FAH won't launch with graphics card (again!)
iokeith
Post by iokeith »
I have a PC which operates FAH correctly but when a GT 1030 card is installed FAH fails to launch.
The same problem occurred with a similar PC which was cured by replacing the latest driver 45.709 with the Windows default driver 43.200. https://foldingforum.org/viewtopic.php?f=80&t=36324
So I installed 43.200 as before, but in this case, it didn’t work. Nor with the latest driver.
Somehow I got it folding with the driver 43.200 and with the graphics card in (pausing, restarting, pausing) but the GPU slot was disabled. The system info said:
GPUs 1
GPU 0 Bus: 1 Slot: 0 Func: 0 NVIDIA: 5 GP108 [GeForce GT 1030] 1127
CUDA Not detected: Failed to open dynamic library 'nvcuda.dll': the specified module could not be found
OpenCL Not detected: Failed to open dynamic library OpenCL.dll': the specified module could not be found
log:
*********************** Log Started 2020-11-11T22:27:38Z ***********************
22:27:38:******************************* libFAH ********************************
22:27:38:         Date: Oct 20 2020
22:27:38:         Time: 13:36:55
22:27:38:     Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
22:27:38:       Branch: master
22:27:38:     Compiler: Visual C++ 2015
22:27:38:      Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:27:38:     Platform: win32 10
22:27:38:         Bits: 32
22:27:38:         Mode: Release
22:27:38:****************************** FAHClient ******************************
22:27:38:      Version: 7.6.21
22:27:38:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:27:38:    Copyright: 2020 foldingathome.org
22:27:38:     Homepage: https://foldingathome.org/
22:27:38:         Time: 13:41:04
22:27:38:     Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
22:27:38:         Bits: 32
22:27:38:       Config: C:\ProgramData\FAHClient\config.xml
22:27:38:******************************** CBang ********************************
22:27:38:         Time: 11:36:18
22:27:38:     Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
22:27:38:         Bits: 32
22:27:38:******************************* System ********************************
22:27:38:          CPU: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
22:27:38:       CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:27:38:         CPUs: 6
22:27:38:       Memory: 3.93GiB
22:27:38:  Free Memory: 2.01GiB
22:27:38:      Threads: WINDOWS_THREADS
22:27:38:   OS Version: 6.2
22:27:38:  Has Battery: false
22:27:38:   On Battery: false
22:27:38:   UTC Offset: 0
22:27:38:          PID: 1296
22:27:38:          CWD: C:\ProgramData\FAHClient
22:27:38:Win32 Service: false
22:27:38:           OS: Windows 10 Home
22:27:38:      OS Arch: AMD64
22:27:38:         GPUs: 1
22:27:38:        GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP108 [GeForce GT 1030] 1127
22:27:38:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:27:38:               specified module could not be found.
22:27:38:
22:27:38:       OpenCL: Not detected: Failed to open dynamic library 'OpenCL.dll': The
22:27:38:
22:27:38:***********************************************************************
22:27:39:<config>
22:27:39:  <!-- Network -->
22:27:39:  <proxy v=':8080'/>
22:27:39:
22:27:39:  <!-- Slot Control -->
22:27:39:  <power v='full'/>
22:27:39:
22:27:39:  <!-- User Information -->
22:27:39:  <passkey v='*****'/>
22:27:39:  <user v='iokeith'/>
22:27:39:
22:27:39:  <!-- Folding Slots -->
22:27:39:  <slot id='0' type='CPU'>
22:27:39:    <paused v='true'/>
22:27:39:  </slot>
22:27:39:</config>
22:27:39:Trying to access database...
22:27:39:Successfully acquired database lock
22:27:39:FS00:Initialized folding slot 00: cpu:5
22:27:39:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:1:0 GP108 [GeForce GT 1030] 1127.  Disabling.
