I have f@h on my laptop aswell as on my gaming rig, first it stopped folding on my laptop (allways yellow) and doesn´t start again (tried F5, restarting browser and Laptop), now the same happend with my gaming rigs gpu, just shows yellow and nothing happens anymore (CPU still funtional and folding...)
How to start folding again?
restart folding?
Re: restart folding?
Welcome to Folding@Home!
The easiest way to get accurate help is to post the first 200 lines of the log where it shows your configuration.
viewtopic.php?f=24&t=26036
If you want 'blind' help, I would uninstall F@H including data, and reinstall it. (Sometimes Install does a better job of detecting your hardware)
My gaming rigs log:
Edit: NVM PC finally started folding again after a couple restarts, Laptop still doesn´t.
*********************** Log Started 2020-12-02T13:15:04Z ***********************
13:15:04:******************************* libFAH ********************************
13:15:04: Date: Oct 20 2020
13:15:04: Time: 13:36:55
13:15:04: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
13:15:04: Branch: master
13:15:04: Compiler: Visual C++ 2015
13:15:04: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:15:04: Platform: win32 10
13:15:04: Bits: 32
13:15:04: Mode: Release
13:15:04:****************************** FAHClient ******************************
13:15:04: Version: 7.6.21
13:15:04: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:15:04: Copyright: 2020 foldingathome.org
13:15:04: Homepage: https://foldingathome.org/
13:15:04: Time: 13:41:04
13:15:04: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
13:15:04: Bits: 32
13:15:04: Config: C:\ProgramData\FAHClient\config.xml
13:15:04:******************************** CBang ********************************
13:15:04: Time: 11:36:18
13:15:04: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
13:15:04: Bits: 32
13:15:04:******************************* System ********************************
13:15:04: CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
13:15:04: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
13:15:04: CPUs: 8
13:15:04: Memory: 15.94GiB
13:15:04: Free Memory: 13.63GiB
13:15:04: Threads: WINDOWS_THREADS
13:15:04: OS Version: 6.2
13:15:04: Has Battery: false
13:15:04: On Battery: false
13:15:04: UTC Offset: 1
13:15:04: PID: 9436
13:15:04: CWD: C:\ProgramData\FAHClient
13:15:04: Win32 Service: false
13:15:04: OS: Windows 10 Enterprise
13:15:04: OS Arch: AMD64
13:15:04: GPUs: 1
13:15:04: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
13:15:04: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.1
13:15:04:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:457.30
13:15:04:***********************************************************************
13:15:05:<config>
13:15:05: <!-- Slot Control -->
13:15:05: <power v='FULL'/>
13:15:05:
13:15:05: <!-- User Information -->
13:15:05: <passkey v='*****'/>
13:15:05: <team v='268147'/>
13:15:05: <user v='Berliner_Mediziner_Hobbit'/>
13:15:05:
13:15:05: <!-- Folding Slots -->
13:15:05: <slot id='0' type='CPU'/>
13:15:05: <slot id='1' type='GPU'>
13:15:05: <pci-bus v='1'/>
13:15:05: <pci-slot v='0'/>
13:15:05: </slot>
13:15:05:</config>
13:15:05:Trying to access database...
13:15:05:Successfully acquired database lock
13:15:05:FS00:Initialized folding slot 00: cpu:7
13:15:05:FS01:Initialized folding slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372
13:15:05:WU01:FS00:Starting
13:15:05:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 9436 -checkpoint 15 -np 7
13:15:05:WU01:FS00:Started FahCore on PID 9736
13:15:05:WU01:FS00:Core PID:9764
13:15:05:WU01:FS00:FahCore 0xa8 started
13:15:05:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:15:05:WU01:FS00:0xa8:*********************** Log Started 2020-12-02T13:15:05Z ***********************
13:15:05:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
13:15:05:WU01:FS00:0xa8: Core: Gromacs
13:15:05:WU01:FS00:0xa8: Type: 0xa8
13:15:05:WU01:FS00:0xa8: Version: 0.0.9
13:15:05:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:15:05:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
13:15:05:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
13:15:05:WU01:FS00:0xa8: Date: Oct 28 2020
13:15:05:WU01:FS00:0xa8: Time: 16:17:37
13:15:05:WU01:FS00:0xa8: Revision: 15f9b5e1edd6089f1a45553d2709a6aba62f735c
13:15:05:WU01:FS00:0xa8: Branch: master
13:15:05:WU01:FS00:0xa8: Compiler: Visual C++ 2019 16.7
13:15:05:WU01:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:15:05:WU01:FS00:0xa8: Platform: win32 10
13:15:05:WU01:FS00:0xa8: Bits: 64
13:15:05:WU01:FS00:0xa8: Mode: Release
13:15:05:WU01:FS00:0xa8: SIMD: avx2_256
13:15:05:WU01:FS00:0xa8: OpenMP: ON
13:15:05:WU01:FS00:0xa8: CUDA: OFF
13:15:05:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 9736 -checkpoint 15 -np 7
13:15:05:WU01:FS00:0xa8:************************************ libFAH ************************************
13:15:05:WU01:FS00:0xa8: Time: 15:11:42
13:15:05:WU01:FS00:0xa8:************************************ CBang *************************************
13:15:05:WU01:FS00:0xa8: Time: 15:11:22
13:15:05:WU01:FS00:0xa8:************************************ System ************************************
13:15:05:WU01:FS00:0xa8: CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
13:15:05:WU01:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
13:15:05:WU01:FS00:0xa8: CPUs: 8
13:15:05:WU01:FS00:0xa8: Memory: 15.94GiB
13:15:05:WU01:FS00:0xa8:Free Memory: 13.66GiB
