COULD NOT FOLD: FahCore returned: INTERRUPTED (102 = 0x66)
ronnieross
Post by ronnieross »
Moved topic to forum for issues with CPU folding from GPU - j
Hello, since yesterday I could not fold anymore.
Can somebody help me? I haven't touch anything...
21:14:17:Read GPUs.txt
21:14:17:Removing old file 'logs/log-20201106-224908.txt'
21:14:17:******************************* libFAH ********************************
21:14:17:       Date: Oct 20 2020
21:14:17:       Time: 20:36:39
21:14:17:   Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
21:14:17:     Branch: master
21:14:17:   Compiler: GNU 8.3.0
21:14:17:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
21:14:17:             -fdata-sections -O3 -funroll-loops -fno-pie
21:14:17:   Platform: linux2 5.8.0-1-amd64
21:14:17:       Bits: 64
21:14:17:       Mode: Release
21:14:17:****************************** FAHClient ******************************
21:14:17:    Version: 7.6.21
21:14:17:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:14:17:  Copyright: 2020 foldingathome.org
21:14:17:   Homepage: https://foldingathome.org/
21:14:17:       Time: 20:39:00
21:14:17:   Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
21:14:17:       Bits: 64
21:14:17:     Config: /usr/bin/config.xml
21:14:17:******************************** CBang ********************************
21:14:17:       Time: 18:37:59
21:14:17:   Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
21:14:17:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
21:14:17:       Bits: 64
21:14:17:******************************* System ********************************
21:14:17:        CPU: Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
21:14:17:     CPU ID: GenuineIntel Family 6 Model 166 Stepping 0
21:14:17:       CPUs: 12
21:14:17:     Memory: 15.36GiB
21:14:17:Free Memory: 12.12GiB
21:14:17:    Threads: POSIX_THREADS
21:14:17: OS Version: 5.4
21:14:17:Has Battery: false
21:14:17: On Battery: false
21:14:17: UTC Offset: 1
21:14:17:        PID: 16816
21:14:17:        CWD: /usr/bin
21:14:17:         OS: Linux 5.4.0-54-generic x86_64
21:14:17:    OS Arch: AMD64
21:14:17:       GPUs: 1
21:14:17:      GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 CML GT2 [UHD Graphics]
21:14:17:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
21:14:17:             libcuda.so: cannot open shared object file: No such file or
21:14:17:             directory
21:14:17:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
21:14:17:             libOpenCL.so: cannot open shared object file: No such file or
21:14:17:             directory
21:14:17:***********************************************************************
21:14:17:<config>
21:14:17:  <!-- Network -->
21:14:17:  <proxy v=':8080'/>
21:14:17:
21:14:17:  <!-- Slot Control -->
21:14:17:  <power v='light'/>
21:14:17:
21:14:17:  <!-- Folding Slots -->
21:14:17:  <slot id='0' type='CPU'/>
21:14:17:  <slot id='1' type='GPU'>
21:14:17:    <pci-bus v='0'/>
21:14:17:    <pci-slot v='2'/>
21:14:17:  </slot>
21:14:17:</config>
21:14:17:Trying to access database...
21:14:17:Successfully acquired database lock
21:14:17:FS00:Initialized folding slot 00: cpu:6
21:14:17:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 CML GT2 [UHD Graphics].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
21:14:17:WU00:FS00:Starting
21:14:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:14:17:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-203704.txt'
21:14:17:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:14:17:WU00:FS00:Started FahCore on PID 16825
21:14:17:WU00:FS00:Core PID:16829
21:14:17:WU00:FS00:FahCore 0xa8 started
21:14:17:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:14:17:WU00:FS00:Started FahCore on PID 16844
21:14:17:WU00:FS00:Core PID:16848
21:14:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:15:17:WU00:FS00:Starting
21:15:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:15:17:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-203804.txt'
21:15:17:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:15:17:WU00:FS00:Started FahCore on PID 16858
21:15:17:WU00:FS00:Core PID:16862
21:15:17:WU00:FS00:FahCore 0xa8 started
21:15:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:16:17:WU00:FS00:Starting
21:16:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:16:17:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-203904.txt'
21:16:17:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:16:17:WU00:FS00:Started FahCore on PID 17179
21:16:17:WU00:FS00:Core PID:17184
21:16:17:WU00:FS00:FahCore 0xa8 started
21:16:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:17:17:WU00:FS00:Starting
21:17:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:17:17:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204004.txt'
21:17:17:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:17:17:WU00:FS00:Started FahCore on PID 18279
21:17:17:WU00:FS00:Core PID:18283
21:17:17:WU00:FS00:FahCore 0xa8 started
21:17:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:18:17:WU00:FS00:Starting
21:18:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:18:17:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204104.txt'
21:18:17:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:18:17:WU00:FS00:Started FahCore on PID 18408
21:18:17:WU00:FS00:Core PID:18412
21:18:17:WU00:FS00:FahCore 0xa8 started
21:18:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:19:17:WU00:FS00:Starting
21:19:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:19:17:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204204.txt'
21:19:17:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:19:17:WU00:FS00:Started FahCore on PID 18493
21:19:17:WU00:FS00:Core PID:18497
21:19:17:WU00:FS00:FahCore 0xa8 started
21:19:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:20:17:WU00:FS00:Starting