22:27:51:FS01:Paused
22:28:40:Saving configuration to config.xml
22:28:40:<config>
22:28:40:  <!-- Network -->
22:28:40:  <proxy v=':8080'/>
22:28:40:
22:28:40:  <!-- Slot Control -->
22:28:40:  <power v='full'/>
22:28:40:
22:28:40:  <!-- User Information -->
22:28:40:  <passkey v='*****'/>
22:28:40:  <user v='iokeith'/>
22:28:40:
22:28:40:  <!-- Folding Slots -->
22:28:40:  <slot id='0' type='CPU'>
22:28:40:    <paused v='true'/>
22:28:40:  </slot>
22:28:40:  <slot id='1' type='GPU'>
22:28:40:    <pci-bus v='1'/>
22:28:40:    <pci-slot v='0'/>
22:28:40:  </slot>
22:28:40:</config>
Installed 32.400
22:33:27:FS00:Unpaused
22:33:27:FS01:Unpaused
22:33:27:WU00:FS00:Starting
22:33:27:WARNING:WU00:FS00:Changed SMP threads from 6 to 5 this can cause some work units to fail
22:33:27:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 1296 -checkpoint 15 -np 5
22:33:27:WU00:FS00:Started FahCore on PID 10188
22:33:27:WU00:FS00:Core PID:10204
22:33:27:WU00:FS00:FahCore 0xa7 started
22:33:30:WU00:FS00:0xa7:*********************** Log Started 2020-11-11T22:33:30Z ***********************
22:33:30:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:33:30:WU00:FS00:0xa7:       Type: 0xa7
22:33:30:WU00:FS00:0xa7:       Core: Gromacs
22:33:30:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10188 -checkpoint 15 -np
22:33:30:WU00:FS00:0xa7:             5
22:33:30:WU00:FS00:0xa7:************************************ CBang *************************************
22:33:30:WU00:FS00:0xa7:       Date: Nov 27 2019
22:33:30:WU00:FS00:0xa7:       Time: 03:40:09
22:33:30:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:33:30:WU00:FS00:0xa7:     Branch: master
22:33:30:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:33:30:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:33:30:WU00:FS00:0xa7:   Platform: win32 10
22:33:30:WU00:FS00:0xa7:       Bits: 64
22:33:30:WU00:FS00:0xa7:       Mode: Release
22:33:30:WU00:FS00:0xa7:************************************ System ************************************
22:33:30:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
22:33:30:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:33:30:WU00:FS00:0xa7:       CPUs: 6
22:33:30:WU00:FS00:0xa7:     Memory: 3.93GiB
22:33:30:WU00:FS00:0xa7:Free Memory: 1.67GiB
22:33:30:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:33:30:WU00:FS00:0xa7: OS Version: 6.2
22:33:30:WU00:FS00:0xa7:Has Battery: false
22:33:30:WU00:FS00:0xa7: On Battery: false
22:33:30:WU00:FS00:0xa7: UTC Offset: 0
22:33:30:WU00:FS00:0xa7:        PID: 10204
22:33:30:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
22:33:30:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:33:30:WU00:FS00:0xa7:    Version: 0.0.19
22:33:30:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:33:30:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:33:30:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:33:30:WU00:FS00:0xa7:       Date: Nov 25 2019
22:33:30:WU00:FS00:0xa7:       Time: 17:12:41
22:33:30:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:33:30:WU00:FS00:0xa7:************************************ Build *************************************
22:33:30:WU00:FS00:0xa7:       SIMD: avx_256
22:33:30:WU00:FS00:0xa7:********************************************************************************
22:33:30:WU00:FS00:0xa7:Project: 16925 (Run 36, Clone 257, Gen 19)
22:33:30:WU00:FS00:0xa7:Unit: 0x0000001681d528e50000000000240101
22:33:30:WU00:FS00:0xa7:Digital signatures verified
22:33:30:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
22:33:30:WU00:FS00:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -cpi state.cpt -cpt 15 -nt 4
22:33:30:WU00:FS00:0xa7:Steps: first=9500000 total=500000
22:33:32:WU00:FS00:0xa7:Completed 279502 out of 500000 steps (55%)
22:33:45:Saving configuration to config.xml
22:33:45:<config>
22:33:45:  <!-- Network -->
22:33:45:  <proxy v=':8080'/>
22:33:45:
22:33:45:  <!-- Slot Control -->
22:33:45:  <power v='full'/>
22:33:45:
22:33:45:  <!-- User Information -->
22:33:45:  <passkey v='*****'/>
22:33:45:  <user v='iokeith'/>
22:33:45:
22:33:45:  <!-- Folding Slots -->
22:33:45:  <slot id='0' type='CPU'/>
22:33:45:  <slot id='1' type='GPU'>
22:33:45:    <pci-bus v='1'/>
22:33:45:    <pci-slot v='0'/>
22:33:45:  </slot>
22:33:45:</config>
22:34:02:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
In TechPower GPU-Z OpenCL was ticked but CUDA was unticked. Files OpenCL.dll 2.2.1.0 and nvcuda.dll 26.21.14.3200 were present in both System32 and sysWOW64 directories.