13:15:05:WU01:FS00:0xa8: Threads: WINDOWS_THREADS
13:15:05:WU01:FS00:0xa8: OS Version: 6.2
13:15:05:WU01:FS00:0xa8:Has Battery: false
13:15:05:WU01:FS00:0xa8: On Battery: false
13:15:05:WU01:FS00:0xa8: UTC Offset: 1
13:15:05:WU01:FS00:0xa8: PID: 9764
13:15:05:WU01:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
13:15:05:WU01:FS00:0xa8:********************************************************************************
13:15:05:WU01:FS00:0xa8:Project: 16812 (Run 0, Clone 1020, Gen 37)
13:15:05:WU01:FS00:0xa8:Unit: 0x0000002bb2aec48a5f8ddfb618a8b916
13:15:05:WU01:FS00:0xa8:Digital signatures verified
13:15:05:WU01:FS00:0xa8:Calling: mdrun -c frame37.gro -s frame37.tpr -x frame37.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
13:15:05:WU01:FS00:0xa8:Steps: first=18500000 total=19000000
13:15:07:WU01:FS00:0xa8:Completed 243201 out of 500000 steps (48%)
13:15:08:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:15:08:WU00:FS01:Connecting to assign2.foldingathome.org:80
13:15:10:WU00:FS01:Assigned to work server 129.213.157.105
13:15:10:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
13:15:10:WU00:FS01:Connecting to 129.213.157.105:8080
13:15:31:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:15:31:WU00:FS01:Connecting to 129.213.157.105:80
13:15:52:ERROR:WU00:FS01:Exception: Failed to connect to 129.213.157.105:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
13:15:52:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:15:53:WU00:FS01:Assigned to work server 128.252.203.9
13:15:53:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 128.252.203.9
13:15:53:WU00:FS01:Connecting to 128.252.203.9:8080
13:15:53:ERROR:WU00:FS01:Exception: Server did not assign work unit
13:15:57:WU01:FS00:0xa8:Completed 245000 out of 500000 steps (49%)
13:16:52:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:16:53:WU00:FS01:Assigned to work server 129.213.157.105
13:16:53:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
13:16:53:WU00:FS01:Connecting to 129.213.157.105:8080
13:17:14:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:17:14:WU00:FS01:Connecting to 129.213.157.105:80
13:17:47:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:18:13:WU01:FS00:0xa8:Completed 250000 out of 500000 steps (50%)
13:18:29:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:18:31:WU00:FS01:Assigned to work server 129.213.157.105
13:18:31:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
13:18:31:WU00:FS01:Connecting to 129.213.157.105:8080
13:18:52:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:18:52:WU00:FS01:Connecting to 129.213.157.105:80
13:19:13:ERROR:WU00:FS01:Exception: Failed to connect to 129.213.157.105:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
13:20:30:WU01:FS00:0xa8:Completed 255000 out of 500000 steps (51%)
13:21:06:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:21:07:WU00:FS01:Assigned to work server 129.213.157.105
13:21:08:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
13:21:08:WU00:FS01:Connecting to 129.213.157.105:8080
13:21:53:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:22:48:WU01:FS00:0xa8:Completed 260000 out of 500000 steps (52%)
13:25:06:WU01:FS00:0xa8:Completed 265000 out of 500000 steps (53%)
13:25:21:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:25:21:WU00:FS01:Assigned to work server 129.213.157.105
13:25:22:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
13:25:22:WU00:FS01:Connecting to 129.213.157.105:8080
13:25:38:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:27:23:WU01:FS00:0xa8:Completed 270000 out of 500000 steps (54%)
13:29:38:WU01:FS00:0xa8:Completed 275000 out of 500000 steps (55%)
13:31:54:WU01:FS00:0xa8:Completed 280000 out of 500000 steps (56%)
13:32:12:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:32:13:WU00:FS01:Assigned to work server 129.213.157.105
13:32:14:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
13:32:14:WU00:FS01:Connecting to 129.213.157.105:8080
13:32:35:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:32:35:WU00:FS01:Connecting to 129.213.157.105:80
13:32:57:ERROR:WU00:FS01:Exception: Failed to connect to 129.213.157.105:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
13:34:10:WU01:FS00:0xa8:Completed 285000 out of 500000 steps (57%)
13:36:39:WU01:FS00:0xa8:Completed 290000 out of 500000 steps (58%)
13:38:59:WU01:FS00:0xa8:Completed 295000 out of 500000 steps (59%)
13:41:15:WU01:FS00:0xa8:Completed 300000 out of 500000 steps (60%)
13:43:18:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:43:18:WU00:FS01:Assigned to work server 129.213.157.105
13:43:19:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
13:43:19:WU00:FS01:Connecting to 129.213.157.105:8080
13:43:29:WU01:FS00:0xa8:Completed 305000 out of 500000 steps (61%)
13:43:51:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
13:45:46:WU01:FS00:0xa8:Completed 310000 out of 500000 steps (62%)
13:48:02:WU01:FS00:0xa8:Completed 315000 out of 500000 steps (63%)
13:50:19:WU01:FS00:0xa8:Completed 320000 out of 500000 steps (64%)
13:52:35:WU01:FS00:0xa8:Completed 325000 out of 500000 steps (65%)
13:54:58:WU01:FS00:0xa8:Completed 330000 out of 500000 steps (66%)
13:57:25:WU01:FS00:0xa8:Completed 335000 out of 500000 steps (67%)
13:58:31:16:127.0.0.1:New Web session
13:58:43:FS00:Paused
13:58:43:FS01:Paused
13:58:43:FS00:Shutting core down
13:58:43:WU01:FS00:0xa8:WARNING:Console control signal 1 on PID 9764
13:58:43:WU01:FS00:0xa8:Exiting, please wait. . .
