I've set the controller up to "Finish" so the current task will be the last, just in case it goes to the same servers.
Two other PCs are uploading results as usual, to different servers.
The header of the log is:
*********************** Log Started 2020-11-04T21:53:36Z ***********************
21:53:36:******************************* libFAH ********************************
21:53:36: Date: Oct 9 2020
21:53:36: Time: 10:37:10
21:53:36: Revision: 06b99f7701e0d3f883dd14a78b459ad27da23809
21:53:36: Branch: master
21:53:36: Compiler: Visual C++ 2015
21:53:36: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
21:53:36: Platform: win32 10
21:53:36: Bits: 32
21:53:36: Mode: Release
21:53:36:****************************** FAHClient ******************************
21:53:36: Version: 7.6.20
21:53:36: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:53:36: Copyright: 2020 foldingathome.org
21:53:36: Homepage: https://foldingathome.org/
21:53:36: Date: Oct 12 2020
21:53:36: Time: 15:02:06
21:53:36: Revision: c858fe2a8342bfa3e116e00b394d8dfa322ecd18
21:53:36: Bits: 32
21:53:36: Args: --open-web-control
21:53:36: Config: C:\ProgramData\FAHClient\config.xml
21:53:36:******************************** CBang ********************************
21:53:36: Time: 10:29:47
21:53:36: Revision: ab0a6d9e35982b831a74cb2706c569fe46bac2af
21:53:36: Bits: 32
21:53:36:******************************* System ********************************
21:53:36: CPU: Intel(R) Core(TM) i5-9400 CPU @ 2.90GHz
21:53:36: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
21:53:36: CPUs: 6
21:53:36: Memory: 31.81GiB
21:53:36: Free Memory: 25.95GiB
21:53:36: Threads: WINDOWS_THREADS
21:53:36: OS Version: 6.2
21:53:36: Has Battery: false
21:53:36: On Battery: false
21:53:36: UTC Offset: -6
21:53:36: PID: 16308
21:53:36: CWD: C:\ProgramData\FAHClient
21:53:36: Win32 Service: false
21:53:36: OS: Windows 10 Enterprise
21:53:36: OS Arch: AMD64
21:53:36: GPUs: 1
21:53:36: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
21:53:36: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
21:53:36: specified module could not be found.
21:53:36:
21:53:36:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
21:53:36:***********************************************************************
21:53:37:<config>
21:53:37: <!-- Folding Core -->
21:53:37: <checkpoint v='10'/>
21:53:37:
21:53:37: <!-- HTTP Server -->
21:53:37: <allow v='127.0.0.1 192.168.0.0/24'/>
21:53:37:
21:53:37: <!-- Network -->
21:53:37: <proxy v=':8080'/>
21:53:37:
21:53:37: <!-- Remote Command Server -->
21:53:37: <command-allow-no-pass v='127.0.0.1 192.168.0.0/24'/>
21:53:37:
21:53:37: <!-- User Information -->
21:53:37: <passkey v='*****'/>
21:53:37: <team v='134653'/>
21:53:37: <user v='Bert_Hyman'/>
21:53:37:
21:53:37: <!-- Folding Slots -->
21:53:37: <slot id='0' type='CPU'>
21:53:37: <paused v='true'/>
21:53:37: </slot>
21:53:37: <slot id='1' type='GPU'>
21:53:37: <pci-bus v='0'/>
21:53:37: <pci-slot v='2'/>
21:53:37: </slot>
21:53:37:</config>Code: Select all
22:05:43:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16812 run:1 clone:1168 gen:14 core:0xa8 unit:0x00000013b2aec48a5f8ddf78fc178604
22:05:43:WU00:FS00:Uploading 8.40MiB to 178.174.196.138
22:05:43:WU00:FS00:Connecting to 178.174.196.138:8080
22:06:14:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
22:06:14:WU00:FS00:Trying to send results to collection server
22:06:14:WU00:FS00:Uploading 8.40MiB to 130.237.11.145
22:06:14:WU00:FS00:Connecting to 130.237.11.145:8080
22:06:35:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
22:06:35:WU00:FS00:Connecting to 130.237.11.145:80
22:06:56:ERROR:WU00:FS00:Exception: Failed to connect to 130.237.11.145:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:07:58:WU01:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
22:12:22:WU01:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
22:12:35:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16812 run:1 clone:1168 gen:14 core:0xa8 unit:0x00000013b2aec48a5f8ddf78fc178604