I tried looking at the registry of the non-working machine. In comparison to the working machine, this had an additional HKEY Local Machine\Software\Khronos\OpenCL\Vendors entry with a File Repository address to the Intel UHD Graphics 630 folder with a DWORD value of 0. This was also present in the HKEY Local Machine\Software\WOW6432Node\Khronos\OpenCL\Vendors entry. This seemed a bit odd but no idea if this is important.
Any suggestions please? Thanks
Re: FAH won't launch with graphics card (again!)
If GPU-Z can't detect CUDA, then it's a driver/OS level issue which means that F@H will not be able to use the GPU.
Given that you experimented with various drivers, it could have caused a corruption so use DDU (https://www.guru3d.com/files-details/di ... nload.html) and then install the "usable" drivers and see what happens.
Knish
Post by Knish »
it was windows patch Tuesday recently... so chances r high u need to reinstall nvidia's driver all over again
ajm
Post by ajm »
I installed the latest Windows updates yesterday on all machines. I paused and shut down one of them, installed my 1030 in this machine and booted it:
*********************** Log Started 2020-11-12T08:48:37Z ***********************
08:48:37:Trying to access database...
08:48:37:Successfully acquired database lock
08:48:37:Read GPUs.txt
08:48:37:Enabled folding slot 00: PAUSED cpu:16 (by user)
08:48:38:Enabled folding slot 01: PAUSED gpu:0:GP108 [GeForce GT 1030] 1127 (by user)
08:48:38:WARNING:WU00:No longer matches Slot 1's configuration and there are no other matching slots, dumping
08:48:38:****************************** FAHClient ******************************
08:48:38:        Version: 7.6.13
08:48:38:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:48:38:      Copyright: 2020 foldingathome.org
08:48:38:       Homepage: https://foldingathome.org/
08:48:38:           Date: Apr 27 2020
08:48:38:           Time: 21:21:01
08:48:38:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
08:48:38:         Branch: master
08:48:38:       Compiler: Visual C++ 2008
08:48:38:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:48:38:       Platform: win32 10
08:48:38:           Bits: 32
08:48:38:           Mode: Release
08:48:38:         Config: C:\Users\ajmch\AppData\Roaming\FAHClient\config.xml
08:48:38:******************************** CBang ********************************
08:48:38:           Date: Apr 24 2020
08:48:38:           Time: 17:07:55
08:48:38:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
08:48:38:           Bits: 32
08:48:38:******************************* System ********************************
08:48:38:            CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
08:48:38:         CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
08:48:38:           CPUs: 20
08:48:38:         Memory: 63.69GiB
08:48:38:    Free Memory: 59.94GiB
08:48:38:        Threads: WINDOWS_THREADS
08:48:38:     OS Version: 6.2
08:48:38:    Has Battery: false
08:48:38:     On Battery: false
08:48:38:     UTC Offset: 1
08:48:38:            PID: 15224
08:48:38:            CWD: C:\Users\ajmch\AppData\Roaming\FAHClient
08:48:38:  Win32 Service: false
08:48:38:             OS: Windows 10 Enterprise
08:48:38:        OS Arch: AMD64
08:48:38:           GPUs: 2
