I am trying to figure out if F@H want my CPU cycles or not as there appears to be a severe shortage of CPU WU's.
I have a 3950X with 24 threads assigned to F@H sitting here idle doing nuffink...
Shortage of CPU WU's
Re: Shortage of CPU WU's
Do not panic. This will be resolved soon, as I believe that some of the servers are being upgraded/updated.
One of the project managers, who will have better information than I do will post an update when one is available.
In the meanwhile, I'm getting ready to do a Fedora OS update on 3 of my systems within the next 24-30 hours, so you might get a few that I won't be running during that time.
Paul
Paul
Yep, there's still a real need of CPUs... it's just unfortunate timing of lack of CPU Projects due to Server upgrades/issues plus researchers who are finishing up and new researchers who are coming on-board. The fall time (in Northern hemisphere) is generally when staff turn over happens which can have an impact on Project availability.
Not only am I not receiving CPU WU's for my 3900X to process, sever 155.247.166.220 is not receiving the 7 Project 16918 WU's that my Graphics card has processed overnight.
Colonel_Klink
RTX 2080 Super
AMD Ryzen 9 3900X
RTX 2080 Super
AMD Ryzen 9 3900X
155.247.166.220 looking to be up and assigning/receiving - not a huge amount of disk space being reported but a couple of terabytes is usually enough not to have issues there ... I hope this won't be a reoccurrence of the issues you've had previously with returning WUs as iirc we didn't get that resolved as such it just went away? ... Lets see if anyone else is having issues - I'll check the logs from my kit and see if I've had any from this server (appears not but my throughput of gpu wus is low).
@Neil-B Thanks for remembering. Yes you are right the problem went away for the most part. Occasionally I'll see one or two WU's waiting for the 66.170.000.50 server but over past couple of weeks none have been waithing for more an few hours. And until this morning I'd haven't had any backed up for a week. Had a string of days over 3M PPD, then the CPU shortage hit and to get any CPU WU's I had to reconfigure from one CPU slot of 21 cores to 2 Slots of 10, and that worked from Friday to Sunday, now no CPU WUs for almost 24 hours. The GPU keeps picking up new work but the ones from Project 16918 are not being uploaded.
This is a snipit of the latest few failures for one that has tried 51 times so far,
The same set of comments over and over.
15:43:40:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
15:43:40:WU03:FS01:Connecting to 130.237.11.145:80
15:44:01:ERROR:WU03:FS01:Exception: Failed to connect to 130.237.11.145:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:42:31:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:16918 run:165 clone:142 gen:5 core:0x22 unit:0x000000050002894c5f17616ee39e74e1
16:42:31:WU03:FS01:Uploading 15.35MiB to 155.247.166.220
16:42:31:WU03:FS01:Connecting to 155.247.166.220:8080
16:42:37:WU03:FS01:Upload 35.83%
16:42:45:WU03:FS01:Upload 57.41%
16:44:00:WU03:FS01:Upload 57.82%
16:44:00:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
16:44:00:WU03:FS01:Trying to send results to collection server