13:58:44:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:58:46:FS00:Unpaused
13:58:46:FS01:Unpaused
13:58:46:WU01:FS00:Starting
13:58:46:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 9436 -checkpoint 15 -np 7
13:58:46:WU01:FS00:Started FahCore on PID 1176
13:58:47:WU01:FS00:Core PID:1108
13:58:47:WU01:FS00:FahCore 0xa8 started
13:58:47:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:58:47:WU01:FS00:0xa8:*********************** Log Started 2020-12-02T13:58:47Z ***********************
13:58:47:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
13:58:47:WU01:FS00:0xa8: Core: Gromacs
13:58:47:WU01:FS00:0xa8: Type: 0xa8
13:58:47:WU01:FS00:0xa8: Version: 0.0.9
13:58:47:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:58:47:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
13:58:47:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
13:58:47:WU01:FS00:0xa8: Date: Oct 28 2020
13:58:47:WU01:FS00:0xa8: Time: 16:17:37
13:58:47:WU01:FS00:0xa8: Revision: 15f9b5e1edd6089f1a45553d2709a6aba62f735c
13:58:47:WU01:FS00:0xa8: Branch: master
13:58:47:WU01:FS00:0xa8: Compiler: Visual C++ 2019 16.7
13:58:47:WU01:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:58:47:WU01:FS00:0xa8: Platform: win32 10
13:58:47:WU01:FS00:0xa8: Bits: 64
13:58:47:WU01:FS00:0xa8: Mode: Release
13:58:47:WU01:FS00:0xa8: SIMD: avx2_256
13:58:47:WU01:FS00:0xa8: OpenMP: ON
13:58:47:WU01:FS00:0xa8: CUDA: OFF
13:58:47:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 1176 -checkpoint 15 -np 7
13:58:47:WU01:FS00:0xa8:************************************ libFAH ************************************
13:58:47:WU01:FS00:0xa8: Time: 15:11:42
13:58:47:WU01:FS00:0xa8:************************************ CBang *************************************
13:58:47:WU01:FS00:0xa8: Time: 15:11:22
13:58:47:WU01:FS00:0xa8:************************************ System ************************************
13:58:47:WU01:FS00:0xa8: CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
13:58:47:WU01:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
13:58:47:WU01:FS00:0xa8: CPUs: 8
13:58:47:WU01:FS00:0xa8: Memory: 15.94GiB
13:58:47:WU01:FS00:0xa8:Free Memory: 11.90GiB
13:58:47:WU01:FS00:0xa8: Threads: WINDOWS_THREADS
13:58:47:WU01:FS00:0xa8: OS Version: 6.2
13:58:47:WU01:FS00:0xa8:Has Battery: false
13:58:47:WU01:FS00:0xa8: On Battery: false
13:58:47:WU01:FS00:0xa8: UTC Offset: 1
13:58:47:WU01:FS00:0xa8: PID: 1108
13:58:47:WU01:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
13:58:47:WU01:FS00:0xa8:********************************************************************************
13:58:47:WU01:FS00:0xa8:Project: 16812 (Run 0, Clone 1020, Gen 37)
13:58:47:WU01:FS00:0xa8:Unit: 0x0000002bb2aec48a5f8ddfb618a8b916
13:58:47:WU01:FS00:0xa8:Digital signatures verified
13:58:47:WU01:FS00:0xa8:Calling: mdrun -c frame37.gro -s frame37.tpr -x frame37.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
13:58:47:WU01:FS00:0xa8:Steps: first=18500000 total=19000000
13:58:49:WU01:FS00:0xa8:Completed 337482 out of 500000 steps (67%)
13:58:51:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:58:51:WU00:FS01:Connecting to assign2.foldingathome.org:80
13:58:52:WU00:FS01:Assigned to work server 129.213.157.105
13:58:52:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
13:58:52:WU00:FS01:Connecting to 129.213.157.105:8080
13:59:14:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:59:14:WU00:FS01:Connecting to 129.213.157.105:80
13:59:35:ERROR:WU00:FS01:Exception: Failed to connect to 129.213.157.105:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
14:00:00:27:127.0.0.1:New Web session
14:00:06:WU01:FS00:0xa8:Completed 340000 out of 500000 steps (68%)
14:00:24:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:00:24:WU00:FS01:Assigned to work server 129.213.157.105
14:00:30:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
14:00:30:WU00:FS01:Connecting to 129.213.157.105:8080
14:00:33:FS00:Shutting core down
14:00:33:WU01:FS00:0xa8:WARNING:Console control signal 1 on PID 1108
14:00:33:WU01:FS00:0xa8:Exiting, please wait. . .
14:00:34:WU01:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
14:00:34:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:00:34:WU01:FS00:Starting
14:00:34:WARNING:WU01:FS00:Changed SMP threads from 7 to 4 this can cause some work units to fail
14:00:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 9436 -checkpoint 15 -np 4
14:00:35:WU01:FS00:Started FahCore on PID 148
14:00:35:WU01:FS00:Core PID:4000
14:00:35:WU01:FS00:FahCore 0xa8 started
14:00:35:WU01:FS00:0xa8:*********************** Log Started 2020-12-02T14:00:35Z ***********************
14:00:35:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:00:35:WU01:FS00:0xa8: Core: Gromacs
14:00:35:WU01:FS00:0xa8: Type: 0xa8
14:00:35:WU01:FS00:0xa8: Version: 0.0.9
14:00:35:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:00:35:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
14:00:35:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
14:00:35:WU01:FS00:0xa8: Date: Oct 28 2020
14:00:35:WU01:FS00:0xa8: Time: 16:17:37
14:00:35:WU01:FS00:0xa8: Revision: 15f9b5e1edd6089f1a45553d2709a6aba62f735c
14:00:35:WU01:FS00:0xa8: Branch: master
14:00:35:WU01:FS00:0xa8: Compiler: Visual C++ 2019 16.7
14:00:35:WU01:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:00:35:WU01:FS00:0xa8: Platform: win32 10
14:00:35:WU01:FS00:0xa8: Bits: 64