08:48:38:          GPU 0: Bus:23 Slot:0 Func:0 NVIDIA:5 GP108 [GeForce GT 1030] 1127
08:48:38:          GPU 1: Bus:101 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2080 SUPER]
08:48:38:  CUDA Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:7.5 Driver:10.1
08:48:38:  CUDA Device 1: Platform:0 Device:1 Bus:23 Slot:0 Compute:6.1 Driver:10.1
08:48:38:OpenCL Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:1.2 Driver:432.0
08:48:38:OpenCL Device 1: Platform:0 Device:1 Bus:23 Slot:0 Compute:1.2 Driver:432.0
08:48:38:******************************* libFAH ********************************
08:48:38:           Date: Apr 15 2020
08:48:38:           Time: 14:53:14
08:48:38:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
08:48:38:           Bits: 32
08:48:38:***********************************************************************
08:48:38:<config>
08:48:38:  <!-- HTTP Server -->
08:48:38:  <allow v='127.0.0.1 192.168.1.127'/>
08:48:38:
08:48:38:  <!-- Network -->
08:48:38:  <proxy v=':8080'/>
08:48:38:
08:48:38:  <!-- Remote Command Server -->
08:48:38:  <command-allow-no-pass v='127.0.0.1 192.168.1.127'/>
08:48:38:
08:48:38:  <!-- Slot Control -->
08:48:38:  <power v='full'/>
08:48:38:
08:48:38:  <!-- User Information -->
08:48:38:  <passkey v='*****'/>
08:48:38:  <team v='182116'/>
08:48:38:  <user v='ajm'/>
08:48:38:
08:48:38:  <!-- Folding Slots -->
08:48:38:  <slot id='0' type='CPU'>
08:48:38:    <cpus v='16'/>
08:48:38:    <paused v='true'/>
08:48:38:  </slot>
08:48:38:  <slot id='1' type='GPU'>
08:48:38:  </slot>
08:48:38:</config>
08:48:38:WU00:FS01:Sending unit results: id:00 state:SEND error:DUMPED project:17426 run:0 clone:1994 gen:5 core:0x22 unit:0x00000006cedfaa9200000000000007ca
08:48:38:WU00:FS01:Connecting to 206.223.170.146:8080
08:48:39:WU00:FS01:Server responded WORK_ACK (400)
08:48:39:WU00:FS01:Cleaning up
08:49:04:FS01:Unpaused
08:49:04:WU00:FS01:Connecting to assign1.foldingathome.org:80
08:49:04:WU00:FS01:Assigned to work server 18.188.125.154
08:49:04:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP108 [GeForce GT 1030] 1127 from 18.188.125.154
08:49:04:WU00:FS01:Connecting to 18.188.125.154:8080
08:49:05:WU00:FS01:Downloading 3.88MiB
08:49:07:WU00:FS01:Download complete
08:49:07:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17507 run:0 clone:1390 gen:32 core:0x22 unit:0x0000003a12bc7d9a000000000000056e
08:49:07:WU00:FS01:Starting
08:49:07:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 15224 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
08:49:07:WU00:FS01:Started FahCore on PID 4188
08:49:07:WU00:FS01:Core PID:8716
08:49:07:WU00:FS01:FahCore 0x22 started
08:49:07:WU00:FS01:0x22:*********************** Log Started 2020-11-12T08:49:07Z ***********************
08:49:07:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:49:07:WU00:FS01:0x22:       Core: Core22
08:49:07:WU00:FS01:0x22:       Type: 0x22
08:49:07:WU00:FS01:0x22:    Version: 0.0.13
08:49:07:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:49:07:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
08:49:07:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
08:49:07:WU00:FS01:0x22:       Date: Sep 19 2020
08:49:07:WU00:FS01:0x22:       Time: 02:35:58
08:49:07:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
08:49:07:WU00:FS01:0x22:     Branch: core22-0.0.13
