RX5700XT not folding (Linux)
DrCMac
Post by DrCMac »
Felt proud of myself for getting OpenCL working (symlink /opt/amdgpu-pro/lib64/libOpenCL.so to /opt/amdgpu-pro/lib64/libOpenCL.so.1)
Then spent a few days thinking that the fact I was seeing no activity from my GPU was due to the advertised lack of WUs (even though running folding on Windows found WUs easily)
Then tried deleting and adding back the GPU slot a couple of times. Checked that it is running FahCore_22. Watched the logfile for clues.
Then yesterday I saw a logfile that indicated that the GPU had successfully downloaded a WU. But still it sits idle.
I have folding power set to Full
I'm stumped.
Here's the logfile : as usual it doesn't even seem to have requested a WU for the GPU. The last thing for the GPU slot is, as always "18:50:51:WU01:FS01:0x22: Configuring platform OpenCL"
and there it sits.
Thanks for any sugestions.
*********************** Log Started 2020-11-22T18:50:46Z ***********************
18:50:46:******************************* libFAH ********************************
18:50:46:           Date: Oct 20 2020
18:50:46:           Time: 20:36:41
18:50:46:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
18:50:46:         Branch: master
18:50:46:       Compiler: GNU 4.9.4
18:50:46:        Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections
18:50:46:                 -O3 -funroll-loops
18:50:46:       Platform: linux2 5.8.0-1-amd64
18:50:46:           Bits: 64
18:50:46:           Mode: Release
18:50:46:****************************** FAHClient ******************************
18:50:46:        Version: 7.6.21
18:50:46:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:50:46:      Copyright: 2020 foldingathome.org
18:50:46:       Homepage: https://foldingathome.org/
18:50:46:           Time: 20:38:59
18:50:46:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
18:50:46:           Bits: 64
18:50:46:           Args: --child /etc/fahclient/config.xml --run-as fahclient
18:50:46:                 --pid-file=/var/run/fahclient.pid --daemon
18:50:46:         Config: /etc/fahclient/config.xml
18:50:46:******************************** CBang ********************************
18:50:46:           Time: 18:38:01
18:50:46:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
18:50:46:                 -O3 -funroll-loops -fPIC
18:50:46:           Bits: 64
18:50:46:******************************* System ********************************
18:50:46:            CPU: AMD Ryzen 9 3900X 12-Core Processor
18:50:46:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:50:46:           CPUs: 24
18:50:46:         Memory: 15.52GiB
18:50:46:    Free Memory: 1.33GiB
18:50:46:        Threads: POSIX_THREADS
18:50:46:     OS Version: 5.9
18:50:46:    Has Battery: false
18:50:46:     On Battery: false
18:50:46:     UTC Offset: 0
18:50:46:            PID: 30228
18:50:46:            CWD: /var/lib/fahclient
18:50:46:             OS: Linux 5.9.8-2-default x86_64
18:50:46:        OS Arch: AMD64
18:50:46:           GPUs: 1
18:50:46:          GPU 0: Bus:11 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT
18:50:46:                 / 5700/5700 XT]
18:50:46:           CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
18:50:46:                 libcuda.so: cannot open shared object file: No such file or
18:50:46:                 directory
18:50:46:OpenCL Device 0: Platform:0 Device:0 Bus:11 Slot:0 Compute:2.0 Driver:3180.7
18:50:46:***********************************************************************
18:50:46:<config>
18:50:46:  <!-- Network -->
18:50:46:  <proxy v=':8080'/>
18:50:46:
18:50:46:  <!-- Slot Control -->
18:50:46:  <power v='full'/>
18:50:46:
18:50:46:  <!-- User Information -->
18:50:46:  <passkey v='*****'/>
18:50:46:  <team v='244715'/>
18:50:46:  <user v='Charles_McEvoy'/>
18:50:46:
18:50:46:  <!-- Folding Slots -->
18:50:46:  <slot id='0' type='CPU'/>
18:50:46:  <slot id='1' type='GPU'>
18:50:46:    <pci-bus v='11'/>
18:50:46:    <pci-slot v='0'/>
18:50:46:  </slot>
18:50:46:</config>
18:50:46:Trying to access database...
