BSOD FahCore_a7.exe
Sir_Launcelot
BSOD FahCore_a7.exe
Post by Sir_Launcelot »
I have been receiving some BSOD on windows lately related to FoH. It seems related to a DPC watchdog violation. Basically some call within dxgmms2.sys
is taking longer than 500 ticks, and crashes the system. I don't see anything in the FaH logs, but have analyzed the memory dump. Please let me know what relivant additional information I can provide. I have two FaH logs, both before and after, but suspect there won't be much info due to the BSOD.
https://docs.microsoft.com/en-us/windows-hardware/drivers/debugger/bug-check-0x133-dpc-watchdog-violation
Microsoft Windows [Version 10.0.20246.1]
Debug
Microsoft (R) Windows Debugger Version 10.0.20153.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Active memory is available
Dump completed successfully, progress percentage: 100
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*https://msdl.microsoft.com/download/symbols
Symbol search path is: srv*https://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 10 Kernel Version 20241 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Edition build lab: 20241.1000.amd64fre.rs_prerelease.201016-1450
Machine Name:
Kernel base = 0xfffff804`30800000 PsLoadedModuleList = 0xfffff804`31433b10
Debug session time: Wed Oct 28 19:54:51.476 2020 (UTC - 5:00)
System Uptime: 0 days 23:03:23.203
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff804`30c0db40 48894c2408      mov     qword ptr [rsp+8],rcx ss:fffff804`2ca6cbd0=0000000000000133
0: kd> !analyze -v
*                        Bugcheck Analysis                                    *
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000000, A single DPC or ISR exceeded its time allotment. The offending
	component can usually be identified with a stack trace.
Arg2: 0000000000000501, The DPC time count (in ticks).
Arg3: 0000000000000500, The DPC time allotment (in ticks).
Arg4: fffff8043150a348, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
	additional information regarding this single DPC timeout
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: TickPeriods                                   ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 12359
    Key  : Analysis.DebugAnalysisProvider.CPP
    Value: Create: 8007007e on DELLG3
    Key  : Analysis.DebugData
    Value: CreateObject
    Key  : Analysis.DebugModel
    Value: CreateObject
    Key  : Analysis.Elapsed.mSec
    Value: 13090
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 143
    Key  : Analysis.System
    Value: CreateObject
    Key  : Dump.Attributes.FilterDumpFile
    Value: 1
    Key  : WER.OS.Branch
    Value: rs_prerelease
    Key  : WER.OS.Timestamp
    Value: 2020-10-16T14:50:00Z
    Key  : WER.OS.Version
    Value: 10.0.20241.1000
ADDITIONAL_XML: 1
OS_BUILD_LAYERS: 1
DUMP_FILE_ATTRIBUTES: 0x1840
  Filter Dump
BUGCHECK_CODE:  133
BUGCHECK_P1: 0
BUGCHECK_P2: 501
BUGCHECK_P3: 500
BUGCHECK_P4: fffff8043150a348
DPC_TIMEOUT_TYPE:  SINGLE_DPC_TIMEOUT_EXCEEDED
TRAP_FRAME:  fffff8042ca654f0 -- (.trap 0xfffff8042ca654f0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=000000c135c7602a rbx=0000000000000000 rcx=000000c135c7602a
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80444e58fb9 rsp=fffff8042ca65688 rbp=ffff97879d164110
 r8=0000000000989680  r9=000000000573dd00 r10=16424a667f3b14e0
r11=000000b1ba16bcaf r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl zr na po nc
dxgmms2!VidSchiConvertGpuTimeStampToSchedulerUnits+0x71:
fffff804`44e58fb9 4c8bc0          mov     r8,rax
Resetting default scope
PROCESS_NAME:  FahCore_a7.exe
DPC_STACK_BASE:  FFFFF8042CA65FB0
STACK_TEXT:
fffff804`2ca6cbc8 fffff804`30c44c5b     : 00000000`00000133 00000000`00000000 00000000`00000501 00000000`00000500 : nt!KeBugCheckEx
fffff804`2ca6cbd0 fffff804`30a17e60     : 0000adf5`4a0d186e fffff804`2a496180 fffff804`2ca654f0 00000000`00000000 : nt!KeAccumulateTicks+0x229ddb
fffff804`2ca6cc30 fffff804`30a17ca4     : ffff9787`8be53490 fffff804`314fe4c0 fffff804`314fe570 fffff804`2a496180 : nt!KeClockInterruptNotify+0x150
fffff804`2ca6cf40 fffff804`30b15a00     : fffff804`314fe3a0 fffff3a2`96585aa9 00000000`00000183 16425072`b6266000 : nt!HalpTimerClockIpiRoutine+0x14
fffff804`2ca6cf70 fffff804`30c0f6da     : fffff804`2ca65570 fffff804`314fe4c0 00000000`00000000 00000000`00000693 : nt!KiCallInterruptServiceRoutine+0xa0
fffff804`2ca6cfb0 fffff804`30c0fca7     : 00001aac`00000800 fffff804`30c0fcb4 ffff9787`a6a52e80 fffff804`44e59a1c : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
fffff804`2ca654f0 fffff804`44e58fb9     : fffff804`44e5b68a 00001aac`00000800 00000000`00989680 ffff9787`83a63000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff804`2ca65688 fffff804`44e5b68a     : 00001aac`00000800 00000000`00989680 ffff9787`83a63000 00000000`00000001 : dxgmms2!VidSchiConvertGpuTimeStampToSchedulerUnits+0x71
fffff804`2ca65690 fffff804`44e5d7f5     : ffff9787`8be53490 00000000`00989680 ffff9787`83a5f000 ffff9787`83a5f000 : dxgmms2!VidSchiUpdateHwSchRunningTime+0x192
fffff804`2ca656f0 fffff804`44e3f666     : ffff9787`83a644f0 ffff9787`83a5d000 fffff804`2ca65790 fffff804`30a21f00 : dxgmms2!VidSchiProcessMonitoredFenceSignaledDpc+0x81
fffff804`2ca65760 fffff804`4060265a     : ffff9787`7dfc2030 fffff804`2ca65849 fffff804`2ca65e90 fffff804`30a57a64 : dxgmms2!VidSchDdiNotifyDpc+0x1caa6