08:49:07:WU00:FS01:0x22:   Compiler: Visual C++ 2015
08:49:07:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
08:49:07:WU00:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
08:49:07:WU00:FS01:0x22:   Platform: win32 10
08:49:07:WU00:FS01:0x22:       Bits: 64
08:49:07:WU00:FS01:0x22:       Mode: Release
08:49:07:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
08:49:07:WU00:FS01:0x22:             <peastman@stanford.edu>
08:49:07:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 4188 -checkpoint 15
08:49:07:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
08:49:07:WU00:FS01:0x22:             1 -gpu 1
08:49:07:WU00:FS01:0x22:************************************ libFAH ************************************
08:49:07:WU00:FS01:0x22:       Date: Sep 7 2020
08:49:07:WU00:FS01:0x22:       Time: 19:09:56
08:49:07:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
08:49:07:WU00:FS01:0x22:     Branch: HEAD
08:49:08:WU00:FS01:0x22:************************************ CBang *************************************
08:49:08:WU00:FS01:0x22:       Date: Sep 7 2020
08:49:08:WU00:FS01:0x22:       Time: 19:08:30
08:49:08:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
08:49:08:WU00:FS01:0x22:     Branch: HEAD
08:49:08:WU00:FS01:0x22:   Compiler: Visual C++ 2015
08:49:08:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
08:49:08:WU00:FS01:0x22:   Platform: win32 10
08:49:08:WU00:FS01:0x22:       Bits: 64
08:49:08:WU00:FS01:0x22:       Mode: Release
08:49:08:WU00:FS01:0x22:************************************ System ************************************
08:49:08:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
08:49:08:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
08:49:08:WU00:FS01:0x22:       CPUs: 20
08:49:08:WU00:FS01:0x22:     Memory: 63.69GiB
08:49:08:WU00:FS01:0x22:Free Memory: 59.65GiB
08:49:08:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
08:49:08:WU00:FS01:0x22: OS Version: 6.2
08:49:08:WU00:FS01:0x22:Has Battery: false
08:49:08:WU00:FS01:0x22: On Battery: false
08:49:08:WU00:FS01:0x22: UTC Offset: 1
08:49:08:WU00:FS01:0x22:        PID: 8716
08:49:08:WU00:FS01:0x22:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
08:49:08:WU00:FS01:0x22:************************************ OpenMM ************************************
08:49:08:WU00:FS01:0x22:   Revision: 189320d0
08:49:08:WU00:FS01:0x22:********************************************************************************
08:49:08:WU00:FS01:0x22:Project: 17507 (Run 0, Clone 1390, Gen 32)
08:49:08:WU00:FS01:0x22:Unit: 0x0000003a12bc7d9a000000000000056e
08:49:08:WU00:FS01:0x22:Reading tar file core.xml
08:49:08:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
08:49:08:WU00:FS01:0x22:Reading tar file state.xml.bz2
08:49:08:WU00:FS01:0x22:Reading tar file system.xml.bz2
08:49:08:WU00:FS01:0x22:Digital signatures verified
08:49:08:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:49:08:WU00:FS01:0x22:Version 0.0.13
08:49:08:WU00:FS01:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
08:49:08:WU00:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
08:49:08:WU00:FS01:0x22:  XTC frame write interval: 62500 steps (2.5%) [40 total]
08:49:08:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
08:49:08:WU00:FS01:0x22:There are 4 platforms available.
