GTX 1060 3GB only 160k PPD
sptn.
Post by sptn. »
Hello Everyone,
as some may know I reactivated an old machine and upgraded it a bit for part time folding.
The machine is up and running. My only concern is, that the GPU only produces 160K PPD.
As discussed in my initial thread, one reason could be that we shut down the machine every day (after finishing the last WU) and change users including passkeys.
But lately I checked and found the GPU temp at ~69 deg and the GPU fan at around 68 deg. Maybe I do not get the full bonus due to changing users and passkeys but shouldn't the graphics card fold as fast as it can? 68% fan speed sounds enthusiastic but not like fill load.
Could this be a driver problem? Could this be a Linux problem?
CPU: Intel® Core2 Quad Processor Q9400S 2.66 GHz
RAM: Geil 4GB
Mainboard: Biostar g31d-m7
GPU: Nvidia GTX1060 3GB
OS: Ubuntu 20.04
Nvidia Driver: 440.95
Today's log:
*********************** Log Started 2020-11-03T05:24:23Z ***********************
05:24:23:******************************* libFAH ********************************
05:24:23:           Date: Oct 8 2020
05:24:23:           Time: 19:34:47
05:24:23:       Revision: 06b99f7701e0d3f883dd14a78b459ad27da23809
05:24:23:         Branch: master
05:24:23:       Compiler: GNU 8.3.0
05:24:23:        Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections
05:24:23:                 -O3 -funroll-loops -fno-pie
05:24:23:       Platform: linux2 5.8.0-1-amd64
05:24:23:           Bits: 64
05:24:23:           Mode: Release
05:24:23:****************************** FAHClient ******************************
05:24:23:        Version: 7.6.20
05:24:23:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:24:23:      Copyright: 2020 foldingathome.org
05:24:23:       Homepage: https://foldingathome.org/
05:24:23:           Date: Oct 12 2020
05:24:23:           Time: 22:00:41
05:24:23:       Revision: c858fe2a8342bfa3e116e00b394d8dfa322ecd18
05:24:23:           Bits: 64
05:24:23:           Args: -v --chdir /var/snap/folding-at-home-fcole90/common
05:24:23:         Config: /var/snap/folding-at-home-fcole90/common/config.xml
05:24:23:******************************** CBang ********************************
05:24:23:           Time: 19:34:20
05:24:23:       Revision: ab0a6d9e35982b831a74cb2706c569fe46bac2af
05:24:23:                 -O3 -funroll-loops -fno-pie -fPIC
05:24:23:           Bits: 64
05:24:23:******************************* System ********************************
05:24:23:            CPU: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
05:24:23:         CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
05:24:23:           CPUs: 4
05:24:23:         Memory: 3.84GiB
05:24:23:    Free Memory: 3.20GiB
05:24:23:        Threads: POSIX_THREADS
05:24:23:     OS Version: 5.4
05:24:23:    Has Battery: false
05:24:23:     On Battery: false
05:24:23:     UTC Offset: 1
05:24:23:            PID: 789
05:24:23:            CWD: /var/snap/folding-at-home-fcole90/48
05:24:23:             OS: Linux 5.4.0-52-generic x86_64
05:24:23:        OS Arch: AMD64
05:24:23:           GPUs: 1
05:24:23:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 3GB] 3935
05:24:23:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
05:24:23:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:440.95
05:24:23:***********************************************************************
05:24:23:<config>
05:24:23:  <!-- Client Control -->
05:24:23:  <client-threads v='6'/>
05:24:23:  <cycle-rate v='4'/>
05:24:23:  <cycles v='-1'/>
05:24:23:  <disable-sleep-when-active v='true'/>
05:24:23:  <exit-when-done v='false'/>
05:24:23:  <fold-anon v='false'/>
05:24:23:  <idle-seconds v='300'/>
05:24:23:  <open-web-control v='false'/>
05:24:23:  <update-gpus-txt v='true'/>
05:24:23:
05:24:23:  <!-- Configuration -->
05:24:23:  <config-rotate v='true'/>
05:24:23:  <config-rotate-dir v='configs'/>
05:24:23:  <config-rotate-max v='16'/>
05:24:23:
05:24:23:  <!-- Debugging -->
05:24:23:  <assignment-servers>
05:24:23:    assign1.foldingathome.org assign2.foldingathome.org assign3.foldingathome.org assign4.foldingathome.org
05:24:23:  </assignment-servers>
05:24:23:  <auth-as v='true'/>
05:24:23:  <capture-directory v='capture'/>
05:24:23:  <capture-on-error v='false'/>
05:24:23:  <capture-packets v='false'/>
05:24:23:  <capture-requests v='false'/>