18:50:46:Successfully acquired database lock
18:50:46:FS00:Initialized folding slot 00: cpu:23
18:50:46:FS01:Initialized folding slot 01: gpu:11:0 Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
18:50:46:WU01:FS01:Starting
18:50:46:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 30228 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
18:50:46:WU01:FS01:Started FahCore on PID 30237
18:50:46:WU01:FS01:Core PID:30241
18:50:46:WU01:FS01:FahCore 0x22 started
18:50:47:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:50:47:WU01:FS01:0x22:*********************** Log Started 2020-11-22T18:50:46Z ***********************
18:50:47:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:50:47:WU01:FS01:0x22:       Core: Core22
18:50:47:WU01:FS01:0x22:       Type: 0x22
18:50:47:WU01:FS01:0x22:    Version: 0.0.13
18:50:47:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:50:47:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
18:50:47:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
18:50:47:WU01:FS01:0x22:       Date: Sep 19 2020
18:50:47:WU01:FS01:0x22:       Time: 01:10:35
18:50:47:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
18:50:47:WU01:FS01:0x22:     Branch: core22-0.0.13
18:50:47:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
18:50:47:WU01:FS01:0x22:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
18:50:47:WU01:FS01:0x22:             -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
18:50:47:WU01:FS01:0x22:   Platform: linux2 4.19.76-linuxkit
18:50:47:WU01:FS01:0x22:       Bits: 64
18:50:47:WU01:FS01:0x22:       Mode: Release
18:50:47:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:50:47:WU01:FS01:0x22:             <peastman@stanford.edu>
18:50:47:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 30237 -checkpoint 15
18:50:47:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
18:50:47:WU01:FS01:0x22:             -gpu-usage 100
18:50:47:WU01:FS01:0x22:************************************ libFAH ************************************
18:50:47:WU01:FS01:0x22:       Date: Sep 15 2020
18:50:47:WU01:FS01:0x22:       Time: 05:14:43
18:50:47:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:50:47:WU01:FS01:0x22:     Branch: HEAD
18:50:47:WU01:FS01:0x22:************************************ CBang *************************************
18:50:47:WU01:FS01:0x22:       Time: 05:11:04
18:50:47:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:50:47:WU01:FS01:0x22:             -funroll-loops -fPIC
18:50:47:WU01:FS01:0x22:************************************ System ************************************
18:50:47:WU01:FS01:0x22:        CPU: AMD Ryzen 9 3900X 12-Core Processor
18:50:47:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:50:47:WU01:FS01:0x22:       CPUs: 24
18:50:47:WU01:FS01:0x22:     Memory: 15.52GiB
18:50:47:WU01:FS01:0x22:Free Memory: 1.30GiB
18:50:47:WU01:FS01:0x22:    Threads: POSIX_THREADS
18:50:47:WU01:FS01:0x22: OS Version: 5.9
18:50:47:WU01:FS01:0x22:Has Battery: false
18:50:47:WU01:FS01:0x22: On Battery: false
18:50:47:WU01:FS01:0x22: UTC Offset: 0
18:50:47:WU01:FS01:0x22:        PID: 30241
18:50:47:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
18:50:47:WU01:FS01:0x22:************************************ OpenMM ************************************
18:50:47:WU01:FS01:0x22:   Revision: 189320d0
18:50:47:WU01:FS01:0x22:********************************************************************************
18:50:47:WU01:FS01:0x22:Project: 13428 (Run 12325, Clone 22, Gen 0)
18:50:47:WU01:FS01:0x22:Unit: 0x0000000012bc7d9a0000000030250016
18:50:47:WU01:FS01:0x22:Digital signatures verified
18:50:47:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:50:47:WU01:FS01:0x22:Version 0.0.13
18:50:47:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
18:50:47:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
18:50:47:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
18:50:47:WU01:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
18:50:47:WU01:FS01:0x22:There are 3 platforms available.