16:44:00:WU03:FS01:Uploading 15.35MiB to 130.237.11.145
16:44:00:WU03:FS01:Connecting to 130.237.11.145:8080
16:44:21:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
16:44:21:WU03:FS01:Connecting to 130.237.11.145:80
16:44:42:ERROR:WU03:FS01:Exception: Failed to connect to 130.237.11.145:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:42:31:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:16918 run:165 clone:142 gen:5 core:0x22 unit:0x000000050002894c5f17616ee39e74e1
17:42:31:WU03:FS01:Uploading 15.35MiB to 155.247.166.220
17:42:31:WU03:FS01:Connecting to 155.247.166.220:8080
17:42:40:WU03:FS01:Upload 28.91%
17:43:26:WU03:FS01:Upload 29.31%
17:43:26:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
17:43:26:WU03:FS01:Trying to send results to collection server
17:43:26:WU03:FS01:Uploading 15.35MiB to 130.237.11.145
17:43:26:WU03:FS01:Connecting to 130.237.11.145:8080
17:43:47:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
17:43:47:WU03:FS01:Connecting to 130.237.11.145:80
17:44:09:ERROR:WU03:FS01:Exception: Failed to connect to 130.237.11.145:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:42:31:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:16918 run:165 clone:142 gen:5 core:0x22 unit:0x000000050002894c5f17616ee39e74e1
18:42:32:WU03:FS01:Uploading 15.35MiB to 155.247.166.220
18:42:32:WU03:FS01:Connecting to 155.247.166.220:8080
18:42:40:WU03:FS01:Upload 25.24%
18:43:14:WU03:FS01:Upload 25.65%
18:43:15:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
18:43:15:WU03:FS01:Trying to send results to collection server
18:43:15:WU03:FS01:Uploading 15.35MiB to 130.237.11.145
18:43:15:WU03:FS01:Connecting to 130.237.11.145:8080
18:43:36:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
18:43:36:WU03:FS01:Connecting to 130.237.11.145:80
18:43:57:ERROR:WU03:FS01:Exception: Failed to connect to 130.237.11.145:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Colonel_Klink
RTX 2080 Super
AMD Ryzen 9 3900X
RTX 2080 Super
AMD Ryzen 9 3900X
I am not sure where to post this. It seems to cover the waterfront.
14:14:40:WU00:FS00:0xa8:*********************** Log Started 2020-11-06T14:14:39Z ***********************
14:14:40:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:14:40:WU00:FS00:0xa8: Core: Gromacs
14:14:40:WU00:FS00:0xa8: Type: 0xa8
14:14:40:WU00:FS00:0xa8: Version: 0.0.9
14:14:40:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:14:40:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
14:14:40:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
14:14:40:WU00:FS00:0xa8: Date: Oct 28 2020
14:14:40:WU00:FS00:0xa8: Time: 22:15:07
14:14:40:WU00:FS00:0xa8: Compiler: GNU 8.3.0
14:14:40:WU00:FS00:0xa8: Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
14:14:40:WU00:FS00:0xa8: -fdata-sections -O3 -funroll-loops -fno-pie
14:14:40:WU00:FS00:0xa8: Platform: linux2 4.15.0-108-generic
14:14:40:WU00:FS00:0xa8: Bits: 64
14:14:40:WU00:FS00:0xa8: Mode: Release
14:14:40:WU00:FS00:0xa8: SIMD: avx2_256
14:14:40:WU00:FS00:0xa8: OpenMP: ON
14:14:40:WU00:FS00:0xa8: CUDA: OFF
14:14:40:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 14264 -checkpoint 15 -np
14:14:40:WU00:FS00:0xa8: 10
14:14:40:WU00:FS00:0xa8:************************************ libFAH ************************************