05:24:23:  <capture-responses v='false'/>
05:24:23:  <capture-sockets v='false'/>
05:24:23:  <debug-sockets v='false'/>
05:24:23:  <exception-locations v='true'/>
05:24:23:  <stack-traces v='false'/>
05:24:23:
05:24:23:  <!-- Error Handling -->
05:24:23:  <max-slot-errors v='10'/>
05:24:23:  <max-unit-errors v='5'/>
05:24:23:
05:24:23:  <!-- Folding Core -->
05:24:23:  <checkpoint v='15'/>
05:24:23:  <core-priority v='idle'/>
05:24:23:  <cpu-usage v='100'/>
05:24:23:  <gpu-usage v='100'/>
05:24:23:  <no-assembly v='false'/>
05:24:23:
05:24:23:  <!-- Folding Slot Configuration -->
05:24:23:  <cause v='ANY'/>
05:24:23:  <client-subtype v='LINUX'/>
05:24:23:  <client-type v='normal'/>
05:24:23:  <cpu-species v='X86_PENTIUM_II'/>
05:24:23:  <cpu-type v='AMD64'/>
05:24:23:  <cpus v='-1'/>
05:24:23:  <disable-viz v='false'/>
05:24:23:  <gpu v='true'/>
05:24:23:  <gpu-beta v='false'/>
05:24:23:  <max-packet-size v='normal'/>
05:24:23:  <os-species v='UNKNOWN'/>
05:24:23:  <os-type v='LINUX'/>
05:24:23:  <project-key v='0'/>
05:24:23:  <smp v='true'/>
05:24:23:
05:24:23:  <!-- GUI -->
05:24:23:  <gui-enabled v='true'/>
05:24:23:
05:24:23:  <!-- HTTP Server -->
05:24:23:  <allow v='127.0.0.1'/>
05:24:23:  <connection-timeout v='60'/>
05:24:23:  <deny v='0/0'/>
05:24:23:  <http-addresses v='0:7396'/>
05:24:23:  <https-addresses v=''/>
05:24:23:  <max-connect-time v='900'/>
05:24:23:  <max-connections v='800'/>
05:24:23:  <max-request-length v='52428800'/>
05:24:23:  <min-connect-time v='300'/>
05:24:23:
05:24:23:  <!-- Logging -->
05:24:23:  <log v='log.txt'/>
05:24:23:  <log-color v='true'/>
05:24:23:  <log-crlf v='false'/>
05:24:23:  <log-date v='false'/>
05:24:23:  <log-date-periodically v='21600'/>
05:24:23:  <log-domain v='false'/>
05:24:23:  <log-header v='true'/>
05:24:23:  <log-level v='true'/>
05:24:23:  <log-no-info-header v='true'/>
05:24:23:  <log-redirect v='false'/>
05:24:23:  <log-rotate v='true'/>
05:24:23:  <log-rotate-dir v='logs'/>
05:24:23:  <log-rotate-max v='16'/>
05:24:23:  <log-short-level v='false'/>
05:24:23:  <log-simple-domains v='true'/>
05:24:23:  <log-thread-id v='false'/>
05:24:23:  <log-thread-prefix v='true'/>
05:24:23:  <log-time v='true'/>
05:24:23:  <log-to-screen v='true'/>
05:24:23:  <log-truncate v='false'/>
05:24:23:  <verbosity v='3'/>
05:24:23:
05:24:23:  <!-- Network -->
05:24:23:  <proxy v=''/>
05:24:23:  <proxy-enable v='false'/>
05:24:23:  <proxy-pass v='*****'/>
05:24:23:  <proxy-user v=''/>
05:24:23:
05:24:23:  <!-- Process Control -->
05:24:23:  <child v='false'/>
05:24:23:  <daemon v='false'/>
05:24:23:  <fork v='false'/>
05:24:23:  <pid v='false'/>
05:24:23:  <pid-file v='FAHClient.pid'/>
05:24:23:  <respawn v='false'/>
05:24:23:  <service v='false'/>
05:24:23:
05:24:23:  <!-- Remote Command Server -->
05:24:23:  <command-address v='0.0.0.0'/>
05:24:23:  <command-allow-no-pass v='127.0.0.1'/>
05:24:23:  <command-deny-no-pass v='0/0'/>
05:24:23:  <command-enable v='true'/>
05:24:23:  <command-port v='36330'/>
05:24:23:
05:24:23:  <!-- Slot Control -->
05:24:23:  <auto-conf v='true'/>
05:24:23:  <idle v='false'/>
05:24:23:  <max-shutdown-wait v='60'/>
05:24:23:  <pause-on-battery v='true'/>
05:24:23:  <pause-on-start v='false'/>
05:24:23:  <paused v='false'/>
05:24:23:  <power v='full'/>
05:24:23:
05:24:23:  <!-- User Information -->
05:24:23:  <machine-id v='0'/>
05:24:23:  <passkey v='*****'/>
05:24:23:  <team v='10817'/>
05:24:23:  <user v='minosDD'/>
05:24:23:
05:24:23:  <!-- Web Server -->
05:24:23:  <web-allow v='127.0.0.1'/>
05:24:23:  <web-deny v='0/0'/>
05:24:23:  <web-enable v='true'/>
05:24:23:
05:24:23:  <!-- Web Server Sessions -->
05:24:23:  <session-cookie v='sid'/>
05:24:23:  <session-lifetime v='86400'/>
05:24:23:  <session-timeout v='3600'/>
05:24:23:
05:24:23:  <!-- Work Unit Control -->
05:24:23:  <dump-after-deadline v='true'/>
05:24:23:  <max-queue v='16'/>
05:24:23:  <max-units v='0'/>
05:24:23:  <next-unit-percentage v='99'/>
05:24:23:  <stall-detection-enabled v='false'/>
05:24:23:  <stall-percent v='5'/>
05:24:23:  <stall-timeout v='1800'/>
05:24:23:
05:24:23:  <!-- Folding Slots -->
05:24:23:  <slot id='0' type='CPU'/>
05:24:23:  <slot id='1' type='GPU'>
05:24:23:    <pci-bus v='1'/>
05:24:23:    <pci-slot v='0'/>
05:24:23:  </slot>
05:24:23:</config>
05:24:23:Trying to access database...