fffff804`2ca657d0 fffff804`4507a02b     : ffff9787`7dfc2030 00000000`00000000 ffff9787`7dfc2030 ffff9787`7d844000 : dxgkrnl!DxgNotifyDpcCB+0x9a
fffff804`2ca658b0 fffff804`4580a83f     : fffff804`45079fbe ffff9787`7d844000 fffff804`2ca65e00 00000000`00000000 : nvlddmkm+0x9a02b
fffff804`2ca65940 fffff804`4580aad3     : fffff804`4580a7d7 ffff9787`7d844000 ffff9787`7d844000 fffff804`2ca65e90 : nvlddmkm+0x82a83f
fffff804`2ca659d0 fffff804`45809da8     : ffff9787`7d844000 fffff804`00000000 00000000`00000000 ffff9787`7dfc26e8 : nvlddmkm+0x82aad3
fffff804`2ca65a00 fffff804`45095b34     : ffff9787`7d844000 fffff804`2ca65e00 fffff804`2ca65e90 00000000`00000000 : nvlddmkm+0x829da8
fffff804`2ca65a30 fffff804`40602fb7     : fffff804`45095aaf ffff9787`7dfc2180 ffff9787`7df86900 ffff9787`88a2c080 : nvlddmkm+0xb5b34
fffff804`2ca65ac0 fffff804`30ae2ca5     : fffff804`2a496180 ffff9787`61ded000 fffff804`2ca65e70 fffff804`00000002 : dxgkrnl!DpiFdoDpcForIsr+0x67
fffff804`2ca65b10 fffff804`30ae1cbd     : fffff804`00000000 00000000`00000022 00000000`00000004 fffff804`00000010 : nt!KiExecuteAllDpcs+0x505
fffff804`2ca65d00 fffff804`30c15855     : 00000000`00000000 fffff804`2a496180 ffffdd00`fb9a0640 00000000`00006b38 : nt!KiRetireDpcList+0x24d
fffff804`2ca65fb0 fffff804`30c15640     : ffffdd00`fb9a0640 fffff804`30b2ba4a 000002b0`7c1fac00 000002b0`00a8c400 : nt!KxRetireDpcList+0x5
fffffd87`3428f9a0 fffff804`30c14e85     : 00000000`00006b38 fffff804`30c0f7a1 00000000`00006b34 00000000`00000000 : nt!KiDispatchInterruptContinue
fffffd87`3428f9d0 fffff804`30c0f7a1     : 00000000`00006b34 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDpcInterruptBypass+0x25
fffffd87`3428f9e0 00007ff6`62fe4ac4     : 00000000`00000000 000002b0`003e78c0 00000000`00000001 000002b0`7907c094 : nt!KiInterruptDispatch+0xb1
000000ca`d41fe3a0 00007ff6`62beb62b     : 000002b0`7674d040 00000000`00000000 000002b0`792226f0 000002b0`7643f6b0 : FahCore_a7!tng_compress_pos_int_find_algo+0xa4d65d
000000ca`d41feb00 00007ff6`629eb164     : 00000000`00000000 000002b0`76a37c80 3fefae14`00000000 00000000`00000000 : FahCore_a7!tng_compress_pos_int_find_algo+0x6541c4
000000ca`d41feba0 00007ff6`629e9e1d     : 000002b0`763b47c0 00000000`000000f1 000000ca`d41fed70 000002b0`791f2e40 : FahCore_a7!tng_compress_pos_int_find_algo+0x453cfd
000000ca`d41fec10 00007ff6`629e77c7     : 000002b0`7b459490 000002b0`7baf4ba0 000002b0`78beb170 00000000`00000000 : FahCore_a7!tng_compress_pos_int_find_algo+0x4529b6
000000ca`d41feee0 00007ff6`62980cbf     : 000002b0`78beb170 000000ca`d41ff130 00000000`00000000 00000000`00000000 : FahCore_a7!tng_compress_pos_int_find_algo+0x450360
000000ca`d41fefd0 00007ff6`6297d1d4     : 000002b0`75283aa0 000000ca`d41ff9f0 000002b0`75283aa0 000002b0`74e5b0f0 : FahCore_a7!tng_compress_pos_int_find_algo+0x3e9858
000000ca`d41ff870 00007ff6`6297dc0a     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : FahCore_a7!tng_compress_pos_int_find_algo+0x3e5d6d
000000ca`d41ffc70 00007ff6`62a0e2d2     : 000002b0`72a89d48 000002b0`72a89d48 00000000`00000000 00000000`00000000 : FahCore_a7!tng_compress_pos_int_find_algo+0x3e67a3
000000ca`d41ffea0 00007ff6`62a0fbfd     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : FahCore_a7!tng_compress_pos_int_find_algo+0x476e6b
000000ca`d41ffed0 00007ffb`bf7f4ede     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : FahCore_a7!tng_compress_pos_int_find_algo+0x478796
000000ca`d41fff00 00007ffb`c052795b     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : KERNEL32!BaseThreadInitThunk+0x1e
000000ca`d41fff30 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlUserThreadStart+0x2b
SYMBOL_NAME:  dxgmms2!VidSchiConvertGpuTimeStampToSchedulerUnits+71
MODULE_NAME: dxgmms2
IMAGE_NAME:  dxgmms2.sys
IMAGE_VERSION:  10.0.20241.1000
STACK_COMMAND:  .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET:  71
FAILURE_BUCKET_ID:  0x133_DPC_dxgmms2!VidSchiConvertGpuTimeStampToSchedulerUnits
OS_VERSION:  10.0.20241.1000
BUILDLAB_STR:  rs_prerelease
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {e27aef5e-3cd7-84ff-1d36-41d9dc535b09}
Followup:     MachineOwner
Logs
*********************** Log Started 2020-10-28T15:36:44Z ***********************
15:36:44:******************************* libFAH ********************************
15:36:44:           Date: Oct 20 2020
15:36:44:           Time: 13:36:55
15:36:44:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:36:44:         Branch: master
15:36:44:       Compiler: Visual C++ 2015
15:36:44:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:36:44:       Platform: win32 10
15:36:44:           Bits: 32
15:36:44:           Mode: Release
15:36:44:****************************** FAHClient ******************************
15:36:44:        Version: 7.6.21
15:36:44:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:36:44:      Copyright: 2020 foldingathome.org
15:36:44:       Homepage: https://foldingathome.org/
15:36:44:           Time: 13:41:04
15:36:44:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:36:44:           Bits: 32
15:36:44:           Args: --open-web-control
15:36:44:         Config: C:\Users\JMill\AppData\Roaming\FAHClient\config.xml
15:36:44:******************************** CBang ********************************
15:36:44:           Time: 11:36:18
15:36:44:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:36:44:           Bits: 32
