missing credit server 128.252.203.1
goodyca
Post by goodyca »
The following WU's were successfully uploaded to the subject server, but no credit was issued. I have checked the WU Status of each at https://apps.foldingathome.org/wu, and they are all show as "Not found."
Completion Time and Project Description
11/12/20 07:04 PM Project: 16453 (Run 104 , Clone 4 , Gen 171)
11/12/20 09:18 PM Project: 16453 (Run 116 , Clone 4 , Gen 156)
11/13/20 02:44 AM Project: 16455 (Run 0 , Clone 108 , Gen 172)
11/13/20 03:03 AM Project: 16455 (Run 0 , Clone 499 , Gen 136)
Here is an example log file for one of the WU's
02:24:52:WU01:FS01:Connecting to assign1.foldingathome.org:80
02:24:53:WU01:FS01:Assigned to work server 128.252.203.1
02:24:53:WU01:FS01:Requesting new work unit for slot 01: READY cpu:7 from 128.252.203.1
02:24:53:WU01:FS01:Connecting to 128.252.203.1:8080
02:24:54:WU01:FS01:Downloading 1.35MiB
02:24:54:WU01:FS01:Download complete
02:24:54:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16455 run:0 clone:499 gen:136 core:0xa7 unit:0x0000009480fccb015f7215ad385f0e0c
02:24:55:WU01:FS01:Starting
02:24:55:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 706 -lifeline 1567 -checkpoint 15 -np 7
02:24:55:WU01:FS01:Started FahCore on PID 291351
02:24:55:WU01:FS01:Core PID:291355
02:24:55:WU01:FS01:FahCore 0xa7 started
02:24:55:WU01:FS01:0xa7:*********************** Log Started 2020-11-13T02:24:55Z ***********************
02:24:55:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
02:24:55:WU01:FS01:0xa7:       Type: 0xa7
02:24:55:WU01:FS01:0xa7:       Core: Gromacs
02:24:55:WU01:FS01:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 291351 -checkpoint 15 -np
02:24:55:WU01:FS01:0xa7:             7
02:24:55:WU01:FS01:0xa7:************************************ CBang *************************************
02:24:55:WU01:FS01:0xa7:       Date: Nov 27 2019
02:24:55:WU01:FS01:0xa7:       Time: 11:26:54
02:24:55:WU01:FS01:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
02:24:55:WU01:FS01:0xa7:     Branch: master
02:24:55:WU01:FS01:0xa7:   Compiler: GNU 8.3.0
02:24:55:WU01:FS01:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
02:24:55:WU01:FS01:0xa7:             -fno-pie -fPIC
02:24:55:WU01:FS01:0xa7:   Platform: linux2 4.19.0-5-amd64
02:24:55:WU01:FS01:0xa7:       Bits: 64
02:24:55:WU01:FS01:0xa7:       Mode: Release
02:24:55:WU01:FS01:0xa7:************************************ System ************************************
02:24:55:WU01:FS01:0xa7:        CPU: Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz
02:24:55:WU01:FS01:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
02:24:55:WU01:FS01:0xa7:       CPUs: 8
02:24:55:WU01:FS01:0xa7:     Memory: 15.55GiB
02:24:55:WU01:FS01:0xa7:Free Memory: 5.27GiB
02:24:55:WU01:FS01:0xa7:    Threads: POSIX_THREADS
02:24:55:WU01:FS01:0xa7: OS Version: 5.8
02:24:55:WU01:FS01:0xa7:Has Battery: false
02:24:55:WU01:FS01:0xa7: On Battery: false
02:24:55:WU01:FS01:0xa7: UTC Offset: -6
02:24:55:WU01:FS01:0xa7:        PID: 291355
02:24:55:WU01:FS01:0xa7:        CWD: /var/lib/fahclient/work
02:24:55:WU01:FS01:0xa7:******************************** Build - libFAH ********************************
02:24:55:WU01:FS01:0xa7:    Version: 0.0.19
02:24:55:WU01:FS01:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:24:55:WU01:FS01:0xa7:  Copyright: 2019 foldingathome.org
02:24:55:WU01:FS01:0xa7:   Homepage: https://foldingathome.org/
02:24:55:WU01:FS01:0xa7:       Date: Nov 26 2019