05:24:24:Successfully acquired database lock
05:24:24:FS00:Initialized folding slot 00: cpu:3 - READY
05:24:24:FS01:Initialized folding slot 01: gpu:1:0 GP106 [GeForce GTX 1060 3GB] 3935 - READY
05:24:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
05:24:24:WU01:FS01:Connecting to assign1.foldingathome.org:80
05:24:25:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
05:24:25:WU00:FS00:Connecting to assign2.foldingathome.org:80
05:24:25:WU01:FS01:Assigned to work server 129.213.157.105
05:24:25:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GP106 [GeForce GTX 1060 3GB] 3935 - READY from 129.213.157.105
05:24:25:WU01:FS01:Connecting to 129.213.157.105:8080
05:24:26:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
05:24:26:WU00:FS00:Connecting to assign3.foldingathome.org:80
05:24:26:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
05:24:26:WU00:FS00:Connecting to assign4.foldingathome.org:80
05:24:27:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
05:24:27:ERROR:WU00:FS00:Exception: Could not get an assignment
05:24:27:WU00:FS00:Connecting to assign1.foldingathome.org:80
05:24:27:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
05:24:27:WU00:FS00:Connecting to assign2.foldingathome.org:80
05:24:28:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
05:24:28:WU00:FS00:Connecting to assign3.foldingathome.org:80
05:24:28:WU00:FS00:Assigned to work server 178.174.196.138
05:24:29:WU00:FS00:Requesting new work unit for slot 00: cpu:3 - READY from 178.174.196.138
05:24:29:WU00:FS00:Connecting to 178.174.196.138:8080
05:24:32:WU01:FS01:Downloading 17.29MiB
05:24:38:WU01:FS01:Download 37.96%
05:24:43:WU01:FS01:Download complete
05:24:43:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14909 run:26 clone:13 gen:51 core:0x22 unit:0x0000004281d59d695f5260246cc07293
05:24:44:WU01:FS01:Starting
05:24:44:WU01:FS01:Running FahCore: /snap/folding-at-home-fcole90/48/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 789 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
05:24:44:WU01:FS01:Started FahCore on PID 1267
05:24:44:WU01:FS01:Core PID:1271
05:24:44:WU01:FS01:FahCore 0x22 started
05:24:46:WU01:FS01:0x22:*********************** Log Started 2020-11-03T05:24:46Z ***********************
05:24:46:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
05:24:46:WU01:FS01:0x22:       Core: Core22
05:24:46:WU01:FS01:0x22:       Type: 0x22
05:24:46:WU01:FS01:0x22:    Version: 0.0.13
05:24:46:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:24:46:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
05:24:46:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
05:24:46:WU01:FS01:0x22:       Date: Sep 19 2020
05:24:46:WU01:FS01:0x22:       Time: 01:10:35
05:24:46:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
05:24:46:WU01:FS01:0x22:     Branch: core22-0.0.13
05:24:46:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
05:24:46:WU01:FS01:0x22:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
05:24:46:WU01:FS01:0x22:             -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
05:24:46:WU01:FS01:0x22:   Platform: linux2 4.19.76-linuxkit
05:24:46:WU01:FS01:0x22:       Bits: 64
05:24:46:WU01:FS01:0x22:       Mode: Release
05:24:46:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
05:24:46:WU01:FS01:0x22:             <peastman@stanford.edu>
05:24:46:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1267 -checkpoint 15
05:24:46:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
05:24:46:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
05:24:46:WU01:FS01:0x22:************************************ libFAH ************************************
05:24:46:WU01:FS01:0x22:       Date: Sep 15 2020
05:24:46:WU01:FS01:0x22:       Time: 05:14:43
05:24:46:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
05:24:46:WU01:FS01:0x22:     Branch: HEAD
05:24:46:WU01:FS01:0x22:************************************ CBang *************************************
05:24:46:WU01:FS01:0x22:       Time: 05:11:04
05:24:46:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
05:24:46:WU01:FS01:0x22:             -funroll-loops -fPIC
05:24:46:WU01:FS01:0x22:************************************ System ************************************
05:24:46:WU01:FS01:0x22:        CPU: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
05:24:46:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
05:24:46:WU01:FS01:0x22:       CPUs: 4
05:24:46:WU01:FS01:0x22:     Memory: 3.84GiB
05:24:46:WU01:FS01:0x22:Free Memory: 2.98GiB
05:24:46:WU01:FS01:0x22:    Threads: POSIX_THREADS
05:24:46:WU01:FS01:0x22: OS Version: 5.4
05:24:46:WU01:FS01:0x22:Has Battery: false
05:24:46:WU01:FS01:0x22: On Battery: false
05:24:46:WU01:FS01:0x22: UTC Offset: 1
05:24:46:WU01:FS01:0x22:        PID: 1271
05:24:46:WU01:FS01:0x22:        CWD: /var/snap/folding-at-home-fcole90/common/work
05:24:46:WU01:FS01:0x22:************************************ OpenMM ************************************
05:24:46:WU01:FS01:0x22:   Revision: 189320d0
05:24:46:WU01:FS01:0x22:********************************************************************************
05:24:46:WU01:FS01:0x22:Project: 14909 (Run 26, Clone 13, Gen 51)
05:24:46:WU01:FS01:0x22:Unit: 0x0000004281d59d695f5260246cc07293
05:24:46:WU01:FS01:0x22:Reading tar file core.xml
05:24:46:WU01:FS01:0x22:Reading tar file integrator.xml
05:24:46:WU01:FS01:0x22:Reading tar file state.xml
05:24:47:WU01:FS01:0x22:Reading tar file system.xml
05:24:48:WU01:FS01:0x22:Digital signatures verified
05:24:48:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
05:24:48:WU01:FS01:0x22:Version 0.0.13
05:24:48:WU01:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
05:24:48:WU01:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
05:24:48:WU01:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
05:24:48:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
05:24:52:WU01:FS01:0x22:There are 4 platforms available.