15:36:44:******************************* System ********************************
15:36:44:            CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
15:36:44:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
15:36:44:           CPUs: 8
15:36:44:         Memory: 63.85GiB
15:36:44:    Free Memory: 55.00GiB
15:36:44:        Threads: WINDOWS_THREADS
15:36:44:     OS Version: 6.2
15:36:44:    Has Battery: true
15:36:44:     On Battery: false
15:36:44:     UTC Offset: -4
15:36:44:            PID: 13088
15:36:44:            CWD: C:\Users\JMill\AppData\Roaming\FAHClient
15:36:44:  Win32 Service: false
15:36:44:             OS: Windows 10 Enterprise
15:36:44:        OS Arch: AMD64
15:36:44:           GPUs: 2
15:36:44:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
15:36:44:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:5 GP107M [GeForce GTX 1050 Mobile]
15:36:44:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.1
15:36:44:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:456.71
15:36:44:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:29.20
15:36:44:***********************************************************************
15:36:44:<config>
15:36:44:  <!-- Folding Slot Configuration -->
15:36:44:  <cause v='COVID_19'/>
15:36:44:
15:36:44:  <!-- Network -->
15:36:44:  <proxy v=':8080'/>
15:36:44:
15:36:44:  <!-- Slot Control -->
15:36:44:  <power v='full'/>
15:36:44:
15:36:44:  <!-- User Information -->
15:36:44:  <passkey v='*****'/>
15:36:44:  <team v='224497'/>
15:36:44:  <user v='Sir_Launcelot'/>
15:36:44:
15:36:44:  <!-- Folding Slots -->
15:36:44:  <slot id='0' type='CPU'>
15:36:44:    <cpus v='8'/>
15:36:44:  </slot>
15:36:44:  <slot id='1' type='GPU'>
15:36:44:    <gpu-beta v='False'/>
15:36:44:    <paused v='true'/>
15:36:44:    <pci-bus v='0'/>
15:36:44:    <pci-slot v='2'/>
15:36:44:  </slot>
15:36:44:  <slot id='2' type='GPU'>
15:36:44:    <pci-bus v='1'/>
15:36:44:    <pci-slot v='0'/>
15:36:44:  </slot>
15:36:44:</config>
15:36:44:Trying to access database...
15:36:44:Successfully acquired database lock
15:36:44:FS00:Initialized folding slot 00: cpu:8
15:36:44:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 Gen9p5/GT2 [UHD Graphics 630].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
15:36:44:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 Gen9p5/GT2 [UHD Graphics 630].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
15:36:44:FS02:Initialized folding slot 02: gpu:1:0 GP107M [GeForce GTX 1050 Mobile]
15:36:44:WU00:FS00:Starting
15:36:44:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\JMill\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13088 -checkpoint 15 -np 8
15:36:45:WU00:FS00:Started FahCore on PID 10832
15:36:45:WU00:FS00:Core PID:17936
15:36:45:WU00:FS00:FahCore 0xa7 started
15:36:45:WU00:FS00:0xa7:*********************** Log Started 2020-10-28T15:36:45Z ***********************
15:36:45:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:36:45:WU00:FS00:0xa7:       Type: 0xa7
15:36:45:WU00:FS00:0xa7:       Core: Gromacs
15:36:45:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10832 -checkpoint 15 -np
15:36:45:WU00:FS00:0xa7:             8
15:36:45:WU00:FS00:0xa7:************************************ CBang *************************************
15:36:45:WU00:FS00:0xa7:       Date: Nov 27 2019
15:36:45:WU00:FS00:0xa7:       Time: 03:40:09
15:36:45:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
15:36:45:WU00:FS00:0xa7:     Branch: master
15:36:45:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
15:36:45:WU01:FS02:Connecting to assign1.foldingathome.org:80
15:36:45:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:36:45:WU00:FS00:0xa7:   Platform: win32 10
15:36:45:WU00:FS00:0xa7:       Bits: 64
15:36:45:WU00:FS00:0xa7:       Mode: Release
15:36:45:WU00:FS00:0xa7:************************************ System ************************************
15:36:45:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
15:36:45:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
15:36:45:WU00:FS00:0xa7:       CPUs: 8
15:36:45:WU00:FS00:0xa7:     Memory: 63.85GiB
15:36:45:WU00:FS00:0xa7:Free Memory: 54.97GiB
15:36:45:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
15:36:45:WU00:FS00:0xa7: OS Version: 6.2
15:36:45:WU00:FS00:0xa7:Has Battery: true
15:36:45:WU00:FS00:0xa7: On Battery: false
15:36:45:WU00:FS00:0xa7: UTC Offset: -4
15:36:45:WU00:FS00:0xa7:        PID: 17936
15:36:45:WU00:FS00:0xa7:        CWD: C:\Users\JMill\AppData\Roaming\FAHClient\work
15:36:45:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:36:45:WU00:FS00:0xa7:    Version: 0.0.19
15:36:45:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:36:45:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:36:45:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
15:36:45:WU00:FS00:0xa7:       Date: Nov 25 2019
15:36:45:WU00:FS00:0xa7:       Time: 17:12:41
15:36:45:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
15:36:45:WU00:FS00:0xa7:************************************ Build *************************************
15:36:45:WU00:FS00:0xa7:       SIMD: avx_256
15:36:45:WU00:FS00:0xa7:********************************************************************************
15:36:45:WU00:FS00:0xa7:Project: 17201 (Run 0, Clone 1588, Gen 373)
15:36:45:WU00:FS00:0xa7:Unit: 0x000001a380fccb0a5f32fef63d47109d
15:36:45:WU00:FS00:0xa7:Digital signatures verified
