Need more GPU Work Units.
LazyDev
Post by LazyDev »
Was wondering if an assignment server went down or something, because my GPU's are no getting new work units.
*********************** Log Started 2020-11-25T00:02:36Z ***********************
00:03:06:WARNING:WU04:FS10:WorkServer connection failed on port 8080 trying 80
00:03:06:WARNING:WU00:FS07:WorkServer connection failed on port 8080 trying 80
00:03:06:WARNING:WU03:FS09:WorkServer connection failed on port 8080 trying 80
00:03:22:ERROR:WU01:FS08:Exception: 10002: Received short response, expected 512 bytes, got 0
00:03:27:ERROR:WU04:FS10:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:03:27:ERROR:WU00:FS07:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:03:27:ERROR:WU03:FS09:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:03:49:WARNING:WU03:FS09:WorkServer connection failed on port 8080 trying 80
00:03:53:ERROR:WU01:FS08:Exception: 10002: Received short response, expected 512 bytes, got 0
00:04:01:ERROR:WU00:FS07:Exception: 10002: Received short response, expected 512 bytes, got 0
00:04:10:ERROR:WU03:FS09:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:04:13:ERROR:WU04:FS10:Exception: 10002: Received short response, expected 512 bytes, got 0
00:04:28:WARNING:WU00:FS07:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:04:28:WARNING:WU04:FS10:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:04:44:WARNING:WU01:FS08:WorkServer connection failed on port 8080 trying 80
00:04:49:WARNING:WU03:FS09:WorkServer connection failed on port 8080 trying 80
00:04:49:WARNING:WU00:FS07:WorkServer connection failed on port 8080 trying 80
00:04:50:WARNING:WU04:FS10:WorkServer connection failed on port 8080 trying 80
00:04:57:ERROR:WU00:FS07:Exception: 10002: Received short response, expected 512 bytes, got 0
00:05:09:ERROR:WU04:FS10:Exception: 10002: Received short response, expected 512 bytes, got 0
00:05:10:ERROR:WU03:FS09:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:05:17:ERROR:WU01:FS08:Exception: 10002: Received short response, expected 512 bytes, got 0
00:06:05:WARNING:WU04:FS10:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:06:21:WARNING:WU01:FS08:WorkServer connection failed on port 8080 trying 80
00:06:26:WARNING:WU03:FS09:WorkServer connection failed on port 8080 trying 80
00:06:27:WARNING:WU04:FS10:WorkServer connection failed on port 8080 trying 80
00:06:37:ERROR:WU04:FS10:Exception: 10002: Received short response, expected 512 bytes, got 0
00:06:42:ERROR:WU00:FS07:Exception: 10002: Received short response, expected 512 bytes, got 0
00:06:43:ERROR:WU01:FS08:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:06:47:ERROR:WU03:FS09:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:08:42:WARNING:WU03:FS09:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:08:42:WARNING:WU04:FS10:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:09:03:WARNING:WU00:FS07:WorkServer connection failed on port 8080 trying 80
00:09:04:WARNING:WU04:FS10:WorkServer connection failed on port 8080 trying 80
00:09:09:ERROR:WU01:FS08:Exception: 10002: Received short response, expected 512 bytes, got 0
00:09:25:ERROR:WU00:FS07:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:09:35:ERROR:WU04:FS10:Exception: 10002: Received short response, expected 512 bytes, got 0
00:12:56:WARNING:WU00:FS07:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:12:57:WARNING:WU04:FS10:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:13:13:WARNING:WU01:FS08:WorkServer connection failed on port 8080 trying 80
00:13:18:WARNING:WU04:FS10:WorkServer connection failed on port 8080 trying 80
00:13:28:ERROR:WU00:FS07:Exception: 10002: Received short response, expected 512 bytes, got 0
00:13:34:ERROR:WU01:FS08:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:13:47:ERROR:WU04:FS10:Exception: 10002: Received short response, expected 512 bytes, got 0
00:19:48:WARNING:WU00:FS07:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:19:48:WARNING:WU04:FS10:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:20:04:WARNING:WU01:FS08:WorkServer connection failed on port 8080 trying 80
00:20:09:WARNING:WU00:FS07:WorkServer connection failed on port 8080 trying 80
00:20:10:WARNING:WU04:FS10:WorkServer connection failed on port 8080 trying 80
00:20:31:ERROR:WU00:FS07:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:20:31:ERROR:WU04:FS10:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:20:37:ERROR:WU01:FS08:Exception: 10002: Received short response, expected 512 bytes, got 0
00:30:48:WARNING:WU01:FS08:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:30:54:WARNING:WU04:FS10:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:31:10:WARNING:WU01:FS08:WorkServer connection failed on port 8080 trying 80
00:31:13:ERROR:WU04:FS10:Exception: 10002: Received short response, expected 512 bytes, got 0
00:31:25:ERROR:WU00:FS07:Exception: 10002: Received short response, expected 512 bytes, got 0
00:31:31:ERROR:WU01:FS08:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:32:26:ERROR:WU04:FS10:Exception: 10002: Received short response, expected 512 bytes, got 0
00:32:47:WARNING:WU00:FS07:WorkServer connection failed on port 8080 trying 80
00:32:57:ERROR:WU01:FS08:Exception: 10002: Received short response, expected 512 bytes, got 0
00:33:19:ERROR:WU00:FS07:Exception: 10002: Received short response, expected 512 bytes, got 0
00:34:02:ERROR:WU04:FS10:Exception: 10002: Received short response, expected 512 bytes, got 0
00:34:03:WARNING:WU00:FS07:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:34:04:WARNING:WU01:FS08:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:34:26:WARNING:WU01:FS08:WorkServer connection failed on port 8080 trying 80
00:34:35:ERROR:WU00:FS07:Exception: 10002: Received short response, expected 512 bytes, got 0
00:34:47:ERROR:WU01:FS08:Exception: Failed to connect to 129.213.157.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
https://prnt.sc/vph0zq
gs60
Re: Need more GPU Work Units.
Post by gs60 »
Yea, that server appears to have bit the dirt. Just quit and restart the application and it will usually switch servers. Just did that with mine and off and running again.
anandhanju
Post by anandhanju »
The researchers are aware of this and are enabling new GPU projects/ adding new simulations.
Two out my three GPU PCs were stuck, a reboot solved both.
psaam0001
Post by psaam0001 »
Sometimes a few mouse clicks to reboot the computer will work faster than throwing a temper tantrum.
Paul
gunnarre
Post by gunnarre »
Was that in response to a deleted post, Paul, because I don't see anyone acting that way in this thread.
psaam0001
Post by psaam0001 »
gunnarre wrote:Was that in response to a deleted post, Paul, because I don't see anyone acting that way in this thread.
No, I've gotten frustrated enough when important work on my system comes to a screeching halt, where I have lost my temper--and have started from scratch w/re-installing software.
Sorry for the confusion.... I just try to be more civilized here. Though it might be time for me to gently shut my systems off for a couple of hours (after completing the WU's in progress), and give them a little bit of preventative maintenance (in order to keep me from doing emergency maintenance).
Paul
I presume you know about the FINISH function (if you decide to shut down for a while).
psaam0001
Post by psaam0001 »
For sure... :)
I just need to put a new I/O shield to keep dust from entering my refurbished system (where the onboard video connector and USB ports are in the rear). 1-hr or less.
Oh, a quick peek inside my Dell to see if the CPU cooler needs dusting. I can't get another BTX style motherboard for it, so if it fries--that computer's done (salvage what I can).
Paul