05:24:52:WU01:FS01:0x22:Platform 0: Reference
05:24:52:WU01:FS01:0x22:Platform 1: CPU
05:24:52:WU01:FS01:0x22:Platform 2: OpenCL
05:24:52:WU01:FS01:0x22:  opencl-device 0 specified
05:24:52:WU01:FS01:0x22:Platform 3: CUDA
05:24:52:WU01:FS01:0x22:  cuda-device 0 specified
05:25:00:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
05:25:04:WU01:FS01:0x22:Attempting to create CUDA context:
05:25:04:WU01:FS01:0x22:  Configuring platform CUDA
05:25:27:WU00:FS00:Connecting to assign1.foldingathome.org:80
05:25:28:WU00:FS00:Assigned to work server 178.174.196.138
05:25:28:WU00:FS00:Requesting new work unit for slot 00: cpu:3 - READY from 178.174.196.138
05:25:28:WU00:FS00:Connecting to 178.174.196.138:8080
05:25:28:ERROR:WU00:FS00:Exception: Server did not assign work unit
05:25:50:WU01:FS01:0x22:  Using CUDA and gpu 0
05:25:50:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
Thanks in advance.
Regards Tobi!
aetch
Re: GTX 1060 3GB only 160k PPD
Post by aetch »
Don't equate temperature to load.
The airflow through your computer, room temperature, gpu cooling solution will all have different effects on a loaded up graphics card.
I changed my setup so both my folding cards are in the same machine. They're both running 95-100% load but on reduced power targets (~60%), one is 78 deg, the other is 62 deg.
Take a look at the NVIDIA-SMI command, it's in the Windows and linux drivers and can be used to both monitor and manipulate your graphics cards.
Low score, hmmm.
Changing passkey + userID - I know there is a minimum of 10 units returned before a bonus can be earned but I don't know if that's per slot, within a time period, or just total for that userID + passkey (assuming the passkey has been entered correctly and is valid).
Part-time use - The work unit has got to be returned within the initial timeout period to earn bonus points, after that it's down to base points. If you hit the expiry, oh dear, the unit is dropped and no points (well, I think that's what happens anyway).
Folding speed - The card will fold as fast as you let it but there's no guarantee the work unit is big enough to fully utilise it. Others can advise better but it's possible your processor is holding you back as well, the gpu needs a dedicate cpu thread to handle memory swaps between the system RAM and gpu RAM as well as to carry out sanity checks on the progress of your gpu.
These are only my thoughts and may be completely wrong.
sptn.
Post by sptn. »
aetch wrote:Don't equate temperature to load.
Absolutely. You are totally right. If this is the case I never expected such a low fan speed and GPU-temp at room temperature.
I will check the GPU load using the NVIDIA-SMI tool. This is what I needed. When it says ~100% the changing usernames and passkeys have to be the reason.
EDIT: I checked... Utilization 97%. So it is most likey the passkey
| NVIDIA-SMI 440.95.01    Driver Version: 440.95.01    CUDA Version: 10.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 106...  Off  | 00000000:01:00.0  On |                  N/A |
| 69%   68C    P2   110W / 120W |    447MiB /  3011MiB |     97%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0       988      G   /usr/lib/xorg/Xorg                            94MiB |
|    0      1307      G   /usr/bin/gnome-shell                         174MiB |
|    0      6404      C   .../64bit/22-0.0.13/Core_22.fah/FahCore_22   173MiB |
aetch wrote:...Changing passkey + userID - I know there is a minimum of 10 units returned before a bonus can be earned but I don't know if that's per slot, within a time period, or just total for that userID + passkey (assuming the passkey has been entered correctly and is valid).
Part-time use - The work unit has got to be returned within the initial timeout period to earn bonus points, after that it's down to base points. If you hit the expiry, oh dear, the unit is dropped and no points (well, I think that's what happens anyway)...
The return of 10 WUs is per combination of username/passkey, it isn't tied to a Slot or system or team. Once a combination is qualified, it remains until it is disqualified.
A WU that reached expiry deadline will get zero points and count against your >=80% completion rate. That means if you folded 10 WUs and 3 of those WUs reached the expiry deadline, you will not qualify for bonus since your completion rate is 70% which is less than 80% required. Please note that this is overall completion rate, not the last 10 WUs you submitted.
The points are allocated to the username/passkey combination that was when the WU was assigned. Thus, if you downloaded a WU with UsernameA/PasskeyA and then during the middle of the WU, changed it to UsernameB/PasskeyB, the points at the end will be allocated to UsernameA/PasskeyA.
Changing passkeys and/or usernames is absolutely not the way to maximize PPDs. If you judge by the WU count, are you talking about fewer wus per day? That won't change although it might be limited by your power limits reducing your actual performance.