15:36:45:WU00:FS00:0xa7:Calling: mdrun -s frame373.tpr -o frame373.trr -x frame373.xtc -cpi state.cpt -cpt 15 -nt 8
15:36:45:WU00:FS00:0xa7:Steps: first=93250000 total=250000
15:36:48:WU01:FS02:Assigned to work server 129.213.157.105
15:36:48:WU01:FS02:Requesting new work unit for slot 02: gpu:1:0 GP107M [GeForce GTX 1050 Mobile] from 129.213.157.105
15:36:48:WU01:FS02:Connecting to 129.213.157.105:8080
15:36:57:ERROR:WU01:FS02:Exception: Server did not assign work unit
15:36:57:WU01:FS02:Connecting to assign1.foldingathome.org:80
15:36:57:WU01:FS02:Assigned to work server 129.213.157.105
15:36:57:WU01:FS02:Requesting new work unit for slot 02: gpu:1:0 GP107M [GeForce GTX 1050 Mobile] from 129.213.157.105
15:36:57:WU01:FS02:Connecting to 129.213.157.105:8080
15:37:11:WU01:FS02:Downloading 11.38MiB
15:37:13:WU01:FS02:Download complete
15:37:13:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14905 run:262 clone:8 gen:18 core:0x22 unit:0x0000001981d59d695f4ec9dceff10979
15:37:13:WU01:FS02:Starting
15:37:13:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\JMill\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 13088 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
15:37:13:WU01:FS02:Started FahCore on PID 584
15:37:14:WU01:FS02:Core PID:10492
15:37:14:WU01:FS02:FahCore 0x22 started
15:37:14:WU01:FS02:0x22:*********************** Log Started 2020-10-28T15:37:14Z ***********************
15:37:14:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
15:37:14:WU01:FS02:0x22:       Core: Core22
15:37:14:WU01:FS02:0x22:       Type: 0x22
15:37:14:WU01:FS02:0x22:    Version: 0.0.13
15:37:14:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:37:14:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
15:37:14:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
15:37:14:WU01:FS02:0x22:       Date: Sep 19 2020
15:37:14:WU01:FS02:0x22:       Time: 02:35:58
15:37:14:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
15:37:14:WU01:FS02:0x22:     Branch: core22-0.0.13
15:37:14:WU01:FS02:0x22:   Compiler: Visual C++ 2015
15:37:14:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:37:14:WU01:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
15:37:14:WU01:FS02:0x22:   Platform: win32 10
15:37:14:WU01:FS02:0x22:       Bits: 64
15:37:14:WU01:FS02:0x22:       Mode: Release
15:37:14:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:37:14:WU01:FS02:0x22:             <peastman@stanford.edu>
15:37:14:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 584 -checkpoint 15
15:37:14:WU01:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
15:37:14:WU01:FS02:0x22:             nvidia -gpu 0 -gpu-usage 100
15:37:14:WU01:FS02:0x22:************************************ libFAH ************************************
15:37:14:WU01:FS02:0x22:       Date: Sep 7 2020
15:37:14:WU01:FS02:0x22:       Time: 19:09:56
15:37:14:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
15:37:14:WU01:FS02:0x22:     Branch: HEAD
15:37:15:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:37:15:WU01:FS02:0x22:   Platform: win32 10
15:37:15:WU01:FS02:0x22:       Bits: 64
15:37:15:WU01:FS02:0x22:       Mode: Release
15:37:15:WU01:FS02:0x22:************************************ CBang *************************************
15:37:15:WU01:FS02:0x22:       Date: Sep 7 2020
15:37:15:WU01:FS02:0x22:       Time: 19:08:30
15:37:15:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
15:37:15:WU01:FS02:0x22:     Branch: HEAD
15:37:15:WU01:FS02:0x22:   Compiler: Visual C++ 2015
15:37:15:WU01:FS02:0x22:************************************ System ************************************
15:37:15:WU01:FS02:0x22:        CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
15:37:15:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
15:37:15:WU01:FS02:0x22:       CPUs: 8
15:37:15:WU01:FS02:0x22:     Memory: 63.85GiB
15:37:15:WU01:FS02:0x22:Free Memory: 54.86GiB
15:37:15:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
15:37:15:WU01:FS02:0x22: OS Version: 6.2
15:37:15:WU01:FS02:0x22:Has Battery: true
15:37:15:WU01:FS02:0x22: On Battery: false
15:37:15:WU01:FS02:0x22: UTC Offset: -4
15:37:15:WU01:FS02:0x22:        PID: 10492
15:37:15:WU01:FS02:0x22:        CWD: C:\Users\JMill\AppData\Roaming\FAHClient\work
15:37:15:WU01:FS02:0x22:************************************ OpenMM ************************************
15:37:15:WU01:FS02:0x22:   Revision: 189320d0
15:37:15:WU01:FS02:0x22:********************************************************************************
15:37:15:WU01:FS02:0x22:Project: 14905 (Run 262, Clone 8, Gen 18)
15:37:15:WU01:FS02:0x22:Unit: 0x0000001981d59d695f4ec9dceff10979
15:37:15:WU01:FS02:0x22:Reading tar file core.xml
15:37:15:WU01:FS02:0x22:Reading tar file integrator.xml
15:37:15:WU01:FS02:0x22:Reading tar file state.xml
15:37:16:WU01:FS02:0x22:Reading tar file system.xml
15:37:21:WU01:FS02:0x22:Digital signatures verified
15:37:21:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
15:37:21:WU01:FS02:0x22:Version 0.0.13
15:37:23:WU01:FS02:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
15:37:23:WU01:FS02:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
15:37:23:WU01:FS02:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
15:37:23:WU01:FS02:0x22:  Global context and integrator variables write interval: disabled
15:37:24:WU01:FS02:0x22:There are 4 platforms available.