18:50:47:WU01:FS01:0x22:Platform 0: Reference
18:50:47:WU01:FS01:0x22:Platform 1: CPU
18:50:47:WU01:FS01:0x22:Platform 2: OpenCL
18:50:47:WU01:FS01:0x22:  opencl-device 0 specified
18:50:47:WU00:FS00:Assigned to work server 128.252.203.1
18:50:47:WU00:FS00:Requesting new work unit for slot 00: cpu:23 from 128.252.203.1
18:50:47:WU00:FS00:Connecting to 128.252.203.1:8080
18:50:51:WU01:FS01:0x22:Attempting to create OpenCL context:
18:51:18:ERROR:WU00:FS00:Exception: Not connected
18:51:18:WU00:FS00:Connecting to assign1.foldingathome.org:80
18:51:19:WU00:FS00:Assigned to work server 129.213.40.229
18:51:19:WU00:FS00:Requesting new work unit for slot 00: cpu:23 from 129.213.40.229
18:51:19:WU00:FS00:Connecting to 129.213.40.229:8080
18:51:20:WU00:FS00:Downloading 6.53MiB
18:51:22:WU00:FS00:Download complete
18:51:22:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16925 run:9 clone:1939 gen:32 core:0xa7 unit:0x0000002781d528e50000000000090793
18:51:22:WU00:FS00:Starting
18:51:22:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 706 -lifeline 30228 -checkpoint 15 -np 23
18:51:22:WU00:FS00:Started FahCore on PID 31349
18:51:22:WU00:FS00:Core PID:31353
18:51:22:WU00:FS00:FahCore 0xa7 started
18:51:23:WU00:FS00:0xa7:*********************** Log Started 2020-11-22T18:51:22Z ***********************
18:51:23:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:51:23:WU00:FS00:0xa7:       Type: 0xa7
18:51:23:WU00:FS00:0xa7:       Core: Gromacs
18:51:23:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 31349 -checkpoint 15 -np
18:51:23:WU00:FS00:0xa7:             23
18:51:23:WU00:FS00:0xa7:************************************ CBang *************************************
18:51:23:WU00:FS00:0xa7:       Date: Nov 27 2019
18:51:23:WU00:FS00:0xa7:       Time: 11:26:54
18:51:23:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
18:51:23:WU00:FS00:0xa7:     Branch: master
18:51:23:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
18:51:23:WU00:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
18:51:23:WU00:FS00:0xa7:             -fno-pie -fPIC
18:51:23:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
18:51:23:WU00:FS00:0xa7:       Bits: 64
18:51:23:WU00:FS00:0xa7:       Mode: Release
18:51:23:WU00:FS00:0xa7:************************************ System ************************************
18:51:23:WU00:FS00:0xa7:        CPU: AMD Ryzen 9 3900X 12-Core Processor
18:51:23:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:51:23:WU00:FS00:0xa7:       CPUs: 24
18:51:23:WU00:FS00:0xa7:     Memory: 15.52GiB
18:51:23:WU00:FS00:0xa7:Free Memory: 688.58MiB
18:51:23:WU00:FS00:0xa7:    Threads: POSIX_THREADS
18:51:23:WU00:FS00:0xa7: OS Version: 5.9
18:51:23:WU00:FS00:0xa7:Has Battery: false
18:51:23:WU00:FS00:0xa7: On Battery: false
18:51:23:WU00:FS00:0xa7: UTC Offset: 0
18:51:23:WU00:FS00:0xa7:        PID: 31353
18:51:23:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
18:51:23:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:51:23:WU00:FS00:0xa7:    Version: 0.0.19
18:51:23:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:51:23:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:51:23:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
18:51:23:WU00:FS00:0xa7:       Date: Nov 26 2019
18:51:23:WU00:FS00:0xa7:       Time: 00:41:42
18:51:23:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
18:51:23:WU00:FS00:0xa7:************************************ Build *************************************
18:51:23:WU00:FS00:0xa7:       SIMD: avx_256
18:51:23:WU00:FS00:0xa7:********************************************************************************
18:51:23:WU00:FS00:0xa7:Project: 16925 (Run 9, Clone 1939, Gen 32)
18:51:23:WU00:FS00:0xa7:Unit: 0x0000002781d528e50000000000090793
18:51:23:WU00:FS00:0xa7:Reading tar file core.xml
18:51:23:WU00:FS00:0xa7:Reading tar file frame32.tpr
18:51:23:WU00:FS00:0xa7:Digital signatures verified
18:51:23:WU00:FS00:0xa7:Reducing thread count from 23 to 22 to avoid domain decomposition by a prime number > 3
18:51:23:WU00:FS00:0xa7:Reducing thread count from 22 to 21 to avoid domain decomposition with large prime factor 11
18:51:23:WU00:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -cpt 15 -nt 21
18:51:23:WU00:FS00:0xa7:Steps: first=16000000 total=500000
18:51:24:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
gunnarre
Re: RX5700XT not folding (Linux)
Post by gunnarre »
What does the clinfo command show?