21:20:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:20:17:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204304.txt'
21:20:17:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:20:17:WU00:FS00:Started FahCore on PID 18574
21:20:17:WU00:FS00:Core PID:18578
21:20:17:WU00:FS00:FahCore 0xa8 started
21:20:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:21:17:WU00:FS00:Starting
21:21:17:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:21:17:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204404.txt'
21:21:17:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:21:17:WU00:FS00:Started FahCore on PID 18605
21:21:17:WU00:FS00:Core PID:18609
21:21:17:WU00:FS00:FahCore 0xa8 started
21:21:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:22:18:WU00:FS00:Starting
21:22:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:22:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204504.txt'
21:22:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:22:18:WU00:FS00:Started FahCore on PID 18629
21:22:18:WU00:FS00:Core PID:18633
21:22:18:WU00:FS00:FahCore 0xa8 started
21:22:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:23:18:WU00:FS00:Starting
21:23:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:23:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204605.txt'
21:23:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:23:18:WU00:FS00:Started FahCore on PID 18655
21:23:18:WU00:FS00:Core PID:18659
21:23:18:WU00:FS00:FahCore 0xa8 started
21:23:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:24:18:WU00:FS00:Starting
21:24:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:24:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204705.txt'
21:24:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:24:18:WU00:FS00:Started FahCore on PID 18673
21:24:18:WU00:FS00:Core PID:18677
21:24:18:WU00:FS00:FahCore 0xa8 started
21:24:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:25:18:WU00:FS00:Starting
21:25:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:25:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204805.txt'
21:25:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:25:18:WU00:FS00:Started FahCore on PID 18909
21:25:18:WU00:FS00:Core PID:18913
21:25:18:WU00:FS00:FahCore 0xa8 started
21:25:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:26:18:WU00:FS00:Starting
21:26:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:26:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-204905.txt'
21:26:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:26:18:WU00:FS00:Started FahCore on PID 19061
21:26:18:WU00:FS00:Core PID:19065
21:26:18:WU00:FS00:FahCore 0xa8 started
21:26:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:27:18:WU00:FS00:Starting
21:27:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:27:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-205005.txt'
21:27:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:27:18:WU00:FS00:Started FahCore on PID 19434
21:27:18:WU00:FS00:Core PID:19438
21:27:18:WU00:FS00:FahCore 0xa8 started
21:27:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:28:18:WU00:FS00:Starting
21:28:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:28:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-205105.txt'
21:28:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:28:18:WU00:FS00:Started FahCore on PID 19475
21:28:18:WU00:FS00:Core PID:19479
21:28:18:WU00:FS00:FahCore 0xa8 started
21:28:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:29:18:WU00:FS00:Starting
21:29:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:29:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-205205.txt'
21:29:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:29:18:WU00:FS00:Started FahCore on PID 19682
21:29:18:WU00:FS00:Core PID:19686
21:29:18:WU00:FS00:FahCore 0xa8 started
21:29:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:30:18:WU00:FS00:Starting
21:30:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:30:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-205305.txt'
21:30:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:30:18:WU00:FS00:Started FahCore on PID 19888
21:30:18:WU00:FS00:Core PID:19892
21:30:18:WU00:FS00:FahCore 0xa8 started
21:30:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:31:18:WU00:FS00:Starting
21:31:18:WARNING:WU00:FS00:AS lowered CPUs from 6 to 5
21:31:18:WU00:FS00:Removing old file 'work/00/logfile_01-20201130-205405.txt'
21:31:18:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /usr/bin/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 00 -suffix 01 -version 706 -lifeline 16816 -checkpoint 15 -np 5
21:31:18:WU00:FS00:Started FahCore on PID 19998
21:31:18:WU00:FS00:Core PID:20002
21:31:18:WU00:FS00:FahCore 0xa8 started
21:31:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Re: COULD NOT FOLD: FahCore returned: INTERRUPTED (102 = 0x6
Can't tell from the log what WU is failing, that information will be in an older log that recorded its download. One thing to try is changing the number of CPU threads down to 4, for some reason this WU was assigned with a value of 5. That fails on some projects.
First pause the folding, change the CPU thread count in FAHControl using Configure, and then start folding after the changes have been saved.
Maddog
Post by Maddog »
I would not be suprised if this is not another 16926 WU. If it is and the suggestion from Joe H does not get You folding again, then the WU will need to be dumped.
Pause FAH, Go into file manager: datasystem / var / lib / fahclient / work , Delete the folder with the number corresponding to the slot that is stuck, then click on Fold, in FAH control.
Lockheed_Tvr
CPU WUs - Linux [INTERRUPTED]
Post by Lockheed_Tvr »
All of my CPU slots on Linux boxes have been idle since the middle of yesterday (Monday, Nov 30). They all are trying to reach 129.32.209.204. Some, depending on when they finished their last WU, have been down over a day an a half.