15:37:24:WU01:FS02:0x22:Platform 0: Reference
15:37:24:WU01:FS02:0x22:Platform 1: CPU
15:37:24:WU01:FS02:0x22:Platform 2: OpenCL
15:37:24:WU01:FS02:0x22:  opencl-device 0 specified
15:37:24:WU01:FS02:0x22:Platform 3: CUDA
15:37:24:WU01:FS02:0x22:  cuda-device 0 specified
15:37:24:18:127.0.0.1:New Web session
15:37:38:WU01:FS02:0x22:Attempting to create CUDA context:
15:37:38:WU01:FS02:0x22:  Configuring platform CUDA
15:37:49:WU01:FS02:0x22:  Using CUDA and gpu 0
15:37:51:WU01:FS02:0x22:Checkpoint completed at step 0
15:59:53:WU01:FS02:0x22:Checkpoint completed at step 100000
16:22:21:WU01:FS02:0x22:Checkpoint completed at step 200000
16:37:38:33:127.0.0.1:New Web session
16:44:20:WU01:FS02:0x22:Checkpoint completed at step 300000
17:06:14:WU01:FS02:0x22:Checkpoint completed at step 400000
17:28:09:WU01:FS02:0x22:Checkpoint completed at step 500000
17:50:02:WU01:FS02:0x22:Checkpoint completed at step 600000
18:11:51:WU01:FS02:0x22:Checkpoint completed at step 700000
18:24:34:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
18:24:34:WU00:FS00:0xa7:Saving result file frame373.trr
18:24:34:WU00:FS00:0xa7:Saving result file frame373.xtc
18:24:34:WU00:FS00:0xa7:Saving result file md.log
18:24:34:WU00:FS00:0xa7:Saving result file science.log
18:24:34:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:24:34:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:24:34:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17201 run:0 clone:1588 gen:373 core:0xa7 unit:0x000001a380fccb0a5f32fef63d47109d
18:24:34:WU00:FS00:Uploading 1.88MiB to 128.252.203.10
18:24:34:WU00:FS00:Connecting to 128.252.203.10:8080
18:24:37:WU00:FS00:Upload complete
18:24:38:WU00:FS00:Server responded WORK_ACK (400)
18:24:38:WU00:FS00:Final credit estimate, 465.00 points
18:24:38:WU00:FS00:Cleaning up
18:33:22:WU01:FS02:0x22:Checkpoint completed at step 800000
18:54:34:WU01:FS02:0x22:Checkpoint completed at step 900000
19:17:35:WU01:FS02:0x22:Checkpoint completed at step 1000000
19:40:20:WU01:FS02:0x22:Checkpoint completed at step 1100000
20:03:58:WU01:FS02:0x22:Checkpoint completed at step 1200000
20:27:10:WU01:FS02:0x22:Checkpoint completed at step 1300000
20:49:45:WU01:FS02:0x22:Checkpoint completed at step 1400000
21:12:04:WU01:FS02:0x22:Checkpoint completed at step 1500000
21:34:31:WU01:FS02:0x22:Checkpoint completed at step 1600000
******************************* Date: 2020-10-28 *******************************
21:56:55:WU01:FS02:0x22:Checkpoint completed at step 1700000
22:18:58:WU01:FS02:0x22:Checkpoint completed at step 1800000
22:41:04:WU01:FS02:0x22:Checkpoint completed at step 1900000
22:58:42:WU00:FS02:Connecting to assign1.foldingathome.org:80
22:58:42:WU00:FS02:Assigned to work server 129.213.157.105
22:58:42:WU00:FS02:Requesting new work unit for slot 02: gpu:1:0 GP107M [GeForce GTX 1050 Mobile] from 129.213.157.105
22:58:42:WU00:FS02:Connecting to 129.213.157.105:8080
22:58:43:ERROR:WU00:FS02:Exception: Server did not assign work unit
22:58:43:WU00:FS02:Connecting to assign1.foldingathome.org:80
22:58:43:WU00:FS02:Assigned to work server 129.213.157.105
22:58:43:WU00:FS02:Requesting new work unit for slot 02: gpu:1:0 GP107M [GeForce GTX 1050 Mobile] from 129.213.157.105
22:58:43:WU00:FS02:Connecting to 129.213.157.105:8080
22:58:47:WU00:FS02:Downloading 11.38MiB
22:58:50:WU00:FS02:Download complete
22:58:50:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14905 run:396 clone:11 gen:91 core:0x22 unit:0x0000007881d59d695f4ec9da9c1e4bb2
23:03:06:WU01:FS02:0x22:Average performance: 6.53555 ns/day
23:03:08:WU01:FS02:0x22:Checkpoint completed at step 2000000
23:03:15:WU01:FS02:0x22:Saving result file ..\logfile_01.txt
23:03:15:WU01:FS02:0x22:Saving result file checkpointIntegrator.xml
23:03:15:WU01:FS02:0x22:Saving result file checkpointState.xml
23:03:18:WU01:FS02:0x22:Saving result file positions.xtc
23:03:18:WU01:FS02:0x22:Saving result file science.log
23:03:18:WU01:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
23:03:19:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:03:19:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:14905 run:262 clone:8 gen:18 core:0x22 unit:0x0000001981d59d695f4ec9dceff10979
23:03:19:WU01:FS02:Uploading 11.29MiB to 129.213.157.105
23:03:19:WU01:FS02:Connecting to 129.213.157.105:8080
23:03:19:WU00:FS02:Starting
23:03:19:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\JMill\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 13088 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
23:03:19:WU00:FS02:Started FahCore on PID 9596
23:03:19:WU00:FS02:Core PID:17988
23:03:19:WU00:FS02:FahCore 0x22 started
23:03:20:WU00:FS02:0x22:*********************** Log Started 2020-10-28T23:03:19Z ***********************
23:03:20:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
23:03:20:WU00:FS02:0x22:       Core: Core22
23:03:20:WU00:FS02:0x22:       Type: 0x22
23:03:20:WU00:FS02:0x22:    Version: 0.0.13
23:03:20:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:03:20:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
23:03:20:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
23:03:20:WU00:FS02:0x22:       Date: Sep 19 2020
23:03:20:WU00:FS02:0x22:       Time: 02:35:58
23:03:20:WU00:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
23:03:20:WU00:FS02:0x22:     Branch: core22-0.0.13
23:03:20:WU00:FS02:0x22:   Compiler: Visual C++ 2015
23:03:20:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
23:03:20:WU00:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
23:03:20:WU00:FS02:0x22:   Platform: win32 10
23:03:20:WU00:FS02:0x22:       Bits: 64
23:03:20:WU00:FS02:0x22:       Mode: Release
23:03:20:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:03:20:WU00:FS02:0x22:             <peastman@stanford.edu>
23:03:20:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9596 -checkpoint 15
23:03:20:WU00:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
23:03:20:WU00:FS02:0x22:             nvidia -gpu 0 -gpu-usage 100
23:03:20:WU00:FS02:0x22:************************************ libFAH ************************************
23:03:20:WU00:FS02:0x22:       Date: Sep 7 2020
23:03:20:WU00:FS02:0x22:       Time: 19:09:56
23:03:20:WU00:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
23:03:20:WU00:FS02:0x22:     Branch: HEAD
23:03:20:WU00:FS02:0x22:************************************ CBang *************************************
23:03:20:WU00:FS02:0x22:       Time: 19:08:30
23:03:20:WU00:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
23:03:20:WU00:FS02:0x22:************************************ System ************************************
23:03:20:WU00:FS02:0x22:        CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
23:03:20:WU00:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
23:03:20:WU00:FS02:0x22:       CPUs: 8
23:03:20:WU00:FS02:0x22:     Memory: 63.85GiB
23:03:20:WU00:FS02:0x22:Free Memory: 50.47GiB
23:03:20:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
23:03:20:WU00:FS02:0x22: OS Version: 6.2
23:03:20:WU00:FS02:0x22:Has Battery: true
23:03:20:WU00:FS02:0x22: On Battery: false
23:03:20:WU00:FS02:0x22: UTC Offset: -4
23:03:20:WU00:FS02:0x22:        PID: 17988
23:03:20:WU00:FS02:0x22:        CWD: C:\Users\JMill\AppData\Roaming\FAHClient\work
23:03:20:WU00:FS02:0x22:************************************ OpenMM ************************************
23:03:20:WU00:FS02:0x22:   Revision: 189320d0
23:03:20:WU00:FS02:0x22:********************************************************************************
23:03:20:WU00:FS02:0x22:Project: 14905 (Run 396, Clone 11, Gen 91)
23:03:20:WU00:FS02:0x22:Unit: 0x0000007881d59d695f4ec9da9c1e4bb2
23:03:20:WU00:FS02:0x22:Reading tar file core.xml
23:03:20:WU00:FS02:0x22:Reading tar file integrator.xml
23:03:20:WU00:FS02:0x22:Reading tar file state.xml
23:03:22:WU00:FS02:0x22:Reading tar file system.xml
23:03:24:WU00:FS02:0x22:Digital signatures verified
23:03:24:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
23:03:24:WU00:FS02:0x22:Version 0.0.13
23:03:25:WU01:FS02:Upload 26.02%
23:03:25:WU00:FS02:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
23:03:25:WU00:FS02:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
23:03:25:WU00:FS02:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
23:03:25:WU00:FS02:0x22:  Global context and integrator variables write interval: disabled
23:03:25:WU00:FS02:0x22:There are 4 platforms available.