08:49:08:WU00:FS01:0x22:Platform 0: Reference
08:49:08:WU00:FS01:0x22:Platform 1: CPU
08:49:08:WU00:FS01:0x22:Platform 2: OpenCL
08:49:08:WU00:FS01:0x22:  opencl-device 1 specified
08:49:08:WU00:FS01:0x22:Platform 3: CUDA
08:49:08:WU00:FS01:0x22:  cuda-device 1 specified
08:49:10:WU00:FS01:0x22:Attempting to create CUDA context:
08:49:10:WU00:FS01:0x22:  Configuring platform CUDA
08:49:14:WU00:FS01:0x22:  Using CUDA and gpu 1
08:49:14:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
08:49:15:WU00:FS01:0x22:Checkpoint completed at step 0
08:49:28:Adding folding slot 02: READY gpu:1:TU104 [GeForce RTX 2080 SUPER]
08:49:28:Removing old file 'configs/config-20201028-145325.xml'
08:49:28:Saving configuration to config.xml
08:49:28:<config>
08:49:28:  <!-- HTTP Server -->
08:49:28:  <allow v='127.0.0.1 192.168.1.127'/>
08:49:28:
08:49:28:  <!-- Network -->
08:49:28:  <proxy v=':8080'/>
08:49:28:
08:49:28:  <!-- Remote Command Server -->
08:49:28:  <command-allow-no-pass v='127.0.0.1 192.168.1.127'/>
08:49:28:
08:49:28:  <!-- Slot Control -->
08:49:28:  <power v='full'/>
08:49:28:
08:49:28:  <!-- User Information -->
08:49:28:  <passkey v='*****'/>
08:49:28:  <team v='182116'/>
08:49:28:  <user v='ajm'/>
08:49:28:
08:49:28:  <!-- Folding Slots -->
08:49:28:  <slot id='0' type='CPU'>
08:49:28:    <cpus v='16'/>
08:49:28:    <paused v='true'/>
08:49:28:  </slot>
08:49:28:  <slot id='1' type='GPU'/>
08:49:28:  <slot id='2' type='GPU'/>
08:49:28:</config>
08:49:28:WU01:FS02:Connecting to assign1.foldingathome.org:80
08:49:29:WU01:FS02:Assigned to work server 18.188.125.154
08:49:29:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:TU104 [GeForce RTX 2080 SUPER] from 18.188.125.154
08:49:29:WU01:FS02:Connecting to 18.188.125.154:8080
08:49:30:WU01:FS02:Downloading 7.51MiB
08:49:33:WU01:FS02:Download complete
08:49:33:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13428 run:3505 clone:31 gen:1 core:0x22 unit:0x0000000112bc7d9a000000000db1001f
08:49:33:WU01:FS02:Starting
08:49:33:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ajmch\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 15224 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:49:33:WU01:FS02:Started FahCore on PID 5148
08:49:33:WU01:FS02:Core PID:5304
08:49:33:WU01:FS02:FahCore 0x22 started
08:49:33:WU01:FS02:0x22:*********************** Log Started 2020-11-12T08:49:33Z ***********************
08:49:33:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
08:49:33:WU01:FS02:0x22:       Core: Core22
08:49:33:WU01:FS02:0x22:       Type: 0x22
08:49:33:WU01:FS02:0x22:    Version: 0.0.13
08:49:33:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:49:33:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
08:49:33:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
08:49:33:WU01:FS02:0x22:       Date: Sep 19 2020
08:49:33:WU01:FS02:0x22:       Time: 02:35:58
08:49:33:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
08:49:33:WU01:FS02:0x22:     Branch: core22-0.0.13
08:49:33:WU01:FS02:0x22:   Compiler: Visual C++ 2015
08:49:33:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
08:49:33:WU01:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
08:49:33:WU01:FS02:0x22:   Platform: win32 10
08:49:33:WU01:FS02:0x22:       Bits: 64
08:49:33:WU01:FS02:0x22:       Mode: Release
08:49:33:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
08:49:33:WU01:FS02:0x22:             <peastman@stanford.edu>
08:49:33:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5148 -checkpoint 15
08:49:33:WU01:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
08:49:33:WU01:FS02:0x22:             0 -gpu 0
08:49:33:WU01:FS02:0x22:************************************ libFAH ************************************
08:49:33:WU01:FS02:0x22:       Date: Sep 7 2020
08:49:33:WU01:FS02:0x22:       Time: 19:09:56
08:49:33:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