14:14:40:WU00:FS00:0xa8: Time: 22:12:00
14:14:40:WU00:FS00:0xa8:************************************ CBang *************************************
14:14:40:WU00:FS00:0xa8: Time: 22:11:46
14:14:40:WU00:FS00:0xa8: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
14:14:40:WU00:FS00:0xa8:************************************ System ************************************
14:14:40:WU00:FS00:0xa8: CPU: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
14:14:40:WU00:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
14:14:40:WU00:FS00:0xa8: CPUs: 12
14:14:40:WU00:FS00:0xa8: Memory: 15.57GiB
14:14:40:WU00:FS00:0xa8:Free Memory: 8.32GiB
14:14:40:WU00:FS00:0xa8: Threads: POSIX_THREADS
14:14:40:WU00:FS00:0xa8: OS Version: 5.4
14:14:40:WU00:FS00:0xa8:Has Battery: false
14:14:40:WU00:FS00:0xa8: On Battery: false
14:14:40:WU00:FS00:0xa8: UTC Offset: -5
14:14:40:WU00:FS00:0xa8: PID: 14268
14:14:40:WU00:FS00:0xa8: CWD: /var/lib/fahclient/work
14:14:40:WU00:FS00:0xa8:********************************************************************************
14:14:40:WU00:FS00:0xa8:Project: 16926 (Run 0, Clone 8564, Gen 9)
14:14:40:WU00:FS00:0xa8:Unit: 0x000000098120d1cc5fa22aa0074f36b1
14:14:40:WU00:FS00:0xa8:Reading tar file core.xml
14:14:40:WU00:FS00:0xa8:Reading tar file frame9.tpr
14:14:40:WU00:FS00:0xa8:Digital signatures verified
14:14:40:WU00:FS00:0xa8:Calling: mdrun -c frame9.gro -s frame9.tpr -x frame9.xtc -cpt 15 -nt 10 -ntmpi 1
14:14:40:WU00:FS00:0xa8:Steps: first=450000000 total=500000000
14:14:40:WU00:FS00:0xa8:Completed 1 out of 50000000 steps (0%)
14:15:50:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 129.213.40.229:80: Connection timed out
14:15:50:WU01:FS00:Trying to send results to collection server
14:15:50:WU01:FS00:Uploading 6.15MiB to 150.136.14.110
14:15:50:WU01:FS00:Connecting to 150.136.14.110:8080
14:15:53:WU01:FS00:Upload complete
14:15:53:WU01:FS00:Server responded WORK_ACK (400)
14:15:53:WU01:FS00:Final credit estimate, 13557.00 points
14:15:53:WU01:FS00:Cleaning up
14:16:10:WU00:FS00:0xa8:Completed 500000 out of 50000000 steps (1%)
14:17:40:WU00:FS00:0xa8:Completed 1000000 out of 50000000 steps (2%)
14:19:11:WU00:FS00:0xa8:Completed 1500000 out of 50000000 steps (3%)
14:20:41:WU00:FS00:0xa8:Completed 2000000 out of 50000000 steps (4%)
14:22:12:WU00:FS00:0xa8:Completed 2500000 out of 50000000 steps (5%)
14:23:43:WU00:FS00:0xa8:Completed 3000000 out of 50000000 steps (6%)
14:25:13:WU00:FS00:0xa8:Completed 3500000 out of 50000000 steps (7%)
14:26:44:WU00:FS00:0xa8:Completed 4000000 out of 50000000 steps (8%)
14:28:15:WU00:FS00:0xa8:Completed 4500000 out of 50000000 steps (9%)
14:29:46:WU00:FS00:0xa8:Completed 5000000 out of 50000000 steps (10%)
14:31:16:WU00:FS00:0xa8:Completed 5500000 out of 50000000 steps (11%)
14:32:47:WU00:FS00:0xa8:Completed 6000000 out of 50000000 steps (12%)
14:34:17:WU00:FS00:0xa8:Completed 6500000 out of 50000000 steps (13%)
14:35:48:WU00:FS00:0xa8:Completed 7000000 out of 50000000 steps (14%)
14:37:19:WU00:FS00:0xa8:Completed 7500000 out of 50000000 steps (15%)
14:38:49:WU00:FS00:0xa8:Completed 8000000 out of 50000000 steps (16%)
14:40:20:WU00:FS00:0xa8:Completed 8500000 out of 50000000 steps (17%)