23:03:25:WU00:FS02:0x22:Platform 0: Reference
23:03:25:WU00:FS02:0x22:Platform 1: CPU
23:03:25:WU00:FS02:0x22:Platform 2: OpenCL
23:03:25:WU00:FS02:0x22:  opencl-device 0 specified
23:03:25:WU00:FS02:0x22:Platform 3: CUDA
23:03:25:WU00:FS02:0x22:  cuda-device 0 specified
23:03:31:WU01:FS02:Upload 57.58%
23:03:37:WU01:FS02:Upload 88.59%
23:03:40:WU01:FS02:Upload complete
23:03:40:WU01:FS02:Server responded WORK_ACK (400)
23:03:40:WU01:FS02:Final credit estimate, 73708.00 points
23:03:40:WU01:FS02:Cleaning up
23:03:40:WU00:FS02:0x22:Attempting to create CUDA context:
23:03:40:WU00:FS02:0x22:  Configuring platform CUDA
23:03:46:WU00:FS02:0x22:  Using CUDA and gpu 0
23:03:47:WU00:FS02:0x22:Checkpoint completed at step 0
23:25:56:WU00:FS02:0x22:Checkpoint completed at step 100000
23:48:03:WU00:FS02:0x22:Checkpoint completed at step 200000
00:10:06:WU00:FS02:0x22:Checkpoint completed at step 300000
00:32:09:WU00:FS02:0x22:Checkpoint completed at step 400000
00:48:43:WU01:FS00:Connecting to assign4.foldingathome.org:80
00:48:43:WU01:FS00:Assigned to work server 129.213.40.229
00:48:43:WU01:FS00:Requesting new work unit for slot 00: cpu:8 from 129.213.40.229
00:48:43:WU01:FS00:Connecting to 129.213.40.229:8080
00:48:43:WU01:FS00:Downloading 6.53MiB
00:48:44:WU01:FS00:Download complete
00:48:44:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16925 run:13 clone:57 gen:1 core:0xa7 unit:0x0000000181d528e55f70edb9232e151c
00:48:44:WU01:FS00:Starting
00:48:44:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\JMill\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 13088 -checkpoint 15 -np 8
00:48:44:WU01:FS00:Started FahCore on PID 21372
00:48:44:WU01:FS00:Core PID:27268
00:48:44:WU01:FS00:FahCore 0xa7 started
00:48:45:WU01:FS00:0xa7:*********************** Log Started 2020-10-29T00:48:44Z ***********************
00:48:45:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:48:45:WU01:FS00:0xa7:       Type: 0xa7
00:48:45:WU01:FS00:0xa7:       Core: Gromacs
00:48:45:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 21372 -checkpoint 15 -np
00:48:45:WU01:FS00:0xa7:             8
00:48:45:WU01:FS00:0xa7:************************************ CBang *************************************
00:48:45:WU01:FS00:0xa7:       Date: Nov 27 2019
00:48:45:WU01:FS00:0xa7:       Time: 03:40:09
00:48:45:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
00:48:45:WU01:FS00:0xa7:     Branch: master
00:48:45:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
00:48:45:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:48:45:WU01:FS00:0xa7:   Platform: win32 10
00:48:45:WU01:FS00:0xa7:       Bits: 64
00:48:45:WU01:FS00:0xa7:       Mode: Release
00:48:45:WU01:FS00:0xa7:************************************ System ************************************
00:48:45:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
00:48:45:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
00:48:45:WU01:FS00:0xa7:       CPUs: 8
00:48:45:WU01:FS00:0xa7:     Memory: 63.85GiB
00:48:45:WU01:FS00:0xa7:Free Memory: 50.23GiB
00:48:45:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
00:48:45:WU01:FS00:0xa7: OS Version: 6.2
00:48:45:WU01:FS00:0xa7:Has Battery: true
00:48:45:WU01:FS00:0xa7: On Battery: false
00:48:45:WU01:FS00:0xa7: UTC Offset: -4
00:48:45:WU01:FS00:0xa7:        PID: 27268
00:48:45:WU01:FS00:0xa7:        CWD: C:\Users\JMill\AppData\Roaming\FAHClient\work
00:48:45:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
00:48:45:WU01:FS00:0xa7:    Version: 0.0.19
00:48:45:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:48:45:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:48:45:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
00:48:45:WU01:FS00:0xa7:       Date: Nov 25 2019
00:48:45:WU01:FS00:0xa7:       Time: 17:12:41
00:48:45:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
00:48:45:WU01:FS00:0xa7:************************************ Build *************************************
00:48:45:WU01:FS00:0xa7:       SIMD: avx_256
00:48:45:WU01:FS00:0xa7:********************************************************************************
00:48:45:WU01:FS00:0xa7:Project: 16925 (Run 13, Clone 57, Gen 1)
00:48:45:WU01:FS00:0xa7:Unit: 0x0000000181d528e55f70edb9232e151c
00:48:45:WU01:FS00:0xa7:Reading tar file core.xml
00:48:45:WU01:FS00:0xa7:Reading tar file frame1.tpr
00:48:45:WU01:FS00:0xa7:Digital signatures verified
00:48:45:WU01:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 8
00:48:45:WU01:FS00:0xa7:Steps: first=500000 total=500000
00:53:30:WU00:FS02:0x22:Checkpoint completed at step 500000
*********************** Log Started 2020-10-29T22:00:09Z ***********************
22:00:09:******************************* libFAH ********************************
22:00:09:           Date: Oct 20 2020
22:00:09:           Time: 13:36:55
22:00:09:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
22:00:09:         Branch: master
22:00:09:       Compiler: Visual C++ 2015
22:00:09:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:00:09:       Platform: win32 10
22:00:09:           Bits: 32
22:00:09:           Mode: Release
22:00:09:****************************** FAHClient ******************************
22:00:09:        Version: 7.6.21
22:00:09:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:00:09:      Copyright: 2020 foldingathome.org
22:00:09:       Homepage: https://foldingathome.org/
22:00:09:           Time: 13:41:04
22:00:09:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
22:00:09:           Bits: 32
22:00:09:           Args: --open-web-control
22:00:09:         Config: C:\Users\JMill\AppData\Roaming\FAHClient\config.xml
22:00:09:******************************** CBang ********************************
22:00:09:           Time: 11:36:18
22:00:09:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
22:00:09:           Bits: 32
22:00:09:******************************* System ********************************
22:00:09:            CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
