: 0x0000000012bc7d9a000000000b3c0029
20:03:05:WU02:FS01:0x22:Reading tar file core.xml
20:03:05:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
20:03:05:WU02:FS01:0x22:Reading tar file state.xml.bz2
20:03:05:WU02:FS01:0x22:Reading tar file system.xml.bz2
20:03:05:WU02:FS01:0x22:Digital signatures verified
20:03:05:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:03:05:WU02:FS01:0x22:Version 0.0.13
20:03:07:WU02:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
20:03:07:WU02:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
20:03:07:WU02:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
20:03:07:WU02:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
20:03:07:WU02:FS01:0x22:There are 3 platforms available.
20:03:07:WU02:FS01:0x22:Platform 0: Reference
20:03:07:WU02:FS01:0x22:Platform 1: CPU
20:03:07:WU02:FS01:0x22:Platform 2: OpenCL
20:03:07:WU02:FS01:0x22:  opencl-device 0 specified
20:03:36:WU02:FS01:0x22:Attempting to create OpenCL context:
20:03:36:WU02:FS01:0x22:  Configuring platform OpenCL
20:03:50:WU02:FS01:0x22:Failed to create OpenCL context:
20:03:50:WU02:FS01:0x22:Error compiling kernel: "C:\Users\User\AppData\Local\Temp\OCL14016T24.cl", line 21: warning: OpenCL
20:03:50:WU02:FS01:0x22:          extension is now part of core
20:03:50:WU02:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
20:03:50:WU02:FS01:0x22:                           ^
20:03:50:WU02:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
20:03:50:WU02:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
20:03:50:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:03:50:WU02:FS01:0x22:Saving result file science.log
20:03:50:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:03:50:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:03:50:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13428 run:2876 clone:41 gen:0 core:0x22 unit:0x0000000012bc7d9a000000000b3c0029
20:03:50:WU02:FS01:Uploading 2.76KiB to 18.188.125.154
20:03:50:WU02:FS01:Connecting to 18.188.125.154:8080
20:03:51:WU02:FS01:Upload complete
20:03:51:WU02:FS01:Server responded WORK_ACK (400)
20:03:51:WU02:FS01:Cleaning up
20:08:21:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
Re: GPU Failing after several retries
Has Windows recently updated your video drivers? The ones provided by MS through Windows Update are incomplete and do not include OpenCL support.
jcnwilson
Post by jcnwilson »
I'll have to check tomorrow. I did a clean install of the drivers from AMD's website in my troubleshooting steps, so I wouldn't think it would be a driver issue.
jcnwilson
Post by jcnwilson »
The issue seems to have resolved itself. I told the GPU to fold, and after failing once, it got a WU from a different server and has been folding for a while now. Looking through the log, it appears that the same work server (18.188.125.154) sent out all the WU's that failed yesterday, and if that was the problem all along. Either way, this issue is resolved.