14:00:35:WU01:FS00:0xa8: Mode: Release
14:00:35:WU01:FS00:0xa8: SIMD: avx2_256
14:00:35:WU01:FS00:0xa8: OpenMP: ON
14:00:35:WU01:FS00:0xa8: CUDA: OFF
14:00:35:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 148 -checkpoint 15 -np 4
14:00:35:WU01:FS00:0xa8:************************************ libFAH ************************************
14:00:35:WU01:FS00:0xa8: Time: 15:11:42
14:00:35:WU01:FS00:0xa8:************************************ CBang *************************************
14:00:35:WU01:FS00:0xa8: Time: 15:11:22
14:00:35:WU01:FS00:0xa8:************************************ System ************************************
14:00:35:WU01:FS00:0xa8: CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
14:00:35:WU01:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
14:00:35:WU01:FS00:0xa8: CPUs: 8
14:00:35:WU01:FS00:0xa8: Memory: 15.94GiB
14:00:35:WU01:FS00:0xa8:Free Memory: 11.73GiB
14:00:35:WU01:FS00:0xa8: Threads: WINDOWS_THREADS
14:00:35:WU01:FS00:0xa8: OS Version: 6.2
14:00:35:WU01:FS00:0xa8:Has Battery: false
14:00:35:WU01:FS00:0xa8: On Battery: false
14:00:35:WU01:FS00:0xa8: UTC Offset: 1
14:00:35:WU01:FS00:0xa8: PID: 4000
14:00:35:WU01:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
14:00:35:WU01:FS00:0xa8:********************************************************************************
14:00:35:WU01:FS00:0xa8:Project: 16812 (Run 0, Clone 1020, Gen 37)
14:00:35:WU01:FS00:0xa8:Unit: 0x0000002bb2aec48a5f8ddfb618a8b916
14:00:35:WU01:FS00:0xa8:Digital signatures verified
14:00:35:WU01:FS00:0xa8:Calling: mdrun -c frame37.gro -s frame37.tpr -x frame37.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
14:00:35:WU01:FS00:0xa8:Steps: first=18500000 total=19000000
14:00:36:WU01:FS00:0xa8:Completed 340902 out of 500000 steps (68%)
14:00:50:Removing old file 'configs/config-20201129-183751.xml'
14:00:50:Saving configuration to config.xml
14:00:50:<config>
14:00:50: <!-- Slot Control -->
14:00:50: <power v='LIGHT'/>
14:00:50:
14:00:50: <!-- User Information -->
14:00:50: <passkey v='*****'/>
14:00:50: <team v='268147'/>
14:00:50: <user v='Berliner_Mediziner_Hobbit'/>
14:00:50:
14:00:50: <!-- Folding Slots -->
14:00:50: <slot id='0' type='CPU'/>
14:00:50: <slot id='1' type='GPU'>
14:00:50: <pci-bus v='1'/>
14:00:50: <pci-slot v='0'/>
14:00:50: </slot>
14:00:50:</config>
14:00:51:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:00:51:WU00:FS01:Connecting to 129.213.157.105:80
14:01:36:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
14:02:46:51:127.0.0.1:New Web session
14:02:52:FS00:Shutting core down
14:02:52:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:02:52:WU01:FS00:0xa8:WARNING:Console control signal 1 on PID 4000
14:02:53:WU01:FS00:0xa8:Exiting, please wait. . .
14:02:53:WU00:FS01:Assigned to work server 129.213.157.105
14:02:53:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
14:02:53:WU00:FS01:Connecting to 129.213.157.105:8080
14:02:54:WU01:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
14:02:54:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:02:54:WU01:FS00:Starting
14:02:54:WARNING:WU01:FS00:Changed SMP threads from 4 to 7 this can cause some work units to fail
14:02:54:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 9436 -checkpoint 15 -np 7
14:02:54:WU01:FS00:Started FahCore on PID 228
14:02:54:WU01:FS00:Core PID:8000
14:02:54:WU01:FS00:FahCore 0xa8 started
14:02:55:WU01:FS00:0xa8:*********************** Log Started 2020-12-02T14:02:54Z ***********************
14:02:55:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:02:55:WU01:FS00:0xa8: Core: Gromacs
14:02:55:WU01:FS00:0xa8: Type: 0xa8
14:02:55:WU01:FS00:0xa8: Version: 0.0.9
14:02:55:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:02:55:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
14:02:55:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
14:02:55:WU01:FS00:0xa8: Date: Oct 28 2020
14:02:55:WU01:FS00:0xa8: Time: 16:17:37
14:02:55:WU01:FS00:0xa8: Revision: 15f9b5e1edd6089f1a45553d2709a6aba62f735c
14:02:55:WU01:FS00:0xa8: Branch: master
14:02:55:WU01:FS00:0xa8: Compiler: Visual C++ 2019 16.7
14:02:55:WU01:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:02:55:WU01:FS00:0xa8: Platform: win32 10
14:02:55:WU01:FS00:0xa8: Bits: 64
14:02:55:WU01:FS00:0xa8: Mode: Release
14:02:55:WU01:FS00:0xa8: SIMD: avx2_256
14:02:55:WU01:FS00:0xa8: OpenMP: ON
14:02:55:WU01:FS00:0xa8: CUDA: OFF
14:02:55:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 228 -checkpoint 15 -np 7
14:02:55:WU01:FS00:0xa8:************************************ libFAH ************************************
14:02:55:WU01:FS00:0xa8: Time: 15:11:42
14:02:55:WU01:FS00:0xa8:************************************ CBang *************************************
14:02:55:WU01:FS00:0xa8: Time: 15:11:22
14:02:55:WU01:FS00:0xa8:************************************ System ************************************
14:02:55:WU01:FS00:0xa8: CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
14:02:55:WU01:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
14:02:55:WU01:FS00:0xa8: CPUs: 8
14:02:55:WU01:FS00:0xa8: Memory: 15.94GiB
14:02:55:WU01:FS00:0xa8:Free Memory: 11.80GiB
14:02:55:WU01:FS00:0xa8: Threads: WINDOWS_THREADS
14:02:55:WU01:FS00:0xa8: OS Version: 6.2
14:02:55:WU01:FS00:0xa8:Has Battery: false
14:02:55:WU01:FS00:0xa8: On Battery: false
14:02:55:WU01:FS00:0xa8: UTC Offset: 1
