Failed to get ID from assign1.foldingathome.org:80
StephenF420
Post by StephenF420 »
I checked my firewall (pc and router), exceptions in MalwareBytes, exception in Pi-Hole, FAH works on mobile network, I can ping all the assign servers.
Something is blocking me from getting assignments and I can't figure out what.
*********************** Log Started 2020-11-25T14:46:41Z ***********************
14:46:41:******************************* libFAH ********************************
14:46:41:           Date: Oct 20 2020
14:46:41:           Time: 13:36:55
14:46:41:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:46:41:         Branch: master
14:46:41:       Compiler: Visual C++ 2015
14:46:41:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:46:41:       Platform: win32 10
14:46:41:           Bits: 32
14:46:41:           Mode: Release
14:46:41:****************************** FAHClient ******************************
14:46:41:        Version: 7.6.21
14:46:41:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:46:41:      Copyright: 2020 foldingathome.org
14:46:41:       Homepage: https://foldingathome.org/
14:46:41:           Time: 13:41:04
14:46:41:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:46:41:           Bits: 32
14:46:41:           Args: --open-web-control
14:46:41:******************************** CBang ********************************
14:46:41:           Time: 11:36:18
14:46:41:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:46:41:           Bits: 32
14:46:41:******************************* System ********************************
14:46:41:            CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
14:46:41:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
14:46:41:           CPUs: 16
14:46:41:         Memory: 31.94GiB
14:46:41:    Free Memory: 23.19GiB
14:46:41:        Threads: WINDOWS_THREADS
14:46:41:     OS Version: 6.2
14:46:41:    Has Battery: false
14:46:41:     On Battery: false
14:46:41:     UTC Offset: 1
14:46:41:            PID: 1148
14:46:41:            CWD: C:\ProgramData\FAHClient
14:46:41:  Win32 Service: false
14:46:41:             OS: Windows 10 Enterprise
14:46:41:        OS Arch: AMD64
14:46:41:           GPUs: 1
14:46:41:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:1
14:46:41:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.1
14:46:41:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:457.30
14:46:41:***********************************************************************
14:46:41:<config>
14:46:41:  <!-- Folding Slots -->
14:46:41:</config>
14:46:41:Trying to access database...
14:46:41:Successfully acquired database lock
14:46:41:FS00:Initialized folding slot 00: cpu:14
14:46:41:WARNING:FS01:Disabling beta GPU slot 01: gpu:1:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
14:46:42:3:127.0.0.1:New Web session
14:47:14:Set client configured
14:47:14:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:47:15:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:47:15:WU00:FS00:Connecting to assign2.foldingathome.org:80
14:47:15:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:47:15:WU00:FS00:Connecting to assign3.foldingathome.org:80
14:47:15:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:47:15:WU00:FS00:Connecting to assign4.foldingathome.org:80
14:47:15:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:47:15:ERROR:WU00:FS00:Exception: Could not get an assignment ID
14:47:15:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:47:16:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:47:16:WU00:FS00:Connecting to assign2.foldingathome.org:80
14:47:16:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:47:16:WU00:FS00:Connecting to assign3.foldingathome.org:80
14:47:16:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:47:16:WU00:FS00:Connecting to assign4.foldingathome.org:80
14:47:16:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:47:16:ERROR:WU00:FS00:Exception: Could not get an assignment ID
14:47:42:Saving configuration to config.xml
14:47:42:<config>
14:47:42:  <!-- Slot Control -->
14:47:42:  <power v='FULL'/>
14:47:42:
14:47:42:  <!-- User Information -->
14:47:42:  <passkey v='*****'/>
14:47:42:  <team v='223518'/>
14:47:42:  <user v='StephenF420'/>
14:47:42:
14:47:42:  <!-- Folding Slots -->
14:47:42:  <slot id='0' type='CPU'/>
14:47:42:  <slot id='1' type='GPU'>
14:47:42:    <pci-bus v='1'/>
14:47:42:    <pci-slot v='0'/>
14:47:42:  </slot>
14:47:42:</config>
14:48:16:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:48:16:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:48:16:WU00:FS00:Connecting to assign2.foldingathome.org:80
14:48:16:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:48:16:WU00:FS00:Connecting to assign3.foldingathome.org:80
14:48:16:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:48:16:WU00:FS00:Connecting to assign4.foldingathome.org:80
14:48:16:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
14:48:16:ERROR:WU00:FS00:Exception: Could not get an assignment ID
psaam0001
Re: Failed to get ID from assign1.foldingathome.org:80
Post by psaam0001 »
Could you post the output of the system information from the Folding At Home Advanced Control (FAHControl)? It will give us a little bit more information about the card you are using, so one of the more experienced members of the forum who has knowledge of these issues can help (should I not be able to).
Without having any more information to go on at this point of time, I am suspecting that we may need to take a peek at the GPUs.txt file once we have your GPU card related information, and see if one of the file maintainers needs to fix something on their end (so you get an updated copy that will not cause an error).
Paul
StephenF420
You mean this? I have a GTX1060 6GB by the way.
https://prnt.sc/vqlgs6
Post by Neil-B »
to me that looks like a dns/proxy/firewall error rather than anything in the gpus.txt - https errors tend to indicate that?
psaam0001
Post by psaam0001 »
:::: Admitting that it is time for letting someone who can provide better help w/resolving this take over. ::::
Paul
Post by Neil-B »
Here is a thread from someone who had a similar (same ?) issue https://foldingforum.org/viewtopic.php?f=18&t=32956 where the final post might explain why you can ping but the FAHClient can't get through ... I'll trawl the forums for other threads where people have worked through this issue sucessfully and post links into this post in case any help.
https://foldingforum.org/viewtopic.php?f=61&t=29150
You may have more than one problem, but I can clearly see one. It says you GPU is identified as NVIDIA:1. That means the client believes the GPU is unsupported or the drivers are not configured correctly.
At the very beginning of FAH's log (well, really a couple hundred lines from the beginning), the client starts by configuring the hardware it finds. It should look something like this.
03:20:51: CWD: (whatever)
03:20:51: OS: (whatever)
03:20:51: OS Arch: AMD64
03:20:51: GPUs: 1
03:20:51: GPU 0: Bus:103 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64] (or whatever)
A lot if that kind of information is repeated each time a FAHCore starts, but those are incomplete.
In the one shown above:
14:46:41: GPUs: 1
You'll notice that the GPU is identified as a NVIDIA:1 and it does not give it's name. I can't tell why.
the output from Linux lspci or from FAHClient --lspci in the console/command prompt showing GPU items would also be helpful
