Hi,
I uninstalled the FAHClient from my Win 10 PC per the Uninstall in the start menu. After that the HideControl.exe in the Windows Start-up list was not removed. It now only shows as 'Program'.
How do I remove that entry from the Start-up list?
Thanks,
fdm
FAHClient leaves start-up entry after uninstall
Re: FAHClient leaves start-up entry after uninstall
Welcome to the F@H Forum fdm,
That's weird but can you download the latest version (V7.6.21), install it using the default settings and then uninstall it with the option to delete the data. That would in theory remove all traces of the application.