14:02:55:WU01:FS00:0xa8: PID: 8000
14:02:55:WU01:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
14:02:55:WU01:FS00:0xa8:********************************************************************************
14:02:55:WU01:FS00:0xa8:Project: 16812 (Run 0, Clone 1020, Gen 37)
14:02:55:WU01:FS00:0xa8:Unit: 0x0000002bb2aec48a5f8ddfb618a8b916
14:02:55:WU01:FS00:0xa8:Digital signatures verified
14:02:55:WU01:FS00:0xa8:Calling: mdrun -c frame37.gro -s frame37.tpr -x frame37.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
14:02:55:WU01:FS00:0xa8:Steps: first=18500000 total=19000000
14:02:56:WU01:FS00:0xa8:Completed 344302 out of 500000 steps (68%)
14:03:14:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:03:14:WU00:FS01:Connecting to 129.213.157.105:80
14:03:18:WU01:FS00:0xa8:Completed 345000 out of 500000 steps (69%)
14:03:53:Removing old file 'configs/config-20201129-205506.xml'
14:03:53:Saving configuration to config.xml
14:03:53:<config>
14:03:53: <!-- Slot Control -->
14:03:53: <power v='FULL'/>
14:03:53:
14:03:53: <!-- User Information -->
14:03:53: <passkey v='*****'/>
14:03:53: <team v='268147'/>
14:03:53: <user v='Berliner_Mediziner_Hobbit'/>
14:03:53:
14:03:53: <!-- Folding Slots -->
14:03:53: <slot id='0' type='CPU'/>
14:03:53: <slot id='1' type='GPU'>
14:03:53: <pci-bus v='1'/>
14:03:53: <pci-slot v='0'/>
14:03:53: </slot>
14:03:53:</config>
14:03:59:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
14:04:29:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:04:30:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:04:30:WU00:FS01:Connecting to assign2.foldingathome.org:80
14:04:30:WU00:FS01:Assigned to work server 129.213.157.105
14:04:30:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
14:04:30:WU00:FS01:Connecting to 129.213.157.105:8080
14:04:51:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:04:52:WU00:FS01:Connecting to 129.213.157.105:80
14:05:14:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
14:05:36:WU01:FS00:0xa8:Completed 350000 out of 500000 steps (70%)
14:07:07:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:07:07:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:07:07:WU00:FS01:Connecting to assign2.foldingathome.org:80
14:07:07:WU00:FS01:Assigned to work server 129.213.157.105
14:07:08:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
14:07:08:WU00:FS01:Connecting to 129.213.157.105:8080
14:07:29:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:07:29:WU00:FS01:Connecting to 129.213.157.105:80
14:07:50:ERROR:WU00:FS01:Exception: Failed to connect to 129.213.157.105:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
14:07:59:WU01:FS00:0xa8:Completed 355000 out of 500000 steps (71%)
14:10:16:WU01:FS00:0xa8:Completed 360000 out of 500000 steps (72%)
14:11:21:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:11:21:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:11:21:WU00:FS01:Connecting to assign2.foldingathome.org:80
14:11:22:WU00:FS01:Assigned to work server 206.223.170.146
14:11:22:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 206.223.170.146
14:11:22:WU00:FS01:Connecting to 206.223.170.146:8080
14:11:22:ERROR:WU00:FS01:Exception: Server did not assign work unit
14:12:38:WU01:FS00:0xa8:Completed 365000 out of 500000 steps (73%)
14:14:59:WU01:FS00:0xa8:Completed 370000 out of 500000 steps (74%)
14:17:17:WU01:FS00:0xa8:Completed 375000 out of 500000 steps (75%)
14:17:48:FS00:Finishing
14:17:48:FS01:Finishing
14:18:12:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:18:13:WU00:FS01:Assigned to work server 129.213.157.105
14:19:34:WU01:FS00:0xa8:Completed 380000 out of 500000 steps (76%)
14:21:50:WU01:FS00:0xa8:Completed 385000 out of 500000 steps (77%)
14:24:12:WU01:FS00:0xa8:Completed 390000 out of 500000 steps (78%)
14:26:29:WU01:FS00:0xa8:Completed 395000 out of 500000 steps (79%)
14:28:47:WU01:FS00:0xa8:Completed 400000 out of 500000 steps (80%)
14:31:04:WU01:FS00:0xa8:Completed 405000 out of 500000 steps (81%)
14:33:22:WU01:FS00:0xa8:Completed 410000 out of 500000 steps (82%)
14:35:38:WU01:FS00:0xa8:Completed 415000 out of 500000 steps (83%)
14:37:55:WU01:FS00:0xa8:Completed 420000 out of 500000 steps (84%)
14:40:12:WU01:FS00:0xa8:Completed 425000 out of 500000 steps (85%)
14:42:28:WU01:FS00:0xa8:Completed 430000 out of 500000 steps (86%)
14:44:45:WU01:FS00:0xa8:Completed 435000 out of 500000 steps (87%)
14:47:02:WU01:FS00:0xa8:Completed 440000 out of 500000 steps (88%)
14:49:19:WU01:FS00:0xa8:Completed 445000 out of 500000 steps (89%)
14:51:49:WU01:FS00:0xa8:Completed 450000 out of 500000 steps (90%)
14:54:29:WU01:FS00:0xa8:Completed 455000 out of 500000 steps (91%)
14:56:50:WU01:FS00:0xa8:Completed 460000 out of 500000 steps (92%)
14:59:10:WU01:FS00:0xa8:Completed 465000 out of 500000 steps (93%)
15:01:31:WU01:FS00:0xa8:Completed 470000 out of 500000 steps (94%)
15:03:51:WU01:FS00:0xa8:Completed 475000 out of 500000 steps (95%)
15:06:14:WU01:FS00:0xa8:Completed 480000 out of 500000 steps (96%)
15:08:33:WU01:FS00:0xa8:Completed 485000 out of 500000 steps (97%)
15:10:50:WU01:FS00:0xa8:Completed 490000 out of 500000 steps (98%)
15:13:10:WU01:FS00:0xa8:Completed 495000 out of 500000 steps (99%)
15:15:29:WU01:FS00:0xa8:Completed 500000 out of 500000 steps (100%)
15:15:30:WU01:FS00:0xa8:Saving result file ..\logfile_01.txt
15:15:30:WU01:FS00:0xa8:Saving result file frame37.gro
15:15:31:WU01:FS00:0xa8:Saving result file frame37.xtc