22:12:35:WU00:FS00:Uploading 8.40MiB to 178.174.196.138
22:12:35:WU00:FS00:Connecting to 178.174.196.138:8080
22:13:05:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
22:13:05:WU00:FS00:Trying to send results to collection server
22:13:05:WU00:FS00:Uploading 8.40MiB to 130.237.11.145
22:13:05:WU00:FS00:Connecting to 130.237.11.145:8080
22:13:26:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
22:13:26:WU00:FS00:Connecting to 130.237.11.145:80
22:13:47:ERROR:WU00:FS00:Exception: Failed to connect to 130.237.11.145:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:16:46:WU01:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
22:21:09:WU01:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
22:23:40:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16812 run:1 clone:1168 gen:14 core:0xa8 unit:0x00000013b2aec48a5f8ddf78fc178604
22:23:40:WU00:FS00:Uploading 8.40MiB to 178.174.196.138
22:23:40:WU00:FS00:Connecting to 178.174.196.138:8080
22:24:10:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
22:24:10:WU00:FS00:Trying to send results to collection server
22:24:10:WU00:FS00:Uploading 8.40MiB to 130.237.11.145
22:24:10:WU00:FS00:Connecting to 130.237.11.145:8080
22:24:31:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
22:24:31:WU00:FS00:Connecting to 130.237.11.145:80
22:24:53:ERROR:WU00:FS00:Exception: Failed to connect to 130.237.11.145:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:25:30:WU01:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
22:29:53:WU01:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
22:34:15:WU01:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
22:38:38:WU01:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
22:41:37:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16812 run:1 clone:1168 gen:14 core:0xa8 unit:0x00000013b2aec48a5f8ddf78fc178604
22:41:37:WU00:FS00:Uploading 8.40MiB to 178.174.196.138
22:41:37:WU00:FS00:Connecting to 178.174.196.138:8080
22:42:07:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
22:42:07:WU00:FS00:Trying to send results to collection server
22:42:07:WU00:FS00:Uploading 8.40MiB to 130.237.11.145
22:42:07:WU00:FS00:Connecting to 130.237.11.145:8080
22:42:28:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
22:42:28:WU00:FS00:Connecting to 130.237.11.145:80
22:42:49:ERROR:WU00:FS00:Exception: Failed to connect to 130.237.11.145:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:43:00:WU01:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
22:47:21:WU01:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
22:51:44:WU01:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
22:56:06:WU01:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
23:00:29:WU01:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
23:04:51:WU01:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
23:09:14:WU01:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
23:10:39:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16812 run:1 clone:1168 gen:14 core:0xa8 unit:0x00000013b2aec48a5f8ddf78fc178604
23:10:39:WU00:FS00:Uploading 8.40MiB to 178.174.196.138
23:10:39:WU00:FS00:Connecting to 178.174.196.138:8080
23:11:09:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
23:11:09:WU00:FS00:Trying to send results to collection server
23:11:10:WU00:FS00:Uploading 8.40MiB to 130.237.11.145
23:11:10:WU00:FS00:Connecting to 130.237.11.145:8080
23:11:31:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
23:11:31:WU00:FS00:Connecting to 130.237.11.145:80
23:11:52:ERROR:WU00:FS00:Exception: Failed to connect to 130.237.11.145:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:13:36:WU01:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
23:17:59:WU01:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
23:22:20:WU01:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
23:26:42:WU01:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
23:31:05:WU01:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