Also, the attempt behavior is different than usual. Instead of increasing the time between each attempt, it just resets to 1 minute and tries again. Some of the boxes have well over 2000 attempts.
But oddly, the log doesn't say "no work unit available". Instead it says "WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)"
I don't know if it is a server issuing bad WUs or something else. This is happening across all 12 of my Linux boxes at home.
I'm not actually sure if this is a server issue, or a core issue, or what, but I thought I'd start here.
15:01:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:02:21:WU02:FS02:Starting
15:02:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143021.txt'
15:02:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:02:21:WU02:FS02:Started FahCore on PID 6746
15:02:21:WU02:FS02:Core PID:6750
15:02:21:WU02:FS02:FahCore 0xa8 started
15:02:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:03:21:WU02:FS02:Starting
15:03:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143121.txt'
15:03:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:03:21:WU02:FS02:Started FahCore on PID 6755
15:03:21:WU02:FS02:Core PID:6759
15:03:21:WU02:FS02:FahCore 0xa8 started
15:03:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:04:21:WU02:FS02:Starting
15:04:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143221.txt'
15:04:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:04:21:WU02:FS02:Started FahCore on PID 6764
15:04:21:WU02:FS02:Core PID:6768
15:04:21:WU02:FS02:FahCore 0xa8 started
15:04:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:05:21:WU02:FS02:Starting
15:05:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143321.txt'
15:05:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:05:21:WU02:FS02:Started FahCore on PID 6775
15:05:21:WU02:FS02:Core PID:6779
15:05:21:WU02:FS02:FahCore 0xa8 started
15:05:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:06:21:WU02:FS02:Starting
15:06:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143421.txt'
15:06:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:06:21:WU02:FS02:Started FahCore on PID 6786
15:06:21:WU02:FS02:Core PID:6790
15:06:21:WU02:FS02:FahCore 0xa8 started
15:06:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:07:21:WU02:FS02:Starting
15:07:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143521.txt'
15:07:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:07:21:WU02:FS02:Started FahCore on PID 6795
15:07:21:WU02:FS02:Core PID:6799
15:07:21:WU02:FS02:FahCore 0xa8 started
15:07:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:08:21:WU02:FS02:Starting
15:08:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143621.txt'
15:08:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:08:21:WU02:FS02:Started FahCore on PID 6804
15:08:21:WU02:FS02:Core PID:6808
15:08:21:WU02:FS02:FahCore 0xa8 started
15:08:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:09:21:WU02:FS02:Starting
15:09:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143721.txt'
15:09:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:09:21:WU02:FS02:Started FahCore on PID 6813
15:09:21:WU02:FS02:Core PID:6817
15:09:21:WU02:FS02:FahCore 0xa8 started
15:09:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:10:21:WU02:FS02:Starting
15:10:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143821.txt'
15:10:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:10:21:WU02:FS02:Started FahCore on PID 6823
15:10:21:WU02:FS02:Core PID:6827
15:10:21:WU02:FS02:FahCore 0xa8 started
15:10:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:11:21:WU02:FS02:Starting
15:11:21:WU02:FS02:Removing old file 'work/02/logfile_01-20201201-143921.txt'
15:11:21:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.9/Core_a8.fah/FahCore_a8 -dir 02 -suffix 01 -version 706 -lifeline 1087 -checkpoint 15 -np 7
15:11:21:WU02:FS02:Started FahCore on PID 6833
15:11:21:WU02:FS02:Core PID:6837
15:11:21:WU02:FS02:FahCore 0xa8 started
15:11:22:WU02:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
Reason: not a server issue, changed subject and merged with topic on correct forum
Yeroon
Re: 129.32.209.204 is not issuing CPU WUs to Linux boxes
Post by Yeroon »
See this thread:
viewtopic.php?f=19&t=36493
Lockheed_Tvr
Thanks.
ronnieross
Thanks guys, I've tried every hint, but seems I could not fold anymore. :(
Have you considered doing a fresh installation where you deleted the data files before installing it fresh?
ronnieross
Yes I've done a fresh installation after an uninstall with "purge" flag.
It didn't work but, some days later, folding is available again.
Is this because I have now only four cores running and gpu off? :shock:
Maddog
Post by Maddog »
ronnieross wrote:Yes I've done a fresh installation after an uninstall with "purge" flag.
Hello, glad You are folding again. If You look at the thread linked further above You will see that the problem for most people was not the number of threads but a problem with that particular project and the Linux client. If you want to fold faster You can increase the number of threads manually in the configure tab of FAH Control.Just avoid prime numbers like 7, 11, 13 etc. Be aware though, any changes will not take effect until the current work unit finishes and a new one is downloaded.
Did You disable the GPU yourself or was it not recognised when you did the reinstall ? It may be possible to get your GPU working again (no guarantee though). See in the System information tab if it is listed and if it is, then try to add a GPU slot manually in the configure tab.