15:15:31:WU01:FS00:0xa8:Saving result file md.log
15:15:31:WU01:FS00:0xa8:Saving result file science.log
15:15:31:WU01:FS00:0xa8:Saving result file state.cpt
15:15:31:WU01:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
15:15:31:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:15:31:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16812 run:0 clone:1020 gen:37 core:0xa8 unit:0x0000002bb2aec48a5f8ddfb618a8b916
15:15:31:WU01:FS00:Uploading 8.61MiB to 178.174.196.138
15:15:31:WU01:FS00:Connecting to 178.174.196.138:8080
15:15:37:WU01:FS00:Upload 91.51%
15:15:37:WU01:FS00:Upload complete
15:15:37:WU01:FS00:Server responded WORK_ACK (400)
15:15:37:WU01:FS00:Final credit estimate, 6861.00 points
15:15:37:WU01:FS00:Cleaning up
18:54:01:100:127.0.0.1:New Web session
18:54:12:FS00:Paused
18:54:12:FS01:Paused
18:54:13:FS00:Unpaused
18:54:13:FS01:Unpaused
18:54:14:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
18:54:14:WU00:FS01:Connecting to 129.213.157.105:8080
18:54:14:WU01:FS00:Connecting to assign1.foldingathome.org:80
18:54:15:WU01:FS00:Assigned to work server 128.252.203.10
18:54:15:WU01:FS00:Requesting new work unit for slot 00: cpu:7 from 128.252.203.10
18:54:15:WU01:FS00:Connecting to 128.252.203.10:8080
18:54:16:WU01:FS00:Downloading 2.07MiB
18:54:22:WU01:FS00:Download 6.04%
18:54:31:WU01:FS00:Download 12.08%
18:54:35:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
18:54:35:WU00:FS01:Connecting to 129.213.157.105:80
18:54:36:FS00:Paused
18:54:36:FS01:Paused
18:54:39:Removing old file 'configs/config-20201129-205607.xml'
18:54:39:Saving configuration to config.xml
18:54:39:<config>
18:54:39: <!-- Slot Control -->
18:54:39: <power v='FULL'/>
18:54:39:
18:54:39: <!-- User Information -->
18:54:39: <passkey v='*****'/>
18:54:39: <team v='268147'/>
18:54:39: <user v='Berliner_Mediziner_Hobbit'/>
18:54:39:
18:54:39: <!-- Folding Slots -->
18:54:39: <slot id='0' type='CPU'>
18:54:39: <paused v='true'/>
18:54:39: </slot>
18:54:39: <slot id='1' type='GPU'>
18:54:39: <pci-bus v='1'/>
18:54:39: <pci-slot v='0'/>
18:54:39: </slot>
18:54:39:</config>
18:54:40:WU01:FS00:Download 18.12%
18:54:48:WU01:FS00:Download 24.16%
18:54:55:WU01:FS00:Download 30.20%
18:54:56:ERROR:WU00:FS01:Exception: Failed to connect to 129.213.157.105:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
18:55:03:WU01:FS00:Download 36.23%
18:55:11:WU01:FS00:Download 42.27%
18:55:19:WU01:FS00:Download 48.31%
18:55:26:WU01:FS00:Download 54.35%
18:55:34:WU01:FS00:Download 60.39%
18:55:42:WU01:FS00:Download 66.43%
18:55:50:WU01:FS00:Download 72.47%
18:55:56:WU01:FS00:Download 78.51%
******************************* Date: 2020-12-02 *******************************
19:24:52:WU01:FS00:Download 81.36%
19:24:52:ERROR:WU01:FS00:Exception: Transfer failed
19:26:12:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
19:26:46:FS00:Unpaused
19:26:46:FS01:Unpaused
19:26:46:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:26:46:WU01:FS00:Connecting to assign1.foldingathome.org:80
19:26:46:WU00:FS01:Assigned to work server 129.213.157.105
19:26:46:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
19:26:46:WU00:FS01:Connecting to 129.213.157.105:8080
19:26:48:WU01:FS00:Assigned to work server 130.237.11.145
19:26:48:WU01:FS00:Requesting new work unit for slot 00: cpu:7 from 130.237.11.145
19:26:48:WU01:FS00:Connecting to 130.237.11.145:8080
19:26:48:WU01:FS00:Downloading 2.06MiB
19:26:54:WU01:FS00:Download 60.59%
19:26:58:Removing old file 'configs/config-20201129-205708.xml'
19:26:58:Saving configuration to config.xml
19:26:58:<config>
19:26:58: <!-- Slot Control -->
19:26:58: <power v='FULL'/>
19:26:58:
19:26:58: <!-- User Information -->
19:26:58: <passkey v='*****'/>
19:26:58: <team v='268147'/>
19:26:58: <user v='Berliner_Mediziner_Hobbit'/>
19:26:58:
19:26:58: <!-- Folding Slots -->
19:26:58: <slot id='0' type='CPU'/>
19:26:58: <slot id='1' type='GPU'>
19:26:58: <pci-bus v='1'/>
19:26:58: <pci-slot v='0'/>
19:26:58: </slot>
19:26:58:</config>
19:26:59:121:127.0.0.1:New Web session
19:27:00:WU01:FS00:Download 96.95%
19:27:00:WU01:FS00:Download complete
19:27:00:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16814 run:9 clone:1408 gen:32 core:0xa8 unit:0x0000002182ed0b910000000000090580
19:27:00:WU01:FS00:Starting
19:27:00:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 9436 -checkpoint 15 -np 7
19:27:00:WU01:FS00:Started FahCore on PID 6628
19:27:00:WU01:FS00:Core PID:13216
19:27:00:WU01:FS00:FahCore 0xa8 started
19:27:01:WU01:FS00:0xa8:*********************** Log Started 2020-12-02T19:27:00Z ***********************
19:27:01:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:27:01:WU01:FS00:0xa8: Core: Gromacs
19:27:01:WU01:FS00:0xa8: Type: 0xa8
19:27:01:WU01:FS00:0xa8: Version: 0.0.9
19:27:01:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:27:01:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
19:27:01:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
19:27:01:WU01:FS00:0xa8: Date: Oct 28 2020
19:27:01:WU01:FS00:0xa8: Time: 16:17:37
19:27:01:WU01:FS00:0xa8: Revision: 15f9b5e1edd6089f1a45553d2709a6aba62f735c
19:27:01:WU01:FS00:0xa8: Branch: master
19:27:01:WU01:FS00:0xa8: Compiler: Visual C++ 2019 16.7
19:27:01:WU01:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:27:01:WU01:FS00:0xa8: Platform: win32 10
19:27:01:WU01:FS00:0xa8: Bits: 64