14:41:51:WU00:FS00:0xa8:Completed 9000000 out of 50000000 steps (18%)
14:43:22:WU00:FS00:0xa8:Completed 9500000 out of 50000000 steps (19%)
14:44:52:WU00:FS00:0xa8:Completed 10000000 out of 50000000 steps (20%)
14:46:22:WU00:FS00:0xa8:Completed 10500000 out of 50000000 steps (21%)
14:47:53:WU00:FS00:0xa8:Completed 11000000 out of 50000000 steps (22%)
14:49:24:WU00:FS00:0xa8:Completed 11500000 out of 50000000 steps (23%)
14:50:54:WU00:FS00:0xa8:Completed 12000000 out of 50000000 steps (24%)
14:52:25:WU00:FS00:0xa8:Completed 12500000 out of 50000000 steps (25%)
14:53:56:WU00:FS00:0xa8:Completed 13000000 out of 50000000 steps (26%)
14:55:27:WU00:FS00:0xa8:Completed 13500000 out of 50000000 steps (27%)
14:56:57:WU00:FS00:0xa8:Completed 14000000 out of 50000000 steps (28%)
14:58:28:WU00:FS00:0xa8:Completed 14500000 out of 50000000 steps (29%)
14:59:58:WU00:FS00:0xa8:Completed 15000000 out of 50000000 steps (30%)
15:01:28:WU00:FS00:0xa8:Completed 15500000 out of 50000000 steps (31%)
15:02:59:WU00:FS00:0xa8:Completed 16000000 out of 50000000 steps (32%)
15:04:30:WU00:FS00:0xa8:Completed 16500000 out of 50000000 steps (33%)
15:06:00:WU00:FS00:0xa8:Completed 17000000 out of 50000000 steps (34%)
15:07:30:WU00:FS00:0xa8:Completed 17500000 out of 50000000 steps (35%)
15:09:01:WU00:FS00:0xa8:Completed 18000000 out of 50000000 steps (36%)
15:10:32:WU00:FS00:0xa8:Completed 18500000 out of 50000000 steps (37%)
15:12:02:WU00:FS00:0xa8:Completed 19000000 out of 50000000 steps (38%)
15:13:33:WU00:FS00:0xa8:Completed 19500000 out of 50000000 steps (39%)
15:15:04:WU00:FS00:0xa8:Completed 20000000 out of 50000000 steps (40%)
15:16:34:WU00:FS00:0xa8:Completed 20500000 out of 50000000 steps (41%)
15:18:05:WU00:FS00:0xa8:Completed 21000000 out of 50000000 steps (42%)
15:19:36:WU00:FS00:0xa8:Completed 21500000 out of 50000000 steps (43%)
15:21:06:WU00:FS00:0xa8:Completed 22000000 out of 50000000 steps (44%)
15:22:37:WU00:FS00:0xa8:Completed 22500000 out of 50000000 steps (45%)
15:24:08:WU00:FS00:0xa8:Completed 23000000 out of 50000000 steps (46%)
15:25:38:WU00:FS00:0xa8:Completed 23500000 out of 50000000 steps (47%)
15:27:09:WU00:FS00:0xa8:Completed 24000000 out of 50000000 steps (48%)
15:28:40:WU00:FS00:0xa8:Completed 24500000 out of 50000000 steps (49%)
15:30:10:WU00:FS00:0xa8:Completed 25000000 out of 50000000 steps (50%)
15:31:41:WU00:FS00:0xa8:Completed 25500000 out of 50000000 steps (51%)
15:33:12:WU00:FS00:0xa8:Completed 26000000 out of 50000000 steps (52%)
15:34:43:WU00:FS00:0xa8:Completed 26500000 out of 50000000 steps (53%)
15:36:13:WU00:FS00:0xa8:Completed 27000000 out of 50000000 steps (54%)
15:37:44:WU00:FS00:0xa8:Completed 27500000 out of 50000000 steps (55%)
15:39:15:WU00:FS00:0xa8:Completed 28000000 out of 50000000 steps (56%)
15:40:46:WU00:FS00:0xa8:Completed 28500000 out of 50000000 steps (57%)
15:42:16:WU00:FS00:0xa8:Completed 29000000 out of 50000000 steps (58%)
15:43:47:WU00:FS00:0xa8:Completed 29500000 out of 50000000 steps (59%)
15:45:17:WU00:FS00:0xa8:Completed 30000000 out of 50000000 steps (60%)
15:46:48:WU00:FS00:0xa8:Completed 30500000 out of 50000000 steps (61%)
15:48:19:WU00:FS00:0xa8:Completed 31000000 out of 50000000 steps (62%)
