[tuto],openSuse leap >= 15.2, fah >= 7.6.21
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
promeneur
Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
Post by promeneur »
A great news for openSuse users
there is now openSuse packages from community user "Curiosity"
add the repo containing the packages
sudo zypper addrepo https://download.opensuse.org/repositories/home:Curiosity/openSUSE_Leap_$releasever/home:Curiosity.repo
sudo zypper refresh
then install the packages
sudo zypper install fetch-fahclient
sudo zypper install python-fahcontrol
sudo zypper install fetch-fahviewer
No more problem about zip2 not installed.
No more necessity to create a systemd service for FAH.
No more compliancy problem with libopenssl openSuse package.
then
start fahclient
[code]
sudo systemctl daemon-reload
sudo systemctl start fahclient.service
[/code]
Complete fahclient settings via fahcontrol settings with your "name ", team number (if you are a member of one) and your "passkey".
then
you must ask system to start FAH at PC startup. For this use the tool "services manager" in yast. Choose "at system startup" for fahclient.
WARNING
if you previously installed folding@home with rpms from folding@home and with my tuto about openSuse Leap 15.1 or older
then
before installing rpms with rpms from openSuse
in /etc/systemd/system/
delete fahclient.service file
in /usr/local/bin/
delete FAHClient file
promeneur
Re: [tuto],openSuse leap 15.2, fah >= 7.6.21
Post by promeneur »
some problems may occurs:
- cpu too hot
- fah does not decrease its cpu power consumption when you launch an app.
- setting "folding power"to "light" or "medium" does not work
in this case see my solution
viewtopic.php?f=89&t=31637#p307170
or the one of Bruce
viewtopic.php?f=89&t=31637#p307174
promeneur
Post by promeneur »
I tested Bruce's solution.
The CPU of my PC gets 4 cores.
FAH settings : Power "full" when i am "working"
Result:
- my solution "cpulimit --exe FahCore_a8 --limit 50" : about 32 °C
- Bruce's solution "only one core for folding" : about 42 °C
My solution is complex.
Bruce's solution is easy.
Post by Neil-B »
One wonders what you might class a "cpu too hot" as both of the figures you quote achieved are barely luke warm - there might be a little thermal headroom for more folding? :)
promeneur
Post by promeneur »
@Neil-b
I forgot I want a silent PC thus I want to minimize fan noise. I can reach this with cpulimit.
Post by Neil-B »
That would explain the temperature choice :)
promeneur
Re: [tuto],openSuse , Tumbleweed, fah = 7.6.21
Post by promeneur »