19:27:01:WU01:FS00:0xa8: Mode: Release
19:27:01:WU01:FS00:0xa8: SIMD: avx2_256
19:27:01:WU01:FS00:0xa8: OpenMP: ON
19:27:01:WU01:FS00:0xa8: CUDA: OFF
19:27:01:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 6628 -checkpoint 15 -np 7
19:27:01:WU01:FS00:0xa8:************************************ libFAH ************************************
19:27:01:WU01:FS00:0xa8: Time: 15:11:42
19:27:01:WU01:FS00:0xa8:************************************ CBang *************************************
19:27:01:WU01:FS00:0xa8: Time: 15:11:22
19:27:01:WU01:FS00:0xa8:************************************ System ************************************
19:27:01:WU01:FS00:0xa8: CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
19:27:01:WU01:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
19:27:01:WU01:FS00:0xa8: CPUs: 8
19:27:01:WU01:FS00:0xa8: Memory: 15.94GiB
19:27:01:WU01:FS00:0xa8:Free Memory: 11.72GiB
19:27:01:WU01:FS00:0xa8: Threads: WINDOWS_THREADS
19:27:01:WU01:FS00:0xa8: OS Version: 6.2
19:27:01:WU01:FS00:0xa8:Has Battery: false
19:27:01:WU01:FS00:0xa8: On Battery: false
19:27:01:WU01:FS00:0xa8: UTC Offset: 1
19:27:01:WU01:FS00:0xa8: PID: 13216
19:27:01:WU01:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
19:27:01:WU01:FS00:0xa8:********************************************************************************
19:27:01:WU01:FS00:0xa8:Project: 16814 (Run 9, Clone 1408, Gen 32)
19:27:01:WU01:FS00:0xa8:Unit: 0x0000002182ed0b910000000000090580
19:27:01:WU01:FS00:0xa8:Reading tar file core.xml
19:27:01:WU01:FS00:0xa8:Reading tar file frame32.tpr
19:27:01:WU01:FS00:0xa8:Digital signatures verified
19:27:01:WU01:FS00:0xa8:Calling: mdrun -c frame32.gro -s frame32.tpr -x frame32.xtc -cpt 15 -nt 7 -ntmpi 1
19:27:01:WU01:FS00:0xa8:Steps: first=16000000 total=16500000
19:27:02:WU01:FS00:0xa8:Completed 1 out of 500000 steps (0%)
19:27:07:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
19:27:07:WU00:FS01:Connecting to 129.213.157.105:80
19:27:28:ERROR:WU00:FS01:Exception: Failed to connect to 129.213.157.105:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
19:27:33:FS00:Paused
19:27:33:FS01:Paused
19:27:33:FS00:Shutting core down
19:27:33:WU01:FS00:0xa8:WARNING:Console control signal 1 on PID 13216
19:27:33:WU01:FS00:0xa8:Exiting, please wait. . .
19:27:35:WU01:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
19:27:35:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:27:59:Removing old file 'configs/config-20201129-212233.xml'
19:27:59:Saving configuration to config.xml
19:27:59:<config>
19:27:59: <!-- Slot Control -->
19:27:59: <power v='FULL'/>
19:27:59:
19:27:59: <!-- User Information -->
19:27:59: <passkey v='*****'/>
19:27:59: <team v='268147'/>
19:27:59: <user v='Berliner_Mediziner_Hobbit'/>
19:27:59:
19:27:59: <!-- Folding Slots -->
19:27:59: <slot id='0' type='CPU'>
19:27:59: <paused v='true'/>
19:27:59: </slot>
19:27:59: <slot id='1' type='GPU'>
19:27:59: <pci-bus v='1'/>
19:27:59: <pci-slot v='0'/>
19:27:59: </slot>
19:27:59:</config>
19:28:36:FS00:Unpaused
19:28:36:FS01:Unpaused
19:28:36:WU00:FS01:Connecting to assign1.foldingathome.org:80
19:28:36:WU01:FS00:Starting
19:28:36:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 9436 -checkpoint 15 -np 7
19:28:36:WU01:FS00:Started FahCore on PID 13144
19:28:36:WU01:FS00:Core PID:2008
19:28:36:WU01:FS00:FahCore 0xa8 started
19:28:37:WU00:FS01:Assigned to work server 129.213.157.105
19:28:37:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 6GB] 4372 from 129.213.157.105
19:28:37:WU00:FS01:Connecting to 129.213.157.105:8080
19:28:37:WU01:FS00:0xa8:*********************** Log Started 2020-12-02T19:28:36Z ***********************
19:28:37:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
19:28:37:WU01:FS00:0xa8: Core: Gromacs
19:28:37:WU01:FS00:0xa8: Type: 0xa8
19:28:37:WU01:FS00:0xa8: Version: 0.0.9
19:28:37:WU01:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:28:37:WU01:FS00:0xa8: Copyright: 2020 foldingathome.org
19:28:37:WU01:FS00:0xa8: Homepage: https://foldingathome.org/
19:28:37:WU01:FS00:0xa8: Date: Oct 28 2020
19:28:37:WU01:FS00:0xa8: Time: 16:17:37
19:28:37:WU01:FS00:0xa8: Revision: 15f9b5e1edd6089f1a45553d2709a6aba62f735c
19:28:37:WU01:FS00:0xa8: Branch: master
19:28:37:WU01:FS00:0xa8: Compiler: Visual C++ 2019 16.7
19:28:37:WU01:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
19:28:37:WU01:FS00:0xa8: Platform: win32 10
19:28:37:WU01:FS00:0xa8: Bits: 64
19:28:37:WU01:FS00:0xa8: Mode: Release
19:28:37:WU01:FS00:0xa8: SIMD: avx2_256
19:28:37:WU01:FS00:0xa8: OpenMP: ON
19:28:37:WU01:FS00:0xa8: CUDA: OFF
19:28:37:WU01:FS00:0xa8: Args: -dir 01 -suffix 01 -version 706 -lifeline 13144 -checkpoint 15 -np
19:28:37:WU01:FS00:0xa8: 7
19:28:37:WU01:FS00:0xa8:************************************ libFAH ************************************
19:28:37:WU01:FS00:0xa8: Time: 15:11:42
19:28:37:WU01:FS00:0xa8:************************************ CBang *************************************
19:28:37:WU01:FS00:0xa8: Time: 15:11:22
19:28:37:WU01:FS00:0xa8:************************************ System ************************************
19:28:37:WU01:FS00:0xa8: CPU: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
19:28:37:WU01:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
19:28:37:WU01:FS00:0xa8: CPUs: 8
19:28:37:WU01:FS00:0xa8: Memory: 15.94GiB
19:28:37:WU01:FS00:0xa8:Free Memory: 11.82GiB
19:28:37:WU01:FS00:0xa8: Threads: WINDOWS_THREADS