DrCMac
Post by DrCMac »
  Platform Name                                   AMD Accelerated Parallel Processing
  Platform Vendor                                 Advanced Micro Devices, Inc.
  Platform Version                                OpenCL 2.1 AMD-APP (3180.7)
  Platform Extensions                             cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
  Platform Host timer resolution                  1ns
  Platform Extensions function suffix             AMD
  Device Name                                     gfx1010
  Device Vendor                                   Advanced Micro Devices, Inc.
  Device Version                                  OpenCL 2.0 AMD-APP (3180.7)
  Driver Version                                  3180.7 (PAL,LC)
  Device OpenCL C Version                         OpenCL C 2.0
  Device Board Name (AMD)                         AMD Radeon RX 5700 XT 50th Anniversary
  Device Topology (AMD)                           PCI-E, 0b:00.0
  Max compute units                               20
  SIMD per compute unit (AMD)                     4
  SIMD width (AMD)                                32
  SIMD instruction width (AMD)                    1
  Max clock frequency                             2100MHz
  Graphics IP (AMD)                               10.10
    Max number of sub-devices                     20
    Supported affinity domains                    (n/a)
  Max work item sizes                             1024x1024x1024
  Preferred work group size (AMD)                 256
  Max work group size (AMD)                       1024
  Preferred work group size multiple              32
  Wavefront width (AMD)                           32
    char                                                 4 / 4
    short                                                2 / 2
    half                                                 1 / 1        (cl_khr_fp16)
  Half-precision Floating-point support           (cl_khr_fp16)
    Denormals                                     No
    Infinity and NANs                             No
    Round to nearest                              No
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
  Global memory size                              8573157376 (7.984GiB)
  Global free memory (AMD)                        8306688 (7.922GiB)
  Global memory channels (AMD)                    8
  Global memory banks per channel (AMD)           4
  Global memory bank width (AMD)                  256 bytes
  Max memory allocation                           7059013632 (6.574GiB)
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   Yes
    Fine-grained system sharing                   No
    Atomics                                       No
  Alignment of base address                       2048 bits (256 bytes)
  Preferred alignment for atomics
    SVM                                           0 bytes
    Global                                        0 bytes
    Local                                         0 bytes
  Max size for global variable                    6353112064 (5.917GiB)
  Preferred total size of global vars             8573157376 (7.984GiB)
  Global Memory cache size                        16384 (16KiB)
  Global Memory cache line size                   64 bytes
    Max number of samplers per kernel             16
    Max size for 1D images from buffer            134217728 pixels
    Max 1D or 2D image array size                 2048 images
    Base address alignment for 2D image buffers   256 bytes
    Pitch alignment for 2D image buffers          256 pixels
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             2048x2048x2048 pixels
    Max number of read image args                 128
    Max number of write image args                64
    Max number of read/write image args           64
  Max number of pipe args                         16
  Max active pipe reservations                    16
  Max pipe packet size                            2764046336 (2.574GiB)
  Local memory size                               65536 (64KiB)
  Local memory syze per CU (AMD)                  65536 (64KiB)
  Local memory banks (AMD)                        32
  Max constant buffer size                        7059013632 (6.574GiB)
  Preferred constant buffer size (AMD)            16384 (16KiB)
  Queue properties (on host)
  Queue properties (on device)
    Out-of-order execution                        Yes
    Preferred size                                262144 (256KiB)
    Max size                                      8388608 (8MiB)
  Max queues on device                            1
  Max events on device                            1024
  Number of P2P devices (AMD)                     0
  P2P devices (AMD)                               <printDeviceInfo:147: get number of CL_DEVICE_P2P_DEVICES_AMD : error -30>
  Profiling timer offset since Epoch (AMD)        1606005730155549339ns (Sun Nov 22 00:42:10 2020)
  Execution capabilities
    Thread trace supported (AMD)                  Yes
    Number of async queues (AMD)                  4
    Max real-time compute queues (AMD)            1
    Max real-time compute units (AMD)             0
  printf() buffer size                            4194304 (4MiB)
  Built-in kernels                                (n/a)
  Device Extensions                               cl_khr_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_khr_gl_depth_images cl_amd_device_attribute_query cl_amd_media_ops cl_amd_media_ops2 cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_gl_event cl_khr_depth_images cl_khr_mipmap_image cl_khr_mipmap_image_writes cl_amd_copy_buffer_p2p
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  No platform
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   No platform
  clCreateContext(NULL, ...) [default]            No platform
  clCreateContext(NULL, ...) [other]              Success [AMD]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  Success (1)
    Device Name                                   gfx1010
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  Success (1)
    Device Name                                   gfx1010
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
    Device Name                                   gfx1010
psaam0001
Post by psaam0001 »
    Device Name                                   gfx1010
    Device Name                                   gfx1010
    Device Name                                   gfx1010
Would you mind telling me what distribution you are using (Fedora; CentOS; Debian; Ubuntu; other)? Please include version information where possible.