Your GPU has 1152 shader cores which is neither particularly large or small compared to other active GPUs. It's enough to reduce the OpenCL performance for especially small proteins. I have not evaluated that effect when running CUDA.
sptn.
Post by sptn. »
I found the problem why the Bonus does not kick in....
I have a passkey and I entered it correct (copied it from the email, several times)
But checking the "recent CPUs" - Page of FAH the work units of this client are all marked as no bonus counted (0).
The problem seems to be that the client does not want to eat my passkey. It says it matches, but at the end the bonus does not kick in.
I read the advice, to use a separate passkey fot each client. But on the FAH FAQ page it says "Use one and only one Passkey for all clients". What is adviced, one or several passkeys?
I am using a second passkey now and see if that works.
sptn. wrote:...I read the advice, to use a separate passkey fot each client. But on the FAH FAQ page it says "Use one and only one Passkey for all clients". What is adviced, one or several passkeys?
Both options are available for donors. However, I personally choose to stick with a single combination of username/passkey across all my clients.
You can also check the status of your username/passkey combination by using this site: https://apps.foldingathome.org/bonus
sptn.
Post by sptn. »
Yep, I already used it. For the new passkey no information is available, I guess because no WUs were completed using it.
But that means there is a different reason why the passkey is not accepted.
When you copied it, did you accidentally include the trailing space? Have you verified that the config.xml has the same passkey that is in the email?
sptn.
Post by sptn. »
PantherX wrote:When you copied it, did you accidentally include the trailing space? Have you verified that the config.xml has the same passkey that is in the email?
Yep, I know this problem from other software. I am sure I just copied the relevant numbers and letters.
The Config-File says nothing about a passkey...
<config>
  <core-priority v='low'/>
  <!-- Network -->
  <proxy v=':8080'/>
  <power v='full'/>
  <team v='10817'/>
  <user v='sptn.'/>
    <pci-bus v='1'/>
    <pci-slot v='0'/>
  </slot>
</config>
But the log does...
*********************** Log Started 2020-11-12T08:28:45Z ***********************
08:28:45:******************************* libFAH ********************************
08:28:45:           Date: Oct 8 2020
08:28:45:           Time: 19:34:47
08:28:45:       Revision: 06b99f7701e0d3f883dd14a78b459ad27da23809
08:28:45:         Branch: master
08:28:45:       Compiler: GNU 8.3.0
08:28:45:        Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections
08:28:45:                 -O3 -funroll-loops -fno-pie
08:28:45:       Platform: linux2 5.8.0-1-amd64
08:28:45:           Bits: 64
08:28:45:           Mode: Release
08:28:45:****************************** FAHClient ******************************
08:28:45:        Version: 7.6.20
08:28:45:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:28:45:      Copyright: 2020 foldingathome.org
08:28:45:       Homepage: https://foldingathome.org/
08:28:45:           Date: Oct 12 2020
08:28:45:           Time: 22:00:41
08:28:45:       Revision: c858fe2a8342bfa3e116e00b394d8dfa322ecd18
08:28:45:           Bits: 64
08:28:45:           Args: -v --chdir /var/snap/folding-at-home-fcole90/common
08:28:45:         Config: /var/snap/folding-at-home-fcole90/common/config.xml
08:28:45:******************************** CBang ********************************
08:28:45:           Time: 19:34:20
08:28:45:       Revision: ab0a6d9e35982b831a74cb2706c569fe46bac2af
08:28:45:                 -O3 -funroll-loops -fno-pie -fPIC
08:28:45:           Bits: 64
08:28:45:******************************* System ********************************
08:28:45:            CPU: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
08:28:45:         CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
08:28:45:           CPUs: 4
08:28:45:         Memory: 3.84GiB
08:28:45:    Free Memory: 3.25GiB
08:28:45:        Threads: POSIX_THREADS
08:28:45:     OS Version: 5.4
08:28:45:    Has Battery: false
08:28:45:     On Battery: false
08:28:45:     UTC Offset: 1
08:28:45:            PID: 773
08:28:45:            CWD: /var/snap/folding-at-home-fcole90/48
08:28:45:             OS: Linux 5.4.0-52-generic x86_64
08:28:45:        OS Arch: AMD64
08:28:45:           GPUs: 1
08:28:45:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 3GB] 3935
08:28:45:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
08:28:45:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:440.95
08:28:45:***********************************************************************
08:28:45:<config>
08:28:45:  <!-- Client Control -->
08:28:45:  <client-threads v='6'/>
08:28:45:  <cycle-rate v='4'/>
08:28:45:  <cycles v='-1'/>
08:28:45:  <disable-sleep-when-active v='true'/>
08:28:45:  <exit-when-done v='false'/>
08:28:45:  <fold-anon v='false'/>