02:24:55:WU01:FS01:0xa7:       Time: 00:41:42
02:24:55:WU01:FS01:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
02:24:55:WU01:FS01:0xa7:************************************ Build *************************************
02:24:55:WU01:FS01:0xa7:       SIMD: avx_256
02:24:55:WU01:FS01:0xa7:********************************************************************************
02:24:55:WU01:FS01:0xa7:Project: 16455 (Run 0, Clone 499, Gen 136)
02:24:55:WU01:FS01:0xa7:Unit: 0x0000009480fccb015f7215ad385f0e0c
02:24:55:WU01:FS01:0xa7:Reading tar file core.xml
02:24:55:WU01:FS01:0xa7:Reading tar file frame136.tpr
02:24:55:WU01:FS01:0xa7:Digital signatures verified
02:24:55:WU01:FS01:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
02:24:55:WU01:FS01:0xa7:Calling: mdrun -s frame136.tpr -o frame136.trr -x frame136.xtc -cpt 15 -nt 6
02:24:55:WU01:FS01:0xa7:Steps: first=34000000 total=250000
02:24:56:WU01:FS01:0xa7:Completed 1 out of 250000 steps (0%)
02:25:19:WU01:FS01:0xa7:Completed 2500 out of 250000 steps (1%)
02:25:42:WU01:FS01:0xa7:Completed 5000 out of 250000 steps (2%)
02:26:05:WU01:FS01:0xa7:Completed 7500 out of 250000 steps (3%)
03:01:57:WU01:FS01:0xa7:Completed 242500 out of 250000 steps (97%)
03:02:21:WU01:FS01:0xa7:Completed 245000 out of 250000 steps (98%)
03:02:44:WU01:FS01:0xa7:Completed 247500 out of 250000 steps (99%)
03:03:07:WU01:FS01:0xa7:Completed 250000 out of 250000 steps (100%)
03:03:07:WU01:FS01:0xa7:Saving result file ../logfile_01.txt
03:03:07:WU01:FS01:0xa7:Saving result file frame136.trr
03:03:07:WU01:FS01:0xa7:Saving result file frame136.xtc
03:03:07:WU01:FS01:0xa7:Saving result file md.log
03:03:07:WU01:FS01:0xa7:Saving result file science.log
03:03:07:WU01:FS01:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
03:03:08:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:03:08:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16455 run:0 clone:499 gen:136 core:0xa7 unit:0x0000009480fccb015f7215ad385f0e0c
03:03:08:WU01:FS01:Uploading 1.15MiB to 128.252.203.1
03:03:08:WU01:FS01:Connecting to 128.252.203.1:8080
03:03:11:WU01:FS01:Upload complete
03:03:12:WU01:FS01:Server responded WORK_ACK (400)
03:03:12:WU01:FS01:Final credit estimate, 2444.00 points
03:03:12:WU01:FS01:Cleaning up
Re: missing credit server 128.252.203.1
Thanks for the report. The correct people have been notified and are working to identify the issue and resolve it. Historically speaking, as long as the completed WU is successfully uploaded to the Server, you will be assigned points. Let's wait and see what happens here :)
Chris_TG
Post by Chris_TG »
The same here. I have not gotten any credits since two weeks now.
Frogging101
Post by Frogging101 »
I've also observed WUs uploaded to this server not being recorded. The following WUs were all uploaded to this server and none of them show up on the WU status page presently:
2020-11-18T15:37:44Z: project:16454 run:5 clone:4 gen:125
2020-11-19T05:42:17Z: project:16455 run:0 clone:1446 gen:202
2020-11-21T02:03:02Z: project:16456 run:108 clone:5 gen:3
2020-11-23T04:44:15Z: project:16455 run:0 clone:649 gen:250
2020-11-23T20:14:46Z: project:16457 run:177 clone:4 gen:17
2020-11-24T18:55:17Z: project:16455 run:0 clone:1367 gen:255
2020-11-25T16:50:07Z: project:16457 run:150 clone:0 gen:50
The server's owner has been notified. I predict they'll all show up but probably not today as it's a holiday in the UsA and a lot of folks are home with their family.
Frogging101
Mine have shown up. Thanks.