15:49:49:WU00:FS00:0xa8:Completed 31500000 out of 50000000 steps (63%)
15:51:20:WU00:FS00:0xa8:Completed 32000000 out of 50000000 steps (64%)
15:52:50:WU00:FS00:0xa8:Completed 32500000 out of 50000000 steps (65%)
15:54:21:WU00:FS00:0xa8:Completed 33000000 out of 50000000 steps (66%)
15:55:51:WU00:FS00:0xa8:Completed 33500000 out of 50000000 steps (67%)
15:57:22:WU00:FS00:0xa8:Completed 34000000 out of 50000000 steps (68%)
15:58:53:WU00:FS00:0xa8:Completed 34500000 out of 50000000 steps (69%)
16:00:24:WU00:FS00:0xa8:Completed 35000000 out of 50000000 steps (70%)
16:01:54:WU00:FS00:0xa8:Completed 35500000 out of 50000000 steps (71%)
16:03:25:WU00:FS00:0xa8:Completed 36000000 out of 50000000 steps (72%)
16:04:56:WU00:FS00:0xa8:Completed 36500000 out of 50000000 steps (73%)
16:06:27:WU00:FS00:0xa8:Completed 37000000 out of 50000000 steps (74%)
16:07:57:WU00:FS00:0xa8:Completed 37500000 out of 50000000 steps (75%)
16:09:28:WU00:FS00:0xa8:Completed 38000000 out of 50000000 steps (76%)
16:10:59:WU00:FS00:0xa8:Completed 38500000 out of 50000000 steps (77%)
16:12:29:WU00:FS00:0xa8:Completed 39000000 out of 50000000 steps (78%)
16:14:00:WU00:FS00:0xa8:Completed 39500000 out of 50000000 steps (79%)
16:15:31:WU00:FS00:0xa8:Completed 40000000 out of 50000000 steps (80%)
16:17:02:WU00:FS00:0xa8:Completed 40500000 out of 50000000 steps (81%)
16:18:33:WU00:FS00:0xa8:Completed 41000000 out of 50000000 steps (82%)
16:20:03:WU00:FS00:0xa8:Completed 41500000 out of 50000000 steps (83%)
16:21:34:WU00:FS00:0xa8:Completed 42000000 out of 50000000 steps (84%)
16:23:05:WU00:FS00:0xa8:Completed 42500000 out of 50000000 steps (85%)
16:24:35:WU00:FS00:0xa8:Completed 43000000 out of 50000000 steps (86%)
16:26:06:WU00:FS00:0xa8:Completed 43500000 out of 50000000 steps (87%)
16:27:37:WU00:FS00:0xa8:Completed 44000000 out of 50000000 steps (88%)
16:29:07:WU00:FS00:0xa8:Completed 44500000 out of 50000000 steps (89%)
16:30:37:WU00:FS00:0xa8:Completed 45000000 out of 50000000 steps (90%)
16:32:08:WU00:FS00:0xa8:Completed 45500000 out of 50000000 steps (91%)
16:33:39:WU00:FS00:0xa8:Completed 46000000 out of 50000000 steps (92%)
16:35:10:WU00:FS00:0xa8:Completed 46500000 out of 50000000 steps (93%)
16:36:40:WU00:FS00:0xa8:Completed 47000000 out of 50000000 steps (94%)
16:38:11:WU00:FS00:0xa8:Completed 47500000 out of 50000000 steps (95%)
16:39:42:WU00:FS00:0xa8:Completed 48000000 out of 50000000 steps (96%)
16:41:12:WU00:FS00:0xa8:Completed 48500000 out of 50000000 steps (97%)
16:42:43:WU00:FS00:0xa8:Completed 49000000 out of 50000000 steps (98%)
16:44:14:WU00:FS00:0xa8:Completed 49500000 out of 50000000 steps (99%)
16:44:14:WU01:FS00:Connecting to 65.254.110.245:80
16:44:14:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:44:14:WU01:FS00:Connecting to 18.218.241.186:80
16:44:15:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:44:15:WU01:FS00:Connecting to 65.254.110.245:80
16:44:15:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:44:15:WU01:FS00:Connecting to 18.218.241.186:80
16:44:15:ERROR:WU01:FS00:Exception: Could not get an assignment
16:44:16:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:44:16:WU01:FS00:Connecting to 18.218.241.186:80
16:44:16:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:44:16:WU01:FS00:Connecting to 65.254.110.245:80