08:28:45:  <idle-seconds v='300'/>
08:28:45:  <open-web-control v='false'/>
08:28:45:  <update-gpus-txt v='true'/>
08:28:45:
08:28:45:  <!-- Configuration -->
08:28:45:  <config-rotate v='true'/>
08:28:45:  <config-rotate-dir v='configs'/>
08:28:45:  <config-rotate-max v='16'/>
08:28:45:
08:28:45:  <!-- Debugging -->
08:28:45:  <assignment-servers>
08:28:45:    assign1.foldingathome.org assign2.foldingathome.org assign3.foldingathome.org assign4.foldingathome.org
08:28:45:  </assignment-servers>
08:28:45:  <auth-as v='true'/>
08:28:45:  <capture-directory v='capture'/>
08:28:45:  <capture-on-error v='false'/>
08:28:45:  <capture-packets v='false'/>
08:28:45:  <capture-requests v='false'/>
08:28:45:  <capture-responses v='false'/>
08:28:45:  <capture-sockets v='false'/>
08:28:45:  <debug-sockets v='false'/>
08:28:45:  <exception-locations v='true'/>
08:28:45:  <stack-traces v='false'/>
08:28:45:
08:28:45:  <!-- Error Handling -->
08:28:45:  <max-slot-errors v='10'/>
08:28:45:  <max-unit-errors v='5'/>
08:28:45:
08:28:45:  <!-- Folding Core -->
08:28:45:  <checkpoint v='15'/>
08:28:45:  <core-priority v='low'/>
08:28:45:  <cpu-usage v='100'/>
08:28:45:  <gpu-usage v='100'/>
08:28:45:  <no-assembly v='false'/>
08:28:45:
08:28:45:  <!-- Folding Slot Configuration -->
08:28:45:  <cause v='ANY'/>
08:28:45:  <client-subtype v='LINUX'/>
08:28:45:  <client-type v='normal'/>
08:28:45:  <cpu-species v='X86_PENTIUM_II'/>
08:28:45:  <cpu-type v='AMD64'/>
08:28:45:  <cpus v='-1'/>
08:28:45:  <disable-viz v='false'/>
08:28:45:  <gpu v='true'/>
08:28:45:  <gpu-beta v='false'/>
08:28:45:  <max-packet-size v='normal'/>
08:28:45:  <os-species v='UNKNOWN'/>
08:28:45:  <os-type v='LINUX'/>
08:28:45:  <project-key v='0'/>
08:28:45:  <smp v='true'/>
08:28:45:
08:28:45:  <!-- GUI -->
08:28:45:  <gui-enabled v='true'/>
08:28:45:
08:28:45:  <!-- HTTP Server -->
08:28:45:  <allow v='127.0.0.1'/>
08:28:45:  <connection-timeout v='60'/>
08:28:45:  <deny v='0/0'/>
08:28:45:  <http-addresses v='0:7396'/>
08:28:45:  <https-addresses v=''/>
08:28:45:  <max-connect-time v='900'/>
08:28:45:  <max-connections v='800'/>
08:28:45:  <max-request-length v='52428800'/>
08:28:45:  <min-connect-time v='300'/>
08:28:45:
08:28:45:  <!-- Logging -->
08:28:45:  <log v='log.txt'/>
08:28:45:  <log-color v='true'/>
08:28:45:  <log-crlf v='false'/>
08:28:45:  <log-date v='false'/>
08:28:45:  <log-date-periodically v='21600'/>
08:28:45:  <log-domain v='false'/>
08:28:45:  <log-header v='true'/>
08:28:45:  <log-level v='true'/>
08:28:45:  <log-no-info-header v='true'/>
08:28:45:  <log-redirect v='false'/>
08:28:45:  <log-rotate v='true'/>
08:28:45:  <log-rotate-dir v='logs'/>
08:28:45:  <log-rotate-max v='16'/>
08:28:45:  <log-short-level v='false'/>
08:28:45:  <log-simple-domains v='true'/>
08:28:45:  <log-thread-id v='false'/>
08:28:45:  <log-thread-prefix v='true'/>
08:28:45:  <log-time v='true'/>
08:28:45:  <log-to-screen v='true'/>
08:28:45:  <log-truncate v='false'/>
08:28:45:  <verbosity v='3'/>
08:28:45:
08:28:45:  <!-- Network -->
08:28:45:  <proxy v=':8080'/>
08:28:45:  <proxy-enable v='false'/>
08:28:45:  <proxy-pass v='*****'/>
08:28:45:  <proxy-user v=''/>
08:28:45:
08:28:45:  <!-- Process Control -->
08:28:45:  <child v='false'/>
08:28:45:  <daemon v='false'/>
08:28:45:  <fork v='false'/>
08:28:45:  <pid v='false'/>
08:28:45:  <pid-file v='FAHClient.pid'/>
08:28:45:  <respawn v='false'/>
08:28:45:  <service v='false'/>
08:28:45:
08:28:45:  <!-- Remote Command Server -->
08:28:45:  <command-address v='0.0.0.0'/>
08:28:45:  <command-allow-no-pass v='127.0.0.1'/>
08:28:45:  <command-deny-no-pass v='0/0'/>
08:28:45:  <command-enable v='true'/>
08:28:45:  <command-port v='36330'/>
08:28:45:
08:28:45:  <!-- Slot Control -->
08:28:45:  <auto-conf v='true'/>
08:28:45:  <idle v='false'/>
08:28:45:  <max-shutdown-wait v='60'/>
08:28:45:  <pause-on-battery v='true'/>
08:28:45:  <pause-on-start v='false'/>
08:28:45:  <paused v='false'/>
08:28:45:  <power v='full'/>
08:28:45:
08:28:45:  <!-- User Information -->
08:28:45:  <machine-id v='0'/>
08:28:45:  <passkey v='*****'/>
08:28:45:  <team v='10817'/>
08:28:45:  <user v='sptn.'/>
08:28:45:
08:28:45:  <!-- Web Server -->
08:28:45:  <web-allow v='127.0.0.1'/>
08:28:45:  <web-deny v='0/0'/>
08:28:45:  <web-enable v='true'/>
08:28:45:
08:28:45:  <!-- Web Server Sessions -->
08:28:45:  <session-cookie v='sid'/>
08:28:45:  <session-lifetime v='86400'/>
08:28:45:  <session-timeout v='3600'/>
08:28:45:
08:28:45:  <!-- Work Unit Control -->
08:28:45:  <dump-after-deadline v='true'/>
08:28:45:  <max-queue v='16'/>
08:28:45:  <max-units v='0'/>
08:28:45:  <next-unit-percentage v='99'/>
08:28:45:  <stall-detection-enabled v='false'/>
08:28:45:  <stall-percent v='5'/>
08:28:45:  <stall-timeout v='1800'/>
08:28:45:
08:28:45:  <!-- Folding Slots -->
08:28:45:  <slot id='0' type='CPU'/>
08:28:45:  <slot id='1' type='GPU'>
08:28:45:    <pci-bus v='1'/>
08:28:45:    <pci-slot v='0'/>
08:28:45:  </slot>
08:28:45:</config>
08:28:45:Trying to access database...