08:49:33:WU01:FS02:0x22:     Branch: HEAD
08:49:33:WU01:FS02:0x22:************************************ CBang *************************************
08:49:33:WU01:FS02:0x22:       Time: 19:08:30
08:49:33:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
08:49:33:WU01:FS02:0x22:************************************ System ************************************
08:49:33:WU01:FS02:0x22:        CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
08:49:33:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
08:49:33:WU01:FS02:0x22:       CPUs: 20
08:49:33:WU01:FS02:0x22:     Memory: 63.69GiB
08:49:33:WU01:FS02:0x22:Free Memory: 59.10GiB
08:49:33:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
08:49:33:WU01:FS02:0x22: OS Version: 6.2
08:49:33:WU01:FS02:0x22:Has Battery: false
08:49:33:WU01:FS02:0x22: On Battery: false
08:49:33:WU01:FS02:0x22: UTC Offset: 1
08:49:33:WU01:FS02:0x22:        PID: 5304
08:49:33:WU01:FS02:0x22:        CWD: C:\Users\ajmch\AppData\Roaming\FAHClient\work
08:49:33:WU01:FS02:0x22:************************************ OpenMM ************************************
08:49:33:WU01:FS02:0x22:   Revision: 189320d0
08:49:33:WU01:FS02:0x22:********************************************************************************
08:49:33:WU01:FS02:0x22:Project: 13428 (Run 3505, Clone 31, Gen 1)
08:49:33:WU01:FS02:0x22:Unit: 0x0000000112bc7d9a000000000db1001f
08:49:33:WU01:FS02:0x22:Reading tar file core.xml
08:49:33:WU01:FS02:0x22:Reading tar file integrator.xml.bz2
08:49:33:WU01:FS02:0x22:Reading tar file state.xml.bz2
08:49:33:WU01:FS02:0x22:Reading tar file system.xml.bz2
08:49:33:WU01:FS02:0x22:Digital signatures verified
08:49:33:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
08:49:33:WU01:FS02:0x22:Version 0.0.13
08:49:33:WU01:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
08:49:33:WU01:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
08:49:33:WU01:FS02:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
08:49:33:WU01:FS02:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
08:49:33:WU01:FS02:0x22:There are 4 platforms available.
08:49:33:WU01:FS02:0x22:Platform 0: Reference
08:49:33:WU01:FS02:0x22:Platform 1: CPU
08:49:33:WU01:FS02:0x22:Platform 2: OpenCL
08:49:33:WU01:FS02:0x22:  opencl-device 0 specified
08:49:33:WU01:FS02:0x22:Platform 3: CUDA
08:49:33:WU01:FS02:0x22:  cuda-device 0 specified
08:49:38:Removing old file 'configs/config-20201030-074537.xml'
08:49:38:Saving configuration to config.xml
08:49:38:<config>
08:49:38:  <!-- HTTP Server -->
08:49:38:  <allow v='127.0.0.1 192.168.1.127'/>
08:49:38:
08:49:38:  <!-- Network -->
08:49:38:  <proxy v=':8080'/>
08:49:38:
08:49:38:  <!-- Remote Command Server -->
08:49:38:  <command-allow-no-pass v='127.0.0.1 192.168.1.127'/>
08:49:38:
08:49:38:  <!-- Slot Control -->
08:49:38:  <power v='full'/>
08:49:38:
08:49:38:  <!-- User Information -->
08:49:38:  <passkey v='*****'/>
08:49:38:  <team v='182116'/>
08:49:38:  <user v='ajm'/>
08:49:38:
08:49:38:  <!-- Folding Slots -->
08:49:38:  <slot id='0' type='CPU'>
08:49:38:    <cpus v='16'/>
08:49:38:    <paused v='true'/>
08:49:38:  </slot>
08:49:38:  <slot id='1' type='GPU'/>
08:49:38:  <slot id='2' type='GPU'/>
08:49:38:</config>
08:49:41:WU01:FS02:0x22:Attempting to create CUDA context:
08:49:41:WU01:FS02:0x22:  Configuring platform CUDA
08:49:48:WU01:FS02:0x22:  Using CUDA and gpu 0
08:49:48:WU01:FS02:0x22:Completed 0 out of 1000000 steps (0%)
08:49:48:WU01:FS02:0x22:Checkpoint completed at step 0
08:50:54:WU01:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
08:52:00:WU01:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
Las, this operation changed the slot configuration and my previous WU was dumped. :cry: The 1030 was immediately recognized and I had to add a slot for the card (2080S) that was previously folding in this machine.