22:00:09:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:00:09:           CPUs: 8
22:00:09:         Memory: 63.85GiB
22:00:09:    Free Memory: 55.27GiB
22:00:09:        Threads: WINDOWS_THREADS
22:00:09:     OS Version: 6.2
22:00:09:    Has Battery: true
22:00:09:     On Battery: false
22:00:09:     UTC Offset: -4
22:00:09:            PID: 11888
22:00:09:            CWD: C:\Users\JMill\AppData\Roaming\FAHClient
22:00:09:  Win32 Service: false
22:00:09:             OS: Windows 10 Enterprise
22:00:09:        OS Arch: AMD64
22:00:09:           GPUs: 2
22:00:09:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
22:00:09:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:5 GP107M [GeForce GTX 1050 Mobile]
22:00:09:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.1
22:00:09:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:457.9
22:00:09:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:29.20
22:00:09:***********************************************************************
22:00:09:<config>
22:00:09:  <!-- Folding Slot Configuration -->
22:00:09:  <cause v='COVID_19'/>
22:00:09:
22:00:09:  <!-- Network -->
22:00:09:  <proxy v=':8080'/>
22:00:09:
22:00:09:  <!-- Slot Control -->
22:00:09:  <power v='full'/>
22:00:09:
22:00:09:  <!-- User Information -->
22:00:09:  <passkey v='*****'/>
22:00:09:  <team v='224497'/>
22:00:09:  <user v='Sir_Launcelot'/>
22:00:09:
22:00:09:  <!-- Folding Slots -->
22:00:09:  <slot id='0' type='CPU'>
22:00:09:    <cpus v='8'/>
22:00:09:  </slot>
22:00:09:  <slot id='1' type='GPU'>
22:00:09:    <gpu-beta v='False'/>
22:00:09:    <paused v='true'/>
22:00:09:    <pci-bus v='0'/>
22:00:09:    <pci-slot v='2'/>
22:00:09:  </slot>
22:00:09:  <slot id='2' type='GPU'>
22:00:09:    <pci-bus v='1'/>
22:00:09:    <pci-slot v='0'/>
22:00:09:  </slot>
22:00:09:</config>
22:00:09:Trying to access database...
22:00:09:Successfully acquired database lock
22:00:09:FS00:Initialized folding slot 00: cpu:8
22:00:09:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 Gen9p5/GT2 [UHD Graphics 630].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
22:00:09:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 Gen9p5/GT2 [UHD Graphics 630].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
22:00:09:FS02:Initialized folding slot 02: gpu:1:0 GP107M [GeForce GTX 1050 Mobile]
22:00:09:WU01:FS00:Starting
22:00:09:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\JMill\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11888 -checkpoint 15 -np 8
22:00:09:WU01:FS00:Started FahCore on PID 17068
22:00:09:WU01:FS00:Core PID:18100
22:00:09:WU01:FS00:FahCore 0xa7 started
22:00:09:WU00:FS02:Starting
22:00:10:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\JMill\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11888 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
22:00:10:WU00:FS02:Started FahCore on PID 7792
22:00:10:WU00:FS02:Core PID:13536
22:00:10:WU00:FS02:FahCore 0x22 started
22:00:10:WU01:FS00:0xa7:*********************** Log Started 2020-10-29T22:00:09Z ***********************
22:00:10:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:00:10:WU01:FS00:0xa7:       Type: 0xa7
22:00:10:WU01:FS00:0xa7:       Core: Gromacs
22:00:10:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 17068 -checkpoint 15 -np
22:00:10:WU01:FS00:0xa7:             8
22:00:10:WU01:FS00:0xa7:************************************ CBang *************************************
22:00:10:WU01:FS00:0xa7:       Date: Nov 27 2019
22:00:10:WU01:FS00:0xa7:       Time: 03:40:09
22:00:10:WU01:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
22:00:10:WU01:FS00:0xa7:     Branch: master
22:00:10:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
22:00:10:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:00:10:WU01:FS00:0xa7:   Platform: win32 10
22:00:10:WU01:FS00:0xa7:       Bits: 64
22:00:10:WU01:FS00:0xa7:       Mode: Release
22:00:10:WU01:FS00:0xa7:************************************ System ************************************
22:00:10:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
22:00:10:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:00:10:WU01:FS00:0xa7:       CPUs: 8
22:00:10:WU01:FS00:0xa7:     Memory: 63.85GiB
22:00:10:WU01:FS00:0xa7:Free Memory: 55.23GiB
22:00:10:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
22:00:10:WU01:FS00:0xa7: OS Version: 6.2
22:00:10:WU01:FS00:0xa7:Has Battery: true
22:00:10:WU01:FS00:0xa7: On Battery: false
22:00:10:WU01:FS00:0xa7: UTC Offset: -4
22:00:10:WU01:FS00:0xa7:        PID: 18100
22:00:10:WU01:FS00:0xa7:        CWD: C:\Users\JMill\AppData\Roaming\FAHClient\work
22:00:10:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:00:10:WU01:FS00:0xa7:    Version: 0.0.19
22:00:10:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:00:10:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:00:10:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:00:10:WU01:FS00:0xa7:       Date: Nov 25 2019
22:00:10:WU01:FS00:0xa7:       Time: 17:12:41
22:00:10:WU01:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
22:00:10:WU01:FS00:0xa7:************************************ Build *************************************
22:00:10:WU01:FS00:0xa7:       SIMD: avx_256
22:00:10:WU01:FS00:0xa7:********************************************************************************
22:00:10:WU01:FS00:0xa7:Project: 16925 (Run 13, Clone 57, Gen 1)
22:00:10:WU01:FS00:0xa7:Unit: 0x0000000181d528e55f70edb9232e151c
22:00:10:WU01:FS00:0xa7:Digital signatures verified
22:00:10:WU01:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 8
22:00:10:WU00:FS02:0x22:*********************** Log Started 2020-10-29T22:00:10Z ***********************
22:00:10:WU01:FS00:0xa7:Steps: first=500000 total=500000
22:00:10:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
22:00:10:WU00:FS02:0x22:       Core: Core22
22:00:10:WU00:FS02:0x22:       Type: 0x22
22:00:10:WU00:FS02:0x22:    Version: 0.0.13