08:28:46:Successfully acquired database lock
08:28:46:FS00:Initialized folding slot 00: cpu:3 - READY
08:28:46:FS01:Initialized folding slot 01: gpu:1:0 GP106 [GeForce GTX 1060 3GB] 3935 - READY
08:28:46:WU02:FS00:Starting
08:28:46:WU02:FS00:Running FahCore: /snap/folding-at-home-fcole90/48/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/lin/64bit-sse2/a7-0.0.19/Core_a7.fah/FahCore_a7 -dir 02 -suffix 01 -version 706 -lifeline 773 -checkpoint 15 -np 3
08:28:46:WU02:FS00:Started FahCore on PID 978
08:28:46:WU02:FS00:Core PID:982
08:28:46:WU02:FS00:FahCore 0xa7 started
08:28:49:WU01:FS01:Starting
08:28:49:WU01:FS01:Running FahCore: /snap/folding-at-home-fcole90/48/usr/bin/FAHCoreWrapper /var/snap/folding-at-home-fcole90/common/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 773 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
08:28:49:WU01:FS01:Started FahCore on PID 999
08:28:49:WU01:FS01:Core PID:1003
08:28:49:WU01:FS01:FahCore 0x22 started
08:28:52:WU02:FS00:0xa7:*********************** Log Started 2020-11-12T08:28:52Z ***********************
08:28:52:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:28:52:WU02:FS00:0xa7:       Type: 0xa7
08:28:52:WU02:FS00:0xa7:       Core: Gromacs
08:28:52:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 978 -checkpoint 15 -np 3
08:28:52:WU02:FS00:0xa7:************************************ CBang *************************************
08:28:52:WU02:FS00:0xa7:       Date: Nov 27 2019
08:28:52:WU02:FS00:0xa7:       Time: 11:26:54
08:28:52:WU02:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
08:28:52:WU02:FS00:0xa7:     Branch: master
08:28:52:WU02:FS00:0xa7:   Compiler: GNU 8.3.0
08:28:52:WU02:FS00:0xa7:    Options: -std=c++11 -ffunction-sections -fdata-sections -O3 -funroll-loops
08:28:52:WU02:FS00:0xa7:             -fno-pie -fPIC
08:28:52:WU02:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
08:28:52:WU02:FS00:0xa7:       Bits: 64
08:28:52:WU02:FS00:0xa7:       Mode: Release
08:28:52:WU02:FS00:0xa7:************************************ System ************************************
08:28:52:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
08:28:52:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
08:28:52:WU02:FS00:0xa7:       CPUs: 4
08:28:52:WU02:FS00:0xa7:     Memory: 3.84GiB
08:28:52:WU02:FS00:0xa7:Free Memory: 3.14GiB
08:28:52:WU02:FS00:0xa7:    Threads: POSIX_THREADS
08:28:52:WU02:FS00:0xa7: OS Version: 5.4
08:28:52:WU02:FS00:0xa7:Has Battery: false
08:28:52:WU02:FS00:0xa7: On Battery: false
08:28:52:WU02:FS00:0xa7: UTC Offset: 1
08:28:52:WU02:FS00:0xa7:        PID: 982
08:28:52:WU02:FS00:0xa7:        CWD: /var/snap/folding-at-home-fcole90/common/work
08:28:52:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
08:28:52:WU02:FS00:0xa7:    Version: 0.0.19
08:28:52:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:28:52:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:28:52:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
08:28:52:WU02:FS00:0xa7:       Date: Nov 26 2019
08:28:52:WU02:FS00:0xa7:       Time: 00:41:43
08:28:52:WU02:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
08:28:52:WU02:FS00:0xa7:************************************ Build *************************************
08:28:52:WU02:FS00:0xa7:       SIMD: sse2
08:28:52:WU02:FS00:0xa7:********************************************************************************
08:28:52:WU02:FS00:0xa7:Project: 17201 (Run 0, Clone 221, Gen 452)
08:28:52:WU02:FS00:0xa7:Unit: 0x0000020180fccb0a5f32ff25e2d3633c
08:28:52:WU02:FS00:0xa7:Digital signatures verified
08:28:53:WU02:FS00:0xa7:Calling: mdrun -s frame452.tpr -o frame452.trr -x frame452.xtc -cpi state.cpt -cpt 15 -nt 3
08:29:00:WU01:FS01:0x22:*********************** Log Started 2020-11-12T08:28:59Z ***********************
08:29:00:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:29:00:WU01:FS01:0x22:       Core: Core22
08:29:00:WU01:FS01:0x22:       Type: 0x22
08:29:00:WU01:FS01:0x22:    Version: 0.0.13
08:29:00:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:29:00:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
08:29:00:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
08:29:00:WU01:FS01:0x22:       Date: Sep 19 2020
08:29:00:WU01:FS01:0x22:       Time: 01:10:35
08:29:00:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
08:29:00:WU01:FS01:0x22:     Branch: core22-0.0.13
08:29:00:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
08:29:00:WU01:FS01:0x22:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