But after that, both cards can fold with CUDA, no problem. :D
So I would follow PantherX's suggestion.
iokeith
Post by iokeith »
Thanks I'll try these suggestions when I have the time.
On another topic, I installed TechPower GPU-Z on the working machine with a GT 1030 and found PCIe voltage when running very low at 1.9v @25w and on light running idle at 10.5v @12w, shown below
To me this suggests the card shouldn't work at all or produce invalid work units, yet it has been clocking up 150k-200k PPD for some time compared with ~40K PPD without the card. Any thoughts on this?
GPU Clock [MHz].........................1721.0.....139.0
Memory Clock [MHz].....................1502.0.....202.5
GPU Temperature [°C]...................55.0 .......39.0
Fan Speed (%) [%]........................ 45..........37
Fan Speed (RPM) [RPM...................2250.......1911
Memory Used [MB]....................... 188.........135
GPU Load [%]..............................79..........0
Memory Controller Load [%].............20...........9
Video Engine Load [%]....................0............0
Bus Interface Load [%]...................21...........0
Board Power Draw [W]...................25.8 ........12.5
PCIe Slot Power [W]..................... 25.8 ........12.4
PCIe Slot Voltage [V].....................1.9...........10.4
Power Consumption (%) [% TDP]........0.0...........0.0
PerfCap Reason []........................4.............16
GPU Voltage [V........................... 1.0620.......0.6750
CPU Temperature [°C]..................50.0..........49.0
System Memory Used [MB].............3380..........3151
iokeith
Post by iokeith »
I think I'm going to give up on this computer for FAH. The PC Windows is up to date. I tried DDU instead of revounistaller and installed driver 43.200 and the latest 45.370 and swapped cards but FAH doesn't launch on reboot.
With GT 1030 in, FAH will work with Microsoft Basic Display adaptor, but the GPU slot is always disabled, and when Nvidia drivers are installed, FAH cannot connect and launch at all
With GT 1030 out, FAH works as normal. Would have been nice to know what the problem was
One person has reported issues with the latest nVidia drivers and the F@h software - viewtopic.php?f=108&t=36420&p=345851#p345851. Don't know if that is what you are running into.
psaam0001
Post by psaam0001 »
Right now, I am running version 451.76 on a Windows 10 (Home) machine (with a GT 710 and a GTX 1650 Super), using the latest OS updates, and am not having issues at this time.
Are you able to roll back the NVidia drivers to the last version that worked, and/or Windows to where it was before the 20H2 update?
Paul
iokeith
Post by iokeith »
I've had this problem for over two weeks now, ever since I first put a graphics card into the machine, FAH refused to launch. What is confusing is I have a near identical machine with a GT 1030 which is running FAH using driver 43.200 with no problems. It's a mystery.
I've subsequently moved the GT1030 into an Optiplex WIn 10 Pro 8Gb quad core i5-4590 with an existing GTX 1650 using the latest driver 45.370, and installed driver 43.200 for the GT 1030. Ok and running FAH!
Then along came a windows update and reinstalled 43.200 for both cards! But again all OK!
I thought I would install the driver 45.370 for both cards and again all Ok, tho on restarting the two CPU cores stalled while the two cards resumed running. I had to click pause and then fold to kickstart the CPU to run, tho the CPU discarded its current work unit and loaded a new one. After a restart, everything still looks good! Just monitoring now for performance, temperature and power.
Thanks for all the suggestions!