19:28:37:WU01:FS00:0xa8: OS Version: 6.2
19:28:37:WU01:FS00:0xa8:Has Battery: false
19:28:37:WU01:FS00:0xa8: On Battery: false
19:28:37:WU01:FS00:0xa8: UTC Offset: 1
19:28:37:WU01:FS00:0xa8: PID: 2008
19:28:37:WU01:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
19:28:37:WU01:FS00:0xa8:********************************************************************************
19:28:37:WU01:FS00:0xa8:Project: 16814 (Run 9, Clone 1408, Gen 32)
19:28:37:WU01:FS00:0xa8:Unit: 0x0000002182ed0b910000000000090580
19:28:37:WU01:FS00:0xa8:Digital signatures verified
19:28:37:WU01:FS00:0xa8:Calling: mdrun -c frame32.gro -s frame32.tpr -x frame32.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
19:28:37:WU01:FS00:0xa8:Steps: first=16000000 total=16500000
19:28:38:WU01:FS00:0xa8:Completed 1162 out of 500000 steps (0%)
Laptop (Linux Ubuntu)
*********************** Log Started 2020-12-02T19:31:56Z ***********************
19:31:56:******************************* libFAH ********************************
19:31:56: Date: Oct 20 2020
19:31:56: Time: 20:36:39
19:31:56: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
19:31:56: Branch: master
19:31:56: Compiler: GNU 8.3.0
19:31:56: Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
19:31:56: -fdata-sections -O3 -funroll-loops -fno-pie
19:31:56: Platform: linux2 5.8.0-1-amd64
19:31:56: Bits: 64
19:31:56: Mode: Release
19:31:56:****************************** FAHClient ******************************
19:31:56: Version: 7.6.21
19:31:56: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:31:56: Copyright: 2020 foldingathome.org
19:31:56: Homepage: https://foldingathome.org/
19:31:56: Time: 20:39:00
19:31:56: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
19:31:56: Bits: 64
19:31:56: Args: --child /etc/fahclient/config.xml --run-as fahclient
19:31:56: --pid-file=/var/run/fahclient.pid --daemon
19:31:56: Config: /etc/fahclient/config.xml
19:31:56:******************************** CBang ********************************
19:31:56: Time: 18:37:59
19:31:56: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
19:31:56: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
19:31:56: Bits: 64
19:31:56:******************************* System ********************************
19:31:56: CPU: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
19:31:56: CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
19:31:56: CPUs: 4
19:31:56: Memory: 3.59GiB
19:31:56:Free Memory: 2.67GiB
19:31:56: Threads: POSIX_THREADS
19:31:56: OS Version: 5.4
19:31:56:Has Battery: true
19:31:56: On Battery: false
19:31:56: UTC Offset: 1
19:31:56: PID: 1248
19:31:56: CWD: /var/lib/fahclient
19:31:56: OS: Linux 5.4.0-54-generic x86_64
19:31:56: OS Arch: AMD64
19:31:56: GPUs: 1
19:31:56: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 620]
19:31:56: CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
19:31:56: libcuda.so: cannot open shared object file: No such file or
19:31:56: directory
19:31:56: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
19:31:56: libOpenCL.so: cannot open shared object file: No such file or
19:31:56: directory
19:31:56:***********************************************************************
19:31:56:<config>
19:31:56: <!-- Client Control -->
19:31:56: <fold-anon v='true'/>
19:31:56:
19:31:56: <!-- Folding Slot Configuration -->
19:31:56: <cause v='HUNTINGTONS'/>
19:31:56: <gpu v='false'/>
19:31:56:
19:31:56: <!-- Slot Control -->
19:31:56: <power v='FULL'/>
19:31:56:
19:31:56: <!-- User Information -->
19:31:56: <team v='268147'/>
19:31:56: <user v='Berliner Mediziner LpTp'/>
19:31:56:
19:31:56: <!-- Folding Slots -->
19:31:56: <slot id='0' type='CPU'/>
19:31:56:</config>
19:31:56:Trying to access database...
19:31:56:Successfully acquired database lock
19:31:56:FS00:Initialized folding slot 00: cpu:4
19:31:56:WU00:FS00:Starting
19:31:56:WU00:FS00:Removing old file 'work/00/logfile_01-20201201-055416.txt'
19:31:56:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 1248 -checkpoint 15 -np 4
19:31:56:WU00:FS00:Started FahCore on PID 1263
19:31:56:WU00:FS00:Core PID:1271
19:31:56:WU00:FS00:FahCore 0xa8 started
19:31:56:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:31:56:WU00:FS00:Started FahCore on PID 1338
19:31:56:WU00:FS00:Core PID:1342
19:31:57:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:32:21:13:127.0.0.1:New Web session
19:32:56:WU00:FS00:Starting
19:32:56:WU00:FS00:Removing old file 'work/00/logfile_01-20201201-055516.txt'
19:32:56:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 1248 -checkpoint 15 -np 4
19:32:56:WU00:FS00:Started FahCore on PID 2696
19:32:56:WU00:FS00:Core PID:2700
19:32:56:WU00:FS00:FahCore 0xa8 started
19:32:57:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:33:56:WU00:FS00:Starting
19:33:56:WU00:FS00:Removing old file 'work/00/logfile_01-20201201-055617.txt'
19:33:56:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 1248 -checkpoint 15 -np 4
19:33:56:WU00:FS00:Started FahCore on PID 2914
19:33:56:WU00:FS00:Core PID:2918
19:33:56:WU00:FS00:FahCore 0xa8 started
19:33:57:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
When I translate your error message, it sounds like this unresolved issue.
viewtopic.php?f=18&t=36474
you´r right seems likely to be the issue. thanks
I had this on one of my PCs, and a restart fixed it for the moment, I hope they fix it more permanently.