08:29:00:WU01:FS01:0x22:             -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
08:29:00:WU01:FS01:0x22:   Platform: linux2 4.19.76-linuxkit
08:29:00:WU01:FS01:0x22:       Bits: 64
08:29:00:WU01:FS01:0x22:       Mode: Release
08:29:00:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
08:29:00:WU01:FS01:0x22:             <peastman@stanford.edu>
08:29:00:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 999 -checkpoint 15
08:29:00:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
08:29:00:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
08:29:00:WU01:FS01:0x22:************************************ libFAH ************************************
08:29:00:WU01:FS01:0x22:       Date: Sep 15 2020
08:29:00:WU01:FS01:0x22:       Time: 05:14:43
08:29:00:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
08:29:00:WU01:FS01:0x22:     Branch: HEAD
08:29:00:WU01:FS01:0x22:************************************ CBang *************************************
08:29:00:WU01:FS01:0x22:       Time: 05:11:04
08:29:00:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
08:29:00:WU01:FS01:0x22:             -funroll-loops -fPIC
08:29:00:WU01:FS01:0x22:************************************ System ************************************
08:29:00:WU01:FS01:0x22:        CPU: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
08:29:00:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
08:29:00:WU01:FS01:0x22:       CPUs: 4
08:29:00:WU01:FS01:0x22:     Memory: 3.84GiB
08:29:00:WU01:FS01:0x22:Free Memory: 3.11GiB
08:29:00:WU01:FS01:0x22:    Threads: POSIX_THREADS
08:29:00:WU01:FS01:0x22: OS Version: 5.4
08:29:00:WU01:FS01:0x22:Has Battery: false
08:29:00:WU01:FS01:0x22: On Battery: false
08:29:00:WU01:FS01:0x22: UTC Offset: 1
08:29:00:WU01:FS01:0x22:        PID: 1003
08:29:00:WU01:FS01:0x22:        CWD: /var/snap/folding-at-home-fcole90/common/work
08:29:00:WU01:FS01:0x22:************************************ OpenMM ************************************
08:29:00:WU01:FS01:0x22:   Revision: 189320d0
08:29:00:WU01:FS01:0x22:********************************************************************************
08:29:00:WU01:FS01:0x22:Project: 17424 (Run 0, Clone 1242, Gen 5)
08:29:00:WU01:FS01:0x22:Unit: 0x00000006cedfaa9200000000000004da
08:29:00:WU01:FS01:0x22:Digital signatures verified
08:29:00:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:29:00:WU01:FS01:0x22:Version 0.0.13
08:29:00:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
08:29:00:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
08:29:00:WU01:FS01:0x22:  XTC frame write interval: 10000 steps (0.8%) [125 total]
08:29:00:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
08:29:01:WU02:FS00:0xa7:Steps: first=113000000 total=250000
08:29:10:WU02:FS00:0xa7:Completed 134562 out of 250000 steps (53%)
08:29:16:WU01:FS01:0x22:There are 4 platforms available.
08:29:16:WU01:FS01:0x22:Platform 0: Reference
08:29:16:WU01:FS01:0x22:Platform 1: CPU
08:29:16:WU01:FS01:0x22:Platform 2: OpenCL
08:29:16:WU01:FS01:0x22:  opencl-device 0 specified
08:29:16:WU01:FS01:0x22:Platform 3: CUDA
08:29:16:WU01:FS01:0x22:  cuda-device 0 specified
08:29:35:WU01:FS01:0x22:Attempting to create CUDA context:
08:29:35:WU01:FS01:0x22:  Configuring platform CUDA
sptn.
Post by sptn. »
I found someone who had the same problem on a Linux machine in this Thread: https://foldingforum.org/viewtopic.php? ... ey#p345045
In the FAH FAQ I read, that simply adding the passkey into the xml file may corrupt it. How would be the correct way to do it?
Knish
Post by Knish »
FAHClient --send-command "options passkey=xxxxxxxxxxxxxxxxx"
Please reduce the logging level back to 3 the default so that only the changes in default values are shown. Anything higher than 3 doesn't help out in 99.99%
sptn.
Post by sptn. »
Knish wrote:FAHClient --send-command "options passkey=xxxxxxxxxxxxxxxxx"
Is this command to be performed in the terminal? I guess so..
PantherX wrote:Please reduce the logging level back to 3 the default so that only the changes in default values are shown. Anything higher than 3 doesn't help out in 99.99%
Oh okay, can not remember that I changed this. Thanks for the advice
sptn. wrote:I found the problem why the Bonus does not kick in....
Did you use FAHControl to enter the passkey? If not, there's every reason to beleive you did not enter it successfull
Passing it as a command-line parameter works. So does a FAHControl edit of your config.xml.
In any case, there will be no bonus until that User:Passkey has successfully completed 10 WU (no matter how many clients use that pair).