16:44:16:ERROR:WU01:FS00:Exception: Could not get an assignment
16:45:15:WU01:FS00:Connecting to 65.254.110.245:80
16:45:16:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:45:16:WU01:FS00:Connecting to 18.218.241.186:80
16:45:16:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:45:16:WU01:FS00:Connecting to 65.254.110.245:80
16:45:16:ERROR:WU01:FS00:Exception: Could not get an assignment
16:45:44:WU00:FS00:0xa8:Completed 50000000 out of 50000000 steps (100%)
16:45:44:WU00:FS00:0xa8:Saving result file ../logfile_01.txt
16:45:44:WU00:FS00:0xa8:Saving result file frame9.gro
16:45:44:WU00:FS00:0xa8:Saving result file frame9.xtc
16:45:44:WU00:FS00:0xa8:Saving result file md.log
16:45:44:WU00:FS00:0xa8:Saving result file science.log
16:45:44:WU00:FS00:0xa8:Saving result file state.cpt
16:45:44:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
16:45:44:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:45:44:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16926 run:0 clone:8564 gen:9 core:0xa8 unit:0x000000098120d1cc5fa22aa0074f36b1
16:45:44:WU00:FS00:Uploading 972.00KiB to 129.32.209.204
16:45:44:WU00:FS00:Connecting to 129.32.209.204:8080
16:45:45:WU00:FS00:Upload complete
16:45:45:WU00:FS00:Server responded WORK_ACK (400)
16:45:45:WU00:FS00:Final credit estimate, 22116.00 points
16:45:45:WU00:FS00:Cleaning up
16:46:53:WU01:FS00:Connecting to 65.254.110.245:80
16:46:53:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:46:53:WU01:FS00:Connecting to 18.218.241.186:80
16:46:53:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:46:54:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:46:54:WU01:FS00:Connecting to 18.218.241.186:80
16:46:54:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:46:54:ERROR:WU01:FS00:Exception: Could not get an assignment
16:49:30:WU01:FS00:Connecting to 65.254.110.245:80
16:49:30:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:49:30:WU01:FS00:Connecting to 18.218.241.186:80
16:49:30:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:49:31:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:49:31:WU01:FS00:Connecting to 18.218.241.186:80
16:49:31:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:49:31:ERROR:WU01:FS00:Exception: Could not get an assignment
16:53:44:WU01:FS00:Connecting to 65.254.110.245:80
16:53:44:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:53:44:WU01:FS00:Connecting to 18.218.241.186:80
16:53:45:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:53:45:WU01:FS00:Connecting to 65.254.110.245:80
16:53:45:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:53:45:WU01:FS00:Connecting to 18.218.241.186:80
16:53:45:ERROR:WU01:FS00:Exception: Could not get an assignment
17:00:36:WU01:FS00:Connecting to 65.254.110.245:80
17:00:36:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:00:36:WU01:FS00:Connecting to 18.218.241.186:80
17:00:36:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:00:37:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:00:37:ERROR:WU01:FS00:Exception: Could not get an assignment
More FahCore_a8 Projects were released to Beta so hopefully, they can be released to Full soon to ease the CPU WU shortage