22:00:10:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:00:10:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
22:00:10:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
22:00:10:WU00:FS02:0x22:       Date: Sep 19 2020
22:00:10:WU00:FS02:0x22:       Time: 02:35:58
22:00:10:WU00:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
22:00:10:WU00:FS02:0x22:     Branch: core22-0.0.13
22:00:10:WU00:FS02:0x22:   Compiler: Visual C++ 2015
22:00:10:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
22:00:10:WU00:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
22:00:10:WU00:FS02:0x22:   Platform: win32 10
22:00:10:WU00:FS02:0x22:       Bits: 64
22:00:10:WU00:FS02:0x22:       Mode: Release
22:00:10:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:00:10:WU00:FS02:0x22:             <peastman@stanford.edu>
22:00:11:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7792 -checkpoint 15
22:00:11:WU00:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
22:00:11:WU00:FS02:0x22:             nvidia -gpu 0 -gpu-usage 100
22:00:11:WU00:FS02:0x22:************************************ libFAH ************************************
22:00:11:WU00:FS02:0x22:       Date: Sep 7 2020
22:00:11:WU00:FS02:0x22:       Time: 19:09:56
22:00:11:WU00:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
22:00:11:WU00:FS02:0x22:     Branch: HEAD
22:00:11:WU00:FS02:0x22:   Compiler: Visual C++ 2015
22:00:11:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
22:00:11:WU00:FS02:0x22:   Platform: win32 10
22:00:11:WU00:FS02:0x22:       Bits: 64
22:00:11:WU00:FS02:0x22:       Mode: Release
22:00:11:WU00:FS02:0x22:************************************ CBang *************************************
22:00:11:WU00:FS02:0x22:       Time: 19:08:30
22:00:11:WU00:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
22:00:11:WU00:FS02:0x22:************************************ System ************************************
22:00:11:WU00:FS02:0x22:        CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
22:00:11:WU00:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:00:11:WU00:FS02:0x22:       CPUs: 8
22:00:11:WU00:FS02:0x22:     Memory: 63.85GiB
22:00:11:WU00:FS02:0x22:Free Memory: 55.20GiB
22:00:11:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
22:00:11:WU00:FS02:0x22: OS Version: 6.2
22:00:11:WU00:FS02:0x22:Has Battery: true
22:00:11:WU00:FS02:0x22: On Battery: false
22:00:11:WU00:FS02:0x22: UTC Offset: -4
22:00:11:WU00:FS02:0x22:        PID: 13536
22:00:11:WU00:FS02:0x22:        CWD: C:\Users\JMill\AppData\Roaming\FAHClient\work
22:00:11:WU00:FS02:0x22:************************************ OpenMM ************************************
22:00:11:WU00:FS02:0x22:   Revision: 189320d0
22:00:12:WU00:FS02:0x22:********************************************************************************
22:00:12:WU00:FS02:0x22:Project: 14905 (Run 396, Clone 11, Gen 91)
22:00:12:WU00:FS02:0x22:Unit: 0x0000007881d59d695f4ec9da9c1e4bb2
22:00:12:WU00:FS02:0x22:Digital signatures verified
22:00:12:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
22:00:12:WU00:FS02:0x22:Version 0.0.13
22:00:12:WU00:FS02:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
22:00:14:WU00:FS02:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
22:00:14:WU00:FS02:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
22:00:14:WU00:FS02:0x22:  Global context and integrator variables write interval: disabled
22:00:16:WU00:FS02:0x22:There are 4 platforms available.
22:00:16:WU00:FS02:0x22:Platform 0: Reference
22:00:16:WU00:FS02:0x22:Platform 1: CPU
22:00:16:WU00:FS02:0x22:Platform 2: OpenCL
22:00:16:WU00:FS02:0x22:  opencl-device 0 specified
22:00:16:WU00:FS02:0x22:Platform 3: CUDA
22:00:16:WU00:FS02:0x22:  cuda-device 0 specified
22:00:19:17:127.0.0.1:New Web session
22:01:44:WU00:FS02:0x22:Attempting to create CUDA context:
22:01:44:WU00:FS02:0x22:  Configuring platform CUDA
22:02:08:WU00:FS02:0x22:  Using CUDA and gpu 0
22:29:36:WU00:FS02:0x22:Checkpoint completed at step 600000
22:54:26:WU00:FS02:0x22:Checkpoint completed at step 700000
23:18:42:WU00:FS02:0x22:Checkpoint completed at step 800000
23:42:34:WU00:FS02:0x22:Checkpoint completed at step 900000
00:00:05:WARNING:WU01:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
00:00:05:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
00:00:05:WARNING:WU00:FS02:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
00:00:05:WARNING:WU00:FS02:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
Re: BSOD FahCore_a7.exe
Post by foldy »
Does this also happen when you do not run GPU slot and only CPU?
Post by Neil-B »
I believe a fair few of the DPC_WATCHDOG_VIOLATION BSODs are triggered by driver related issues ... have you had any recent patches/updates to drivers that you can roll back and discount?
Have you been adjusting the Windows task priority settings?
By default, FAH allocates one CPU (really, thread) to support data transfers to/from each GPU. You have manually forced all 8 threads to be used by FAHCore_22 wich iss NOT recommended. This leaves zero to support your GPU. Does the problem go away if you reduce your demands on your CPU?
Gennady
Post by Gennady »
This is BSOD inside Nvidia driver:
For some reason, it's blocked the DPC (Differed Procedure Call) for a long period of time. Thus, the system terminated its work.
Something wrong with nvlddmkm.sys(.dll)
It's weird that FahCore_a7 (a CPU dependent process) is having issues with Nvidia drivers :?
Post by foldy »
I think it is the other way, nvidia driver calls for DPC blocked check and process blocking DPC is FahCore_a7. I also see VidSchiUpdateHwSchRunningTime which maybe is new Windows 10 GPU HW Scheduler?
First, as Bruce was trying to point out, you have overcommitted your CPU to CPU folding by assigning all 8 threads to that. That leaves no CPU threads to be used exclusively by the GPU folding core and the driver. Start by reducing the number of CPU threads assigned to CPU folding to 6 or less, the A7 core will not use 7.