I am looking at your information, and am trying to see if there is a specific set of updated AMD drivers for your distribution, so we can start narrowing down possible solutions (between me, and the other more experienced folders with more technical knowledge).
From what I see, the OpenCL libraries are not loading [correctly]. Do not pay attention to the warning about the CUDA libraries not being detected--AMD cards/iGPU's don't support CUDA (that's an NVidia technology). Where did you obtain the OpenCL library files?
Paul
psaam0001
Post by psaam0001 »
Addendum:
Please see https://www.amd.com/en/support/kb/relea ... inux-20-45 for the most recent drivers (11/18/2020).
Paul
DrCMac
Post by DrCMac »
Thanks! I'm using OpenSuse Tumbleweed fully updated
I though I had won when I stopped seeing "OpenCL not found" errors in the log - obviously not!
I'm using amdgpu-pro-20.40 and the latest is 20.45 so I'll update that and let you know.
psaam0001
Post by psaam0001 »
Try getting that OpenCL library package from here: https://software.opensuse.org/package/ocl-icd
Paul
Post by Neil-B »
in the past loading the opencl dev drivers has helped - https://foldingforum.org/viewtopic.php? ... ev#p345235
psaam0001
Post by psaam0001 »
If you know the command for installing them from OpenSUSE's command line, that might help. As I think the one shown in the post you link to is for Debian.
Paul
Post by Neil-B »
I posted link simply to save time as to the driver name (originally just typed dev drivers) ... with linux I have to leave it up to folders to work out their own way of finding installing such for their distro as there are too many damn options for a poor windows guy like me to keep track of :)
psaam0001
Post by psaam0001 »
I know.... What works in Fedora, may not in OpenSuse.
There comes a point where Duck Duck Go (the search engine) becomes one of your best tools.
Paul
Post by Neil-B »
yup ... or google/bing/etc. ... the important bit was to get (however one does) the ocl-icd-opencl-dev drivers and install them (by whatever method one does with fedora) ... I have no clue if the following is the right stuff for the linux version in use but it was what I quickly found with google ... https://pkgs.org/download/ocl-icd-devel-64bit ... hope this helps the op - might not be the solution anyways - but the presence of those dev drivers have solved many Opencl issues for others
What can further complicate matters is that the most recent build of Core_22 for GPU folding is distributed with the necessary OpenCL runtime code. That can sometimes conflict with the dev kit code if the versions don't match and the dev kit is installed. They are looking into the problem and a future revision of the core may include a fix.
In theory the dev kit should not be needed at all. But with the proliferation of distros of linux, various levels of updates, and so on means that sometimes installing the kit fixes up something, and other times does not work.
psaam0001
Post by psaam0001 »
On this thread, I have tried.... But as we can agree to, we (as folder's) are the ones who need to be knowledgeable enough to ask the right questions, from the right sources, in order to get the right answers.
Paul
Post by Neil-B »
Paul ... your efforts and thoughts are very much appreciated - I recall a good few "catches" from yourself that have helped folders ... my "knowledge" of linux is laughable tbh - I just have far too much free time and read pretty much every post made to the forums ... if I spot patterns I mention them - they may not be the correct solution but sometimes if I am lucky they help people get to solutions ... and hopefully I dont send people off in the wrong direction too often !! ... I hope none of my posts came across in any way as dismissive or anything else negative as they really weren't intended to - I am maybe a big tired and didn't post quite as thoughtfully as I might have ... Sorry ... Neil
